The equation
x^7+14*x^4+35*x^3+14*x^2+7*x+88 = 0
has the unique real root
x = (1+sqrt(2))^(1/7)+(1-sqrt(2))^(1/7)-(3+2*sqrt(2))^(1/7)-(3-2*sqrt(2))^(1/7).
Here is its verification:
Is it possible to find that in Maple? I unsuccessfully tried the solve command with the explicit option.
I was required to purchase Maple 17 for my upcoming Calculus III course, and until now, I have been using my TI-Nspire CAS CX for all of my CAS needs.  I am going through various tutorials/labs in an effort to learn how to use the Maple 17 Software. As a part of this process, I am attempting to solve a system of equations and was told to use the following command:
>solve({2*x+3*y=7,5*x+8*y=9},{x,y});
in order to receive the answer
{y=-17,x=29}.
Instead, I have received the following error message, which has no help attached to it through the help page.
solve({2*x+3*y = 7, 5*x+8*y = 9}, {x, y});
I am hoping this has something to do with Mac vs. Windows software, and that it has a simple solution.  I would greatly appreciate any guidance!
There are two normals to a point on a curve.  How do I get the PlotPositionVector of Student[VectorCalculus] to point in the other direction.
with(Student[VectorCalculus]:
R1:=PositionVector([p,p^2],polar[r,t]):
PlotPositionVector(-R1,p=1..2,normal=true,points=[1.5])
The normal vector points towards the insided of the curve.  Can I use PlotPositionVector to have it point the opposite way (towards the outside of the curve)?
ODE:=diff((-diff(u(y),y))^n,y)=A;
bcs:=D(u)(0)=0,u(h)=0;
dsolve({ODE,bcs});
             u(y) = 0
Does anyone has any maple worksheet that generate surface using the PDE method described in this article?  I am trying to learn this method but I am not familiar with the mathematics to do it although the paper gives some description of it.  I hope someone can demonstrate the procedure in Maple.  Thanks
http://www.researchgate.net/publication/259095177_Automatic_shape_optimisation_of_pharmaceutical_tablets_using_Partial_Differential_Equations/file/72e7e52a87ed129d4a.pdf
Pleas i want to do continued fractional expansion to transfer function G(s) with numerator and denomenator as a polynomial in Lplace operator s.
with my gratitude
I need to maximize two multivariate objective functions (f(x1,y1,z1,t1) and g(x2,y2,z2,t2)) with inequality and nonnegativity constraints (x1, x2>0 and y1, z1, t1, y2, z2, t2 >=0). I am looking for parametric not numerical solutions.
What is the best way to find the solution to such a problem using maple?
Hi:
i will plot the following equation so that the horizontal axis in terms of omega and vertical axis in terms of a,but i can not do it,can i help me?
equation:
Hi ,
I would like to resolve the Kortweg and de Devries equation :
> KDV2:= diff( u(X,T), T)+ 6*u(X,T)*diff(u(X,T),X)+ diff(u(X,T),X$3);
I used pdsolve but I have a problem to enter the IBC :
I want
u(infinity, t) =0
u( -infinity, t )=0
u ( x, 0 ) = 1
So I did :
> SOL:=pdsolve(diff( u(X,T), T)+ 6*u(X,T)*diff(u(X,T),X)+ diff(u(X,T),X$3)=0,{u(-10, T) = 0, u(10, T) = 0, u(X, 0) =1},numeric,time=T,range=-10..10);
But it doesn't work.
( I remplace infinity by 10 because then I want the graphic representation of the solution )
Could you help me please ?
I am completely new to Maple (and this kind of software in general).
I am just on my first steps of learning...but I quickly noticed, that if I write Pi and hit enter, I do not get
the well-known greek Pi-symbol. I get an ordinary "p" as the result.
I checked the greek-palette...nearly all items in this palette are ordinary letters.
Does anyone have an idea whats wrong?
BTW: I don`t know if it could have to do with that, but I use a german windows 7 installation.
