Question: How to integrate this ode and how to substitue this boundary value
The example below is an attempt to solve a boundary value problem (BVP) without manually replacing terms in expressions and some questions where there might be room for improvement. (Only the first integration step is shown to keep it short)
My objective is to have clean Maple input with minimal manual interventions or low-level manipulations (such as using op and similar commands).
ode := diff(phi(s), s, s)+K*cos(phi(s)) = 0
diff(diff(phi(s), s), s)+K*cos(phi(s)) = 0
map(int, ode, s)
int(diff(diff(phi(s), s), s)+K*cos(phi(s)), s) = 0
Student[ODEs]:-Integrate(ode, phi(s))
Error, (in assuming) when calling 'Student:-ODEs:-Integrate'. Received: 'The given ODE, diff(diff(phi(s),s),s)+K*cos(phi(s)) = 0, is not exact'
...not a clue for me
Since I know the result: Multiplying by diff(phi(x), x) to make integration work.  Q1: Are there other ways to integrate a single step without a priori knowledge?
(diff(phi(s), s))*ode
(diff(phi(s), s))*(diff(diff(phi(s), s), s)+K*cos(phi(s))) = 0
int(lhs((diff(phi(s), s))*(diff(diff(phi(s), s), s)+K*cos(phi(s))) = 0), s)+c__1 = 0
(1/2)*(diff(phi(s), s))^2+K*sin(phi(s))+c__1 = 0
Boundary condition for s = L
Eval(diff(phi(s), s), s = L) = `φ'`[0]
(4) evaluated at the boundary
expand(map(Eval, (1/2)*(diff(phi(s), s))^2+K*sin(phi(s))+c__1 = 0, s = L))
Eval((1/2)*(diff(phi(s), s))^2, {s = L})+Eval(K*sin(phi(s)), {s = L})+c__1 = Eval(0, s = L)
Q2: How to simplify expression (6) with (5) using Maple commands to get this expression for the integration constant
c__1 = -(1/2)*`φ'`[0]^2-K*sin(Eval(phi(s), s = L))
Some attempts
algsubs(Eval(diff(phi(s), s), s = L) = `φ'`[0], Eval((1/2)*(diff(phi(s), s))^2, {s = L})+Eval(K*sin(phi(s)), {s = L})+c__1 = Eval(0, s = L)); applyrule(Eval(diff(phi(s), s), s = L) = `φ'`[0], Eval((1/2)*(diff(phi(s), s))^2, {s = L})+Eval(K*sin(phi(s)), {s = L})+c__1 = Eval(0, s = L)); simplify(Eval((1/2)*(diff(phi(s), s))^2, {s = L})+Eval(K*sin(phi(s)), {s = L})+c__1 = Eval(0, s = L), {Eval(diff(phi(s), s), s = L) = `φ'`[0]}); Physics:-Substitute(Eval(diff(phi(s), s), s = L) = `φ'`[0], Eval((1/2)*(diff(phi(s), s))^2, {s = L})+Eval(K*sin(phi(s)), {s = L})+c__1 = Eval(0, s = L))
map(`^`, Eval(diff(phi(s), s), s = L) = `φ'`[0], 2)
(Eval(diff(phi(s), s), s = L))^2 = `φ'`[0]^2
Doing it manually
isolate(subs({Eval(0, s = L) = 0, Eval((1/2)*(diff(phi(s), s))^2, {s = L}) = (1/2)*`φ'`[0]^2}, Eval((1/2)*(diff(phi(s), s))^2, {s = L})+Eval(K*sin(phi(s)), {s = L})+c__1 = Eval(0, s = L)), c__1)
c__1 = -(1/2)*`φ'`[0]^2-(Eval(K*sin(phi(s)), {s = L}))
or
isolate(algsubs(value(Eval(diff(phi(s), s), s = L) = `φ'`[0]), value(Eval((1/2)*(diff(phi(s), s))^2, {s = L})+Eval(K*sin(phi(s)), {s = L})+c__1 = Eval(0, s = L))), c__1)
c__1 = -(1/2)*`φ'`[0]^2-K*sin(phi(L))
subs(phi(L) = Eval(phi(s), s = L), c__1 = -(1/2)*`φ'`[0]^2-(Eval(K*sin(phi(s)), {s = L})))
Q3: Are there ways to prevent commands evaluating Eval(phi(s), s = L)to phi(L)which might suggest incorrectly a new independent variable?
Q4: In (6), why is s = L sometimes in brackets {} ?
Download BVP_with_questions.mw
