Question: make plot parameter edits stay after save and reload in document mode
I am in document mode where I have plots that I generated using the right click on the expression. Then I edit the range and style and drag in two other expressions that plot. everything looks wonderfull until I save and reload the document. and all the edits and dragged in plots are gone. When I try to use plotbuilder to get around this when I reload the document the plotbuilder screens come up when the document executes waiting for all the plot info to be input again. I Think that if I use a worksheet plot command directly with all the parameters and expressions included that it would do what I want. But I would think that when you hit save in document mode it should save what you see. Is there a way to freeze a plot for document purposes so that it becomes a dumb graphic instead of live?
