Question: Resize plots with legends and export
Hello everyone,
I'm trying to generate plots in Maple so that I can export the image and be easily read in a document. I usually use the plots [display] command as I often reuse "subplots". The main problem appears when entering a legend, as it disrupts the proportions and I have to rescale everything manually. In doing so I sometimes get small, hard-to-read images or captions. Is there any way to resize the image and caption other than manually? Even better, is there a way to scale both to a certain image size and to make the caption legible at that size (e.g. image 7 cm wide and font equivalent to 10 pt in Word)?
Thank you so much in advance
