Hello! Hope everything fine with you. Please share the command to find the max and min values of the attached function, I had tried but I was only for one variable. I am waiting your quick response.
Examples.pdf
Mob #: 0086-13001903838
I would like to solve this equation :
tan(gamma0(t)) = tan(gamma[1](t)-theta[1](t)-psi[1](t)
I would like to select the solution of arctan by assuming the domain of variation of some variables. In my case, if -Pi/2 < gamma[1](t) - theta[1](t) - psi[1](t) < Pi/2, the arctan gives only one solution.
Can you help me to solve this equation ?
eq:=tan(gamma0(t)) = tan(gamma[1](t)-theta[1](t)-psi[1](t))
solve(eq,gamma0(t)) assuming -Pi/2 < gamma[1](t) - theta[1](t) - psi[1](t) < Pi/2
I guess that I don't use properly the "assume" function.
The result that I would like to obain is quiet simple :
gamma0(t)) = gamma[1](t)-theta[1](t)-psi[1](t)
Thanks a lot for your help
Here is my Maple 16 code:
 I expected to get outuput
a [a,b,c]
a [a,c,b]
But I get no output.
Why?
2*t*exp(t) + 2*t
would like to apply op recurively
and output list
[2,t,exp(t),2,t]
not the same ordering every time of monomials after determinant and map sign positive and op in maple 15
sometimes i need to use Reverse or Rotate List to adjust.
why ordering is different in list of monomials?
is it caused by virus?
I wonder how is it possible to numerically evaluate two-dimensional sum, something like this:
sum
Hi my dear friends, I am haunted by a problem of how to convert a very very very long equation to Latex or Word properly?
Thank you for taking a look at the following 'long and boring' equation and sharing your brilliant idea.
"1/12*R^2*h^3*rho*diff(diff(alpha(t),t),t)*cos(beta(t))^2*Pi+1/2*R^4*h*rho*sin(gamma(t))*diff(diff(phi(t),t),t)*Pi-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(diff(alpha(t),t),t)-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*diff(gamma(t),t)*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*diff(gamma(t),t)*Pi+1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*diff(diff(phi(t),t),t)*Pi+1/2*R^4*h*rho*cos(gamma(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(diff(phi(t),t),t)+1/2*R^4*h*rho*sin(gamma(t))*diff(diff(psi(t),t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(theta(t),t),t)*sin(phi(t))*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(theta(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(theta(t),t),t)*sin(phi(t))*Pi+1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(theta(t),t)*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*diff(phi(t),t)*Pi*diff(beta(t),t)*sin(beta(t))+1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))*diff(phi(t),t)*diff(beta(t),t)*sin(beta(t))-1/12*R^2*h^3*rho*cos(beta(t))^2*diff(gamma(t),t)*sin(gamma(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(phi(t),t),t)*Pi+1/4*R^4*h*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(phi(t),t)*Pi+1/12*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(phi(t),t),t)*Pi-1/12*R^2*h^3*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(phi(t),t)*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*cos(phi(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*cos(gamma(t))*diff(theta(t),t)*cos(phi(t))*Pi*diff(beta(t),t)*sin(beta(t))-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(phi(t),t)^2*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)*cos(theta(t))+1/4*R^4*h*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)*cos(theta(t))+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*sin(alpha(t))^2*sin(phi(t))*diff(phi(t),t)*cos(gamma(t))+1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*cos(alpha(t))^2*sin(phi(t))*diff(phi(t),t)*cos(gamma(t))+1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(theta(t),t)*cos(phi(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(phi(t),t)^2*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi+1/6*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)*cos(phi(t))*diff(theta(t),t)*sin(theta(t))*Pi+1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(theta(t),t)*cos(phi(t))*Pi+1/2*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/2*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(theta(t),t)*cos(phi(t))*diff(phi(t),t)*Pi-1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*cos(theta(t))^2*Pi+1/4*R^4*h*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi-1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)*cos(phi(t))^2*cos(theta(t))-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi+1/6*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*diff(phi(t),t)*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*diff(theta(t),t)^2*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*cos(phi(t))^2*cos(gamma(t))+1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*cos(theta(t))^2*Pi+1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi+1/6*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(beta(t))*Pi*cos(beta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*sin(alpha(t))*cos(theta(t))^2*cos(gamma(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))-1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi+1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*sin(gamma(t))*sin(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi-1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))+1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*cos(phi(t))*Pi-1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*cos(phi(t))*Pi+1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*diff(psi(t),t)^2*cos(phi(t))^2*cos(theta(t))^2*cos(gamma(t))-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*diff(phi(t),t)*Pi-1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*diff(diff(alpha(t),t),t)*Pi-1/2*R^4*h*rho*cos(gamma(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(diff(psi(t),t),t)-1/4*R^4*h*rho*diff(diff(theta(t),t),t)*Pi*cos(beta(t))^2*cos(phi(t))*cos(gamma(t))+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*diff(diff(psi(t),t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(gamma(t),t)*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(gamma(t),t)*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)^2*cos(alpha(t))*sin(alpha(t))+1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(alpha(t))*sin(alpha(t))-1/12*R^2*h^3*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(alpha(t))*sin(alpha(t))-1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi+1/4*R^4*h*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)^2*cos(alpha(t))*sin(alpha(t))+1/2*R^4*h*rho*Pi*cos(beta(t))*diff(alpha(t),t)*diff(beta(t),t)*sin(beta(t))-1/6*R^2*h^3*rho*diff(alpha(t),t)*cos(beta(t))*Pi*diff(beta(t),t)*sin(beta(t))+1/12*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*diff(phi(t),t)*Pi-1/2*R^4*h*rho*diff(gamma(t),t)*sin(gamma(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/2*R^4*h*rho*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi-1/4*R^4*h*rho*Pi*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*diff(phi(t),t)+1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/2*R^4*h*rho*sin(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(gamma(t),t),t)*Pi+1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(gamma(t),t)*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(gamma(t),t),t)*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(gamma(t),t)*Pi+1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(theta(t),t)*cos(phi(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*sin(theta(t))*cos(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(gamma(t))+1/4*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*sin(theta(t))*sin(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*sin(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(theta(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*sin(theta(t))*sin(alpha(t))^2*diff(psi(t),t)^2*cos(phi(t))*cos(theta(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)*cos(phi(t))*diff(phi(t),t)*cos(theta(t))*cos(gamma(t))-1/12*R^2*h^3*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)*cos(phi(t))*diff(phi(t),t)*cos(theta(t))*cos(gamma(t))+1/4*R^4*h*rho*Pi*cos(beta(t))^2*sin(theta(t))*cos(alpha(t))^2*diff(psi(t),t)^2*cos(phi(t))*cos(theta(t))*cos(gamma(t))+1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*cos(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(theta(t))-1/12*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2+1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*Pi*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))-1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(theta(t))*sin(alpha(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)*cos(phi(t))*diff(theta(t),t)*sin(theta(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/6*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi-1/6*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)^2*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*cos(phi(t))^2*cos(gamma(t))-1/12*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(theta(t))*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2+1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*diff(phi(t),t)*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi+1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)*cos(phi(t))^2*cos(theta(t))-1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/6*R^2*h^3*rho*cos(beta(t))*cos(gamma(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi*diff(beta(t),t)*sin(beta(t))-1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/2*R^4*h*rho*Pi*cos(beta(t))*diff(psi(t),t)*sin(phi(t))*cos(theta(t))*cos(gamma(t))*diff(beta(t),t)*sin(beta(t))-1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))-1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(phi(t))*cos(alpha(t))*sin(alpha(t))+1/12*R^2*h^3*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi+1/2*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))-1/12*R^2*h^3*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(phi(t))^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(theta(t))*cos(alpha(t))^2*diff(psi(t),t)*cos(gamma(t))+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*sin(alpha(t))^2*cos(phi(t))+1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*sin(phi(t))*cos(phi(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(theta(t))*sin(alpha(t))^2*diff(psi(t),t)*cos(gamma(t))+1/2*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(phi(t))*cos(alpha(t))*sin(alpha(t))+1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(phi(t))^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*sin(phi(t))*cos(phi(t))-1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*cos(alpha(t))^2*cos(phi(t))-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)*diff(phi(t),t)*cos(phi(t))*cos(theta(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*diff(theta(t),t)*sin(theta(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(theta(t))*diff(gamma(t),t)*sin(gamma(t))+1/2*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(phi(t),t)*Pi-1/6*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(psi(t),t),t)*sin(theta(t))*Pi+1/4*R^4*h*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(psi(t),t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(theta(t),t)*cos(phi(t))*Pi+1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))*sin(theta(t))*diff(psi(t),t)*diff(beta(t),t)*sin(beta(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))*cos(phi(t))*cos(gamma(t))*diff(beta(t),t)*sin(beta(t))-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*diff(psi(t),t)*sin(theta(t))*Pi*diff(beta(t),t)*sin(beta(t))+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(phi(t))*cos(theta(t))*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(phi(t),t)*sin(phi(t))*cos(gamma(t))+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*cos(phi(t))*diff(gamma(t),t)*sin(gamma(t))+1/12*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*sin(theta(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi-1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi+1/2*R^4*h*rho*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi-1/2*R^4*h*rho*cos(gamma(t))*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*Pi*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(theta(t),t)*cos(theta(t))*diff(psi(t),t)-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(phi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(phi(t))^2*cos(alpha(t))*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(phi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))+1/6*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(theta(t),t)^2*cos(phi(t))^2*Pi*sin(alpha(t))+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*cos(alpha(t))^2*diff(phi(t),t)*cos(gamma(t))-1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(alpha(t))^2*diff(phi(t),t)*cos(gamma(t))-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi+1/4*R^4*h*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(diff(psi(t),t),t)*sin(phi(t))*cos(theta(t))*cos(gamma(t))-1/3*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))*cos(theta(t))*sin(phi(t))*Pi*sin(alpha(t))+1/4*R^4*h*rho*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*diff(psi(t),t)^2*cos(phi(t))^2*cos(theta(t))^2*cos(gamma(t))-1/4*R^4*h*rho*sin(beta(t))*Pi*cos(beta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*sin(alpha(t))*cos(theta(t))^2*cos(gamma(t))+1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi+R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(phi(t))*cos(alpha(t))*cos(theta(t))*sin(alpha(t))+1/6*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))-1/2*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))-1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))-1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))+1/6*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))+1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))^2*sin(alpha(t)) = 0"
I was trying to make a function (or procedure) that uses the simplify command and outputed all the different types of simplify that are in the right click menu.  I never know which one to chose so until I get the hang of what they are, I wanted to see all of them at once.  Can someone set me off on the right path?
I would like to simplify a trigonometric equation that I obtain with a vectorial closure (in mechanics)
Here the equation that I would like to simplify
eq_liaison :=(-sin(p(t)+g(t))*cos(a(t))-sin(b(t))*sin(a(t))*cos(p(t)+g(t)))*l2[1]+((-sin(p(t)+g(t))*cos(a(t))-sin(b(t))*sin(a(t))*cos(p(t)+g(t)))*cos(th(t))+(-cos(p(t)+g(t))*cos(a(t))+sin(a(t))*sin(b(t))*sin(p(t)+g(t)))*sin(th(t)))*l3[1] = 0
Do you have ideas so as to simplify again this expression ?
This expression can still be simplified. You can find here the result expected :
I find surprising that I have so many difficulties to make trigonometric simplications with the trigonometric functions.
Thank you for your help
PS : Sorry for duplicating posts. As I didn't receive any answer, I have tried to simplified my post to isolate the difficulty.
I am looking for a quick implementation in Maple to approximate a solution to the travelling salesman problem in a graph of several thousand vertices randomly placed in the unit square. I've tried TravelingSaleman in the GraphTheory package; it bogs down with just a handful (say, twelve) of vertices. I also tried Bruno Buerrier's implementation of the two-opt algorithm; on my machine that took more than a day for 2048 vertices.
Is anyone aware of a quicker implementation in Maple?
Hi there.
I have a equation following:
with letters {a,b,c,d,k} is missing all solutions ,but with {z,u,w,t} letters works fine.
Bug_maple.mw
I_Mariusz
i want a plot with labels = ["x values", "y values"] but without displaying y-axis
thanks in advance!
I have plotted an equation which is in terms of 'a & omega'
Now i need coordinates of every points as an n*2 matrix
restart; with(plots)
E := implicitplot(0.4e-3*a^2*omega^2+(-2.1739*a+a*omega^2+(1.495414012*(sqrt(a^2+.2916)*EllipticE(sqrt(a^2/(a^2+.2916)))-.2916*EllipticK(sqrt(a^2/(a^2+.2916)))/sqrt(a^2+.2916)))/a)^2-0.1e-3 = 0, omega = 0 .. 1.5, a = 0 .. .7, grid = [200, 200], color = red, thickness = 3):
PLOT(CURVES(Array(1..1171, 1..2, {(1, 1) = .0, (1, 2) = .1563469655787127, (2, 1) = 0.411404206213146e-2, (2, 2) = .1563715710259522, (3, 1) = 0.7537688442e-2, (3, 2) = .1563939703226259, (4, 1) = 0.11453278530964653e-1, (4, 2) = .1564641819447511, (5, 1) = 0.1507537688e-1, (5, 2) = .15653540477192268, (6, 1) = 0.1861188724047196e-1, (6, 2) = .15664108581877745, (7, 1) = 0.2261306533e-1, (7, 2) = .15677253817326953, (8, 1) = 0.25599994493771153e-1, (8, 2) = .15689755703889574, (9, 1) = 0.3015075377e-1, (9, 2) = .1571075215866537, (10, 1) = 0.3242521581787689e-1, (10, 2) = .15723004168932495, (11, 1) = 0.3768844221e-1, (11, 2) = .1575434428479125, (12, 1) = 0.3909288395460391e-1, (12, 2) = .15763605115972262, (13, 1) = 0.4522613065e-1, (13, 2) = .1580844082091386, (14, 1) = 0.4560620688944438e-1, (14, 2) = .158114088390209, (15, 1) = 0.4764869985153962e-1, (15, 2) = .1582914573, (16, 1) = 0.5204162039916189e-1, (16, 2) = .15862848335201973, (17, 1) = 0.5276381909e-1, (17, 2) = .15868992174261032, (18, 1) = 0.5837968585731567e-1, (18, 2) = .1591883074075377, (19, 1) = 0.6030150754e-1, (19, 2) = .15937801020899345, (20, 1) = 0.6458489561557128e-1, (20, 2) = .15981013078670622, (21, 1) = 0.6783919598e-1, (21, 2) = .160176487241211, (22, 1) = 0.7065484457382515e-1, (22, 2) = .1604950758706586, (23, 1) = 0.7537688442e-1, (23, 2) = .16109337109567876, (24, 1) = 0.7658532352018085e-1, (24, 2) = .16124510695944796, (25, 1) = 0.805813499008662e-1, (25, 2) = .1618090452, (26, 1) = 0.8242671215465647e-1, (26, 2) = .16203671353312998, (27, 1) = 0.8291457286000001e-1, (27, 2) = .16210413044792332, (28, 1) = 0.8826417929324287e-1, (28, 2) = .16283015015429084, (29, 1) = 0.904522613e-1, (29, 2) = .16316400984452806, (30, 1) = 0.9396930534693831e-1, (30, 2) = .1636853459516551, (31, 1) = 0.9798994975e-1, (31, 2) = .16435809016344582, (32, 1) = 0.9953317989166656e-1, (32, 2) = .16460645912228727, (33, 1) = .10348031148371162, (33, 2) = .1653266332, (34, 1) = .10500945609610703, (34, 2) = .1655684515121711, (35, 1) = .1055276382, (35, 2) = .16566098682384123, (36, 1) = .11052117326438587, (36, 2) = .16651390474986943, (37, 1) = .1130653266, (37, 2) = .16700677204260045, (38, 1) = .11589064181312089, (38, 2) = .16752574069219858, (39, 1) = .1206030151, (39, 2) = .16851216850911968, (40, 1) = .12110349883838589, (40, 2) = .16861066202341454, (41, 1) = .122139540949522, (41, 2) = .1688442211, (42, 1) = .12638254550555122, (42, 2) = .16966469484940266, (43, 1) = .1281407035, (43, 2) = .17005235758919762, (44, 1) = .13157164917804653, (44, 2) = .17076070110173922, (45, 1) = .135678392, (45, 2) = .1717326132535611, (46, 1) = .13659497627188055, (46, 2) = .17193406976339443, (47, 1) = .1382828915235487, (47, 2) = .1723618091, (48, 1) = .1416551472841524, (48, 2) = .17309024454992056, (49, 1) = .1432160804, (49, 2) = .1734770360582889, (50, 1) = .1466677855036304, (50, 2) = .174268601294131, (51, 1) = .1507537688, (51, 2) = .1753499101663136, (52, 1) = .15149998042302312, (52, 2) = .17553116491585571, (53, 1) = .1527341814199683, (53, 2) = .175879397, (54, 1) = .15641056483426513, (54, 2) = .17675714680070748, (55, 1) = .1582914573, (55, 2) = .17727585933216883, (56, 1) = .1612416351715959, (56, 2) = .17802023523441637, (57, 1) = .1658291457, (57, 2) = .17936629609487686, (58, 1) = .16587102451962582, (58, 2) = .17937744145121168, (59, 1) = .16593369754540996, (59, 2) = .1793969849, (60, 1) = .17069645778368336, (60, 2) = .18064316057275676, (61, 1) = .1733668342, (61, 2) = .1814566697357216, (62, 1) = .17533134212275173, (62, 2) = .1819978025151992, (63, 1) = .1781677256590961, (63, 2) = .1829145729, (64, 1) = .17989932145951784, (64, 2) = .1833836667628912, (65, 1) = .1809045226, (65, 2) = .18370113669326119, (66, 1) = .18453928746276133, (66, 2) = .1847359372070223, (67, 1) = .188442211, (67, 2) = .186041774318842, (68, 1) = .18895226379950275, (68, 2) = .18619413616474317, (69, 1) = .18962414585713816, (69, 2) = .1864321608, (70, 1) = .19352401701856153, (70, 2) = .1875782393021984, (71, 1) = .1959798995, (71, 2) = .1884278375837101, (72, 1) = .19794481725849886, (72, 2) = .18903278715851288, (73, 1) = .20045117752386254, (73, 2) = .1899497488, (74, 1) = .20231044794143524, (74, 2) = .1905130807774606, (75, 1) = .2035175879, (75, 2) = .19094440102144117, (76, 1) = .20673715713903199, (76, 2) = .19196487108359372, (77, 1) = .21071765865965755, (77, 2) = .1934673367, (78, 1) = .210919986781138, (78, 2) = .19353047185427236, (79, 1) = .2110552764, (79, 2) = .19358035292660802, (80, 1) = .2153504304721779, (80, 2) = .1949805193777135, (81, 1) = .2185929648, (81, 2) = .19624220476735219, (82, 1) = .21951361459471921, (82, 2) = .19655528803727368, (83, 1) = .220559693818866, (83, 2) = .1969849246, (84, 1) = .22380281657196704, (84, 2) = .1980712484167096, (85, 1) = .2261306533, (85, 2) = .19900426808883254, (86, 1) = .22796753073484188, (86, 2) = .19964530311091175, (87, 1) = .22999525398791076, (87, 2) = .2005025126, (88, 1) = .23210999355251577, (88, 2) = .20122974173135783, (89, 1) = .2336683417, (89, 2) = .20187269529339172, (90, 1) = .23627283634234642, (90, 2) = .20280466967381558, (91, 1) = .23906773088042566, (91, 2) = .2040201005, (92, 1) = .24028550777061808, (92, 2) = .20444967759681473, (93, 1) = .2412060301, (93, 2) = .204840388245712, (94, 1) = .2444429751737546, (94, 2) = .20602711411793337, (95, 1) = .2478214695999889, (95, 2) = .2075376885, (96, 1) = .24834109968376933, (96, 2) = .2077255773240134, (97, 1) = .2487437186, (97, 2) = .20790128484539636, (98, 1) = .252489482515476, (98, 2) = .20930725324938332, (99, 1) = .256281407, (99, 2) = .2110496186290694, (100, 1) = .2562880193831866, (100, 2) = .21105219062123806, (101, 1) = .2562943908258979, (101, 2) = .2110552764, (102, 1) = .26042230322198406, (102, 2) = .212640446099698, (103, 1) = .2638190955, (103, 2) = .21424381425046282, (104, 1) = .2641998913635977, (104, 2) = .21439515956466476, (105, 1) = .2645571585520604, (105, 2) = .2145728643, (106, 1) = .26825000147542855, (106, 2) = .21602269613110664, (107, 1) = .2713567839, (107, 2) = .21752863992089982, (108, 1) = .27200070242220775, (108, 2) = .21778995698678882, (109, 1) = .2725890871945216, (109, 2) = .2180904523, (110, 1) = .27597988723170386, (110, 2) = .219450592019427, (111, 1) = .2788944724, (111, 2) = .22090098019948495, (112, 1) = .27969725652919275, (112, 2) = .22123340760850677, (113, 1) = .2804118157639838, (113, 2) = .2216080402, (114, 1) = .283618132254194, (114, 2) = .22292125355124234, (115, 1) = .2864321608, (115, 2) = .22435856050825176, (116, 1) = .2872950900428197, (116, 2) = .2247229278775256, (117, 1) = .2880433831984684, (117, 2) = .2251256282, (118, 1) = .29116990158350164, (118, 2) = .2264322704136034, (119, 1) = .2939698492, (119, 2) = .2278998650257172, (120, 1) = .2947986307063212, (120, 2) = .22825645140438025, (121, 1) = .2954988272759236, (121, 2) = .2286432161, (122, 1) = .29863944855385915, (122, 2) = .2299816576761657, (123, 1) = .3015075377, (123, 2) = .23152418338227845, (124, 1) = .30221116730105624, (124, 2) = .23183244352137405, (125, 1) = .30279033114215453, (125, 2) = .232160804, (126, 1) = .3060301271596008, (126, 2) = .23356785020418652, (127, 1) = .3090452261, (127, 2) = .2352316447014429, (128, 1) = .3095348534013429, (128, 2) = .23544989925720808, (129, 1) = .30992746284733075, (129, 2) = .235678392, (130, 1) = .3133444099346572, (130, 2) = .2371896941485172, (131, 1) = .3165829146, (131, 2) = .23902330205384661, (132, 1) = .31677063657843346, (132, 2) = .23910837631056248, (133, 1) = .31691724815204936, (133, 2) = .2391959799, (134, 1) = .3205839061629061, (134, 2) = .24084643846151332, (135, 1) = .3237977008207778, (135, 2) = .2427135679, (136, 1) = .3239626997077225, (136, 2) = .2427872561026439, (137, 1) = .324120603, (137, 2) = .24287665200373632, (138, 1) = .3277493216791142, (138, 2) = .24453775375937492, (139, 1) = .3305894716179565, (139, 2) = .2462311558, (140, 1) = .3311308893678871, (140, 2) = .24647727674692, (141, 1) = .3316582914, (141, 2) = .2467835549689252, (142, 1) = .33484037350574114, (142, 2) = .24826377207879788, (143, 1) = .33726661427309146, (143, 2) = .2497487437, (144, 1) = .3382357167737991, (144, 2) = .2501968664964736, (145, 1) = .3391959799, (145, 2) = .2507689682864231, (146, 1) = .34185565973081394, (146, 2) = .25202514775072543, (147, 1) = .3438305170126463, (147, 2) = .2532663317, (148, 1) = .3452768774193954, (148, 2) = .25394616744041676, (149, 1) = .3467336683, (149, 2) = .2548367630850394, (150, 1) = .3487924843457991, (150, 2) = .25582313879683616, (151, 1) = .35028050460732685, (151, 2) = .2567839196, (152, 1) = .3522532246943719, (152, 2) = .2577257145915511, (153, 1) = .3542713568, (153, 2) = .258992096032466, (154, 1) = .355646577930956, (154, 2) = .2596597377242915, (155, 1) = .356613489956487, (155, 2) = .2603015076, (156, 1) = .35916257815712477, (156, 2) = .2615365255463198, (157, 1) = .3618090452, (157, 2) = .26324180296336236, (158, 1) = .3624116312465448, (158, 2) = .2635378886836086, (159, 1) = .36282345633954893, (159, 2) = .2638190955, (160, 1) = .3660015162650624, (160, 2) = .265380196940051, (161, 1) = .3689568243623757, (161, 2) = .2673366834, (162, 1) = .36914704156615796, (162, 2) = .2674298730633427, (163, 1) = .3693467337, (163, 2) = .2675584668960912, (164, 1) = .37276508141208897, (164, 2) = .26925904243141174, (165, 1) = .3751087624447853, (165, 2) = .2708542714, (166, 1) = .37596870650284064, (166, 2) = .2712816053429114, (167, 1) = .3768844221, (167, 2) = .27188718811737245, (168, 1) = .3794462813572124, (168, 2) = .27317632498676503, (169, 1) = .38115313529001693, (169, 2) = .2743718593, (170, 1) = .38272548573151655, (170, 2) = .27516361754329915, (171, 1) = .3844221105, (171, 2) = .27631660317460116, (172, 1) = .3860354639396687, (172, 2) = .27713654902102, (173, 1) = .3870788206689781, (173, 2) = .2778894473, (174, 1) = .3894118058305985, (174, 2) = .27907851075651846, (175, 1) = .391959799, (175, 2) = .2808593013214599, (176, 1) = .3925192611802801, (176, 2) = .2811459528506871, (177, 1) = .3928699254515984, (177, 2) = .2814070352, (178, 1) = .39601999075370253, (178, 2) = .2830298669590452, (179, 1) = .39865339649823994, (179, 2) = .2849246231, (180, 1) = .399054215984739, (180, 2) = .28513148309849307, (181, 1) = .3994974874, (181, 2) = .2854410813479102, (182, 1) = .4025394978638157, (182, 2) = .28702260620343356, (183, 1) = .40445346238143115, (183, 2) = .2884422111, (184, 1) = .40567205625734704, (184, 2) = .28907833358784873, (185, 1) = .4070351759, (185, 2) = .2900578777122225, (186, 1) = .4089557678778346, (186, 2) = .2910635227487732, (187, 1) = .41012599927130694, (187, 2) = .291959799, (188, 1) = .4122139513300834, (188, 2) = .29306062507766373, (189, 1) = .4145728643, (189, 2) = .29480677486942214, (190, 1) = .41524840249674494, (190, 2) = .2951621358385316, (191, 1) = .4156461222869131, (191, 2) = .295477387, (192, 1) = .4186682810347394, (192, 2) = .29708378046000994, (193, 1) = .4211708817900251, (193, 2) = .2989949749, (194, 1) = .4216089056599046, (194, 2) = .29922907689427447, (195, 1) = .4221105528, (195, 2) = .29960026414159835, (196, 1) = .4250189113577072, (196, 2) = .30115532881412016, (197, 1) = .42673813074297334, (197, 2) = .3025125628, (198, 1) = .4280881553513352, (198, 2) = .30324060287926796, (199, 1) = .4296482412, (199, 2) = .30443065848243966, (200, 1) = .43124296130670364, (200, 2) = .305285948066613, (201, 1) = .4321524720222676, (201, 2) = .3060301508, (202, 1) = .43447882908159996, (202, 2) = .3072934643680706, (203, 1) = .4371859296, (203, 2) = .3094261430078931, (204, 1) = .4373072082542931, (204, 2) = .30949114199573585, (205, 1) = .43737370440049944, (205, 2) = .3095477387, (206, 1) = .4407626456393019, (206, 2) = .3113961925325087, (207, 1) = .44280925121024983, (207, 2) = .3130653267, (208, 1) = .44368693138175197, (208, 2) = .31354911382601347, (209, 1) = .4447236181, (209, 2) = .31436552367991755, (210, 1) = .44691325438868024, (210, 2) = .31556108433775903, (211, 1) = .44811968623247306, (211, 2) = .3165829146, (212, 1) = .4500128454767157, (212, 2) = .3176321964049001, (213, 1) = .4522613065, (213, 2) = .31946347593252944, (214, 1) = .452891529738174, (214, 2) = .3198063983277594, (215, 1) = .45322441588014806, (215, 2) = .3201005025, (216, 1) = .4562256549567938, (216, 2) = .3217680612026317, (217, 1) = .4584156737738623, (217, 2) = .3236180905, (218, 1) = .45904270810555414, (218, 2) = .3239710243773858, (219, 1) = .459798995, (219, 2) = .32458718918913143, (220, 1) = .4622940370494772, (220, 2) = .3259713254501975, (221, 1) = .4636177231597405, (221, 2) = .3271356784, (222, 1) = .4653001003370227, (222, 2) = .3280860838510044, (223, 1) = .4673366834, (223, 2) = .3298052569263673, (224, 1) = .4681701175821987, (224, 2) = .3302643304394618, (225, 1) = .4685923820791582, (225, 2) = .3306532664, (226, 1) = .4714342533295569, (226, 2) = .3322586550104123, (227, 1) = .4736127372887472, (227, 2) = .3341708543, (228, 1) = .4741784948157407, (228, 2) = .33449559689080793, (229, 1) = .47487437180000003, (229, 2) = .33508357622689244, (230, 1) = .4774064804372275, (230, 2) = .3365067915250223, (231, 1) = .4786946396102586, (231, 2) = .3376884422, (232, 1) = .48036051097030574, (232, 2) = .33864583189626307, (233, 1) = .4824120603, (233, 2) = .3404462819598845, (234, 1) = .4831554993207043, (234, 2) = .3408590919824476, (235, 1) = .48351475560029955, (235, 2) = .3412060302, (236, 1) = .486403767498123, (236, 2) = .34286082141813395, (237, 1) = .4884380204147546, (237, 2) = .3447236181, (238, 1) = .48910930455562657, (238, 2) = .3451158253762942, (239, 1) = .4899497487, (239, 2) = .34585451237338455, (240, 1) = .4922582746972002, (240, 2) = .3471638939577644, (241, 1) = .4933783239162865, (241, 2) = .3482412061, (242, 1) = .49520497458841906, (242, 2) = .34930635529855064, (243, 1) = .4974874372, (243, 2) = .3513969608302578, (244, 1) = .4978411444834455, (244, 2) = .3515937306019973, (245, 1) = .4980028813388976, (245, 2) = .351758794, (246, 1) = .5011382603441314, (246, 2) = .35357266444242547, (247, 1) = .5029123014095499, (247, 2) = .3552763819, (248, 1) = .5038426326656263, (248, 2) = .35582821194859127, (249, 1) = .5050251256, (249, 2) = .35691345813736414, (250, 1) = .506840931853553, (250, 2) = .35794659364031206, (251, 1) = .5076747727105544, (251, 2) = .3587939699, (252, 1) = .5098347969513135, (252, 2) = .3600670445452593, (253, 1) = .5121706405090248, (253, 2) = .3623115578, (254, 1) = .5123417375182368, (254, 2) = .3624147268724672, (255, 1) = .5125628141, (255, 2) = .36261833722107134, (256, 1) = .515627776465587, (256, 2) = .3643988299968633, (257, 1) = .517037436286423, (257, 2) = .3658291458, (258, 1) = .5183776657705376, (258, 2) = .3666331362691778, (259, 1) = .5201005025000001, (259, 2) = .3682925798270953, (260, 1) = .5211218094273468, (260, 2) = .3688701238032814, (261, 1) = .5215606671057531, (261, 2) = .3693467337, (262, 1) = .5242388999126684, (262, 2) = .37093306948506855, (263, 1) = .5261408456874557, (263, 2) = .3728643216, (264, 1) = .526789770654438, (264, 2) = .37326025105693345, (265, 1) = .5276381909, (265, 2) = .37408073813624665, (266, 1) = .5298408117505049, (266, 2) = .3753540198600239, (267, 1) = .5307890461341223, (267, 2) = .3763819096, (268, 1) = .5327024621228297, (268, 2) = .3775361709741368, (269, 1) = .5350235561041898, (269, 2) = .3798994975, (270, 1) = .5350889609440974, (270, 2) = .37994005944647224, (271, 1) = .5351758794, (271, 2) = .38002457646404664, (272, 1) = .5383866426757877, (272, 2) = .3819187292705555, (273, 1) = .5397678254418192, (273, 2) = .3834170855, (274, 1) = .5410400965701394, (274, 2) = .3841980387361613, (275, 1) = .5427135678, (275, 2) = .38590965937995525, (276, 1) = .543705513710889, (276, 2) = .386471765317025, (277, 1) = .5440979633663376, (277, 2) = .3869346734, (278, 1) = .5467869878557947, (278, 2) = .3885513319766563, (279, 1) = .5485339197773342, (279, 2) = .3904522613, (280, 1) = .5492686492431231, (280, 2) = .3909108112642211, (281, 1) = .5502512563, (281, 2) = .3919219623354962, (282, 1) = .552209960639181, (282, 2) = .3930557872542605, (283, 1) = .5529844139193156, (283, 2) = .3939698493, (284, 1) = .5550630770255085, (284, 2) = .39524192087419674, (285, 1) = .5571162262826977, (285, 2) = .3974874372, (286, 1) = .5574014126054714, (286, 2) = .3976682855148931, (287, 1) = .5577889447, (287, 2) = .3980700966510423, (288, 1) = .5605658940567053, (288, 2) = .39970911548792387, (289, 1) = .5616601137346005, (289, 2) = .4010050252, (290, 1) = .5632313898737636, (290, 2) = .401982805400379, (291, 1) = .5653266332, (291, 2) = .4042902645303774, (292, 1) = .5655545878763909, (292, 2) = .40441623425162243, (293, 1) = .5656346345021266, (293, 2) = .4045226131, (294, 1) = .5687951576899943, (294, 2) = .4064215562472058, (295, 1) = .5701537839480469, (295, 2) = .408040201, (296, 1) = .571304894879362, (296, 2) = .4087679334861818, (297, 1) = .5728643216, (297, 2) = .4105001595793406, (298, 1) = .573890981475691, (298, 2) = .4110786810471146, (299, 1) = .5742499574625818, (299, 2) = .411557789, (300, 1) = .5769146360350601, (300, 2) = .4131852301743854, (301, 1) = .5784881143647418, (301, 2) = .4150753769, (302, 1) = .5792939134001516, (302, 2) = .4155924886583565, (303, 1) = .58040201, (303, 2) = .4168360034851491, (304, 1) = .5820916234225818, (304, 2) = .41780447862865666, (305, 1) = .5826778032589655, (305, 2) = .4185929649, (306, 1) = .5849375309142315, (306, 2) = .4199939764134728, (307, 1) = .5866812236992927, (307, 2) = .4221105528, (308, 1) = .5872067269735419, (308, 2) = .42245260617253105, (309, 1) = .5879396985, (309, 2) = .42328487231509143, (310, 1) = .5901748181793824, (310, 2) = .424585084855552, (311, 1) = .5909416297801887, (311, 2) = .4256281407, (312, 1) = .5928742661563755, (312, 2) = .4268429304079858, (313, 1) = .5947477331341324, (313, 2) = .4291457287, (314, 1) = .5950500399391007, (314, 2) = .4293451572806191, (315, 1) = .5954773869, (315, 2) = .42983686771803714, (316, 1) = .5981546733456532, (316, 2) = .4314139162823743, (317, 1) = .5990599732896797, (317, 2) = .4326633166, (318, 1) = .6007331668179969, (318, 2) = .4337282072816926, (319, 1) = .6026995817042107, (319, 2) = .4361809046, (320, 1) = .6028293309636257, (320, 2) = .43626758533533183, (321, 1) = .6030150754, (321, 2) = .43648448192499756, (322, 1) = .6060420969519619, (322, 2) = .4382858824504494, (323, 1) = .6070475298616599, (323, 2) = .4396984925, (324, 1) = .6085209028289573, (324, 2) = .4406466942810953, (325, 1) = .6105465714823727, (325, 2) = .4432160804, (326, 1) = .610549100469022, (326, 2) = .44321778995449523, (327, 1) = .6105527638, (327, 2) = .44322213796208026, (328, 1) = .6138455353056087, (328, 2) = .44519704166243534, (329, 1) = .6149160064931423, (329, 2) = .4467336684, (330, 1) = .6162428430226877, (330, 2) = .4475958860111768, (331, 1) = .6180904522, (331, 2) = .44998451105692194, (332, 1) = .618361032979732, (332, 2) = .4501249852718516, (333, 1) = .6184311109683637, (333, 2) = .4502512563, (334, 1) = .6215714415476802, (334, 2) = .45214438258902223, (335, 1) = .6226746600685912, (335, 2) = .4537688443, (336, 1) = .6239033103668259, (336, 2) = .4545737651068926, (337, 1) = .6256281407, (337, 2) = .4568521499901121, (338, 1) = .6260703963670847, (338, 2) = .4570800462232006, (339, 1) = .6261798113812319, (339, 2) = .4572864322, (340, 1) = .629224615214578, (340, 2) = .4591256653360729, (341, 1) = .630330704663824, (341, 2) = .4608040201, (342, 1) = .6315057682571499, (342, 2) = .4615787151776155, (343, 1) = .6331658291, (343, 2) = .4638253825811738, (344, 1) = .6336751962287598, (344, 2) = .46408390343765954, (345, 1) = .6337940389714881, (345, 2) = .4643216081, (346, 1) = .6368083372536868, (346, 2) = .46613935889382885, (347, 1) = .6378894739173245, (347, 2) = .467839196, (348, 1) = .6390529293504151, (348, 2) = .46860947052377216, (349, 1) = .6407035176, (349, 2) = .47090538903042267, (350, 1) = .6411729686877367, (350, 2) = .47113770682074047, (351, 1) = .6412744469548372, (351, 2) = .47135678400000003, (352, 1) = .6443244310598472, (352, 2) = .4731846122950122, (353, 1) = .6453545506161649, (353, 2) = .4748743719, (354, 1) = .64654686035321, (354, 2) = .475665066530673, (355, 1) = .648241206, (355, 2) = .4780964241606354, (356, 1) = .6485547404531187, (356, 2) = .47824564372465095, (357, 1) = .6486159014391775, (357, 2) = .4783919598, (358, 1) = .6517730630078912, (358, 2) = .48026134784736546, (359, 1) = .6527275625074144, (359, 2) = .4819095478, (360, 1) = .6539889836503494, (360, 2) = .48274483951400615, (361, 1) = .6557788945, (361, 2) = .48540677089959555, (362, 1) = .6558011432731569, (362, 2) = .4854167529392525, (363, 1) = .655804895158075, (363, 2) = .4854271357, (364, 1) = .6591523462683724, (364, 2) = .4873704461722893, (365, 1) = .6600078620797836, (365, 2) = .4889447237, (366, 1) = .6613800684774144, (366, 2) = .4898484304254017, (367, 1) = .6630661423301804, (367, 2) = .4924623116, (368, 1) = .6631655196107269, (368, 