p1>0, p2<0 and x[0] are arbitrary constants. How can i solve this integral?
   I want to see
thanks in advance.
First of all, I'm beginner in Maple.
I want to plot  "M" versus "kc" and "deltah" as a 3D curve (M is real and positive). Intervals of kc and deltah are  given (see attached file). These three parameters (i.e, M,kc,deltah) should satisfiy the following equation:
Eq=-(1-(deltab+deltah))-(1-(deltab+deltah))/(kc-3/2)-deltah/sigmah-deltah/(sigmah*(kh-3/2))-(1/6)*deltab*sqrt(3)*mu*(1/sqrt((M-u0b+sqrt(3)*sqrt(mu*sigmab))**2)+1/sqrt((M-u0b-sqrt(3)*sqrt(mu*sigmab))**2))/sqrt(mu*sigmab)-(1/6)*sqrt(3)*(1/sqrt((M+sqrt(3)*sqrt(sigmai))**2)-1/sqrt((M-sqrt(3)*sqrt(sigmai))**2))/sqrt(sigmai)=0.
Other parameters are as follows:
 kh=3, sigmah=4,sigmab=1,u0b=0.05,sigmai=1/300,deltab=1e-6,mu=1836.
3D.mw
How to solve and plot a ODE system in RK method.
eq1 := diff(f(x), x, x, x)-(1/2)*Sc*sin(alpha)*g(x)*(diff(g(x), x, x))+(1/2)*x*cos(alpha)*(diff(f(x), x, x))+(1/2)*sin(alpha)*f(x)*(diff(f(x), x, x)) = 0; eq2 := (diff(g(x), x, x, x))/Pm+(1/2)*x*cos(alpha)*(diff(g(x), x, x))+sin(alpha)*f(x)*(diff(g(x), x, x))-sin(alpha)*(diff(f(x), x, x))*g(x) = 0; eq3 := (diff(theta(x), x, x))/Pr+(1/2)*x*cos(alpha)*(diff(theta(x), x))+(1/2)*x*(diff(f(x), x))*(diff(theta(x), x))+sin(alpha)*(x*(diff(f(x), x))-f(x))*(diff(theta(x), x))-Nb*(diff(s(x), x))*(diff(theta(x), x))-Nt*(diff(theta(x), x))^2+(1/4)*Sc*Br*sin(alpha)^2*(diff(f(x), x))^2*(x*(diff(g(x), x))-g(x))+(diff(g(x), x))^2*(x*(diff(f(x), x))-f(x)) = 0; eq4 := diff(s(x), x, x)+S*((1/2)*cos(alpha)*x*(diff(s(x), x))+(1/2)*sin(alpha)*f(x)*(diff(s(x), x)))+Nt*(diff(theta(x), x, x))/Nb = 0
ics := f(0) = 0, (D(f))(0) = 1, g(0) = 0, (D(g))(0) = 1, theta(0) = 1, s(0) = 1; bcs := (D(f))(100) = 0, (D(g))(100) = 0, theta(100) = 0, s(100) = 0
alpha = - 30 degree, Sc = 1.0, Pm = .1, Pr = 6.2, Nb = .1, Nt = .1, Br = .5, S = 1
I would like to create/import a list from a text-file. The text-file "example.txt" has the following structur:
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
10 12
11 14
On every line are two numbers, separated by a space. The list should contain only the second number, in this example
L:=[1, 2, 3, 4, 5, 6, 7, 8, 9, 12, 14].
The original text-file has 12615 lines, the biggest number is around  3.126 * 10^139.
Thanks for your help.
Was working with some antenna design equations and noticed that in a certain plot definition, the addition of gridlines changes the shape of the plotted curve.  Is this a bug or is there something obvious here that I am overlooking?  This one really has me scratching my head.  The only difference between the two plots below is the addition of the gridline spec.
Many thanks!
gridlines_change_plot.mw
I'm currently exploring the properties of a sum in Maple, and I was wondering how to obtain the values of the following sum:
sum 1/(i*j*k*) such that 1<=i+j+k<= n
I'm interested in the values of this sum for a given n. How can I express this efficiently in Maple?
Hi, I have an homework where I need to find the highest point and the lowest point on an ellipse form by the intersection of two equations wich are 4x-3y+8z=5 and z^2=x^2+y^2 and I have to use the LagrangeMultiplier command. I get how it works but I can't get the correct form. How should I do it ?
Is it possible overlay one column graph on top of another ? And if, how do I do it?
I have here a function
                           "sin(x)/x"
and suppose sin(x)/x = 0
Can I now use MapleAI to retrieve the correct command for this in Maple..could I?
The intersection points with the x-axis are positive and negative multiples of Pi
I have put these in an ordered list, but Maple gives this:
For x domain = -20...20
X := {x = Pi}, {x = 2*Pi}, {x = 3*Pi}, {x = 4*Pi}, {x = 5*Pi}, {x = 6*Pi}, {x = -6*Pi}, {x = -5*Pi}, {x = -4*Pi}, {x = -3*Pi}, {x = -2*Pi}, {x = -Pi};
X := sort(eval~(x, [X]));
 X := [, -6 Pi, -5 Pi, -4 Pi, -3 Pi, -2 Pi, -Pi, 2 Pi, 3 Pi, 4 Pi, 5 Pi, 6 Pi]
A strange ranking that Maple comes up with ?
with(NaturalLanguage);
        [Explain, GetCommand, GetMath, Query, RawQuery]
GetCommand("give for Maple solve command all options?");
            "solve(equations, variables, options);"
Explain("give for Maple solve command all options?");
"Maple is a symbolic and numeric computing environment. Its
   "solve" command is used to find solutions (roots) of a given
   equation or a system of equations.