Thank you,
regards,
Kai
I want to create a linearied model for a single or multi degree of freedom vibration system by MapleSim. i faced a lot of problem such as causalize ports, i search the user manual but i didn't find it useful. i attach a very simply one degree of freedom vibration system. i wondering if every one create a linearized model for it. my final goal is governing the equation and determine the natural frequency with nyquist plots. i have mapleSim 6.2 and Maple 17. Thanks
prob1.msim
F+(1/4)*(4*(-Lambda)^(3/2)*h*m^2-2*sqrt(-Lambda)*exp(Lambda*h^2*m^2)*h*m+sqrt(Pi)*erf(h*m*sqrt(-Lambda)))/(m^2*(-Lambda)^(3/2)) = 0;
how to solve this for m for real roots, where the rest are constants with Lambda>0.
Hi:
I have a curve(plot) in Maple and i should find the math equation for it,everybody can help me how to find it?
AOA... I want to solve the following system in maple pl help
sys_ode := diff(y(eta), eta, eta, eta)+3*y(eta)*(diff(y(eta), eta, eta))-2*(diff(y(eta), eta))^2+x(eta) = 0, diff(x(eta), eta, eta)+3*Pr*y(eta)*(diff(x(eta), eta)) = 0
ics := y(0) = 0, (D(y))(0) = 0, (D(y))(infinity) = 0, x(0) = 1, x(infinity) = 0
Help.mw
Dear all;
Please give me few minutes to correct the output of this procedure.Many thinks.
We will solve the waves equations: diff(f(x,y,t),t$2)=c^2*( diff(f(x,y,t),x$2) +diff(f(x,y,t),y$2));  where (x,y,t) in [0,1]*[0,1]*[0,T] using finite difference.  With Initial boundary conditions: [u(0,y,t)=u(1,y,t)=0],   [u(x,0,t)=u(x,1,t)=0],  [u(x,y,0)=f(x,y),   diff(u(x,y,0),t)=g(x,y)]... The code is done and perfect but....The output of this procedure is Nothing. How can I plot the solution...
f:=(x,y)->x*(x-1)*y*(y-1);
g:=(x,y)->0;
analytical_sol:=proc(dx,dy,dt,Tf)
local Ft, Fx,Fy,x,y, c1,c2,c,j,k,i,u;
Ft := floor(Tf/dt)+1;
Fx := floor(1/dx)+1;
Fy := floor(1/dy)+1;
x:=[seq(0..1,dx)]:
y:=[seq(0..1,dy)]:
c1 := (c*dt/dx)^2;
c2 := (c*dt/dy)^2;
#Initial position
for j from  1 to Fx do
   for k from 1 to Fy do
  u[j,k,1] := f(-dx + j*dx, -dy + k*dy) -dt*g(-dx+j*dx, -dy + k*dy);
   u[j,k,2] := f(-dx + j*dx, -dy +k*dy);
# Boundary values j=1
for i from  1 to Ft +1 do
         u[1,k,i] := 0;
         u[Fx,k,i] := 0;
         u[j,1,i] := 0;
         u[j,Fy,i] := 0;
for i from 3 to Ft + 1 do
  for j from 2 to Fx-1 do
    for k from 2 to Fy-1 do
u[j, k, i] := 2*u[j,k,i-1] - u[j,k,i-2] + c1*(u[j+1,k,i-1]-2*u[j,k,i-1]+u[j-1,k,i-1]) + c2*(u[j,k+1,i-1] - 2*u[j, k, i-1] + u[j,k-1, i-1]);
return Matrix([seq([seq([seq(u[i,j,k],i=1..Fx)],j=1..Fy)],k=1..Ft)]):
## Try the test
f:=(x, y) -> x (x - 1) y (y - 1)
g:=(x, y) -> 0;
analytical_sol(0.1,0.1,0.1,2);
First 1487 1488 1489 1490 1491 1492 1493 Last Page 1489 of 2471