2) = .49253280780125996, (369, 1) = .6633165829, (369, 2) = .49274529682446533, (370, 1) = .6664574008536912, (370, 2) = .49451418446327766, (371, 1) = .6671916688909929, (371, 2) = .4959798995, (372, 1) = .6687201033375192, (372, 2) = .4969758445718083, (373, 1) = .6702685660547512, (373, 2) = .4994974875, (374, 1) = .6705011863405904, (374, 2) = .49966226048012097, (375, 1) = .6708542713, (375, 2) = .5001774441430769, (376, 1) = .6736784716571493, (376, 2) = .5016971152583087, (377, 1) = .6742704585741014, (377, 2) = .5030150754, (378, 1) = .6760080517394262, (378, 2) = .50412756583881, (379, 1) = .677399246611721, (379, 2) = .5065326634, (380, 1) = .6777947901740559, (380, 2) = .5068113425534924, (381, 1) = .6783919598, (381, 2) = .5077201960344483, (382, 1) = .6807968774505293, (382, 2) = .5089279564028008, (383, 1) = .6812277157139974, (383, 2) = .5100502513, (384, 1) = .6832413537672619, (384, 2) = .5113047886948117, (385, 1) = .6844556297290976, (385, 2) = .5135678392, (386, 1) = .6850466625571178, (386, 2) = .5139798991760498, (387, 1) = .6859296482, (387, 2) = .5153920731517049, (388, 1) = .6877753661910225, (388, 2) = .5162240921293607, (389, 1) = .6880318827296975, (389, 2) = .5170854272000001, (390, 1) = .6904148909644026, (390, 2) = .5185099018496149, (391, 1) = .691432076216194, (391, 2) = .5206030151, (392, 1) = .6922567301232537, (392, 2) = .5211679648411685, (393, 1) = .6934673366999999, (393, 2) = .5232237897260825, (394, 1) = .6945317640609436, (394, 2) = .5236238703202625, (395, 1) = .6946196251507182, (395, 2) = .5241206031, (396, 1) = .6975187814979922, (396, 2) = .5257475167716869, (397, 1) = .698317581437037, (397, 2) = .527638191, (398, 1) = .6994243262800321, (398, 2) = .5283758504451243, (399, 1) = .7009425609360174, (399, 2) = .5311557789, (400, 1) = .7009668454087546, (400, 2) = .5311735960896531, (401, 1) = .7010050251, (401, 2) = .531235022213899, (402, 1) = .7045330536072332, (402, 2) = .5330269535591804, (403, 1) = .7050907594978423, (403, 2) = .5346733669, (404, 1) = .7065477859856253, (404, 2) = .5356043330680816, (405, 1) = .707826439370854, (405, 2) = .5381909548, (406, 1) = .7081081959007527, (406, 2) = .5383937296842604, (407, 1) = .7085427135, (407, 2) = .5391383297211966, (408, 1) = .7114127298251807, (408, 2) = .5403692018355573, (409, 1) = .7117074971453883, (409, 2) = .5417085428, (410, 1) = .7136235371248519, (410, 2) = .5428550797200062, (411, 1) = .7146400679090801, (411, 2) = .5452261307, (412, 1) = .7152171450153232, (412, 2) = .5456289839518809, (413, 1) = .716080402, (413, 2) = .5472318084850784, (414, 1) = .7180345888276969, (414, 2) = .5478317647522599, (415, 1) = .7180648234578784, (415, 2) = .5487437186, (416, 1) = .7206438027624761, (416, 2) = .5501317195290782, (417, 1) = .7213690656048836, (417, 2) = .5522613066, (418, 1) = .7222959479644129, (418, 2) = .5528783063997659, (419, 1) = .7236180904, (419, 2) = .5556142807592881, (420, 1) = .7239053069243766, (420, 2) = .5556448601244978, (421, 1) = .7238626413394168, (421, 2) = .5557788945, (422, 1) = .727589654427056, (422, 2) = .5574430859364774, (423, 1) = .7279818096371112, (423, 2) = .5592964825, (424, 1) = .7293484692190622, (424, 2) = .560139893668453, (425, 1) = .7304488507618105, (425, 2) = .5628140704, (426, 1) = .7307271473996758, (426, 2) = .5630140984296936, (427, 1) = .7311557789, (427, 2) = .5638422925589597, (428, 1) = .7344031167623684, (428, 2) = .5648162339728443, (429, 1) = .734397592924741, (429, 2) = .5663316583, (430, 1) = .7363825553752067, (430, 2) = .56741008388943, (431, 1) = .737141981461179, (431, 2) = .5698492463, (432, 1) = .737774574082815, (432, 2) = .5702780631322483, (433, 1) = .7386934673000001, (433, 2) = .5722948844201498, (434, 1) = .7407898893748043, (434, 2) = .5723885039169664, (435, 1) = .7403417330236419, (435, 2) = .5733668342, (436, 1) = .7434181560698958, (436, 2) = .5746795674198217, (437, 1) = .7437609615715551, (437, 2) = .5768844222, (438, 1) = .7448263593479074, (438, 2) = .5775399938652186, (439, 1) = .7458907583865892, (439, 2) = .5804020101, (440, 1) = .7460238544868412, (440, 2) = .5804987507109741, (441, 1) = .7462311558, (441, 2) = .5809274807500572, (442, 1) = .7505285078494064, (442, 2) = .5819141670550128, (443, 1) = .7502570823615815, (443, 2) = .583919598, (444, 1) = .7519232985586441, (444, 2) = .5847808526522201, (445, 1) = .7525801176410079, (445, 2) = .5874371860000001, (446, 1) = .7530674347922731, (446, 2) = .5877645103884115, (447, 1) = .7537688442, (447, 2) = .5894754545594193, (448, 1) = .7584052102297473, (448, 2) = .5887911364317532, (449, 1) = .7564023156361204, (449, 2) = .5909547739, (450, 1) = .7591949895306978, (450, 2) = .5919401606880849, (451, 1) = .759272894687191, (451, 2) = .5944723619, (452, 1) = .7601756102366055, (452, 2) = .5950001256665833, (453, 1) = .7610832014050026, (453, 2) = .5979899498, (454, 1) = .7611712213813305, (454, 2) = .59805309503502, (455, 1) = .7613065326, (455, 2) = .598365048803723, (456, 1) = .767397979816176, (456, 2) = .5986648623863265, (457, 1) = .7660541949332249, (457, 2) = .6015075377, (458, 1) = .7674897400218551, (458, 2) = .6021396288757908, (459, 1) = .7678552870305516, (459, 2) = .6050251257, (460, 1) = .7682732811148212, (460, 2) = .6052915643547006, (461, 1) = .7688442211, (461, 2) = .6069776370063522, (462, 1) = .7718788618065875, (462, 2) = .6050251257, (463, 1) = .7701772158845703, (463, 2) = .604403061453053, (464, 1) = .770635160312404, (464, 2) = .6015075377, (465, 1) = .7698840051758535, (465, 2) = .6010223051340272, (466, 1) = .7693019342651174, (466, 2) = .5979899498, (467, 1) = .7691335900028758, (467, 2) = .5978549109794257, (468, 1) = .7688442211, (468, 2) = .5970283535448404, (469, 1) = .7625054523889951, (469, 2) = .5974304539090726, (470, 1) = .7652436454649781, (470, 2) = .5944723619, (471, 1) = .7632377617406646, (471, 2) = .5935711216258162, (472, 1) = .7633131740612666, (472, 2) = .5909547739, (473, 1) = .7624996825719582, (473, 2) = .5903979705903055, (474, 1) = .7617545533100927, (474, 2) = .5874371860000001, (475, 1) = .7615921668021366, (475, 2) = .5873038900377399, (476, 1) = .7613065326, (476, 2) = .5865669253736254, (477, 1) = .7569338344741664, (477, 2) = .5859601905051313, (478, 1) = .7579615162167681, (478, 2) = .583919598, (479, 1) = .7559963080423406, (479, 2) = .5828801148794847, (480, 1) = .7557746899991786, (480, 2) = .5804020101, (481, 1) = .754987936365745, (481, 2) = .5798331004258871, (482, 1) = .7540704239167212, (482, 2) = .5768844222, (483, 1) = .7539627708881196, (483, 2) = .5767939230768193, (484, 1) = .7537688442, (484, 2) = .5763388147300418, (485, 1) = .749920454738908, (485, 2) = .5751627493226872, (486, 1) = .7502967109764029, (486, 2) = .5733668342, (487, 1) = .7485199994771032, (487, 2) = .5722987071567582, (488, 1) = .7480444164864417, (488, 2) = .5698492463, (489, 1) = .7473545920573336, (489, 2) = .5693249760346543, (490, 1) = .7462519616831753, (490, 2) = .5663316583, (491, 1) = .7462446452833709, (491, 2) = .566325363207796, (492, 1) = .7462311558, (492, 2) = .5662963205225036, (493, 1) = .7423910852437003, (493, 2) = .56460610329231, (494, 1) = .7423854545821322, (494, 2) = .5628140704, (495, 1) = .7408624230141795, (495, 2) = .5618018910858994, (496, 1) = .7401474389059498, (496, 2) = .5592964825, (497, 1) = .739609202013443, (497, 2) = .558869139629677, (498, 1) = .7386934673000001, (498, 2) = .5566994627265854, (499, 1) = .7373337242500462, (499, 2) = .5564134412710765, (500, 1) = .7375529280200395, (500, 2) = .5557788945, (501, 1) = .7346089216718232, (501, 2) = .5541674278823114, (502, 1) = .7342999024776851, (502, 2) = .5522613066, (503, 1) = .733062385712161, (503, 2) = .5513715567340894, (504, 1) = .7321051772528755, (504, 2) = .5487437186, (505, 1) = .7317620125548746, (505, 2) = .5484608095626671, (506, 1) = .7311557789, (506, 2) = .5471755221786071, (507, 1) = .7288972832717391, (507, 2) = .5462800953065466, (508, 1) = .7289300200295219, (508, 2) = .5452261307, (509, 1) = .7266745141310627, (509, 2) = .5437997996525366, (510, 1) = .7260795175455097, (510, 2) = .5417085428, (511, 1) = .7251468695415849, (511, 2) = .5409951125271665, (512, 1) = .7239344481102331, (512, 2) = .5381909548, (513, 1) = .7238224227793333, (513, 2) = .5380955996914517, (514, 1) = .7236180904, (514, 2) = .5377004001994169, (515, 1) = .7205798536292655, (515, 2) = .5360912107182814, (516, 1) = .7203358064748968, (516, 2) = .5346733669, (517, 1) = .7186332419606867, (517, 2) = .5334820415579187, (518, 1) = .7177465380996019, (518, 2) = .5311557789, (519, 1) = .7171343576488055, (519, 2) = .5306639329333539, (520, 1) = .716080402, (520, 2) = .5285185728725448, (521, 1) = .7150690635072785, (521, 2) = .5281101489543252, (522, 1) = .7150651474523091, (522, 2) = .527638191, (523, 1) = .7122825627912577, (523, 2) = .5258929280304899, (524, 1) = .7117254561452948, (524, 2) = .5241206031, (525, 1) = .7105078811503773, (525, 2) = .5232035248544668, (526, 1) = .709313814793679, (526, 2) = .5206030151, (527, 1) = .7090374677850002, (527, 2) = .5203721297713757, (528, 1) = .7085427135, (528, 2) = .5194599433133028, (529, 1) = .7061965922202815, (529, 2) = .5181802837909769, (530, 1) = .7059485994655371, (530, 2) = .5170854272000001, (531, 1) = .7039713812850835, (531, 2) = .5157011276154781, (532, 1) = .7030763413046126, (532, 2) = .5135678392, (533, 1) = .7023107244229887, (533, 2) = .5129585128527364, (534, 1) = .7010050251, (534, 2) = .5104631685122588, (535, 1) = .7005554626379362, (535, 2) = .510260047114437, (536, 1) = .700532426213646, (536, 2) = .5100502513, (537, 1) = .6975634682865297, (537, 2) = .5081387232371546, (538, 1) = .6969674540361994, (538, 2) = .5065326634, (539, 1) = .6956310906601928, (539, 2) = .5055229115289454, (540, 1) = .6943755773322701, (540, 2) = .5030150754, (541, 1) = .6940487375441052, (541, 2) = .5027437550076268, (542, 1) = .6934673366999999, (542, 2) = .5017356084998368, (543, 1) = .6913371583211333, (543, 2) = .5004915707246309, (544, 1) = .6910267347144636, (544, 2) = .4994974875, (545, 1) = .6890134177468648, (545, 2) = .49805839503115934, (546, 1) = .6880274190127694, (546, 2) = .4959798995, (547, 1) = .6872536468046716, (547, 2) = .49536203349619656, (548, 1) = .6859296482, (548, 2) = .49301879363440343, (549, 1) = .685365858020765, (549, 2) = .49272541368214706, (550, 1) = .6853023469688783, (550, 2) = .4924623116, (551, 1) = .682474224619088, (551, 2) = .49055725469525724, (552, 1) = .6817575115020593, (552, 2) = .4889447237, (553, 1) = .6804849100825205, (553, 2) = .48796801354594393, (554, 1) = .6790822467362455, (554, 2) = .4854271357, (555, 1) = .678834251722961, (555, 2) = .48522073280379174, (556, 1) = .6783919598, (556, 2) = .48450428140603924, (557, 1) = .6760310197132064, (557, 2) = .48301131981962253, (558, 1) = .6755781421632182, (558, 2) = .4819095478, (559, 1) = .6737471333022285, (559, 2) = .48055954551950053, (560, 1) = .6725809693019373, (560, 2) = .4783919598, (561, 1) = .6719486597541052, (561, 2) = .4778812451977635, (562, 1) = .6708542713, (562, 2) = .47609475103423465, (563, 1) = .6697009134032972, (563, 2) = .4754126055820677, (564, 1) = .6694993265551618, (564, 2) = .4748743719, (565, 1) = .6670435226254972, (565, 2) = .47313513337132346, (566, 1) = .666112911098834, (566, 2) = .47135678400000003, (567, 1) = .6650697765711803, (567, 2) = .470538626934842, (568, 1) = .6634290004731302, (568, 2) = .467839196, (569, 1) = .663388825704418, (569, 2) = .46780548269146327, (570, 1) = .6633165829, (570, 2) = .4676961942750159, (571, 1) = .6603750781831043, (571, 2) = .46569431029341324, (572, 1) = .6596771357613036, (572, 2) = .4643216081, (573, 1) = .6581969611630083, (573, 2) = .4631931769649324, (574, 1) = .6567554866881687, (574, 2) = .4608040201, (575, 1) = .6564013509925426, (575, 2) = .46051354040513176, (576, 1) = .6557788945, (576, 2) = .4595730965627197, (577, 1) = .6537397262340544, (577, 2) = .458238044039406, (578, 1) = .653269570325969, (578, 2) = .4572864322, (579, 1) = .6513281106571419, (579, 2) = .4558458767206357, (580, 1) = .6500829412056062, (580, 2) = .4537688443, (581, 1) = .6494058675855644, (581, 2) = .45322533555491956, (582, 1) = .648241206, (582, 2) = .45146938976750345, (583, 1) = .6471314835186666, (583, 2) = .45076912680306686, (584, 1) = .6468824467628159, (584, 2) = .4502512563, (585, 1) = .6444595005529137, (585, 2) = .44849846426527284, (586, 1) = .6434065207570968, (586, 2) = .4467336684, (587, 1) = .6424001139154676, (587, 2) = .44594192343477523, (588, 1) = .6407035176, (588, 2) = .4433922488286544, (589, 1) = .640539879063162, (589, 2) = .44329244505124804, (590, 1) = .6405040091082581, (590, 2) = .4432160804, (591, 1) = .6375857072618107, (591, 2) = .4411534706302463, (592, 1) = .636719683162204, (592, 2) = .4396984925, (593, 1) = .6353810440093814, (593, 2) = .43866472556188096, (594, 1) = .6337205514840445, (594, 2) = .4361809046, (595, 1) = .6335194856748709, (595, 2) = .4360158648634963, (596, 1) = .6331658291, (596, 2) = .43552130590189286, (597, 1) = .6306997544480649, (597, 2) = .4338141514637429, (598, 1) = .630014403647833, (598, 2) = .4326633166, (599, 1) = .6283449534455033, (599, 2) = .43139547065930706, (600, 1) = .626831398160579, (600, 2) = .4291457287, (601, 1) = .6263912030507452, (601, 2) = .4287896329282202, (602, 1) = .6256281407, (602, 2) = .4277318173711414, (603, 1) = .6237934249672785, (603, 2) = .42648434138338354, (604, 1) = .6232814929969428, (604, 2) = .4256281407, (605, 1) = .6212876297995694, (605, 2) = .4241361245151448, (606, 1) = .6199136766926232, (606, 2) = .4221105528, (607, 1) = .6192411383681233, (607, 2) = .4215735659317196, (608, 1) = .6180904522, (608, 2) = .41999392989842765, (609, 1) = .616857782320856, (609, 2) = .41916821084032985, (610, 1) = .6165111271613823, (610, 2) = .4185929649, (611, 1) = .6142045961622684, (611, 2) = .4168887764255166, (612, 1) = .6129619753822434, (612, 2) = .4150753769, (613, 1) = .6120668188759711, (613, 2) = .4143688178685641, (614, 1) = .6105527638, (614, 2) = .412312865809618, (615, 1) = .6098837981359486, (615, 2) = .4118699729747824, (616, 1) = .6096934239531301, (616, 2) = .411557789, (617, 1) = .6070913933803693, (617, 2) = .4096555072325644, (618, 1) = .6059709460662753, (618, 2) = .408040201, (619, 1) = .6048658222920855, (619, 2) = .4071765191219374, (620, 1) = .6030150754, (620, 2) = .40469329619235833, (621, 1) = .602863103225005, (621, 2) = .40459353344698695, (622, 1) = .6028191648435827, (622, 2) = .4045226131, (623, 1) = .5999438705289032, (623, 2) = .4024382541126821, (624, 1) = .5989355752445181, (624, 2) = .4010050252, (625, 1) = .5976358992595766, (625, 2) = .39999771942265216, (626, 1) = .5957404771292144, (626, 2) = .3974874372, (627, 1) = .5956446569324523, (627, 2) = .3974093778530017, (628, 1) = .5954773869, (628, 2) = .397197178428286, (629, 1) = .5927584434127191, (629, 2) = .39523868958685016, (630, 1) = .5918514724459307, (630, 2) = .3939698493, (631, 1) = .5903751176564264, (631, 2) = .3928333203344865, (632, 1) = .5885520206003342, (632, 2) = .3904522613, (633, 1) = .5883280361978662, (633, 2) = .39027103704202615, (634, 1) = .5879396985, (634, 2) = .3897845642725306, (635, 1) = .5855323425286143, (635, 2) = .388058106165355, (636, 1) = .5847151459560386, (636, 2) = .3869346734, (637, 1) = .583081996106934, (637, 2) = .38568401324046714, (638, 1) = .5813205236176994, (638, 2) = .3834170855, (639, 1) = .5809833455097835, (639, 2) = .3831457955928636, (640, 1) = .58040201, (640, 2) = .3824269427112342, (641, 1) = .5782637540893907, (641, 2) = .3808973502809784, (642, 1) = .5775241560912212, (642, 2) = .3798994975, (643, 1) = .5757555660659562, (643, 2) = .3785502500902252, (644, 1) = .5740446234513643, (644, 2) = .3763819096, (645, 1) = .5736101496605641, (645, 2) = .3760338564971544, (646, 1) = .5728643216, (646, 2) = .3751237128720331, (647, 1) = .5709518864082601, (647, 2) = .3737567913764426, (648, 1) = .5702772216056209, (648, 2) = .3728643216, (649, 1) = .5683954495706423, (649, 2) = .3714322073018429, (650, 1) = .5667237108415353, (650, 2) = .3693467337, (651, 1) = .5662084085110162, (651, 2) = .3689352385571988, (652, 1) = .5653266332, (652, 2) = .36787345287702866, (653, 1) = .5635969930978948, (653, 2) = .3666363111656846, (654, 1) = .5629742751203055, (654, 2) = .3658291458, (655, 1) = .5610018707510682, (655, 2) = .3643297802952932, (656, 1) = .5593579214862341, (656, 2) = .3623115578, (657, 1) = .5587784698638669, (657, 2) = .36184977939894725, (658, 1) = .5577889447, (658, 2) = .3606740064671954, (659, 1) = .5562002812612103, (659, 2) = .35953534616721994, (660, 1) = .5556163996636694, (660, 2) = .3587939699, (661, 1) = .5535756490882806, (661, 2) = .3572425865635195, (662, 1) = .5519481774786923, (662, 2) = .3552763819, (663, 1) = .5513210977851705, (663, 2) = .3547771225430924, (664, 1) = .5502512563, (664, 2) = .3535225218982832, (665, 1) = .5487638237914856, (665, 2) = .3524529291574846, (666, 1) = .548205776205795, (666, 2) = .351758794, (667, 1) = .5461181799936377, (667, 2) = .35016997500641434, (668, 1) = .544496180139183, (668, 2) = .3482412061, (669, 1) = .5438374735468877, (669, 2) = .34771671674648225, (670, 1) = .5427135678, (670, 2) = .34641553129293345, (671, 1) = .5412904328298684, (671, 2) = .3453877477678323, (672, 1) = .5407455821183196, (672, 2) = .3447236181, (673, 1) = .5386313821145924, (673, 2) = .3431110501756922, (674, 1) = .5370043558098199, (674, 2) = .3412060302, (675, 1) = .5363291734444303, (675, 2) = .3406678263003589, (676, 1) = .5351758794, (676, 2) = .33934905705466345, (677, 1) = .5337835154128445, (677, 2) = .3383382120668299, (678, 1) = .5332398612580557, (678, 2) = .3376884422, (679, 1) = .5311176601280995, (679, 2) = .33606468992432753, (680, 1) = .5294758544975693, (680, 2) = .3341708543, (681, 1) = .5287981735955245, (681, 2) = .33362952905234794, (682, 1) = .5276381909, (682, 2) = .3323186760003023, (683, 1) = .5262469554379412, (683, 2) = .331302509611936, (684, 1) = .5256934115411425, (684, 2) = .3306532664, (685, 1) = .5235798548993649, (685, 2) = .3290295685767022, (686, 1) = .5219145061356738, (686, 2) = .3271356784, (687, 1) = .5212468376963585, (687, 2) = .3266007219780744, (688, 1) = .5201005025000001, (688, 2) = .3253195784676084, (689, 1) = .5186850235658629, (689, 2) = .32427864733217493, (690, 1) = .5181117055244628, (690, 2) = .3236180905, (691, 1) = .5160212069601587, (691, 2) = .32200417379522084, (692, 1) = .5143247836090906, (692, 2) = .3201005025, (693, 1) = .5136779093293781, (693, 2) = .319580124729249, (694, 1) = .5125628141, (694, 2) = .31834660021807604, (695, 1) = .5111023195067798, (695, 2) = .31726447873058555, (696, 1) = .5105008431478002, (696, 2) = .3165829146, (697, 1) = .5084453397499787, (697, 2) = .3149868146935932, (698, 1) = .5067117899829481, (698, 2) = .3130653267, (699, 1) = .5060945113548043, (699, 2) = .3125662800096956, (700, 1) = .5050251256, (700, 2) = .31139425376022367, (701, 1) = .5035037033920832, (701, 2) = .3102577357465086, (702, 1) = .5028674645938366, (702, 2) = .3095477387, (703, 1) = .5008562487621461, (703, 2) = .3079756266466038, (704, 1) = .49908128227054965, (704, 2) = .3060301508, (705, 1) = .4985001758104025, (705, 2) = .3055575394377303, (706, 1) = .4974874372, (706, 2) = .304456676546889, (707, 1) = .4958943147128132, (707, 2) = .3032560199677323, (708, 1) = .49521878144648995, (708, 2) = .3025125628, (709, 1) = .4932583275103768, (709, 2) = .30096855938442, (710, 1) = .49143970647138974, (710, 2) = .2989949749, (711, 1) = .4908988792003061, (711, 2) = .298552047341585, (712, 1) = .4899497487, (712, 2) = .29752756673713127, (713, 1) = .48827959177296715, (713, 2) = .29625679356151713, (714, 1) = .48756259349954817, (714, 2) = .295477387, (715, 1) = .48565636950125635, (715, 2) = .2939633760049808, (716, 1) = .48379416623613464, (716, 2) = .291959799, (717, 1) = .48329505343318435, (717, 2) = .2915477355401902, (718, 1) = .4824120603, (718, 2) = .29060010572401485, (719, 1) = .48066534454485493, (719, 2) = .289257345103619, (720, 1) = .47990739947365446, (720, 2) = .2884422111, (721, 1) = .4780556794864358, (721, 2) = .2869576008322615, (722, 1) = .47615259656772946, (722, 2) = .2849246231, (723, 1) = .4756936967468298, (723, 2) = .2845422714653925, (724, 1) = .47487437180000003, (724, 2) = .28366679383246324, (725, 1) = .47305780017959376, (725, 2) = .2822547686180363, (726, 1) = .4722624051299407, (726, 2) = .2814070352, (727, 1) = .4704621014253052, (727, 2) = .27994850679648364, (728, 1) = .4685237910654614, (728, 2) = .2778894473, (729, 1) = .46810043644502464, (729, 2) = .27753302920421585, (730, 1) = .4673366834, (730, 2) = .27671924899829126, (731, 1) = .46546377749248996, (731, 2) = .2752458820767158, (732, 1) = .46463777623472186, (732, 2) = .2743718593, (733, 1) = .462882201913298, (733, 2) = .2729330294153084, (734, 1) = .4609176282518206, (734, 2) = .2708542714, (735, 1) = .46052168811302885, (735, 2) = .2705170146062497, (736, 1) = .459798995, (736, 2) = .2697479304931192, (737, 1) = .45789077658558486, (737, 2) = .26822718533516565, (738, 1) = .4570446831118084, (738, 2) = .2673366834, (739, 1) = .45532332511948964, (739, 2) = .26590774140465334, (740, 1) = .4533450939443153, (740, 2) = .2638190955, (741, 1) = .4529647331489658, (741, 2) = .26349082973670407, (742, 1) = .4522613065, (742, 2) = .26274186058939175, (743, 1) = .45034718990228606, (743, 2) = .26119476200718766, (744, 1) = .4494955971073297, (744, 2) = .2603015076, (745, 1) = .4477938652157189, (745, 2) = .258868725580079, (746, 1) = .4458186726999408, (746, 2) = .2567839196, (747, 1) = .44543801222302604, (747, 2) = .2564505356778167, (748, 1) = .4447236181, (748, 2) = .2556880681641911, (749, 1) = .4428425490702933, (749, 2) = .2541441638972261, (750, 1) = .44200453441815535, (750, 2) = .2532663317, (751, 1) = .4403034553215288, (751, 2) = .2518114863495001, (752, 1) = .4383524930074799, (752, 2) = .2497487437, (753, 1) = .4379513052215547, (753, 2) = .24939156841671048, (754, 1) = .4371859296, (754, 2) = .24857107563014877, (755, 1) = .4353877964736239, (755, 2) = .24707028458753777, (756, 1) = .4345873846928278, (756, 2) = .2462311558, (757, 1) = .43286326512169326, (757, 2) = .24473081131174035, (758, 1) = .4309626518773221, (758, 2) = .2427135679, (759, 1) = .43051604146422656, (759, 2) = .2423085944341507, (760, 1) = .4296482412, (760, 2) = .24137212881002684, (761, 1) = .4279956301622233, (761, 2) = .23996719840183553, (762, 1) = .42726228438416436, (762, 2) = .2391959799, (763, 1) = .4254864014928762, (763, 2) = .23762058385228169, (764, 1) = .4236677223513047, (764, 2) = .235678392, (765, 1) = .42314575835299, (765, 2) = .23519529606428433, (766, 1) = .4221105528, (766, 2) = .23406808191854572, (767, 1) = .4206809764038216, (767, 2) = .23282793965787185, (768, 1) = .42005011927364955, (768, 2) = .232160804, (769, 1) = .41818835035804597, (769, 2) = .23047357720488884, (770, 1) = .4164891423916891, (770, 2) = .2286432161, (771, 1) = .41585654734415745, (771, 2) = .22804416402407998, (772, 1) = .4145728643, (772, 2) = .22663005384130125, (773, 1) = .4134615419041726, (773, 2) = .22564424531510408, (774, 1) = .4129751290419361, (774, 2) = .2251256282, (775, 1) = .41098762195120536, (775, 2) = .22328115333415552, (776, 1) = .409451948899132, (776, 2) = .2216080402, (777, 1) = .40866775863832683, (777, 2) = .22084616825977926, (778, 1) = .4070351759, (778, 2) = .21902147969544994, (779, 1) = .40635849858888623, (779, 2) = .2184062350392016, (780, 1) = .40606557138981003, (780, 2) = .2180904523, (781, 1) = .40390643609215177, (781, 2) = .21603294289083183, (782, 1) = .4025853816638798, (782, 2) = .2145728643, (783, 1) = .40160277314883797, (783, 2) = .21359039763582902, (784, 1) = .3994974874, (784, 2) = .2111953916267515, (785, 1) = .3993974872014272, (785, 2) = .21110194315906863, (786, 1) = .3993548061582575, (786, 2) = .2110552764, (787, 1) = .3969718915680006, (787, 2) = .20871629988156515, (788, 1) = .3959241588145738, (788, 2) = .2075376885, (789, 1) = .39469021826668604, (789, 2) = .20626349281323436, (790, 1) = .39275962858671026, (790, 2) = .2040201005, (791, 1) = .392519651602392, (791, 2) = .20375883595370253, (792, 1) = .391959799, (792, 2) = .20308410518162512, (793, 1) = .39021706301913595, (793, 2) = .20131578937565633, (794, 1) = .38950935111294255, (794, 2) = .2005025126, (795, 1) = .38796528144486087, (795, 2) = .1988490328100629, (796, 1) = .3864011183684566, (796, 2) = .1969849246, (797, 1) = .38582386658866763, (797, 2) = .19633077177101954, (798, 1) = .3844221105, (798, 2) = .19459086094504696, (799, 1) = .3836829143299022, (799, 2) = .193812294910751, (800, 1) = .3833902777843438, (800, 2) = .1934673367, (801, 1) = .381471712002041, (801, 2) = .1913266014245525, (802, 1) = .38035036929423216, (802, 2) = .1899497488, (803, 1) = .3793717347632515, (803, 2) = .18878900286408398, (804, 1) = .3775375943541058, (804, 2) = .1864321608, (805, 1) = .37736166644215346, (805, 2) = .18620944677492798, (806, 1) = .3768844221, (806, 2) = .18556448319466476, (807, 1) = .37526450636538733, (807, 2) = .18367053357185437, (808, 1) = .37467008495738585, (808, 2) = .1829145729, (809, 1) = .3732225171948196, (809, 2) = .1811058738946159, (810, 1) = .3719455222249287, (810, 2) = .1793969849, (811, 1) = .37127502391601463, (811, 2) = .1784971161376429, (812, 1) = .3694265308925138, (812, 2) = .175879397, (813, 1) = .36940710803346855, (813, 2) = .17585122231120817, (814, 1) = .3693467337, (814, 2) = .17576016082628151, (815, 1) = .3674517163812426, (815, 2) = .17324615049865977, (816, 1) = .36682165777307724, (816, 2) = .1723618091, (817, 1) = .36559224125493306, (817, 2) = .1705963175909678, (818, 1) = .36442118216746267, (818, 2) = .1688442211, (819, 1) = .3638217120726433, (819, 2) = .16790497657723402, (820, 1) = .36221745198925714, (820, 2) = .1653266332, (821, 1) = .3621305321083684, (821, 2) = .16517660597467304, (822, 1) = .3618090452, (822, 2) = .16461658191612735, (823, 1) = .36042004933611393, (823, 2) = .1624572432845554, (824, 1) = .36001413241598124, (824, 2) = .1618090452, (825, 1) = .35878654053790004, (825, 2) = .1597019594676269, (826, 1) = .35797284794656337, (826, 2) = .1582914573, (827, 1) = .3572489110137369, (827, 2) = .15690193200815655, (828, 1) = .35613069273590464, (828, 2) = .1547738694, (829, 1) = .35580307897280694, (829, 2) = .15405906570310007, (830, 1) = .35448015596563326, (830, 2) = .1512562814, (831, 1) = .35444769995839687, (831, 2) = .15117398792654935, (832, 1) = .3542713568, (832, 2) = .15075051674419104, (833, 1) = .35313609511999666, (833, 2) = .14826848227396078, (834, 1) = .3528862293167243, (834, 2) = .1477386935, (835, 1) = .3519356554209787, (835, 2) = .14531109948720555, (836, 1) = .3514838197463479, (836, 2) = .1442211055, (837, 1) = .3508593758497697, (837, 2) = .14229577534659707, (838, 1) = .3502938221071534, (838, 2) = .1407035176, (839, 1) = .34991447247732055, (839, 2) = .13921914234538285, (840, 1) = .34931756648448753, (840, 2) = .1371859297, (841, 1) = .34911207147452883, (841, 2) = .1360760082080354, (842, 1) = .3485591799566558, (842, 2) = .1336683417, (843, 1) = .34846783507255363, (843, 2) = .13285906388814606, (844, 1) = .3480257881214767, (844, 2) = .1301507538, (845, 1) = .34800289002801055, (845, 2) = .12955845032131563, (846, 1) = .3477271310309451, (846, 2) = .1266331658, (847, 1) = .34774494448408766, (847, 2) = .1261612369230366, (848, 1) = .34767622997613645, (848, 2) = .1231155779, (849, 1) = .3477303651018057, (849, 2) = .12265045273463923, (850, 1) = .34788888406570395, (850, 2) = .11959799, (851, 1) = .3480062614091848, (851, 2) = .11900411321008608, (852, 1) = .34838511373913356, (852, 2) = .116080402, (853, 1) = .34863491884857173, (853, 2) = .11519315176081538, (854, 1) = .34918839173015104, (854, 2) = .1125628141, (855, 1) = .3496982391676152, (855, 2) = .11117934768200291, (856, 1) = .3503275726503486, (856, 2) = .1090452261, (857, 1) = .35130638070456277, (857, 2) = .10691129368498048, (858, 1) = .3518364954202148, (858, 2) = .1055276382, (859, 1) = .35360882560815554, (859, 2) = .10231923151700102, (860, 1) = .3537558522159866, (860, 2) = .1020100503, (861, 1) = .3542713568, (861, 2) = .10121702392963003, (862, 1) = .35600053248665653, (862, 2) = 0.9849246232e-1, (863, 1) = .3570572854492312, (863, 2) = 0.971923622763001e-1, (864, 1) = .3586926055897353, (864, 2) = 0.9497487438e-1, (865, 1) = .3618090452, (865, 2) = 0.9158716902677788e-1, (866, 1) = .36192709856954863, (866, 2) = 0.9145728644e-1, (867, 1) = .36205005931326456, (867, 2) = 0.9134481318799587e-1, (868, 1) = .3655390548364391, (868, 2) = 0.879396985e-1, (869, 1) = .3693467337, (869, 2) = 0.8479882969331587e-1, (870, 1) = .3698033059098153, (870, 2) = 0.8442211056e-1, (871, 1) = .3706635536566944, (871, 2) = 0.8380759457671531e-1, (872, 1) = .3745661678736847, (872, 2) = 0.8090452262e-1, (873, 1) = .3768844221, (873, 2) = 0.7939356176205672e-1, (874, 1) = .3799996782143442, (874, 2) = 0.7738693467999999e-1, (875, 1) = .3844221105, (875, 2) = 0.7484642389505781e-1, (876, 1) = .3861556705887529, (876, 2) = 0.7386934674000001e-1, (877, 1) = .391959799, (877, 2) = 0.7090689451692438e-1, (878, 1) = .3930765595362171, (878, 2) = 0.703517588e-1, (879, 1) = .3994974874, (879, 2) = 0.6742285625731652e-1, (880, 1) = .40083272374395407, (880, 2) = 0.6683417086e-1, (881, 1) = .4070351759, (881, 2) = 0.6429437718838504e-1, (882, 1) = .40952543844393996, (882, 2) = 0.6331658292e-1, (883, 1) = .4145728643, (883, 2) = 0.6145535700961236e-1, (884, 1) = .4192968081098093, (884, 2) = 0.59798994980000006e-1, (885, 1) = .4221105528, (885, 2) = 0.58862877992759986e-1, (886, 1) = .4282230450362326, (886, 2) = 0.56946498586872965e-1, (887, 1) = .4296482412, (887, 2) = 0.5648318909637347e-1, (888, 1) = .4303077493632227, (888, 2) = 0.56281407039999995e-1, (889, 1) = .4371859296, (889, 2) = 0.54259072419220275e-1, (890, 1) = .44264178968086776, (890, 2) = 0.527638191e-1, (891, 1) = .4447236181, (891, 2) = 0.52210303355024364e-1, (892, 1) = .4472230956927635, (892, 2) = 0.515973962167451e-1, (893, 1) = .4522613065, (893, 2) = 0.50284417107303435e-1, (894, 1) = .45658545521222793, (894, 2) = 0.4924623116e-1, (895, 1) = .459798995, (895, 2) = 0.4848899261063059e-1, (896, 1) = .46280252505544006, (896, 2) = 0.4784458379282528e-1, (897, 1) = .4673366834, (897, 2) = 0.46795889980450964e-1, (898, 1) = .47240959498250634, (898, 2) = 0.4572864322e-1, (899, 1) = .47487437180000003, (899, 2) = 0.4521380652728622e-1, (900, 1) = .4767185263750812, (900, 2) = 0.44868037758152964e-1, (901, 1) = .4824120603, (901, 2) = 0.4369939046343149e-1, (902, 1) = .48959308784095523, (902, 2) = 0.4237749701516724e-1, (903, 1) = .4899497487, (903, 2) = 0.4230553368836941e-1, (904, 1) = .49047231758269894, (904, 2) = 0.4221105528e-1, (905, 1) = .4974874372, (905, 2) = 0.4093529701697809e-1, (906, 1) = .5016543282464547, (906, 2) = 0.4026650611393161e-1, (907, 1) = .5050251256, (907, 2) = 0.396633456864977e-1, (908, 1) = .5111714689337563, (908, 2) = 0.3869346734e-1, (909, 1) = .5125628141, (909, 2) = 0.3846993033295939e-1, (910, 1) = .5132454260727137, (910, 2) = 0.3837491508425573e-1, (911, 1) = .5201005025000001, (911, 2) = 0.3729037232594075e-1, (912, 1) = .5243561999220785, (912, 2) = 0.3670747519840497e-1, (913, 1) = .5276381909, (913, 2) = 0.361960293284916e-1, (914, 1) = .5351639749169139, (914, 2) = 0.35181434825398046e-1, (915, 1) = .5351758794, (915, 2) = 0.3517960712411226e-1, (916, 1) = .5352039640893407, (916, 2) = 0.351758794e-1, (917, 1) = .5427135678, (917, 2) = 0.3414537152140694e-1, (918, 1) = .5456536286452462, (918, 2) = 0.3380385101595303e-1, (919, 1) = .5502512563, (919, 2) = 0.3318185834638168e-1, (920, 1) = .5559125375649836, (920, 2) = 0.32533948127986365e-1, (921, 1) = .5577889447, (921, 2) = 0.32283633189427896e-1, (922, 1) = .5633336520075796, (922, 2) = 0.3165829146e-1, (923, 1) = .5653266332, (923, 2) = 0.3142227202497525e-1, (924, 1) = .565966100123562, (924, 2) = 0.31359873560641016e-1, (925, 1) = .5728643216, (925, 2) = 0.305538817413697e-1, (926, 1) = .5758455924285844, (926, 2) = 0.30267031732083685e-1, (927, 1) = .58040201, (927, 2) = 0.29741684432756765e-1, (928, 1) = .5855573291499552, (928, 2) = 0.29252475874925958e-1, (929, 1) = .5879396985, (929, 2) = 0.2898136940407693e-1, (930, 1) = .595115285505753, (930, 2) = 0.283096841716094e-1, (931, 1) = .5954773869, (931, 2) = 0.28269007546813177e-1, (932, 1) = .5968666341939834, (932, 2) = 0.2814070352e-1, (933, 1) = .6030150754, (933, 2) = 0.2753280844868558e-1, (934, 1) = .6045819714386098, (934, 2) = 0.2740948536449127e-1, (935, 1) = .6105527638, (935, 2) = 0.26826477584338135e-1, (936, 1) = .6139314406005736, (936, 2) = 0.2656398767076758e-1, (937, 1) = .6180904522, (937, 2) = 0.26162862729445055e-1, (938, 1) = .6231622868236661, (938, 2) = 0.2577384738023213e-1, (939, 1) = .6256281407, (939, 2) = 0.2553889994482989e-1, (940, 1) = .6322835703619627, (940, 2) = 0.25034836326758337e-1, (941, 1) = .6331658291, (941, 2) = 0.24951778970738848e-1, (942, 1) = .6375598731700047, (942, 2) = 0.2462311558e-1, (943, 1) = .6407035176, (943, 2) = 0.24365645583709933e-1, (944, 1) = .6413404044011137, (944, 2) = 0.24325901737790392e-1, (945, 1) = .648241206, (945, 2) = 0.2376726243192491e-1, (946, 1) = .650354354409826, (946, 2) = 0.2363697966289041e-1, (947, 1) = .6557788945, (947, 2) = 0.23202876747452174e-1, (948, 1) = .6592792159444876, (948, 2) = 0.22989632229951592e-1, (949, 1) = .6633165829, (949, 2) = 0.22670196423136894e-1, (950, 1) = .6681212854119927, (950, 2) = 0.223809210616549e-1, (951, 1) = .6708542713, (951, 2) = 0.22167107750822528e-1, (952, 1) = .6768863475434768, (952, 2) = 0.21808146687717637e-1, (953, 1) = .6783919598, (953, 2) = 0.21691659655115058e-1, (954, 1) = .6855797218834964, (954, 2) = 0.2126882658863016e-1, (955, 1) = .6859296482, (955, 2) = 0.21242049584500284e-1, (956, 1) = .6882769815080421, (956, 2) = 0.2110552764e-1, (957, 1) = .6934673366999999, (957, 2) = 0.20765257463606517e-1, (958, 1) = .6942782870063637, (958, 2) = 0.20727084161545162e-1, (959, 1) = .7010050251, (959, 2) = 0.2029078959933281e-1, (960, 1) = .7029443560795692, (960, 2) = 0.2020050651105533e-1, (961, 1) = .7085427135, (961, 2) = 0.19841225711516006e-1, (962, 1) = .7115485178221507, (962, 2) = 0.19702818966963537e-1, (963, 1) = .716080402, (963, 2) = 0.1941501363032748e-1, (964, 1) = .7200947644244649, (964, 2) = 0.1923215849793163e-1, (965, 1) = .7236180904, (965, 2) = 0.19010712863990607e-1, (966, 1) = .7285867916455377, (966, 2) = 0.18786800409660548e-1, (967, 1) = .7311557789, (967, 2) = 0.18626985602721843e-1, (968, 1) = .7370280236098778, (968, 2) = 0.1836514675980933e-1, (969, 1) = .7386934673000001, (969, 2) = 0.1826258831020113e-1, (970, 1) = .7454216355278264, (970, 2) = 0.17965715824150474e-1, (971, 1) = .7462311558, (971, 2) = 0.17916364329992548e-1, (972, 1) = .7537520904730234, (972, 2) = 0.175879397e-1, (973, 1) = .7537688442, (973, 2) = 0.1758708291517289e-1, (974, 1) = .7537708232711489, (974, 2) = 0.1758701613345861e-1, (975, 1) = .7613065326, (975, 2) = 0.17205408105431967e-1, (976, 1) = .762189441390788, (976, 2) = 0.17175915600755754e-1, (977, 1) = .7688442211, (977, 2) = 0.16842180636616112e-1, (978, 1) = .7705641600195864, (978, 2) = 0.16785301532962777e-1, (979, 1) = .7763819095, (979, 2) = 0.16496341045990695e-1, (980, 1) = .7788975599900472, (980, 2) = 0.16413969480211094e-1, (981, 1) = .783919598, (981, 2) = 0.161669001252912e-1, (982, 1) = .7871920474477319, (982, 2) = 0.16060796615708868e-1, (983, 1) = .7914572864, (983, 2) = 0.15852933714335812e-1, (984, 1) = .7954498668852796, (984, 2) = 0.15724735487661082e-1, (985, 1) = .7989949749, (985, 2) = 0.15553577831292395e-1, (986, 1) = .8036731134194652, (986, 2) = 0.15404808378503531e-1, (987, 1) = .8065326633000001, (987, 2) = 0.1526802429009741e-1, (988, 1) = .8118637441392688, (988, 2) = 0.15100101960862838e-1, (989, 1) = .8140703517000001, (989, 2) = 0.14995516542107262e-1, (990, 1) = .820023588478201, (990, 2) = 0.14809762557900735e-1, (991, 1) = .8216080402, (991, 2) = 0.14735345990338197e-1, (992, 1) = .828154357305367, (992, 2) = 0.14532991700125845e-1, (993, 1) = .8291457286, (993, 2) = 0.14486848543279984e-1, (994, 1) = .8362576521039642, (994, 2) = 0.14269042089977133e-1, (995, 1) = .8366834170999999, (995, 2) = 0.1424940141519132e-1, (996, 1) = .8425838567082613, (996, 2) = 0.1407035176e-1, (997, 1) = .8442211055, (997, 2) = 0.14008820617902599e-1, (998, 1) = .8443593944967582, (998, 2) = 0.14005816894479228e-1, (999, 1) = .8517587939, (999, 2) = 0.137301598694701e-1, (1000, 1) = .8525230281459295, (1000, 2) = 0.13713709114603212e-1, (1001, 1) = .8592964824, (1001, 2) = 0.13463554679394443e-1, (1002, 1) = .8606590540865626, (1002, 2) = 0.1343448496932211e-1, (1003, 1) = .8668341708, (1003, 2) = 0.1320838470286819e-1, (1004, 1) = .8687689137120126, (1004, 2) = 0.13167471741238845e-1, (1005, 1) = .8743718593, (1005, 2) = 0.12964066476802675e-1, (1006, 1) = .87685396181245, (1006, 2) = 0.12912037247604214e-1, (1007, 1) = .8819095477, (1007, 2) = 0.12730051028875658e-1, (1008, 1) = .8849154718718103, (1008, 2) = 0.12667587157122835e-1, (1009, 1) = .8894472362, (1009, 