I am trying to write a procedure that takes two intervals of real numbers (in interval notation) and checks if one is a subset of the other. For example, isSubset([-5,2],[-10,infinity)) would return true, but isSubset([-5,2],(-5,infinity)) would return false. Any idea how to go about this? I am having difficulty knowing where to start.
I have an equation, I would like to collect or regroup all similar terms
MCode.mw
Hello!!
Matrice: (x,y)=(-2,-3),(-1,2),(3,4),(1,-2)
When plotting 3 lines with points are ok, but the fourth line os missing! All 4 points are there
How to include the 4th line?
Kjell
For instance, “[1, 2, 3]”, “[``([1, 2]), uneval([3])]”, and “[[1, 2], [3, 'NULL']]” are fully rectangular. “[1, 2, [3]]”, “[`[]`(1, 2), [3]]”, and “[[1, 2], [3, NULL]]” are considered nonrectangular, but if we temporarily freeze the "ragged" parts or regard them as a depth-1 container, the corresponding expressions will seem rectangular. `type(…, list(Non(list)))` and `type(…, listlist(Non(list)))` check these, but they do not work for general cases.
To be specific, the desired output should be something like
IsRectangular([[[l, 2], [3, 4]], [[5, 6], [7, 8]]]);
                            true, 3
IsRectangular([[[O, l, 2], [3, 4]], [[5, 6], [7, 8]]]);
                            false, 2
IsRectangular([[[[l], 2], [3, 4]], [[5, 6], [7, 8]]], 3);
                            true, 3
IsRectangular([[O, [l, 2], [3, 4]], [[5, 6], [7, 8]]], 2);
                            false, 1
The results above can be obtained by some observations. However, if the input has deeper levels, evaluating this will be a punishing work:
test__1 := [[[[[[[[-288],[-287],[-286]],[[-285],[-284],[-283]],[[-282],[-281],[-280]],[[-279],[-278],[-277]]]],[[[[-276],[-275],[-274]],[[-273],[-272],[-271]],[[-270],[-269],[-268]],[[-267],[-266],[-265]]]],[[[[-264],[-263],[-262]],[[-261],[-260],[-259]],[[-258],[-257],[-256]],[[-255],[-254],[-253]]]]],[[[[[-252],[-251],[-250]],[[-249],[-248],[-247]],[[-246],[-245],[-244]],[[-243],[-242],[-241]]]],[[[[-240],[-239],[-238]],[[-237],[-236],[-235]],[[-234],[-233],[-232]],[[-231],[-230],[-229]]]],[[[[-228],[-227],[-226]],[[-225],[-224],[-223]],[[-222],[-221],[-220]],[[-219],[-218],[-217]]]]]],[[[[[[-216],[-215],[-214]],[[-213],[-212],[-211]],[[-210],[-209],[-208]],[[-207],[-206],[-205]]]],[[[[-204],[-203],[-202]],[[-201],[-200],[-199]],[[-198],[-197],[-196]],[[-195],[-194],[-193]]]],[[[[-192],[-191],[-190]],[[-189],[-188],[-187]],[[-186],[-185],[-184]],[[-183],[-182],[-181]]]]],[[[[[-180],[-179],[-178]],[[-177],[-176],[-175]],[[-174],[-173],[-172]],[[-171],[-170],[