Hello community. I'm trying to use Maple for some study.
My goal is to get the Wiener-Hopf equation in matrix form like in the book (eq 3.56).
So at first i need the gradient of eq 3.53, the result is eq 3.55 (nabla is not printed) .
Could you please provide an example of this operation, if it is possible, thanks.
_local(D);
f := (x, y) -> 3*x^2 - 3*y*x + 6*y^2 - 6*x + 7*y - 9;
coeffs(f(x, y));
A, B, C, D, E, F := %;
theta := 1/2*arctan(B/(A - C));
solve({-2*A*xc - B*yc = D, -B*xc - 2*C*yc = E});
assign(%);
x := xcan*cos(theta) - ycan*sin(theta) + xc;
y := xcan*sin(theta) + ycan*cos(theta) + yc;
Eq := simplify(expand(f(x, y)));
xcan^2/simplify(sqrt(-tcoeff(Eq)/coeff(Eq, xcan^2)))^`2` + ycan^2/simplify(sqrt(-tcoeff(Eq)/coeff(Eq, ycan^2)))^`2` = 1;
a := sqrt(-tcoeff(Eq)/coeff(Eq, xcan^2));
b := sqrt(-tcoeff(Eq)/coeff(Eq, ycan^2));
c := sqrt(a^2 - b^2);
F1 := [xc + c*cos(theta), yc + c*sin(theta)];
evalf(%);
F1 := [xc - c*cos(theta), yc - c*sin(theta)];
evalf(%);
Points := pointplot([F1[], F2[]], symbol = solidcircle, color = [red], symbolsize = 6);
xcan := plot(yc + tan(theta)*('x' - xc), 'x' = -2 .. 3.5, color = black);
ycan := plot(yc - ('x' - xc)/tan(theta), 'x' = 0.1 .. 1.5, color = black);
Ellipse := plots[implicitplot](f('x', 'y'), 'x' = -2 .. 3.5, 'y' = -2 .. 1.5, color = red, thickness = 2, gridrefine = 5);
labels := plots[textplot]([[0.4, 1.3, "ycan"], [3.2, 0.75, "xcan"]], font = [TIMES, ROMAN, 14]);
plots[display](xcan, ycan, Points, Ellipse, labels, scaling = constrained);
I do not why I get this message:
Error, (in plots:-display) expecting plot structure but received: pointplot([17/21-(2/21)*(1407/(-(3/2)*2^(1/2)+9/2)-1407/((3/2)*2^(1/2)+9/2))^(1/2)*cos((1/8)*Pi), -8/21-(2/21)*(1407/(-(3/2)*2^(1/2)+9/2)-1407/((3/2)*2^(1/2)+9/2))^(1/2)*sin((1/8)*Pi), F2[]], symbol = solidcircle, color = [red], symbolsize = 6) NULL;
Thank you for your help.
I have an expression and I want to find its maximum value.
expr:=sin(sqrt(3)*t)*cos(sqrt(3)*t)*(sqrt(3)*cos(sqrt(3)*t) - sin(sqrt(3)*t))/3
It is easy to find its maximum value in a numerical form.
Optimization:-Maximize(sin(sqrt(3)*t)*cos(sqrt(3)*t)*(sqrt(3)*cos(sqrt(3)*t) - sin(sqrt(3)*t))/3)
[0.324263244248023330, [t = 1.39084587050767]]
The images of the expression is as follows.
But does it exist an acceptable maximum value in symbolic form?  As the function maximize seems to take a lot of time, I don't see any hope so far. Perhaps the expression is indeed complex.
maximize(expr)# it runs long time.
We try to find the derivative of expr and get some points where thier derivatives are 0.
s:=[solve(diff(expr,t),t)]
evalf~(s) # Some solutions seem to have been left out.
[0.7607468963 + 0.*I, -0.4229534936 - 0.*I, 0.2668063857 + 0.*I]
ex:=convert(expr,exp):
s:=[solve(diff(ex,t)=0,t)]:
s1:=evalf~(s);# choose the 6th item: 1.390845877 + (4.655829150*10^(-9))*I
fexpr := unapply(ex, t);
evalf(fexpr(s1[6]));
fexpr (s[6]); # a very long expression that is not quite acceptable.
