Question: How to: Define parameters -> Run script -> output data -> repeat step 1 for a lot of steps and different parameters
In my the script a determinant of a matrix is set equal to 0 and then solved for. This formula has infinite solutions. So i will find the second root with: Student:-Calculus1:-Roots(Y, N = 0 .. limit, numeric) . This gives me several solutions and then i pick the second one as this is the critical buckling load of the column with the current parameters.
Everytime i change a parameter i need to rerun a part of the script. I would like to generate a table where i define lets say parameter A and B and then run the script to give me value Ncr. then repeat this a 100 times with diferent parameters to see the influence of the parameters.
Ive been looking around but i am not able to figure this one out. I think something like this should be possible? Thank you very much in advance!
A B Ncr
0,1 0,1
0,1 0,5
0,1 1
0,5 0,1
0,5 0,5
0,5 1
1 0,1
1 0,5
1 1