-169]]]],[[[[-168],[-167],[-166]],[[-165],[-164],[-163]],[[-162],[-161],[-160]],[[-159],[-158],[-157]]]],[[[[-156],[-155],[-154]],[[-153],[-152],[-151]],[[-150],[-149],[-148]],[[-147],[-146],[-145]]]]]],[[[[[[-144],[-143],[-142]],[[-141],[-140],[-139]],[[-138],[-137],[-136]],[[-135],[-134],[-133]]]],[[[[-132],[-131],[-130]],[[-129],[-128],[-127]],[[-126],[-125],[-124]],[[-123],[-122],[-121]]]],[[[[-120],[-119],[-118]],[[-117],[-116],[-115]],[[-114],[-113],[-112]],[[-111],[-110],[-109]]]]],[[[[[-108],[-107],[-106]],[[-105],[-104],[-103]],[[-102],[-101],[-100]],[[-99],[-98],[-97]]]],[[[[-96],[-95],[-94]],[[-93],[-92],[-91]],[[-90],[-89],[-88]],[[-87],[-86],[-85]]]],[[[[-84],[-83],[-82]],[[-81],[-80],[-79]],[[-78],[-77],[-76]],[[-75],[-74],[-73]]]]]],[[[[[[-72],[-71],[-70]],[[-69],[-68],[-67]],[[-66],[-65],[-64]],[[-63],[-62],[-61]]]],[[[[-60],[-59],[-58]],[[-57],[-56],[-55]],[[-54],[-53],[-52]],[[-51],[-50],[-49]]]],[[[[-48],[-47],[-46]],[[-45],[-44],[-43]],[[-42],[-41],[-40]],[[-39],[-38],[-37]]]]],[[[[[-36],[-35],[-34]],[[-33],[-32],[-31]],[[-30],[-29],[-28]],[[-27],[-26],[-25]]]],[[[[-24],[-23],[-22]],[[-21],[-20],[-19]],[[-18],[-17],[-16]],[[-15],[-14],[-13]]]],[[[[-12],[-11],[-10]],[[-9],[-8],[-7]],[[-6],[-5],[-4]],[[-3],[-2],[-1],[-0]]]]]]],[[[[[[[0],[1],[2]],[[3],[4],[5]],[[6],[7],[8]],[[9],[10],[11]]]],[[[[12],[13],[14]],[[15],[16],[17]],[[18],[19],[20]],[[21],[22],[23]]]],[[[[24],[25],[26]],[[27],[28],[29]],[[30],[31],[32]],[[33],[34],[35]]]]],[[[[[36],[37],[38]],[[39],[40],[41]],[[42],[43],[44]],[[45],[46],[47]]]],[[[[48],[49],[50]],[[51],[52],[53]],[[54],[55],[56]],[[57],[58],[59]]]],[[[[60],[61],[62]],[[63],[64],[65]],[[66],[67],[68]],[[69],[70],[71]]]]]],[[[[[[72],[73],[74]],[[75],[76],[77]],[[78],[79],[80]],[[81],[82],[83]]]],[[[[84],[85],[86]],[[87],[88],[89]],[[90],[91],[92]],[[93],[94],[95]]]],[[[[96],[97],[98]],[[99],[100],[101]],[[102],[103],[104]],[[105],[106],[107]]]]],[[[[[108],[109],[110]],[[111],[112],[113]],[[114],[115],[116]],[[117],[118],[119]]]],[[[[120],[121],[122]],[[123],[124],[125]],[[126],[127],[128]],[[129],[130],[131]]]],[[[[132],[133],[134]],[[135],[136],[137]],[[138],[139],[140]],[[141],[142],[143]]]]]],[[[[[[144],[145],[146]],[[147],[148],[149]],[[150],[151],[152]],[[153],[154],[155]]]],[[[[156],[157],[158]],[[159],[160],[161]],[[162],[163],[164]],[[165],[166],[167]]]],[[[[168],[169],[170]],[[171],[172],[173]],[[174],[175],[176]],[[177],[178],[179]]]]],[[[[[180],[181],[182]],[[183],[184],[185]],[[186],[187],[188]],[[189],[190],[191]]]],[[[[192],[193],[194]],[[195],[196],[197]],[[198],[199],[200]],[[201],[202],[203]]]],[[[