2) = 0.12505821439256576e-1, (1010, 1) = .8929546421108857, (1010, 2) = 0.1243356232561369e-1, (1011, 1) = .8969849246, (1011, 2) = 0.12290890824841728e-1, (1012, 1) = .9009726001279909, (1012, 2) = 0.1220943650302366e-1, (1013, 1) = .904522613, (1013, 2) = 0.12084800358004747e-1, (1014, 1) = .9089704079143057, (1014, 2) = 0.11994714149059275e-1, (1015, 1) = .9120603015, (1015, 2) = 0.11887117334707719e-1, (1016, 1) = .9169490659352877, (1016, 2) = 0.11788928343894226e-1, (1017, 1) = .9195979899, (1017, 2) = 0.11697433621062113e-1, (1018, 1) = .9249095173296698, (1018, 2) = 0.11591638978278456e-1, (1019, 1) = .9271356784, (1019, 2) = 0.11515363969705617e-1, (1020, 1) = .9328526515029625, (1020, 2) = 0.11402430963448429e-1, (1021, 1) = .9346733668, (1021, 2) = 0.11340544619749256e-1, (1022, 1) = .9407793076969329, (1022, 2) = 0.11220912658563596e-1, (1023, 1) = .9422110552, (1023, 2) = 0.1117263192432869e-1, (1024, 1) = .9486902783114621, (1024, 2) = 0.11046714330906418e-1, (1025, 1) = .9497487437000001, (1025, 2) = 0.1101130107700609e-1, (1026, 1) = .9565863114418658, (1026, 2) = 0.10879486795653657e-1, (1027, 1) = .9572864321, (1027, 2) = 0.10856244955774159e-1, (1028, 1) = .9644681142626971, (1028, 2) = 0.10718900109481845e-1, (1029, 1) = .9648241206, (1029, 2) = 0.10707173025501376e-1, (1030, 1) = .9723363549339009, (1030, 2) = 0.10564642384247074e-1, (1031, 1) = .972361809, (1031, 2) = 0.10563810333045955e-1, (1032, 1) = .972948630488885, (1032, 2) = 0.1055276382e-1, (1033, 1) = .9798994975, (1033, 2) = 0.10375296743919172e-1, (1034, 1) = .9802894902052824, (1034, 2) = 0.10370767223166771e-1, (1035, 1) = .9874371859, (1035, 2) = 0.10189649970835095e-1, (1036, 1) = .9882349895451341, (1036, 2) = 0.10180455450153872e-1, (1037, 1) = .9949748743, (1037, 2) = 0.10010949173809373e-1, (1038, 1) = .9961650738976088, (1038, 2) = 0.999733736006387e-2, (1039, 1) = 1.002512563, (1039, 2) = 0.9838884859509671e-2, (1040, 1) = 1.0040804354592772, (1040, 2) = 0.982108996268309e-2, (1041, 1) = 1.010050251, (1041, 2) = 0.9673163544900765e-2, (1042, 1) = 1.0119817298630203, (1042, 2) = 0.9651407083880376e-2, (1043, 1) = 1.01758794, (1043, 2) = 0.9513506697126249e-2, (1044, 1) = 1.019869580330979, (1044, 2) = 0.9487998269652366e-2, (1045, 1) = 1.025125628, (1045, 2) = 0.9359650041939265e-2, (1046, 1) = 1.0277445763542137, (1046, 2) = 0.9330588011703222e-2, (1047, 1) = 1.032663317, (1047, 2) = 0.9211342550790206e-2, (1048, 1) = 1.0356072791518431, (1048, 2) = 0.9178914735089576e-2, (1049, 1) = 1.040201005, (1049, 2) = 0.9068345848323164e-2, (1050, 1) = 1.0434582198901152, (1050, 2) = 0.9032730115307322e-2, (1051, 1) = 1.047738693, (1051, 2) = 0.8930433399104435e-2, (1052, 1) = 1.0512979052007219, (1052, 2) = 0.8891798249098935e-2, (1053, 1) = 1.055276382, (1053, 2) = 0.8797389809478761e-2, (1054, 1) = 1.0591268151015514, (1054, 2) = 0.8755894933705672e-2, (1055, 1) = 1.06281407, (1055, 2) = 0.8669010341211997e-2, (1056, 1) = 1.0669454061442312, (1056, 2) = 0.8624807095195669e-2, (1057, 1) = 1.070351759, (1057, 2) = 0.8545100142396437e-2, (1058, 1) = 1.0747541125000146, (1058, 2) = 0.849833206595714e-2, (1059, 1) = 1.077889447, (1059, 2) = 0.8425473873461183e-2, (1060, 1) = 1.0825533475002227, (1060, 2) = 0.8376277080769497e-2, (1061, 1) = 1.085427136, (1061, 2) = 0.8309955025592194e-2, (1062, 1) = 1.0903435038637583, (1062, 2) = 0.825845868211691e-2, (1063, 1) = 1.092964824, (1063, 2) = 0.8198375587480662e-2, (1064, 1) = 1.098124956361655, (1064, 2) = 0.8144702229217713e-2, (1065, 1) = 1.100502513, (1065, 2) = 0.8090575419868377e-2, (1066, 1) = 1.1058980607216682, (1066, 2) = 0.8034841401954203e-2, (1067, 1) = 1.108040201, (1067, 2) = 0.7986402020879288e-2, (1068, 1) = 1.1136631564424686, (1068, 2) = 0.7928717792678995e-2, (1069, 1) = 1.115577889, (1069, 2) = 0.7885709958806586e-2, (1070, 1) = 1.12142056817452, (1070, 2) = 0.7826180406757498e-2, (1071, 1) = 1.123115578, (1071, 2) = 0.7788360554924944e-2, (1072, 1) = 1.1291706029325228, (1072, 2) = 0.7727085352140572e-2, (1073, 1) = 1.130653266, (1073, 2) = 0.7694221588903191e-2, (1074, 1) = 1.136913555945145, (1074, 2) = 0.763129539487053e-2, (1075, 1) = 1.138190955, (1075, 2) = 0.76031668339430775e-2, (1076, 1) = 1.144649706412218, (1076, 2) = 0.7538679650546904e-2, (1077, 1) = 1.145728643, (1077, 2) = 0.75150758714770905e-2, (1078, 1) = 1.1523793233660806, (1078, 2) = 0.7449113211899923e-2, (1079, 1) = 1.153266332, (1079, 2) = 0.742983367651974e-2, (1080, 1) = 1.1601026607210896, (1080, 2) = 0.7362476896054679e-2, (1081, 1) = 1.16080402, (1081, 2) = 0.7347330459511903e-2, (1082, 1) = 1.1678199639698905, (1082, 2) = 0.7278656876054324e-2, (1083, 1) = 1.168341709, (1083, 2) = 0.72674612771414715e-2, (1084, 1) = 1.1755314643121628, (1084, 2) = 0.7197544477196978e-2, (1085, 1) = 1.175879397, (1085, 2) = 0.7190125892962781e-2, (1086, 1) = 1.1832373850662354, (1086, 2) = 0.71190358540171176e-2, (1087, 1) = 1.183417085, (1087, 2) = 0.71152284588298234e-2, (1088, 1) = 1.1909379399404183, (1088, 2) = 0.7043031773890721e-2, (1089, 1) = 1.190954774, (1089, 2) = 0.7042677335802723e-2, (1090, 1) = 1.1917412351176269, (1090, 2) = 0.7035175879999999e-2, (1091, 1) = 1.198492462, (1091, 2) = 0.6930572699126082e-2, (1092, 1) = 1.1987185238181046, (1092, 2) = 0.69296803726821305e-2, (1093, 1) = 1.206030151, (1093, 2) = 0.6817094642930465e-2, (1094, 1) = 1.2065014290735379, (1094, 2) = 0.681524609942756e-2, (1095, 1) = 1.213567839, (1095, 2) = 0.6707104748696734e-2, (1096, 1) = 1.214276769996557, (1096, 2) = 0.67043414393934e-2, (1097, 1) = 1.221105528, (1097, 2) = 0.660047513151033e-2, (1098, 1) = 1.2220448262760126, (1098, 2) = 0.659683665877399e-2, (1099, 1) = 1.228643216, (1099, 2) = 0.6497083404960625e-2, (1100, 1) = 1.2298058622217876, (1100, 2) = 0.6492607611288709e-2, (1101, 1) = 1.236180904, (1101, 2) = 0.6396812289077833e-2, (1102, 1) = 1.2375601338214697, (1102, 2) = 0.639153534422181e-2, (1103, 1) = 1.243718593, (1103, 2) = 0.6299549430507505e-2, (1104, 1) = 1.2453078856874127, (1104, 2) = 0.6293505915632566e-2, (1105, 1) = 1.251256281, (1105, 2) = 0.6205187243968288e-2, (1106, 1) = 1.2530493503958227, (1106, 2) = 0.6198410223798384e-2, (1107, 1) = 1.25879397, (1107, 2) = 0.6113622509922266e-2, (1108, 1) = 1.2607847533153351, (1108, 2) = 0.6106143611594024e-2, (1109, 1) = 1.266331658, (1109, 2) = 0.6024756333067465e-2, (1110, 1) = 1.268514308313239, (1110, 2) = 0.601660580910859e-2, (1111, 1) = 1.273869347, (1111, 2) = 0.5938493832349033e-2, (1112, 1) = 1.2762382223896214, (1112, 2) = 0.59297006332274076e-2, (1113, 1) = 1.281407035, (1113, 2) = 0.58547440350789695e-2, (1114, 1) = 1.283956692368622, (1114, 2) = 0.5845335862589219e-2, (1115, 1) = 1.288944724, (1115, 2) = 0.5773419610608419e-2, (1116, 1) = 1.2916699086100987, (1116, 2) = 0.5763422987235457e-2, (1117, 1) = 1.296482412, (1117, 2) = 0.5694436786844592e-2, (1118, 1) = 1.299378052070196, (1118, 2) = 0.5683877101183213e-2, (1119, 1) = 1.3040201, (1119, 2) = 0.5617715132353588e-2, (1120, 1) = 1.307081298478856, (1120, 2) = 0.5606616695458106e-2, (1121, 1) = 1.311557789, (1121, 2) = 0.5543177397281742e-2, (1122, 1) = 1.314779815340327, (1122, 2) = 0.55315634995066285e-2, (1123, 1) = 1.319095477, (1123, 2) = 0.5470749445679901e-2, (1124, 1) = 1.3224737632974548, (1124, 2) = 0.5458642391049434e-2, (1125, 1) = 1.326633166, (1125, 2) = 0.540036000120043e-2, (1126, 1) = 1.3301632973227266, (1126, 2) = 0.53877811659392184e-2, (1127, 1) = 1.334170854, (1127, 2) = 0.5331940629590904e-2, (1128, 1) = 1.3378485658135628, (1128, 2) = 0.53189104938605476e-2, (1129, 1) = 1.341708543, (1129, 2) = 0.5265425527342091e-2, (1130, 1) = 1.3455297116798746, (1130, 2) = 0.5251963724623916e-2, (1131, 1) = 1.349246231, (1131, 2) = 0.5200751470099699e-2, (1132, 1) = 1.3532068721423451, (1132, 2) = 0.5186876816854617e-2, (1133, 1) = 1.35678392, (1133, 2) = 0.513785764049644e-2, (1134, 1) = 1.3608801791070615, (1134, 2) = 0.5123588184394362e-2, (1135, 1) = 1.364321608, (1135, 2) = 0.5076685573683551e-2, (1136, 1) = 1.3685497590319484, (1136, 2) = 0.5062038615830922e-2, (1137, 1) = 1.371859296, (1137, 2) = 0.50171790218632795e-2, (1138, 1) = 1.3762157350164028, (1138, 2) = 0.500217115594679e-2, (1139, 1) = 1.379396985, (1139, 2) = 0.4959283859897053e-2, (1140, 1) = 1.383878223746966, (1140, 2) = 0.49439310085502754e-2, (1141, 1) = 1.386934673, (1141, 2) = 0.4902948031323432e-2, (1142, 1) = 1.3915373385162417, (1142, 2) = 0.48872654645150965e-2, (1143, 1) = 1.394472362, (1143, 2) = 0.4848121398297026e-2, (1144, 1) = 1.399193187662768, (1144, 2) = 0.4832123774606931e-2, (1145, 1) = 1.40201005, (1145, 2) = 0.4794755721534188e-2, (1146, 1) = 1.4068458763116132, (1146, 2) = 0.477845710138426e-2, (1147, 1) = 1.409547739, (1147, 2) = 0.474280452752723e-2, (1148, 1) = 1.414495504702633, (1148, 2) = 0.4726218416447846e-2, (1149, 1) = 1.417085427, (1149, 2) = 0.4692223081836024e-2, (1150, 1) = 1.422142170476746, (1150, 2) = 0.46753624319423905e-2, (1151, 1) = 1.424623116, (1151, 2) = 0.4642968265171549e-2, (1152, 1) = 1.4297859664576211, (1152, 2) = 0.46258455248896204e-2, (1153, 1) = 1.432160804, (1153, 2) = 0.4594998559349632e-2, (1154, 1) = 1.437426982704413, (1154, 2) = 0.45776256735536765e-2, (1155, 1) = 1.439698492, (1155, 2) = 0.45482739392615785e-2, (1156, 1) = 1.4450653070434634, (1156, 2) = 0.45306623781697156e-2, (1157, 1) = 1.447236181, (1157, 2) = 0.4502755819620253e-2, (1158, 1) = 1.452701021972946, (1158, 2) = 0.44849166094580745e-2, (1159, 1) = 1.454773869, (1159, 2) = 0.4458407028562616e-2, (1160, 1) = 1.4603342089784799, (1160, 2) = 0.4440350748504083e-2, (1161, 1) = 1.462311558, (1161, 2) = 0.441519169049109e-2, (1162, 1) = 1.4679649448741687, (1162, 2) = 0.4396928517051396e-2, (1163, 1) = 1.469849246, (1163, 2) = 0.4373075238167609e-2, (1164, 1) = 1.475593305588006, (1164, 2) = 0.43546149370622626e-2, (1165, 1) = 1.477386935, (1165, 2) = 0.4332024301478836e-2, (1166, 1) = 1.4832193623974281, (1166, 2) = 0.43133762679546e-2, (1167, 1) = 1.484924623, (1167, 2) = 0.4292006710999836e-2, (1168, 1) = 1.4908431861151392, (1168, 2) = 0.4273179963752635e-2, (1169, 1) = 1.492462312, (1169, 2) = 0.4252991400793571e-2, (1170, 1) = 1.4984648429204566, (1170, 2) = 0.4233994619210856e-2, (1171, 1) = 1.5, (1171, 2) = 0.4214948412973115e-2}, datatype = float[8], order = C_order, attributes = [source_rtable = (Array(1..1203, 1..2, {(1, 1) = 1171.0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .1563469655787127, (3, 1) = 0.411404206213146e-2, (3, 2) = .1563715710259522, (4, 1) = 0.7537688442e-2, (4, 2) = .1563939703226259, (5, 1) = 0.11453278530964653e-1, (5, 2) = .1564641819447511, (6, 1) = 0.1507537688e-1, (6, 2) = .15653540477192268, (7, 1) = 0.1861188724047196e-1, (7, 2) = .15664108581877745, (8, 1) = 0.2261306533e-1, (8, 2) = .15677253817326953, (9, 1) = 0.25599994493771153e-1, (9, 2) = .15689755703889574, (10, 1) = 0.3015075377e-1, (10, 2) = .1571075215866537, (11, 1) = 0.3242521581787689e-1, (11, 2) = .15723004168932495, (12, 1) = 0.3768844221e-1, (12, 2) = .1575434428479125, (13, 1) = 0.3909288395460391e-1, (13, 2) = .15763605115972262, (14, 1) = 0.4522613065e-1, (14, 2) = .1580844082091386, (15, 1) = 0.4560620688944438e-1, (15, 2) = .158114088390209, (16, 1) = 0.4764869985153962e-1, (16, 2) = .1582914573, (17, 1) = 0.5204162039916189e-1, (17, 2) = .15862848335201973, (18, 1) = 0.5276381909e-1, (18, 2) = .15868992174261032, (19, 1) = 0.5837968585731567e-1, (19, 2) = .1591883074075377, (20, 1) = 0.6030150754e-1, (20, 2) = .15937801020899345, (21, 1) = 0.6458489561557128e-1, (21, 2) = .15981013078670622, (22, 1) = 0.6783919598e-1, (22, 2) = .160176487241211, (23, 1) = 0.7065484457382515e-1, (23, 2) = .1604950758706586, (24, 1) = 0.7537688442e-1, (24, 2) = .16109337109567876, (25, 1) = 0.7658532352018085e-1, (25, 2) = .16124510695944796, (26, 1) = 0.805813499008662e-1, (26, 2) = .1618090452, (27, 1) = 0.8242671215465647e-1, (27, 2) = .16203671353312998, (28, 1) = 0.8291457286000001e-1, (28, 2) = .16210413044792332, (29, 1) = 0.8826417929324287e-1, (29, 2) = .16283015015429084, (30, 1) = 0.904522613e-1, (30, 2) = .16316400984452806, (31, 1) = 0.9396930534693831e-1, (31, 2) = .1636853459516551, (32, 1) = 0.9798994975e-1, (32, 2) = .16435809016344582, (33, 1) = 0.9953317989166656e-1, (33, 2) = .16460645912228727, (34, 1) = .10348031148371162, (34, 2) = .1653266332, (35, 1) = .10500945609610703, (35, 2) = .1655684515121711, (36, 1) = .1055276382, (36, 2) = .16566098682384123, (37, 1) = .11052117326438587, (37, 2) = .16651390474986943, (38, 1) = .1130653266, (38, 2) = .16700677204260045, (39, 1) = .11589064181312089, (39, 2) = .16752574069219858, (40, 1) = .1206030151, (40, 2) = .16851216850911968, (41, 1) = .12110349883838589, (41, 2) = .16861066202341454, (42, 1) = .122139540949522, (42, 2) = .1688442211, (43, 1) = .12638254550555122, (43, 2) = .16966469484940266, (44, 1) = .1281407035, (44, 2) = .17005235758919762, (45, 1) = .13157164917804653, (45, 2) = .17076070110173922, (46, 1) = .135678392, (46, 2) = .1717326132535611, (47, 1) = .13659497627188055, (47, 2) = .17193406976339443, (48, 1) = .1382828915235487, (48, 2) = .1723618091, (49, 1) = .1416551472841524, (49, 2) = .17309024454992056, (50, 1) = .1432160804, (50, 2) = .1734770360582889, (51, 1) = .1466677855036304, (51, 2) = .174268601294131, (52, 1) = .1507537688, (52, 2) = .1753499101663136, (53, 1) = .15149998042302312, (53, 2) = .17553116491585571, (54, 1) = .1527341814199683, (54, 2) = .175879397, (55, 1) = .15641056483426513, (55, 2) = .17675714680070748, (56, 1) = .1582914573, (56, 2) = .17727585933216883, (57, 1) = .1612416351715959, (57, 2) = .17802023523441637, (58, 1) = .1658291457, (58, 2) = .17936629609487686, (59, 1) = .16587102451962582, (59, 2) = .17937744145121168, (60, 1) = .16593369754540996, (60, 2) = .1793969849, (61, 1) = .17069645778368336, (61, 2) = .18064316057275676, (62, 1) = .1733668342, (62, 2) = .1814566697357216, (63, 1) = .17533134212275173, (63, 2) = .1819978025151992, (64, 1) = .1781677256590961, (64, 2) = .1829145729, (65, 1) = .17989932145951784, (65, 2) = .1833836667628912, (66, 1) = .1809045226, (66, 2) = .18370113669326119, (67, 1) = .18453928746276133, (67, 2) = .1847359372070223, (68, 1) = .188442211, (68, 2) = .186041774318842, (69, 1) = .18895226379950275, (69, 2) = .18619413616474317, (70, 1) = .18962414585713816, (70, 2) = .1864321608, (71, 1) = .19352401701856153, (71, 2) = .1875782393021984, (72, 1) = .1959798995, (72, 2) = .1884278375837101, (73, 1) = .19794481725849886, (73, 2) = .18903278715851288, (74, 1) = .20045117752386254, (74, 2) = .1899497488, (75, 1) = .20231044794143524, (75, 2) = .1905130807774606, (76, 1) = .2035175879, (76, 2) = .19094440102144117, (77, 1) = .20673715713903199, (77, 2) = .19196487108359372, (78, 1) = .21071765865965755, (78, 2) = .1934673367, (79, 1) = .210919986781138, (79, 2) = .19353047185427236, (80, 1) = .2110552764, (80, 2) = .19358035292660802, (81, 1) = .2153504304721779, (81, 2) = .1949805193777135, (82, 1) = .2185929648, (82, 2) = .19624220476735219, (83, 1) = .21951361459471921, (83, 2) = .19655528803727368, (84, 1) = .220559693818866, (84, 2) = .1969849246, (85, 1) = .22380281657196704, (85, 2) = .1980712484167096, (86, 1) = .2261306533, (86, 2) = .19900426808883254, (87, 1) = .22796753073484188, (87, 2) = .19964530311091175, (88, 1) = .22999525398791076, (88, 2) = .2005025126, (89, 1) = .23210999355251577, (89, 2) = .20122974173135783, (90, 1) = .2336683417, (90, 2) = .20187269529339172, (91, 1) = .23627283634234642, (91, 2) = .20280466967381558, (92, 1) = .23906773088042566, (92, 2) = .2040201005, (93, 1) = .24028550777061808, (93, 2) = .20444967759681473, (94, 1) = .2412060301, (94, 2) = .204840388245712, (95, 1) = .2444429751737546, (95, 2) = .20602711411793337, (96, 1) = .2478214695999889, (96, 2) = .2075376885, (97, 1) = .24834109968376933, (97, 2) = .2077255773240134, (98, 1) = .2487437186, (98, 2) = .20790128484539636, (99, 1) = .252489482515476, (99, 2) = .20930725324938332, (100, 1) = .256281407, (100, 2) = .2110496186290694, (101, 1) = .2562880193831866, (101, 2) = .21105219062123806, (102, 1) = .2562943908258979, (102, 2) = .2110552764, (103, 1) = .26042230322198406, (103, 2) = .212640446099698, (104, 1) = .2638190955, (104, 2) = .21424381425046282, (105, 1) = .2641998913635977, (105, 2) = .21439515956466476, (106, 1) = .2645571585520604, (106, 2) = .2145728643, (107, 1) = .26825000147542855, (107, 2) = .21602269613110664, (108, 1) = .2713567839, (108, 2) = .21752863992089982, (109, 1) = .27200070242220775, (109, 2) = .21778995698678882, (110, 1) = .2725890871945216, (110, 2) = .2180904523, (111, 1) = .27597988723170386, (111, 2) = .219450592019427, (112, 1) = .2788944724, (112, 2) = .22090098019948495, (113, 1) = .27969725652919275, (113, 2) = .22123340760850677, (114, 1) = .2804118157639838, (114, 2) = .2216080402, (115, 1) = .283618132254194, (115, 2) = .22292125355124234, (116, 1) = .2864321608, (116, 2) = .22435856050825176, (117, 1) = .2872950900428197, (117, 2) = .2247229278775256, (118, 1) = .2880433831984684, (118, 2) = .2251256282, (119, 1) = .29116990158350164, (119, 2) = .2264322704136034, (120, 1) = .2939698492, (120, 2) = .2278998650257172, (121, 1) = .2947986307063212, (121, 2) = .22825645140438025, (122, 1) = .2954988272759236, (122, 2) = .2286432161, (123, 1) = .29863944855385915, (123, 2) = .2299816576761657, (124, 1) = .3015075377, (124, 2) = .23152418338227845, (125, 1) = .30221116730105624, (125, 2) = .23183244352137405, (126, 1) = .30279033114215453, (126, 2) = .232160804, (127, 1) = .3060301271596008, (127, 2) = .23356785020418652, (128, 1) = .3090452261, (128, 2) = .2352316447014429, (129, 1) = .3095348534013429, (129, 2) = .23544989925720808, (130, 1) = .30992746284733075, (130, 2) = .235678392, (131, 1) = .3133444099346572, (131, 2) = .2371896941485172, (132, 1) = .3165829146, (132, 2) = .23902330205384661, (133, 1) = .31677063657843346, (133, 2) = .23910837631056248, (134, 1) = .31691724815204936, (134, 2) = .2391959799, (135, 1) = .3205839061629061, (135, 2) = .24084643846151332, (136, 1) = .3237977008207778, (136, 2) = .2427135679, (137, 1) = .3239626997077225, (137, 2) = .2427872561026439, (138, 1) = .324120603, (138, 2) = .24287665200373632, (139, 1) = .3277493216791142, (139, 2) = .24453775375937492, (140, 1) = .3305894716179565, (140, 2) = .2462311558, (141, 1) = .3311308893678871, (141, 2) = .24647727674692, (142, 1) = .3316582914, (142, 2) = .2467835549689252, (143, 1) = .33484037350574114, (143, 2) = .24826377207879788, (144, 1) = .33726661427309146, (144, 2) = .2497487437, (145, 1) = .3382357167737991, (145, 2) = .2501968664964736, (146, 1) = .3391959799, (146, 2) = .2507689682864231, (147, 1) = .34185565973081394, (147, 2) = .25202514775072543, (148, 1) = .3438305170126463, (148, 2) = .2532663317, (149, 1) = .3452768774193954, (149, 2) = .25394616744041676, (150, 1) = .3467336683, (150, 2) = .2548367630850394, (151, 1) = .3487924843457991, (151, 2) = .25582313879683616, (152, 1) = .35028050460732685, (152, 2) = .2567839196, (153, 1) = .3522532246943719, (153, 2) = .2577257145915511, (154, 1) = .3542713568, (154, 2) = .258992096032466, (155, 1) = .355646577930956, (155, 2) = .2596597377242915, (156, 1) = .356613489956487, (156, 2) = .2603015076, (157, 1) = .35916257815712477, (157, 2) = .2615365255463198, (158, 1) = .3618090452, (158, 2) = .26324180296336236, (159, 1) = .3624116312465448, (159, 2) = .2635378886836086, (160, 1) = .36282345633954893, (160, 2) = .2638190955, (161, 1) = .3660015162650624, (161, 2) = .265380196940051, (162, 1) = .3689568243623757, (162, 2) = .2673366834, (163, 1) = .36914704156615796, (163, 2) = .2674298730633427, (164, 1) = .3693467337, (164, 2) = .2675584668960912, (165, 1) = .37276508141208897, (165, 2) = .26925904243141174, (166, 1) = .3751087624447853, (166, 2) = .2708542714, (167, 1) = .37596870650284064, (167, 2) = .2712816053429114, (168, 1) = .3768844221, (168, 2) = .27188718811737245, (169, 1) = .3794462813572124, (169, 2) = .27317632498676503, (170, 1) = .38115313529001693, (170, 2) = .2743718593, (171, 1) = .38272548573151655, (171, 2) = .27516361754329915, (172, 1) = .3844221105, (172, 2) = .27631660317460116, (173, 1) = .3860354639396687, (173, 2) = .27713654902102, (174, 1) = .3870788206689781, (174, 2) = .2778894473, (175, 1) = .3894118058305985, (175, 2) = .27907851075651846, (176, 1) = .391959799, (176, 2) = .2808593013214599, (177, 1) = .3925192611802801, (177, 2) = .2811459528506871, (178, 1) = .3928699254515984, (178, 2) = .2814070352, (179, 1) = .39601999075370253, (179, 2) = .2830298669590452, (180, 1) = .39865339649823994, (180, 2) = .2849246231, (181, 1) = .399054215984739, (181, 2) = .28513148309849307, (182, 1) = .3994974874, (182, 2) = .2854410813479102, (183, 1) = .4025394978638157, (183, 2) = .28702260620343356, (184, 1) = .40445346238143115, (184, 2) = .2884422111, (185, 1) = .40567205625734704, (185, 2) = .28907833358784873, (186, 1) = .4070351759, (186, 2) = .2900578777122225, (187, 1) = .4089557678778346, (187, 2) = .2910635227487732, (188, 1) = .41012599927130694, (188, 2) = .291959799, (189, 1) = .4122139513300834, (189, 2) = .29306062507766373, (190, 1) = .4145728643, (190, 2) = .29480677486942214, (191, 1) = .41524840249674494, (191, 2) = .2951621358385316, (192, 1) = .4156461222869131, (192, 2) = .295477387, (193, 1) = .4186682810347394, (193, 2) = .29708378046000994, (194, 1) = .4211708817900251, (194, 2) = .2989949749, (195, 1) = .4216089056599046, (195, 2) = .29922907689427447, (196, 1) = .4221105528, (196, 2) = .29960026414159835, (197, 1) = .4250189113577072, (197, 2) = .30115532881412016, (198, 1) = .42673813074297334, (198, 2) = .3025125628, (199, 1) = .4280881553513352, (199, 2) = .30324060287926796, (200, 1) = .4296482412, (200, 2) = .30443065848243966, (201, 1) = .43124296130670364, (201, 2) = .305285948066613, (202, 1) = .4321524720222676, (202, 2) = .3060301508, (203, 1) = .43447882908159996, (203, 2) = .3072934643680706, (204, 1) = .4371859296, (204, 2) = .3094261430078931, (205, 1) = .4373072082542931, (205, 2) = .30949114199573585, (206, 1) = .43737370440049944, (206, 2) = .3095477387, (207, 1) = .4407626456393019, (207, 2) = .3113961925325087, (208, 1) = .44280925121024983, (208, 2) = .3130653267, (209, 1) = .44368693138175197, (209, 2) = .31354911382601347, (210, 1) = .4447236181, (210, 2) = .31436552367991755, (211, 1) = .44691325438868024, (211, 2) = .31556108433775903, (212, 1) = .44811968623247306, (212, 2) = .3165829146, (213, 1) = .4500128454767157, (213, 2) = .3176321964049001, (214, 1) = .4522613065, (214, 2) = .31946347593252944, (215, 1) = .452891529738174, (215, 2) = .3198063983277594, (216, 1) = .45322441588014806, (216, 2) = .3201005025, (217, 1) = .4562256549567938, (217, 2) = .3217680612026317, (218, 1) = .4584156737738623, (218, 2) = .3236180905, (219, 1) = .45904270810555414, (219, 2) = .3239710243773858, (220, 1) = .459798995, (220, 2) = .32458718918913143, (221, 1) = .4622940370494772, (221, 2) = .3259713254501975, (222, 1) = .4636177231597405, (222, 2) = .3271356784, (223, 1) = .4653001003370227, (223, 2) = .3280860838510044, (224, 1) = .4673366834, (224, 2) = .3298052569263673, (225, 1) = .4681701175821987, (225, 2) = .3302643304394618, (226, 1) = .4685923820791582, (226, 2) = .3306532664, (227, 1) = .4714342533295569, (227, 2) = .3322586550104123, (228, 1) = .4736127372887472, (228, 2) = .3341708543, (229, 1) = .4741784948157407, (229, 2) = .33449559689080793, (230, 1) = .47487437180000003, (230, 2) = .33508357622689244, (231, 1) = .4774064804372275, (231, 2) = .3365067915250223, (232, 1) = .4786946396102586, (232, 2) = .3376884422, (233, 1) = .48036051097030574, (233, 2) = .33864583189626307, (234, 1) = .4824120603, (234, 2) = .3404462819598845, (235, 1) = .4831554993207043, (235, 2) = .3408590919824476, (236, 1) = .48351475560029955, (236, 2) = .3412060302, (237, 1) = .486403767498123, (237, 2) = .34286082141813395, (238, 1) = .4884380204147546, (238, 2) = .3447236181, (239, 1) = .48910930455562657, (239, 2) = .3451158253762942, (240, 1) = .4899497487, (240, 2) = .34585451237338455, (241, 1) = .4922582746972002, (241, 2) = .3471638939577644, (242, 1) = .4933783239162865, (242, 2) = .3482412061, (243, 1) = .49520497458841906, (243, 2) = .34930635529855064, (244, 1) = .4974874372, (244, 2) = .3513969608302578, (245, 1) = .4978411444834455, (245, 2) = .3515937306019973, (246, 1) = .4980028813388976, (246, 2) = .351758794, (247, 1) = .5011382603441314, (247, 2) = .35357266444242547, (248, 1) = .5029123014095499, (248, 2) = .3552763819, (249, 1) = .5038426326656263, (249, 2) = .35582821194859127, (250, 1) = .5050251256, (250, 2) = .35691345813736414, (251, 1) = .506840931853553, (251, 2) = .35794659364031206, (252, 1) = .5076747727105544, (252, 2) = .3587939699, (253, 1) = .5098347969513135, (253, 2) = .3600670445452593, (254, 1) = .5121706405090248, (254, 2) = .3623115578, (255, 1) = .5123417375182368, (255, 2) = .3624147268724672, (256, 1) = .5125628141, (256, 2) = .36261833722107134, (257, 1) = .515627776465587, (257, 2) = .3643988299968633, (258, 1) = .517037436286423, (258, 2) = .3658291458, (259, 1) = .5183776657705376, (259, 2) = .3666331362691778, (260, 1) = .5201005025000001, (260, 2) = .3682925798270953, (261, 1) = .5211218094273468, (261, 2) = .3688701238032814, (262, 1) = .5215606671057531, (262, 2) = .3693467337, (263, 1) = .5242388999126684, (263, 2) = .37093306948506855, (264, 1) = .5261408456874557, (264, 2) = .3728643216, (265, 1) = .526789770654438, (265, 2) = .37326025105693345, (266, 1) = .5276381909, (266, 2) = .37408073813624665, (267, 1) = .5298408117505049, (267, 2) = .3753540198600239, (268, 1) = .5307890461341223, (268, 2) = .3763819096, (269, 1) = .5327024621228297, (269, 2) = .3775361709741368, (270, 1) = .5350235561041898, (270, 2) = .3798994975, (271, 1) = .5350889609440974, (271, 2) = .37994005944647224, (272, 1) = .5351758794, (272, 2) = .38002457646404664, (273, 1) = .5383866426757877, (273, 2) = .3819187292705555, (274, 1) = .5397678254418192, (274, 2) = .3834170855, (275, 1) = .5410400965701394, (275, 2) = .3841980387361613, (276, 1) = .5427135678, (276, 2) = .38590965937995525, (277, 1) = .543705513710889, (277, 2) = .386471765317025, (278, 1) = .5440979633663376, (278, 2) = .3869346734, (279, 1) = .5467869878557947, (279, 2) = .3885513319766563, (280, 1) = .5485339197773342, (280, 2) = .3904522613, (281, 1) = .5492686492431231, (281, 2) = .3909108112642211, (282, 1) = .5502512563, (282, 2) = .3919219623354962, (283, 1) = .552209960639181, (283, 2) = .3930557872542605, (284, 1) = .5529844139193156, (284, 2) = .3939698493, (285, 1) = .5550630770255085, (285, 2) = .39524192087419674, (286, 1) = .5571162262826977, (286, 2) = .3974874372, (287, 1) = .5574014126054714, (287, 2) = .3976682855148931, (288, 1) = .5577889447, (288, 2) = .3980700966510423, (289, 1) = .5605658940567053, (289, 2) = .39970911548792387, (290, 1) = .5616601137346005, (290, 2) = .4010050252, (291, 1) = .5632313898737636, (291, 2) = .401982805400379, (292, 1) = .5653266332, (292, 2) = .4042902645303774, (293, 1) = .5655545878763909, (293, 2) = .40441623425162243, (294, 1) = .5656346345021266, (294, 2) = .4045226131, (295, 1) = .5687951576899943, (295, 2) = .4064215562472058, (296, 1) = .5701537839480469, (296, 2) = .408040201, (297, 1) = .571304894879362, (297, 2) = .4087679334861818, (298, 1) = .5728643216, (298, 2) = .4105001595793406, (299, 1) = .573890981475691, (299, 2) = .4110786810471146, (300, 1) = .5742499574625818, (300, 2) = .411557789, (301, 1) = .5769146360350601, (301, 2) = .4131852301743854, (302, 1) = .5784881143647418, (302, 2) = .4150753769, (303, 1) = .5792939134001516, (303, 2) = .4155924886583565, (304, 1) = .58040201, (304, 2) = .4168360034851491, (305, 1) = .5820916234225818, (305, 2) = .41780447862865666, (306, 1) = .5826778032589655, (306, 2) = .4185929649, (307, 1) = .5849375309142315, (307, 2) = .4199939764134728, (308, 1) = .5866812236992927, (308, 2) = .4221105528, (309, 1) = .5872067269735419, (309, 2) = .42245260617253105, (310, 1) = .5879396985, (310, 2) = .42328487231509143, (311, 1) = .5901748181793824, (311, 2) = .424585084855552, (312, 1) = .5909416297801887, (312, 2) = .4256281407, (313, 1) = .5928742661563755, (313, 2) = .4268429304079858, (314, 1) = .5947477331341324, (314, 2) = .4291457287, (315, 1) = .5950500399391007, (315, 2) = .4293451572806191, (316, 1) = .5954773869, (316, 2) = .42983686771803714, (317, 1) = .5981546733456532, (317, 2) = .4314139162823743, (318, 1) = .5990599732896797, (318, 2) = .4326633166, (319, 1) = .6007331668179969, (319, 2) = .4337282072816926, (320, 1) = .6026995817042107, (320, 2) = .4361809046, (321, 1) = .6028293309636257, (321, 2) = .43626758533533183, (322, 1) = .6030150754, (322, 2) = .43648448192499756, (323, 1) = .6060420969519619, (323, 2) = .4382858824504494, (324, 1) = .6070475298616599, (324, 2) = .4396984925, (325, 1) = .6085209028289573, (325, 2) = .4406466942810953, (326, 1) = .6105465714823727, (326, 2) = .4432160804, (327, 1) = .610549100469022, (327, 2) = .44321778995449523, (328, 1) = .6105527638, (328, 2) = .44322213796208026, (329, 1) = .6138455353056087, (329, 2) = .44519704166243534, (330, 1) = .6149160064931423, (330, 2) = .4467336684, (331, 1) = .6162428430226877, (331, 2) = .4475958860111768, (332, 1) = .6180904522, (332, 2) = .44998451105692194, (333, 1) = .618361032979732, (333, 2) = .4501249852718516, (334, 1) = .6184311109683637, (334, 2) = .4502512563, (335, 1) = .6215714415476802, (335, 2) = .45214438258902223, (336, 1) = .6226746600685912, (336, 2) = .4537688443, (337, 1) = .6239033103668259, (337, 2) = .4545737651068926, (338, 1) = .6256281407, (338, 2) = .4568521499901121, (339, 1) = .6260703963670847, (339, 2) = .4570800462232006, (340, 1) = .6261798113812319, (340, 2) = .4572864322, (341, 1) = .629224615214578, (341, 2) = .4591256653360729, (342, 1) = .630330704663824, (342, 2) = .4608040201, (343, 1) = .6315057682571499, (343, 2) = .4615787151776155, (344, 1) = .6331658291, (344, 2) = .4638253825811738, (345, 1) = .6336751962287598, (345, 2) = .46408390343765954, (346, 1) = .6337940389714881, (346, 2) = .4643216081, (347, 1) = .6368083372536868, (347, 2) = .46613935889382885, (348, 1) = .6378894739173245, (348, 2) = .467839196, (349, 1) = .6390529293504151, (349, 2) = .46860947052377216, (350, 1) = .6407035176, (350, 2) = .47090538903042267, (351, 1) = .6411729686877367, (351, 2) = .47113770682074047, (352, 1) = .6412744469548372, (352, 2) = .47135678400000003, (353, 1) = .6443244310598472, (353, 2) = .4731846122950122, (354, 1) = .6453545506161649, (354, 2) = .4748743719, (355, 1) = .64654686035321, (355, 2) = .475665066530673, (356, 1) = .648241206, (356, 2) = .4780964241606354, (357, 1) = .6485547404531187, (357, 2) = .47824564372465095, (358, 1) = .6486159014391775, (358, 2) = .4783919598, (359, 1) = .6517730630078912, (359, 2) = .48026134784736546, (360, 1) = .6527275625074144, (360, 2) = .4819095478, (361, 1) = .6539889836503494, (361, 2) = .48274483951400615, (362, 1) = .6557788945, (362, 2) = .48540677089959555, (363, 1) = .6558011432731569, (363, 2) = .4854167529392525, (364, 1) = .655804895158075, (364, 2) = .4854271357, (365, 1) = .6591523462683724, (365, 2) = .4873704461722893, (366, 1) = .6600078620797836, (366, 2) = .4889447237, (367, 1) = .6613800684774144, (367, 2) = .4898484304254017, (368, 1) = .6630661423301804, (368, 2) = .4924623116, (369, 1) = .6631655196107269, (369, 2) = .49253280780125996, (370, 1) = .6633165829, (370, 2) = .49274529682446533, (371, 1) = .6664574008536912, (371, 2) = .49451418446327766, (372, 1) = .6671916688909929, (372, 2) = .4959798995, (373, 1) = .6687201033375192, (373, 2) = .4969758445718083, (374, 1) = .6702685660547512, (374, 2) = .4994974875, (375, 1) = .6705011863405904, (375, 2) = .49966226048012097, (376, 1) = .6708542713, (376, 2) = .5001774441430769, (377, 1) = .6736784716571493, (377, 2) = .5016971152583087, (378, 1) = .6742704585741014, (378, 2) = .5030150754, (379, 1) = .6760080517394262, (379, 2) = .50412756583881, (380, 1) = .677399246611721, (380, 2) = .5065326634, (381, 1) = .6777947901740559, (381, 2) = .5068113425534924, (382, 1) = .6783919598, (382, 2) = .5077201960344483, (383, 1) = .6807968774505293, (383, 2) = .5089279564028008, (384, 1) = .6812277157139974, (384, 2) = .5100502513, (385, 1) = .6832413537672619, (385, 2) = .5113047886948117, (386, 1) = .6844556297290976, (386, 2) = .5135678392, (387, 1) = .6850466625571178, (387, 2) = .5139798991760498, (388, 1) = .6859296482, (388, 2) = .5153920731517049, (389, 1) = .6877753661910225, (389, 2) = .5162240921293607, (390, 1) = .6880318827296975, (390, 2) = .5170854272000001, (391, 1) = .6904148909644026, (391, 2) = .5185099018496149, (392, 1) = .691432076216194, (392, 2) = .5206030151, (393, 1) = .6922567301232537, (393, 2) = .5211679648411685, (394, 1) = .6934673366999999, (394, 2) = .5232237897260825, (395, 1) = .6945317640609436, (395, 2) = .5236238703202625, (396, 1) = .6946196251507182, (396, 2) = .5241206031, (397, 1) = .6975187814979922, (397, 2) = .5257475167716869, (398, 1) = .698317581437037, (398, 2) = .527638191, (399, 1) = .6994243262800321, (399, 2) = .5283758504451243, (400, 1) = .7009425609360174, (400, 2) = .5311557789, (401, 1) = .7009668454087546, (401, 2) = .5311735960896531, (402, 1) = .7010050251, (402, 2) = .531235022213899, (403, 1) = .7045330536072332, (403, 2) = .5330269535591804, (404, 1) = .7050907594978423, (404, 2) = .5346733669, (405, 1) = .7065477859856253, (405, 2) = .5356043330680816, (406, 1) = .707826439370854, (406, 2) = .5381909548, (407, 1) = .7081081959007527, (407, 2) = .5383937296842604, (408, 1) = .7085427135, (408, 2) = .5391383297211966, (409, 1) = .7114127298251807, (409, 2) = .5403692018355573, (410, 1) = .7117074971453883, (410, 2) = .5417085428, (411, 1) = .7136235371248519, (411, 2) = .5428550797200062, (412, 1) = .7146400679090801, (412, 2) = .5452261307, (413, 1) = .7152171450153232, (413, 2) = .5456289839518809, (414, 1) = .716080402, (414, 2) = .5472318084850784, (415, 1) = .7180345888276969, (415, 2) = .5478317647522599, (416, 1) = .7180648234578784, (416, 2) = .5487437186, (417, 1) = .7206438027624761, (417, 2) = .5501317195290782, (418, 1) = .7213690656048836, (418, 2) = .5522613066, (419, 1) = .7222959479644129, (419, 2) = .5528783063997659, (420, 1) = .7236180904, (420, 2) = .5556142807592881, (421, 1) = .7239053069243766, (421, 2) = .5556448601244978, (422, 1) = .7238626413394168, (422, 2) = .5557788945, (423, 1) = .727589654427056, (423, 2) = .5574430859364774, (424, 1) = .7279818096371112, (424, 2) = .5592964825, (425, 1) = .7293484692190622, (425, 2) = .560139893668453, (426, 1) = .7304488507618105, (426, 2) = .5628140704, (427, 1) = .7307271473996758, (427, 2) = .5630140984296936, (428, 1) = .7311557789, (428, 2) = .5638422925589597, (429, 1) = .7344031167623684, (429, 2) = .5648162339728443, (430, 1) = .734397592924741, (430, 2) = .5663316583, (431, 1) = .7363825553752067, (431, 2) = .56741008388943, (432, 1) = .737141981461179, (432, 2) = .5698492463, (433, 1) = .737774574082815, (433, 2) = .5702780631322483, (434, 1) = .7386934673000001, (434, 2) = .5722948844201498, (435, 1) = .7407898893748043, (435, 2) = .5723885039169664, (436, 1) = .7403417330236419, (436, 2) = .5733668342, (437, 1) = .7434181560698958, (437, 2) = .5746795674198217, (438, 1) = .7437609615715551, (438, 2) = .5768844222, (439, 1) = .7448263593479074, (439, 2) = .5775399938652186, (440, 1) = .7458907583865892, (440, 2) = .5804020101, (441, 1) = .7460238544868412, (441, 2) = .5804987507109741, (442, 1) = .7462311558, (442, 2) = .5809274807500572, (443, 1) = .7505285078494064, (443, 2) = .5819141670550128, (444, 1) = .7502570823615815, (444, 2) = .583919598, (445, 1) = .7519232985586441, (445, 2) = .5847808526522201, (446, 1) = .7525801176410079, (446, 2) = .5874371860000001, (447, 1) = .7530674347922731, (447, 2) = .5877645103884115, (448, 1) = .7537688442, (448, 2) = .5894754545594193, (449, 1) = .7584052102297473, (449, 2) = .5887911364317532, (450, 1) = .7564023156361204, (450, 2) = .5909547739, (451, 1) = .7591949895306978, (451, 2) = .5919401606880849, (452, 1) = .759272894687191, (452, 2) = .5944723619, (453, 1) = .7601756102366055, (453, 2) = .5950001256665833, (454, 1) = .7610832014050026, (454, 2) = .5979899498, (455, 1) = .7611712213813305, (455, 2) = .59805309503502, (456, 1) = .7613065326, (456, 2) = .598365048803723, (457, 1) = .767397979816176, (457, 2) = .5986648623863265, (458, 1) = .7660541949332249, (458, 2) = .6015075377, (459, 1) = .7674897400218551, (459, 2) = .6021396288757908, (460, 1) = .7678552870305516, (460, 2) = .6050251257, (461, 1) = .7682732811148212, (461, 2) = .6052915643547006, (462, 1) = .7688442211, (462, 2) = .6069776370063522, (463, 1) = .7718788618065875, (463, 2) = .6050251257, (464, 1) = .7701772158845703, (464, 2) = .604403061453053, (465, 1) = .770635160312404, (465, 2) = .6015075377, (466, 1) = .7698840051758535, (466, 2) = .6010223051340272, (467, 1) = .7693019342651174, (467, 2) = .5979899498, (468, 1) = .7691335900028758, (468, 2) = .5978549109794257, (469, 1) = .7688442211, (469, 2) = .5970283535448404, (470, 1) = .7625054523889951, (470, 2) = .5974304539090726, (471, 