  There are a number of options (or "parameters") which can be
   specified in this command to alter its behavior:
  1. `Allsolutions`: This option makes Maple to generate all
   possible solutions of an equation.
  2. `Real`: This option only provides the real solutions. If
   equations do not have real solutions, it will return an
   empty set.
  3. `Positive`: It only includes positive solutions in the
   output.
  4. `explicit`: If specified, Maple attempts to isolate roots
   and provide an explicit solution for each variable.
  5. `assume = real`: This option restrict the solutions to
   only real numbers.
  6. `parametric`: This option allows Maple to write the
   solutions in a parametric form.
  7. `avoid ={x = a}`: This option makes solve exclude the
   possibility `x = a` as a solution.
  8. `MaxDegree = d`: This option allows you to limit the
   degree of the polynomial equations to be considered.
  9. `maxdepth = d`: This sets a limit on recursive depth to
   which the computation should go to seek a solution.
  10. `multiplicities`: This option reports multiplicity of the
   roots.
  11. `solutions = vars`: This option tells Maple to look for
   solutions for specific variables.
  12. `numeric`: This option makes solve find a numeric
   solution to the equation.
  13. `symbolic`: This option makes solve find a symbolic
  14. `simplify`: This option simplifies the solutions returned
   by solve.
  15. `sqrt`: This option allows square roots in the output.
  It is important to note that not all options are suited for
   use with all types of equations. Also, the "solve" command
   in Maple can be occasionally limited by the complexity of
   the equation, and may sometimes fail to find solutions that
   more specialized software or methods can find."
I am trying to solve the following set of equations, I am able to find solutions for a simplified case (b=0) using the command solve but cannot seem to solve it for general b.
Is there a better way to attempt to find a solution?
solve.mw
eqn := [(2*((q*r*a3^2-(1/2)*b^2*a3^2-(1/2)*r^2*a3^2-(1/2)*a2^2)*b^4*cos(theta)^4+(2*((q*r-(1/4)*b^2-(1/4)*r^2)*(b^2+r^2)*a4^2*sin(theta)^2-(1/2)*r^4*a3^2+q*r^3*a3^2+(1/2)*(1/2-b^2*a3^2+(1/2)*a1^2-a2^2)*r^2-(1/2)*q*(a1^2+1)*r+(1/4)*b^2*(a1^2+1)))*b^2*cos(theta)^2+2*r*(q^2*sin(theta)^4*b^2*r*a4^2-2*a4*((1/8)*a4*r^5-(1/4)*q*a4*r^4+(1/4)*b^2*a4*r^3-(1/2)*q*b*a1*r^2+b*((1/8)*b^3*a4+q^2*a1)*r+(1/4)*q*b^3*(a4*b-2*a1))*sin(theta)^2-(1/4)*r^5*a3^2+(1/2)*q*r^4*a3^2+(1/4)*(-a3^2*b^2+a1^2-a2^2+1)*r^3+q*(-a1^2-1/2)*r^2+((1/4)*b^2*(a1^2+1)+q^2*a1^2)*r-(1/2)*q*b^2*a1^2)))/((r^2+b^2*cos(theta)^2)*(-b^2+2*q*r-r^2)), (2*((q*r*s3^2-(1/2)*b^2*s3^2-(1/2)*r^2*s3^2-(1/2)*s2^2)*b^4*cos(theta)^4+(2*((q*r-(1