Question: Can I save imported data into a variable so I don't have to execute the import command everytime I open the worksheet?
Setup:
I am working with a 'large' data set( ~70MB .csv file).  Using the import command I can import the data into a maple worksheet.  After import the dimension of the imported object 434000 rows by 30 columns.  The first 2 columns contain time stamp strings, the rest are numeric.
Issue:
Importing this data set takes about 5 minutes everytime the command is called, which is everytime the worksheet is opened or re executed.  This is a lot of redundent processing.
Question:
Is there a way that I can import the data once and have it saved as a variable in the variable manager associated with the worksheet?  I want to avoid using the import command in a reduent manner.