-I/6*(-sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44))/(6*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)) + 6*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)/sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44)))*(-sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44))/(12*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)) - 3*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)/sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44)))*(sqrt(3)*(-sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44))/(12*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)) - 3*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)/sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44))) + (-sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44))/(6*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)) + 6*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)/sqrt(-(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3)*((1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3)*sqrt(3)*I - 2*I*sqrt(3)*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) + (1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(2/3) + 36*I*sqrt(3) + 2*(1404*I*sqrt(3) - 1396 + 36*sqrt(-3018 - 3018*I*sqrt(3)))^(1/3) - 44)))*I/2)
An interesting problem is that an acceptably concise expression (although it is very subjective) for the maximum value may not exist mathematically. But knowing this in advance is difficult.
Download compute_zlc.mw
During my reaserch on diffusion I am arrived at the integral with argument
exp(-1/sqrt(x^2 + 1)) which Maple is not able to solve.
If some experts in solving integrals is able to solve it please keep me informed.
The file in Maple 2022 is below
primes_integral_diffusion.mw
Hello everyone!
I use this procedure to open my inbox:
>restart;
ShellExecute := define_external('ShellExecuteA', hwnd::(integer[4]), lpOperation::string, lpFile::string, lpParameters::string, lpDirectory::string, nShowCmd::integer[4], 'RETURN'::integer[4], LIB = "C:\\WINDOWS\\SYSTEM32\\shell32.dll"):
OpenBrowser := proc(someURL::string := "http://")
ShellExecute(0, " ", someURL, " ", " ", 1); NULL;
Case 1:  I entered the correct email address of my friend who sent me the mail
>OpenBrowser("https://mail.google.com/mail/u/0/?tab=rm&ogbl#inbox/xxxxxxGqRZXPKXGzrrSrfHscdNWspRJF");
As a result, the content of the message I received was opened with full information.
Case 2:  When I enter an arbitrary email address that is not my friend, the result is that no content is displayed.
>OpenBrowser("https://mail.google.com/mail/u/0/?tab=rm&ogbl#inbox/yyyyyyGqRZXPKXGzrrSrfHscdNWspRJf");
On the email there is only the message: The conversation you requested could not be loaded.
May I ask:  Is there any Maple command to return true in case 1 and to return false in case 2 ?
Thank you very much for your help !
Procedure returns two values. I would like to print a comment after them if possible, without it being a returned value
foo := proc(a, b)
local x, y;
x := a^2 - b;
y := b^2 - a;
# return x,y, "test on foo"  # returns 3 values
return x, y, print(" tests on return"); end proc;
A, B := foo(6, 3);
                       " tests on return"
                         A, B := 33, 3  #would like "tests on return here"
Dear Users!
I hope are fine here. I got the following expression after a lot of computations
((1/2)*r*(r-1)+(1/6)*r*(r-1)*(r-2))*`Δy`[-1]^3+(1/2)*r*(r-1)*`Δy`[-1]^2+(1/120)*r*(r-1)*(r-2)*(r-3)*(r-4)*`Δy`[-2]^7+((1/6)*r*(r-1)*(r-2)+(1/12)*r*(r-1)*(r-2)*(r-3)+(1/120)*r*(r-1)*(r-2)*(r-3)*(r-4))*`Δy`[-2]^5+((1/6)*r*(r-1)*(r-2)+(1/24)*r*(r-1)*(r-2)*(r-3))*`Δy`[-2]^4+((1/24)*r*(r-1)*(r-2)*(r-3)+(1/60)*r*(r-1)*(r-2)*(r-3)*(r-4))*`Δy`[-3]^7+((1/24)*r*(r-1)*(r-2)*(r-3)+(1/60)*r*(r-1)*(r-2)*(r-3)*(r-4))*`Δy`[-3]^6+r*`Δy`[0]+y[0]
Actually, for the above, I want the factorization of each coefficient of `Δy`[0], `Δy`[-1], `Δy`[-2] etc and the above expression shoud be in descending order given as:
y[0]+r*`Δy`[0]+(1/2)*r*(r-1)*`Δy`[-1]^2+(1/6)*r*(r-1)*(1+r)*`Δy`[-1]^3+(1/24)*r*(r-1)*(r-2)*(1+r)*`Δy`[-2]^4+(1/120)*r*(r-1)*(r-2)*(r+2)*(1+r)*`Δy`[-2]^5+(1/120)*r*(r-1)*(r-2)*(r-3)*(r-4)*`Δy`[-2]^7+(1/120)*r*(r-1)*(r-2)*(r-3)*(-3+2*r)*`Δy`[-3]^6+(1/120)*r*(r-1)*(r-2)*(r-3)*(-3+2*r)*`Δy`[-3]^7
I am waiting for your positive response. Thanks
I was trying New-Display-Of-Arbitrary-Constants-And-Functions- but found a small problem.
in my code I build the constants of integrations using parse("_C"||N); where N is an integer that can go up to as many constants of integration are needed. For example, for 4th order ode, there will be 4 of them.