/4)*b^2-(1/4)*r^2)*(b^2+r^2)*s4^2*sin(theta)^2-(1/2)*r^4*s3^2+q*r^3*s3^2+(1/2)*(1/2-b^2*s3^2+(1/2)*s1^2-s2^2)*r^2-(1/2)*q*(s1^2+1)*r+(1/4)*b^2*(s1^2+1)))*b^2*cos(theta)^2+2*r*(q^2*sin(theta)^4*b^2*r*s4^2-2*s4*((1/8)*r^5*s4-(1/4)*q*r^4*s4+(1/4)*b^2*r^3*s4-(1/2)*q*b*r^2*s1+b*((1/8)*b^3*s4+q^2*s1)*r+(1/4)*q*b^3*(b*s4-2*s1))*sin(theta)^2-(1/4)*r^5*s3^2+(1/2)*q*r^4*s3^2+(1/4)*(-b^2*s3^2+s1^2-s2^2+1)*r^3+q*(-s1^2-1/2)*r^2+((1/4)*b^2*(s1^2+1)+q^2*s1^2)*r-(1/2)*q*b^2*s1^2)))/((r^2+b^2*cos(theta)^2)*(-b^2+2*q*r-r^2)), (2*((1/2)*s2*sqrt(b^4*cos(theta)^4+8*q*sin(theta)^2*b^2*r+2*b^2*cos(theta)^2*r^2+r^4)+(q*r-(1/2)*b^2-(1/2)*r^2)*(b*sin(theta)^2*s4+s1)))/(-b^2+2*q*r-r^2), (2*((1/2)*a2*sqrt(b^4*cos(theta)^4+8*q*sin(theta)^2*b^2*r+2*b^2*cos(theta)^2*r^2+r^4)+(q*r-(1/2)*b^2-(1/2)*r^2)*(b*sin(theta)^2*a4+a1)))/(-b^2+2*q*r-r^2), (sqrt(b^4*cos(theta)^4+8*q*sin(theta)^2*b^2*r+2*b^2*cos(theta)^2*r^2+r^4)*n2+(2*(1+sin(theta)^2*b*n4+n1))*(q*r-(1/2)*b^2-(1/2)*r^2))/(-b^2+2*q*r-r^2), (2*(b^4*(q*s3*r*a3-(1/2)*s3*b^2*a3-(1/2)*s3*r^2*a3-(1/2)*a2*s2)*cos(theta)^4+(2*((q*r-(1/4)*b^2-(1/4)*r^2)*(b^2+r^2)*s4*a4*sin(theta)^2-(1/2)*s3*r^4*a3+q*s3*r^3*a3+(1/2)*(-s3*b^2*a3+(1/2)*a1*s1-a2*s2)*r^2-(1/2)*q*r*a1*s1+(1/4)*b^2*a1*s1))*b^2*cos(theta)^2+(2*(q^2*s4*sin(theta)^4*b^2*r*a4+(-(1/4)*s4*r^5*a4+(1/2)*q*s4*r^4*a4-(1/2)*s4*b^2*r^3*a4+(1/2)*q*b*(a1*s4+a4*s1)*r^2-b*((1/4)*s4*b^3*a4+q^2*(a1*s4+a4*s1))*r-(1/2)*q*b^3*(a4*b*s4-a1*s4-a4*s1))*sin(theta)^2-(1/4)*s3*r^5*a3+(1/2)*q*s3*r^4*a3+(1/4)*(-a3*b^2*s3+a1*s1-a2*s2)*r^3-q*r^2*a1*s1+a1*s1*(q^2+(1/4)*b^2)*r-(1/2)*q*b^2*a1*s1))*r))/((r^2+b^2*cos(theta)^2)*(-b^2+2*q*r-r^2)), (2*((1/2)*a2*sqrt(b^4*cos(theta)^4+8*q*sin(theta)^2*b^2*r+2*b^2*cos(theta)^2*r^2+r^4)+(q*r-(1/2)*b^2-(1/2)*r^2)*(b*sin(theta)^2*a4+a1)))/(-b^2+2*q*r-r^2), (2*(b^4*(q*n3*r*a3-(1/2)*n3*b^2*a3-(1/2)*n3*r^2*a3-(1/2)*a2*n2)*cos(theta)^4+(2*((q*r-(1/4)*b^2-(1/4)*r^2)*(b^2+r^2)*n4*a4*sin(theta)^2-(1/2)*n3*r^4*a3+q*n3*r^3*a3+(1/2)*(-n3*b^2*a3+(1/2)*a1*n1-a2*n2)*r^2-(1/2)*q*r*a1*n1+(1/4)*b^2*a1*n1))*b^2*cos(theta)^2+(2*(q^2*n4*sin(theta)^4*b^2*r*a4+(-(1/4)*n4*r^5*a4+(1/2)*q*n4*r^4*a4-(1/2)*n4*b^2*r^3*a4+(1/2)*q*b*(a1*n4+a4*n1)*r^2-b*((1/4)*n4*b^3*a4+q^2*(a1*n4+a4*n1))*r-(1/2)*q*b^3*(a4*b*n4-a1*n4-a4*n1))*sin(theta)^2-(1/4)*n3*r^5*a3+(1/2)*q*n3*r^4*a3+(1/4)*(-a3*b^2*n3+a1*n1-a2*n2)*r^3-q*r^2*a1*n1+a1*n1*(q^2+(1/4)*b^2)*r-(1/2)*q*b^2*a1*n1))*r))/((r^2+b^2*cos(theta)^2)*(-b^2+2*q*r-r^2)), (2*(b^4*(q*s3*r*n3-(1/2)*s3*b^2*n3-(1/2)*s3*r^2*n3-(1/2)*n2*s2)*cos(theta)^4+(2*((q*r-(1/4)*b^2-(1/4)*r^2)*(b^2+r^2)*s4*n4*sin(theta)^2-(1/2)*s3*r^4*n3+q*s3*r^3*n3+(1/2)*(-s3*b^2*n3+(1/2)*n1*s1-n2*s2)*r^2-(1/2)*q*r*n1*s1+(1/4)*b^2*n1*s1))*b^2*cos(theta)^2+(2*(q^2*s4*sin(theta)^4*b^2*r*n4+(-(1/4)*s4*r^5*n4+(1/2)*q*s4*r^4*n4-