Please could someone explain the background and motivation for using evalhf, and its scope and limitations.
I am not a computer scientist and only have a rudimentary knowledge regarding computer hardware, so the idea of the "hardware float" is abstract and not at all clear to me.
I have tried to go through the page https://www.maplesoft.com/support/help/maple/view.aspx?path=evalhf, but things like "double precision" do not mean anything to me.
Any comments or discussion, or direction to articles aimed at the novice, about what the evalhf instruction does would be much appreciated.
Season's Greetings!
Mikey
A case where simplify(...) and simplify~(...) both return the wrong result.
Should we consider this a simplify bug?
A simple case
J := Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity)
     Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity)
(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity))
# OK
op(1, J) = simplify(op(1, J))
Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity) = Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity)
# OK
op(2, J) = simplify(op(2, J))
Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity) = Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity)
# But...
# Not OK
simplify(J)
(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[1]^2*varphi[2](r[1]), r[1] = -infinity .. infinity))
# Not OK
simplify~(J)
# OK
map(simplify, J)
A slightly more complex case
J := (Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity))-(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[2]*varphi[2](r[2]), r[2] = -infinity .. infinity))^2;
is(J=simplify(J))
is(J=simplify~(J))
is(J=map(simplify, J));
map(simplify, J);
(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[1]^2*varphi[2](r[1]), r[1] = -infinity .. infinity))-(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[1]*varphi[2](r[1]), r[1] = -infinity .. infinity))^2
add(map(u -> map(simplify, u), [op(J)]));
is(J=%);
Download Simplify_is_wrong.mw
Good Morning Sir. How to get the series of g(x).I couldn't get  it.
AGM.mw
Please help to plot this equation
fwf-v.mw
I am a beginner using Maple 18. In the procedure I am analyzing, the result is 0.*I. This result means that the procedure cannot be completed until the end, displaying the graph. I am attaching Maple worksheet. Please help me solve this problem.
Capillarity.mw
Maple does not give solution to this first order ode with IC, if asked to do it implicit. It only solves it explicit.
ode := diff(y(x), x) - 2*(2*y(x) - x)/(x + y(x)) = 0;
ic:=y(0)=2;
dsolve([ode,ic],'implicit'); #maple gives no solution when implicit!
Then I asked Maple for an implicit solution but with no IC. Then solved for the constant of integration myself, and plugged this back in the solution. But odetest now says the initial conditions do not verify.
Here are the steps I did to solve for the constant of integration. I do not see any error I made. Does any one see where my error is and why odetest does not verify the solution for IC?
This first order ode has unique solution. Here is my worksheet.
35220
ic:=y(0)=2;
diff(y(x), x)-2*(2*y(x)-x)/(x+y(x)) = 0
y(0) = 2
#lets now try finding the constant of integration ourself
sol:=dsolve(ode,'implicit')
2*ln(-(-y(x)+x)/x)-3*ln(-(-y(x)+2*x)/x)-ln(x)-c__1 = 0
#setup equation and plugin the IC. Raise both sides to exp. RHS becomes 1
eq:=exp(lhs(sol))=1;
exp(2*ln(-(-y(x)+x)/x)-3*ln(-(-y(x)+2*x)/x)-ln(x)-c__1) = 1
simplify(eq,exp);
(y(x)-x)^2*exp(-c__1)/(y(x)-2*x)^3 = 1
#plugin in y=2 at x=0
eval(%,[y(x)=2,x=0]);
(1/2)*exp(-c__1) = 1
#solve for constant of integration
solve(%,c__1)
-ln(2)
#subtitute back in the solution
sol:=eval(sol,c__1=%);
2*ln(-(-y(x)+x)/x)-3*ln(-(-y(x)+2*x)/x)-ln(x)+ln(2) = 0
#verify. Why it failed check on IC?? Notice it is not [0,0].
odetest(sol,[ode,ic])
[0, 2]
Download why_fails_to_verify.mw
I bought Maple 2023 student version. (I am student) and installed it on windows 10.
I wanted to try it on Linux to see if runs better. So Installed the Linux version. When I tried to activate using the same purchase code I got, I get error that I have no more activations or I exceeded the number of activations.
But I installed Maple 2023 only one time, on windows which is my main OS. Never installed it anywhere else before.
Is one really only allowed one installation?
How would then I can try Maple on Linux but keep my Maple on windows until I decide if Maple works better on Linux or not?
Please, I need your help. I want to plot the spectrum of a dataset in #Problem 1.
In #Problem 2 If it is possible, how can I convert that function from the time domain to the frequency domain?
Fourier_transform.mw
I would like to apply the pappus theorem to an ellipse. Pascale's theorem
How to insert a condition in the final graph to display the parabola, its vertex, the axis of symmetry, and the roots (if they exist), and only display the parabola, the vertex, and its axis of symmetry otherwise. Thank you for your insights
S5AléatoireParaboleSommetGraphe.mw
Greetings! I need a maple code of logarithm of residuals for graphical comparison of iterative methods. Can anyone help me out by sharing a code comparing log of residuals of 2 or 3 iterative methods?
I think the GF function, input, accepts out-of-range inputs.
From ?GF: The G:-input and G:-output commands convert from an integer in the range
  "0 .. p^k - 1" to the corresponding polynomial and back
GF_strange.mw
The first GF was from a typo. I think it should have produced an error message, according to help.
If I understand correctly, GF(7,1) should only have 7 members.
The second GF is to allow the input 28856.
Tom Dean
This first order ode is quadrature with initial conditions. By existence theorem it has solution and is unique on some interval that includes the initial conditions (because f and f_y  are continuous on the initial condition).
But for some reason Maple can't find the solution, unless one adds 'implicit' option. Why is that? I thought that Maple will automatically return implicit solution if can't find explicit solution.
So does one then needs to try with implicit solution again if no solution is returned? I am basically asking if this is expected behavior of dsolve.
Below is worksheet also with the solution that Maple verifies is valid and satisfies the ode and also initial conditions.
ode:=diff(y(x), x) = sin(y(x)) + 1;
ic:=y(0)=Pi;
sol:=dsolve([ode,ic]);
20212
`The "Physics Updates" version in the MapleCloud is 1618 and is the same as the version installed in this computer, created 2023, November 29, 17:28 hours Pacific Time.`
ic:=y(0)=Pi;
diff(y(x), x) = sin(y(x))+1
y(0) = Pi
maple_sol:=dsolve([ode,ic],'implicit');
odetest(maple_sol,[ode,ic])
(2+x*tan((1/2)*y(x))+x)/(tan((1/2)*y(x))+1) = 0
[0, 0]
maple_sol:=dsolve([ode,ic],y(x),'explicit');
mysol:=y(x)=2*arccos(-x/(sqrt(4+4*x+2*x^2)));
odetest(mysol,[ode,ic]) assuming x>=0
y(x) = 2*Pi-2*arccos(x/(2*x^2+4*x+4)^(1/2))
[0, 0]
Download unable_to_dsolve_quadature_dec_22_2023.mw
Why does
eq:=Z^2=y/x;
solve(eq,Z)
give
I never told maple that y>=0 and x>=0 ?   I was expecting what we will do by hand. which is
Note that sqrt(x*y) is same as sqrt(x)*sqrt(y) only when y and x are not negative.
Is there an option to make Maple not do this and give same result as above? I tried PDEtools:-Solve and it gives same solution as solve.
Maple 2023.2.1 on windows 10
First 146 147 148 149 150 151 152 Last Page 148 of 2430