[204],[205],[206]],[[207],[208],[209]],[[210],[211],[212]],[[213],[214],[215]]]]]],[[[[[[216],[217],[218]],[[219],[220],[221]],[[222],[223],[224]],[[225],[226],[227]]]],[[[[228],[229],[230]],[[231],[232],[233]],[[234],[235],[236]],[[237],[238],[239]]]],[[[[240],[241],[242]],[[243],[244],[245]],[[246],[247],[248]],[[249],[250],[251]]]]],[[[[[252],[253],[254]],[[255],[256],[257]],[[258],[259],[260]],[[261],[262],[263]]]],[[[[264],[265],[266]],[[267],[268],[269]],[[270],[271],[272]],[[273],[274],[275]]]],[[[[276],[277],[278]],[[279],[280],[281]],[[282],[283],[284]],[[285],[286],[287]]]]]]]]:
test__2 := [[[[[[[[-288],[-287],[-286]],[[-285],[-284],[-283]],[[-282],[-281],[-280]],[[-279],[-278],[-277]]]],[[[[-276],[-275],[-274]],[[-273],[-272],[-271]],[[-270],[-269],[-268]],[[-267],[-266],[-265]]]],[[[[-264],[-263],[-262]],[[-261],[-260],[-259]],[[-258],[-257],[-256]],[[-255],[-254],[-253]]]]],[[[[[-252],[-251],[-250]],[[-249],[-248],[-247]],[[-246],[-245],[-244]],[[-243],[-242],[-241]]]],[[[[-240],[-239],[-238]],[[-237],[-236],[-235]],[[-234],[-233],[-232]],[[-231],[-230],[-229]]]],[[[[-228],[-227],[-226]],[[-225],[-224],[-223]],[[-222],[-221],[-220]],[[-219],[-218],[-217]]]]]],[[[[[[-216],[-215],[-214]],[[-213],[-212],[-211]],[[-210],[-209],[-208]],[[-207],[-206],[-205]]]],[[[[-204],[-203],[-202]],[[-201],[-200],[-199]],[[-198],[-197],[-196]],[[-195],[-194],[-193]]]],[[[[-192],[-191],[-190]],[[-189],[-188],[-187]],[[-186],[-185],[-184]],[[-183],[-182],[-181]]]]],[[[[[-180],[-179],[-178]],[[-177],[-176],[-175]],[[-174],[-173],[-172]],[[-171],[-170],[-169]]]],[[[[-168],[-167],[-166]],[[-165],[-164],[-163]],[[-162],[-161],[-160]],[[-159],[-158],[-157]]]],[[[[-156],[-155],[-154]],[[-153],[-152],[-151]],[[-150],[-149],[-148]],[[-147],[-146],[-145]]]]]],[[[[[[-144],[-143],[-142]],[[-141],[-140],[-139]],[[-138],[-137],[-136]],[[-135],[-134],[-133]]]],[[[[-132],[-131],[-130]],[[-129],[-128],[-127]],[[-126],[-125],[-124]],[[-123],[-122],[-121]]]],[[[[-120],[-119],[-118]],[[-117],[-116],[-115]],[[-114],[-113],[-112]],[[-111],[-110],[-109]]]]],[[[[[-108],[-107],[-106]],[[-105],[-104],[-103]],[[-102],[-101],[-100]],[[-99],[-98],[-97]]]],[[[[-96],[-95],[-94]],[[-93],[-92],[-91]],[[-90],[-89],[-88]],[[-87],[-86],[-85]]]],[[[[-84],[-83],[-82]],[[-81],[-80],[-79]],[[-78],[-77],[-76]],[[-75],[-74],[-73]]]]]],[[[[[[-72],[-71],[-70]],[[-69],[-68],[-67]],[[-66],[-65],[-64]],[[-63],[-62],[-61]]]],[[[[-60],[-59],[-58]],[[-57],[-56],[-55]],[[-54],[-53],[-52]],[[-51],[-50],[-49]]]],[[[[-48],[-47],[-46]],[[-45],[-44],[-43]],[[-42],[-41],[-40]],[[-39],[-38],[-37]]]]],[[[[[-36],[-35],[-34