Can one evaluate dirac spinor products using the Standard Model package? How far can I take the evaluation in the package? See maplesheet with commentary.
Evaluating_spinor_products_with_the_standard_model_package.mw
When adding singsol=all to this ode in the first example, dsolve returns nothing. But it should have returned the general solution if it can not find singular solution. This is what it does always as can be seen from the second example given below.
Why did dsolve return nothing in the first example? Is this a bug?
319824
ode:=y(x)=x*diff(y(x),x)+ a*diff(y(x),x)/(sqrt(1+diff(y(x),x)^2));
sol_1:=dsolve(ode,y(x));
sol_2:=dsolve(ode,y(x),singsol=all);
y(x) = x*(diff(y(x), x))+a*(diff(y(x), x))/(1+(diff(y(x), x))^2)^(1/2)
y(x) = x*c__1+a*c__1/(c__1^2+1)^(1/2)
"sol_2 := "
ode:=diff(y(x),x)^2-(1+2*x*y(x))*diff(y(x),x)+2*x*y(x) = 0;
sol_2:=dsolve(ode,y(x), singsol=all)
(diff(y(x), x))^2-(1+2*y(x)*x)*(diff(y(x), x))+2*y(x)*x = 0
y(x) = c__1*exp(x^2), y(x) = x+c__1
Download missing_sol.mw
I have a question regarding the combstruct package, to be more precise, the specification of a combinatorial species as it is described here:
https://www.maplesoft.com/support/help/maple/view.aspx?path=combstruct%2fspecification
Is there any available constructor to generate the functorial composition of two species? For example, a simple graph can be seen as a subset of the set of all 2-element subsets of a given node set. This is nothing else than the functorial composition of E*E with E_2*E, where E denotes the species of sets and E_2 the species of 2-element sets. Thus, the species of subsets can be expressed as E*E and the one of 2-element subsets as E_2*E. Written in the Magma syntax, it should be the functorial composition of Prod(Set(Z),Set(Z)) with Prod(Set(Z,card=2),Set(Z)). Applying the count-function, it should produce the series https://oeis.org/A000088.
How can I achieve that?
How to find series values.I got this error.Please Help.
Maple code for the problem is
TFBE.mw
i have a question. can maple recognize similar expressions in an equation? for example can maple recognize these two silimiar expressions in the picture below and give it ? I want maple itself recognize similar expressions, not i give an input to find similiar results. thnx in advance
A chordal graph is one in which all cycles of four or more vertices have a chord, which is an edge that is not part of the cycle but connects two vertices of the cycle. A perfect elimination ordering in a graph is an ordering of the vertices of the graph such that, for each vertex v, v and the neighbors of v that occur after v in the order form a clique.  A graph is chordal if and only if it has a perfect elimination ordering.
I  use IsChordal  to test whether the lexicographic product of  two graphs g1,g2 is a chordal graph. It returned true and provided a perfect elimination sequence 1, 2, ..., 30. However, vertices of s  are "1:1", "1:2", ..., "10:3", rather than using Arabic numerals. Therefore, it is difficult for me to extract useful information from the perfect elimination sequence.
with(GraphTheory):
g1:=PathGraph(10):
g2:=CycleGraph(3):
s:=LexicographicProduct(g1,g2):
IsChordal(s,eliminationordering=true)
true, [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30]
DrawGraph(s)
Vertices(s)
["1:1", "1:2", "1:3", "2:1", "2:2", "2:3", "3:1", "3:2", "3:3", "4:1", "4:2", "4:3", "5:1", "5:2", "5:3", "6:1", "6:2", "6:3", "7:1", "7:2", "7:3", "8:1", "8:2", "8:3", "9:1", "9:2", "9:3", "10:1", "10:2", "10:3"]
Download ischordgraph.mw
Hi senior, i am trying to customize the range for horizontal axis means in my case y axis but got error, also trying to give different color for outcomes. Please help in this regards.
Axis_Help.mw
Is it possible to use a vector in the piecewise fuction? I have tried the following and other stuff but the the error below
timestep := <seq(1 .. 100)>;
piecewise(`<`~(30, timestep), 1);
Error, (in PiecewiseTools:-Is) wrong kind of parameters in piecewise
I have a time vector and would like to create a u(t), unit step fuction to "turn on" a function at a certain time. e.g.
output(t)=u(t)*f(t)
Where u(t)=1 for t>turn_on_time and 0 otherwise.
TIA for help
  Could you please give maple code for Shooting Method/Kellor box Method or any numerical method except RK Method to this system of Differential Equations.
SMMS.mw
In a recent answer I posted, I had a relation of the form
I*Int(f(x), x) = something - 2*I*Int(f(x), x)
and I wanted to isolate the term Int(f(x), x).
