Question: Can't figure out how to turn off Typesetting Assistant
Not sure what  I did, but now  the typsetting rule assistant pops up every time I executre my document (twice!).  Searching the internet, I found that I should be able to turn it off by "expanding the blocks" (?) and then finding the call to this assistant.  Problem is, I can't find this "Expand block"  -- it is not under View it they claim it is in various posts.  Also, if I step through the worksheet, I can't find it ; it only pops up when I execute the entire worksheet.  I attached it here for someone to guide me on how to find where/why this is happening.
Thanks!coupled_network.mw
with(Syrup)
interface('displayprecision' = 4)
SyrupDefaults:-infolevel := 1; SyrupDefaults:-subscript_params := true
Circuit Netlist
ckt1
Definitions
Cp := 1/(`ω0p`^2*Lp)
1/(`ω0p`^2*Lp)
(1.2.1)
Cs := 1/(`ω0s`^2*Ls)
1/(`ω0s`^2*Ls)
(1.2.2)
M := k*sqrt(Ls*Lp)
k*(Ls*Lp)^(1/2)
(1.2.3)
assumptions := `and`(`and`(`and`(`and`(`and`(`and`(`ω0p` > 0, `ω0s` > 0), Lp > 0), Ls > 0), k > 0), Rp > 0), Rs > 0), omega > 0NULL
0 < `&omega;0p` and 0 < `&omega;0s` and 0 < Lp and 0 < Ls and 0 < k and 0 < Rp and 0 < Rs, 0 < omega
(1.2.4)
Simplifications
`&omega;0p` := `&omega;0p`
`&omega;0p`
(1.3.1)
`&omega;0s` := `&omega;0s`
`&omega;0s`
(1.3.2)
Rs := Rs
Rs
(1.3.3)
Rp := Rp
Rp
(1.3.4)
Lp := Lp
Lp
(1.3.5)
Ls := Ls
Ls
(1.3.6)
Not On Resonance
w := omega
omega
(1.3.1.1)
Solve System
sol, rest := `assuming`([Solve("ec:ckt1", analysis = ac, 'returnall')], [assumptions])
Solution
s := I*w
I*omega
(1.5.1)
vin := eval(v[N03], sol)
vin
(1.5.2)
Secondary Current
I2sol := `assuming`([simplify(eval(i[L2], rest))], [assumptions])
omega^3*k*Ls^(1/2)*Lp^(1/2)*vin/(Lp*Ls*(k-1)*(k+1)*omega^4+I*(Lp*Rs+Ls*Rp)*omega^3+(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega^2+I*(-Lp*Rs*`&omega;0p`^2-Ls*Rp*`&omega;0s`^2)*omega-Ls*Lp*`&omega;0p`^2*`&omega;0s`^2)
(1.5.3)
sol1 := solve(I2sol = I2, k)[1]
(1/2)*(Lp^(1/2)*Ls^(1/2)*vin*omega+(4*I2^2*Lp^2*Ls^2*omega^4-4*I2^2*Lp^2*Ls^2*omega^2*`&omega;0p`^2-4*I2^2*Lp^2*Ls^2*omega^2*`&omega;0s`^2+4*I2^2*Lp^2*Ls^2*`&omega;0p`^2*`&omega;0s`^2-(4*I)*I2^2*Lp^2*Ls*Rs*omega^3+(4*I)*I2^2*Lp^2*Ls*Rs*omega*`&omega;0p`^2-(4*I)*I2^2*Lp*Ls^2*Rp*omega^3+(4*I)*I2^2*Lp*Ls^2*Rp*omega*`&omega;0s`^2-4*I2^2*Lp*Ls*Rp*Rs*omega^2+Lp*Ls*vin^2*omega^2)^(1/2))/(I2*Lp*Ls*omega^2)
(1.5.4)
Coupling
kcoup := `assuming`([simplify(sol1)], [assumptions])
(1/2)*(vin*omega+(-4*(omega+`&omega;0p`)*I2^2*(omega-`&omega;0p`)*((-omega^2+`&omega;0s`^2)*Ls+I*Rs*omega)*Lp-4*(I*(omega+`&omega;0s`)*Rp*I2^2*(omega-`&omega;0s`)*Ls+omega*(I2^2*Rp*Rs-(1/4)*vin^2))*omega)^(1/2))/(Ls^(1/2)*Lp^(1/2)*I2*omega^2)
(1.5.5)
Zmutual
Zmutual := `assuming`([expand(abs(vin/I2sol))], [assumptions])
(Lp^2*Ls^2*k^4*omega^8-2*Lp^2*Ls^2*k^2*omega^8+2*Lp^2*Ls^2*k^2*omega^6*`&omega;0p`^2+2*Lp^2*Ls^2*k^2*omega^6*`&omega;0s`^2-2*Lp^2*Ls^2*k^2*omega^4*`&omega;0p`^2*`&omega;0s`^2+Lp^2*Ls^2*omega^8-2*Lp^2*Ls^2*omega^6*`&omega;0p`^2-2*Lp^2*Ls^2*omega^6*`&omega;0s`^2+Lp^2*Ls^2*omega^4*`&omega;0p`^4+4*Lp^2*Ls^2*omega^4*`&omega;0p`^2*`&omega;0s`^2+Lp^2*Ls^2*omega^4*`&omega;0s`^4-2*Lp^2*Ls^2*omega^2*`&omega;0p`^4*`&omega;0s`^2-2*Lp^2*Ls^2*omega^2*`&omega;0p`^2*`&omega;0s`^4+Lp^2*Ls^2*`&omega;0p`^4*`&omega;0s`^4+2*Lp*Ls*Rp*Rs*k^2*omega^6+Lp^2*Rs^2*omega^6-2*Lp^2*Rs^2*omega^4*`&omega;0p`^2+Lp^2*Rs^2*omega^2*`&omega;0p`^4+Ls^2*Rp^2*omega^6-2*Ls^2*Rp^2*omega^4*`&omega;0s`^2+Ls^2*Rp^2*omega^2*`&omega;0s`^4+Rp^2*Rs^2*omega^4)^(1/2)/(omega^3*k*Ls^(1/2)*Lp^(1/2))