]],[[-33],[-32],[-31]],[[-30],[-29],[-28]],[[-27],[-26],[-25]]]],[[[[-24],[-23],[-22]],[[-21],[-20],[-19]],[[-18],[-17],[-16]],[[-15],[-14],[-13]]]],[[[[-12],[-11],[-10]],[[-9],[-8],[-7]],[[-6],[-5],[-4]],[[-3],[-2,0],[-0]]]]]]],[[[[[[[-1],[1],[2]],[[3],[4],[5]],[[6],[7],[8]],[[9],[10],[11]]]],[[[[12],[13],[14]],[[15],[16],[17]],[[18],[19],[20]],[[21],[22],[23]]]],[[[[24],[25],[26]],[[27],[28],[29]],[[30],[31],[32]],[[33],[34],[35]]]]],[[[[[36],[37],[38]],[[39],[40],[41]],[[42],[43],[44]],[[45],[46],[47]]]],[[[[48],[49],[50]],[[51],[52],[53]],[[54],[55],[56]],[[57],[58],[59]]]],[[[[60],[61],[62]],[[63],[64],[65]],[[66],[67],[68]],[[69],[70],[71]]]]]],[[[[[[72],[73],[74]],[[75],[76],[77]],[[78],[79],[80]],[[81],[82],[83]]]],[[[[84],[85],[86]],[[87],[88],[89]],[[90],[91],[92]],[[93],[94],[95]]]],[[[[96],[97],[98]],[[99],[100],[101]],[[102],[103],[104]],[[105],[106],[107]]]]],[[[[[108],[109],[110]],[[111],[112],[113]],[[114],[115],[116]],[[117],[118],[119]]]],[[[[120],[121],[122]],[[123],[124],[125]],[[126],[127],[128]],[[129],[130],[131]]]],[[[[132],[133],[134]],[[135],[136],[137]],[[138],[139],[140]],[[141],[142],[143]]]]]],[[[[[[144],[145],[146]],[[147],[148],[149]],[[150],[151],[152]],[[153],[154],[155]]]],[[[[156],[157],[158]],[[159],[160],[161]],[[162],[163],[164]],[[165],[166],[167]]]],[[[[168],[169],[170]],[[171],[172],[173]],[[174],[175],[176]],[[177],[178],[179]]]]],[[[[[180],[181],[182]],[[183],[184],[185]],[[186],[187],[188]],[[189],[190],[191]]]],[[[[192],[193],[194]],[[195],[196],[197]],[[198],[199],[200]],[[201],[202],[203]]]],[[[[204],[205],[206]],[[207],[208],[209]],[[210],[211],[212]],[[213],[214],[215]]]]]],[[[[[[216],[217],[218]],[[219],[220],[221]],[[222],[223],[224]],[[225],[226],[227]]]],[[[[228],[229],[230]],[[231],[232],[233]],[[234],[235],[236]],[[237],[238],[239]]]],[[[[240],[241],[242]],[[243],[244],[245]],[[246],[247],[248]],[[249],[250],[251]]]]],[[[[[252],[253],[254]],[[255],[256],[257]],[[258],[259],[260]],[[261],[262],[263]]]],[[[[264],[265],[266]],[[267],[268],[269]],[[270],[271],[272]],[[273],[274],[275]]]],[[[[276],[277],[278]],[[279],[280],[281]],[[282],[283],[284]],[[285],[286],[287]]]]]]]]:
test__3 := [[[[[[[[-288],[-287],[-286]],[[-285],[-284],[-283]],[[-282],[-281],[-280]],[[-279],[-278],[-277]]]],[[[[-276],[-275],[-274]],[[-273],[-272],[-271]],[[-270],[-269],[-268]],[[-267],[-266],[-265]]]],[[[[-264],[-263],[-262]],[[-261],[-260],[-259]],[[-258],[-257],[-256]],[[-255],[-254],[-253]]]]],[[[[[-252],[-251],[-250]],[[-249],[-248],[-247]],[[-246],[-245],[-244]],[[-243],[-242],[-241]]]],[[[[-240],[-239],[-238]],[[-237],[-236