Can you change f(eta) to upflow curve and theta(eta) to downflow curve.
In my Problem,Boundary Conditions are
theta(infinity) = 0, (D(f))(infinity) = 1 , (Take, eta =infinity)
Flows will be correct for what value is taken for infinity .
I take  eta = 5. and also tried changing ranges  but could't find it.Please Help to fix the curve.
my code is,
SM.mw
I am creating a random question about the trigonometric form of a complex number. My correction code does not accept all possible amplitudes for the argument (for example, it does not accept 13Pi/6 for an argument of Pi/6). Any ideas on how to fix the code?
QComplexCis.mw
Is there a viewer in Maple to view the .mw files within the Windows or Maple directory [or alternative OS environment], not unlike a pdf or MS Word viewer?
It would make it a lot easier to check through working files without having to load all of them into the system, particulary for developmental work.
regards, RH
I am trying to find three integer a, b, c so that equation (x-a)^4 + (x-b)^4 = c has four different solutions integer x. I tried
k := 0;
for a from -10 to 10 do
    for b from -10 to 10 do
for c from -10 to 10 do
if a*b*c <> 0 and igcd(a, b) = 1 then X := [solve((x - a)^4 + (x - b)^4 = c, x)]; if type(X[1], integer) and type(X[2], integer) and type(X[3], integer) and type(X[4], integer) and nops({X[1], X[2], X[3], X[4]}) = 4 then k := k + 1; L[k] := [a, b, c, X[]]; end if; end if; end do; end do;
L := convert(L, list);
k;
L;
I do not get any solution
In a recent question/conversation, I had discussed integrating dsolve/numeric-based codes with NLPsolve at
https://www.mapleprimes.com/questions/236494-Inconsistent-Behavior-With-Dsolvenumeric-And-NLPSolve-sqp
@acer was able to help resolve the issue by calling NLPSolve with higher optimality tolerance.
I am starting a new question/post to show the need for evalhf as the previous post takes too long to load.
Code is attached for the same.
currentdir();
"C:\Users\Venkat\OneDrive - The University of Texas at Austin\Documents\trial\Learnningsqpoptim"
Test code written by Dr. Venkat Subramanian at UT Austin, 05/31/2023 and has been updated multiple times. This code uses CVP approach (piecwise constant) to perform optimal control. NLPSolve combination with RK2 approach to integrate ODEs (constant step size) works well for this problem. But dsolve numeric based codes work (with optimality tolerance fix from acer), but cannot handle large values of nvar (optimization variables).
Digits:=15;
15
eqodes:=[diff(ca(t),t)=-(u+u^2/2)*1.0*ca(t),diff(cb(t),t)=1.0*u*ca(t)-0.1*cb(t)];
[diff(ca(t), t) = -1.0*(u+(1/2)*u^2)*ca(t), diff(cb(t), t) = 1.0*u*ca(t)-.1*cb(t)]
soln:=dsolve({op(eqodes),ca(0)=alpha,cb(0)=beta},type=numeric,'parameters'=[alpha,beta,u],savebinary=true):
Note that Vector or Array form can be used for RK2h to implement the procedure for any number of variables/ODEs. But the challenge will be when implicit methods are used to integrate ODEs/DAEs and running them in evalhf form (this can be done with Gauss elimination type linear solver, but this will be limited to small number of ODEs/DAEs say 200 or so).