I noticed only the first 2 come out using the nice c__1,c__2 notation, but anything after 2 ,they come out using old notation _C3, _C4.
Here is a MWE
`The "Physics Updates" version in the MapleCloud is 1346 and is the same as the version installed in this computer, created 2022, October 7, 13:4 hours Pacific Time.`
dsolve(diff(y(x),x)=1,arbitraryconstants=subscripted);
pdsolve(diff(psi(x,t),x$2)=0,arbitraryfunctions=subscripted);
y(x) = x+c__1
psi(x, t) = f__1(t)*x+f__2(t)
_C1
c__1
for N from 1 to 4 do
    parse("_C"||N);
od;
c__1
c__2
_C3
_C4
So now my solution comes out with mixed looking constants. Why does this happen for N>2?
Download problem_with_C.mw
So for now, I went back to using the old method of using alias as follows
alias(seq(c[k] = _C||k, k = 0..10)):
_C1
c[1]
    parse("_C"||N);
od;
c[1]
c[2]
c[3]
c[4]
Download problem_with_C_alias.mw
Strange behavior. I don't know if this can be made to work.  I replaced an equation with an interpolation object, f(x).
tInt := int(f, 133  .. 134, numeric);
tInt := 324.95206944305  <= Computes a result. I
tInt := int(f, 133  .. 312, numeric);
tInt:= int(fproc, 133. .. 312.) <= Won't compute it. The interpolation object has 3051 points, so that's not the problem. The name "fproc" is not something I have in my  code, just the name, "f".
If I try to make the  integral just slightly more complex by  passing a variable in, it doesn't work at all. This was to see if I could integrate with a varying divisor: f(x)/(x+1)
int(f(x), x = 133 .. 134, numeric);
Error, (in int) wrong number (or type) of arguments: invalid options or option values passed to definite integration. <=
A fallback  was to use summation, but that doesn't work at all, same typ of error as the Error for int. (Not shown.)
So my fallback is to use a for loop to sum the set. The for loops produce another set of values, and I think I have to make interpolation objects for that as well. And so on. I really  was expecting  Maple to handle this better.
When I try to change the number format (decimal places) of a sequence in Maple Flow using the right hand slide out context panel all numbers in the sequence are replaced by only the first number in the sequence.  I'm not sure if it has been fixed in 2022.1
Before the adjustment ...
Selecting fixed prompts the result to stop after the first number in the series.
Can anyone else confirm this issue?
conjcl := proc(k, p, n) local t, L, q; L := []; t := 0; q := p^n - 1; while k*p^t <> k mod q do t := t + 1; L := [op(L), t mod q]; end do; return L; end proc
I'm fairly new to coding with Maple / in general, but basically for my course I need to do the following:
For each t=0,1,... I need to first check if kp^t = k mod (p^n-1), and if it isn't, I compute t mod (p^n-1) then add it to my list. The problem I have is I just can't seem to get it to work. I incliuded both the screenshot of the code and typed it out. Thanks in advance
Good day sirs,
I am having trouble identifying the error in the system of first-order ODEs. It gives the error code of
" Error, (in dsolve/numeric/process_input) received more than one indication of the dependent vars [theta[1](t), theta[2](t), theta[3](t), theta[4](t), theta[5](t), theta[6](t), theta[7](t), theta[8](t), theta[9](t)].
The document is attached below.
"  Systems_error.mw
The attached worksheet contains expressions that cause a warning message to appear in my worksheet.  In another post it was suggested that the variable i should be explicitly declared local in the definition of the arrow expression. However, as shown in the same worksheet, this gives rise to an error message. Subsequently, I found a statement in help that suggested this approach would not work in 2-d math notation.  Are there any other ways of eliminating these warnings in 2-d math notation?
warningmessage.mw
I run my code, I think evrything is well coded, but I get the following error
invalid left hand side in assignment
Please, I need a help to solve this problem,  I haven't any idea about the origin of this error
IOMMcode.mw
In a Maple session I have several worksheets open. When I click on the close cross of a worksheet tab the following can happen:
Closing the worksheet next to it works as normal
This occurs irregularly. For far I could not make it reproducible to report it to Maplesoft support. Anyone has seen something like this or ideas what the cause could be?
First 266 267 268 269 270 271 272 Last Page 268 of 2431