],[-235]],[[-234],[-233],[-232]],[[-231],[-230],[-229]]]],[[[[-228],[-227],[-226]],[[-225],[-224],[-223]],[[-222],[-221],[-220]],[[-219],[-218],[-217]]]]]],[[[[[[-216],[-215],[-214]],[[-213],[-212],[-211]],[[-210],[-209],[-208]],[[-207],[-206],[-205]]]],[[[[-204],[-203],[-202]],[[-201],[-200],[-199]],[[-198],[-197],[-196]],[[-195],[-194],[-193]]]],[[[[-192],[-191],[-190]],[[-189],[-188],[-187]],[[-186],[-185],[-184]],[[-183],[-182],[-181]]]]],[[[[[-180],[-179],[-178]],[[-177],[-176],[-175]],[[-174],[-173],[-172]],[[-171],[-170],[-169]]]],[[[[-168],[-167],[-166]],[[-165],[-164],[-163]],[[-162],[-161],[-160]],[[-159],[-158],[-157]]]],[[[[-156],[-155],[-154]],[[-153],[-152],[-151]],[[-150],[-149],[-148]],[[-147],[-146],[-145]]]]]],[[[[[[-144],[-143],[-142]],[[-141],[-140],[-139]],[[-138],[-137],[-136]],[[-135],[-134],[-133]]]],[[[[-132],[-131],[-130]],[[-129],[-128],[-127]],[[-126],[-125],[-124]],[[-123],[-122],[-121]]]],[[[[-120],[-119],[-118]],[[-117],[-116],[-115]],[[-114],[-113],[-112]],[[-111],[-110],[-109]]]]],[[[[[-108],[-107],[-106]],[[-105],[-104],[-103]],[[-102],[-101],[-100]],[[-99],[-98],[-97]]]],[[[[-96],[-95],[-94]],[[-93],[-92],[-91]],[[-90],[-89],[-88]],[[-87],[-86],[-85]]]],[[[[-84],[-83],[-82]],[[-81],[-80],[-79]],[[-78],[-77],[-76]],[[-75],[-74],[-73]]]]]],[[[[[[-72],[-71],[-70]],[[-69],[-68],[-67]],[[-66],[-65],[-64]],[[-63],[-62],[-61]]]],[[[[-60],[-59],[-58]],[[-57],[-56],[-55]],[[-54],[-53],[-52]],[[-51],[-50],[-49]]]],[[[[-48],[-47],[-46]],[[-45],[-44],[-43]],[[-42],[-41],[-40]],[[-39],[-38],[-37]]]]],[[[[[-36],[-35],[-34]],[[-33],[-32],[-31]],[[-30],[-29],[-28]],[[-27],[-26],[-25]]]],[[[[-24],[-23],[-22]],[[-21],[-20],[-19]],[[-18],[-17],[-16]],[[-15],[-14],[-13]]]],[[[[-12],[-11],[-10]],[[-9],[-8],[-7]],[[-6],[-5],[-4]],[[-3],[-2,-0]]]]]]],[[[[[[-1],[[1],[2]],[[3],[4],[5]],[[6],[7],[8]],[[9],[10],[11]]]],[[[[12],[13],[14]],[[15],[16],[17]],[[18],[19],[20]],[[21],[22],[23]]]],[[[[24],[25],[26]],[[27],[28],[29]],[[30],[31],[32]],[[33],[34],[35]]]]],[[[[[36],[37],[38]],[[39],[40],[41]],[[42],[43],[44]],[[45],[46],[47]]]],[[[[48],[49],[50]],[[51],[52],[53]],[[54],[55],[56]],[[57],[58],[59]]]],[[[[60],[61],[62]],[[63],[64],[65]],[[66],[67],[68]],[[69],[70],[71]]]]]],[[[[[[72],[73],[74]],[[75],[76],[77]],[[78],[79],[80]],[[81],[82],[83]]]],[[[[84],[85],[86]],[[87],[88],[89]],[[90],[91],[92]],[[93],[94],[95]]]],[[[[96],[97],[98]],[[99],[100],[101]],[[102],[103],[104]],[[105],[106],[107]]]]],[[[[[108],[109],[110]],[[111],[112],[113]],[[114],[115],[116]],[[117],[118],[119]]]],[[[[120],[121],[122]],[[123],[124],[125]],[[126],[127],[128]],[[129