RK2h:=proc(NN,u,dt,y0::Vector(datatype=float[8]))#this procedure can be made efficient in vector form
local j,c1mid,c2mid,c10,c20,c1,c2;
option hfloat;
c10:=y0[1];c20:=y0[2];
for j from 1 to NN do
  c1mid:=c10+dt/NN*(-(u+u^2/2)*c10):
  c2mid:=c20+dt/NN*(u*c10)-0.1*dt/NN*c20:
  c1:=c10/2+c1mid/2+dt/NN/2*(-(u+u^2/2)*c1mid):
  c2:=c20/2+c2mid/2+dt/NN/2*(u*c1mid)-0.1*dt/NN/2*c2mid:
  c10:=c1:c20:=c2:
y0[1]:=c10:y0[2]:=c20:
soln('parameters'=[1,0,0.1]);soln(0.1);
[alpha = 1., beta = 0., u = .1]
[t = .1, ca(t) = HFloat(0.9895549324188543), cb(t) = HFloat(0.009898024276129616)]
ssdsolve:=proc(x)
interface(warnlevel=0):
#if  type(x,Vector)#if type is not needed for this problem, might be needed for other problems
#then
local z1,n1,i,c10,c20,dt,u;
global soln,nvar;
dt:=evalf(1.0/nvar):
c10:=1.0:c20:=0.0:
for i from 1 to nvar do
u:=x[i]:
soln('parameters'=[c10,c20,u]):
z1:=soln(dt):
c10:=subs(z1,ca(t)):c20:=subs(z1,cb(t)):
-c20;
 #else 'procname'(args):
#end if:
ssRK2:=proc(x)#based on RK2
#interface(warnlevel=0):
option hfloat;
#if  type(x,Vector)
#then
local z1,n1,i,c10,c20,dt,u,NN,y0;
global nvar,RK2h;
y0:=Array(1..2,[1.0,0.0],datatype=float[8]):
#y0[1]:=1.0:y0[2]:=0.0:
NN:=256*2/nvar;#NN is hardcode based on the assumption that nvar will be a multiple of 2 <=256
u:=x[i]:
evalhf(RK2h(NN,u,dt,y0)):
-y0[2];
#end if:
nvar:=2;
ic0:=Vector(nvar,[seq(0.1,i=1..nvar)],datatype=float):
bl := Vector(nvar,[seq(0.,i=1..nvar)],datatype=float):bu := Vector(nvar,[seq(5.,i=1..nvar)],datatype=float):
infolevel[Optimization]:=15;
15
CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],optimalitytolerance=1e-6)):
NLPSolve: calling NLP solver
NLPSolve: using method=sqp
NLPSolve: number of problem variables 2
NLPSolve: number of nonlinear inequality constraints 0
NLPSolve: number of nonlinear equality constraints 0
NLPSolve: number of general linear constraints 0
NLPSolve: feasibility tolerance set to 0.1053671213e-7
NLPSolve: optimality tolerance set to 0.1e-5
NLPSolve: iteration limit set to 50
NLPSolve: infinite bound set to 0.10e21
NLPSolve: trying evalhf mode
NLPSolve: trying evalf mode
attemptsolution: number of major iterations taken 11
memory used=0.96MiB, alloc change=0 bytes, cpu time=16.00ms, real time=121.00ms, gc time=0ns
Calling the procedures based on RK2 with NLPSolve uses evalf for numerical gradient (fdiff). Providing a procedure for gradient solves this issue.
gradRK2 := proc (x,g)
option hfloat;
local base, i, xnew, del;
global nvar,ssRK2;
xnew:=Array(1..nvar,datatype=float[8]):
base := ssRK2(x);
for i to nvar do
xnew[i] := x[i]; end do;
for i to nvar do
del := max(1e-5,.1e-6*x[i]);
xnew[i] := xnew[i]+del;
g[i] := (ssRK2(xnew)-base)/del;
xnew[i] := xnew[i]-del;
CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],objectivegradient=gradRK2,optimalitytolerance=1e-6)):
memory used=184.77KiB, alloc change=0 bytes, cpu time=31.00ms, real time=110.00ms, gc time=0ns
Significant saving in memory used is seen. CPU time is also less, which is more apparent at larger valeus of nvar.
dsolvenumeric based codes work for optimization, but evalf is invoked possibly for both the objective and gradient
CodeTools:-Usage(Optimization:-NLPSolve(nvar,(ssdsolve),[],initialpoint=ic0,[bl,bu],optimalitytolerance=1e-6)):
memory used=14.61MiB, alloc change=37.00MiB, cpu time=94.00ms, real time=213.00ms, gc time=46.88ms
Providing gradient procedure doesn't help with evalhf computaiton for dsolve/numeric based procedures.