1) = .7652436454649781, (471, 2) = .5944723619, (472, 1) = .7632377617406646, (472, 2) = .5935711216258162, (473, 1) = .7633131740612666, (473, 2) = .5909547739, (474, 1) = .7624996825719582, (474, 2) = .5903979705903055, (475, 1) = .7617545533100927, (475, 2) = .5874371860000001, (476, 1) = .7615921668021366, (476, 2) = .5873038900377399, (477, 1) = .7613065326, (477, 2) = .5865669253736254, (478, 1) = .7569338344741664, (478, 2) = .5859601905051313, (479, 1) = .7579615162167681, (479, 2) = .583919598, (480, 1) = .7559963080423406, (480, 2) = .5828801148794847, (481, 1) = .7557746899991786, (481, 2) = .5804020101, (482, 1) = .754987936365745, (482, 2) = .5798331004258871, (483, 1) = .7540704239167212, (483, 2) = .5768844222, (484, 1) = .7539627708881196, (484, 2) = .5767939230768193, (485, 1) = .7537688442, (485, 2) = .5763388147300418, (486, 1) = .749920454738908, (486, 2) = .5751627493226872, (487, 1) = .7502967109764029, (487, 2) = .5733668342, (488, 1) = .7485199994771032, (488, 2) = .5722987071567582, (489, 1) = .7480444164864417, (489, 2) = .5698492463, (490, 1) = .7473545920573336, (490, 2) = .5693249760346543, (491, 1) = .7462519616831753, (491, 2) = .5663316583, (492, 1) = .7462446452833709, (492, 2) = .566325363207796, (493, 1) = .7462311558, (493, 2) = .5662963205225036, (494, 1) = .7423910852437003, (494, 2) = .56460610329231, (495, 1) = .7423854545821322, (495, 2) = .5628140704, (496, 1) = .7408624230141795, (496, 2) = .5618018910858994, (497, 1) = .7401474389059498, (497, 2) = .5592964825, (498, 1) = .739609202013443, (498, 2) = .558869139629677, (499, 1) = .7386934673000001, (499, 2) = .5566994627265854, (500, 1) = .7373337242500462, (500, 2) = .5564134412710765, (501, 1) = .7375529280200395, (501, 2) = .5557788945, (502, 1) = .7346089216718232, (502, 2) = .5541674278823114, (503, 1) = .7342999024776851, (503, 2) = .5522613066, (504, 1) = .733062385712161, (504, 2) = .5513715567340894, (505, 1) = .7321051772528755, (505, 2) = .5487437186, (506, 1) = .7317620125548746, (506, 2) = .5484608095626671, (507, 1) = .7311557789, (507, 2) = .5471755221786071, (508, 1) = .7288972832717391, (508, 2) = .5462800953065466, (509, 1) = .7289300200295219, (509, 2) = .5452261307, (510, 1) = .7266745141310627, (510, 2) = .5437997996525366, (511, 1) = .7260795175455097, (511, 2) = .5417085428, (512, 1) = .7251468695415849, (512, 2) = .5409951125271665, (513, 1) = .7239344481102331, (513, 2) = .5381909548, (514, 1) = .7238224227793333, (514, 2) = .5380955996914517, (515, 1) = .7236180904, (515, 2) = .5377004001994169, (516, 1) = .7205798536292655, (516, 2) = .5360912107182814, (517, 1) = .7203358064748968, (517, 2) = .5346733669, (518, 1) = .7186332419606867, (518, 2) = .5334820415579187, (519, 1) = .7177465380996019, (519, 2) = .5311557789, (520, 1) = .7171343576488055, (520, 2) = .5306639329333539, (521, 1) = .716080402, (521, 2) = .5285185728725448, (522, 1) = .7150690635072785, (522, 2) = .5281101489543252, (523, 1) = .7150651474523091, (523, 2) = .527638191, (524, 1) = .7122825627912577, (524, 2) = .5258929280304899, (525, 1) = .7117254561452948, (525, 2) = .5241206031, (526, 1) = .7105078811503773, (526, 2) = .5232035248544668, (527, 1) = .709313814793679, (527, 2) = .5206030151, (528, 1) = .7090374677850002, (528, 2) = .5203721297713757, (529, 1) = .7085427135, (529, 2) = .5194599433133028, (530, 1) = .7061965922202815, (530, 2) = .5181802837909769, (531, 1) = .7059485994655371, (531, 2) = .5170854272000001, (532, 1) = .7039713812850835, (532, 2) = .5157011276154781, (533, 1) = .7030763413046126, (533, 2) = .5135678392, (534, 1) = .7023107244229887, (534, 2) = .5129585128527364, (535, 1) = .7010050251, (535, 2) = .5104631685122588, (536, 1) = .7005554626379362, (536, 2) = .510260047114437, (537, 1) = .700532426213646, (537, 2) = .5100502513, (538, 1) = .6975634682865297, (538, 2) = .5081387232371546, (539, 1) = .6969674540361994, (539, 2) = .5065326634, (540, 1) = .6956310906601928, (540, 2) = .5055229115289454, (541, 1) = .6943755773322701, (541, 2) = .5030150754, (542, 1) = .6940487375441052, (542, 2) = .5027437550076268, (543, 1) = .6934673366999999, (543, 2) = .5017356084998368, (544, 1) = .6913371583211333, (544, 2) = .5004915707246309, (545, 1) = .6910267347144636, (545, 2) = .4994974875, (546, 1) = .6890134177468648, (546, 2) = .49805839503115934, (547, 1) = .6880274190127694, (547, 2) = .4959798995, (548, 1) = .6872536468046716, (548, 2) = .49536203349619656, (549, 1) = .6859296482, (549, 2) = .49301879363440343, (550, 1) = .685365858020765, (550, 2) = .49272541368214706, (551, 1) = .6853023469688783, (551, 2) = .4924623116, (552, 1) = .682474224619088, (552, 2) = .49055725469525724, (553, 1) = .6817575115020593, (553, 2) = .4889447237, (554, 1) = .6804849100825205, (554, 2) = .48796801354594393, (555, 1) = .6790822467362455, (555, 2) = .4854271357, (556, 1) = .678834251722961, (556, 2) = .48522073280379174, (557, 1) = .6783919598, (557, 2) = .48450428140603924, (558, 1) = .6760310197132064, (558, 2) = .48301131981962253, (559, 1) = .6755781421632182, (559, 2) = .4819095478, (560, 1) = .6737471333022285, (560, 2) = .48055954551950053, (561, 1) = .6725809693019373, (561, 2) = .4783919598, (562, 1) = .6719486597541052, (562, 2) = .4778812451977635, (563, 1) = .6708542713, (563, 2) = .47609475103423465, (564, 1) = .6697009134032972, (564, 2) = .4754126055820677, (565, 1) = .6694993265551618, (565, 2) = .4748743719, (566, 1) = .6670435226254972, (566, 2) = .47313513337132346, (567, 1) = .666112911098834, (567, 2) = .47135678400000003, (568, 1) = .6650697765711803, (568, 2) = .470538626934842, (569, 1) = .6634290004731302, (569, 2) = .467839196, (570, 1) = .663388825704418, (570, 2) = .46780548269146327, (571, 1) = .6633165829, (571, 2) = .4676961942750159, (572, 1) = .6603750781831043, (572, 2) = .46569431029341324, (573, 1) = .6596771357613036, (573, 2) = .4643216081, (574, 1) = .6581969611630083, (574, 2) = .4631931769649324, (575, 1) = .6567554866881687, (575, 2) = .4608040201, (576, 1) = .6564013509925426, (576, 2) = .46051354040513176, (577, 1) = .6557788945, (577, 2) = .4595730965627197, (578, 1) = .6537397262340544, (578, 2) = .458238044039406, (579, 1) = .653269570325969, (579, 2) = .4572864322, (580, 1) = .6513281106571419, (580, 2) = .4558458767206357, (581, 1) = .6500829412056062, (581, 2) = .4537688443, (582, 1) = .6494058675855644, (582, 2) = .45322533555491956, (583, 1) = .648241206, (583, 2) = .45146938976750345, (584, 1) = .6471314835186666, (584, 2) = .45076912680306686, (585, 1) = .6468824467628159, (585, 2) = .4502512563, (586, 1) = .6444595005529137, (586, 2) = .44849846426527284, (587, 1) = .6434065207570968, (587, 2) = .4467336684, (588, 1) = .6424001139154676, (588, 2) = .44594192343477523, (589, 1) = .6407035176, (589, 2) = .4433922488286544, (590, 1) = .640539879063162, (590, 2) = .44329244505124804, (591, 1) = .6405040091082581, (591, 2) = .4432160804, (592, 1) = .6375857072618107, (592, 2) = .4411534706302463, (593, 1) = .636719683162204, (593, 2) = .4396984925, (594, 1) = .6353810440093814, (594, 2) = .43866472556188096, (595, 1) = .6337205514840445, (595, 2) = .4361809046, (596, 1) = .6335194856748709, (596, 2) = .4360158648634963, (597, 1) = .6331658291, (597, 2) = .43552130590189286, (598, 1) = .6306997544480649, (598, 2) = .4338141514637429, (599, 1) = .630014403647833, (599, 2) = .4326633166, (600, 1) = .6283449534455033, (600, 2) = .43139547065930706, (601, 1) = .626831398160579, (601, 2) = .4291457287, (602, 1) = .6263912030507452, (602, 2) = .4287896329282202, (603, 1) = .6256281407, (603, 2) = .4277318173711414, (604, 1) = .6237934249672785, (604, 2) = .42648434138338354, (605, 1) = .6232814929969428, (605, 2) = .4256281407, (606, 1) = .6212876297995694, (606, 2) = .4241361245151448, (607, 1) = .6199136766926232, (607, 2) = .4221105528, (608, 1) = .6192411383681233, (608, 2) = .4215735659317196, (609, 1) = .6180904522, (609, 2) = .41999392989842765, (610, 1) = .616857782320856, (610, 2) = .41916821084032985, (611, 1) = .6165111271613823, (611, 2) = .4185929649, (612, 1) = .6142045961622684, (612, 2) = .4168887764255166, (613, 1) = .6129619753822434, (613, 2) = .4150753769, (614, 1) = .6120668188759711, (614, 2) = .4143688178685641, (615, 1) = .6105527638, (615, 2) = .412312865809618, (616, 1) = .6098837981359486, (616, 2) = .4118699729747824, (617, 1) = .6096934239531301, (617, 2) = .411557789, (618, 1) = .6070913933803693, (618, 2) = .4096555072325644, (619, 1) = .6059709460662753, (619, 2) = .408040201, (620, 1) = .6048658222920855, (620, 2) = .4071765191219374, (621, 1) = .6030150754, (621, 2) = .40469329619235833, (622, 1) = .602863103225005, (622, 2) = .40459353344698695, (623, 1) = .6028191648435827, (623, 2) = .4045226131, (624, 1) = .5999438705289032, (624, 2) = .4024382541126821, (625, 1) = .5989355752445181, (625, 2) = .4010050252, (626, 1) = .5976358992595766, (626, 2) = .39999771942265216, (627, 1) = .5957404771292144, (627, 2) = .3974874372, (628, 1) = .5956446569324523, (628, 2) = .3974093778530017, (629, 1) = .5954773869, (629, 2) = .397197178428286, (630, 1) = .5927584434127191, (630, 2) = .39523868958685016, (631, 1) = .5918514724459307, (631, 2) = .3939698493, (632, 1) = .5903751176564264, (632, 2) = .3928333203344865, (633, 1) = .5885520206003342, (633, 2) = .3904522613, (634, 1) = .5883280361978662, (634, 2) = .39027103704202615, (635, 1) = .5879396985, (635, 2) = .3897845642725306, (636, 1) = .5855323425286143, (636, 2) = .388058106165355, (637, 1) = .5847151459560386, (637, 2) = .3869346734, (638, 1) = .583081996106934, (638, 2) = .38568401324046714, (639, 1) = .5813205236176994, (639, 2) = .3834170855, (640, 1) = .5809833455097835, (640, 2) = .3831457955928636, (641, 1) = .58040201, (641, 2) = .3824269427112342, (642, 1) = .5782637540893907, (642, 2) = .3808973502809784, (643, 1) = .5775241560912212, (643, 2) = .3798994975, (644, 1) = .5757555660659562, (644, 2) = .3785502500902252, (645, 1) = .5740446234513643, (645, 2) = .3763819096, (646, 1) = .5736101496605641, (646, 2) = .3760338564971544, (647, 1) = .5728643216, (647, 2) = .3751237128720331, (648, 1) = .5709518864082601, (648, 2) = .3737567913764426, (649, 1) = .5702772216056209, (649, 2) = .3728643216, (650, 1) = .5683954495706423, (650, 2) = .3714322073018429, (651, 1) = .5667237108415353, (651, 2) = .3693467337, (652, 1) = .5662084085110162, (652, 2) = .3689352385571988, (653, 1) = .5653266332, (653, 2) = .36787345287702866, (654, 1) = .5635969930978948, (654, 2) = .3666363111656846, (655, 1) = .5629742751203055, (655, 2) = .3658291458, (656, 1) = .5610018707510682, (656, 2) = .3643297802952932, (657, 1) = .5593579214862341, (657, 2) = .3623115578, (658, 1) = .5587784698638669, (658, 2) = .36184977939894725, (659, 1) = .5577889447, (659, 2) = .3606740064671954, (660, 1) = .5562002812612103, (660, 2) = .35953534616721994, (661, 1) = .5556163996636694, (661, 2) = .3587939699, (662, 1) = .5535756490882806, (662, 2) = .3572425865635195, (663, 1) = .5519481774786923, (663, 2) = .3552763819, (664, 1) = .5513210977851705, (664, 2) = .3547771225430924, (665, 1) = .5502512563, (665, 2) = .3535225218982832, (666, 1) = .5487638237914856, (666, 2) = .3524529291574846, (667, 1) = .548205776205795, (667, 2) = .351758794, (668, 1) = .5461181799936377, (668, 2) = .35016997500641434, (669, 1) = .544496180139183, (669, 2) = .3482412061, (670, 1) = .5438374735468877, (670, 2) = .34771671674648225, (671, 1) = .5427135678, (671, 2) = .34641553129293345, (672, 1) = .5412904328298684, (672, 2) = .3453877477678323, (673, 1) = .5407455821183196, (673, 2) = .3447236181, (674, 1) = .5386313821145924, (674, 2) = .3431110501756922, (675, 1) = .5370043558098199, (675, 2) = .3412060302, (676, 1) = .5363291734444303, (676, 2) = .3406678263003589, (677, 1) = .5351758794, (677, 2) = .33934905705466345, (678, 1) = .5337835154128445, (678, 2) = .3383382120668299, (679, 1) = .5332398612580557, (679, 2) = .3376884422, (680, 1) = .5311176601280995, (680, 2) = .33606468992432753, (681, 1) = .5294758544975693, (681, 2) = .3341708543, (682, 1) = .5287981735955245, (682, 2) = .33362952905234794, (683, 1) = .5276381909, (683, 2) = .3323186760003023, (684, 1) = .5262469554379412, (684, 2) = .331302509611936, (685, 1) = .5256934115411425, (685, 2) = .3306532664, (686, 1) = .5235798548993649, (686, 2) = .3290295685767022, (687, 1) = .5219145061356738, (687, 2) = .3271356784, (688, 1) = .5212468376963585, (688, 2) = .3266007219780744, (689, 1) = .5201005025000001, (689, 2) = .3253195784676084, (690, 1) = .5186850235658629, (690, 2) = .32427864733217493, (691, 1) = .5181117055244628, (691, 2) = .3236180905, (692, 1) = .5160212069601587, (692, 2) = .32200417379522084, (693, 1) = .5143247836090906, (693, 2) = .3201005025, (694, 1) = .5136779093293781, (694, 2) = .319580124729249, (695, 1) = .5125628141, (695, 2) = .31834660021807604, (696, 1) = .5111023195067798, (696, 2) = .31726447873058555, (697, 1) = .5105008431478002, (697, 2) = .3165829146, (698, 1) = .5084453397499787, (698, 2) = .3149868146935932, (699, 1) = .5067117899829481, (699, 2) = .3130653267, (700, 1) = .5060945113548043, (700, 2) = .3125662800096956, (701, 1) = .5050251256, (701, 2) = .31139425376022367, (702, 1) = .5035037033920832, (702, 2) = .3102577357465086, (703, 1) = .5028674645938366, (703, 2) = .3095477387, (704, 1) = .5008562487621461, (704, 2) = .3079756266466038, (705, 1) = .49908128227054965, (705, 2) = .3060301508, (706, 1) = .4985001758104025, (706, 2) = .3055575394377303, (707, 1) = .4974874372, (707, 2) = .304456676546889, (708, 1) = .4958943147128132, (708, 2) = .3032560199677323, (709, 1) = .49521878144648995, (709, 2) = .3025125628, (710, 1) = .4932583275103768, (710, 2) = .30096855938442, (711, 1) = .49143970647138974, (711, 2) = .2989949749, (712, 1) = .4908988792003061, (712, 2) = .298552047341585, (713, 1) = .4899497487, (713, 2) = .29752756673713127, (714, 1) = .48827959177296715, (714, 2) = .29625679356151713, (715, 1) = .48756259349954817, (715, 2) = .295477387, (716, 1) = .48565636950125635, (716, 2) = .2939633760049808, (717, 1) = .48379416623613464, (717, 2) = .291959799, (718, 1) = .48329505343318435, (718, 2) = .2915477355401902, (719, 1) = .4824120603, (719, 2) = .29060010572401485, (720, 1) = .48066534454485493, (720, 2) = .289257345103619, (721, 1) = .47990739947365446, (721, 2) = .2884422111, (722, 1) = .4780556794864358, (722, 2) = .2869576008322615, (723, 1) = .47615259656772946, (723, 2) = .2849246231, (724, 1) = .4756936967468298, (724, 2) = .2845422714653925, (725, 1) = .47487437180000003, (725, 2) = .28366679383246324, (726, 1) = .47305780017959376, (726, 2) = .2822547686180363, (727, 1) = .4722624051299407, (727, 2) = .2814070352, (728, 1) = .4704621014253052, (728, 2) = .27994850679648364, (729, 1) = .4685237910654614, (729, 2) = .2778894473, (730, 1) = .46810043644502464, (730, 2) = .27753302920421585, (731, 1) = .4673366834, (731, 2) = .27671924899829126, (732, 1) = .46546377749248996, (732, 2) = .2752458820767158, (733, 1) = .46463777623472186, (733, 2) = .2743718593, (734, 1) = .462882201913298, (734, 2) = .2729330294153084, (735, 1) = .4609176282518206, (735, 2) = .2708542714, (736, 1) = .46052168811302885, (736, 2) = .2705170146062497, (737, 1) = .459798995, (737, 2) = .2697479304931192, (738, 1) = .45789077658558486, (738, 2) = .26822718533516565, (739, 1) = .4570446831118084, (739, 2) = .2673366834, (740, 1) = .45532332511948964, (740, 2) = .26590774140465334, (741, 1) = .4533450939443153, (741, 2) = .2638190955, (742, 1) = .4529647331489658, (742, 2) = .26349082973670407, (743, 1) = .4522613065, (743, 2) = .26274186058939175, (744, 1) = .45034718990228606, (744, 2) = .26119476200718766, (745, 1) = .4494955971073297, (745, 2) = .2603015076, (746, 1) = .4477938652157189, (746, 2) = .258868725580079, (747, 1) = .4458186726999408, (747, 2) = .2567839196, (748, 1) = .44543801222302604, (748, 2) = .2564505356778167, (749, 1) = .4447236181, (749, 2) = .2556880681641911, (750, 1) = .4428425490702933, (750, 2) = .2541441638972261, (751, 1) = .44200453441815535, (751, 2) = .2532663317, (752, 1) = .4403034553215288, (752, 2) = .2518114863495001, (753, 1) = .4383524930074799, (753, 2) = .2497487437, (754, 1) = .4379513052215547, (754, 2) = .24939156841671048, (755, 1) = .4371859296, (755, 2) = .24857107563014877, (756, 1) = .4353877964736239, (756, 2) = .24707028458753777, (757, 1) = .4345873846928278, (757, 2) = .2462311558, (758, 1) = .43286326512169326, (758, 2) = .24473081131174035, (759, 1) = .4309626518773221, (759, 2) = .2427135679, (760, 1) = .43051604146422656, (760, 2) = .2423085944341507, (761, 1) = .4296482412, (761, 2) = .24137212881002684, (762, 1) = .4279956301622233, (762, 2) = .23996719840183553, (763, 1) = .42726228438416436, (763, 2) = .2391959799, (764, 1) = .4254864014928762, (764, 2) = .23762058385228169, (765, 1) = .4236677223513047, (765, 2) = .235678392, (766, 1) = .42314575835299, (766, 2) = .23519529606428433, (767, 1) = .4221105528, (767, 2) = .23406808191854572, (768, 1) = .4206809764038216, (768, 2) = .23282793965787185, (769, 1) = .42005011927364955, (769, 2) = .232160804, (770, 1) = .41818835035804597, (770, 2) = .23047357720488884, (771, 1) = .4164891423916891, (771, 2) = .2286432161, (772, 1) = .41585654734415745, (772, 2) = .22804416402407998, (773, 1) = .4145728643, (773, 2) = .22663005384130125, (774, 1) = .4134615419041726, (774, 2) = .22564424531510408, (775, 1) = .4129751290419361, (775, 2) = .2251256282, (776, 1) = .41098762195120536, (776, 2) = .22328115333415552, (777, 1) = .409451948899132, (777, 2) = .2216080402, (778, 1) = .40866775863832683, (778, 2) = .22084616825977926, (779, 1) = .4070351759, (779, 2) = .21902147969544994, (780, 1) = .40635849858888623, (780, 2) = .2184062350392016, (781, 1) = .40606557138981003, (781, 2) = .2180904523, (782, 1) = .40390643609215177, (782, 2) = .21603294289083183, (783, 1) = .4025853816638798, (783, 2) = .2145728643, (784, 1) = .40160277314883797, (784, 2) = .21359039763582902, (785, 1) = .3994974874, (785, 2) = .2111953916267515, (786, 1) = .3993974872014272, (786, 2) = .21110194315906863, (787, 1) = .3993548061582575, (787, 2) = .2110552764, (788, 1) = .3969718915680006, (788, 2) = .20871629988156515, (789, 1) = .3959241588145738, (789, 2) = .2075376885, (790, 1) = .39469021826668604, (790, 2) = .20626349281323436, (791, 1) = .39275962858671026, (791, 2) = .2040201005, (792, 1) = .392519651602392, (792, 2) = .20375883595370253, (793, 1) = .391959799, (793, 2) = .20308410518162512, (794, 1) = .39021706301913595, (794, 2) = .20131578937565633, (795, 1) = .38950935111294255, (795, 2) = .2005025126, (796, 1) = .38796528144486087, (796, 2) = .1988490328100629, (797, 1) = .3864011183684566, (797, 2) = .1969849246, (798, 1) = .38582386658866763, (798, 2) = .19633077177101954, (799, 1) = .3844221105, (799, 2) = .19459086094504696, (800, 1) = .3836829143299022, (800, 2) = .193812294910751, (801, 1) = .3833902777843438, (801, 2) = .1934673367, (802, 1) = .381471712002041, (802, 2) = .1913266014245525, (803, 1) = .38035036929423216, (803, 2) = .1899497488, (804, 1) = .3793717347632515, (804, 2) = .18878900286408398, (805, 1) = .3775375943541058, (805, 2) = .1864321608, (806, 1) = .37736166644215346, (806, 2) = .18620944677492798, (807, 1) = .3768844221, (807, 2) = .18556448319466476, (808, 1) = .37526450636538733, (808, 2) = .18367053357185437, (809, 1) = .37467008495738585, (809, 2) = .1829145729, (810, 1) = .3732225171948196, (810, 2) = .1811058738946159, (811, 1) = .3719455222249287, (811, 2) = .1793969849, (812, 1) = .37127502391601463, (812, 2) = .1784971161376429, (813, 1) = .3694265308925138, (813, 2) = .175879397, (814, 1) = .36940710803346855, (814, 2) = .17585122231120817, (815, 1) = .3693467337, (815, 2) = .17576016082628151, (816, 1) = .3674517163812426, (816, 2) = .17324615049865977, (817, 1) = .36682165777307724, (817, 2) = .1723618091, (818, 1) = .36559224125493306, (818, 2) = .1705963175909678, (819, 1) = .36442118216746267, (819, 2) = .1688442211, (820, 1) = .3638217120726433, (820, 2) = .16790497657723402, (821, 1) = .36221745198925714, (821, 2) = .1653266332, (822, 1) = .3621305321083684, (822, 2) = .16517660597467304, (823, 1) = .3618090452, (823, 2) = .16461658191612735, (824, 1) = .36042004933611393, (824, 2) = .1624572432845554, (825, 1) = .36001413241598124, (825, 2) = .1618090452, (826, 1) = .35878654053790004, (826, 2) = .1597019594676269, (827, 1) = .35797284794656337, (827, 2) = .1582914573, (828, 1) = .3572489110137369, (828, 2) = .15690193200815655, (829, 1) = .35613069273590464, (829, 2) = .1547738694, (830, 1) = .35580307897280694, (830, 2) = .15405906570310007, (831, 1) = .35448015596563326, (831, 2) = .1512562814, (832, 1) = .35444769995839687, (832, 2) = .15117398792654935, (833, 1) = .3542713568, (833, 2) = .15075051674419104, (834, 1) = .35313609511999666, (834, 2) = .14826848227396078, (835, 1) = .3528862293167243, (835, 2) = .1477386935, (836, 1) = .3519356554209787, (836, 2) = .14531109948720555, (837, 1) = .3514838197463479, (837, 2) = .1442211055, (838, 1) = .3508593758497697, (838, 2) = .14229577534659707, (839, 1) = .3502938221071534, (839, 2) = .1407035176, (840, 1) = .34991447247732055, (840, 2) = .13921914234538285, (841, 1) = .34931756648448753, (841, 2) = .1371859297, (842, 1) = .34911207147452883, (842, 2) = .1360760082080354, (843, 1) = .3485591799566558, (843, 2) = .1336683417, (844, 1) = .34846783507255363, (844, 2) = .13285906388814606, (845, 1) = .3480257881214767, (845, 2) = .1301507538, (846, 1) = .34800289002801055, (846, 2) = .12955845032131563, (847, 1) = .3477271310309451, (847, 2) = .1266331658, (848, 1) = .34774494448408766, (848, 2) = .1261612369230366, (849, 1) = .34767622997613645, (849, 2) = .1231155779, (850, 1) = .3477303651018057, (850, 2) = .12265045273463923, (851, 1) = .34788888406570395, (851, 2) = .11959799, (852, 1) = .3480062614091848, (852, 2) = .11900411321008608, (853, 1) = .34838511373913356, (853, 2) = .116080402, (854, 1) = .34863491884857173, (854, 2) = .11519315176081538, (855, 1) = .34918839173015104, (855, 2) = .1125628141, (856, 1) = .3496982391676152, (856, 2) = .11117934768200291, (857, 1) = .3503275726503486, (857, 2) = .1090452261, (858, 1) = .35130638070456277, (858, 2) = .10691129368498048, (859, 1) = .3518364954202148, (859, 2) = .1055276382, (860, 1) = .35360882560815554, (860, 2) = .10231923151700102, (861, 1) = .3537558522159866, (861, 2) = .1020100503, (862, 1) = .3542713568, (862, 2) = .10121702392963003, (863, 1) = .35600053248665653, (863, 2) = 0.9849246232e-1, (864, 1) = .3570572854492312, (864, 2) = 0.971923622763001e-1, (865, 1) = .3586926055897353, (865, 2) = 0.9497487438e-1, (866, 1) = .3618090452, (866, 2) = 0.9158716902677788e-1, (867, 1) = .36192709856954863, (867, 2) = 0.9145728644e-1, (868, 1) = .36205005931326456, (868, 2) = 0.9134481318799587e-1, (869, 1) = .3655390548364391, (869, 2) = 0.879396985e-1, (870, 1) = .3693467337, (870, 2) = 0.8479882969331587e-1, (871, 1) = .3698033059098153, (871, 2) = 0.8442211056e-1, (872, 1) = .3706635536566944, (872, 2) = 0.8380759457671531e-1, (873, 1) = .3745661678736847, (873, 2) = 0.8090452262e-1, (874, 1) = .3768844221, (874, 2) = 0.7939356176205672e-1, (875, 1) = .3799996782143442, (875, 2) = 0.7738693467999999e-1, (876, 1) = .3844221105, (876, 2) = 0.7484642389505781e-1, (877, 1) = .3861556705887529, (877, 2) = 0.7386934674000001e-1, (878, 1) = .391959799, (878, 2) = 0.7090689451692438e-1, (879, 1) = .3930765595362171, (879, 2) = 0.703517588e-1, (880, 1) = .3994974874, (880, 2) = 0.6742285625731652e-1, (881, 1) = .40083272374395407, (881, 2) = 0.6683417086e-1, (882, 1) = .4070351759, (882, 2) = 0.6429437718838504e-1, (883, 1) = .40952543844393996, (883, 2) = 0.6331658292e-1, (884, 1) = .4145728643, (884, 2) = 0.6145535700961236e-1, (885, 1) = .4192968081098093, (885, 2) = 0.59798994980000006e-1, (886, 1) = .4221105528, (886, 2) = 0.58862877992759986e-1, (887, 1) = .4282230450362326, (887, 2) = 0.56946498586872965e-1, (888, 1) = .4296482412, (888, 2) = 0.5648318909637347e-1, (889, 1) = .4303077493632227, (889, 2) = 0.56281407039999995e-1, (890, 1) = .4371859296, (890, 2) = 0.54259072419220275e-1, (891, 1) = .44264178968086776, (891, 2) = 0.527638191e-1, (892, 1) = .4447236181, (892, 2) = 0.52210303355024364e-1, (893, 1) = .4472230956927635, (893, 2) = 0.515973962167451e-1, (894, 1) = .4522613065, (894, 2) = 0.50284417107303435e-1, (895, 1) = .45658545521222793, (895, 2) = 0.4924623116e-1, (896, 1) = .459798995, (896, 2) = 0.4848899261063059e-1, (897, 1) = .46280252505544006, (897, 2) = 0.4784458379282528e-1, (898, 1) = .4673366834, (898, 2) = 0.46795889980450964e-1, (899, 1) = .47240959498250634, (899, 2) = 0.4572864322e-1, (900, 1) = .47487437180000003, (900, 2) = 0.4521380652728622e-1, (901, 1) = .4767185263750812, (901, 2) = 0.44868037758152964e-1, (902, 1) = .4824120603, (902, 2) = 0.4369939046343149e-1, (903, 1) = .48959308784095523, (903, 2) = 0.4237749701516724e-1, (904, 1) = .4899497487, (904, 2) = 0.4230553368836941e-1, (905, 1) = .49047231758269894, (905, 2) = 0.4221105528e-1, (906, 1) = .4974874372, (906, 2) = 0.4093529701697809e-1, (907, 1) = .5016543282464547, (907, 2) = 0.4026650611393161e-1, (908, 1) = .5050251256, (908, 2) = 0.396633456864977e-1, (909, 1) = .5111714689337563, (909, 2) = 0.3869346734e-1, (910, 1) = .5125628141, (910, 2) = 0.3846993033295939e-1, (911, 1) = .5132454260727137, (911, 2) = 0.3837491508425573e-1, (912, 1) = .5201005025000001, (912, 2) = 0.3729037232594075e-1, (913, 1) = .5243561999220785, (913, 2) = 0.3670747519840497e-1, (914, 1) = .5276381909, (914, 2) = 0.361960293284916e-1, (915, 1) = .5351639749169139, (915, 2) = 0.35181434825398046e-1, (916, 1) = .5351758794, (916, 2) = 0.3517960712411226e-1, (917, 1) = .5352039640893407, (917, 2) = 0.351758794e-1, (918, 1) = .5427135678, (918, 2) = 0.3414537152140694e-1, (919, 1) = .5456536286452462, (919, 2) = 0.3380385101595303e-1, (920, 1) = .5502512563, (920, 2) = 0.3318185834638168e-1, (921, 1) = .5559125375649836, (921, 2) = 0.32533948127986365e-1, (922, 1) = .5577889447, (922, 2) = 0.32283633189427896e-1, (923, 1) = .5633336520075796, (923, 2) = 0.3165829146e-1, (924, 1) = .5653266332, (924, 2) = 0.3142227202497525e-1, (925, 1) = .565966100123562, (925, 2) = 0.31359873560641016e-1, (926, 1) = .5728643216, (926, 2) = 0.305538817413697e-1, (927, 1) = .5758455924285844, (927, 2) = 0.30267031732083685e-1, (928, 1) = .58040201, (928, 2) = 0.29741684432756765e-1, (929, 1) = .5855573291499552, (929, 2) = 0.29252475874925958e-1, (930, 1) = .5879396985, (930, 2) = 0.2898136940407693e-1, (931, 1) = .595115285505753, (931, 2) = 0.283096841716094e-1, (932, 1) = .5954773869, (932, 2) = 0.28269007546813177e-1, (933, 1) = .5968666341939834, (933, 2) = 0.2814070352e-1, (934, 1) = .6030150754, (934, 2) = 0.2753280844868558e-1, (935, 1) = .6045819714386098, (935, 2) = 0.2740948536449127e-1, (936, 1) = .6105527638, (936, 2) = 0.26826477584338135e-1, (937, 1) = .6139314406005736, (937, 2) = 0.2656398767076758e-1, (938, 1) = .6180904522, (938, 2) = 0.26162862729445055e-1, (939, 1) = .6231622868236661, (939, 2) = 0.2577384738023213e-1, (940, 1) = .6256281407, (940, 2) = 0.2553889994482989e-1, (941, 1) = .6322835703619627, (941, 2) = 0.25034836326758337e-1, (942, 1) = .6331658291, (942, 2) = 0.24951778970738848e-1, (943, 1) = .6375598731700047, (943, 2) = 0.2462311558e-1, (944, 1) = .6407035176, (944, 2) = 0.24365645583709933e-1, (945, 1) = .6413404044011137, (945, 2) = 0.24325901737790392e-1, (946, 1) = .648241206, (946, 2) = 0.2376726243192491e-1, (947, 1) = .650354354409826, (947, 2) = 0.2363697966289041e-1, (948, 1) = .6557788945, (948, 2) = 0.23202876747452174e-1, (949, 1) = .6592792159444876, (949, 2) = 0.22989632229951592e-1, (950, 1) = .6633165829, (950, 2) = 0.22670196423136894e-1, (951, 1) = .6681212854119927, (951, 2) = 0.223809210616549e-1, (952, 1) = .6708542713, (952, 2) = 0.22167107750822528e-1, (953, 1) = .6768863475434768, (953, 2) = 0.21808146687717637e-1, (954, 1) = .6783919598, (954, 2) = 0.21691659655115058e-1, (955, 1) = .6855797218834964, (955, 2) = 0.2126882658863016e-1, (956, 1) = .6859296482, (956, 2) = 0.21242049584500284e-1, (957, 1) = .6882769815080421, (957, 2) = 0.2110552764e-1, (958, 1) = .6934673366999999, (958, 2) = 0.20765257463606517e-1, (959, 1) = .6942782870063637, (959, 2) = 0.20727084161545162e-1, (960, 1) = .7010050251, (960, 2) = 0.2029078959933281e-1, (961, 1) = .7029443560795692, (961, 2) = 0.2020050651105533e-1, (962, 1) = .7085427135, (962, 2) = 0.19841225711516006e-1, (963, 1) = .7115485178221507, (963, 2) = 0.19702818966963537e-1, (964, 1) = .716080402, (964, 2) = 0.1941501363032748e-1, (965, 1) = .7200947644244649, (965, 2) = 0.1923215849793163e-1, (966, 1) = .7236180904, (966, 2) = 0.19010712863990607e-1, (967, 1) = .7285867916455377, (967, 2) = 0.18786800409660548e-1, (968, 1) = .7311557789, (968, 2) = 0.18626985602721843e-1, (969, 1) = .7370280236098778, (969, 2) = 0.1836514675980933e-1, (970, 1) = .7386934673000001, (970, 2) = 0.1826258831020113e-1, (971, 1) = .7454216355278264, (971, 2) = 0.17965715824150474e-1, (972, 1) = .7462311558, (972, 2) = 0.17916364329992548e-1, (973, 1) = .7537520904730234, (973, 2) = 0.175879397e-1, (974, 1) = .7537688442, (974, 2) = 0.1758708291517289e-1, (975, 1) = .7537708232711489, (975, 2) = 0.1758701613345861e-1, (976, 1) = .7613065326, (976, 2) = 0.17205408105431967e-1, (977, 1) = .762189441390788, (977, 2) = 0.17175915600755754e-1, (978, 1) = .7688442211, (978, 2) = 0.16842180636616112e-1, (979, 1) = .7705641600195864, (979, 2) = 0.16785301532962777e-1, (980, 1) = .7763819095, (980, 2) = 0.16496341045990695e-1, (981, 1) = .7788975599900472, (981, 2) = 0.16413969480211094e-1, (982, 1) = .783919598, (982, 2) = 0.161669001252912e-1, (983, 1) = .7871920474477319, (983, 2) = 0.16060796615708868e-1, (984, 1) = .7914572864, (984, 2) = 0.15852933714335812e-1, (985, 1) = .7954498668852796, (985, 2) = 0.15724735487661082e-1, (986, 1) = .7989949749, (986, 2) = 0.15553577831292395e-1, (987, 1) = .8036731134194652, (987, 2) = 0.15404808378503531e-1, (988, 1) = .8065326633000001, (988, 2) = 0.1526802429009741e-1, (989, 1) = .8118637441392688, (989, 2) = 0.15100101960862838e-1, (990, 1) = .8140703517000001, (990, 2) = 0.14995516542107262e-1, (991, 1) = .820023588478201, (991, 2) = 0.14809762557900735e-1, (992, 1) = .8216080402, (992, 2) = 0.14735345990338197e-1, (993, 1) = .828154357305367, (993, 2) = 0.14532991700125845e-1, (994, 1) = .8291457286, (994, 2) = 0.14486848543279984e-1, (995, 1) = .8362576521039642, (995, 2) = 0.14269042089977133e-1, (996, 1) = .8366834170999999, (996, 2) = 0.1424940141519132e-1, (997, 1) = .8425838567082613, (997, 2) = 0.1407035176e-1, (998, 1) = .8442211055, (998, 2) = 0.14008820617902599e-1, (999, 1) = .8443593944967582, (999, 2) = 0.14005816894479228e-1, (1000, 1) = .8517587939, (1000, 2) = 0.137301598694701e-1, (1001, 1) = .8525230281459295, (1001, 2) = 0.13713709114603212e-1, (1002, 1) = .8592964824, (1002, 2) = 0.13463554679394443e-1, (1003, 1) = .8606590540865626, (1003, 2) = 0.1343448496932211e-1, (1004, 1) = .8668341708, (1004, 2) = 0.1320838470286819e-1, (1005, 1) = .8687689137120126, (1005, 2) = 0.13167471741238845e-1, (1006, 1) = .8743718593, (1006, 2) = 0.12964066476802675e-1, (1007, 1) = .87685396181245, (1007, 2) = 0.12912037247604214e-1, (1008, 1) = .8819095477, (1008, 2) = 0.12730051028875658e-1, (1009, 1) = .8849154718718103, (1009, 2) = 0.12667587157122835e-1, (1010, 1) = .8894472362, (1010, 2) = 0.12505821439256576e-1, (1011, 1) = .8929546421108857, (1011, 2) = 0.1243356232561369e-1, (1012, 1) = .8969849246, (1012, 2) = 0.12290890824841728e-1, (1013, 1) = .9009726001279909, (1013, 2) = 0.1220943650302366e-1, (1014, 1) = .904522613, (1014, 2) = 0.12084800358004747e-1, (1015, 1) = .9089704079143057, (1015, 2) = 0.11994714149059275e-1, (1016, 1) = .9120603015, (1016, 2) = 0.11887117334707719e-1, (1017, 1) = .9169490659352877, (1017, 2) = 0.11788928343894226e-1, (1018, 1) = .9195979899, (1018, 2) = 0.11697433621062113e-1, (1019, 1) = .9249095173296698, (1019, 2) = 0.11591638978278456e-1, (1020, 1) = .9271356784, (1020, 2) = 0.11515363969705617e-1, (1021, 1) = .9328526515029625, (1021, 2) = 0.11402430963448429e-1, (1022, 1) = .9346733668, (1022, 2) = 0.11340544619749256e-1, (1023, 1) = .9407793076969329, (1023, 2) = 0.11220912658563596e-1, (1024, 1) = .9422110552, (1024, 2) = 0.1117263192432869e-1, (1025, 1) = .9486902783114621, (1025, 2) = 0.11046714330906418e-1, (1026, 1) = .9497487437000001, (1026, 2) = 0.1101130107700609e-1, (1027, 1) = .9565863114418658, (1027, 2) = 0.10879486795653657e-1, (1028, 1) = .9572864321, (1028, 2) = 0.10856244955774159e-1, (1029, 1) = .9644681142626971, (1029, 2) = 0.10718900109481845e-1, (1030, 1) = .9648241206, (1030, 2) = 0.10707173025501376e-1, (1031, 1) = .9723363549339009, (1031, 2) = 0.10564642384247074e-1, (1032, 1) = .972361809, (1032, 2) = 0.10563810333045955e-1, (1033, 1) = .972948630488885, (1033, 2) = 0.1055276382e-1, (1034, 1) = .9798994975, (1034, 2) = 0.10375296743919172e-1, (1035, 1) = .9802894902052824, (1035, 2) = 0.10370767223166771e-1, (1036, 1) = .9874371859, (1036, 2) = 0.10189649970835095e-1, (1037, 1) = .9882349895451341, (1037, 2) = 0.10180455450153872e-1, (1038, 1) = .9949748743, (1038, 2) = 0.10010949173809373e-1, (1039, 1) = .9961650738976088, (1039, 2) = 0.999733736006387e-2, (1040, 1) = 1.002512563, (1040, 2) = 0.9838884859509671e-2, (1041, 1) = 1.0040804354592772, (1041, 2) = 0.982108996268309e-2, (1042, 1) = 1.010050251, (1042, 2) = 0.9673163544900765e-2, (1043, 1) = 1.0119817298630203, (1043, 2) = 0.9651407083880376e-2, (1044, 1) = 1.01758794, (1044, 2) = 0.9513506697126249e-2, (1045, 1) = 1.019869580330979, (1045, 2) = 0.9487998269652366e-2, (1046, 1) = 1.025125628, (1046, 2) = 0.9359650041939265e-2, (1047, 1) = 1.0277445763542137, (1047, 2) = 0.9330588011703222e-2, (1048, 1) = 1.032663317, (1048, 2) = 0.9211342550790206e-2, (1049, 1) = 1.0356072791518431, (1049, 2) = 0.9178914735089576e-2, (1050, 1) = 1.040201005, (1050, 2) = 0.9068345848323164e-2, (1051, 1) = 1.0434582198901152, (1051, 2) = 0.9032730115307322e-2, (1052, 1) = 1.047738693, (1052, 2) = 0.8930433399104435e-2, (1053, 1) = 1.0512979052007219, (1053, 2) = 0.8891798249098935e-2, (1054, 1) = 1.055276382, (1054, 2) = 0.8797389809478761e-2, (1055, 1) = 1.0591268151015514, (1055, 2) = 0.8755894933705672e-2, (1056, 1) = 1.06281407, (1056, 2) = 0.8669010341211997e-2, (1057, 1) = 1.0669454061442312, (1057, 2) = 0.8624807095195669e-2, (1058, 1) = 1.070351759, (1058, 2) = 0.8545100142396437e-2, (1059, 1) = 1.0747541125000146, (1059, 2) = 0.849833206595714e-2, (1060, 1) = 1.077889447, (1060, 2) = 0.8425473873461183e-2, (1061, 1) = 1.0825533475002227, (1061, 2) = 0.8376277080769497e-2, (1062, 1) = 1.085427136, (1062, 2) = 0.8309955025592194e-2, (1063, 1) = 1.0903435038637583, (1063, 2) = 0.825845868211691e-2, (1064, 1) = 1.092964824, (1064, 2) = 0.8198375587480662e-2, (1065, 1) = 1.098124956361655, (1065, 2) = 0.8144702229217713e-2, (1066, 1) = 1.100502513, (1066, 2) = 0.8090575419868377e-2, (1067, 1) = 1.1058980607216682, (1067, 2) = 0.8034841401954203e-2, (1068, 1) = 1.108040201, (1068, 2) = 0.7986402020879288e-2, (1069, 1) = 1.1136631564424686, (1069, 2) = 0.7928717792678995e-2, (1070, 1) = 1.115577889, (1070, 2) = 0.7885709958806586e-2, (1071, 1) = 1.12142056817452, (1071, 2) = 0.7826180406757498e-2, (1072, 1) = 1.123115578, (1072, 2) = 0.7788360554924944e-2, (1073, 1) = 1.1291706029325228, (1073, 2) = 0.7727085352140572e-2, (1074, 1) = 1.130653266, (1074, 2) = 0.7694221588903191e-2, (1075, 1) = 1.136913555945145, (1075, 2) = 0.763129539487053e-2, (1076, 1) = 1.138190955, (1076, 2) = 0.76031668339430775e-2, (1077, 1) = 1.144649706412218, (1077, 2) = 0.7538679650546904e-2, (1078, 1) = 1.145728643, (1078, 2) = 0.75150758714770905e-2, (1079, 1) = 1.1523793233660806, (1079, 2) = 0.7449113211899923e-2, (1080, 1) = 1.153266332, (1080, 2) = 0.742983367651974e-2, (1081, 1) = 1.1601026607210896, (1081, 2) = 0.7362476896054679e-2, (1082, 1) = 1.16080402, (1082, 2) = 0.7347330459511903e-2, (1083, 1) = 1.1678199639698905, (1083, 2) = 0.7278656876054324e-2, (1084, 1) = 1.168341709, (1084, 2) = 0.72674612771414715e-2, (1085, 1) = 1.1755314643121628, (1085, 2) = 0.7197544477196978e-2, (1086, 1) = 1.175879397, (1086, 2) = 0.7190125892962781e-2, (1087, 1) = 1.1832373850662354, (1087, 2) = 0.71190358540171176e-2, (1088, 1) = 1.183417085, (1088, 2) = 0.71152284588298234e-2, (1089, 1) = 1.1909379399404183, (1089, 2) = 0.7043031773890721e-2, (1090, 1) = 1.190954774, (1090, 2) = 0.7042677335802723e-2, (1091, 1) = 1.1917412351176269, (1091, 2) = 0.7035175879999999e-2, (1092, 1) = 1.198492462, (1092, 2) = 0.6930572699126082e-2, (1093, 1) = 1.1987185238181046, (1093, 2) = 0.69296803726821305e-2, (1094, 1) = 1.206030151, (1094, 2) = 0.6817094642930465e-2, (1095, 1) = 1.2065014290735379, (1095, 2) = 0.681524609942756e-2, (1096, 1) = 1.213567839, (1096, 2) = 0.6707104748696734e-2, (1097, 1) = 1.214276769996557, (1097, 2) = 0.67043414393934e-2, (1098, 1) = 1.221105528, (1098, 2) = 0.660047513151033e-2, (1099, 1) = 1.2220448262760126, (1099, 2) = 0.659683665877399e-2, (1100, 1) = 1.228643216, (1100, 2) = 0.6497083404960625e-2, (1101, 1) = 1.2298058622217876, (1101, 