(1/2)*s4*b^2*r^3*n4+(1/2)*q*b*(n1*s4+n4*s1)*r^2-b*((1/4)*s4*b^3*n4+q^2*(n1*s4+n4*s1))*r-(1/2)*q*b^3*(b*n4*s4-n1*s4-n4*s1))*sin(theta)^2-(1/4)*s3*r^5*n3+(1/2)*q*s3*r^4*n3+(1/4)*(-b^2*n3*s3+n1*s1-n2*s2)*r^3-q*r^2*n1*s1+n1*s1*(q^2+(1/4)*b^2)*r-(1/2)*q*b^2*n1*s1))*r))/((r^2+b^2*cos(theta)^2)*(-b^2+2*q*r-r^2)), (2*((q*r*n3^2-(1/2)*b^2*n3^2-(1/2)*r^2*n3^2-(1/2)*n2^2)*b^4*cos(theta)^4+(2*((q*r-(1/4)*b^2-(1/4)*r^2)*(b^2+r^2)*n4^2*sin(theta)^2-(1/2)*r^4*n3^2+q*r^3*n3^2+(1/2)*(-b^2*n3^2+(1/2)*n1^2-n2^2)*r^2-(1/2)*q*r*n1^2+(1/4)*b^2*n1^2))*b^2*cos(theta)^2+2*r*(q^2*sin(theta)^4*b^2*r*n4^2-2*n4*((1/8)*n4*r^5-(1/4)*q*n4*r^4+(1/4)*n4*b^2*r^3-(1/2)*q*b*r^2*n1+b*((1/8)*n4*b^3+q^2*n1)*r+(1/4)*q*b^3*(b*n4-2*n1))*sin(theta)^2-(1/4)*r^5*n3^2+(1/2)*q*r^4*n3^2+(1/4)*(-b^2*n3^2+n1^2-n2^2)*r^3-q*r^2*n1^2+n1^2*(q^2+(1/4)*b^2)*r-(1/2)*q*b^2*n1^2)))/((r^2+b^2*cos(theta)^2)*(-b^2+2*q*r-r^2)), -(32*(((1/8)*(b*(-a2*a4+s2*s4)*(q-r)*sin(theta)^2+q*(a1*a2-s1*s2))*(q*r-(1/2)*b^2-(1/2)*r^2)*b^6*cos(theta)^6-(1/4)*b^4*((q*b^2-(3/2)*q*r^2+(3/2)*r^3)*(q*r-(1/2)*b^2-(1/2)*r^2)*(-a2*a4+s2*s4)*b*sin(theta)^2+(a1*a2-s1*s2)*q*(q*b^2*r+(1/2)*q*r^3-(1/2)*b^4-(3/4)*b^2*r^2))*cos(theta)^4+(b*(-a3*a4+s3*s4)*sin(theta)^2-s3*s1+a3*a1)*r*q*(q*r-(1/2)*b^2-(1/2)*r^2)^2*b^4*sin(theta)*cos(theta)^3+(1/8)*(7*(((1/14)*(3*(-a2*a4+s2*s4))*r^3-13*q*(-a2*a4+s2*s4)*r^2*(1/14)+(q^2+3*b^2*(1/14))*(-a2*a4+s2*s4)*r-(1/2)*q*b*(b*(-a2*a4+s2*s4)+(1/7)*a2*a1-(1/7)*s1*s2))*b*sin(theta)^2-(1/7)*r*(a1*a2-s1*s2)*(q-(1/2)*r)*q))*r^4*b^2*cos(theta)^2+(b*(-a3*a4+s3*s4)*sin(theta)^2-s3*s1+a3*a1)*r^3*q*(q*r-(1/2)*b^2-(1/2)*r^2)^2*b^2*sin(theta)*cos(theta)+(1/4)*(((1/4)*(-a2*a4+s2*s4)*r^5-7*q*(-a2*a4+s2*s4)*r^4*(1/4)+(1/2)*(5*(q^2+(1/10)*b^2))*(-a2*a4+s2*s4)*r^3-7*q*b^2*(-a2*a4+s2*s4)*r^2*(1/4)+q^2*b^2*(-a2*a4+s2*s4)*r-(1/2)*q*(b*(-a2*a4+s2*s4)+a2*a1-s1*s2)*b^3)*b*sin(theta)^2+r*(a1*a2-s1*s2)*(q*b^2+(1/2)*q*r^2-(3/4)*b^2*r-(1/4)*r^3)*q)*r^4)*sqrt(b^4*cos(theta)^4+8*q*sin(theta)^2*b^2*r+2*b^2*cos(theta)^2*r^2+r^4)-(1/32)*q*b^10*(a2-s2)*(a2+s2)*cos(theta)^10+(1/8)*b^8*((2*((1/8)*(-a4^2+s4^2)*r^4+5*q*(a4^2-s4^2)*r^3*(1/8)+(s4-a4)*(s4+a4)*(q^2+(1/4)*b^2)*r^2-3*q*b^2*(s4-a4)*(s4+a4)*r*(1/4)+(1/8)*((-a4^2+s4^2)*b^2-a2^2+s2^2)*b^2))*r*sin(theta)^2+(1/4)*(-a3^2+s3^2)*r^5+(a3^2-s3^2)*q*r^4+((1/2)*b^2+q^2)*(s3-a3)*(s3+a3)*r^3-((-a3^2+s3^2)*b^2+7*a2^2*(1/4)-7*s2^2*(1/4))*q*r^2+(1/4)*b^4*(-a3^2+s3^2)*r+q*b^2*(a2-s2)*(a2+s2))*cos(theta)^8+(1/2)*r*q*(q*r-(1/2)*b^2-(1/2)*r^2)*b^8*sin(theta)*(-a2*a3+s2*s3)*cos(theta)^7+(1/8)*((s4-a4)*(s4+a4)*(q*r-(1/2)*b^2)^2*q*b^2*sin(theta)^4+((-a4^2+s4^2)*r^7+25*q*(a4^2-s4^2)*r^6*(1/4)+(15*(s4-a4))*(s4+a4)*(q^2+2*b^2*(1/15))*r^5-33*q*b*((-a4^2+s4^2)*b+2*s1*s4*(1/33)-2*a1*a4*(1/33))*r^4*(1/4)+((-a4^2+s4^2)*b^4+((12*(-a4^2+s4^2))*q^