graddsolve := proc (x,g)
global nvar,ssdsolve;
#xnew:=Vector(nvar,datatype=float[8]):
base := ssdsolve(x);
for i to nvar do
for i to nvar do
g[i] := (ssdsolve(xnew)-base)/del;
CodeTools:-Usage(Optimization:-NLPSolve(nvar,(ssdsolve),[],initialpoint=ic0,[bl,bu],objectivegradient=graddsolve,optimalitytolerance=1e-6)):
memory used=3.82MiB, alloc change=0 bytes, cpu time=31.00ms, real time=129.00ms, gc time=0ns
Calling both RK2 and dsolve based procedures again to check the values and computation meterics
s1RK2:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],objectivegradient=gradRK2,optimalitytolerance=1e-6)):
memory used=185.09KiB, alloc change=0 bytes, cpu time=16.00ms, real time=95.00ms, gc time=0ns
s1dsolve:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,ssdsolve,[],initialpoint=ic0,[bl,bu],objectivegradient=graddsolve,optimalitytolerance=1e-6)):
memory used=3.82MiB, alloc change=0 bytes, cpu time=31.00ms, real time=122.00ms, gc time=0ns
s1RK2[1];s1dsolve[1];
-.523900304316377463
-.523901163953022553
Next, a for loop is written to optimize for increasing values of nvar. One can see that evalhf is important for larger values of nvar. While dsolve/numeric is a superior code, not being able to use it in evalhf format is a significant weakness and should be addressed. Note that dsolve numeric evalutes procedures that are evaluated in evalhf or compiled form, so hopefully this is an easy fix.
infolevel[Optimization]:=0:
for j from 1 to 9 do
nvar:=2^(j-1):
soptRK[j]:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],objectivegradient=gradRK2,optimalitytolerance=1e-6)):
print(2^(j-1),soptRK[j][1]);
memory used=88.40KiB, alloc change=0 bytes, cpu time=0ns, real time=10.00ms, gc time=0ns
1, HFloat(-0.5008626988793192)
memory used=155.66KiB, alloc change=0 bytes, cpu time=16.00ms, real time=30.00ms, gc time=0ns
2, -.523900304316377463
memory used=175.36KiB, alloc change=0 bytes, cpu time=62.00ms, real time=80.00ms, gc time=0ns
4, -.535152497919956782
memory used=243.69KiB, alloc change=0 bytes, cpu time=156.00ms, real time=239.00ms, gc time=0ns
8, -.540546896131004706
memory used=260.09KiB, alloc change=0 bytes, cpu time=141.00ms, real time=260.00ms, gc time=0ns
16, -.542695734426874465
memory used=385.84KiB, alloc change=0 bytes, cpu time=313.00ms, real time=545.00ms, gc time=0ns
32, -.542932877726400531
memory used=0.65MiB, alloc change=0 bytes, cpu time=734.00ms, real time=1.18s, gc time=0ns
64, -.543011976841572652
memory used=1.24MiB, alloc change=0 bytes, cpu time=1.55s, real time=2.40s, gc time=0ns
128, -.543035276649319276
memory used=2.99MiB, alloc change=0 bytes, cpu time=3.45s, real time=5.92s, gc time=0ns
256, -.543041496228812814
for j from 1 to 6 do
nvar:=2^(j-1):
soptdsolve[j]:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalf(ssdsolve),[],initialpoint=ic0,[bl,bu],objectivegradient=graddsolve,optimalitytolerance=1e-6)):
print(2^(j-1),soptdsolve[j][1]);
memory used=0.66MiB, alloc change=0 bytes, cpu time=16.00ms, real time=11.00ms, gc time=0ns
1, HFloat(-0.5008631947224957)
memory used=3.79MiB, alloc change=0 bytes, cpu time=15.00ms, real time=52.00ms, gc time=0ns
2, -.523901163953022553
memory used=21.28MiB, alloc change=0 bytes, cpu time=78.00ms, real time=236.00ms, gc time=0ns