The function isolate failed to do it and I was forced to use some workaround to do the "isolation".
Trying to understand what happened here, it seems that isolate fails when the term to isolate is multiplied by the imaginary unit
Here are a few examples
expr := I*(Int(x^2*ln(-x+sqrt(x^2-1)), x)) = g(x) -(2*I)*(Int(x^2*ln(-x+sqrt(x^2-1)), x))
I*(Int(x^2*ln(-x+(x^2-1)^(1/2)), x)) = g(x)-(2*I)*(Int(x^2*ln(-x+(x^2-1)^(1/2)), x))
# no isolation
isolate(expr, lhs(expr))
# isolation
expr_1 := expand(expr / I)
isolate(expr_1, lhs(expr_1))
Int(x^2*ln(-x+(x^2-1)^(1/2)), x) = -((1/3)*I)*g(x)
# no isolation neither, so the problem is not related to "Int"
expr := I*diff(h(x), x) = g(x) -2*I*diff(h(x), x):
I*(diff(h(x), x)) = g(x)-(2*I)*(diff(h(x), x))
# no isolation neither, so the problem comes from "I"
expr := I*A = g(x) -2*I*A:
I*A = g(x)-(2*I)*A
# isolation (of course)
expr := c*A = g(x) -2*c*A:
c*A = (1/3)*g(x)
Download Isolation.mw
I guess this is a known behavior, but why it is so?
Is there a way to force the "isolation" without using a trick like in result (3)
Hello community, I am new in this forum and sorry if the following seems rudimentary:
I am replicating a distribution function using Statistics[Distribution] as defined here:
Vose Software's Beta Subjective
I have tested numerically and the function works for this initial values: Min := 3; Mlikely := 8; Avg := 9; Max := 18;
But failed to complete with these values (which I tested works in another software) Min := 1000; Mlikely := 1400; Avg := 1500; Max := 2100;
What puzzles me is the inconsistency of handling the functions (be aware that the server kernel could be slow at times). I hope I don't have to give up and continue my custom distribution project in another software.
Here is the document:
The Beta Subjective Distribution
with(Statistics)
18
Mid := (Min+Max)*(1/2)
21/2
alpha := 2*(Avg-Min)*(Mid-Mlikely)/((Avg-Mlikely)*(Max-Min))
beta := alpha*(Max-Avg)/(Avg-Min)
NULLNULLNULLNULL
f := simplify(piecewise(Min <= x and x <= Max, (x-Min)^(alpha-1)*(Max-x)^(beta-1)/(Beta(alpha, beta)*(Max-Min)^(alpha+beta-1)), 0))
piecewise(x < 3, 0, x <= 18, (4/16875)*(x-3)*(-18+x)^2, 18 < x, 0)
MD := Distribution(PDF = unapply(f, x), Conditions = [`and`(Min < Mlikely and Mlikely < Max and Min < Avg and Avg < Max and Mlikely <> Avg, piecewise(Avg < Mlikely, Mlikely > Mid, Mid > Mlikely))])
_m2352873740384
X := RandomVariable(MD)
_R
evalf(Mean(X))NULL
9.
evalf(Mode(X))
{8.}
evalf(Quantile(X, .25))
HFloat(6.645331256340534)
A := Sample(X, 10^5)
Mean(A)
HFloat(8.989513601786443)
Mode(A)
HFloat(8.399525182283146)
Variance(A)
HFloat(9.029923294780689)
Skewness(A)
HFloat(0.29817612117709397)
(14)
Kurtosis(A)
HFloat(2.3706624578773154)
(15)
Quantile(A, .25)
HFloat(6.63427086578336)
(16)
Download Distribution-Beta-Subjective.mw
I need to create a matrix with 4 dimensions, but I don't know how I can do this. The variable that I need to store could be written in this form:
>S[i,j,k,l];
I don't want to write this with a subscript, but like a matrix.
Hello there,
This is another issue, associated with substitution. In the following Maple expressions, I tried to substitutte the denominator of 'eq_K1_m4' in order to make it as 'eq_K1_m4_desired', but did not get any success (yet).