2-a2^2+s2^2)*b^2+2*q^2*(-a1*a4+s1*s4)*b)*r^3-(2*((1/8)*(7*(-a4^2+s4^2))*b^3+(1/2)*(-a1*a4+s1*s4)*b^2+q^2*(-a1*a4+s1*s4)))*q*b*r^2+2*q^2*b^3*(-a1*a4+s1*s4)*r-(1/2)*q*b^5*(-a1*a4+s1*s4))*sin(theta)^2+(-a3^2+s3^2)*r^7+(6*(a3^2-s3^2))*q*r^6+(12*(q^2+(1/6)*b^2))*(s3-a3)*(s3+a3)*r^5-(8*((-a3^2+s3^2)*b^2+(1/32)*a1^2+11*a2^2*(1/16)-(1/32)*s1^2-11*s2^2*(1/16)))*q*r^4+(b^4*(-a3^2+s3^2)+8*q^2*(-a3^2+s3^2)*b^2+q^2*(a1^2-s1^2))*r^3-(2*b^4*(-a3^2+s3^2)+((1/2)*a1^2-2*a2^2-(1/2)*s1^2+2*s2^2)*b^2+q^2*(a1^2-s1^2))*q*r^2+q^2*b^2*(a1-s1)*(a1+s1)*r-(1/4)*q*b^4*(a1^2+4*a2^2-s1^2-4*s2^2))*b^6*cos(theta)^6-r*q*(q*r-(1/2)*b^2-(1/2)*r^2)*(b^2-(1/2)*r^2)*b^6*sin(theta)*(-a2*a3+s2*s3)*cos(theta)^5+r*b^4*((s4-a4)*(s4+a4)*(q*b^2*r+(17/8)*q*r^3-(1/4)*b^4)*q^2*b^2*sin(theta)^4+((1/16)*(3*(-a4^2+s4^2))*r^8+39*q*(a4^2-s4^2)*r^7*(1/32)+(1/8)*(19*(s4-a4))*(s4+a4)*(q^2+3*b^2*(1/19))*r^6-45*q*b*((-a4^2+s4^2)*b+2*s1*s4*(1/45)-2*a1*a4*(1/45))*r^5*(1/32)-(1/4)*((1/4)*(3*(a4^2-s4^2))*b^2+(-a4^2+s4^2)*q^2+3*a2^2*(1/4)-3*s2^2*(1/4))*b^2*r^4+((1/32)*(3*(-a4^2+s4^2))*b^3+(1/8)*(a1*a4-s1*s4)*b^2+q^2*(-a3^2+s3^2)*b-9*q^2*(-a1*a4+s1*s4)*(1/4))*q*b*r^3-(1/8)*(19*((-a4^2+s4^2)*b^2+(1/19)*(10*(a1*a4-s1*s4))*b+4*a2^2*(1/19)-4*s2^2*(1/19)))*q^2*b^2*r^2-(2*((1/64)*(9*(a4^2-s4^2))*b^3+(1/32)*(-a1*a4+s1*s4)*b^2+q^2*(-a1*a4+s1*s4)))*q*b^3*r+(1/2)*q^2*b^5*(-a1*a4+s1*s4))*sin(theta)^2+(1/16)*(3*(-a3^2+s3^2))*r^8+5*q*(a3^2-s3^2)*r^7*(1/4)+(1/4)*(11*(q^2+3*b^2*(1/22)))*(s3-a3)*(s3+a3)*r^6-(1/2)*(3*((-a3^2+s3^2)*b^2+(1/48)*a1^2+13*a2^2*(1/24)-(1/48)*s1^2-13*s2^2*(1/24)))*q*r^5+(q^2+3*b^2*(1/16))*(s3-a3)*(s3+a3)*b^2*r^4-(1/8)*(9*((1/9)*((1/2)*a1^2-4*a2^2-(1/2)*s1^2+4*s2^2)*b^2+q^2*(a1^2-s1^2)))*q*r^3-((-a3^2+s3^2)*b^2-5*a1^2*(1/8)+5*s1^2*(1/8))*q^2*b^2*r^2-q*b^2*((1/4)*(a3^2-s3^2)*b^4+(1/8)*((1/4)*a1^2+a2^2-(1/4)*s1^2-s2^2)*b^2+q^2*(a1^2-s1^2))*r+(1/4)*q^2*b^4*(a1-s1)*(a1+s1))*cos(theta)^4-(2*(b^2+(1/4)*r^2))*r^3*q*(q*r-(1/2)*b^2-(1/2)*r^2)*b^4*sin(theta)*(-a2*a3+s2*s3)*cos(theta)^3+(q^4*b^4*r^2*(s4-a4)*(s4+a4)*sin(theta)^6-(2*(7*q*(a4^2-s4^2)*r^5*(1/16)+3*b*(-a1*a4+s1*s4)*r^4*(1/8)+q*b^2*(s4-a4)*(s4+a4)*r^3+q^2*(-a1*a4+s1*s4)*b*r^2+(1/2)*q*b^4*(s4-a4)*(s4+a4)*r+(1/8)*b^6*(a4^2-s4^2)))*q^2*b^2*sin(theta)^4+((1/8)*(-a4^2+s4^2)*r^10+23*q*(a4^2-s4^2)*r^9*(1/32)+(1/8)*(11*(s4-a4))*(s4+a4)*(q^2+2*b^2*(1/11))*r^8-(1/32)*(15*((-a4^2+s4^2)*b-2*s1*s4*(1/15)+2*a1*a4*(1/15)))*q*b*r^7-(1/2)*((1/4)*(a4^2-s4^2)*b^3+((-a4^2+s4^2)*q^2+(1/4)*a2^2-(1/4)*s2^2)*b+3*q^2*(-a1*a4+s1*s4)*(1/2))*b*r^6+(2*((1/64)*(23*(-a4^2+s4^2))*b^3+(1/16)*(-a1*a4+s1*s4)*b^2+q^2*(-a3^2+s3^2)*b+9*q^2*(-a1*a4+s1*s4)*(1/8)))*q*b*r^5-(1/8)*(5*((-a4^2+s4^2)*b^2+3*a1^2*(1/5)+8*a2^2*(1/5)-3*s1^2*(1/5)-8*s2^2*(1/5)))*q^2*b^2*r^4+4*q*((1/128)*(15*(-a4^2+s4^2))*b^3+(1/64)*(-a1*a4+s1*s4)