Question: looking help for streamline by using dsolve or numeric method
I am trying to draw the streamline for my coupled system but do not get the outcome. Could anyone please help in this regard?
Detail: My system contains x and y;  Regrading x=0, if I do not assign it to zero, do not get the results. Otherwise, there is no need to put x=0 because I am interested in plotting stream plots between y and x (y on the vertical axis and x on the horizontal axis). Besides this, I solved this system analytically, then considered the stream function, did some steps, and plotted the streamline. It is different from the stream function, which has been obtained directly by using the numeric method. I have assigned the values to the parameters that I used during the analytical plot. I put x=0 and did not get the answer. Besides,  I am uploading the graph as a reference, which I have obtained by considering the stream function. This plot is similar to my flow direction, and I expect the same results from the numeric method.
streamline_Help.mw