Therefore, would you have a look at this issue to see if the intended goal can be achieved?
with(DynamicSystems):
interface(imaginaryunit=j):
eq_K1_m4 := K__1 = E__q0*(R__T*E__B*sin(delta) + X__Td*E__B*cos(delta))/(L__aqs*L__l + L__aqs*X__E + L__aqs*L__ads_p + L__l^2 + 2*L__l*X__E + L__l*L__ads_p + R__E^2 + 2*R__E*R__a + R__a^2 + X__E^2 + X__E*L__ads_p) + (X__q - X__dp)*i__q0*(X__Tq*E__B*sin(delta) - R__T*E__B*cos(delta))/(L__aqs*L__l + L__aqs*X__E + L__aqs*L__ads_p + L__l^2 + 2*L__l*X__E + L__l*L__ads_p + R__E^2 + 2*R__E*R__a + R__a^2 + X__E^2 + X__E*L__ads_p);
K__1 = E__q0*(R__T*E__B*sin(delta)+X__Td*E__B*cos(delta))/(L__aqs*L__l+L__aqs*X__E+L__aqs*L__ads_p+L__l^2+2*L__l*X__E+L__l*L__ads_p+R__E^2+2*R__E*R__a+R__a^2+X__E^2+X__E*L__ads_p)+(X__q-X__dp)*i__q0*(X__Tq*E__B*sin(delta)-R__T*E__B*cos(delta))/(L__aqs*L__l+L__aqs*X__E+L__aqs*L__ads_p+L__l^2+2*L__l*X__E+L__l*L__ads_p+R__E^2+2*R__E*R__a+R__a^2+X__E^2+X__E*L__ads_p)
eq_K1_m4_desired := K__1 = E__q0*(R__T*E__B*sin(delta) + X__Td*E__B*cos(delta))/Dx + (X__q - X__dp)*i__q0*(X__Tq*E__B*sin(delta) - R__T*E__B*cos(delta))/Dx;
K__1 = E__q0*(R__T*E__B*sin(delta)+X__Td*E__B*cos(delta))/Dx+(X__q-X__dp)*i__q0*(X__Tq*E__B*sin(delta)-R__T*E__B*cos(delta))/Dx
eq_Dx := Dx = L__aqs*L__l + L__aqs*X__E + L__aqs*L__ads_p + L__l^2 + 2*L__l*X__E + L__l*L__ads_p + R__E^2 + 2*R__E*R__a + R__a^2 + X__E^2 + X__E*L__ads_p;
Dx = L__aqs*L__l+L__aqs*X__E+L__aqs*L__ads_p+L__l^2+2*L__l*X__E+L__l*L__ads_p+R__E^2+2*R__E*R__a+R__a^2+X__E^2+X__E*L__ads_p
denom(op(1, rhs(eq_K1_m4))) - rhs(eq_Dx); # checking to see if the denominator expression is the same as the expression of Dx
denom(op(2, rhs(eq_K1_m4))) - rhs(eq_Dx); # checking to see if the denominator expression is the same as the expression of Dx
map2(applyrule, eq_Dx, eq_K1_m4); # did not work.
subs(eq_Dx, eq_K1_m4); # did not work.
simplify(eq_K1_m4, {Dx = L__aqs*L__l + L__aqs*X__E + L__aqs*L__ads_p + L__l^2 + 2*L__l*X__E + L__l*L__ads_p + R__E^2 + 2*R__E*R__a + R__a^2 + X__E^2 + X__E*L__ads_p}, [Dx]); # did not work.
K__1 = -E__B*((-R__T*(-X__q+X__dp)*i__q0-E__q0*X__Td)*cos(delta)+sin(delta)*(X__Tq*(-X__q+X__dp)*i__q0-R__T*E__q0))/(L__l^2+(L__aqs+L__ads_p+2*X__E)*L__l+X__E^2+(L__aqs+L__ads_p)*X__E+L__aqs*L__ads_p+(R__E+R__a)^2)
algsubs(eq_Dx, eq_K1_m4); # did not work.
applyrule(L__aqs*L__l + L__aqs*X__E + L__aqs*L__ads_p + L__l^2 + 2*L__l*X__E + L__l*L__ads_p + R__E^2 + 2*R__E*R__a + R__a^2 + X__E^2 + X__E*L__ads_p = Dx, eq_K1_m4); # did not work.
Download Q20230606.mw
I am surprised Maple could not do this integral. Any ideas how to make it do it?
integrand:=(ln(-x + sqrt(x^2 - 1))*x + sqrt(x^2 - 1))*x*sqrt(-x^2 + 1)/sqrt(x^2 - 1);
int(integrand,x)
For reference, another software gives
ClearAll[x]
integrand = (Log[-x + Sqrt[x^2 - 1]]*x + Sqrt[x^2 - 1])*x*Sqrt[-x^2 + 1]/Sqrt[x^2 - 1]
Integrate[integrand, x]
Which I verified to be correct.
Any workarounds? I tried assuming x>0 for example. Not sure what else to try now. I am sure with some pre-processing Maple can do it.
Maple 2023
Please help me to solve this error.   or
Can you give the maple code for Shooting method/ Kellor Box Method for this problem.
mvp-1.mw
First 196 197 198 199 200 201 202 Last Page 198 of 2431