],[130],[131]]]],[[[[132],[133],[134]],[[135],[136],[137]],[[138],[139],[140]],[[141],[142],[143]]]]]],[[[[[[144],[145],[146]],[[147],[148],[149]],[[150],[151],[152]],[[153],[154],[155]]]],[[[[156],[157],[158]],[[159],[160],[161]],[[162],[163],[164]],[[165],[166],[167]]]],[[[[168],[169],[170]],[[171],[172],[173]],[[174],[175],[176]],[[177],[178],[179]]]]],[[[[[180],[181],[182]],[[183],[184],[185]],[[186],[187],[188]],[[189],[190],[191]]]],[[[[192],[193],[194]],[[195],[196],[197]],[[198],[199],[200]],[[201],[202],[203]]]],[[[[204],[205],[206]],[[207],[208],[209]],[[210],[211],[212]],[[213],[214],[215]]]]]],[[[[[[216],[217],[218]],[[219],[220],[221]],[[222],[223],[224]],[[225],[226],[227]]]],[[[[228],[229],[230]],[[231],[232],[233]],[[234],[235],[236]],[[237],[238],[239]]]],[[[[240],[241],[242]],[[243],[244],[245]],[[246],[247],[248]],[[249],[250],[251]]]]],[[[[[252],[253],[254]],[[255],[256],[257]],[[258],[259],[260]],[[261],[262],[263]]]],[[[[264],[265],[266]],[[267],[268],[269]],[[270],[271],[272]],[[273],[274],[275]]]],[[[[276],[277],[278]],[[279],[280],[281]],[[282],[283],[284]],[[285],[286],[287]]]]]]]]:
Is there a generalized test procedure (e.g., ListTools:-IsRectangular) that effectively works for any nested list of an arbitrary nesting level?
HI every one ! i want to know how can i calculate tt component and rr component in Einstein eq or Energy-Momentum eq.please give me a cod for drive component of any equation in maple
Pr:=0.71: n:=-1:
eta0:=0.0699;
EQ1:=diff(H(x), x ) - x*diff(F(x), x ) ;
EQ2:=(1+x^2)*diff(F(x), x$2) + (3*x + x*F(x)-H(x))*diff(F(x), x) + F(x)^2 + G(x)^2 +2*P(x) + x*diff(P(x), x) ;
EQ3:=(1+x^2)*diff(G(x), x$2) + (3*x + x*F(x)-H(x))*diff(G(x), x) ;
EQ4:=(1+x^2)*diff(H(x), x$2) + (3*x + x*F(x)-H(x))*diff(H(x), x) + (1+F(x))*H(x)- diff(P(x), x);
EQ5:=(1+x^2)*diff(theta(x), x$2) + x*(1-2*n)*diff(theta(x), x) + n^2*theta(x) - Pr*( n*F(x)*theta(x) + ( H(x)-x*F(x) )*diff(theta(x), x)  ) ;
EQ:={EQ1=0, EQ2=0,EQ3=0,EQ4=0 ,EQ5=0}:
IC:={ F(0)=0, G(0)=12, H(0)=0, theta(0)= 1, F(eta0)=0, G(eta0)=12, H(eta0)=0, theta(eta0)= 0, P(0)=0};
sol:= dsolve(EQ union IC,numeric,output=Array([0,0.0699]));
ques.mw
This is most likely a simple question for the power users of this forum, but I do not manage to find a solution. I have date in an Excel file. The first column consists of dates (mm/dd/yyyy) and the second of time (hh:mm). I can easily concatenate both in Maple using cat("9/7/2023", "10:22") but how can I convert the obtained string into a date+time that Maple understands?
I create a system of equations (with 9 linear equations and 7 variables).