*b^2+q^2*(-a1*a4+s1*s4))*b^3*r^3-((a4^2-s4^2)*b^4+(1/2)*(3*(-a1*a4+s1*s4))*b^3+q^2*(a1^2-s1^2))*q^2*b^2*r^2+2*q^3*b^5*(-a1*a4+s1*s4)*r-(1/2)*q^2*b^7*(-a1*a4+s1*s4))*sin(theta)^2+(1/8)*(-a3^2+s3^2)*r^10+3*q*(a3^2-s3^2)*r^9*(1/4)+(1/2)*(3*(q^2+(1/6)*b^2))*(s3-a3)*(s3+a3)*r^8-(1/2)*((-a3^2+s3^2)*b^2-(1/16)*a1^2+9*a2^2*(1/16)+(1/16)*s1^2-9*s2^2*(1/16))*q*r^7+((1/8)*b^4*(-a3^2+s3^2)+(a3^2-s3^2)*q^2*b^2+3*q^2*(-a1^2+s1^2)*(1/8))*r^6+9*q*(2*b^4*(-a3^2+s3^2)*(1/3)+(1/3)*((1/6)*a1^2+2*a2^2-(1/6)*s1^2-2*s2^2)*b^2+q^2*(a1^2-s1^2))*r^5*(1/8)+(2*(a3^2-s3^2))*q^2*b^4*r^4+2*q*((1/4)*b^4*(-a3^2+s3^2)+(1/16)*((1/4)*a1^2+a2^2-(1/4)*s1^2-s2^2)*b^2+q^2*(a1^2-s1^2))*b^2*r^3-3*q^2*b^4*(a1-s1)*(a1+s1)*r^2*(1/4)+q^3*b^4*(a1-s1)*(a1+s1)*r-(1/4)*q^2*b^6*(a1-s1)*(a1+s1))*r*b^2*cos(theta)^2-(b^2+(1/2)*r^2)*r^5*q*(q*r-(1/2)*b^2-(1/2)*r^2)*b^2*sin(theta)*(-a2*a3+s2*s3)*cos(theta)-r^3*(q^4*b^4*r^2*(s4-a4)*(s4+a4)*sin(theta)^6-2*r*(7*q*(-a4^2+s4^2)*r^4*(1/16)+(1/2)*q*b^2*(s4-a4)*(s4+a4)*r^2+(-a1*a4+s1*s4)*((1/2)*b^2+q^2)*b*r+(1/2)*q*b^4*(s4-a4)*(s4+a4))*q^2*b^2*sin(theta)^4+((1/32)*(a4^2-s4^2)*r^10+(1/8)*q*(-a4^2+s4^2)*r^9-(1/8)*(s4-a4)*(s4+a4)*((1/2)*b^2+q^2)*r^8-(1/32)*(3*((-a4^2+s4^2)*b+2*s1*s4*(1/3)-2*a1*a4*(1/3)))*q*b*r^7+(1/8)*(7*((1/28)*(a4^2-s4^2)*b^3+((-a4^2+s4^2)*q^2+(1/28)*a2^2-(1/28)*s2^2)*b+2*q^2*(-a1*a4+s1*s4)*(1/7)))*b*r^6-((1/16)*(7*(-a4^2+s4^2))*b^3+(1/8)*(-a1*a4+s1*s4)*b^2+q^2*(-a3^2+s3^2)*b+(1/4)*q^2*(-a1*a4+s1*s4))*q*b*r^5+(1/8)*(9*((-a4^2+s4^2)*b^2+(1/9)*(2*(a1*a4-s1*s4))*b+4*a2^2*(1/9)-4*s2^2*(1/9)))*q^2*b^2*r^4+(2*((1/64)*(7*(a4^2-s4^2))*b^3+(1/32)*(a1*a4-s1*s4)*b^2+q^2*(-a1*a4+s1*s4)))*q*b^3*r^3-q^2*b^2*((1/2)*(a4^2-s4^2)*b^4+(1/2)*(a1^2-s1^2)*b^2+q^2*(a1^2-s1^2))*r^2+2*q^3*b^5*(-a1*a4+s1*s4)*r+(1/4)*q^2*b^7*((-a4^2+s4^2)*b-2*s1*s4+2*a1*a4))*sin(theta)^2+(1/32)*(a3^2-s3^2)*r^10+(1/8)*q*(-a3^2+s3^2)*r^9-(1/8)*((1/2)*b^2+q^2)*(s3-a3)*(s3+a3)*r^8-(1/8)*((-a3^2+s3^2)*b^2+(1/4)*a1^2+(1/4)*a2^2-(1/4)*s1^2-(1/4)*s2^2)*q*r^7+((1/32)*(a3^2-s3^2)*b^4+q^2*(-a3^2+s3^2)*b^2+(1/8)*q^2*(a1^2-s1^2))*r^6-(1/8)*(4*b^4*(-a3^2+s3^2)+((1/2)*a1^2+3*a2^2-(1/2)*s1^2-3*s2^2)*b^2+q^2*(a1^2-s1^2))*q*r^5+q^2*((-a3^2+s3^2)*b^2+(1/8)*s1^2-(1/8)*a1^2)*b^2*r^4+((1/4)*(a3^2-s3^2)*b^4+(1/8)*(-a2^2+s2^2+(1/4)*s1^2-(1/4)*a1^2)*b^2+q^2*(a1^2-s1^2))*q*b^2*r^3+q^3*b^4*(a1-s1)*(a1+s1)*r-(1/4)*q^2*b^6*(a1-s1)*(a1+s1))))/(sqrt(b^4*cos(theta)^4+8*q*sin(theta)^2*b^2*r+2*b^2*cos(theta)^2*r^2+r^4)*(r^2+b^2*cos(theta)^2)^3*(-b^2+2*q*r-r^2)^2)]
solve(eqn, {a1, a2, a3, a4, n1, n2, n3, n4, s1, s2, s3, s4})
Download solve.mw
In many special cases, generalized hypergeometric functions can be transformed into other (possibly less general) functions, but sometimes Maple fails to convert some of them to other functions when possible.