2) = 0.6492607611288709e-2, (1102, 1) = 1.236180904, (1102, 2) = 0.6396812289077833e-2, (1103, 1) = 1.2375601338214697, (1103, 2) = 0.639153534422181e-2, (1104, 1) = 1.243718593, (1104, 2) = 0.6299549430507505e-2, (1105, 1) = 1.2453078856874127, (1105, 2) = 0.6293505915632566e-2, (1106, 1) = 1.251256281, (1106, 2) = 0.6205187243968288e-2, (1107, 1) = 1.2530493503958227, (1107, 2) = 0.6198410223798384e-2, (1108, 1) = 1.25879397, (1108, 2) = 0.6113622509922266e-2, (1109, 1) = 1.2607847533153351, (1109, 2) = 0.6106143611594024e-2, (1110, 1) = 1.266331658, (1110, 2) = 0.6024756333067465e-2, (1111, 1) = 1.268514308313239, (1111, 2) = 0.601660580910859e-2, (1112, 1) = 1.273869347, (1112, 2) = 0.5938493832349033e-2, (1113, 1) = 1.2762382223896214, (1113, 2) = 0.59297006332274076e-2, (1114, 1) = 1.281407035, (1114, 2) = 0.58547440350789695e-2, (1115, 1) = 1.283956692368622, (1115, 2) = 0.5845335862589219e-2, (1116, 1) = 1.288944724, (1116, 2) = 0.5773419610608419e-2, (1117, 1) = 1.2916699086100987, (1117, 2) = 0.5763422987235457e-2, (1118, 1) = 1.296482412, (1118, 2) = 0.5694436786844592e-2, (1119, 1) = 1.299378052070196, (1119, 2) = 0.5683877101183213e-2, (1120, 1) = 1.3040201, (1120, 2) = 0.5617715132353588e-2, (1121, 1) = 1.307081298478856, (1121, 2) = 0.5606616695458106e-2, (1122, 1) = 1.311557789, (1122, 2) = 0.5543177397281742e-2, (1123, 1) = 1.314779815340327, (1123, 2) = 0.55315634995066285e-2, (1124, 1) = 1.319095477, (1124, 2) = 0.5470749445679901e-2, (1125, 1) = 1.3224737632974548, (1125, 2) = 0.5458642391049434e-2, (1126, 1) = 1.326633166, (1126, 2) = 0.540036000120043e-2, (1127, 1) = 1.3301632973227266, (1127, 2) = 0.53877811659392184e-2, (1128, 1) = 1.334170854, (1128, 2) = 0.5331940629590904e-2, (1129, 1) = 1.3378485658135628, (1129, 2) = 0.53189104938605476e-2, (1130, 1) = 1.341708543, (1130, 2) = 0.5265425527342091e-2, (1131, 1) = 1.3455297116798746, (1131, 2) = 0.5251963724623916e-2, (1132, 1) = 1.349246231, (1132, 2) = 0.5200751470099699e-2, (1133, 1) = 1.3532068721423451, (1133, 2) = 0.5186876816854617e-2, (1134, 1) = 1.35678392, (1134, 2) = 0.513785764049644e-2, (1135, 1) = 1.3608801791070615, (1135, 2) = 0.5123588184394362e-2, (1136, 1) = 1.364321608, (1136, 2) = 0.5076685573683551e-2, (1137, 1) = 1.3685497590319484, (1137, 2) = 0.5062038615830922e-2, (1138, 1) = 1.371859296, (1138, 2) = 0.50171790218632795e-2, (1139, 1) = 1.3762157350164028, (1139, 2) = 0.500217115594679e-2, (1140, 1) = 1.379396985, (1140, 2) = 0.4959283859897053e-2, (1141, 1) = 1.383878223746966, (1141, 2) = 0.49439310085502754e-2, (1142, 1) = 1.386934673, (1142, 2) = 0.4902948031323432e-2, (1143, 1) = 1.3915373385162417, (1143, 2) = 0.48872654645150965e-2, (1144, 1) = 1.394472362, (1144, 2) = 0.4848121398297026e-2, (1145, 1) = 1.399193187662768, (1145, 2) = 0.4832123774606931e-2, (1146, 1) = 1.40201005, (1146, 2) = 0.4794755721534188e-2, (1147, 1) = 1.4068458763116132, (1147, 2) = 0.477845710138426e-2, (1148, 1) = 1.409547739, (1148, 2) = 0.474280452752723e-2, (1149, 1) = 1.414495504702633, (1149, 2) = 0.4726218416447846e-2, (1150, 1) = 1.417085427, (1150, 2) = 0.4692223081836024e-2, (1151, 1) = 1.422142170476746, (1151, 2) = 0.46753624319423905e-2, (1152, 1) = 1.424623116, (1152, 2) = 0.4642968265171549e-2, (1153, 1) = 1.4297859664576211, (1153, 2) = 0.46258455248896204e-2, (1154, 1) = 1.432160804, (1154, 2) = 0.4594998559349632e-2, (1155, 1) = 1.437426982704413, (1155, 2) = 0.45776256735536765e-2, (1156, 1) = 1.439698492, (1156, 2) = 0.45482739392615785e-2, (1157, 1) = 1.4450653070434634, (1157, 2) = 0.45306623781697156e-2, (1158, 1) = 1.447236181, (1158, 2) = 0.4502755819620253e-2, (1159, 1) = 1.452701021972946, (1159, 2) = 0.44849166094580745e-2, (1160, 1) = 1.454773869, (1160, 2) = 0.4458407028562616e-2, (1161, 1) = 1.4603342089784799, (1161, 2) = 0.4440350748504083e-2, (1162, 1) = 1.462311558, (1162, 2) = 0.441519169049109e-2, (1163, 1) = 1.4679649448741687, (1163, 2) = 0.4396928517051396e-2, (1164, 1) = 1.469849246, (1164, 2) = 0.4373075238167609e-2, (1165, 1) = 1.475593305588006, (1165, 2) = 0.43546149370622626e-2, (1166, 1) = 1.477386935, (1166, 2) = 0.4332024301478836e-2, (1167, 1) = 1.4832193623974281, (1167, 2) = 0.43133762679546e-2, (1168, 1) = 1.484924623, (1168, 2) = 0.4292006710999836e-2, (1169, 1) = 1.4908431861151392, (1169, 2) = 0.4273179963752635e-2, (1170, 1) = 1.492462312, (1170, 2) = 0.4252991400793571e-2, (1171, 1) = 1.4984648429204566, (1171, 2) = 0.4233994619210856e-2, (1172, 1) = 1.5, (1172, 2) = 0.4214948412973115e-2, (1173, 1) = 15.0, (1173, 2) = .0, (1174, 1) = .7763819095, (1174, 2) = .607778751889855, (1175, 1) = .7765917979042034, (1175, 2) = .6084447656798948, (1176, 1) = .7767164064919965, (1176, 2) = .6085427136, (1177, 1) = .7771436112395627, (1177, 2) = .6117048407848357, (1178, 1) = .7777259884990406, (1178, 2) = .6120603016, (1179, 1) = .7767494783952099, (1179, 2) = .6154063573521529, (1180, 1) = .7773546337016262, (1180, 2) = .6155778894999999, (1181, 1) = .7763819095, (1181, 2) = .615964402185334, (1182, 1) = .7762628509681525, (1182, 2) = .6156334501478794, (1183, 1) = .7761810796799455, (1183, 2) = .6155778894999999, (1184, 1) = .7755991837432397, (1184, 2) = .6124255736177447, (1185, 1) = .7748754415956448, (1185, 2) = .6120603016, (1186, 1) = .775676891794233, (1186, 2) = .6088717218701738, (1187, 1) = .7738241995201303, (1187, 2) = .6085427136, (1188, 1) = .7763819095, (1188, 2) = .607778751889855, (1189, 1) = 11.0, (1189, 2) = .0, (1190, 1) = .783919598, (1190, 2) = .6188678901371553, (1191, 1) = .78397674840546, (1191, 2) = .6190688072109369, (1192, 1) = .7840111953751815, (1192, 2) = .6190954773999999, (1193, 1) = .7842955859737704, (1193, 2) = .6224376043415832, (1194, 1) = .7845976136243192, (1194, 2) = .6226130653999999, (1195, 1) = .783919598, (1195, 2) = .6242381964078862, (1196, 1) = .7835965867154213, (1196, 2) = .6227638039966131, (1197, 1) = .7833238842954877, (1197, 2) = .6226130653999999, (1198, 1) = .7837710236567536, (1198, 2) = .619164812094172, (1199, 1) = .7835088566664069, (1199, 2) = .6190954773999999, (1200, 1) = .783919598, (1200, 2) = .6188678901371553, (1201, 1) = .0, (1201, 2) = .0, (1202, 1) = .0, (1202, 2) = .0, (1203, 1) = .0, (1203, 2) = .0}, datatype = float[8], order = C_order))]), Array(1..15, 1..2, {(1, 1) = .7763819095, (1, 2) = .607778751889855, (2, 1) = .7765917979042034, (2, 2) = .6084447656798948, (3, 1) = .7767164064919965, (3, 2) = .6085427136, (4, 1) = .7771436112395627, (4, 2) = .6117048407848357, (5, 1) = .7777259884990406, (5, 2) = .6120603016, (6, 1) = .7767494783952099, (6, 2) = .6154063573521529, (7, 1) = .7773546337016262, (7, 2) = .6155778894999999, (8, 1) = .7763819095, (8, 2) = .615964402185334, (9, 1) = .7762628509681525, (9, 2) = .6156334501478794, (10, 1) = .7761810796799455, (10, 2) = .6155778894999999, (11, 1) = .7755991837432397, (11, 2) = .6124255736177447, (12, 1) = .7748754415956448, (12, 2) = .6120603016, (13, 1) = .775676891794233, (13, 2) = .6088717218701738, (14, 1) = .7738241995201303, (14, 2) = .6085427136, (15, 1) = .7763819095, (15, 2) = .607778751889855}, datatype = float[8], order = C_order, attributes = [source_rtable = (Array(1..1203, 1..2, {(1, 1) = 1171.0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .1563469655787127, (3, 1) = 0.411404206213146e-2, (3, 2) = .1563715710259522, (4, 1) = 0.7537688442e-2, (4, 2) = .1563939703226259, (5, 1) = 0.11453278530964653e-1, (5, 2) = .1564641819447511, (6, 1) = 0.1507537688e-1, (6, 2) = .15653540477192268, (7, 1) = 0.1861188724047196e-1, (7, 2) = .15664108581877745, (8, 1) = 0.2261306533e-1, (8, 2) = .15677253817326953, (9, 1) = 0.25599994493771153e-1, (9, 2) = .15689755703889574, (10, 1) = 0.3015075377e-1, (10, 2) = .1571075215866537, (11, 1) = 0.3242521581787689e-1, (11, 2) = .15723004168932495, (12, 1) = 0.3768844221e-1, (12, 2) = .1575434428479125, (13, 1) = 0.3909288395460391e-1, (13, 2) = .15763605115972262, (14, 1) = 0.4522613065e-1, (14, 2) = .1580844082091386, (15, 1) = 0.4560620688944438e-1, (15, 2) = .158114088390209, (16, 1) = 0.4764869985153962e-1, (16, 2) = .1582914573, (17, 1) = 0.5204162039916189e-1, (17, 2) = .15862848335201973, (18, 1) = 0.5276381909e-1, (18, 2) = .15868992174261032, (19, 1) = 0.5837968585731567e-1, (19, 2) = .1591883074075377, (20, 1) = 0.6030150754e-1, (20, 2) = .15937801020899345, (21, 1) = 0.6458489561557128e-1, (21, 2) = .15981013078670622, (22, 1) = 0.6783919598e-1, (22, 2) = .160176487241211, (23, 1) = 0.7065484457382515e-1, (23, 2) = .1604950758706586, (24, 1) = 0.7537688442e-1, (24, 2) = .16109337109567876, (25, 1) = 0.7658532352018085e-1, (25, 2) = .16124510695944796, (26, 1) = 0.805813499008662e-1, (26, 2) = .1618090452, (27, 1) = 0.8242671215465647e-1, (27, 2) = .16203671353312998, (28, 1) = 0.8291457286000001e-1, (28, 2) = .16210413044792332, (29, 1) = 0.8826417929324287e-1, (29, 2) = .16283015015429084, (30, 1) = 0.904522613e-1, (30, 2) = .16316400984452806, (31, 1) = 0.9396930534693831e-1, (31, 2) = .1636853459516551, (32, 1) = 0.9798994975e-1, (32, 2) = .16435809016344582, (33, 1) = 0.9953317989166656e-1, (33, 2) = .16460645912228727, (34, 1) = .10348031148371162, (34, 2) = .1653266332, (35, 1) = .10500945609610703, (35, 2) = .1655684515121711, (36, 1) = .1055276382, (36, 2) = .16566098682384123, (37, 1) = .11052117326438587, (37, 2) = .16651390474986943, (38, 1) = .1130653266, (38, 2) = .16700677204260045, (39, 1) = .11589064181312089, (39, 2) = .16752574069219858, (40, 1) = .1206030151, (40, 2) = .16851216850911968, (41, 1) = .12110349883838589, (41, 2) = .16861066202341454, (42, 1) = .122139540949522, (42, 2) = .1688442211, (43, 1) = .12638254550555122, (43, 2) = .16966469484940266, (44, 1) = .1281407035, (44, 2) = .17005235758919762, (45, 1) = .13157164917804653, (45, 2) = .17076070110173922, (46, 1) = .135678392, (46, 2) = .1717326132535611, (47, 1) = .13659497627188055, (47, 2) = .17193406976339443, (48, 1) = .1382828915235487, (48, 2) = .1723618091, (49, 1) = .1416551472841524, (49, 2) = .17309024454992056, (50, 1) = .1432160804, (50, 2) = .1734770360582889, (51, 1) = .1466677855036304, (51, 2) = .174268601294131, (52, 1) = .1507537688, (52, 2) = .1753499101663136, (53, 1) = .15149998042302312, (53, 2) = .17553116491585571, (54, 1) = .1527341814199683, (54, 2) = .175879397, (55, 1) = .15641056483426513, (55, 2) = .17675714680070748, (56, 1) = .1582914573, (56, 2) = .17727585933216883, (57, 1) = .1612416351715959, (57, 2) = .17802023523441637, (58, 1) = .1658291457, (58, 2) = .17936629609487686, (59, 1) = .16587102451962582, (59, 2) = .17937744145121168, (60, 1) = .16593369754540996, (60, 2) = .1793969849, (61, 1) = .17069645778368336, (61, 2) = .18064316057275676, (62, 1) = .1733668342, (62, 2) = .1814566697357216, (63, 1) = .17533134212275173, (63, 2) = .1819978025151992, (64, 1) = .1781677256590961, (64, 2) = .1829145729, (65, 1) = .17989932145951784, (65, 2) = .1833836667628912, (66, 1) = .1809045226, (66, 2) = .18370113669326119, (67, 1) = .18453928746276133, (67, 2) = .1847359372070223, (68, 1) = .188442211, (68, 2) = .186041774318842, (69, 1) = .18895226379950275, (69, 2) = .18619413616474317, (70, 1) = .18962414585713816, (70, 2) = .1864321608, (71, 1) = .19352401701856153, (71, 2) = .1875782393021984, (72, 1) = .1959798995, (72, 2) = .1884278375837101, (73, 1) = .19794481725849886, (73, 2) = .18903278715851288, (74, 1) = .20045117752386254, (74, 2) = .1899497488, (75, 1) = .20231044794143524, (75, 2) = .1905130807774606, (76, 1) = .2035175879, (76, 2) = .19094440102144117, (77, 1) = .20673715713903199, (77, 2) = .19196487108359372, (78, 1) = .21071765865965755, (78, 2) = .1934673367, (79, 1) = .210919986781138, (79, 2) = .19353047185427236, (80, 1) = .2110552764, (80, 2) = .19358035292660802, (81, 1) = .2153504304721779, (81, 2) = .1949805193777135, (82, 1) = .2185929648, (82, 2) = .19624220476735219, (83, 1) = .21951361459471921, (83, 2) = .19655528803727368, (84, 1) = .220559693818866, (84, 2) = .1969849246, (85, 1) = .22380281657196704, (85, 2) = .1980712484167096, (86, 1) = .2261306533, (86, 2) = .19900426808883254, (87, 1) = .22796753073484188, (87, 2) = .19964530311091175, (88, 1) = .22999525398791076, (88, 2) = .2005025126, (89, 1) = .23210999355251577, (89, 2) = .20122974173135783, (90, 1) = .2336683417, (90, 2) = .20187269529339172, (91, 1) = .23627283634234642, (91, 2) = .20280466967381558, (92, 1) = .23906773088042566, (92, 2) = .2040201005, (93, 1) = .24028550777061808, (93, 2) = .20444967759681473, (94, 1) = .2412060301, (94, 2) = .204840388245712, (95, 1) = .2444429751737546, (95, 2) = .20602711411793337, (96, 1) = .2478214695999889, (96, 2) = .2075376885, (97, 1) = .24834109968376933, (97, 2) = .2077255773240134, (98, 1) = .2487437186, (98, 2) = .20790128484539636, (99, 1) = .252489482515476, (99, 2) = .20930725324938332, (100, 1) = .256281407, (100, 2) = .2110496186290694, (101, 1) = .2562880193831866, (101, 2) = .21105219062123806, (102, 1) = .2562943908258979, (102, 2) = .2110552764, (103, 1) = .26042230322198406, (103, 2) = .212640446099698, (104, 1) = .2638190955, (104, 2) = .21424381425046282, (105, 1) = .2641998913635977, (105, 2) = .21439515956466476, (106, 1) = .2645571585520604, (106, 2) = .2145728643, (107, 1) = .26825000147542855, (107, 2) = .21602269613110664, (108, 1) = .2713567839, (108, 2) = .21752863992089982, (109, 1) = .27200070242220775, (109, 2) = .21778995698678882, (110, 1) = .2725890871945216, (110, 2) = .2180904523, (111, 1) = .27597988723170386, (111, 2) = .219450592019427, (112, 1) = .2788944724, (112, 2) = .22090098019948495, (113, 1) = .27969725652919275, (113, 2) = .22123340760850677, (114, 1) = .2804118157639838, (114, 2) = .2216080402, (115, 1) = .283618132254194, (115, 2) = .22292125355124234, (116, 1) = .2864321608, (116, 2) = .22435856050825176, (117, 1) = .2872950900428197, (117, 2) = .2247229278775256, (118, 1) = .2880433831984684, (118, 2) = .2251256282, (119, 1) = .29116990158350164, (119, 2) = .2264322704136034, (120, 1) = .2939698492, (120, 2) = .2278998650257172, (121, 1) = .2947986307063212, (121, 2) = .22825645140438025, (122, 1) = .2954988272759236, (122, 2) = .2286432161, (123, 1) = .29863944855385915, (123, 2) = .2299816576761657, (124, 1) = .3015075377, (124, 2) = .23152418338227845, (125, 1) = .30221116730105624, (125, 2) = .23183244352137405, (126, 1) = .30279033114215453, (126, 2) = .232160804, (127, 1) = .3060301271596008, (127, 2) = .23356785020418652, (128, 1) = .3090452261, (128, 2) = .2352316447014429, (129, 1) = .3095348534013429, (129, 2) = .23544989925720808, (130, 1) = .30992746284733075, (130, 2) = .235678392, (131, 1) = .3133444099346572, (131, 2) = .2371896941485172, (132, 1) = .3165829146, (132, 2) = .23902330205384661, (133, 1) = .31677063657843346, (133, 2) = .23910837631056248, (134, 1) = .31691724815204936, (134, 2) = .2391959799, (135, 1) = .3205839061629061, (135, 2) = .24084643846151332, (136, 1) = .3237977008207778, (136, 2) = .2427135679, (137, 1) = .3239626997077225, (137, 2) = .2427872561026439, (138, 1) = .324120603, (138, 2) = .24287665200373632, (139, 1) = .3277493216791142, (139, 2) = .24453775375937492, (140, 1) = .3305894716179565, (140, 2) = .2462311558, (141, 1) = .3311308893678871, (141, 2) = .24647727674692, (142, 1) = .3316582914, (142, 2) = .2467835549689252, (143, 1) = .33484037350574114, (143, 2) = .24826377207879788, (144, 1) = .33726661427309146, (144, 2) = .2497487437, (145, 1) = .3382357167737991, (145, 2) = .2501968664964736, (146, 1) = .3391959799, (146, 2) = .2507689682864231, (147, 1) = .34185565973081394, (147, 2) = .25202514775072543, (148, 1) = .3438305170126463, (148, 2) = .2532663317, (149, 1) = .3452768774193954, (149, 2) = .25394616744041676, (150, 1) = .3467336683, (150, 2) = .2548367630850394, (151, 1) = .3487924843457991, (151, 2) = .25582313879683616, (152, 1) = .35028050460732685, (152, 2) = .2567839196, (153, 1) = .3522532246943719, (153, 2) = .2577257145915511, (154, 1) = .3542713568, (154, 2) = .258992096032466, (155, 1) = .355646577930956, (155, 2) = .2596597377242915, (156, 1) = .356613489956487, (156, 2) = .2603015076, (157, 1) = .35916257815712477, (157, 2) = .2615365255463198, (158, 1) = .3618090452, (158, 2) = .26324180296336236, (159, 1) = .3624116312465448, (159, 2) = .2635378886836086, (160, 1) = .36282345633954893, (160, 2) = .2638190955, (161, 1) = .3660015162650624, (161, 2) = .265380196940051, (162, 1) = .3689568243623757, (162, 2) = .2673366834, (163, 1) = .36914704156615796, (163, 2) = .2674298730633427, (164, 1) = .3693467337, (164, 2) = .2675584668960912, (165, 1) = .37276508141208897, (165, 2) = .26925904243141174, (166, 1) = .3751087624447853, (166, 2) = .2708542714, (167, 1) = .37596870650284064, (167, 2) = .2712816053429114, (168, 1) = .3768844221, (168, 2) = .27188718811737245, (169, 1) = .3794462813572124, (169, 2) = .27317632498676503, (170, 1) = .38115313529001693, (170, 2) = .2743718593, (171, 1) = .38272548573151655, (171, 2) = .27516361754329915, (172, 1) = .3844221105, (172, 2) = .27631660317460116, (173, 1) = .3860354639396687, (173, 2) = .27713654902102, (174, 1) = .3870788206689781, (174, 2) = .2778894473, (175, 1) = .3894118058305985, (175, 2) = .27907851075651846, (176, 1) = .391959799, (176, 2) = .2808593013214599, (177, 1) = .3925192611802801, (177, 2) = .2811459528506871, (178, 1) = .3928699254515984, (178, 2) = .2814070352, (179, 1) = .39601999075370253, (179, 2) = .2830298669590452, (180, 1) = .39865339649823994, (180, 2) = .2849246231, (181, 1) = .399054215984739, (181, 2) = .28513148309849307, (182, 1) = .3994974874, (182, 2) = .2854410813479102, (183, 1) = .4025394978638157, (183, 2) = .28702260620343356, (184, 1) = .40445346238143115, (184, 2) = .2884422111, (185, 1) = .40567205625734704, (185, 2) = .28907833358784873, (186, 1) = .4070351759, (186, 2) = .2900578777122225, (187, 1) = .4089557678778346, (187, 2) = .2910635227487732, (188, 1) = .41012599927130694, (188, 2) = .291959799, (189, 1) = .4122139513300834, (189, 2) = .29306062507766373, (190, 1) = .4145728643, (190, 2) = .29480677486942214, (191, 1) = .41524840249674494, (191, 2) = .2951621358385316, (192, 1) = .4156461222869131, (192, 2) = .295477387, (193, 1) = .4186682810347394, (193, 2) = .29708378046000994, (194, 1) = .4211708817900251, (194, 2) = .2989949749, (195, 1) = .4216089056599046, (195, 2) = .29922907689427447, (196, 1) = .4221105528, (196, 2) = .29960026414159835, (197, 1) = .4250189113577072, (197, 2) = .30115532881412016, (198, 1) = .42673813074297334, (198, 2) = .3025125628, (199, 1) = .4280881553513352, (199, 2) = .30324060287926796, (200, 1) = .4296482412, (200, 2) = .30443065848243966, (201, 1) = .43124296130670364, (201, 2) = .305285948066613, (202, 1) = .4321524720222676, (202, 2) = .3060301508, (203, 1) = .43447882908159996, (203, 2) = .3072934643680706, (204, 1) = .4371859296, (204, 2) = .3094261430078931, (205, 1) = .4373072082542931, (205, 2) = .30949114199573585, (206, 1) = .43737370440049944, (206, 2) = .3095477387, (207, 1) = .4407626456393019, (207, 2) = .3113961925325087, (208, 1) = .44280925121024983, (208, 2) = .3130653267, (209, 1) = .44368693138175197, (209, 2) = .31354911382601347, (210, 1) = .4447236181, (210, 2) = .31436552367991755, (211, 1) = .44691325438868024, (211, 2) = .31556108433775903, (212, 1) = .44811968623247306, (212, 2) = .3165829146, (213, 1) = .4500128454767157, (213, 2) = .3176321964049001, (214, 1) = .4522613065, (214, 2) = .31946347593252944, (215, 1) = .452891529738174, (215, 2) = .3198063983277594, (216, 1) = .45322441588014806, (216, 2) = .3201005025, (217, 1) = .4562256549567938, (217, 2) = .3217680612026317, (218, 1) = .4584156737738623, (218, 2) = .3236180905, (219, 1) = .45904270810555414, (219, 2) = .3239710243773858, (220, 1) = .459798995, (220, 2) = .32458718918913143, (221, 1) = .4622940370494772, (221, 2) = .3259713254501975, (222, 1) = .4636177231597405, (222, 2) = .3271356784, (223, 1) = .4653001003370227, (223, 2) = .3280860838510044, (224, 1) = .4673366834, (224, 2) = .3298052569263673, (225, 1) = .4681701175821987, (225, 2) = .3302643304394618, (226, 1) = .4685923820791582, (226, 2) = .3306532664, (227, 1) = .4714342533295569, (227, 2) = .3322586550104123, (228, 1) = .4736127372887472, (228, 2) = .3341708543, (229, 1) = .4741784948157407, (229, 2) = .33449559689080793, (230, 1) = .47487437180000003, (230, 2) = .33508357622689244, (231, 1) = .4774064804372275, (231, 2) = .3365067915250223, (232, 1) = .4786946396102586, (232, 2) = .3376884422, (233, 1) = .48036051097030574, (233, 2) = .33864583189626307, (234, 1) = .4824120603, (234, 2) = .3404462819598845, (235, 1) = .4831554993207043, (235, 2) = .3408590919824476, (236, 1) = .48351475560029955, (236, 2) = .3412060302, (237, 1) = .486403767498123, (237, 2) = .34286082141813395, (238, 1) = .4884380204147546, (238, 2) = .3447236181, (239, 1) = .48910930455562657, (239, 2) = .3451158253762942, (240, 1) = .4899497487, (240, 2) = .34585451237338455, (241, 1) = .4922582746972002, (241, 2) = .3471638939577644, (242, 1) = .4933783239162865, (242, 2) = .3482412061, (243, 1) = .49520497458841906, (243, 2) = .34930635529855064, (244, 1) = .4974874372, (244, 2) = .3513969608302578, (245, 1) = .4978411444834455, (245, 2) = .3515937306019973, (246, 1) = .4980028813388976, (246, 2) = .351758794, (247, 1) = .5011382603441314, (247, 2) = .35357266444242547, (248, 1) = .5029123014095499, (248, 2) = .3552763819, (249, 1) = .5038426326656263, (249, 2) = .35582821194859127, (250, 1) = .5050251256, (250, 2) = .35691345813736414, (251, 1) = .506840931853553, (251, 2) = .35794659364031206, (252, 1) = .5076747727105544, (252, 2) = .3587939699, (253, 1) = .5098347969513135, (253, 2) = .3600670445452593, (254, 1) = .5121706405090248, (254, 2) = .3623115578, (255, 1) = .5123417375182368, (255, 2) = .3624147268724672, (256, 1) = .5125628141, (256, 2) = .36261833722107134, (257, 1) = .515627776465587, (257, 2) = .3643988299968633, (258, 1) = .517037436286423, (258, 2) = .3658291458, (259, 1) = .5183776657705376, (259, 2) = .3666331362691778, (260, 1) = .5201005025000001, (260, 2) = .3682925798270953, (261, 1) = .5211218094273468, (261, 2) = .3688701238032814, (262, 1) = .5215606671057531, (262, 2) = .3693467337, (263, 1) = .5242388999126684, (263, 2) = .37093306948506855, (264, 1) = .5261408456874557, (264, 2) = .3728643216, (265, 1) = .526789770654438, (265, 2) = .37326025105693345, (266, 1) = .5276381909, (266, 2) = .37408073813624665, (267, 1) = .5298408117505049, (267, 2) = .3753540198600239, (268, 1) = .5307890461341223, (268, 2) = .3763819096, (269, 1) = .5327024621228297, (269, 2) = .3775361709741368, (270, 1) = .5350235561041898, (270, 2) = .3798994975, (271, 1) = .5350889609440974, (271, 2) = .37994005944647224, (272, 1) = .5351758794, (272, 2) = .38002457646404664, (273, 1) = .5383866426757877, (273, 2) = .3819187292705555, (274, 1) = .5397678254418192, (274, 2) = .3834170855, (275, 1) = .5410400965701394, (275, 2) = .3841980387361613, (276, 1) = .5427135678, (276, 2) = .38590965937995525, (277, 1) = .543705513710889, (277, 2) = .386471765317025, (278, 1) = .5440979633663376, (278, 2) = .3869346734, (279, 1) = .5467869878557947, (279, 2) = .3885513319766563, (280, 1) = .5485339197773342, (280, 2) = .3904522613, (281, 1) = .5492686492431231, (281, 2) = .3909108112642211, (282, 1) = .5502512563, (282, 2) = .3919219623354962, (283, 1) = .552209960639181, (283, 2) = .3930557872542605, (284, 1) = .5529844139193156, (284, 2) = .3939698493, (285, 1) = .5550630770255085, (285, 2) = .39524192087419674, (286, 1) = .5571162262826977, (286, 2) = .3974874372, (287, 1) = .5574014126054714, (287, 2) = .3976682855148931, (288, 1) = .5577889447, (288, 2) = .3980700966510423, (289, 1) = .5605658940567053, (289, 2) = .39970911548792387, (290, 1) = .5616601137346005, (290, 2) = .4010050252, (291, 1) = .5632313898737636, (291, 2) = .401982805400379, (292, 1) = .5653266332, (292, 2) = .4042902645303774, (293, 1) = .5655545878763909, (293, 2) = .40441623425162243, (294, 1) = .5656346345021266, (294, 2) = .4045226131, (295, 1) = .5687951576899943, (295, 2) = .4064215562472058, (296, 1) = .5701537839480469, (296, 2) = .408040201, (297, 1) = .571304894879362, (297, 2) = .4087679334861818, (298, 1) = .5728643216, (298, 2) = .4105001595793406, (299, 1) = .573890981475691, (299, 2) = .4110786810471146, (300, 1) = .5742499574625818, (300, 2) = .411557789, (301, 1) = .5769146360350601, (301, 2) = .4131852301743854, (302, 1) = .5784881143647418, (302, 2) = .4150753769, (303, 1) = .5792939134001516, (303, 2) = .4155924886583565, (304, 1) = .58040201, (304, 2) = .4168360034851491, (305, 1) = .5820916234225818, (305, 2) = .41780447862865666, (306, 1) = .5826778032589655, (306, 2) = .4185929649, (307, 1) = .5849375309142315, (307, 2) = .4199939764134728, (308, 1) = .5866812236992927, (308, 2) = .4221105528, (309, 1) = .5872067269735419, (309, 2) = .42245260617253105, (310, 1) = .5879396985, (310, 2) = .42328487231509143, (311, 1) = .5901748181793824, (311, 2) = .424585084855552, (312, 1) = .5909416297801887, (312, 2) = .4256281407, (313, 1) = .5928742661563755, (313, 2) = .4268429304079858, (314, 1) = .5947477331341324, (314, 2) = .4291457287, (315, 1) = .5950500399391007, (315, 2) = .4293451572806191, (316, 1) = .5954773869, (316, 2) = .42983686771803714, (317, 1) = .5981546733456532, (317, 2) = .4314139162823743, (318, 1) = .5990599732896797, (318, 2) = .4326633166, (319, 1) = .6007331668179969, (319, 2) = .4337282072816926, (320, 1) = .6026995817042107, (320, 2) = .4361809046, (321, 1) = .6028293309636257, (321, 2) = .43626758533533183, (322, 1) = .6030150754, (322, 2) = .43648448192499756, (323, 1) = .6060420969519619, (323, 2) = .4382858824504494, (324, 1) = .6070475298616599, (324, 2) = .4396984925, (325, 1) = .6085209028289573, (325, 2) = .4406466942810953, (326, 1) = .6105465714823727, (326, 2) = .4432160804, (327, 1) = .610549100469022, (327, 2) = .44321778995449523, (328, 1) = .6105527638, (328, 2) = .44322213796208026, (329, 1) = .6138455353056087, (329, 2) = .44519704166243534, (330, 1) = .6149160064931423, (330, 2) = .4467336684, (331, 1) = .6162428430226877, (331, 2) = .4475958860111768, (332, 1) = .6180904522, (332, 2) = .44998451105692194, (333, 1) = .618361032979732, (333, 2) = .4501249852718516, (334, 1) = .6184311109683637, (334, 2) = .4502512563, (335, 1) = .6215714415476802, (335, 2) = .45214438258902223, (336, 1) = .6226746600685912, (336, 2) = .4537688443, (337, 1) = .6239033103668259, (337, 2) = .4545737651068926, (338, 1) = .6256281407, (338, 2) = .4568521499901121, (339, 1) = .6260703963670847, (339, 2) = .4570800462232006, (340, 1) = .6261798113812319, (340, 2) = .4572864322, (341, 1) = .629224615214578, (341, 2) = .4591256653360729, (342, 1) = .630330704663824, (342, 2) = .4608040201, (343, 1) = .6315057682571499, (343, 2) = .4615787151776155, (344, 1) = .6331658291, (344, 2) = .4638253825811738, (345, 1) = .6336751962287598, (345, 2) = .46408390343765954, (346, 1) = .6337940389714881, (346, 2) = .4643216081, (347, 1) = .6368083372536868, (347, 2) = .46613935889382885, (348, 1) = .6378894739173245, (348, 2) = .467839196, (349, 1) = .6390529293504151, (349, 2) = .46860947052377216, (350, 1) = .6407035176, (350, 2) = .47090538903042267, (351, 1) = .6411729686877367, (351, 2) = .47113770682074047, (352, 1) = .6412744469548372, (352, 2) = .47135678400000003, (353, 1) = .6443244310598472, (353, 2) = .4731846122950122, (354, 1) = .6453545506161649, (354, 2) = .4748743719, (355, 1) = .64654686035321, (355, 2) = .475665066530673, (356, 1) = .648241206, (356, 2) = .4780964241606354, (357, 1) = .6485547404531187, (357, 2) = .47824564372465095, (358, 1) = .6486159014391775, (358, 2) = .4783919598, (359, 1) = .6517730630078912, (359, 2) = .48026134784736546, (360, 1) = .6527275625074144, (360, 2) = .4819095478, (361, 1) = .6539889836503494, (361, 2) = .48274483951400615, (362, 1) = .6557788945, (362, 2) = .48540677089959555, (363, 1) = .6558011432731569, (363, 2) = .4854167529392525, (364, 1) = .655804895158075, (364, 2) = .4854271357, (365, 1) = .6591523462683724, (365, 2) = .4873704461722893, (366, 1) = .6600078620797836, (366, 2) = .4889447237, (367, 1) = .6613800684774144, (367, 2) = .4898484304254017, (368, 1) = .6630661423301804, (368, 2) = .4924623116, (369, 1) = .6631655196107269, (369, 2) = .49253280780125996, (370, 1) = .6633165829, (370, 2) = .49274529682446533, (371, 1) = .6664574008536912, (371, 2) = .49451418446327766, (372, 1) = .6671916688909929, (372, 2) = .4959798995, (373, 1) = .6687201033375192, (373, 2) = .4969758445718083, (374, 1) = .6702685660547512, (374, 2) = .4994974875, (375, 1) = .6705011863405904, (375, 2) = .49966226048012097, (376, 1) = .6708542713, (376, 2) = .5001774441430769, (377, 1) = .6736784716571493, (377, 2) = .5016971152583087, (378, 1) = .6742704585741014, (378, 2) = .5030150754, (379, 1) = .6760080517394262, (379, 2) = .50412756583881, (380, 1) = .677399246611721, (380, 2) = .5065326634, (381, 1) = .6777947901740559, (381, 2) = .5068113425534924, (382, 1) = .6783919598, (382, 2) = .5077201960344483, (383, 1) = .6807968774505293, (383, 2) = .5089279564028008, (384, 1) = .6812277157139974, (384, 2) = .5100502513, (385, 1) = .6832413537672619, (385, 2) = .5113047886948117, (386, 1) = .6844556297290976, (386, 2) = .5135678392, (387, 1) = .6850466625571178, (387, 2) = .5139798991760498, (388, 1) = .6859296482, (388, 2) = .5153920731517049, (389, 1) = .6877753661910225, (389, 2) = .5162240921293607, (390, 1) = .6880318827296975, (390, 2) = .5170854272000001, (391, 1) = .6904148909644026, (391, 2) = .5185099018496149, (392, 1) = .691432076216194, (392, 2) = .5206030151, (393, 1) = .6922567301232537, (393, 2) = .5211679648411685, (394, 1) = .6934673366999999, (394, 2) = .5232237897260825, (395, 1) = .6945317640609436, (395, 2) = .5236238703202625, (396, 1) = .6946196251507182, (396, 2) = .5241206031, (397, 1) = .6975187814979922, (397, 2) = .5257475167716869, (398, 1) = .698317581437037, (398, 2) = .527638191, (399, 1) = .6994243262800321, (399, 2) = .5283758504451243, (400, 1) = .7009425609360174, (400, 2) = .5311557789, (401, 1) = .7009668454087546, (401, 2) = .5311735960896531, (402, 1) = .7010050251, (402, 2) = .531235022213899, (403, 1) = .7045330536072332, (403, 2) = .5330269535591804, (404, 1) = .7050907594978423, (404, 2) = .5346733669, (405, 1) = .7065477859856253, (405, 2) = .5356043330680816, (406, 1) = .707826439370854, (406, 2) = .5381909548, (407, 1) = .7081081959007527, (407, 2) = .5383937296842604, (408, 1) = .7085427135, (408, 2) = .5391383297211966, (409, 1) = .7114127298251807, (409, 2) = .5403692018355573, (410, 1) = .7117074971453883, (410, 2) = .5417085428, (411, 1) = .7136235371248519, (411, 2) = .5428550797200062, (412, 1) = .7146400679090801, (412, 2) = .5452261307, (413, 1) = .7152171450153232, (413, 2) = .5456289839518809, (414, 1) = .716080402, (414, 2) = .5472318084850784, (415, 1) = .7180345888276969, (415, 2) = .5478317647522599, (416, 1) = .7180648234578784, (416, 2) = .5487437186, (417, 1) = .7206438027624761, (417, 2) = .5501317195290782, (418, 1) = .7213690656048836, (418, 2) = .5522613066, (419, 1) = .7222959479644129, (419, 2) = .5528783063997659, (420, 1) = .7236180904, (420, 2) = .5556142807592881, (421, 1) = .7239053069243766, (421, 2) = .5556448601244978, (422, 1) = .7238626413394168, (422, 2) = .5557788945, (423, 1) = .727589654427056, (423, 2) = .5574430859364774, (424, 1) = .7279818096371112, (424, 2) = .5592964825, (425, 1) = .7293484692190622, (425, 2) = .560139893668453, (426, 1) = .7304488507618105, (426, 2) = .5628140704, (427, 1) = .7307271473996758, (427, 2) = .5630140984296936, (428, 1) = .7311557789, (428, 2) = .5638422925589597, (429, 1) = .7344031167623684, (429, 2) = .5648162339728443, (430, 1) = .734397592924741, (430, 2) = .5663316583, (431, 1) = .7363825553752067, (431, 2) = .56741008388943, (432, 1) = .737141981461179, (432, 2) = .5698492463, (433, 1) = .737774574082815, (433, 2) = .5702780631322483, (434, 1) = .7386934673000001, (434, 2) = .5722948844201498, (435, 1) = .7407898893748043, (435, 2) = .5723885039169664, (436, 1) = .7403417330236419, (436, 2) = .5733668342, (437, 1) = .7434181560698958, (437, 2) = .5746795674198217, (438, 1) = .7437609615715551, (438, 2) = .5768844222, (439, 1) = .7448263593479074, (439, 2) = .5775399938652186, (440, 1) = .7458907583865892, (440, 2) = .5804020101, (441, 1) = .7460238544868412, (441, 2) = .5804987507109741, (442, 1) = .7462311558, (442, 2) = .5809274807500572, (443, 1) = .7505285078494064, (443, 2) = .5819141670550128, (444, 1) = .7502570823615815, (444, 2) = .583919598, (445, 1) = .7519232985586441, (445, 2) = .5847808526522201, (446, 1) = .7525801176410079, (446, 2) = .5874371860000001, (447, 1) = .7530674347922731, (447, 2) = .5877645103884115, (448, 1) = .7537688442, (448, 2) = .5894754545594193, (449, 1) = .7584052102297473, (449, 2) = .5887911364317532, (450, 1) = .7564023156361204, (450, 2) = .5909547739, (451, 1) = .7591949895306978, (451, 2) = .5919401606880849, (452, 1) = .759272894687191, (452, 2) = .5944723619, (453, 1) = .7601756102366055, (453, 2) = .5950001256665833, (454, 1) = .7610832014050026, (454, 2) = .5979899498, (455, 1) = .7611712213813305, (455, 2) = .59805309503502, (456, 1) = .7613065326, (456, 2) = .598365048803723, (457, 1) = .767397979816176, (457, 2) = .5986648623863265, (458, 1) = .7660541949332249, (458, 2) = .6015075377, (459, 1) = .7674897400218551, (459, 2) = .6021396288757908, (460, 1) = .7678552870305516, (460, 2) = .6050251257, (461, 1) = .7682732811148212, (461, 2) = .6052915643547006, (462, 1) = .7688442211, (462, 2) = .6069776370063522, (463, 1) = .7718788618065875, (463, 2) = .6050251257, (464, 1) = .7701772158845703, (464, 2) = .604403061453053, (465, 1) = .770635160312404, (465, 2) = .6015075377, (466, 1) = .7698840051758535, (466, 2) = .6010223051340272, (467, 1) = .7693019342651174, (467, 2) = .5979899498, (468, 1) = .7691335900028758, (468, 2) = .5978549109794257, (469, 1) = .7688442211, (469, 2) = .5970283535448404, (470, 1) = .7625054523889951, (470, 2) = .5974304539090726, (471, 1) = .7652436454649781, (471, 2) = .5944723619, (472, 1) = .7632377617406646, (472, 2) = .5935711216258162, (473, 1) = .7633131740612666, (473, 2) = .5909547739, (474, 1) = .7624996825719582, (474, 2) = .5903979705903055, (475, 1) = .7617545533100927, (475, 2) = .5874371860000001, (476, 1) = .7615921668021366, (476, 2) = .5873038900377399, (477, 1) = .7613065326, (477, 2) = .5865669253736254, (478, 1) = .7569338344741664, (478, 2) = .5859601905051313, (479, 1) = .7579615162167681, (479, 2) = .583919598, (480, 1) = .7559963080423406, (480, 2) = .5828801148794847, (481, 1) = .7557746899991786, (481, 2) = .5804020101, (482, 1) = .754987936365745, (482, 2) = .5798331004258871, (483, 1) = .7540704239167212, (483, 2) = .5768844222, (484, 1) = .7539627708881196, (484, 2) = .5767939230768193, (485, 1) = .7537688442, (485, 2) = .5763388147300418, (486, 1) = .749920454738908, (486, 2) = .5751627493226872, (487, 1) = .7502967109764029, (487, 2) = .5733668342, (488, 1) = .7485199994771032, (488, 2) = .5722987071567582, (489, 1) = .7480444164864417, (489, 2) = .5698492463, (490, 1) = .7473545920573336, (490, 2) = .5693249760346543, (491, 1) = .7462519616831753, (491, 2) = .5663316583, (492, 1) = .7462446452833709, (492, 2) = .566325363207796, (493, 1) = .7462311558, (493, 2) = .5662963205225036, (494, 1) = .7423910852437003, (494, 2) = .56460610329231, (495, 1) = .7423854545821322, (495, 2) = .5628140704, (496, 1) = .7408624230141795, (496, 2) = .5618018910858994, (497, 1) = .7401474389059498, (497, 2) = .5592964825, (498, 1) = .739609202013443, (498, 2) = .558869139629677, (499, 1) = .7386934673000001, (499, 2) = .5566994627265854, (500, 1) = .7373337242500462, (500, 2) = .5564134412710765, (501, 1) = .7375529280200395, (501, 2) = .5557788945, (502, 1) = .7346089216718232, (502, 2) = .5541674278823114, (503, 1) = .7342999024776851, (503, 2) = .5522613066, (504, 1) = .733062385712161, (504, 2) = .5513715567340894, (505, 1) = .7321051772528755, (505, 2) = .5487437186, (506, 1) = .7317620125548746, (506, 2) = .5484608095626671, (507, 1) = .7311557789, (507, 2) = .5471755221786071, (508, 1) = .7288972832717391, (508, 2) = .5462800953065466, (509, 1) = .7289300200295219, (509, 2) = .5452261307, (510, 1) = .7266745141310627, (510, 2) = .5437997996525366, (511, 1) = .7260795175455097, (511, 2) = .5417085428, (512, 1) = .7251468695415849, (512, 2) = .5409951125271665, (513, 1) = .7239344481102331, (513, 2) = .5381909548, (514, 1) = .7238224227793333, (514, 2) = .5380955996914517, (515, 1) = .7236180904, (515, 2) = .5377004001994169, (516, 1) = .7205798536292655, (516, 2) = .5360912107182814, (517, 1) = .7203358064748968, (517, 2) = .5346733669, (518, 1) = .7186332419606867, (518, 2) = .5334820415579187, (519, 1) = .7177465380996019, (519, 2) = .5311557789, (520, 1) = .7171343576488055, (520, 2) = .5306639329333539, (521, 1) = .716080402, (521, 2) = .5285185728725448, (522, 1) = .7150690635072785, (522, 2) = .5281101489543252, (523, 1) = .7150651474523091, (523, 2) = .527638191, (524, 1) = .7122825627912577, (524, 2) = .5258929280304899, (525, 1) = .7117254561452948, (525, 2) = .5241206031, (526, 1) = .7105078811503773, (526, 2) = .5232035248544668, (527, 1) = .709313814793679, (527, 