I get 7 equations from the multiplication of a matrix M with a transposed vector of the 7 variables equals the transposed vector of the 7 variables. Other two simple equations are necessary because they are restrictions. Those two equations a re very simple and thave the 7 variable sin it.
To start I have been trying with fsolve but i haven't been able to solve it yet, as I also get the error: "Error, (in fsolve) number of equations, 9, does not match number of variables, 7"
Have you andy idea to solve this problem? Thanks in advance.
Below is the plot like I want it. The basic plot has been done with a simple plot command.
>plot(0, x = 0 .. 10, y = 0 .. 4, gridlines = true)
But the label of each axis was done manually. But I have tried to do it inside the plot command. A little help would be very appreciated.
So here is what I want the plot to look like:
Thank you in advance for the help.
Mario
Hi everyone,
Do you know if there are some known codes for plotting pseudospectra of squared (and finite) matrices with given spectrum ?
Best,
Rachid
What will be the range of p and q to get the plot and to get the optimum solution?
If possible get a solution for particular value of p and q.
file attached: q1.mw
Hi all, any one help  me to find the values of constants by using given condition and then how to varify that the goiven condition varify the expression. I have found manually but want to varify through maple.
help.mw
I have a list:
mylist := [x^4 + (-4*m - 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, x^4 + (-4*m - 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, x^4 + (-4*m - 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, x^4 + (-4*m - 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, x^4 + (-4*m - 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, x^4 + (-4*m - 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x]
I use
L := map~(normal, mylist);
and get.
L := [x^4 - (4*m + 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, x^4 - (4*m + 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, x^4 - (4*m + 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, x^4 - (4*m + 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x].
I use seq to list L[i] and diff(L[i])
[seq([L[i], diff(L[i], x)], i = 1 .. nops(L))];
and get
[[x^4 - (4*m + 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 4)*x + 3*m - 5], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 5*m - 7], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 7*m - 5], [x^4 - (4*m + 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(2*m + 5)*x + 3*m - 5], [x^4 - (4*m + 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(3*m + 1)*x + 7*m - 10], [x^4 - (4*m + 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x, 4*x^3 - 3*(4*m + 5)*x^2 + 2*(2*m + 1)*x + 7*m - 9]]
How can I insert L'(2), L''(2) and solve the systems L'(2) = 0 and L''(2) > 0 to get the solutions m?
like this
[seq([L[i], diff(L[i], x), solve([L'(2) = 0,L''(2)>0],m) ], i = 1 .. nops(L))]
I also tried
[seq([L[i], diff(L[i], x), eval(diff(L[i], x), x = 2), solve([eval(diff(L[i], x), x = 2) = 0], m)], i = 1 .. nops(L))]
to obtain
[[x^4 - (4*m + 7)*x^3 + (m + 4)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 4)*x + 3*m - 5, -41 - 41*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (5*m - 7)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 5*m - 7, -39 - 39*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (m + 5)*x^2 + (7*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(m + 5)*x + 7*m - 5, -37 - 37*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (2*m + 5)*x^2 + (3*m - 5)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(2*m + 5)*x + 3*m - 5, -37 - 37*m, {m = -1}], [x^4 - (4*m + 7)*x^3 + (3*m + 1)*x^2 + (7*m - 10)*x, 4*x^3 - 3*(4*m + 7)*x^2 + 2*(3*m + 1)*x + 7*m - 10, -58 - 29*m, {m = -2}], [x^4 - (4*m + 5)*x^3 + (2*m + 1)*x^2 + (7*m - 9)*x, 4*x^3 - 3*(4*m + 5)*x^2 + 2*(2*m + 1)*x + 7*m - 9, -33 - 33*m, {m = -1}]]
I need to extract the list of all powers present in multivariable polynomial. For example, for x+y+x^2y^2+y^d I want to get the list [(1,0),(0,1),(2,2),(0,d)]. How to perform this?
First 175 176 177 178 179 180 181 Last Page 177 of 2431