4, -.535153942647626391
memory used=144.82MiB, alloc change=-4.00MiB, cpu time=469.00ms, real time=1.60s, gc time=46.88ms
8, -.540549407239521607
memory used=347.30MiB, alloc change=16.00MiB, cpu time=1.27s, real time=3.45s, gc time=140.62ms
16, -.542699055038344258
memory used=1.33GiB, alloc change=-8.00MiB, cpu time=7.66s, real time=15.92s, gc time=750.00ms
32, -.542936165630524603
SS:=[seq(soptRK[j][1],j=1..9)];
[HFloat(-0.5008626988793192), -.523900304316377463, -.535152497919956782, -.540546896131004706, -.542695734426874465, -.542932877726400531, -.543011976841572652, -.543035276649319276, -.543041496228812814]
E1:=[seq(SS[i]-SS[i+1],i=1..nops(SS)-1)];
[HFloat(0.02303760543705824), 0.11252193603580e-1, 0.5394398211048e-2, 0.2148838295869e-2, 0.237143299527e-3, 0.79099115172e-4, 0.23299807746e-4, 0.6219579494e-5]
To get 6 Digits accuracy we need nvar = 256 which may not be attainable with dsolve/numeric approach unless we are able to call it evalhf format.
Download ImportanceofevalhfNLPSolve.mw
Eval(`&varphi;`(t), t = 0) = `&varphi;__0`, Eval(diff(`&varphi;`(t), t), t = 0) = 0
Eval(varphi(t), t = 0) = varphi__0, Eval(diff(varphi(t), t), t = 0) = 0
`~`[value](convert({Eval(diff(varphi(t), t), t = 0) = 0, Eval(varphi(t), t = 0) = varphi__0}, D))
{eval((D(varphi))(t), t = 0) = 0, varphi(0) = varphi__0}
map(value, convert({Eval(diff(varphi(t), t), t = 0) = 0, Eval(varphi(t), t = 0) = varphi__0}, D))
convert({Eval(diff(varphi(t), t), t = 0) = 0, Eval(varphi(t), t = 0) = varphi__0}, D); `~`[value](%)
{varphi(0) = varphi__0, (D(varphi))(0) = 0}
I have expected elementwise and map to be effective. Why aren't they for this example?
(Evaluation at a point (see help(D)): In output (3) it is the first time that I see a composition of the D operator with the Eval function (vertical bar). Is that an undocumented feature or part of an answer that I could not figure out myself?)
Download Convert_inert_IC_to_D_notation.mw
I am aware of https://www.maplesoft.com/products/system_requirements.aspx which shows requirements for the concurrent version (the old page https://www.maplesoft.com/products/roadmap.aspx does no longer exist)
Does anybody know a list or URL telling which Maple version (supposedly) needs what Windows version and which combinations will not work?
I am asking because I switch to a new NB and consider to setup a virtual machine for old programs.
Here is the code I would like to complete:
theta:= s -> -2*Pi*n*s/ell;
v:=s->piecewise(And(0<=s,s<=ell/2), c*s, ell/2<s, c*(ell-s));
ell:=1;
c:=1;
n:=2;
spacecurve([cos(theta(s)),v(s),sin(theta(s))],s=0..ell,colorscheme = ["valuesplit",???????]);
What to put in place of the question marks so that the color of the curve is, for example, red if s is between 0 and ell/2, and green if s is between ell/2 and ell?
I have a code that compute the elements of the sigma algebra generated by C in the domain X
If X is a discrete set and C is also a discrete set
I get a good results
But in change X to be an interval and C will be set of three elements
No result obtained
sigma_algebra.mw
Where do you think label="dontexpand" is coming from in the following? I never seen this before. Is this a bug?