2) = .5206030151, (528, 1) = .7090374677850002, (528, 2) = .5203721297713757, (529, 1) = .7085427135, (529, 2) = .5194599433133028, (530, 1) = .7061965922202815, (530, 2) = .5181802837909769, (531, 1) = .7059485994655371, (531, 2) = .5170854272000001, (532, 1) = .7039713812850835, (532, 2) = .5157011276154781, (533, 1) = .7030763413046126, (533, 2) = .5135678392, (534, 1) = .7023107244229887, (534, 2) = .5129585128527364, (535, 1) = .7010050251, (535, 2) = .5104631685122588, (536, 1) = .7005554626379362, (536, 2) = .510260047114437, (537, 1) = .700532426213646, (537, 2) = .5100502513, (538, 1) = .6975634682865297, (538, 2) = .5081387232371546, (539, 1) = .6969674540361994, (539, 2) = .5065326634, (540, 1) = .6956310906601928, (540, 2) = .5055229115289454, (541, 1) = .6943755773322701, (541, 2) = .5030150754, (542, 1) = .6940487375441052, (542, 2) = .5027437550076268, (543, 1) = .6934673366999999, (543, 2) = .5017356084998368, (544, 1) = .6913371583211333, (544, 2) = .5004915707246309, (545, 1) = .6910267347144636, (545, 2) = .4994974875, (546, 1) = .6890134177468648, (546, 2) = .49805839503115934, (547, 1) = .6880274190127694, (547, 2) = .4959798995, (548, 1) = .6872536468046716, (548, 2) = .49536203349619656, (549, 1) = .6859296482, (549, 2) = .49301879363440343, (550, 1) = .685365858020765, (550, 2) = .49272541368214706, (551, 1) = .6853023469688783, (551, 2) = .4924623116, (552, 1) = .682474224619088, (552, 2) = .49055725469525724, (553, 1) = .6817575115020593, (553, 2) = .4889447237, (554, 1) = .6804849100825205, (554, 2) = .48796801354594393, (555, 1) = .6790822467362455, (555, 2) = .4854271357, (556, 1) = .678834251722961, (556, 2) = .48522073280379174, (557, 1) = .6783919598, (557, 2) = .48450428140603924, (558, 1) = .6760310197132064, (558, 2) = .48301131981962253, (559, 1) = .6755781421632182, (559, 2) = .4819095478, (560, 1) = .6737471333022285, (560, 2) = .48055954551950053, (561, 1) = .6725809693019373, (561, 2) = .4783919598, (562, 1) = .6719486597541052, (562, 2) = .4778812451977635, (563, 1) = .6708542713, (563, 2) = .47609475103423465, (564, 1) = .6697009134032972, (564, 2) = .4754126055820677, (565, 1) = .6694993265551618, (565, 2) = .4748743719, (566, 1) = .6670435226254972, (566, 2) = .47313513337132346, (567, 1) = .666112911098834, (567, 2) = .47135678400000003, (568, 1) = .6650697765711803, (568, 2) = .470538626934842, (569, 1) = .6634290004731302, (569, 2) = .467839196, (570, 1) = .663388825704418, (570, 2) = .46780548269146327, (571, 1) = .6633165829, (571, 2) = .4676961942750159, (572, 1) = .6603750781831043, (572, 2) = .46569431029341324, (573, 1) = .6596771357613036, (573, 2) = .4643216081, (574, 1) = .6581969611630083, (574, 2) = .4631931769649324, (575, 1) = .6567554866881687, (575, 2) = .4608040201, (576, 1) = .6564013509925426, (576, 2) = .46051354040513176, (577, 1) = .6557788945, (577, 2) = .4595730965627197, (578, 1) = .6537397262340544, (578, 2) = .458238044039406, (579, 1) = .653269570325969, (579, 2) = .4572864322, (580, 1) = .6513281106571419, (580, 2) = .4558458767206357, (581, 1) = .6500829412056062, (581, 2) = .4537688443, (582, 1) = .6494058675855644, (582, 2) = .45322533555491956, (583, 1) = .648241206, (583, 2) = .45146938976750345, (584, 1) = .6471314835186666, (584, 2) = .45076912680306686, (585, 1) = .6468824467628159, (585, 2) = .4502512563, (586, 1) = .6444595005529137, (586, 2) = .44849846426527284, (587, 1) = .6434065207570968, (587, 2) = .4467336684, (588, 1) = .6424001139154676, (588, 2) = .44594192343477523, (589, 1) = .6407035176, (589, 2) = .4433922488286544, (590, 1) = .640539879063162, (590, 2) = .44329244505124804, (591, 1) = .6405040091082581, (591, 2) = .4432160804, (592, 1) = .6375857072618107, (592, 2) = .4411534706302463, (593, 1) = .636719683162204, (593, 2) = .4396984925, (594, 1) = .6353810440093814, (594, 2) = .43866472556188096, (595, 1) = .6337205514840445, (595, 2) = .4361809046, (596, 1) = .6335194856748709, (596, 2) = .4360158648634963, (597, 1) = .6331658291, (597, 2) = .43552130590189286, (598, 1) = .6306997544480649, (598, 2) = .4338141514637429, (599, 1) = .630014403647833, (599, 2) = .4326633166, (600, 1) = .6283449534455033, (600, 2) = .43139547065930706, (601, 1) = .626831398160579, (601, 2) = .4291457287, (602, 1) = .6263912030507452, (602, 2) = .4287896329282202, (603, 1) = .6256281407, (603, 2) = .4277318173711414, (604, 1) = .6237934249672785, (604, 2) = .42648434138338354, (605, 1) = .6232814929969428, (605, 2) = .4256281407, (606, 1) = .6212876297995694, (606, 2) = .4241361245151448, (607, 1) = .6199136766926232, (607, 2) = .4221105528, (608, 1) = .6192411383681233, (608, 2) = .4215735659317196, (609, 1) = .6180904522, (609, 2) = .41999392989842765, (610, 1) = .616857782320856, (610, 2) = .41916821084032985, (611, 1) = .6165111271613823, (611, 2) = .4185929649, (612, 1) = .6142045961622684, (612, 2) = .4168887764255166, (613, 1) = .6129619753822434, (613, 2) = .4150753769, (614, 1) = .6120668188759711, (614, 2) = .4143688178685641, (615, 1) = .6105527638, (615, 2) = .412312865809618, (616, 1) = .6098837981359486, (616, 2) = .4118699729747824, (617, 1) = .6096934239531301, (617, 2) = .411557789, (618, 1) = .6070913933803693, (618, 2) = .4096555072325644, (619, 1) = .6059709460662753, (619, 2) = .408040201, (620, 1) = .6048658222920855, (620, 2) = .4071765191219374, (621, 1) = .6030150754, (621, 2) = .40469329619235833, (622, 1) = .602863103225005, (622, 2) = .40459353344698695, (623, 1) = .6028191648435827, (623, 2) = .4045226131, (624, 1) = .5999438705289032, (624, 2) = .4024382541126821, (625, 1) = .5989355752445181, (625, 2) = .4010050252, (626, 1) = .5976358992595766, (626, 2) = .39999771942265216, (627, 1) = .5957404771292144, (627, 2) = .3974874372, (628, 1) = .5956446569324523, (628, 2) = .3974093778530017, (629, 1) = .5954773869, (629, 2) = .397197178428286, (630, 1) = .5927584434127191, (630, 2) = .39523868958685016, (631, 1) = .5918514724459307, (631, 2) = .3939698493, (632, 1) = .5903751176564264, (632, 2) = .3928333203344865, (633, 1) = .5885520206003342, (633, 2) = .3904522613, (634, 1) = .5883280361978662, (634, 2) = .39027103704202615, (635, 1) = .5879396985, (635, 2) = .3897845642725306, (636, 1) = .5855323425286143, (636, 2) = .388058106165355, (637, 1) = .5847151459560386, (637, 2) = .3869346734, (638, 1) = .583081996106934, (638, 2) = .38568401324046714, (639, 1) = .5813205236176994, (639, 2) = .3834170855, (640, 1) = .5809833455097835, (640, 2) = .3831457955928636, (641, 1) = .58040201, (641, 2) = .3824269427112342, (642, 1) = .5782637540893907, (642, 2) = .3808973502809784, (643, 1) = .5775241560912212, (643, 2) = .3798994975, (644, 1) = .5757555660659562, (644, 2) = .3785502500902252, (645, 1) = .5740446234513643, (645, 2) = .3763819096, (646, 1) = .5736101496605641, (646, 2) = .3760338564971544, (647, 1) = .5728643216, (647, 2) = .3751237128720331, (648, 1) = .5709518864082601, (648, 2) = .3737567913764426, (649, 1) = .5702772216056209, (649, 2) = .3728643216, (650, 1) = .5683954495706423, (650, 2) = .3714322073018429, (651, 1) = .5667237108415353, (651, 2) = .3693467337, (652, 1) = .5662084085110162, (652, 2) = .3689352385571988, (653, 1) = .5653266332, (653, 2) = .36787345287702866, (654, 1) = .5635969930978948, (654, 2) = .3666363111656846, (655, 1) = .5629742751203055, (655, 2) = .3658291458, (656, 1) = .5610018707510682, (656, 2) = .3643297802952932, (657, 1) = .5593579214862341, (657, 2) = .3623115578, (658, 1) = .5587784698638669, (658, 2) = .36184977939894725, (659, 1) = .5577889447, (659, 2) = .3606740064671954, (660, 1) = .5562002812612103, (660, 2) = .35953534616721994, (661, 1) = .5556163996636694, (661, 2) = .3587939699, (662, 1) = .5535756490882806, (662, 2) = .3572425865635195, (663, 1) = .5519481774786923, (663, 2) = .3552763819, (664, 1) = .5513210977851705, (664, 2) = .3547771225430924, (665, 1) = .5502512563, (665, 2) = .3535225218982832, (666, 1) = .5487638237914856, (666, 2) = .3524529291574846, (667, 1) = .548205776205795, (667, 2) = .351758794, (668, 1) = .5461181799936377, (668, 2) = .35016997500641434, (669, 1) = .544496180139183, (669, 2) = .3482412061, (670, 1) = .5438374735468877, (670, 2) = .34771671674648225, (671, 1) = .5427135678, (671, 2) = .34641553129293345, (672, 1) = .5412904328298684, (672, 2) = .3453877477678323, (673, 1) = .5407455821183196, (673, 2) = .3447236181, (674, 1) = .5386313821145924, (674, 2) = .3431110501756922, (675, 1) = .5370043558098199, (675, 2) = .3412060302, (676, 1) = .5363291734444303, (676, 2) = .3406678263003589, (677, 1) = .5351758794, (677, 2) = .33934905705466345, (678, 1) = .5337835154128445, (678, 2) = .3383382120668299, (679, 1) = .5332398612580557, (679, 2) = .3376884422, (680, 1) = .5311176601280995, (680, 2) = .33606468992432753, (681, 1) = .5294758544975693, (681, 2) = .3341708543, (682, 1) = .5287981735955245, (682, 2) = .33362952905234794, (683, 1) = .5276381909, (683, 2) = .3323186760003023, (684, 1) = .5262469554379412, (684, 2) = .331302509611936, (685, 1) = .5256934115411425, (685, 2) = .3306532664, (686, 1) = .5235798548993649, (686, 2) = .3290295685767022, (687, 1) = .5219145061356738, (687, 2) = .3271356784, (688, 1) = .5212468376963585, (688, 2) = .3266007219780744, (689, 1) = .5201005025000001, (689, 2) = .3253195784676084, (690, 1) = .5186850235658629, (690, 2) = .32427864733217493, (691, 1) = .5181117055244628, (691, 2) = .3236180905, (692, 1) = .5160212069601587, (692, 2) = .32200417379522084, (693, 1) = .5143247836090906, (693, 2) = .3201005025, (694, 1) = .5136779093293781, (694, 2) = .319580124729249, (695, 1) = .5125628141, (695, 2) = .31834660021807604, (696, 1) = .5111023195067798, (696, 2) = .31726447873058555, (697, 1) = .5105008431478002, (697, 2) = .3165829146, (698, 1) = .5084453397499787, (698, 2) = .3149868146935932, (699, 1) = .5067117899829481, (699, 2) = .3130653267, (700, 1) = .5060945113548043, (700, 2) = .3125662800096956, (701, 1) = .5050251256, (701, 2) = .31139425376022367, (702, 1) = .5035037033920832, (702, 2) = .3102577357465086, (703, 1) = .5028674645938366, (703, 2) = .3095477387, (704, 1) = .5008562487621461, (704, 2) = .3079756266466038, (705, 1) = .49908128227054965, (705, 2) = .3060301508, (706, 1) = .4985001758104025, (706, 2) = .3055575394377303, (707, 1) = .4974874372, (707, 2) = .304456676546889, (708, 1) = .4958943147128132, (708, 2) = .3032560199677323, (709, 1) = .49521878144648995, (709, 2) = .3025125628, (710, 1) = .4932583275103768, (710, 2) = .30096855938442, (711, 1) = .49143970647138974, (711, 2) = .2989949749, (712, 1) = .4908988792003061, (712, 2) = .298552047341585, (713, 1) = .4899497487, (713, 2) = .29752756673713127, (714, 1) = .48827959177296715, (714, 2) = .29625679356151713, (715, 1) = .48756259349954817, (715, 2) = .295477387, (716, 1) = .48565636950125635, (716, 2) = .2939633760049808, (717, 1) = .48379416623613464, (717, 2) = .291959799, (718, 1) = .48329505343318435, (718, 2) = .2915477355401902, (719, 1) = .4824120603, (719, 2) = .29060010572401485, (720, 1) = .48066534454485493, (720, 2) = .289257345103619, (721, 1) = .47990739947365446, (721, 2) = .2884422111, (722, 1) = .4780556794864358, (722, 2) = .2869576008322615, (723, 1) = .47615259656772946, (723, 2) = .2849246231, (724, 1) = .4756936967468298, (724, 2) = .2845422714653925, (725, 1) = .47487437180000003, (725, 2) = .28366679383246324, (726, 1) = .47305780017959376, (726, 2) = .2822547686180363, (727, 1) = .4722624051299407, (727, 2) = .2814070352, (728, 1) = .4704621014253052, (728, 2) = .27994850679648364, (729, 1) = .4685237910654614, (729, 2) = .2778894473, (730, 1) = .46810043644502464, (730, 2) = .27753302920421585, (731, 1) = .4673366834, (731, 2) = .27671924899829126, (732, 1) = .46546377749248996, (732, 2) = .2752458820767158, (733, 1) = .46463777623472186, (733, 2) = .2743718593, (734, 1) = .462882201913298, (734, 2) = .2729330294153084, (735, 1) = .4609176282518206, (735, 2) = .2708542714, (736, 1) = .46052168811302885, (736, 2) = .2705170146062497, (737, 1) = .459798995, (737, 2) = .2697479304931192, (738, 1) = .45789077658558486, (738, 2) = .26822718533516565, (739, 1) = .4570446831118084, (739, 2) = .2673366834, (740, 1) = .45532332511948964, (740, 2) = .26590774140465334, (741, 1) = .4533450939443153, (741, 2) = .2638190955, (742, 1) = .4529647331489658, (742, 2) = .26349082973670407, (743, 1) = .4522613065, (743, 2) = .26274186058939175, (744, 1) = .45034718990228606, (744, 2) = .26119476200718766, (745, 1) = .4494955971073297, (745, 2) = .2603015076, (746, 1) = .4477938652157189, (746, 2) = .258868725580079, (747, 1) = .4458186726999408, (747, 2) = .2567839196, (748, 1) = .44543801222302604, (748, 2) = .2564505356778167, (749, 1) = .4447236181, (749, 2) = .2556880681641911, (750, 1) = .4428425490702933, (750, 2) = .2541441638972261, (751, 1) = .44200453441815535, (751, 2) = .2532663317, (752, 1) = .4403034553215288, (752, 2) = .2518114863495001, (753, 1) = .4383524930074799, (753, 2) = .2497487437, (754, 1) = .4379513052215547, (754, 2) = .24939156841671048, (755, 1) = .4371859296, (755, 2) = .24857107563014877, (756, 1) = .4353877964736239, (756, 2) = .24707028458753777, (757, 1) = .4345873846928278, (757, 2) = .2462311558, (758, 1) = .43286326512169326, (758, 2) = .24473081131174035, (759, 1) = .4309626518773221, (759, 2) = .2427135679, (760, 1) = .43051604146422656, (760, 2) = .2423085944341507, (761, 1) = .4296482412, (761, 2) = .24137212881002684, (762, 1) = .4279956301622233, (762, 2) = .23996719840183553, (763, 1) = .42726228438416436, (763, 2) = .2391959799, (764, 1) = .4254864014928762, (764, 2) = .23762058385228169, (765, 1) = .4236677223513047, (765, 2) = .235678392, (766, 1) = .42314575835299, (766, 2) = .23519529606428433, (767, 1) = .4221105528, (767, 2) = .23406808191854572, (768, 1) = .4206809764038216, (768, 2) = .23282793965787185, (769, 1) = .42005011927364955, (769, 2) = .232160804, (770, 1) = .41818835035804597, (770, 2) = .23047357720488884, (771, 1) = .4164891423916891, (771, 2) = .2286432161, (772, 1) = .41585654734415745, (772, 2) = .22804416402407998, (773, 1) = .4145728643, (773, 2) = .22663005384130125, (774, 1) = .4134615419041726, (774, 2) = .22564424531510408, (775, 1) = .4129751290419361, (775, 2) = .2251256282, (776, 1) = .41098762195120536, (776, 2) = .22328115333415552, (777, 1) = .409451948899132, (777, 2) = .2216080402, (778, 1) = .40866775863832683, (778, 2) = .22084616825977926, (779, 1) = .4070351759, (779, 2) = .21902147969544994, (780, 1) = .40635849858888623, (780, 2) = .2184062350392016, (781, 1) = .40606557138981003, (781, 2) = .2180904523, (782, 1) = .40390643609215177, (782, 2) = .21603294289083183, (783, 1) = .4025853816638798, (783, 2) = .2145728643, (784, 1) = .40160277314883797, (784, 2) = .21359039763582902, (785, 1) = .3994974874, (785, 2) = .2111953916267515, (786, 1) = .3993974872014272, (786, 2) = .21110194315906863, (787, 1) = .3993548061582575, (787, 2) = .2110552764, (788, 1) = .3969718915680006, (788, 2) = .20871629988156515, (789, 1) = .3959241588145738, (789, 2) = .2075376885, (790, 1) = .39469021826668604, (790, 2) = .20626349281323436, (791, 1) = .39275962858671026, (791, 2) = .2040201005, (792, 1) = .392519651602392, (792, 2) = .20375883595370253, (793, 1) = .391959799, (793, 2) = .20308410518162512, (794, 1) = .39021706301913595, (794, 2) = .20131578937565633, (795, 1) = .38950935111294255, (795, 2) = .2005025126, (796, 1) = .38796528144486087, (796, 2) = .1988490328100629, (797, 1) = .3864011183684566, (797, 2) = .1969849246, (798, 1) = .38582386658866763, (798, 2) = .19633077177101954, (799, 1) = .3844221105, (799, 2) = .19459086094504696, (800, 1) = .3836829143299022, (800, 2) = .193812294910751, (801, 1) = .3833902777843438, (801, 2) = .1934673367, (802, 1) = .381471712002041, (802, 2) = .1913266014245525, (803, 1) = .38035036929423216, (803, 2) = .1899497488, (804, 1) = .3793717347632515, (804, 2) = .18878900286408398, (805, 1) = .3775375943541058, (805, 2) = .1864321608, (806, 1) = .37736166644215346, (806, 2) = .18620944677492798, (807, 1) = .3768844221, (807, 2) = .18556448319466476, (808, 1) = .37526450636538733, (808, 2) = .18367053357185437, (809, 1) = .37467008495738585, (809, 2) = .1829145729, (810, 1) = .3732225171948196, (810, 2) = .1811058738946159, (811, 1) = .3719455222249287, (811, 2) = .1793969849, (812, 1) = .37127502391601463, (812, 2) = .1784971161376429, (813, 1) = .3694265308925138, (813, 2) = .175879397, (814, 1) = .36940710803346855, (814, 2) = .17585122231120817, (815, 1) = .3693467337, (815, 2) = .17576016082628151, (816, 1) = .3674517163812426, (816, 2) = .17324615049865977, (817, 1) = .36682165777307724, (817, 2) = .1723618091, (818, 1) = .36559224125493306, (818, 2) = .1705963175909678, (819, 1) = .36442118216746267, (819, 2) = .1688442211, (820, 1) = .3638217120726433, (820, 2) = .16790497657723402, (821, 1) = .36221745198925714, (821, 2) = .1653266332, (822, 1) = .3621305321083684, (822, 2) = .16517660597467304, (823, 1) = .3618090452, (823, 2) = .16461658191612735, (824, 1) = .36042004933611393, (824, 2) = .1624572432845554, (825, 1) = .36001413241598124, (825, 2) = .1618090452, (826, 1) = .35878654053790004, (826, 2) = .1597019594676269, (827, 1) = .35797284794656337, (827, 2) = .1582914573, (828, 1) = .3572489110137369, (828, 2) = .15690193200815655, (829, 1) = .35613069273590464, (829, 2) = .1547738694, (830, 1) = .35580307897280694, (830, 2) = .15405906570310007, (831, 1) = .35448015596563326, (831, 2) = .1512562814, (832, 1) = .35444769995839687, (832, 2) = .15117398792654935, (833, 1) = .3542713568, (833, 2) = .15075051674419104, (834, 1) = .35313609511999666, (834, 2) = .14826848227396078, (835, 1) = .3528862293167243, (835, 2) = .1477386935, (836, 1) = .3519356554209787, (836, 2) = .14531109948720555, (837, 1) = .3514838197463479, (837, 2) = .1442211055, (838, 1) = .3508593758497697, (838, 2) = .14229577534659707, (839, 1) = .3502938221071534, (839, 2) = .1407035176, (840, 1) = .34991447247732055, (840, 2) = .13921914234538285, (841, 1) = .34931756648448753, (841, 2) = .1371859297, (842, 1) = .34911207147452883, (842, 2) = .1360760082080354, (843, 1) = .3485591799566558, (843, 2) = .1336683417, (844, 1) = .34846783507255363, (844, 2) = .13285906388814606, (845, 1) = .3480257881214767, (845, 2) = .1301507538, (846, 1) = .34800289002801055, (846, 2) = .12955845032131563, (847, 1) = .3477271310309451, (847, 2) = .1266331658, (848, 1) = .34774494448408766, (848, 2) = .1261612369230366, (849, 1) = .34767622997613645, (849, 2) = .1231155779, (850, 1) = .3477303651018057, (850, 2) = .12265045273463923, (851, 1) = .34788888406570395, (851, 2) = .11959799, (852, 1) = .3480062614091848, (852, 2) = .11900411321008608, (853, 1) = .34838511373913356, (853, 2) = .116080402, (854, 1) = .34863491884857173, (854, 2) = .11519315176081538, (855, 1) = .34918839173015104, (855, 2) = .1125628141, (856, 1) = .3496982391676152, (856, 2) = .11117934768200291, (857, 1) = .3503275726503486, (857, 2) = .1090452261, (858, 1) = .35130638070456277, (858, 2) = .10691129368498048, (859, 1) = .3518364954202148, (859, 2) = .1055276382, (860, 1) = .35360882560815554, (860, 2) = .10231923151700102, (861, 1) = .3537558522159866, (861, 2) = .1020100503, (862, 1) = .3542713568, (862, 2) = .10121702392963003, (863, 1) = .35600053248665653, (863, 2) = 0.9849246232e-1, (864, 1) = .3570572854492312, (864, 2) = 0.971923622763001e-1, (865, 1) = .3586926055897353, (865, 2) = 0.9497487438e-1, (866, 1) = .3618090452, (866, 2) = 0.9158716902677788e-1, (867, 1) = .36192709856954863, (867, 2) = 0.9145728644e-1, (868, 1) = .36205005931326456, (868, 2) = 0.9134481318799587e-1, (869, 1) = .3655390548364391, (869, 2) = 0.879396985e-1, (870, 1) = .3693467337, (870, 2) = 0.8479882969331587e-1, (871, 1) = .3698033059098153, (871, 2) = 0.8442211056e-1, (872, 1) = .3706635536566944, (872, 2) = 0.8380759457671531e-1, (873, 1) = .3745661678736847, (873, 2) = 0.8090452262e-1, (874, 1) = .3768844221, (874, 2) = 0.7939356176205672e-1, (875, 1) = .3799996782143442, (875, 2) = 0.7738693467999999e-1, (876, 1) = .3844221105, (876, 2) = 0.7484642389505781e-1, (877, 1) = .3861556705887529, (877, 2) = 0.7386934674000001e-1, (878, 1) = .391959799, (878, 2) = 0.7090689451692438e-1, (879, 1) = .3930765595362171, (879, 2) = 0.703517588e-1, (880, 1) = .3994974874, (880, 2) = 0.6742285625731652e-1, (881, 1) = .40083272374395407, (881, 2) = 0.6683417086e-1, (882, 1) = .4070351759, (882, 2) = 0.6429437718838504e-1, (883, 1) = .40952543844393996, (883, 2) = 0.6331658292e-1, (884, 1) = .4145728643, (884, 2) = 0.6145535700961236e-1, (885, 1) = .4192968081098093, (885, 2) = 0.59798994980000006e-1, (886, 1) = .4221105528, (886, 2) = 0.58862877992759986e-1, (887, 1) = .4282230450362326, (887, 2) = 0.56946498586872965e-1, (888, 1) = .4296482412, (888, 2) = 0.5648318909637347e-1, (889, 1) = .4303077493632227, (889, 2) = 0.56281407039999995e-1, (890, 1) = .4371859296, (890, 2) = 0.54259072419220275e-1, (891, 1) = .44264178968086776, (891, 2) = 0.527638191e-1, (892, 1) = .4447236181, (892, 2) = 0.52210303355024364e-1, (893, 1) = .4472230956927635, (893, 2) = 0.515973962167451e-1, (894, 1) = .4522613065, (894, 2) = 0.50284417107303435e-1, (895, 1) = .45658545521222793, (895, 2) = 0.4924623116e-1, (896, 1) = .459798995, (896, 2) = 0.4848899261063059e-1, (897, 1) = .46280252505544006, (897, 2) = 0.4784458379282528e-1, (898, 1) = .4673366834, (898, 2) = 0.46795889980450964e-1, (899, 1) = .47240959498250634, (899, 2) = 0.4572864322e-1, (900, 1) = .47487437180000003, (900, 2) = 0.4521380652728622e-1, (901, 1) = .4767185263750812, (901, 2) = 0.44868037758152964e-1, (902, 1) = .4824120603, (902, 2) = 0.4369939046343149e-1, (903, 1) = .48959308784095523, (903, 2) = 0.4237749701516724e-1, (904, 1) = .4899497487, (904, 2) = 0.4230553368836941e-1, (905, 1) = .49047231758269894, (905, 2) = 0.4221105528e-1, (906, 1) = .4974874372, (906, 2) = 0.4093529701697809e-1, (907, 1) = .5016543282464547, (907, 2) = 0.4026650611393161e-1, (908, 1) = .5050251256, (908, 2) = 0.396633456864977e-1, (909, 1) = .5111714689337563, (909, 2) = 0.3869346734e-1, (910, 1) = .5125628141, (910, 2) = 0.3846993033295939e-1, (911, 1) = .5132454260727137, (911, 2) = 0.3837491508425573e-1, (912, 1) = .5201005025000001, (912, 2) = 0.3729037232594075e-1, (913, 1) = .5243561999220785, (913, 2) = 0.3670747519840497e-1, (914, 1) = .5276381909, (914, 2) = 0.361960293284916e-1, (915, 1) = .5351639749169139, (915, 2) = 0.35181434825398046e-1, (916, 1) = .5351758794, (916, 2) = 0.3517960712411226e-1, (917, 1) = .5352039640893407, (917, 2) = 0.351758794e-1, (918, 1) = .5427135678, (918, 2) = 0.3414537152140694e-1, (919, 1) = .5456536286452462, (919, 2) = 0.3380385101595303e-1, (920, 1) = .5502512563, (920, 2) = 0.3318185834638168e-1, (921, 1) = .5559125375649836, (921, 2) = 0.32533948127986365e-1, (922, 1) = .5577889447, (922, 2) = 0.32283633189427896e-1, (923, 1) = .5633336520075796, (923, 2) = 0.3165829146e-1, (924, 1) = .5653266332, (924, 2) = 0.3142227202497525e-1, (925, 1) = .565966100123562, (925, 2) = 0.31359873560641016e-1, (926, 1) = .5728643216, (926, 2) = 0.305538817413697e-1, (927, 1) = .5758455924285844, (927, 2) = 0.30267031732083685e-1, (928, 1) = .58040201, (928, 2) = 0.29741684432756765e-1, (929, 1) = .5855573291499552, (929, 2) = 0.29252475874925958e-1, (930, 1) = .5879396985, (930, 2) = 0.2898136940407693e-1, (931, 1) = .595115285505753, (931, 2) = 0.283096841716094e-1, (932, 1) = .5954773869, (932, 2) = 0.28269007546813177e-1, (933, 1) = .5968666341939834, (933, 2) = 0.2814070352e-1, (934, 1) = .6030150754, (934, 2) = 0.2753280844868558e-1, (935, 1) = .6045819714386098, (935, 2) = 0.2740948536449127e-1, (936, 1) = .6105527638, (936, 2) = 0.26826477584338135e-1, (937, 1) = .6139314406005736, (937, 2) = 0.2656398767076758e-1, (938, 1) = .6180904522, (938, 2) = 0.26162862729445055e-1, (939, 1) = .6231622868236661, (939, 2) = 0.2577384738023213e-1, (940, 1) = .6256281407, (940, 2) = 0.2553889994482989e-1, (941, 1) = .6322835703619627, (941, 2) = 0.25034836326758337e-1, (942, 1) = .6331658291, (942, 2) = 0.24951778970738848e-1, (943, 1) = .6375598731700047, (943, 2) = 0.2462311558e-1, (944, 1) = .6407035176, (944, 2) = 0.24365645583709933e-1, (945, 1) = .6413404044011137, (945, 2) = 0.24325901737790392e-1, (946, 1) = .648241206, (946, 2) = 0.2376726243192491e-1, (947, 1) = .650354354409826, (947, 2) = 0.2363697966289041e-1, (948, 1) = .6557788945, (948, 2) = 0.23202876747452174e-1, (949, 1) = .6592792159444876, (949, 2) = 0.22989632229951592e-1, (950, 1) = .6633165829, (950, 2) = 0.22670196423136894e-1, (951, 1) = .6681212854119927, (951, 2) = 0.223809210616549e-1, (952, 1) = .6708542713, (952, 2) = 0.22167107750822528e-1, (953, 1) = .6768863475434768, (953, 2) = 0.21808146687717637e-1, (954, 1) = .6783919598, (954, 2) = 0.21691659655115058e-1, (955, 1) = .6855797218834964, (955, 2) = 0.2126882658863016e-1, (956, 1) = .6859296482, (956, 2) = 0.21242049584500284e-1, (957, 1) = .6882769815080421, (957, 2) = 0.2110552764e-1, (958, 1) = .6934673366999999, (958, 2) = 0.20765257463606517e-1, (959, 1) = .6942782870063637, (959, 2) = 0.20727084161545162e-1, (960, 1) = .7010050251, (960, 2) = 0.2029078959933281e-1, (961, 1) = .7029443560795692, (961, 2) = 0.2020050651105533e-1, (962, 1) = .7085427135, (962, 2) = 0.19841225711516006e-1, (963, 1) = .7115485178221507, (963, 2) = 0.19702818966963537e-1, (964, 1) = .716080402, (964, 2) = 0.1941501363032748e-1, (965, 1) = .7200947644244649, (965, 2) = 0.1923215849793163e-1, (966, 1) = .7236180904, (966, 2) = 0.19010712863990607e-1, (967, 1) = .7285867916455377, (967, 2) = 0.18786800409660548e-1, (968, 1) = .7311557789, (968, 2) = 0.18626985602721843e-1, (969, 1) = .7370280236098778, (969, 2) = 0.1836514675980933e-1, (970, 1) = .7386934673000001, (970, 2) = 0.1826258831020113e-1, (971, 1) = .7454216355278264, (971, 2) = 0.17965715824150474e-1, (972, 1) = .7462311558, (972, 2) = 0.17916364329992548e-1, (973, 1) = .7537520904730234, (973, 2) = 0.175879397e-1, (974, 1) = .7537688442, (974, 2) = 0.1758708291517289e-1, (975, 1) = .7537708232711489, (975, 2) = 0.1758701613345861e-1, (976, 1) = .7613065326, (976, 2) = 0.17205408105431967e-1, (977, 1) = .762189441390788, (977, 2) = 0.17175915600755754e-1, (978, 1) = .7688442211, (978, 2) = 0.16842180636616112e-1, (979, 1) = .7705641600195864, (979, 2) = 0.16785301532962777e-1, (980, 1) = .7763819095, (980, 2) = 0.16496341045990695e-1, (981, 1) = .7788975599900472, (981, 2) = 0.16413969480211094e-1, (982, 1) = .783919598, (982, 2) = 0.161669001252912e-1, (983, 1) = .7871920474477319, (983, 2) = 0.16060796615708868e-1, (984, 1) = .7914572864, (984, 2) = 0.15852933714335812e-1, (985, 1) = .7954498668852796, (985, 2) = 0.15724735487661082e-1, (986, 1) = .7989949749, (986, 2) = 0.15553577831292395e-1, (987, 1) = .8036731134194652, (987, 2) = 0.15404808378503531e-1, (988, 1) = .8065326633000001, (988, 2) = 0.1526802429009741e-1, (989, 1) = .8118637441392688, (989, 2) = 0.15100101960862838e-1, (990, 1) = .8140703517000001, (990, 2) = 0.14995516542107262e-1, (991, 1) = .820023588478201, (991, 2) = 0.14809762557900735e-1, (992, 1) = .8216080402, (992, 2) = 0.14735345990338197e-1, (993, 1) = .828154357305367, (993, 2) = 0.14532991700125845e-1, (994, 1) = .8291457286, (994, 2) = 0.14486848543279984e-1, (995, 1) = .8362576521039642, (995, 2) = 0.14269042089977133e-1, (996, 1) = .8366834170999999, (996, 2) = 0.1424940141519132e-1, (997, 1) = .8425838567082613, (997, 2) = 0.1407035176e-1, (998, 1) = .8442211055, (998, 2) = 0.14008820617902599e-1, (999, 1) = .8443593944967582, (999, 2) = 0.14005816894479228e-1, (1000, 1) = .8517587939, (1000, 2) = 0.137301598694701e-1, (1001, 1) = .8525230281459295, (1001, 2) = 0.13713709114603212e-1, (1002, 1) = .8592964824, (1002, 2) = 0.13463554679394443e-1, (1003, 1) = .8606590540865626, (1003, 2) = 0.1343448496932211e-1, (1004, 1) = .8668341708, (1004, 2) = 0.1320838470286819e-1, (1005, 1) = .8687689137120126, (1005, 2) = 0.13167471741238845e-1, (1006, 1) = .8743718593, (1006, 2) = 0.12964066476802675e-1, (1007, 1) = .87685396181245, (1007, 2) = 0.12912037247604214e-1, (1008, 1) = .8819095477, (1008, 2) = 0.12730051028875658e-1, (1009, 1) = .8849154718718103, (1009, 2) = 0.12667587157122835e-1, (1010, 1) = .8894472362, (1010, 2) = 0.12505821439256576e-1, (1011, 1) = .8929546421108857, (1011, 2) = 0.1243356232561369e-1, (1012, 1) = .8969849246, (1012, 2) = 0.12290890824841728e-1, (1013, 1) = .9009726001279909, (1013, 2) = 0.1220943650302366e-1, (1014, 1) = .904522613, (1014, 2) = 0.12084800358004747e-1, (1015, 1) = .9089704079143057, (1015, 2) = 0.11994714149059275e-1, (1016, 1) = .9120603015, (1016, 2) = 0.11887117334707719e-1, (1017, 1) = .9169490659352877, (1017, 2) = 0.11788928343894226e-1, (1018, 1) = .9195979899, (1018, 2) = 0.11697433621062113e-1, (1019, 1) = .9249095173296698, (1019, 2) = 0.11591638978278456e-1, (1020, 1) = .9271356784, (1020, 2) = 0.11515363969705617e-1, (1021, 1) = .9328526515029625, (1021, 2) = 0.11402430963448429e-1, (1022, 1) = .9346733668, (1022, 2) = 0.11340544619749256e-1, (1023, 1) = .9407793076969329, (1023, 2) = 0.11220912658563596e-1, (1024, 1) = .9422110552, (1024, 2) = 0.1117263192432869e-1, (1025, 1) = .9486902783114621, (1025, 2) = 0.11046714330906418e-1, (1026, 1) = .9497487437000001, (1026, 2) = 0.1101130107700609e-1, (1027, 1) = .9565863114418658, (1027, 2) = 0.10879486795653657e-1, (1028, 1) = .9572864321, (1028, 2) = 0.10856244955774159e-1, (1029, 1) = .9644681142626971, (1029, 2) = 0.10718900109481845e-1, (1030, 1) = .9648241206, (1030, 2) = 0.10707173025501376e-1, (1031, 1) = .9723363549339009, (1031, 2) = 0.10564642384247074e-1, (1032, 1) = .972361809, (1032, 2) = 0.10563810333045955e-1, (1033, 1) = .972948630488885, (1033, 2) = 0.1055276382e-1, (1034, 1) = .9798994975, (1034, 2) = 0.10375296743919172e-1, (1035, 1) = .9802894902052824, (1035, 2) = 0.10370767223166771e-1, (1036, 1) = .9874371859, (1036, 2) = 0.10189649970835095e-1, (1037, 1) = .9882349895451341, (1037, 2) = 0.10180455450153872e-1, (1038, 1) = .9949748743, (1038, 2) = 0.10010949173809373e-1, (1039, 1) = .9961650738976088, (1039, 2) = 0.999733736006387e-2, (1040, 1) = 1.002512563, (1040, 2) = 0.9838884859509671e-2, (1041, 1) = 1.0040804354592772, (1041, 2) = 0.982108996268309e-2, (1042, 1) = 1.010050251, (1042, 2) = 0.9673163544900765e-2, (1043, 1) = 1.0119817298630203, (1043, 2) = 0.9651407083880376e-2, (1044, 1) = 1.01758794, (1044, 2) = 0.9513506697126249e-2, (1045, 1) = 1.019869580330979, (1045, 2) = 0.9487998269652366e-2, (1046, 1) = 1.025125628, (1046, 2) = 0.9359650041939265e-2, (1047, 1) = 1.0277445763542137, (1047, 2) = 0.9330588011703222e-2, (1048, 1) = 1.032663317, (1048, 2) = 0.9211342550790206e-2, (1049, 1) = 1.0356072791518431, (1049, 2) = 0.9178914735089576e-2, (1050, 1) = 1.040201005, (1050, 2) = 0.9068345848323164e-2, (1051, 1) = 1.0434582198901152, (1051, 2) = 0.9032730115307322e-2, (1052, 1) = 1.047738693, (1052, 2) = 0.8930433399104435e-2, (1053, 1) = 1.0512979052007219, (1053, 2) = 0.8891798249098935e-2, (1054, 1) = 1.055276382, (1054, 2) = 0.8797389809478761e-2, (1055, 1) = 1.0591268151015514, (1055, 2) = 0.8755894933705672e-2, (1056, 1) = 1.06281407, (1056, 2) = 0.8669010341211997e-2, (1057, 1) = 1.0669454061442312, (1057, 2) = 0.8624807095195669e-2, (1058, 1) = 1.070351759, (1058, 2) = 0.8545100142396437e-2, (1059, 1) = 1.0747541125000146, (1059, 2) = 0.849833206595714e-2, (1060, 1) = 1.077889447, (1060, 2) = 0.8425473873461183e-2, (1061, 1) = 1.0825533475002227, (1061, 2) = 0.8376277080769497e-2, (1062, 1) = 1.085427136, (1062, 2) = 0.8309955025592194e-2, (1063, 1) = 1.0903435038637583, (1063, 2) = 0.825845868211691e-2, (1064, 1) = 1.092964824, (1064, 2) = 0.8198375587480662e-2, (1065, 1) = 1.098124956361655, (1065, 2) = 0.8144702229217713e-2, (1066, 1) = 1.100502513, (1066, 2) = 0.8090575419868377e-2, (1067, 1) = 1.1058980607216682, (1067, 2) = 0.8034841401954203e-2, (1068, 1) = 1.108040201, (1068, 2) = 0.7986402020879288e-2, (1069, 1) = 1.1136631564424686, (1069, 2) = 0.7928717792678995e-2, (1070, 1) = 1.115577889, (1070, 2) = 0.7885709958806586e-2, (1071, 1) = 1.12142056817452, (1071, 2) = 0.7826180406757498e-2, (1072, 1) = 1.123115578, (1072, 2) = 0.7788360554924944e-2, (1073, 1) = 1.1291706029325228, (1073, 2) = 0.7727085352140572e-2, (1074, 1) = 1.130653266, (1074, 2) = 0.7694221588903191e-2, (1075, 1) = 1.136913555945145, (1075, 2) = 0.763129539487053e-2, (1076, 1) = 1.138190955, (1076, 2) = 0.76031668339430775e-2, (1077, 1) = 1.144649706412218, (1077, 2) = 0.7538679650546904e-2, (1078, 1) = 1.145728643, (1078, 2) = 0.75150758714770905e-2, (1079, 1) = 1.1523793233660806, (1079, 2) = 0.7449113211899923e-2, (1080, 1) = 1.153266332, (1080, 2) = 0.742983367651974e-2, (1081, 1) = 1.1601026607210896, (1081, 2) = 0.7362476896054679e-2, (1082, 1) = 1.16080402, (1082, 2) = 0.7347330459511903e-2, (1083, 1) = 1.1678199639698905, (1083, 2) = 0.7278656876054324e-2, (1084, 1) = 1.168341709, (1084, 2) = 0.72674612771414715e-2, (1085, 1) = 1.1755314643121628, (1085, 2) = 0.7197544477196978e-2, (1086, 1) = 1.175879397, (1086, 2) = 0.7190125892962781e-2, (1087, 1) = 1.1832373850662354, (1087, 2) = 0.71190358540171176e-2, (1088, 1) = 1.183417085, (1088, 2) = 0.71152284588298234e-2, (1089, 1) = 1.1909379399404183, (1089, 2) = 0.7043031773890721e-2, (1090, 1) = 1.190954774, (1090, 2) = 0.7042677335802723e-2, (1091, 1) = 1.1917412351176269, (1091, 2) = 0.7035175879999999e-2, (1092, 1) = 1.198492462, (1092, 2) = 0.6930572699126082e-2, (1093, 1) = 1.1987185238181046, (1093, 2) = 0.69296803726821305e-2, (1094, 1) = 1.206030151, (1094, 2) = 0.6817094642930465e-2, (1095, 1) = 1.2065014290735379, (1095, 2) = 0.681524609942756e-2, (1096, 1) = 1.213567839, (1096, 2) = 0.6707104748696734e-2, (1097, 1) = 1.214276769996557, (1097, 2) = 0.67043414393934e-2, (1098, 1) = 1.221105528, (1098, 2) = 0.660047513151033e-2, (1099, 1) = 1.2220448262760126, (1099, 2) = 0.659683665877399e-2, (1100, 1) = 1.228643216, (1100, 2) = 0.6497083404960625e-2, (1101, 1) = 1.2298058622217876, (1101, 2) = 0.6492607611288709e-2, (1102, 1) = 1.236180904, (1102, 2) = 0.6396812289077833e-2, (1103, 1) = 1.2375601338214697, (1103, 2) = 0.639153534422181e-2, (1104, 1) = 1.243718593, (1104, 2) = 0.6299549430507505e-2, (1105, 1) = 1.2453078856874127, (1105, 2) = 0.6293505915632566e-2, (1106, 1) = 1.251256281, (1106, 2) = 0.6205187243968288e-2, (1107, 1) = 1.2530493503958227, (1107, 2) = 0.6198410223798384e-2, (1108, 1) = 1.25879397, (1108, 2) = 0.6113622509922266e-2, (1109, 1) = 1.2607847533153351, (1109, 2) = 0.6106143611594024e-2, (1110, 1) = 1.266331658, (1110, 2) = 0.6024756333067465e-2, (1111, 1) = 1.268514308313239, (1111, 2) = 0.601660580910859e-2, (1112, 1) = 1.273869347, (1112, 2) = 0.5938493832349033e-2, (1113, 1) = 1.2762382223896214, (1113, 2) = 0.59297006332274076e-2, (1114, 1) = 1.281407035, (1114, 2) = 0.58547440350789695e-2, (1115, 1) = 1.283956692368622, (1115, 2) = 0.5845335862589219e-2, (1116, 1) = 1.288944724, (1116, 2) = 0.5773419610608419e-2, (1117, 1) = 1.2916699086100987, (1117, 2) = 0.5763422987235457e-2, (1118, 1) = 1.296482412, (1118, 2) = 0.5694436786844592e-2, (1119, 1) = 1.299378052070196, (1119, 2) = 0.5683877101183213e-2, (1120, 1) = 1.3040201, (1120, 2) = 0.5617715132353588e-2, (1121, 1) = 1.307081298478856, (1121, 2) = 0.5606616695458106e-2, (1122, 1) = 1.311557789, (1122, 2) = 0.5543177397281742e-2, (1123, 1) = 1.314779815340327, (1123, 2) = 0.55315634995066285e-2, (1124, 1) = 1.319095477, (1124, 2) = 0.5470749445679901e-2, (1125, 1) = 1.3224737632974548, (1125, 2) = 0.5458642391049434e-2, (1126, 1) = 1.326633166, (1126, 2) = 0.540036000120043e-2, (1127, 1) = 1.3301632973227266, (1127, 2) = 0.53877811659392184e-2, (1128, 1) = 1.334170854, (1128, 2) = 0.5331940629590904e-2, (1129, 1) = 1.3378485658135628, (1129, 2) = 0.53189104938605476e-2, (1130, 1) = 1.341708543, (1130, 2) = 0.5265425527342091e-2, (1131, 1) = 1.3455297116798746, (1131, 2) = 0.5251963724623916e-2, (1132, 1) = 1.349246231, (1132, 2) = 0.5200751470099699e-2, (1133, 1) = 1.3532068721423451, (1133, 2) = 0.5186876816854617e-2, (1134, 1) = 1.35678392, (1134, 2) = 0.513785764049644e-2, (1135, 1) = 1.3608801791070615, (1135, 2) = 0.5123588184394362e-2, (1136, 1) = 1.364321608, (1136, 2) = 0.5076685573683551e-2, (1137, 1) = 1.3685497590319484, (1137, 2) = 0.5062038615830922e-2, (1138, 1) = 1.371859296, (1138, 2) = 0.50171790218632795e-2, (1139, 1) = 1.3762157350164028, (1139, 2) = 0.500217115594679e-2, (1140, 1) = 1.379396985, (1140, 2) = 0.4959283859897053e-2, (1141, 1) = 1.383878223746966, (1141, 2) = 0.49439310085502754e-2, (1142, 1) = 1.386934673, (1142, 2) = 0.4902948031323432e-2, (1143, 1) = 1.3915373385162417, (1143, 2) = 0.48872654645150965e-2, (1144, 1) = 1.394472362, (1144, 2) = 0.4848121398297026e-2, (1145, 1) = 1.399193187662768, (1145, 2) = 0.4832123774606931e-2, (1146, 1) = 1.40201005, (1146, 2) = 0.4794755721534188e-2, (1147, 1) = 1.4068458763116132, (1147, 2) = 0.477845710138426e-2, (1148, 1) = 1.409547739, (1148, 2) = 0.474280452752723e-2, (1149, 1) = 1.414495504702633, (1149, 2) = 0.4726218416447846e-2, (1150, 1) = 1.417085427, (1150, 2) = 0.4692223081836024e-2, (1151, 1) = 1.422142170476746, (1151, 2) = 0.46753624319423905e-2, (1152, 1) = 