If possible I'd like to get anyone's opinion on the "security", (for lack of a better word), of the rand command, used to generate random numbers or integers. Lately, if you've seen some of my recent blog posts you may have noticed that I've been curious about cryptography, but I still consider myself a novice, if that. My question is, does any of the brilliant and talented people that I've met on mapleprimes think that it may be possible to "cheat" maple's random number generator ? Would it be possible by some sort of manipulation to predict this command's output with some reasonable amount of confidence ?
This may be a little picky but if I start a new worksheet and enter y=x^2 the return is y=x^2 and it is marked as equation (1). Then entering solve((1),y) where (1)comes from insert, label, etc., I get x^2 showing that the experession x^2 has been "applied" to y as one would expect. Next when I enter g:=unapply((1),x) the function g(x) is created using the expression x^2 and I would expect that x^2 is no longer applied to y. However, when I again enter solve((1),y) I still get x^2. So the question is, what has been "unapplied" from what, as the command (unapply)implies?
I'm using Maple 11, and I have a question on switching between the input modes. In the user manual it only states that one should go the 'tools' drop down menu, select the 'options' choice, and apply the 'maple input' mode to the current worksheet or globally. However, after doing this I still find myself having to click on the "text" button directly above the worksheet area to have the input text stay permanently in the red colored maple input. Is this how others also choose to permanently use the maple input in worksheets ? Is this actually the only, or correct way ? v/r,
If I try to solve t = 5.*x*sqrt(1.+4.*x^2)+2.500000000*arcsinh(2.*x) for x in terms of t, using solve(t = 5.*x*sqrt(1.+4.*x^2)+2.500000000*arcsinh(2.*x),x); I get a RootOf answer form. That is not very useful, so I then use allvalues(%) but it just returns the same RootOf answer. Does returning the the same RootOf answer mean that allvalues can not convert the RootOf solution into an answer that contains the roots? If so, why does solve give the root of solution when it cannot be solved? If not, what does Maple return when it cannot perform a command? I find it disturbing if Maple returns a RootOf solution if it can not solve for the roots, (if that is what is happening). It's like if I ask you what the square root of two is and your reply is that it is the square root of two. That would not be the answer to the question asked. Perhaps there is an effective way to convert the RootOf answer into one containing the roots as opposed to using allvalues(%) which doesn't do the job? Thanks for the help.
Given an expression is there a easy way to convert occurrencies of diff, int, limit, product, sum to their intert forms? For diff one can use convert(%,D), but for int and sum it is not the right way. Are there other ways instead of using "subs(sum=Sum,%)" etc ?
I observe that within graphics numbers are displayed according to local settings (so 0,001 stands for 1/1000) - no problem for me, but annoying, actual output displays with a point as decimal separator. For pretty display I sometimes use something as 'eval(expr, x=1)': '%'=% which works fine in mws, but in mw it displays the eval statement - is there a workaround for both kinds of sheets? And saving a mws as mw does not respect the font size for 2D output (it changes mine from 10 to 12 (and behaves odd, it always uses italics, but we had that already i think). (Win XP home SP2,
I'm trying to animate a group of spheres moving randomly in a box but am having difficulty getting the axes to show up. Specifically i want to be able to export as a GIF, for use in a presentation but when I insert a static set of axes with an arbitrary empty bit of a plot it won't let me export. I can define a set of axes as below, but i can't seem to control the size. Any ideas how to define the axes size in the following bit of maple for one sphere?
Thanks greatly in advance.
> restart;with(plots): with(plottools):with(linalg):with(stats):
> x10:=10:y10:=10:z10:=10:
> ball1 := sphere( [x10,y10,z10], grid=[10,10],axes=normal,color=blue):
i WANT TO DEVELOP A MICROCONTROLLER BASED PID TEMPERATURE CONTROLLER.THE USER WILL SET THE DESIRED TEMPERATURE THROUGH KEYBOARD.I WILL BE USING A TEMPERATURE SENSOR(IC LM35DZ) WHICH WILL BE INPUT TO MICROCONTROLLER 8051 WHICH WILL IMPLEMENT PID ALGORITHM TO CONTROL A RELAY AND HENCE EITHER TURN ON A HEATER OR A COOLER.AN LCD WILL ALSO BE INTERFACED TO DIPLAY THE SET TEMPERATURE AND ACTUAL TEMPERATURE. I DO NOT KNOW THE C CODE FOR THIS.IF ANYONE HAS WORKED ON SUCH KIND OF SYSTEM ,THEN PLEASE SEND ME THE CODE.I WILL BE REALLY VERY GREATFUL.
When I have defined a function and a matrix f(x) A[2000,1] The matrix consists only of numbers; no variables. Is is possible to use the function on the matrix and thus get a new matrix where all the entries are the transformed values? - Kasper
I've noticed that if I'm not connected to the internet and load a worksheet in Maple-11 document mode, it more often than not loads with question marks on some of the lines. It never happens when I'm connected to the internet. Is there some kind of connectivity between Maple-11 and the internet? If anyone else can try this, please do and let me know what happens. I discovered it when I was working on my cable modem and wasn't connected for a while and was loading various worksheets in maple and began seeing the question marks. Then when I plugged the cable back in they stopped showing up.
Thanks to J. Tarr, Georgios Kokovidis and others I got my dataset imported into Maple as a matrix. After having done some computations on it, I would like to export it again to an Excel file. Is this possible? - Kasper
I would like to calculate int( (1/4)*x^3*BesselY(0,x)*BesselK(0,x),x=0..infinity); In an article authors say it is 1/(2*pi). Could help me anybody? Sandor
I'm taking a Maple course and I cannot figure out how to convert from a number to binary (without using the convert(#,binary)). So far I have toBinary:= proc(x::posint) local n, k; n:=x; k:=0; while n > 0 do k:= and I'm not sure where to go from here. I know that I need to find the remainders and decrease my n and then put it into a list and then concatinate in the reverse order. Can someone help me out? Thanks Rachel
Can Maple import a bitmap and then use it in a plot? If it can, can the orientation of the bitmap be changed in the plot? It would be much quicker and would look nicer than using the internal drawing facilities.
Dear Comrades, I'm trying to solve a system of coupled integral equations. Does anybody know how to use IntSolve? And what's the shared library? Do I have to download IntSolve from somewhere? And is this the best way to spolve integral equations if I did? Regards, Andrew
First 2327 2328 2329 2330 2331 2332 2333 Last Page 2329 of 2431