For instance,
4*hypergeom([1, 1], [2, 3, 7/2], -(x/2)**2) -
 35*hypergeom([1, 1], [2, 5/2, 3], -(x/2)**2) -
 2*hypergeom([1, 1], [3, 3, 7/2], -(x/2)**2) +
 10*hypergeom([1, 1], [5/2, 3, 3], -(x/2)**2): # which is, in fact, “360*((Ci(x) - ln(x) + 19/18 - gamma)/x**2 - sin(x)/x**3 + (cos(x) + 5/3)/x**4 - 8/3*sin(x)/x**5)”
expand(%);
RealDomain:-expand(4*hypergeom([1, 1], [2, 3, 7/2], -(x/2)**2) - 35*hypergeom([1, 1], [2, 5/2, 3], -(x/2)**2) - 2*hypergeom([1, 1], [3, 3, 7/2], -(x/2)**2) + 10*hypergeom([1, 1], [5/2, 3, 3], -(x/2)**2))
simplify(%);
RealDomain:-simplify(4*hypergeom([1, 1], [2, 3, 7/2], -(x/2)**2) - 35*hypergeom([1, 1], [2, 5/2, 3], -(x/2)**2) - 2*hypergeom([1, 1], [3, 3, 7/2], -(x/2)**2) + 10*hypergeom([1, 1], [5/2, 3, 3], -(x/2)**2))
Is it possible to obtain a non-hypergeometric form of it? E.g.,
Here are more examples that `simplify/hypergeom` (as well as expand) is unable to deal with:
  1. hypergeom([1, 1, 3/2], [5/2, 5/2, 3, 3], -(x/2)**2):
  2. hypergeom([1, 1], [5/2, 3, 3], -(x/2)**2):
  3. hypergeom([1, 1], [3/2, 2, 2], -(x/2)**2):
  4. hypergeom([3/2], [5/2, 5/2], -(x/2)**2):
  5. … (to be continued)
I have read something like How to simplify this hypergeometric function? - MaplePrimes, yet those tricks do not appear to work here. Is there any workaround?
Edit. There seems to be a bug in `simplify/hypergeom`:
'hypergeom([-1/3, 1/3, -1/2 - m, -m], [1/2, 1/3 - m, 2/3 - m], 1)':
simplify(`%`, hypergeom) assuming m::nonnegint;
                               -1
simplify(eval(`%%`, m = 0), 'constant');
The expected result should be a piecewise function.
I looked up
https://www.maplesoft.com/Applications/TopApplications.aspx
and scrolled. Often, when a new batch of applications is loaded the scroll repositions arbitrarily. Is it my browser? How do I control this?
Hello. I'm trying to model the pharmacodynamics of salicylic acid with two body comportants, SA1 and SA2. At t=1, I wish to inject a single pulse of salicylic acid in the system, so that the variable Inj is equal to Dose for t=1 and equal to zero for any other time t.
But dsolve doesn't seem to take into account this "ifelse" nature of Inj, and as a result, it yields the wrong solution where SA1 and SA2 remain at the initial condition zero throughout. How can I fix this? Here's my code:
k12:=0.0452821;
k21:=0.0641682;
k1x:=0.00426118;
Dose:=484;
Inj:=ifelse(t=1,Dose,0);
ode_sys:=diff(SA2(t),t)=SA1(t)*k12-SA2(t)*k21,diff(SA1(t),t)=Inj-k1x*SA1(t);
ics:=SA2(0)=0,SA1(0)=0;
Solution1:=dsolve({ode_sys,ics},{SA1(t),SA2(t)},type=numeric);
plots:-odeplot(Solution1,[[t,SA1(t),color="red",thickness=1],[t,SA2(t),color="blue",thickness=1]],t=0..500,labels=["Time t","Salicylic acid"],labeldirections=[horizontal,vertical]);
It finds a solution where SA1 and SA2 remain zero throughout, whereas due to the single pulse of salicylic acid, they should be non-zero.
