Hello All Dear Maplesoft professionals, I have a classic internal Maple procedure. It works by call in Maple session like this MyProc[Function]([3/5,7,4.25], ["blue","red","gold"]); I am planning to call it from OpenMaple application (fast and correct and many times). The members of lists will change many times at .exe session (user dialog). What the best way to call it from C code 1. Function Conection DagProc = EvalMapleStatement(kv, "MyProc[Function];"); 2. ???? What kind manipulation by data [3/5,7,4.25], ["blue","red","gold"]
I just uploaded the file Georgeworksheet18.mw. I am looking for a result such that when I collapse the document block I see the statement The answer to 4+3 is 7. on one line. I would like it so that if I expand the document block, and change the command line to 4 + 4 and then collapse the document block I will see The answer to 4 + 4 is 8. Is there any way to accomplish this? View 2292_GeorgeWorksheet18.mw on MapleNet or Download 2292_GeorgeWorksheet18.mw
View file details
Dear Maple users, I am trying to use Minimax to create a rational approximation to a function over a specified approximation interval. But, I keep getting the following error message. Can someone help? > with(numapprox): > Digits:=50; Digits := 50 > minimax(tanh(sqrt(x))/sqrt(x), x=1..10^4, [13,14]); Error, (in numapprox/remez) error curve fails to oscillate sufficiently; try different degrees Thanks, Adnan.
Hi; Is there any way to find a closed form of the following integral by maple, where theta is a real constant. cheers Sayed int(x*exp(-I*x*theta)/sinh(1/2*Pi*x),x=-infinity..infinity);
The problem i have is this, the plot that i am suppose to recieve is one that looks like the 'pointplot3d' below, yet i recieve something which doesn't. Any suggestions as to how to circumvent this? with(plots):Digits:=15: > Omega[0,1]:=.825352549049169: plot3d(MathieuCE(0,Omega[0,1],r*I)*MathieuCE(0,Omega[0,1],theta),theta=0..2*Pi,r=0..1,coords=ellcylindrical,axes=FRAMED); points1:={seq(seq([T/100,2*Pi*S/100,MathieuCE(0,Omega[0,1],2*Pi*S/100)*MathieuCE(0,Omega[0,1],I*T/100)],T=1..100), S=1..100)}: pointplot3d(points1,coords=ellcylindrical, axes=FRAMED, color=red, style=wireframe);
in document mode I like to add a descriptive text after the inline output to label what answer is. You cant just switch to text mode and start typing, it does not work. The only way I have been able to do this is to use the next float or next prime command then backspace twice to erase that output and then I can switch to text mode and append text. Is there a easier way to do this?
How do I display / calculate -1.60x10^-19 when calculating Coulombs? This returns a "Error, invalid power" in Maple 10 (student) and Classic Maple (student) and in the calculator (student).! Frustrating, Yes I am a student and a new user and I need the help the software promises to provide.
I'm trying to solve a system of equations in maple and I have no idea why it's doing what it's doing but it certainly isn't working. Anybody have an idea what's going on? View 2503_numbers2.mw on MapleNet or Download 2503_numbers2.mw
View file details
i have a problem of my equation with differentiation,in the first i run it total OK ,but when i input the value into the equation, the ERROR was show the screen. i don't know which step have the problem in my procedure. under is my maple file,(if you can't understand what mean of this procedure,just send me E-mail). regards View 1984_new equation with water out.mw on MapleNet or Download 1984_new equation with water out.mw
View file details
A colleague asked me about this, and I couldn't help him: > g:=y+exp(2*t): > y2:=subs([y=3,t=0.1],g); y2 := 4.221402758 > subs([y=y2,t=0.1],g); 4.221402758 Why has not the new value of y2 been substituted for y in this last expression? And the same thing happens for eval. Thanks, Alasdair
I've already found the commando's logplot and loglogplot on my own. The first defines a log scale for the y axe. The second defines a log scale for both the axes. Now is my question where could I find the command for plotting a log scale for the x axe. I suspect it is something special because I could not find it in the library plots. My excuses for my terrible English! Greetz Pieter
I am trying to write a paper in which I can, for presentation purposes, collapse document blocks and have the code not shown. I am running into the problem that when I collapse some document blocks code within is not displayed but when I collpase other document blocks all that goes away is the red prompt. I can't figure out why the difference. The attached file has two document blocks which, as far as I can tell, are identical except for a few words of text. When I collpase the first block the code remains displayed, but when I collapse the second block it does not. Can anyone figure out why the difference?
Hello, I'm wondering if it is possible to produce a composite plot in Maple. What I would like to do is: 1. Take one solution of a non-autonomous differential equation, and plot it with respect to t, call this x(t). 2. Take another solution of a similar equation, also plot it with respect to t, call this y(t). 3. Take x(t) vs. t and y(t) vs. t planes and use it to create a 3-dimensional plot containing all the points where (t,x(t))=(t,y(t)). It's difficult to describe, I hope the above is helpful. On a (hopefully) simpler note, when I solve the following: odesys := diff(x(t), t) = 2*x(t)-y(t)-x(t)^3, diff(y(t), t) = x(t)
hi there... im trying to plot this equation onto a graph- x-2y=4 x+2y=12 I dont knw how to put it into maple.....as maple only reads one equation at a time and not as a whole???? help please....
Tried to maximize a simple function f(t), failed. Converted it to different forms, still failed. Simplified the function a bit by hand and tried again, still fail. Only after some major simplification by hand and a transformation: u=s^2=(1/2-t)^2, it finally worked. I must be missing something. I thought such a simple problem should certainly be solved by maple in a flash. Can someone enlighten me please? Thanks a lot. > maximize(t^2*(1-t)^2*(1+t^2)*(1+(1-t)^2), t = 0 .. 1); / 2 2 / 2\ / 2\ \ maximize\t (1 - t) \1 + t / \1 + (1 - t) /, t = 0 .. 1/
First 2374 2375 2376 2377 2378 2379 2380 Last Page 2376 of 2430
