Question: Writing a procedure
EDİT:
I wrote a procedure in order to add the legends inside plots as follows:
newlegend:=proc(f::algebraic,g::algebraic,x_left,x_right)
local A,B,location,y_min,y_max,L1,L2,rect,T,F,G:
y_min:=min(minimize(f,x=x_left..x_right),minimize(g,x=x_left..x_right));
y_max:=max(maximize(f,x=x_left..x_right),maximize(g,x=x_left..x_right));
F:=unapply(f,x):
G:=unapply(g,x):
L1, L2:=plottools:-line([x_left,0.9*y_max],[x_left+abs(x_right-x_left)/15,0.9*y_max],color=red), plottools:-line([x_left,0.7*y_max],[x_left+abs(x_right-x_left)/15,0.7*y_max],color=blue):
rect:=plottools:-rectangle([x_left,y_max-abs(y_max-y_min)/3],[x_left+abs(x_left+x_right)/4,y_max],color=cyan);
T:=plots:-textplot([[x_left+abs(x_right-x_left)/9,0.9*y_max,f],[abs(x_left+x_right)/9,0.7*y_max,g]]):
A:=plot(F(x), x=x_left..x_right, style=line, color=red   ):
B:=plot(G(x), x=x_left..x_right, style=line,  color=blue  ):
plots:-display(A, B, L1, L2, T,rect,  scaling=constrained, size=[800,300],axes=boxed);
newlegend(sin(x),cos(x),0,2*3.14)
Question 1: The lines behind the cyan rectangle seem. How to make the rectangle opaque?
Question 2:  Could you help me improving the procedure? Because I have bad results for some functions.
For example;
newlegend(exp(x),x,0,3)
Some Suggestions:
  • If we add an option to change the location of the legends like 'northeast' or 'southwest' etc, it will be a really good procedure.
  • If we add an option to remove the rectangular like "rectangular=off", it will be great.
If you share your valuable ideas and comments, I will be very glad.
