Question: How to display multiple animations together
I want to display in 3d the following objects
  • Animated plottools objects (e.g. a spinning cube)
  • Static plot objects (e.g. surface plot)/li>
  • Time dependent spacecurves (to trace the path of objects)
Technically I could
  • create a sequence of time stamps
  • generate for each time stamp a plot structure using plots:-display for all the above objects
  • display the sequence of plot structures with plots:-display with the option insequence.
or
  • create separate plots with plots:-animate for each time dependent object
  • plot with plot3d all static objects
  • display all plots with plots:-display
or
  • defining a procedure containing all plotting commands as a function of time
  • create a background plot of all static objects using plots:-display
  • animate the procedure with a plots:-animate call with the background option
Without having any experience, my perference would be the last way. However I intend to generate some plot coordinates with dsolve,numeric. This would mean that at each point in time to be plotted, dsolve starts integration from the inital conditions (which I have not planned to update animation frame by animation frame)
Any recommensations or thoughts on this?