1.424623116, (1152, 2) = 0.4642968265171549e-2, (1153, 1) = 1.4297859664576211, (1153, 2) = 0.46258455248896204e-2, (1154, 1) = 1.432160804, (1154, 2) = 0.4594998559349632e-2, (1155, 1) = 1.437426982704413, (1155, 2) = 0.45776256735536765e-2, (1156, 1) = 1.439698492, (1156, 2) = 0.45482739392615785e-2, (1157, 1) = 1.4450653070434634, (1157, 2) = 0.45306623781697156e-2, (1158, 1) = 1.447236181, (1158, 2) = 0.4502755819620253e-2, (1159, 1) = 1.452701021972946, (1159, 2) = 0.44849166094580745e-2, (1160, 1) = 1.454773869, (1160, 2) = 0.4458407028562616e-2, (1161, 1) = 1.4603342089784799, (1161, 2) = 0.4440350748504083e-2, (1162, 1) = 1.462311558, (1162, 2) = 0.441519169049109e-2, (1163, 1) = 1.4679649448741687, (1163, 2) = 0.4396928517051396e-2, (1164, 1) = 1.469849246, (1164, 2) = 0.4373075238167609e-2, (1165, 1) = 1.475593305588006, (1165, 2) = 0.43546149370622626e-2, (1166, 1) = 1.477386935, (1166, 2) = 0.4332024301478836e-2, (1167, 1) = 1.4832193623974281, (1167, 2) = 0.43133762679546e-2, (1168, 1) = 1.484924623, (1168, 2) = 0.4292006710999836e-2, (1169, 1) = 1.4908431861151392, (1169, 2) = 0.4273179963752635e-2, (1170, 1) = 1.492462312, (1170, 2) = 0.4252991400793571e-2, (1171, 1) = 1.4984648429204566, (1171, 2) = 0.4233994619210856e-2, (1172, 1) = 1.5, (1172, 2) = 0.4214948412973115e-2, (1173, 1) = 15.0, (1173, 2) = .0, (1174, 1) = .7763819095, (1174, 2) = .607778751889855, (1175, 1) = .7765917979042034, (1175, 2) = .6084447656798948, (1176, 1) = .7767164064919965, (1176, 2) = .6085427136, (1177, 1) = .7771436112395627, (1177, 2) = .6117048407848357, (1178, 1) = .7777259884990406, (1178, 2) = .6120603016, (1179, 1) = .7767494783952099, (1179, 2) = .6154063573521529, (1180, 1) = .7773546337016262, (1180, 2) = .6155778894999999, (1181, 1) = .7763819095, (1181, 2) = .615964402185334, (1182, 1) = .7762628509681525, (1182, 2) = .6156334501478794, (1183, 1) = .7761810796799455, (1183, 2) = .6155778894999999, (1184, 1) = .7755991837432397, (1184, 2) = .6124255736177447, (1185, 1) = .7748754415956448, (1185, 2) = .6120603016, (1186, 1) = .775676891794233, (1186, 2) = .6088717218701738, (1187, 1) = .7738241995201303, (1187, 2) = .6085427136, (1188, 1) = .7763819095, (1188, 2) = .607778751889855, (1189, 1) = 11.0, (1189, 2) = .0, (1190, 1) = .783919598, (1190, 2) = .6188678901371553, (1191, 1) = .78397674840546, (1191, 2) = .6190688072109369, (1192, 1) = .7840111953751815, (1192, 2) = .6190954773999999, (1193, 1) = .7842955859737704, (1193, 2) = .6224376043415832, (1194, 1) = .7845976136243192, (1194, 2) = .6226130653999999, (1195, 1) = .783919598, (1195, 2) = .6242381964078862, (1196, 1) = .7835965867154213, (1196, 2) = .6227638039966131, (1197, 1) = .7833238842954877, (1197, 2) = .6226130653999999, (1198, 1) = .7837710236567536, (1198, 2) = .619164812094172, (1199, 1) = .7835088566664069, (1199, 2) = .6190954773999999, (1200, 1) = .783919598, (1200, 2) = .6188678901371553, (1201, 1) = .0, (1201, 2) = .0, (1202, 1) = .0, (1202, 2) = .0, (1203, 1) = .0, (1203, 2) = .0}, datatype = float[8], order = C_order))]), Array(1..11, 1..2, {(1, 1) = .783919598, (1, 2) = .6188678901371553, (2, 1) = .78397674840546, (2, 2) = .6190688072109369, (3, 1) = .7840111953751815, (3, 2) = .6190954773999999, (4, 1) = .7842955859737704, (4, 2) = .6224376043415832, (5, 1) = .7845976136243192, (5, 2) = .6226130653999999, (6, 1) = .783919598, (6, 2) = .6242381964078862, (7, 1) = .7835965867154213, (7, 2) = .6227638039966131, (8, 1) = .7833238842954877, (8, 2) = .6226130653999999, (9, 1) = .7837710236567536, (9, 2) = .619164812094172, (10, 1) = .7835088566664069, (10, 2) = .6190954773999999, (11, 1) = .783919598, (11, 2) = .6188678901371553}, datatype = float[8], order = C_order, attributes = [source_rtable = (Array(1..1203, 1..2, {(1, 1) = 1171.0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .1563469655787127, (3, 1) = 0.411404206213146e-2, (3, 2) = .1563715710259522, (4, 1) = 0.7537688442e-2, (4, 2) = .1563939703226259, (5, 1) = 0.11453278530964653e-1, (5, 2) = .1564641819447511, (6, 1) = 0.1507537688e-1, (6, 2) = .15653540477192268, (7, 1) = 0.1861188724047196e-1, (7, 2) = .15664108581877745, (8, 1) = 0.2261306533e-1, (8, 2) = .15677253817326953, (9, 1) = 0.25599994493771153e-1, (9, 2) = .15689755703889574, (10, 1) = 0.3015075377e-1, (10, 2) = .1571075215866537, (11, 1) = 0.3242521581787689e-1, (11, 2) = .15723004168932495, (12, 1) = 0.3768844221e-1, (12, 2) = .1575434428479125, (13, 1) = 0.3909288395460391e-1, (13, 2) = .15763605115972262, (14, 1) = 0.4522613065e-1, (14, 2) = .1580844082091386, (15, 1) = 0.4560620688944438e-1, (15, 2) = .158114088390209, (16, 1) = 0.4764869985153962e-1, (16, 2) = .1582914573, (17, 1) = 0.5204162039916189e-1, (17, 2) = .15862848335201973, (18, 1) = 0.5276381909e-1, (18, 2) = .15868992174261032, (19, 1) = 0.5837968585731567e-1, (19, 2) = .1591883074075377, (20, 1) = 0.6030150754e-1, (20, 2) = .15937801020899345, (21, 1) = 0.6458489561557128e-1, (21, 2) = .15981013078670622, (22, 1) = 0.6783919598e-1, (22, 2) = .160176487241211, (23, 1) = 0.7065484457382515e-1, (23, 2) = .1604950758706586, (24, 1) = 0.7537688442e-1, (24, 2) = .16109337109567876, (25, 1) = 0.7658532352018085e-1, (25, 2) = .16124510695944796, (26, 1) = 0.805813499008662e-1, (26, 2) = .1618090452, (27, 1) = 0.8242671215465647e-1, (27, 2) = .16203671353312998, (28, 1) = 0.8291457286000001e-1, (28, 2) = .16210413044792332, (29, 1) = 0.8826417929324287e-1, (29, 2) = .16283015015429084, (30, 1) = 0.904522613e-1, (30, 2) = .16316400984452806, (31, 1) = 0.9396930534693831e-1, (31, 2) = .1636853459516551, (32, 1) = 0.9798994975e-1, (32, 2) = .16435809016344582, (33, 1) = 0.9953317989166656e-1, (33, 2) = .16460645912228727, (34, 1) = .10348031148371162, (34, 2) = .1653266332, (35, 1) = .10500945609610703, (35, 2) = .1655684515121711, (36, 1) = .1055276382, (36, 2) = .16566098682384123, (37, 1) = .11052117326438587, (37, 2) = .16651390474986943, (38, 1) = .1130653266, (38, 2) = .16700677204260045, (39, 1) = .11589064181312089, (39, 2) = .16752574069219858, (40, 1) = .1206030151, (40, 2) = .16851216850911968, (41, 1) = .12110349883838589, (41, 2) = .16861066202341454, (42, 1) = .122139540949522, (42, 2) = .1688442211, (43, 1) = .12638254550555122, (43, 2) = .16966469484940266, (44, 1) = .1281407035, (44, 2) = .17005235758919762, (45, 1) = .13157164917804653, (45, 2) = .17076070110173922, (46, 1) = .135678392, (46, 2) = .1717326132535611, (47, 1) = .13659497627188055, (47, 2) = .17193406976339443, (48, 1) = .1382828915235487, (48, 2) = .1723618091, (49, 1) = .1416551472841524, (49, 2) = .17309024454992056, (50, 1) = .1432160804, (50, 2) = .1734770360582889, (51, 1) = .1466677855036304, (51, 2) = .174268601294131, (52, 1) = .1507537688, (52, 2) = .1753499101663136, (53, 1) = .15149998042302312, (53, 2) = .17553116491585571, (54, 1) = .1527341814199683, (54, 2) = .175879397, (55, 1) = .15641056483426513, (55, 2) = .17675714680070748, (56, 1) = .1582914573, (56, 2) = .17727585933216883, (57, 1) = .1612416351715959, (57, 2) = .17802023523441637, (58, 1) = .1658291457, (58, 2) = .17936629609487686, (59, 1) = .16587102451962582, (59, 2) = .17937744145121168, (60, 1) = .16593369754540996, (60, 2) = .1793969849, (61, 1) = .17069645778368336, (61, 2) = .18064316057275676, (62, 1) = .1733668342, (62, 2) = .1814566697357216, (63, 1) = .17533134212275173, (63, 2) = .1819978025151992, (64, 1) = .1781677256590961, (64, 2) = .1829145729, (65, 1) = .17989932145951784, (65, 2) = .1833836667628912, (66, 1) = .1809045226, (66, 2) = .18370113669326119, (67, 1) = .18453928746276133, (67, 2) = .1847359372070223, (68, 1) = .188442211, (68, 2) = .186041774318842, (69, 1) = .18895226379950275, (69, 2) = .18619413616474317, (70, 1) = .18962414585713816, (70, 2) = .1864321608, (71, 1) = .19352401701856153, (71, 2) = .1875782393021984, (72, 1) = .1959798995, (72, 2) = .1884278375837101, (73, 1) = .19794481725849886, (73, 2) = .18903278715851288, (74, 1) = .20045117752386254, (74, 2) = .1899497488, (75, 1) = .20231044794143524, (75, 2) = .1905130807774606, (76, 1) = .2035175879, (76, 2) = .19094440102144117, (77, 1) = .20673715713903199, (77, 2) = .19196487108359372, (78, 1) = .21071765865965755, (78, 2) = .1934673367, (79, 1) = .210919986781138, (79, 2) = .19353047185427236, (80, 1) = .2110552764, (80, 2) = .19358035292660802, (81, 1) = .2153504304721779, (81, 2) = .1949805193777135, (82, 1) = .2185929648, (82, 2) = .19624220476735219, (83, 1) = .21951361459471921, (83, 2) = .19655528803727368, (84, 1) = .220559693818866, (84, 2) = .1969849246, (85, 1) = .22380281657196704, (85, 2) = .1980712484167096, (86, 1) = .2261306533, (86, 2) = .19900426808883254, (87, 1) = .22796753073484188, (87, 2) = .19964530311091175, (88, 1) = .22999525398791076, (88, 2) = .2005025126, (89, 1) = .23210999355251577, (89, 2) = .20122974173135783, (90, 1) = .2336683417, (90, 2) = .20187269529339172, (91, 1) = .23627283634234642, (91, 2) = .20280466967381558, (92, 1) = .23906773088042566, (92, 2) = .2040201005, (93, 1) = .24028550777061808, (93, 2) = .20444967759681473, (94, 1) = .2412060301, (94, 2) = .204840388245712, (95, 1) = .2444429751737546, (95, 2) = .20602711411793337, (96, 1) = .2478214695999889, (96, 2) = .2075376885, (97, 1) = .24834109968376933, (97, 2) = .2077255773240134, (98, 1) = .2487437186, (98, 2) = .20790128484539636, (99, 1) = .252489482515476, (99, 2) = .20930725324938332, (100, 1) = .256281407, (100, 2) = .2110496186290694, (101, 1) = .2562880193831866, (101, 2) = .21105219062123806, (102, 1) = .2562943908258979, (102, 2) = .2110552764, (103, 1) = .26042230322198406, (103, 2) = .212640446099698, (104, 1) = .2638190955, (104, 2) = .21424381425046282, (105, 1) = .2641998913635977, (105, 2) = .21439515956466476, (106, 1) = .2645571585520604, (106, 2) = .2145728643, (107, 1) = .26825000147542855, (107, 2) = .21602269613110664, (108, 1) = .2713567839, (108, 2) = .21752863992089982, (109, 1) = .27200070242220775, (109, 2) = .21778995698678882, (110, 1) = .2725890871945216, (110, 2) = .2180904523, (111, 1) = .27597988723170386, (111, 2) = .219450592019427, (112, 1) = .2788944724, (112, 2) = .22090098019948495, (113, 1) = .27969725652919275, (113, 2) = .22123340760850677, (114, 1) = .2804118157639838, (114, 2) = .2216080402, (115, 1) = .283618132254194, (115, 2) = .22292125355124234, (116, 1) = .2864321608, (116, 2) = .22435856050825176, (117, 1) = .2872950900428197, (117, 2) = .2247229278775256, (118, 1) = .2880433831984684, (118, 2) = .2251256282, (119, 1) = .29116990158350164, (119, 2) = .2264322704136034, (120, 1) = .2939698492, (120, 2) = .2278998650257172, (121, 1) = .2947986307063212, (121, 2) = .22825645140438025, (122, 1) = .2954988272759236, (122, 2) = .2286432161, (123, 1) = .29863944855385915, (123, 2) = .2299816576761657, (124, 1) = .3015075377, (124, 2) = .23152418338227845, (125, 1) = .30221116730105624, (125, 2) = .23183244352137405, (126, 1) = .30279033114215453, (126, 2) = .232160804, (127, 1) = .3060301271596008, (127, 2) = .23356785020418652, (128, 1) = .3090452261, (128, 2) = .2352316447014429, (129, 1) = .3095348534013429, (129, 2) = .23544989925720808, (130, 1) = .30992746284733075, (130, 2) = .235678392, (131, 1) = .3133444099346572, (131, 2) = .2371896941485172, (132, 1) = .3165829146, (132, 2) = .23902330205384661, (133, 1) = .31677063657843346, (133, 2) = .23910837631056248, (134, 1) = .31691724815204936, (134, 2) = .2391959799, (135, 1) = .3205839061629061, (135, 2) = .24084643846151332, (136, 1) = .3237977008207778, (136, 2) = .2427135679, (137, 1) = .3239626997077225, (137, 2) = .2427872561026439, (138, 1) = .324120603, (138, 2) = .24287665200373632, (139, 1) = .3277493216791142, (139, 2) = .24453775375937492, (140, 1) = .3305894716179565, (140, 2) = .2462311558, (141, 1) = .3311308893678871, (141, 2) = .24647727674692, (142, 1) = .3316582914, (142, 2) = .2467835549689252, (143, 1) = .33484037350574114, (143, 2) = .24826377207879788, (144, 1) = .33726661427309146, (144, 2) = .2497487437, (145, 1) = .3382357167737991, (145, 2) = .2501968664964736, (146, 1) = .3391959799, (146, 2) = .2507689682864231, (147, 1) = .34185565973081394, (147, 2) = .25202514775072543, (148, 1) = .3438305170126463, (148, 2) = .2532663317, (149, 1) = .3452768774193954, (149, 2) = .25394616744041676, (150, 1) = .3467336683, (150, 2) = .2548367630850394, (151, 1) = .3487924843457991, (151, 2) = .25582313879683616, (152, 1) = .35028050460732685, (152, 2) = .2567839196, (153, 1) = .3522532246943719, (153, 2) = .2577257145915511, (154, 1) = .3542713568, (154, 2) = .258992096032466, (155, 1) = .355646577930956, (155, 2) = .2596597377242915, (156, 1) = .356613489956487, (156, 2) = .2603015076, (157, 1) = .35916257815712477, (157, 2) = .2615365255463198, (158, 1) = .3618090452, (158, 2) = .26324180296336236, (159, 1) = .3624116312465448, (159, 2) = .2635378886836086, (160, 1) = .36282345633954893, (160, 2) = .2638190955, (161, 1) = .3660015162650624, (161, 2) = .265380196940051, (162, 1) = .3689568243623757, (162, 2) = .2673366834, (163, 1) = .36914704156615796, (163, 2) = .2674298730633427, (164, 1) = .3693467337, (164, 2) = .2675584668960912, (165, 1) = .37276508141208897, (165, 2) = .26925904243141174, (166, 1) = .3751087624447853, (166, 2) = .2708542714, (167, 1) = .37596870650284064, (167, 2) = .2712816053429114, (168, 1) = .3768844221, (168, 2) = .27188718811737245, (169, 1) = .3794462813572124, (169, 2) = .27317632498676503, (170, 1) = .38115313529001693, (170, 2) = .2743718593, (171, 1) = .38272548573151655, (171, 2) = .27516361754329915, (172, 1) = .3844221105, (172, 2) = .27631660317460116, (173, 1) = .3860354639396687, (173, 2) = .27713654902102, (174, 1) = .3870788206689781, (174, 2) = .2778894473, (175, 1) = .3894118058305985, (175, 2) = .27907851075651846, (176, 1) = .391959799, (176, 2) = .2808593013214599, (177, 1) = .3925192611802801, (177, 2) = .2811459528506871, (178, 1) = .3928699254515984, (178, 2) = .2814070352, (179, 1) = .39601999075370253, (179, 2) = .2830298669590452, (180, 1) = .39865339649823994, (180, 2) = .2849246231, (181, 1) = .399054215984739, (181, 2) = .28513148309849307, (182, 1) = .3994974874, (182, 2) = .2854410813479102, (183, 1) = .4025394978638157, (183, 2) = .28702260620343356, (184, 1) = .40445346238143115, (184, 2) = .2884422111, (185, 1) = .40567205625734704, (185, 2) = .28907833358784873, (186, 1) = .4070351759, (186, 2) = .2900578777122225, (187, 1) = .4089557678778346, (187, 2) = .2910635227487732, (188, 1) = .41012599927130694, (188, 2) = .291959799, (189, 1) = .4122139513300834, (189, 2) = .29306062507766373, (190, 1) = .4145728643, (190, 2) = .29480677486942214, (191, 1) = .41524840249674494, (191, 2) = .2951621358385316, (192, 1) = .4156461222869131, (192, 2) = .295477387, (193, 1) = .4186682810347394, (193, 2) = .29708378046000994, (194, 1) = .4211708817900251, (194, 2) = .2989949749, (195, 1) = .4216089056599046, (195, 2) = .29922907689427447, (196, 1) = .4221105528, (196, 2) = .29960026414159835, (197, 1) = .4250189113577072, (197, 2) = .30115532881412016, (198, 1) = .42673813074297334, (198, 2) = .3025125628, (199, 1) = .4280881553513352, (199, 2) = .30324060287926796, (200, 1) = .4296482412, (200, 2) = .30443065848243966, (201, 1) = .43124296130670364, (201, 2) = .305285948066613, (202, 1) = .4321524720222676, (202, 2) = .3060301508, (203, 1) = .43447882908159996, (203, 2) = .3072934643680706, (204, 1) = .4371859296, (204, 2) = .3094261430078931, (205, 1) = .4373072082542931, (205, 2) = .30949114199573585, (206, 1) = .43737370440049944, (206, 2) = .3095477387, (207, 1) = .4407626456393019, (207, 2) = .3113961925325087, (208, 1) = .44280925121024983, (208, 2) = .3130653267, (209, 1) = .44368693138175197, (209, 2) = .31354911382601347, (210, 1) = .4447236181, (210, 2) = .31436552367991755, (211, 1) = .44691325438868024, (211, 2) = .31556108433775903, (212, 1) = .44811968623247306, (212, 2) = .3165829146, (213, 1) = .4500128454767157, (213, 2) = .3176321964049001, (214, 1) = .4522613065, (214, 2) = .31946347593252944, (215, 1) = .452891529738174, (215, 2) = .3198063983277594, (216, 1) = .45322441588014806, (216, 2) = .3201005025, (217, 1) = .4562256549567938, (217, 2) = .3217680612026317, (218, 1) = .4584156737738623, (218, 2) = .3236180905, (219, 1) = .45904270810555414, (219, 2) = .3239710243773858, (220, 1) = .459798995, (220, 2) = .32458718918913143, (221, 1) = .4622940370494772, (221, 2) = .3259713254501975, (222, 1) = .4636177231597405, (222, 2) = .3271356784, (223, 1) = .4653001003370227, (223, 2) = .3280860838510044, (224, 1) = .4673366834, (224, 2) = .3298052569263673, (225, 1) = .4681701175821987, (225, 2) = .3302643304394618, (226, 1) = .4685923820791582, (226, 2) = .3306532664, (227, 1) = .4714342533295569, (227, 2) = .3322586550104123, (228, 1) = .4736127372887472, (228, 2) = .3341708543, (229, 1) = .4741784948157407, (229, 2) = .33449559689080793, (230, 1) = .47487437180000003, (230, 2) = .33508357622689244, (231, 1) = .4774064804372275, (231, 2) = .3365067915250223, (232, 1) = .4786946396102586, (232, 2) = .3376884422, (233, 1) = .48036051097030574, (233, 2) = .33864583189626307, (234, 1) = .4824120603, (234, 2) = .3404462819598845, (235, 1) = .4831554993207043, (235, 2) = .3408590919824476, (236, 1) = .48351475560029955, (236, 2) = .3412060302, (237, 1) = .486403767498123, (237, 2) = .34286082141813395, (238, 1) = .4884380204147546, (238, 2) = .3447236181, (239, 1) = .48910930455562657, (239, 2) = .3451158253762942, (240, 1) = .4899497487, (240, 2) = .34585451237338455, (241, 1) = .4922582746972002, (241, 2) = .3471638939577644, (242, 1) = .4933783239162865, (242, 2) = .3482412061, (243, 1) = .49520497458841906, (243, 2) = .34930635529855064, (244, 1) = .4974874372, (244, 2) = .3513969608302578, (245, 1) = .4978411444834455, (245, 2) = .3515937306019973, (246, 1) = .4980028813388976, (246, 2) = .351758794, (247, 1) = .5011382603441314, (247, 2) = .35357266444242547, (248, 1) = .5029123014095499, (248, 2) = .3552763819, (249, 1) = .5038426326656263, (249, 2) = .35582821194859127, (250, 1) = .5050251256, (250, 2) = .35691345813736414, (251, 1) = .506840931853553, (251, 2) = .35794659364031206, (252, 1) = .5076747727105544, (252, 2) = .3587939699, (253, 1) = .5098347969513135, (253, 2) = .3600670445452593, (254, 1) = .5121706405090248, (254, 2) = .3623115578, (255, 1) = .5123417375182368, (255, 2) = .3624147268724672, (256, 1) = .5125628141, (256, 2) = .36261833722107134, (257, 1) = .515627776465587, (257, 2) = .3643988299968633, (258, 1) = .517037436286423, (258, 2) = .3658291458, (259, 1) = .5183776657705376, (259, 2) = .3666331362691778, (260, 1) = .5201005025000001, (260, 2) = .3682925798270953, (261, 1) = .5211218094273468, (261, 2) = .3688701238032814, (262, 1) = .5215606671057531, (262, 2) = .3693467337, (263, 1) = .5242388999126684, (263, 2) = .37093306948506855, (264, 1) = .5261408456874557, (264, 2) = .3728643216, (265, 1) = .526789770654438, (265, 2) = .37326025105693345, (266, 1) = .5276381909, (266, 2) = .37408073813624665, (267, 1) = .5298408117505049, (267, 2) = .3753540198600239, (268, 1) = .5307890461341223, (268, 2) = .3763819096, (269, 1) = .5327024621228297, (269, 2) = .3775361709741368, (270, 1) = .5350235561041898, (270, 2) = .3798994975, (271, 1) = .5350889609440974, (271, 2) = .37994005944647224, (272, 1) = .5351758794, (272, 2) = .38002457646404664, (273, 1) = .5383866426757877, (273, 2) = .3819187292705555, (274, 1) = .5397678254418192, (274, 2) = .3834170855, (275, 1) = .5410400965701394, (275, 2) = .3841980387361613, (276, 1) = .5427135678, (276, 2) = .38590965937995525, (277, 1) = .543705513710889, (277, 2) = .386471765317025, (278, 1) = .5440979633663376, (278, 2) = .3869346734, (279, 1) = .5467869878557947, (279, 2) = .3885513319766563, (280, 1) = .5485339197773342, (280, 2) = .3904522613, (281, 1) = .5492686492431231, (281, 2) = .3909108112642211, (282, 1) = .5502512563, (282, 2) = .3919219623354962, (283, 1) = .552209960639181, (283, 2) = .3930557872542605, (284, 1) = .5529844139193156, (284, 2) = .3939698493, (285, 1) = .5550630770255085, (285, 2) = .39524192087419674, (286, 1) = .5571162262826977, (286, 2) = .3974874372, (287, 1) = .5574014126054714, (287, 2) = .3976682855148931, (288, 1) = .5577889447, (288, 2) = .3980700966510423, (289, 1) = .5605658940567053, (289, 2) = .39970911548792387, (290, 1) = .5616601137346005, (290, 2) = .4010050252, (291, 1) = .5632313898737636, (291, 2) = .401982805400379, (292, 1) = .5653266332, (292, 2) = .4042902645303774, (293, 1) = .5655545878763909, (293, 2) = .40441623425162243, (294, 1) = .5656346345021266, (294, 2) = .4045226131, (295, 1) = .5687951576899943, (295, 2) = .4064215562472058, (296, 1) = .5701537839480469, (296, 2) = .408040201, (297, 1) = .571304894879362, (297, 2) = .4087679334861818, (298, 1) = .5728643216, (298, 2) = .4105001595793406, (299, 1) = .573890981475691, (299, 2) = .4110786810471146, (300, 1) = .5742499574625818, (300, 2) = .411557789, (301, 1) = .5769146360350601, (301, 2) = .4131852301743854, (302, 1) = .5784881143647418, (302, 2) = .4150753769, (303, 1) = .5792939134001516, (303, 2) = .4155924886583565, (304, 1) = .58040201, (304, 2) = .4168360034851491, (305, 1) = .5820916234225818, (305, 2) = .41780447862865666, (306, 1) = .5826778032589655, (306, 2) = .4185929649, (307, 1) = .5849375309142315, (307, 2) = .4199939764134728, (308, 1) = .5866812236992927, (308, 2) = .4221105528, (309, 1) = .5872067269735419, (309, 2) = .42245260617253105, (310, 1) = .5879396985, (310, 2) = .42328487231509143, (311, 1) = .5901748181793824, (311, 2) = .424585084855552, (312, 1) = .5909416297801887, (312, 2) = .4256281407, (313, 1) = .5928742661563755, (313, 2) = .4268429304079858, (314, 1) = .5947477331341324, (314, 2) = .4291457287, (315, 1) = .5950500399391007, (315, 2) = .4293451572806191, (316, 1) = .5954773869, (316, 2) = .42983686771803714, (317, 1) = .5981546733456532, (317, 2) = .4314139162823743, (318, 1) = .5990599732896797, (318, 2) = .4326633166, (319, 1) = .6007331668179969, (319, 2) = .4337282072816926, (320, 1) = .6026995817042107, (320, 2) = .4361809046, (321, 1) = .6028293309636257, (321, 2) = .43626758533533183, (322, 1) = .6030150754, (322, 2) = .43648448192499756, (323, 1) = .6060420969519619, (323, 2) = .4382858824504494, (324, 1) = .6070475298616599, (324, 2) = .4396984925, (325, 1) = .6085209028289573, (325, 2) = .4406466942810953, (326, 1) = .6105465714823727, (326, 2) = .4432160804, (327, 1) = .610549100469022, (327, 2) = .44321778995449523, (328, 1) = .6105527638, (328, 2) = .44322213796208026, (329, 1) = .6138455353056087, (329, 2) = .44519704166243534, (330, 1) = .6149160064931423, (330, 2) = .4467336684, (331, 1) = .6162428430226877, (331, 2) = .4475958860111768, (332, 1) = .6180904522, (332, 2) = .44998451105692194, (333, 1) = .618361032979732, (333, 2) = .4501249852718516, (334, 1) = .6184311109683637, (334, 2) = .4502512563, (335, 1) = .6215714415476802, (335, 2) = .45214438258902223, (336, 1) = .6226746600685912, (336, 2) = .4537688443, (337, 1) = .6239033103668259, (337, 2) = .4545737651068926, (338, 1) = .6256281407, (338, 2) = .4568521499901121, (339, 1) = .6260703963670847, (339, 2) = .4570800462232006, (340, 1) = .6261798113812319, (340, 2) = .4572864322, (341, 1) = .629224615214578, (341, 2) = .4591256653360729, (342, 1) = .630330704663824, (342, 2) = .4608040201, (343, 1) = .6315057682571499, (343, 2) = .4615787151776155, (344, 1) = .6331658291, (344, 2) = .4638253825811738, (345, 1) = .6336751962287598, (345, 2) = .46408390343765954, (346, 1) = .6337940389714881, (346, 2) = .4643216081, (347, 1) = .6368083372536868, (347, 2) = .46613935889382885, (348, 1) = .6378894739173245, (348, 2) = .467839196, (349, 1) = .6390529293504151, (349, 2) = .46860947052377216, (350, 1) = .6407035176, (350, 2) = .47090538903042267, (351, 1) = .6411729686877367, (351, 2) = .47113770682074047, (352, 1) = .6412744469548372, (352, 2) = .47135678400000003, (353, 1) = .6443244310598472, (353, 2) = .4731846122950122, (354, 1) = .6453545506161649, (354, 2) = .4748743719, (355, 1) = .64654686035321, (355, 2) = .475665066530673, (356, 1) = .648241206, (356, 2) = .4780964241606354, (357, 1) = .6485547404531187, (357, 2) = .47824564372465095, (358, 1) = .6486159014391775, (358, 2) = .4783919598, (359, 1) = .6517730630078912, (359, 2) = .48026134784736546, (360, 1) = .6527275625074144, (360, 2) = .4819095478, (361, 1) = .6539889836503494, (361, 2) = .48274483951400615, (362, 1) = .6557788945, (362, 2) = .48540677089959555, (363, 1) = .6558011432731569, (363, 2) = .4854167529392525, (364, 1) = .655804895158075, (364, 2) = .4854271357, (365, 1) = .6591523462683724, (365, 2) = .4873704461722893, (366, 1) = .6600078620797836, (366, 2) = .4889447237, (367, 1) = .6613800684774144, (367, 2) = .4898484304254017, (368, 1) = .6630661423301804, (368, 2) = .4924623116, (369, 1) = .6631655196107269, (369, 2) = .49253280780125996, (370, 1) = .6633165829, (370, 2) = .49274529682446533, (371, 1) = .6664574008536912, (371, 2) = .49451418446327766, (372, 1) = .6671916688909929, (372, 2) = .4959798995, (373, 1) = .6687201033375192, (373, 2) = .4969758445718083, (374, 1) = .6702685660547512, (374, 2) = .4994974875, (375, 1) = .6705011863405904, (375, 2) = .49966226048012097, (376, 1) = .6708542713, (376, 2) = .5001774441430769, (377, 1) = .6736784716571493, (377, 2) = .5016971152583087, (378, 1) = .6742704585741014, (378, 2) = .5030150754, (379, 1) = .6760080517394262, (379, 2) = .50412756583881, (380, 1) = .677399246611721, (380, 2) = .5065326634, (381, 1) = .6777947901740559, (381, 2) = .5068113425534924, (382, 1) = .6783919598, (382, 2) = .5077201960344483, (383, 1) = .6807968774505293, (383, 2) = .5089279564028008, (384, 1) = .6812277157139974, (384, 2) = .5100502513, (385, 1) = .6832413537672619, (385, 2) = .5113047886948117, (386, 1) = .6844556297290976, (386, 2) = .5135678392, (387, 1) = .6850466625571178, (387, 2) = .5139798991760498, (388, 1) = .6859296482, (388, 2) = .5153920731517049, (389, 1) = .6877753661910225, (389, 2) = .5162240921293607, (390, 1) = .6880318827296975, (390, 2) = .5170854272000001, (391, 1) = .6904148909644026, (391, 2) = .5185099018496149, (392, 1) = .691432076216194, (392, 2) = .5206030151, (393, 1) = .6922567301232537, (393, 2) = .5211679648411685, (394, 1) = .6934673366999999, (394, 2) = .5232237897260825, (395, 1) = .6945317640609436, (395, 2) = .5236238703202625, (396, 1) = .6946196251507182, (396, 2) = .5241206031, (397, 1) = .6975187814979922, (397, 2) = .5257475167716869, (398, 1) = .698317581437037, (398, 2) = .527638191, (399, 1) = .6994243262800321, (399, 2) = .5283758504451243, (400, 1) = .7009425609360174, (400, 2) = .5311557789, (401, 1) = .7009668454087546, (401, 2) = .5311735960896531, (402, 1) = .7010050251, (402, 2) = .531235022213899, (403, 1) = .7045330536072332, (403, 2) = .5330269535591804, (404, 1) = .7050907594978423, (404, 2) = .5346733669, (405, 1) = .7065477859856253, (405, 2) = .5356043330680816, (406, 1) = .707826439370854, (406, 2) = .5381909548, (407, 1) = .7081081959007527, (407, 2) = .5383937296842604, (408, 1) = .7085427135, (408, 2) = .5391383297211966, (409, 1) = .7114127298251807, (409, 2) = .5403692018355573, (410, 1) = .7117074971453883, (410, 2) = .5417085428, (411, 1) = .7136235371248519, (411, 2) = .5428550797200062, (412, 1) = .7146400679090801, (412, 2) = .5452261307, (413, 1) = .7152171450153232, (413, 2) = .5456289839518809, (414, 1) = .716080402, (414, 2) = .5472318084850784, (415, 1) = .7180345888276969, (415, 2) = .5478317647522599, (416, 1) = .7180648234578784, (416, 2) = .5487437186, (417, 1) = .7206438027624761, (417, 2) = .5501317195290782, (418, 1) = .7213690656048836, (418, 2) = .5522613066, (419, 1) = .7222959479644129, (419, 2) = .5528783063997659, (420, 1) = .7236180904, (420, 2) = .5556142807592881, (421, 1) = .7239053069243766, (421, 2) = .5556448601244978, (422, 1) = .7238626413394168, (422, 2) = .5557788945, (423, 1) = .727589654427056, (423, 2) = .5574430859364774, (424, 1) = .7279818096371112, (424, 2) = .5592964825, (425, 1) = .7293484692190622, (425, 2) = .560139893668453, (426, 1) = .7304488507618105, (426, 2) = .5628140704, (427, 1) = .7307271473996758, (427, 2) = .5630140984296936, (428, 1) = .7311557789, (428, 2) = .5638422925589597, (429, 1) = .7344031167623684, (429, 2) = .5648162339728443, (430, 1) = .734397592924741, (430, 2) = .5663316583, (431, 1) = .7363825553752067, (431, 2) = .56741008388943, (432, 1) = .737141981461179, (432, 2) = .5698492463, (433, 1) = .737774574082815, (433, 2) = .5702780631322483, (434, 1) = .7386934673000001, (434, 2) = .5722948844201498, (435, 1) = .7407898893748043, (435, 2) = .5723885039169664, (436, 1) = .7403417330236419, (436, 2) = .5733668342, (437, 1) = .7434181560698958, (437, 2) = .5746795674198217, (438, 1) = .7437609615715551, (438, 2) = .5768844222, (439, 1) = .7448263593479074, (439, 2) = .5775399938652186, (440, 1) = .7458907583865892, (440, 2) = .5804020101, (441, 1) = .7460238544868412, (441, 2) = .5804987507109741, (442, 1) = .7462311558, (442, 2) = .5809274807500572, (443, 1) = .7505285078494064, (443, 2) = .5819141670550128, (444, 1) = .7502570823615815, (444, 2) = .583919598, (445, 1) = .7519232985586441, (445, 2) = .5847808526522201, (446, 1) = .7525801176410079, (446, 2) = .5874371860000001, (447, 1) = .7530674347922731, (447, 2) = .5877645103884115, (448, 1) = .7537688442, (448, 2) = .5894754545594193, (449, 1) = .7584052102297473, (449, 2) = .5887911364317532, (450, 1) = .7564023156361204, (450, 2) = .5909547739, (451, 1) = .7591949895306978, (451, 2) = .5919401606880849, (452, 1) = .759272894687191, (452, 2) = .5944723619, (453, 1) = .7601756102366055, (453, 2) = .5950001256665833, (454, 1) = .7610832014050026, (454, 2) = .5979899498, (455, 1) = .7611712213813305, (455, 2) = .59805309503502, (456, 1) = .7613065326, (456, 2) = .598365048803723, (457, 1) = .767397979816176, (457, 2) = .5986648623863265, (458, 1) = .7660541949332249, (458, 2) = .6015075377, (459, 1) = .7674897400218551, (459, 2) = .6021396288757908, (460, 1) = .7678552870305516, (460, 2) = .6050251257, (461, 1) = .7682732811148212, (461, 2) = .6052915643547006, (462, 1) = .7688442211, (462, 2) = .6069776370063522, (463, 1) = .7718788618065875, (463, 2) = .6050251257, (464, 1) = .7701772158845703, (464, 2) = .604403061453053, (465, 1) = .770635160312404, (465, 2) = .6015075377, (466, 1) = .7698840051758535, (466, 2) = .6010223051340272, (467, 1) = .7693019342651174, (467, 2) = .5979899498, (468, 1) = .7691335900028758, (468, 2) = .5978549109794257, (469, 1) = .7688442211, (469, 2) = .5970283535448404, (470, 1) = .7625054523889951, (470, 2) = .5974304539090726, (471, 1) = .7652436454649781, (471, 2) = .5944723619, (472, 1) = .7632377617406646, (472, 2) = .5935711216258162, (473, 1) = .7633131740612666, (473, 2) = .5909547739, (474, 1) = .7624996825719582, (474, 2) = .5903979705903055, (475, 1) = .7617545533100927, (475, 2) = .5874371860000001, (476, 1) = .7615921668021366, (476, 2) = .5873038900377399, (477, 1) = .7613065326, (477, 2) = .5865669253736254, (478, 1) = .7569338344741664, (478, 2) = .5859601905051313, (479, 1) = .7579615162167681, (479, 2) = .583919598, (480, 1) = .7559963080423406, (480, 2) = .5828801148794847, (481, 1) = .7557746899991786, (481, 2) = .5804020101, (482, 1) = .754987936365745, (482, 2) = .5798331004258871, (483, 1) = .7540704239167212, (483, 2) = .5768844222, (484, 1) = .7539627708881196, (484, 2) = .5767939230768193, (485, 1) = .7537688442, (485, 2) = .5763388147300418, (486, 1) = .749920454738908, (486, 2) = .5751627493226872, (487, 1) = .7502967109764029, (487, 2) = .5733668342, (488, 1) = .7485199994771032, (488, 2) = .5722987071567582, (489, 1) = .7480444164864417, (489, 2) = .5698492463, (490, 1) = .7473545920573336, (490, 2) = .5693249760346543, (491, 1) = .7462519616831753, (491, 2) = .5663316583, (492, 1) = .7462446452833709, (492, 2) = .566325363207796, (493, 1) = .7462311558, (493, 2) = .5662963205225036, (494, 1) = .7423910852437003, (494, 2) = .56460610329231, (495, 1) = .7423854545821322, (495, 2) = .5628140704, (496, 1) = .7408624230141795, (496, 2) = .5618018910858994, (497, 1) = .7401474389059498, (497, 2) = .5592964825, (498, 1) = .739609202013443, (498, 2) = .558869139629677, (499, 1) = .7386934673000001, (499, 2) = .5566994627265854, (500, 1) = .7373337242500462, (500, 2) = .5564134412710765, (501, 1) = .7375529280200395, (501, 2) = .5557788945, (502, 1) = .7346089216718232, (502, 2) = .5541674278823114, (503, 1) = .7342999024776851, (503, 2) = .5522613066, (504, 1) = .733062385712161, (504, 2) = .5513715567340894, (505, 1) = .7321051772528755, (505, 2) = .5487437186, (506, 1) = .7317620125548746, (506, 2) = .5484608095626671, (507, 1) = .7311557789, (507, 2) = .5471755221786071, (508, 1) = .7288972832717391, (508, 2) = .5462800953065466, (509, 1) = .7289300200295219, (509, 2) = .5452261307, (510, 1) = .7266745141310627, (510, 2) = .5437997996525366, (511, 1) = .7260795175455097, (511, 2) = .5417085428, (512, 1) = .7251468695415849, (512, 2) = .5409951125271665, (513, 1) = .7239344481102331, (513, 2) = .5381909548, (514, 1) = .7238224227793333, (514, 2) = .5380955996914517, (515, 1) = .7236180904, (515, 2) = .5377004001994169, (516, 1) = .7205798536292655, (516, 2) = .5360912107182814, (517, 1) = .7203358064748968, (517, 2) = .5346733669, (518, 1) = .7186332419606867, (518, 2) = .5334820415579187, (519, 1) = .7177465380996019, (519, 2) = .5311557789, (520, 1) = .7171343576488055, (520, 2) = .5306639329333539, (521, 1) = .716080402, (521, 2) = .5285185728725448, (522, 1) = .7150690635072785, (522, 2) = .5281101489543252, (523, 1) = .7150651474523091, (523, 2) = .527638191, (524, 1) = .7122825627912577, (524, 2) = .5258929280304899, (525, 1) = .7117254561452948, (525, 2) = .5241206031, (526, 1) = .7105078811503773, (526, 2) = .5232035248544668, (527, 1) = .709313814793679, (527, 2) = .5206030151, (528, 1) = .7090374677850002, (528, 2) = .5203721297713757, (529, 1) = .7085427135, (529, 2) = .5194599433133028, (530, 1) = .7061965922202815, (530, 2) = .5181802837909769, (531, 1) = .7059485994655371, (531, 2) = .5170854272000001, (532, 1) = .7039713812850835, (532, 2) = .5157011276154781, (533, 1) = .7030763413046126, (533, 2) = .5135678392, (534, 1) = .7023107244229887, (534, 2) = .5129585128527364, (535, 1) = .7010050251, (535, 2) = .5104631685122588, (536, 1) = .7005554626379362, (536, 2) = .510260047114437, (537, 1) = .700532426213646, (537, 2) = .5100502513, (538, 1) = .6975634682865297, (538, 2) = .5081387232371546, (539, 1) = .6969674540361994, (539, 2) = .5065326634, (540, 1) = .6956310906601928, (540, 2) = .5055229115289454, (541, 1) = .6943755773322701, (541, 2) = .5030150754, (542, 1) = .6940487375441052, (542, 2) = .5027437550076268, (543, 1) = .6934673366999999, (543, 2) = .5017356084998368, (544, 1) = .6913371583211333, (544, 2) = .5004915707246309, (545, 1) = .6910267347144636, (545, 2) = .4994974875, (546, 1) = .6890134177468648, (546, 2) = .49805839503115934, (547, 1) = .6880274190127694, (547, 2) = .4959798995, (548, 1) = .6872536468046716, (548, 2) = .49536203349619656, (549, 1) = .6859296482, (549, 2) = .49301879363440343, (550, 1) = .685365858020765, (550, 2) = .49272541368214706, (551, 1) = .6853023469688783, (551, 2) = .4924623116, (552, 1) = .682474224619088, (552, 2) = .49055725469525724, (553, 1) = .6817575115020593, (553, 2) = .4889447237, (554, 1) = .6804849100825205, (554, 2) = .48796801354594393, (555, 1) = .6790822467362455, (555, 2) = .4854271357, (556, 1) = .678834251722961, (556, 2) = .48522073280379174, (557, 1) = .6783919598, (557, 2) = .48450428140603924, (558, 1) = .6760310197132064, (558, 2) = .48301131981962253, (559, 1) = .6755781421632182, (559, 2) = .4819095478, (560, 1) = .6737471333022285, (560, 2) = .48055954551950053, (561, 1) = .6725809693019373, (561, 2) = .4783919598, (562, 1) = .6719486597541052, (562, 2) = .4778812451977635, (563, 1) = .6708542713, (563, 2) = .47609475103423465, (564, 1) = .6697009134032972, (564, 2) = .4754126055820677, (565, 1) = .6694993265551618, (565, 2) = .4748743719, (566, 1) = .6670435226254972, (566, 2) = .47313513337132346, (567, 1) = .666112911098834, (567, 2) = .47135678400000003, (568, 1) = .6650697765711803, (568, 2) = .470538626934842, (569, 1) = .6634290004731302, (569, 2) = .467839196, (570, 1) = .663388825704418, (570, 2) = .46780548269146327, (571, 1) = .6633165829, (571, 2) = .4676961942750159, (572, 1) = .6603750781831043, (572, 2) = .46569431029341324, (573, 1) = .6596771357613036, (573, 2) = .4643216081, (574, 1) = .6581969611630083, (574, 2) = .4631931769649324, (575, 1) = .6567554866881687, (575, 2) = .4608040201, (576, 1) = .6564013509925426, (576, 2) = .46051354040513176, (577, 1) = .6557788945, (577, 2) = .4595730965627197, (578, 1) = .6537397262340544, (578, 2) = .458238044039406, (579, 1) = .653269570325969, (579, 2) = .4572864322, (580, 1) = .6513281106571419, (580, 2) = .4558458767206357, (581, 1) = .6500829412056062, (581, 2) = .4537688443, (582, 1) = .6494058675855644, (582, 2) = .45322533555491956, (583, 1) = .648241206, (583, 2) = .45146938976750345, (584, 1) = .6471314835186666, (584, 2) = .45076912680306686, (585, 1) = .6468824467628159, (585, 2) = .4502512563, (586, 1) = .6444595005529137, (586, 2) = .44849846426527284, (587, 