Question: Special characters in Maple workbook code
Special characters like æ,ø,å are causing some troubles when used in Maple Code attachments in workbooks.
I've managed to get around the problem by using HTML equivalents in the first run, but then this will cause problems when exporting the same strings to Excel.
Funnily this problem just arises in Workbooks, not when using the same code in a code edit region.
Special.zip