When using PDEtools:-Solve no such error shows up. Worksheet below
998948
`The "Physics Updates" version in the MapleCloud is 1462 and is the same as the version installed in this computer, created 2023, June 10, 2:26 hours Pacific Time.`
sol:=sum((-2*_R^2+1)/(6*_R^2+4*_R-1)*ln(y(x)/x-_R),_R = RootOf(2*_Z^3+2*_Z^2-_Z+1))-ln(x)-c[1] = 0;
solve(sol,y(x))
sum((-2*_R^2+1)*ln(y(x)/x-_R)/(6*_R^2+4*_R-1), _R = RootOf(2*_Z^3+2*_Z^2-_Z+1))-ln(x)-c[1] = 0
Error, (in solve) cannot solve expressions with sum((-2*_R^2+1)/(6*_R^2+4*_R-1)*ln(y(x)/x-_R),_R = RootOf(2*_Z^3+2*_Z^2-_Z+1,label = "dontexpand")) for y(x)
PDEtools:-Solve(sol,y(x))
y(x) = exp(-c[1])+_R*x
Download dontexpand_june_10_2023.mw
Maple has a myriad of kernel functions for doing different kinds of symbolic replacements to whole expressions: subs, eval, algsubs, applyrule, `simplify/siderels`, `simpl/eval`,  Physics:-Substitute, MTM:-subs, MmaTranslator:-Mma:-ReplaceRepeated, PDEtools:-dsubs, liesymm:-wsubs, student:-powsubs, etc. But if I need to apply transformation rules over and over again until the result no longer changes within  iterations in a singular clean built-in command (so, without explicit while / until / MmaTranslator:-Mma:-FixedPoint) elegantly, only four can be called: eval['recurse']algsubs, applyrule, MmaTranslator['Mma']['ReplaceRepeated']. The difference between applyrule and algsubs has been elucidated in this help page:
applyrule … does not do mathematical transformations as algsubs does.
However, I cannot find any explanation for the potential distinctions between eval['recurse'] and MmaTranslator['Mma']['ReplaceRepeated'] in their documentation. Does anyone know?
Besides, is it possible to use an "operator" form (like ) instead of a "functional" form (like ) to perform (single or repeated) substitutions in Maple?
 Why is the (solve or dsolve command) not executed?
Sam.mw
How to solve ordinary differemtial equation system with initial conditions and boundary conditions. Here, some initial conditions are unknown variables. So how to find these  values of parameters.
eq1 := diff(f(x), x, x, x)+(1/2)*cos(alpha)*x*(diff(f(x), x, x))+(1/2)*sin(alpha)*f(x)*(diff(f(x), x, x)) = 0;
eq2 := diff(g(x), x, x)+diff(g(x), x)+(diff(g(x), x))*(diff(h(x), x))+cos(alpha)*x*(diff(g(x), x))+sin(alpha)*f(x)*g(x) = 0;
eq3 := diff(g(x), x, x)+diff(h(x), x, x)+1/2*(cos(alpha)*x+sin(alpha)*f(x)) = 0
ics:=f(0)=0, f'(0)=1, f''(0)=a[1], g(0)=1, g'(0)=a[2], h(0)=1, h'(0)=a[3];
bcs:=f(x) , g(x), h(x) tends to 0 ad x tends to infinity
How can one set their own symbols for DynamicSystems continuoustimevar?  If I try to use DynamicSystems:-SystemOptions('continuoustimevar'=x): or DynamicSystems:-SystemOptions('continuoustimevar'=y): Maple complains that these letters are already assigned. Why can not one have their own choice of which letters to use?  Is there a workaround?
858904
DynamicSystems:-SystemOptions('continuoustimevar'=t):
Error, (in DynamicSystems:-SystemOptions) cannot assign x to continuoustimevar, already assigned to statevariable
Error, (in DynamicSystems:-SystemOptions) cannot assign y to continuoustimevar, already assigned to outputvariable
DynamicSystems:-SystemOptions('continuoustimevar'=XXXXXX):
Download dynamics_june_9_2023.mw
I have a simple equation that can be solved by hand. But, can Maple solve this equation
cos(x)> a,   with a :  real number.
Can we get all possible solution with different values of a,
Equation.mw
thank you for your help
First 195 196 197 198 199 200 201 Last Page 197 of 2431