(1.5.6)
plot([subs(L = 34*exp(1)-6*omega0 and 34*exp(1)-6*omega0 = 2*Pi*0.85e5, R = 0.1e-1, omega = 2*Pi*85000, Zmutual), subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, R = 0.1e-1, omega = 2*Pi*79000, Zmutual)], k = 0 .. 1, numpoints = 1000)
plot([subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*85000, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*85000, Zmutual), subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*85000, Rp = 0.1e-1, Rs = 0.1e-1, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*79000, Zmutual)], k = 0 .. 1, numpoints = 1000)
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, Zmutual), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
Primary Current
I1sol := `assuming`([simplify(eval(i[L1], rest))], [assumptions])
-I*omega*vin*(-Ls*omega^2+`&omega;0s`^2*Ls+I*Rs*omega)/(Lp*Ls*(k-1)*(k+1)*omega^4+I*(Lp*Rs+Ls*Rp)*omega^3+(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega^2+I*(-Lp*Rs*`&omega;0p`^2-Ls*Rp*`&omega;0s`^2)*omega-Ls*Lp*`&omega;0p`^2*`&omega;0s`^2)
(1.5.7)
at resonance
I1sol_res := simplify(eval(I1sol, [omega = omega0, `&omega;0s` = omega0, `&omega;0p` = omega0]))
vin*Rs/(Lp*Ls*k^2*omega0^2+Rp*Rs)
(1.5.8)
Self Impedance
Zpself := simplify(vin/I1sol)
(I*Lp*(k+1)*Ls*(k-1)*omega^4+(-Lp*Rs-Ls*Rp)*omega^3+I*(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega^2+(Lp*Rs*`&omega;0p`^2+Ls*Rp*`&omega;0s`^2)*omega-I*Lp*Ls*`&omega;0p`^2*`&omega;0s`^2)/(omega*(-Ls*omega^2+`&omega;0s`^2*Ls+I*Rs*omega))
(1.5.9)
at resonance
zpself_res := simplify(eval(Zpself, omega = omega0))
(I*Lp*(k+1)*Ls*(k-1)*omega0^4+(-Lp*Rs-Ls*Rp)*omega0^3+I*(Ls*(`&omega;0p`^2+`&omega;0s`^2)*Lp+Rp*Rs)*omega0^2+(Lp*Rs*`&omega;0p`^2+Ls*Rp*`&omega;0s`^2)*omega0-I*Lp*Ls*`&omega;0p`^2*`&omega;0s`^2)/(omega0*(-Ls*omega0^2+`&omega;0s`^2*Ls+I*Rs*omega0))
(1.5.10)
Normalized
ZselfN := collect(simplify(`assuming`([expand(simplify(I2sol/I1sol))], [assumptions])), Ls)
I*omega^2*k*Ls^(1/2)*Lp^(1/2)/((-omega^2+`&omega;0s`^2)*Ls+I*Rs*omega)
(1.5.11)
Normalized Magnitude
`assuming`([MagZpselfN = simplify(eval(I2sol/I1sol, [`&omega;0p` = omega0, `&omega;0s` = omega0]))], [assumptions])
MagZpselfN = I*omega^2*k*Ls^(1/2)*Lp^(1/2)/(-Ls*omega^2+Ls*omega0^2+I*Rs*omega)
(1.5.12)
Plots
Zself as a function of Coupling Coefficient
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*85000, Zpself/Zmutual), k = 0 .. 1, numpoints = 1000)
plot(subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*85000, abs(Zpself/Zmutual)), k = 0 .. 1, numpoints = 1000)
Normalized - Off Resonance
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*79000, Zpself/Zmutual), k = 0 .. 1, numpoints = 1000)
plot(subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, omega = 2*Pi*79000, abs(Zpself/Zmutual)), k = 0 .. 1, numpoints = 1000)
Normalized, at a given coupling
plot(subs(L = 0.34e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, Zpself/Zmutual), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
plot(subs(Lp = 34*exp(1)-6, Ls = 60*exp(1)-6, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, abs(Zpself/Zmutual)), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
Not Normalized, at a given coupling
plot(subs(Lp = 0.34e-4, Ls = 0.60e-4, omega0 = 2*Pi*0.85e5, Rp = 0.1e-1, Rs = 0.1e-1, R = 0.1e-1, k = .25, abs(Zpself)), omega = 0.79e5 .. 0.90e5, numpoints = 1000)
Solution2
Download coupled_network.mw
