Question: densityplot legend
I am using the following (dummy) code to generate a density plot.
densityplot(x-y^2, x=-5..5, y=-5..5, axes=boxed, style=patchnogrid, numpoints=1000, legendstyle=[location=bottom], labels=[x, y]);
While this command does generate x vs y plots with varying color shared, I cannot figure out where the function (x-y^2) value by looking at the color shades. Is there a way to produce a legend along with the plot that will demonstrate how the function is taking different values with parameters?
I found a similar post, dated 2005, that suggests using the "s_tyle=" command. However, it does not work for some reasons. I would appreciate help in this regard.
Thank you,
Omkar
