I am looking for a package to calculate the power mean (or Hölder mean) defined like
Mean_p(x_n)=(1/N Sum(x_n^p,n=1..N))^(1/p)
in a hopefully obvious notation. I can obviously implement this definition directly in Maple, but there are subtleties (like the limit of p=0) which maybe a mature implementation already covers (?).
I am still mostly on Maple 15 which does not have such a Mean. If 16 or 17 have it I would not becessarily know.
Hey Forums!
Im using maple 16 for some rather simple Engineering calculatioins. One thing about using maple bothers me, and that is the way my result is displayed.
Here is an example
Here is another
Adding "simplify" or "evalf" sometimes does the trick, but id really like...
I have total nine equations,out of which some are linear and some of them are nonlinear.I am a new user of maple.The nine equations are
c2+vc = .34,
c2+c3 = .519,
t8+c3-c4-vc = .132,
t1+t5-c2+0.0435=0,
t1-t2-c2+c3-1.334*vc = 0,
t2+t6-c3-c4+0.0435+1.334*vc=0,
-112.5*t1+112.5*t5+300*c2^2+1000*vc = 38.25,
112.5*t1-112.5*t2-300*c2^2+300*c3-300*c3^2-2000*vc+23.4 = 0,
-112.8*t8+112.5*t2-112.5*t6+300*c4^2-300*c3+300*c3^2+1000*vc+14.85 = 0
This piece of code returns a vector 'Sinrdensity' with identity entries. what's wrong with it?
sinrvalue := [seq(10^((1/10)*i), i = -15 .. 25, .5)];
Sinrdensity := Matrix(1, nops(sinrvalue), 0);
task := proc (sinrdensity, initialpoint, endpoint)
local bft, Theta, bound, value;
for value from initialpoint to endpoint do
bft := unapply(1/(1+I*t), t);
for Theta from 0 to 10^10 while is(0.1e-1 <= evalf(abs(bft(2^Theta...
like f# do
match(tree)
with| verification('hyporesult'(alpha,beta), 'dedeuceto'('Conj'(alpha,beta),gamma) -> 'hyporesult'('Conj'(alpha,gamma),beta)
need to get hyporesult is prefix, and then use if the compare, and get first parameter and second parameter such as for 'Conj'(alpha, gamma)
i use typefunc('hyporesult'(alpha,beta)) can not get 'hyporesult'
moreover...
Who knows what Maple does wrong on this one?
T:=Sum(1/(6*k+1)!, k=0..infinity); evalf(T); value(T); evalf(%);
Sum(1/factorial(6*k+1), k = 0 .. infinity)
1.000198413
(1/6)*3^(1/2)*exp(-1/2)*sin((1/2)*3^(1/2))+(1/6)*3^(1/2)*exp(1/2)*sin((1/2)*3^(1/2))+(1/6)*exp(1/2)*cos((1/2)*3^(1/2))
.6739557747
Download sum.mw
Does any one know how to derive this model in Maple?
The_Price_is_Righ.pdf
I did two polar plots as you see and wanted to color the region between them.
> with(plots);
> a1 := polarplot(1, t = 0 .. 6*Pi*(1/3), thickness = 2, filled = true, color = black);
> a2 := polarplot(2*cos(t), t = 0 .. 6*Pi*(1/3), thickness = 2);
> a3 := polarplot(2*cos(t), t = -(1/3)*Pi .. (1/3)*Pi, filled = true, thickness = 2);
> display(a1, a2, a3);
The program makes the region colored red but there is an overlapping part which...
Can you help me how to program about the interference of wave on the water surface in Maple ?
I've bought NAG C Library for my mac in order to use it in Maple.
However, it seems that Maple doesn't know where to search for it.
Indeed, it returns
Error, (in NAG:-h03abc) external linking: error loading external library libnagc_nag.dylib: dlopen(libnagc_nag.dylib, 129): image not found
I've installed NAG C Library in usr/Library
Thank you very much for your help
If I have several sets of listed data of different lengths,
a1:=[1,2]
a2:=[5,3,4,5]
a3:=[4,8,4,5,3,2,3,4,5]
a4:=[2,2,5,4,7,8]
How do I join the 1st positions into one variable and the 2nd positions into another and so on?
Let the points M_1(-2,3,-4), M_2(4,-1,3) and the two straight lines l_1: x=-t+3,y= 2t-4,z= t+2 , l_2: x=s+4, y= 2s, z= 2s-1 be given. How to find the shortest path from M_1 to M_2 of the form M_1 - A -B - M_2 or M_1 -C - E - M_2, where A belongs to l_1, B belongs to l_2, C belongs to l_2, and E belongs to l_1? In other words, what is the shortest path between M_1 and M_2 which intersects with l_1 and l_2? How to find it with Maple?
Further tags : implicit form, Matlab codegen for GPOPS purposes
Hi there,
I would like to introduce my self and ask you for an advice.
I have a four linked robot that i would really like to control by the meaning of the optimal control theory. The arm has 4 actuators (giving torques U) in corrispondence of 4 rotational joints. P parameters describe the system.
I got ht edynamic system with the Lagrangian method and now I have 4 2nd order...
How do I find all words beginning with "FL" and ending in "S" ?
So currently i am trying to programm a game. for that i would need a Textbox that is updating once the player makes an input. I have a textbox TB1 and a button with the action linked. the action that the button should make is calling an external procedure which in turn updates the textbox. But i currently i keep getting the following error expresion:
Error, (in Maplets:-Tools:-Set) invalid argument(s): [TB1]::string = [7, 8, 9]
So what die i do wrong.
First 1621 1622 1623 1624 1625 1626 1627 Last Page 1623 of 2471