I also tried: Solution1:=dsolve({ode_sys,ics},{SA1(t),SA2(t)},type=numeric,parameters=[Inj=ifelse(t=1,Dose,0)]); but here I get an error message
Can you help? Many thanks. I'm still learning Maple with the book "Mathematische Probleme lösen mit Maple", and now also with the site gould.prof/learning-maple
Maple does not have full_simplify() command like with Mathematica.
So I figured why not make one?
Here is a basic implementation. All what it does is blindly tries different simplifications methods I know about and learned from this forum then at the end sorts the result by leaf count and returns to the user the one with smallest leaf count.
I tried it on few inputs.
Advantage of full_simplify() is that user does not have to keep trying themselves. One disadvantage is that this can take longer time. timelimit can be added to this to make it not hang.
Can you see and make more improvement to this function?
May be we all together can make a better full_simplify() in Maple to use. Feel free to edit and change.
#version 1.0
#increment version number each time when making changes.
full_simplify:=proc(e::anything)
   local result::list;
   local f:=proc(a,b)
      RETURN(MmaTranslator:-Mma:-LeafCount(a)<MmaTranslator:-Mma:-LeafCount(b))
   #add more methods as needed
   result:=[simplify(e),
            simplify(e,size),
            simplify(combine(e)),
            simplify(combine(e),size),
            radnormal(evala( combine(e) )),
            simplify(evala( combine(e) )),
            evala(radnormal( combine(e) )),
            simplify(radnormal( combine(e) )),
            evala(factor(e)),
            simplify(e,ln),
            simplify(e,power),
            simplify(e,RootOf),
            simplify(e,sqrt),
            simplify(e,trig),
            simplify(convert(e,trig)),
            simplify(convert(e,exp)),
            combine(e)
   RETURN( sort(result,f)[1]);
worksheet below
204648
#version 1.0
   local result::list;
   local f:=proc(a,b)
            simplify(e,size),
            evala(factor(e)),
            simplify(e,ln),
            simplify(e,power),
            simplify(e,RootOf),
            simplify(e,sqrt),
            simplify(e,trig),
            combine(e)
#test cases
T:=[(-192*cos(t)^6 + 288*cos(t)^4 - 912*cos(t)^3 - 108*cos(t)^2 + 684*cos(t) - 54)/(4608*cos(t)^9 - 10368*cos(t)^7 + 6208*cos(t)^6 + 7776*cos(t)^5 - 9312*cos(t)^4 - 2440*cos(t)^3 + 3492*cos(t)^2 + 372*cos(t) - 1169),
(10*(5+sqrt(41)))/(sqrt(70+10*sqrt(41))*sqrt(130+10*sqrt(41))),
((6-4*sqrt(2))*ln(3-2*sqrt(2))+(3-2*sqrt(2))*ln(17-12*sqrt(2))+32-24*sqrt(2))/(48*sqrt(2)-72)*(ln(sqrt(2)+1)+sqrt(2))/3,
(1/2)*exp((1/2)*x)*(cosh((1/2)*x)-cosh((3/2)*x)+sinh((1/2)*x)+sinh((3/2)*x))
[(-192*cos(t)^6+288*cos(t)^4-912*cos(t)^3-108*cos(t)^2+684*cos(t)-54)/(4608*cos(t)^9-10368*cos(t)^7+6208*cos(t)^6+7776*cos(t)^5-9312*cos(t)^4-2440*cos(t)^3+3492*cos(t)^2+372*cos(t)-1169), 10*(5+41^(1/2))/((70+10*41^(1/2))^(1/2)*(130+10*41^(1/2))^(1/2)), (1/3)*((6-4*2^(1/2))*ln(3-2*2^(1/2))+(3-2*2^(1/2))*ln(17-12*2^(1/2))+32-24*2^(1/2))*(ln(1+2^(1/2))+2^(1/2))/(48*2^(1/2)-72), (1/2)*exp((1/2)*x)*(cosh((1/2)*x)-cosh((3/2)*x)+sinh((1/2)*x)+sinh((3/2)*x))]
full_simplify~(T)
[-6*(10+cos(6*t)+38*cos(3*t))/(-975+18*cos(9*t)-70*cos(3*t)+194*cos(6*t)), (1/2)*2^(1/2), (1/9)*(ln(1+2^(1/2))+2^(1/2))^2, (1/2)*exp(x)-(1/2)*exp(-x)]
Download full_simplify.mw
In a homework assignment on differential geometry, a student used Mathematica to calculate the torsion of a trefoil curve.  His result, using identical steps as mine, was significantly simpler than what I had gotten with Maple, although as we see in the attached workseet, they are mathematically equivalent.
Is there a way to coax Maple to reduce its result to something like my student has obtained?
My calculation
T1 := (-192*cos(t)^6 + 288*cos(t)^4 - 912*cos(t)^3 - 108*cos(t)^2 + 684*cos(t) - 54)/(4608*cos(t)^9 - 10368*cos(t)^7 + 6208*cos(t)^6 + 7776*cos(t)^5 - 9312*cos(t)^4 - 2440*cos(t)^3 + 3492*cos(t)^2 + 372*cos(t) - 1169);
The student's calculation
T2 := 6*(10+38*cos(3*t)+cos(6*t))/(975+70*cos(3*t)-194*cos(6*t) -18*cos(9*t));
6*(10+38*cos(3*t)+cos(6*t))/(975+70*cos(3*t)-194*cos(6*t)-18*cos(9*t))
simplify(T1 - T2);
Download torsion2.mw
First 126 127 128 129 130 131 132 Last Page 128 of 2430