1) = .6434065207570968, (587, 2) = .4467336684, (588, 1) = .6424001139154676, (588, 2) = .44594192343477523, (589, 1) = .6407035176, (589, 2) = .4433922488286544, (590, 1) = .640539879063162, (590, 2) = .44329244505124804, (591, 1) = .6405040091082581, (591, 2) = .4432160804, (592, 1) = .6375857072618107, (592, 2) = .4411534706302463, (593, 1) = .636719683162204, (593, 2) = .4396984925, (594, 1) = .6353810440093814, (594, 2) = .43866472556188096, (595, 1) = .6337205514840445, (595, 2) = .4361809046, (596, 1) = .6335194856748709, (596, 2) = .4360158648634963, (597, 1) = .6331658291, (597, 2) = .43552130590189286, (598, 1) = .6306997544480649, (598, 2) = .4338141514637429, (599, 1) = .630014403647833, (599, 2) = .4326633166, (600, 1) = .6283449534455033, (600, 2) = .43139547065930706, (601, 1) = .626831398160579, (601, 2) = .4291457287, (602, 1) = .6263912030507452, (602, 2) = .4287896329282202, (603, 1) = .6256281407, (603, 2) = .4277318173711414, (604, 1) = .6237934249672785, (604, 2) = .42648434138338354, (605, 1) = .6232814929969428, (605, 2) = .4256281407, (606, 1) = .6212876297995694, (606, 2) = .4241361245151448, (607, 1) = .6199136766926232, (607, 2) = .4221105528, (608, 1) = .6192411383681233, (608, 2) = .4215735659317196, (609, 1) = .6180904522, (609, 2) = .41999392989842765, (610, 1) = .616857782320856, (610, 2) = .41916821084032985, (611, 1) = .6165111271613823, (611, 2) = .4185929649, (612, 1) = .6142045961622684, (612, 2) = .4168887764255166, (613, 1) = .6129619753822434, (613, 2) = .4150753769, (614, 1) = .6120668188759711, (614, 2) = .4143688178685641, (615, 1) = .6105527638, (615, 2) = .412312865809618, (616, 1) = .6098837981359486, (616, 2) = .4118699729747824, (617, 1) = .6096934239531301, (617, 2) = .411557789, (618, 1) = .6070913933803693, (618, 2) = .4096555072325644, (619, 1) = .6059709460662753, (619, 2) = .408040201, (620, 1) = .6048658222920855, (620, 2) = .4071765191219374, (621, 1) = .6030150754, (621, 2) = .40469329619235833, (622, 1) = .602863103225005, (622, 2) = .40459353344698695, (623, 1) = .6028191648435827, (623, 2) = .4045226131, (624, 1) = .5999438705289032, (624, 2) = .4024382541126821, (625, 1) = .5989355752445181, (625, 2) = .4010050252, (626, 1) = .5976358992595766, (626, 2) = .39999771942265216, (627, 1) = .5957404771292144, (627, 2) = .3974874372, (628, 1) = .5956446569324523, (628, 2) = .3974093778530017, (629, 1) = .5954773869, (629, 2) = .397197178428286, (630, 1) = .5927584434127191, (630, 2) = .39523868958685016, (631, 1) = .5918514724459307, (631, 2) = .3939698493, (632, 1) = .5903751176564264, (632, 2) = .3928333203344865, (633, 1) = .5885520206003342, (633, 2) = .3904522613, (634, 1) = .5883280361978662, (634, 2) = .39027103704202615, (635, 1) = .5879396985, (635, 2) = .3897845642725306, (636, 1) = .5855323425286143, (636, 2) = .388058106165355, (637, 1) = .5847151459560386, (637, 2) = .3869346734, (638, 1) = .583081996106934, (638, 2) = .38568401324046714, (639, 1) = .5813205236176994, (639, 2) = .3834170855, (640, 1) = .5809833455097835, (640, 2) = .3831457955928636, (641, 1) = .58040201, (641, 2) = .3824269427112342, (642, 1) = .5782637540893907, (642, 2) = .3808973502809784, (643, 1) = .5775241560912212, (643, 2) = .3798994975, (644, 1) = .5757555660659562, (644, 2) = .3785502500902252, (645, 1) = .5740446234513643, (645, 2) = .3763819096, (646, 1) = .5736101496605641, (646, 2) = .3760338564971544, (647, 1) = .5728643216, (647, 2) = .3751237128720331, (648, 1) = .5709518864082601, (648, 2) = .3737567913764426, (649, 1) = .5702772216056209, (649, 2) = .3728643216, (650, 1) = .5683954495706423, (650, 2) = .3714322073018429, (651, 1) = .5667237108415353, (651, 2) = .3693467337, (652, 1) = .5662084085110162, (652, 2) = .3689352385571988, (653, 1) = .5653266332, (653, 2) = .36787345287702866, (654, 1) = .5635969930978948, (654, 2) = .3666363111656846, (655, 1) = .5629742751203055, (655, 2) = .3658291458, (656, 1) = .5610018707510682, (656, 2) = .3643297802952932, (657, 1) = .5593579214862341, (657, 2) = .3623115578, (658, 1) = .5587784698638669, (658, 2) = .36184977939894725, (659, 1) = .5577889447, (659, 2) = .3606740064671954, (660, 1) = .5562002812612103, (660, 2) = .35953534616721994, (661, 1) = .5556163996636694, (661, 2) = .3587939699, (662, 1) = .5535756490882806, (662, 2) = .3572425865635195, (663, 1) = .5519481774786923, (663, 2) = .3552763819, (664, 1) = .5513210977851705, (664, 2) = .3547771225430924, (665, 1) = .5502512563, (665, 2) = .3535225218982832, (666, 1) = .5487638237914856, (666, 2) = .3524529291574846, (667, 1) = .548205776205795, (667, 2) = .351758794, (668, 1) = .5461181799936377, (668, 2) = .35016997500641434, (669, 1) = .544496180139183, (669, 2) = .3482412061, (670, 1) = .5438374735468877, (670, 2) = .34771671674648225, (671, 1) = .5427135678, (671, 2) = .34641553129293345, (672, 1) = .5412904328298684, (672, 2) = .3453877477678323, (673, 1) = .5407455821183196, (673, 2) = .3447236181, (674, 1) = .5386313821145924, (674, 2) = .3431110501756922, (675, 1) = .5370043558098199, (675, 2) = .3412060302, (676, 1) = .5363291734444303, (676, 2) = .3406678263003589, (677, 1) = .5351758794, (677, 2) = .33934905705466345, (678, 1) = .5337835154128445, (678, 2) = .3383382120668299, (679, 1) = .5332398612580557, (679, 2) = .3376884422, (680, 1) = .5311176601280995, (680, 2) = .33606468992432753, (681, 1) = .5294758544975693, (681, 2) = .3341708543, (682, 1) = .5287981735955245, (682, 2) = .33362952905234794, (683, 1) = .5276381909, (683, 2) = .3323186760003023, (684, 1) = .5262469554379412, (684, 2) = .331302509611936, (685, 1) = .5256934115411425, (685, 2) = .3306532664, (686, 1) = .5235798548993649, (686, 2) = .3290295685767022, (687, 1) = .5219145061356738, (687, 2) = .3271356784, (688, 1) = .5212468376963585, (688, 2) = .3266007219780744, (689, 1) = .5201005025000001, (689, 2) = .3253195784676084, (690, 1) = .5186850235658629, (690, 2) = .32427864733217493, (691, 1) = .5181117055244628, (691, 2) = .3236180905, (692, 1) = .5160212069601587, (692, 2) = .32200417379522084, (693, 1) = .5143247836090906, (693, 2) = .3201005025, (694, 1) = .5136779093293781, (694, 2) = .319580124729249, (695, 1) = .5125628141, (695, 2) = .31834660021807604, (696, 1) = .5111023195067798, (696, 2) = .31726447873058555, (697, 1) = .5105008431478002, (697, 2) = .3165829146, (698, 1) = .5084453397499787, (698, 2) = .3149868146935932, (699, 1) = .5067117899829481, (699, 2) = .3130653267, (700, 1) = .5060945113548043, (700, 2) = .3125662800096956, (701, 1) = .5050251256, (701, 2) = .31139425376022367, (702, 1) = .5035037033920832, (702, 2) = .3102577357465086, (703, 1) = .5028674645938366, (703, 2) = .3095477387, (704, 1) = .5008562487621461, (704, 2) = .3079756266466038, (705, 1) = .49908128227054965, (705, 2) = .3060301508, (706, 1) = .4985001758104025, (706, 2) = .3055575394377303, (707, 1) = .4974874372, (707, 2) = .304456676546889, (708, 1) = .4958943147128132, (708, 2) = .3032560199677323, (709, 1) = .49521878144648995, (709, 2) = .3025125628, (710, 1) = .4932583275103768, (710, 2) = .30096855938442, (711, 1) = .49143970647138974, (711, 2) = .2989949749, (712, 1) = .4908988792003061, (712, 2) = .298552047341585, (713, 1) = .4899497487, (713, 2) = .29752756673713127, (714, 1) = .48827959177296715, (714, 2) = .29625679356151713, (715, 1) = .48756259349954817, (715, 2) = .295477387, (716, 1) = .48565636950125635, (716, 2) = .2939633760049808, (717, 1) = .48379416623613464, (717, 2) = .291959799, (718, 1) = .48329505343318435, (718, 2) = .2915477355401902, (719, 1) = .4824120603, (719, 2) = .29060010572401485, (720, 1) = .48066534454485493, (720, 2) = .289257345103619, (721, 1) = .47990739947365446, (721, 2) = .2884422111, (722, 1) = .4780556794864358, (722, 2) = .2869576008322615, (723, 1) = .47615259656772946, (723, 2) = .2849246231, (724, 1) = .4756936967468298, (724, 2) = .2845422714653925, (725, 1) = .47487437180000003, (725, 2) = .28366679383246324, (726, 1) = .47305780017959376, (726, 2) = .2822547686180363, (727, 1) = .4722624051299407, (727, 2) = .2814070352, (728, 1) = .4704621014253052, (728, 2) = .27994850679648364, (729, 1) = .4685237910654614, (729, 2) = .2778894473, (730, 1) = .46810043644502464, (730, 2) = .27753302920421585, (731, 1) = .4673366834, (731, 2) = .27671924899829126, (732, 1) = .46546377749248996, (732, 2) = .2752458820767158, (733, 1) = .46463777623472186, (733, 2) = .2743718593, (734, 1) = .462882201913298, (734, 2) = .2729330294153084, (735, 1) = .4609176282518206, (735, 2) = .2708542714, (736, 1) = .46052168811302885, (736, 2) = .2705170146062497, (737, 1) = .459798995, (737, 2) = .2697479304931192, (738, 1) = .45789077658558486, (738, 2) = .26822718533516565, (739, 1) = .4570446831118084, (739, 2) = .2673366834, (740, 1) = .45532332511948964, (740, 2) = .26590774140465334, (741, 1) = .4533450939443153, (741, 2) = .2638190955, (742, 1) = .4529647331489658, (742, 2) = .26349082973670407, (743, 1) = .4522613065, (743, 2) = .26274186058939175, (744, 1) = .45034718990228606, (744, 2) = .26119476200718766, (745, 1) = .4494955971073297, (745, 2) = .2603015076, (746, 1) = .4477938652157189, (746, 2) = .258868725580079, (747, 1) = .4458186726999408, (747, 2) = .2567839196, (748, 1) = .44543801222302604, (748, 2) = .2564505356778167, (749, 1) = .4447236181, (749, 2) = .2556880681641911, (750, 1) = .4428425490702933, (750, 2) = .2541441638972261, (751, 1) = .44200453441815535, (751, 2) = .2532663317, (752, 1) = .4403034553215288, (752, 2) = .2518114863495001, (753, 1) = .4383524930074799, (753, 2) = .2497487437, (754, 1) = .4379513052215547, (754, 2) = .24939156841671048, (755, 1) = .4371859296, (755, 2) = .24857107563014877, (756, 1) = .4353877964736239, (756, 2) = .24707028458753777, (757, 1) = .4345873846928278, (757, 2) = .2462311558, (758, 1) = .43286326512169326, (758, 2) = .24473081131174035, (759, 1) = .4309626518773221, (759, 2) = .2427135679, (760, 1) = .43051604146422656, (760, 2) = .2423085944341507, (761, 1) = .4296482412, (761, 2) = .24137212881002684, (762, 1) = .4279956301622233, (762, 2) = .23996719840183553, (763, 1) = .42726228438416436, (763, 2) = .2391959799, (764, 1) = .4254864014928762, (764, 2) = .23762058385228169, (765, 1) = .4236677223513047, (765, 2) = .235678392, (766, 1) = .42314575835299, (766, 2) = .23519529606428433, (767, 1) = .4221105528, (767, 2) = .23406808191854572, (768, 1) = .4206809764038216, (768, 2) = .23282793965787185, (769, 1) = .42005011927364955, (769, 2) = .232160804, (770, 1) = .41818835035804597, (770, 2) = .23047357720488884, (771, 1) = .4164891423916891, (771, 2) = .2286432161, (772, 1) = .41585654734415745, (772, 2) = .22804416402407998, (773, 1) = .4145728643, (773, 2) = .22663005384130125, (774, 1) = .4134615419041726, (774, 2) = .22564424531510408, (775, 1) = .4129751290419361, (775, 2) = .2251256282, (776, 1) = .41098762195120536, (776, 2) = .22328115333415552, (777, 1) = .409451948899132, (777, 2) = .2216080402, (778, 1) = .40866775863832683, (778, 2) = .22084616825977926, (779, 1) = .4070351759, (779, 2) = .21902147969544994, (780, 1) = .40635849858888623, (780, 2) = .2184062350392016, (781, 1) = .40606557138981003, (781, 2) = .2180904523, (782, 1) = .40390643609215177, (782, 2) = .21603294289083183, (783, 1) = .4025853816638798, (783, 2) = .2145728643, (784, 1) = .40160277314883797, (784, 2) = .21359039763582902, (785, 1) = .3994974874, (785, 2) = .2111953916267515, (786, 1) = .3993974872014272, (786, 2) = .21110194315906863, (787, 1) = .3993548061582575, (787, 2) = .2110552764, (788, 1) = .3969718915680006, (788, 2) = .20871629988156515, (789, 1) = .3959241588145738, (789, 2) = .2075376885, (790, 1) = .39469021826668604, (790, 2) = .20626349281323436, (791, 1) = .39275962858671026, (791, 2) = .2040201005, (792, 1) = .392519651602392, (792, 2) = .20375883595370253, (793, 1) = .391959799, (793, 2) = .20308410518162512, (794, 1) = .39021706301913595, (794, 2) = .20131578937565633, (795, 1) = .38950935111294255, (795, 2) = .2005025126, (796, 1) = .38796528144486087, (796, 2) = .1988490328100629, (797, 1) = .3864011183684566, (797, 2) = .1969849246, (798, 1) = .38582386658866763, (798, 2) = .19633077177101954, (799, 1) = .3844221105, (799, 2) = .19459086094504696, (800, 1) = .3836829143299022, (800, 2) = .193812294910751, (801, 1) = .3833902777843438, (801, 2) = .1934673367, (802, 1) = .381471712002041, (802, 2) = .1913266014245525, (803, 1) = .38035036929423216, (803, 2) = .1899497488, (804, 1) = .3793717347632515, (804, 2) = .18878900286408398, (805, 1) = .3775375943541058, (805, 2) = .1864321608, (806, 1) = .37736166644215346, (806, 2) = .18620944677492798, (807, 1) = .3768844221, (807, 2) = .18556448319466476, (808, 1) = .37526450636538733, (808, 2) = .18367053357185437, (809, 1) = .37467008495738585, (809, 2) = .1829145729, (810, 1) = .3732225171948196, (810, 2) = .1811058738946159, (811, 1) = .3719455222249287, (811, 2) = .1793969849, (812, 1) = .37127502391601463, (812, 2) = .1784971161376429, (813, 1) = .3694265308925138, (813, 2) = .175879397, (814, 1) = .36940710803346855, (814, 2) = .17585122231120817, (815, 1) = .3693467337, (815, 2) = .17576016082628151, (816, 1) = .3674517163812426, (816, 2) = .17324615049865977, (817, 1) = .36682165777307724, (817, 2) = .1723618091, (818, 1) = .36559224125493306, (818, 2) = .1705963175909678, (819, 1) = .36442118216746267, (819, 2) = .1688442211, (820, 1) = .3638217120726433, (820, 2) = .16790497657723402, (821, 1) = .36221745198925714, (821, 2) = .1653266332, (822, 1) = .3621305321083684, (822, 2) = .16517660597467304, (823, 1) = .3618090452, (823, 2) = .16461658191612735, (824, 1) = .36042004933611393, (824, 2) = .1624572432845554, (825, 1) = .36001413241598124, (825, 2) = .1618090452, (826, 1) = .35878654053790004, (826, 2) = .1597019594676269, (827, 1) = .35797284794656337, (827, 2) = .1582914573, (828, 1) = .3572489110137369, (828, 2) = .15690193200815655, (829, 1) = .35613069273590464, (829, 2) = .1547738694, (830, 1) = .35580307897280694, (830, 2) = .15405906570310007, (831, 1) = .35448015596563326, (831, 2) = .1512562814, (832, 1) = .35444769995839687, (832, 2) = .15117398792654935, (833, 1) = .3542713568, (833, 2) = .15075051674419104, (834, 1) = .35313609511999666, (834, 2) = .14826848227396078, (835, 1) = .3528862293167243, (835, 2) = .1477386935, (836, 1) = .3519356554209787, (836, 2) = .14531109948720555, (837, 1) = .3514838197463479, (837, 2) = .1442211055, (838, 1) = .3508593758497697, (838, 2) = .14229577534659707, (839, 1) = .3502938221071534, (839, 2) = .1407035176, (840, 1) = .34991447247732055, (840, 2) = .13921914234538285, (841, 1) = .34931756648448753, (841, 2) = .1371859297, (842, 1) = .34911207147452883, (842, 2) = .1360760082080354, (843, 1) = .3485591799566558, (843, 2) = .1336683417, (844, 1) = .34846783507255363, (844, 2) = .13285906388814606, (845, 1) = .3480257881214767, (845, 2) = .1301507538, (846, 1) = .34800289002801055, (846, 2) = .12955845032131563, (847, 1) = .3477271310309451, (847, 2) = .1266331658, (848, 1) = .34774494448408766, (848, 2) = .1261612369230366, (849, 1) = .34767622997613645, (849, 2) = .1231155779, (850, 1) = .3477303651018057, (850, 2) = .12265045273463923, (851, 1) = .34788888406570395, (851, 2) = .11959799, (852, 1) = .3480062614091848, (852, 2) = .11900411321008608, (853, 1) = .34838511373913356, (853, 2) = .116080402, (854, 1) = .34863491884857173, (854, 2) = .11519315176081538, (855, 1) = .34918839173015104, (855, 2) = .1125628141, (856, 1) = .3496982391676152, (856, 2) = .11117934768200291, (857, 1) = .3503275726503486, (857, 2) = .1090452261, (858, 1) = .35130638070456277, (858, 2) = .10691129368498048, (859, 1) = .3518364954202148, (859, 2) = .1055276382, (860, 1) = .35360882560815554, (860, 2) = .10231923151700102, (861, 1) = .3537558522159866, (861, 2) = .1020100503, (862, 1) = .3542713568, (862, 2) = .10121702392963003, (863, 1) = .35600053248665653, (863, 2) = 0.9849246232e-1, (864, 1) = .3570572854492312, (864, 2) = 0.971923622763001e-1, (865, 1) = .3586926055897353, (865, 2) = 0.9497487438e-1, (866, 1) = .3618090452, (866, 2) = 0.9158716902677788e-1, (867, 1) = .36192709856954863, (867, 2) = 0.9145728644e-1, (868, 1) = .36205005931326456, (868, 2) = 0.9134481318799587e-1, (869, 1) = .3655390548364391, (869, 2) = 0.879396985e-1, (870, 1) = .3693467337, (870, 2) = 0.8479882969331587e-1, (871, 1) = .3698033059098153, (871, 2) = 0.8442211056e-1, (872, 1) = .3706635536566944, (872, 2) = 0.8380759457671531e-1, (873, 1) = .3745661678736847, (873, 2) = 0.8090452262e-1, (874, 1) = .3768844221, (874, 2) = 0.7939356176205672e-1, (875, 1) = .3799996782143442, (875, 2) = 0.7738693467999999e-1, (876, 1) = .3844221105, (876, 2) = 0.7484642389505781e-1, (877, 1) = .3861556705887529, (877, 2) = 0.7386934674000001e-1, (878, 1) = .391959799, (878, 2) = 0.7090689451692438e-1, (879, 1) = .3930765595362171, (879, 2) = 0.703517588e-1, (880, 1) = .3994974874, (880, 2) = 0.6742285625731652e-1, (881, 1) = .40083272374395407, (881, 2) = 0.6683417086e-1, (882, 1) = .4070351759, (882, 2) = 0.6429437718838504e-1, (883, 1) = .40952543844393996, (883, 2) = 0.6331658292e-1, (884, 1) = .4145728643, (884, 2) = 0.6145535700961236e-1, (885, 1) = .4192968081098093, (885, 2) = 0.59798994980000006e-1, (886, 1) = .4221105528, (886, 2) = 0.58862877992759986e-1, (887, 1) = .4282230450362326, (887, 2) = 0.56946498586872965e-1, (888, 1) = .4296482412, (888, 2) = 0.5648318909637347e-1, (889, 1) = .4303077493632227, (889, 2) = 0.56281407039999995e-1, (890, 1) = .4371859296, (890, 2) = 0.54259072419220275e-1, (891, 1) = .44264178968086776, (891, 2) = 0.527638191e-1, (892, 1) = .4447236181, (892, 2) = 0.52210303355024364e-1, (893, 1) = .4472230956927635, (893, 2) = 0.515973962167451e-1, (894, 1) = .4522613065, (894, 2) = 0.50284417107303435e-1, (895, 1) = .45658545521222793, (895, 2) = 0.4924623116e-1, (896, 1) = .459798995, (896, 2) = 0.4848899261063059e-1, (897, 1) = .46280252505544006, (897, 2) = 0.4784458379282528e-1, (898, 1) = .4673366834, (898, 2) = 0.46795889980450964e-1, (899, 1) = .47240959498250634, (899, 2) = 0.4572864322e-1, (900, 1) = .47487437180000003, (900, 2) = 0.4521380652728622e-1, (901, 1) = .4767185263750812, (901, 2) = 0.44868037758152964e-1, (902, 1) = .4824120603, (902, 2) = 0.4369939046343149e-1, (903, 1) = .48959308784095523, (903, 2) = 0.4237749701516724e-1, (904, 1) = .4899497487, (904, 2) = 0.4230553368836941e-1, (905, 1) = .49047231758269894, (905, 2) = 0.4221105528e-1, (906, 1) = .4974874372, (906, 2) = 0.4093529701697809e-1, (907, 1) = .5016543282464547, (907, 2) = 0.4026650611393161e-1, (908, 1) = .5050251256, (908, 2) = 0.396633456864977e-1, (909, 1) = .5111714689337563, (909, 2) = 0.3869346734e-1, (910, 1) = .5125628141, (910, 2) = 0.3846993033295939e-1, (911, 1) = .5132454260727137, (911, 2) = 0.3837491508425573e-1, (912, 1) = .5201005025000001, (912, 2) = 0.3729037232594075e-1, (913, 1) = .5243561999220785, (913, 2) = 0.3670747519840497e-1, (914, 1) = .5276381909, (914, 2) = 0.361960293284916e-1, (915, 1) = .5351639749169139, (915, 2) = 0.35181434825398046e-1, (916, 1) = .5351758794, (916, 2) = 0.3517960712411226e-1, (917, 1) = .5352039640893407, (917, 2) = 0.351758794e-1, (918, 1) = .5427135678, (918, 2) = 0.3414537152140694e-1, (919, 1) = .5456536286452462, (919, 2) = 0.3380385101595303e-1, (920, 1) = .5502512563, (920, 2) = 0.3318185834638168e-1, (921, 1) = .5559125375649836, (921, 2) = 0.32533948127986365e-1, (922, 1) = .5577889447, (922, 2) = 0.32283633189427896e-1, (923, 1) = .5633336520075796, (923, 2) = 0.3165829146e-1, (924, 1) = .5653266332, (924, 2) = 0.3142227202497525e-1, (925, 1) = .565966100123562, (925, 2) = 0.31359873560641016e-1, (926, 1) = .5728643216, (926, 2) = 0.305538817413697e-1, (927, 1) = .5758455924285844, (927, 2) = 0.30267031732083685e-1, (928, 1) = .58040201, (928, 2) = 0.29741684432756765e-1, (929, 1) = .5855573291499552, (929, 2) = 0.29252475874925958e-1, (930, 1) = .5879396985, (930, 2) = 0.2898136940407693e-1, (931, 1) = .595115285505753, (931, 2) = 0.283096841716094e-1, (932, 1) = .5954773869, (932, 2) = 0.28269007546813177e-1, (933, 1) = .5968666341939834, (933, 2) = 0.2814070352e-1, (934, 1) = .6030150754, (934, 2) = 0.2753280844868558e-1, (935, 1) = .6045819714386098, (935, 2) = 0.2740948536449127e-1, (936, 1) = .6105527638, (936, 2) = 0.26826477584338135e-1, (937, 1) = .6139314406005736, (937, 2) = 0.2656398767076758e-1, (938, 1) = .6180904522, (938, 2) = 0.26162862729445055e-1, (939, 1) = .6231622868236661, (939, 2) = 0.2577384738023213e-1, (940, 1) = .6256281407, (940, 2) = 0.2553889994482989e-1, (941, 1) = .6322835703619627, (941, 2) = 0.25034836326758337e-1, (942, 1) = .6331658291, (942, 2) = 0.24951778970738848e-1, (943, 1) = .6375598731700047, (943, 2) = 0.2462311558e-1, (944, 1) = .6407035176, (944, 2) = 0.24365645583709933e-1, (945, 1) = .6413404044011137, (945, 2) = 0.24325901737790392e-1, (946, 1) = .648241206, (946, 2) = 0.2376726243192491e-1, (947, 1) = .650354354409826, (947, 2) = 0.2363697966289041e-1, (948, 1) = .6557788945, (948, 2) = 0.23202876747452174e-1, (949, 1) = .6592792159444876, (949, 2) = 0.22989632229951592e-1, (950, 1) = .6633165829, (950, 2) = 0.22670196423136894e-1, (951, 1) = .6681212854119927, (951, 2) = 0.223809210616549e-1, (952, 1) = .6708542713, (952, 2) = 0.22167107750822528e-1, (953, 1) = .6768863475434768, (953, 2) = 0.21808146687717637e-1, (954, 1) = .6783919598, (954, 2) = 0.21691659655115058e-1, (955, 1) = .6855797218834964, (955, 2) = 0.2126882658863016e-1, (956, 1) = .6859296482, (956, 2) = 0.21242049584500284e-1, (957, 1) = .6882769815080421, (957, 2) = 0.2110552764e-1, (958, 1) = .6934673366999999, (958, 2) = 0.20765257463606517e-1, (959, 1) = .6942782870063637, (959, 2) = 0.20727084161545162e-1, (960, 1) = .7010050251, (960, 2) = 0.2029078959933281e-1, (961, 1) = .7029443560795692, (961, 2) = 0.2020050651105533e-1, (962, 1) = .7085427135, (962, 2) = 0.19841225711516006e-1, (963, 1) = .7115485178221507, (963, 2) = 0.19702818966963537e-1, (964, 1) = .716080402, (964, 2) = 0.1941501363032748e-1, (965, 1) = .7200947644244649, (965, 2) = 0.1923215849793163e-1, (966, 1) = .7236180904, (966, 2) = 0.19010712863990607e-1, (967, 1) = .7285867916455377, (967, 2) = 0.18786800409660548e-1, (968, 1) = .7311557789, (968, 2) = 0.18626985602721843e-1, (969, 1) = .7370280236098778, (969, 2) = 0.1836514675980933e-1, (970, 1) = .7386934673000001, (970, 2) = 0.1826258831020113e-1, (971, 1) = .7454216355278264, (971, 2) = 0.17965715824150474e-1, (972, 1) = .7462311558, (972, 2) = 0.17916364329992548e-1, (973, 1) = .7537520904730234, (973, 2) = 0.175879397e-1, (974, 1) = .7537688442, (974, 2) = 0.1758708291517289e-1, (975, 1) = .7537708232711489, (975, 2) = 0.1758701613345861e-1, (976, 1) = .7613065326, (976, 2) = 0.17205408105431967e-1, (977, 1) = .762189441390788, (977, 2) = 0.17175915600755754e-1, (978, 1) = .7688442211, (978, 2) = 0.16842180636616112e-1, (979, 1) = .7705641600195864, (979, 2) = 0.16785301532962777e-1, (980, 1) = .7763819095, (980, 2) = 0.16496341045990695e-1, (981, 1) = .7788975599900472, (981, 2) = 0.16413969480211094e-1, (982, 1) = .783919598, (982, 2) = 0.161669001252912e-1, (983, 1) = .7871920474477319, (983, 2) = 0.16060796615708868e-1, (984, 1) = .7914572864, (984, 2) = 0.15852933714335812e-1, (985, 1) = .7954498668852796, (985, 2) = 0.15724735487661082e-1, (986, 1) = .7989949749, (986, 2) = 0.15553577831292395e-1, (987, 1) = .8036731134194652, (987, 2) = 0.15404808378503531e-1, (988, 1) = .8065326633000001, (988, 2) = 0.1526802429009741e-1, (989, 1) = .8118637441392688, (989, 2) = 0.15100101960862838e-1, (990, 1) = .8140703517000001, (990, 2) = 0.14995516542107262e-1, (991, 1) = .820023588478201, (991, 2) = 0.14809762557900735e-1, (992, 1) = .8216080402, (992, 2) = 0.14735345990338197e-1, (993, 1) = .828154357305367, (993, 2) = 0.14532991700125845e-1, (994, 1) = .8291457286, (994, 2) = 0.14486848543279984e-1, (995, 1) = .8362576521039642, (995, 2) = 0.14269042089977133e-1, (996, 1) = .8366834170999999, (996, 2) = 0.1424940141519132e-1, (997, 1) = .8425838567082613, (997, 2) = 0.1407035176e-1, (998, 1) = .8442211055, (998, 2) = 0.14008820617902599e-1, (999, 1) = .8443593944967582, (999, 2) = 0.14005816894479228e-1, (1000, 1) = .8517587939, (1000, 2) = 0.137301598694701e-1, (1001, 1) = .8525230281459295, (1001, 2) = 0.13713709114603212e-1, (1002, 1) = .8592964824, (1002, 2) = 0.13463554679394443e-1, (1003, 1) = .8606590540865626, (1003, 2) = 0.1343448496932211e-1, (1004, 1) = .8668341708, (1004, 2) = 0.1320838470286819e-1, (1005, 1) = .8687689137120126, (1005, 2) = 0.13167471741238845e-1, (1006, 1) = .8743718593, (1006, 2) = 0.12964066476802675e-1, (1007, 1) = .87685396181245, (1007, 2) = 0.12912037247604214e-1, (1008, 1) = .8819095477, (1008, 2) = 0.12730051028875658e-1, (1009, 1) = .8849154718718103, (1009, 2) = 0.12667587157122835e-1, (1010, 1) = .8894472362, (1010, 2) = 0.12505821439256576e-1, (1011, 1) = .8929546421108857, (1011, 2) = 0.1243356232561369e-1, (1012, 1) = .8969849246, (1012, 2) = 0.12290890824841728e-1, (1013, 1) = .9009726001279909, (1013, 2) = 0.1220943650302366e-1, (1014, 1) = .904522613, (1014, 2) = 0.12084800358004747e-1, (1015, 1) = .9089704079143057, (1015, 2) = 0.11994714149059275e-1, (1016, 1) = .9120603015, (1016, 2) = 0.11887117334707719e-1, (1017, 1) = .9169490659352877, (1017, 2) = 0.11788928343894226e-1, (1018, 1) = .9195979899, (1018, 2) = 0.11697433621062113e-1, (1019, 1) = .9249095173296698, (1019, 2) = 0.11591638978278456e-1, (1020, 1) = .9271356784, (1020, 2) = 0.11515363969705617e-1, (1021, 1) = .9328526515029625, (1021, 2) = 0.11402430963448429e-1, (1022, 1) = .9346733668, (1022, 2) = 0.11340544619749256e-1, (1023, 1) = .9407793076969329, (1023, 2) = 0.11220912658563596e-1, (1024, 1) = .9422110552, (1024, 2) = 0.1117263192432869e-1, (1025, 1) = .9486902783114621, (1025, 2) = 0.11046714330906418e-1, (1026, 1) = .9497487437000001, (1026, 2) = 0.1101130107700609e-1, (1027, 1) = .9565863114418658, (1027, 2) = 0.10879486795653657e-1, (1028, 1) = .9572864321, (1028, 2) = 0.10856244955774159e-1, (1029, 1) = .9644681142626971, (1029, 2) = 0.10718900109481845e-1, (1030, 1) = .9648241206, (1030, 2) = 0.10707173025501376e-1, (1031, 1) = .9723363549339009, (1031, 2) = 0.10564642384247074e-1, (1032, 1) = .972361809, (1032, 2) = 0.10563810333045955e-1, (1033, 1) = .972948630488885, (1033, 2) = 0.1055276382e-1, (1034, 1) = .9798994975, (1034, 2) = 0.10375296743919172e-1, (1035, 1) = .9802894902052824, (1035, 2) = 0.10370767223166771e-1, (1036, 1) = .9874371859, (1036, 2) = 0.10189649970835095e-1, (1037, 1) = .9882349895451341, (1037, 2) = 0.10180455450153872e-1, (1038, 1) = .9949748743, (1038, 2) = 0.10010949173809373e-1, (1039, 1) = .9961650738976088, (1039, 2) = 0.999733736006387e-2, (1040, 1) = 1.002512563, (1040, 2) = 0.9838884859509671e-2, (1041, 1) = 1.0040804354592772, (1041, 2) = 0.982108996268309e-2, (1042, 1) = 1.010050251, (1042, 2) = 0.9673163544900765e-2, (1043, 1) = 1.0119817298630203, (1043, 2) = 0.9651407083880376e-2, (1044, 1) = 1.01758794, (1044, 2) = 0.9513506697126249e-2, (1045, 1) = 1.019869580330979, (1045, 2) = 0.9487998269652366e-2, (1046, 1) = 1.025125628, (1046, 2) = 0.9359650041939265e-2, (1047, 1) = 1.0277445763542137, (1047, 2) = 0.9330588011703222e-2, (1048, 1) = 1.032663317, (1048, 2) = 0.9211342550790206e-2, (1049, 1) = 1.0356072791518431, (1049, 2) = 0.9178914735089576e-2, (1050, 1) = 1.040201005, (1050, 2) = 0.9068345848323164e-2, (1051, 1) = 1.0434582198901152, (1051, 2) = 0.9032730115307322e-2, (1052, 1) = 1.047738693, (1052, 2) = 0.8930433399104435e-2, (1053, 1) = 1.0512979052007219, (1053, 2) = 0.8891798249098935e-2, (1054, 1) = 1.055276382, (1054, 2) = 0.8797389809478761e-2, (1055, 1) = 1.0591268151015514, (1055, 2) = 0.8755894933705672e-2, (1056, 1) = 1.06281407, (1056, 2) = 0.8669010341211997e-2, (1057, 1) = 1.0669454061442312, (1057, 2) = 0.8624807095195669e-2, (1058, 1) = 1.070351759, (1058, 2) = 0.8545100142396437e-2, (1059, 1) = 1.0747541125000146, (1059, 2) = 0.849833206595714e-2, (1060, 1) = 1.077889447, (1060, 2) = 0.8425473873461183e-2, (1061, 1) = 1.0825533475002227, (1061, 2) = 0.8376277080769497e-2, (1062, 1) = 1.085427136, (1062, 2) = 0.8309955025592194e-2, (1063, 1) = 1.0903435038637583, (1063, 2) = 0.825845868211691e-2, (1064, 1) = 1.092964824, (1064, 2) = 0.8198375587480662e-2, (1065, 1) = 1.098124956361655, (1065, 2) = 0.8144702229217713e-2, (1066, 1) = 1.100502513, (1066, 2) = 0.8090575419868377e-2, (1067, 1) = 1.1058980607216682, (1067, 2) = 0.8034841401954203e-2, (1068, 1) = 1.108040201, (1068, 2) = 0.7986402020879288e-2, (1069, 1) = 1.1136631564424686, (1069, 2) = 0.7928717792678995e-2, (1070, 1) = 1.115577889, (1070, 2) = 0.7885709958806586e-2, (1071, 1) = 1.12142056817452, (1071, 2) = 0.7826180406757498e-2, (1072, 1) = 1.123115578, (1072, 2) = 0.7788360554924944e-2, (1073, 1) = 1.1291706029325228, (1073, 2) = 0.7727085352140572e-2, (1074, 1) = 1.130653266, (1074, 2) = 0.7694221588903191e-2, (1075, 1) = 1.136913555945145, (1075, 2) = 0.763129539487053e-2, (1076, 1) = 1.138190955, (1076, 2) = 0.76031668339430775e-2, (1077, 1) = 1.144649706412218, (1077, 2) = 0.7538679650546904e-2, (1078, 1) = 1.145728643, (1078, 2) = 0.75150758714770905e-2, (1079, 1) = 1.1523793233660806, (1079, 2) = 0.7449113211899923e-2, (1080, 1) = 1.153266332, (1080, 2) = 0.742983367651974e-2, (1081, 1) = 1.1601026607210896, (1081, 2) = 0.7362476896054679e-2, (1082, 1) = 1.16080402, (1082, 2) = 0.7347330459511903e-2, (1083, 1) = 1.1678199639698905, (1083, 2) = 0.7278656876054324e-2, (1084, 1) = 1.168341709, (1084, 2) = 0.72674612771414715e-2, (1085, 1) = 1.1755314643121628, (1085, 2) = 0.7197544477196978e-2, (1086, 1) = 1.175879397, (1086, 2) = 0.7190125892962781e-2, (1087, 1) = 1.1832373850662354, (1087, 2) = 0.71190358540171176e-2, (1088, 1) = 1.183417085, (1088, 2) = 0.71152284588298234e-2, (1089, 1) = 1.1909379399404183, (1089, 2) = 0.7043031773890721e-2, (1090, 1) = 1.190954774, (1090, 2) = 0.7042677335802723e-2, (1091, 1) = 1.1917412351176269, (1091, 2) = 0.7035175879999999e-2, (1092, 1) = 1.198492462, (1092, 2) = 0.6930572699126082e-2, (1093, 1) = 1.1987185238181046, (1093, 2) = 0.69296803726821305e-2, (1094, 1) = 1.206030151, (1094, 2) = 0.6817094642930465e-2, (1095, 1) = 1.2065014290735379, (1095, 2) = 0.681524609942756e-2, (1096, 1) = 1.213567839, (1096, 2) = 0.6707104748696734e-2, (1097, 1) = 1.214276769996557, (1097, 2) = 0.67043414393934e-2, (1098, 1) = 1.221105528, (1098, 2) = 0.660047513151033e-2, (1099, 1) = 1.2220448262760126, (1099, 2) = 0.659683665877399e-2, (1100, 1) = 1.228643216, (1100, 2) = 0.6497083404960625e-2, (1101, 1) = 1.2298058622217876, (1101, 2) = 0.6492607611288709e-2, (1102, 1) = 1.236180904, (1102, 2) = 0.6396812289077833e-2, (1103, 1) = 1.2375601338214697, (1103, 2) = 0.639153534422181e-2, (1104, 1) = 1.243718593, (1104, 2) = 0.6299549430507505e-2, (1105, 1) = 1.2453078856874127, (1105, 2) = 0.6293505915632566e-2, (1106, 1) = 1.251256281, (1106, 2) = 0.6205187243968288e-2, (1107, 1) = 1.2530493503958227, (1107, 2) = 0.6198410223798384e-2, (1108, 1) = 1.25879397, (1108, 2) = 0.6113622509922266e-2, (1109, 1) = 1.2607847533153351, (1109, 2) = 0.6106143611594024e-2, (1110, 1) = 1.266331658, (1110, 2) = 0.6024756333067465e-2, (1111, 1) = 1.268514308313239, (1111, 2) = 0.601660580910859e-2, (1112, 1) = 1.273869347, (1112, 2) = 0.5938493832349033e-2, (1113, 1) = 1.2762382223896214, (1113, 2) = 0.59297006332274076e-2, (1114, 1) = 1.281407035, (1114, 2) = 0.58547440350789695e-2, (1115, 1) = 1.283956692368622, (1115, 2) = 0.5845335862589219e-2, (1116, 1) = 1.288944724, (1116, 2) = 0.5773419610608419e-2, (1117, 1) = 1.2916699086100987, (1117, 2) = 0.5763422987235457e-2, (1118, 1) = 1.296482412, (1118, 2) = 0.5694436786844592e-2, (1119, 1) = 1.299378052070196, (1119, 2) = 0.5683877101183213e-2, (1120, 1) = 1.3040201, (1120, 2) = 0.5617715132353588e-2, (1121, 1) = 1.307081298478856, (1121, 2) = 0.5606616695458106e-2, (1122, 1) = 1.311557789, (1122, 2) = 0.5543177397281742e-2, (1123, 1) = 1.314779815340327, (1123, 2) = 0.55315634995066285e-2, (1124, 1) = 1.319095477, (1124, 2) = 0.5470749445679901e-2, (1125, 1) = 1.3224737632974548, (1125, 2) = 0.5458642391049434e-2, (1126, 1) = 1.326633166, (1126, 2) = 0.540036000120043e-2, (1127, 1) = 1.3301632973227266, (1127, 2) = 0.53877811659392184e-2, (1128, 1) = 1.334170854, (1128, 2) = 0.5331940629590904e-2, (1129, 1) = 1.3378485658135628, (1129, 2) = 0.53189104938605476e-2, (1130, 1) = 1.341708543, (1130, 2) = 0.5265425527342091e-2, (1131, 1) = 1.3455297116798746, (1131, 2) = 0.5251963724623916e-2, (1132, 1) = 1.349246231, (1132, 2) = 0.5200751470099699e-2, (1133, 1) = 1.3532068721423451, (1133, 2) = 0.5186876816854617e-2, (1134, 1) = 1.35678392, (1134, 2) = 0.513785764049644e-2, (1135, 1) = 1.3608801791070615, (1135, 2) = 0.5123588184394362e-2, (1136, 1) = 1.364321608, (1136, 2) = 0.5076685573683551e-2, (1137, 1) = 1.3685497590319484, (1137, 2) = 0.5062038615830922e-2, (1138, 1) = 1.371859296, (1138, 2) = 0.50171790218632795e-2, (1139, 1) = 1.3762157350164028, (1139, 2) = 0.500217115594679e-2, (1140, 1) = 1.379396985, (1140, 2) = 0.4959283859897053e-2, (1141, 1) = 1.383878223746966, (1141, 2) = 0.49439310085502754e-2, (1142, 1) = 1.386934673, (1142, 2) = 0.4902948031323432e-2, (1143, 1) = 1.3915373385162417, (1143, 2) = 0.48872654645150965e-2, (1144, 1) = 1.394472362, (1144, 2) = 0.4848121398297026e-2, (1145, 1) = 1.399193187662768, (1145, 2) = 0.4832123774606931e-2, (1146, 1) = 1.40201005, (1146, 2) = 0.4794755721534188e-2, (1147, 1) = 1.4068458763116132, (1147, 2) = 0.477845710138426e-2, (1148, 1) = 1.409547739, (1148, 2) = 0.474280452752723e-2, (1149, 1) = 1.414495504702633, (1149, 2) = 0.4726218416447846e-2, (1150, 1) = 1.417085427, (1150, 2) = 0.4692223081836024e-2, (1151, 1) = 1.422142170476746, (1151, 2) = 0.46753624319423905e-2, (1152, 1) = 1.424623116, (1152, 2) = 0.4642968265171549e-2, (1153, 1) = 1.4297859664576211, (1153, 2) = 0.46258455248896204e-2, (1154, 1) = 1.432160804, (1154, 2) = 0.4594998559349632e-2, (1155, 1) = 1.437426982704413, (1155, 2) = 0.45776256735536765e-2, (1156, 1) = 1.439698492, (1156, 2) = 0.45482739392615785e-2, (1157, 1) = 1.4450653070434634, (1157, 2) = 0.45306623781697156e-2, (1158, 1) = 1.447236181, (1158, 2) = 0.4502755819620253e-2, (1159, 1) = 1.452701021972946, (1159, 2) = 0.44849166094580745e-2, (1160, 1) = 1.454773869, (1160, 2) = 0.4458407028562616e-2, (1161, 1) = 1.4603342089784799, (1161, 2) = 0.4440350748504083e-2, (1162, 1) = 1.462311558, (1162, 2) = 0.441519169049109e-2, (1163, 1) = 1.4679649448741687, (1163, 2) = 0.4396928517051396e-2, (1164, 1) = 1.469849246, (1164, 2) = 0.4373075238167609e-2, (1165, 1) = 1.475593305588006, (1165, 2) = 0.43546149370622626e-2, (1166, 1) = 1.477386935, (1166, 2) = 0.4332024301478836e-2, (1167, 1) = 1.4832193623974281, (1167, 2) = 0.43133762679546e-2, (1168, 1) = 1.484924623, (1168, 2) = 0.4292006710999836e-2, (1169, 1) = 1.4908431861151392, (1169, 2) = 0.4273179963752635e-2, (1170, 1) = 1.492462312, (1170, 2) = 0.4252991400793571e-2, (1171, 1) = 1.4984648429204566, (1171, 2) = 0.4233994619210856e-2, (1172, 1) = 1.5, (1172, 2) = 0.4214948412973115e-2, (1173, 1) = 15.0, (1173, 2) = .0, (1174, 1) = .7763819095, (1174, 2) = .607778751889855, (1175, 1) = .7765917979042034, (1175, 2) = .6084447656798948, (1176, 1) = .7767164064919965, (1176, 2) = .6085427136, (1177, 1) = .7771436112395627, (1177, 2) = .6117048407848357, (1178, 1) = .7777259884990406, (1178, 2) = .6120603016, (1179, 1) = .7767494783952099, (1179, 2) = .6154063573521529, (1180, 1) = .7773546337016262, (1180, 2) = .6155778894999999, (1181, 1) = .7763819095, (1181, 2) = .615964402185334, (1182, 1) = .7762628509681525, (1182, 2) = .6156334501478794, (1183, 1) = .7761810796799455, (1183, 2) = .6155778894999999, (1184, 1) = .7755991837432397, (1184, 2) = .6124255736177447, (1185, 1) = .7748754415956448, (1185, 2) = .6120603016, (1186, 1) = .775676891794233, (1186, 2) = .6088717218701738, (1187, 1) = .7738241995201303, (1187, 2) = .6085427136, (1188, 1) = .7763819095, (1188, 2) = .607778751889855, (1189, 1) = 11.0, (1189, 2) = .0, (1190, 1) = .783919598, (1190, 2) = .6188678901371553, (1191, 1) = .78397674840546, (1191, 2) = .6190688072109369, (1192, 1) = .7840111953751815, (1192, 2) = .6190954773999999, (1193, 1) = .7842955859737704, (1193, 2) = .6224376043415832, (1194, 1) = .7845976136243192, (1194, 2) = .6226130653999999, (1195, 1) = .783919598, (1195, 2) = .6242381964078862, (1196, 1) = .7835965867154213, (1196, 2) = .6227638039966131, (1197, 1) = .7833238842954877, (1197, 2) = .6226130653999999, (1198, 1) = .7837710236567536, (1198, 2) = .619164812094172, (1199, 1) = .7835088566664069, (1199, 2) = .6190954773999999, (1200, 1) = .783919598, (1200, 2) = .6188678901371553, (1201, 1) = .0, (1201, 2) = .0, (1202, 1) = .0, (1202, 2) = .0, (1203, 1) = .0, (1203, 2) = .0}, datatype = float[8], order = C_order))]), COLOUR(RGB, 1.00000000, 0., 0.)), THICKNESS(3), AXESLABELS(omega, a))
display(E)
Download kiran-problem.mw
Hello.
I want to use units in my calculations, but i recieved an error. I have attached my file. Could you please help me to solve it?
Download Prestressed_Concrete.mwPrestressed_Concrete.mw
First 1190 1191 1192 1193 1194 1195 1196 Last Page 1192 of 2470
