I have an equation which i want solve it with DTM and sketch the graph of f(η) along y axis and η along x axis, f ‘( η) and g( η)
M:=0..5
F[0]:=0;F[1]:=1;F[2]:=a/2;G(0)=0
That's my pleasure If there is somebody help me to code and solve this problem.
Thanks for every one very very much.
maple_calculations.mw
Why does my sequence return 0 at n=9 and n=10, when it should be 4?
Beneath the sequence i have also calculated the limit of f, as x approaches infinity, and it returns 4.
Below the initial screenshot, i have displayed a screenshot of the same plot but with a much bigger x-axis. It seems something weird happens at very large numbers of x. Is it a glitch, and if so how do i fix it?
here is the maple document containing the calculations below: maple_calculations.mw
Good day.
Several years ago, I obtained access to a clustering package that was useful to my studies using Maple 17.
In the meantime, I switched to another computer and now, I  cannot access the file, ClusterAnalysis.mla.
Unfortunately, I do not recall how I was able to access this library file.
Can anybody please advise me on the exact steps that are necessary to initialize and execute this file?
Thanks for reading ...
I'd like to plot row[i] of M_jk (left axis) vs. row[i] of M_ki (right axis). i is the x axis, and varies discretely from 1 to 10 (number of runs). See attached screenshot below for details. My result is off in terms of values... How to fix my plot command?
Please, how do I generate a list of ones in maple?
Dear friends,
I found a file in the Maplesoft Application Center to evaluate the minimum of a function in two variables.
I tried to extend the code to find a minimum for a function in 4 variables.
But the code does not work. Any Help, I will be appreciated.
Amr
Gradient_Search_Program_Code-22-9-2022.mw
How to linearize eq (6) by neglecting all higher order terms i.e., epsilon[1]^2, epsilon[2]^2, epsilon[1]*epsilon[2]... etc? How to do it in maple?
Calculation.mw
Please help me create a variation table of the function in maple like the above figure.
restartNULL
NULL``
Can I disable maple's use of the ' function? (aka prime/derivative function)
For example, if
f := x^2+1
x^2+1
it's derivative is obtained as
Diff(f(x), x) = diff(f(x), x)
Diff(x^2+1, x) = 2*x
We used the prime operator on the f to obtain f' on the right-hand-side.
The problem is, I use prime notation as a naming convention like in defining an integral equation such as:
"psi(t)=∫G(t,t')*psi(t') ⅆt' ."
This is common practice in many texts.
Is there a way that I can disable the operator function of ' so I can use it as a naming scheme? I have tried using the Alias( ) command which works on one evaluation but if an equation is passed to another function the Alias( ) command is extinguished by the previous evaluation and it takes the derivative again which is undesired.
how_do_i_disable_prime_operation.mw
I haven't managed to round values with units, and get the trailing zeroes cut away, so I'd like to use the MapleTA:-Builtin:-numfmt function to do the job.
The problem is, that this function doesn't accept values with units.
I have managed to write a rounding function to do the rounding, but the problem here is that it will write the values with trailing zeroes, which isn't what I want.
Any ideas how to fix that?
How to find values of w for which determinant of A is zero?
determinant.mw
I have a proc that takes a function. This function is called  when the proc needs it to. Normally it will simply do a computation. The return is generally ignored(since the proc is a bit non-deterministic). I would like, though, to store values computed within the function in a global variable. I can't seem to use assign since it forces the variable to be local.
I can print the result of the function and it shows up but what is the proper way to assign variables within a function:
e.g.,
plot(store(x),x=1..2);
Then store would somehow store the values passed to the function(and in this case probably returning x). The example is not my use case and may not actually work properly.I cannot use global in the function passed as an argument to create a global variable.
F := proc(f)
    blah blah f(3)
    blah blah f(4)
R := []:
F(x->store(R, x));
R = [3,4]
The function
f := sin(x)/sqrt(2+sin(2*x));
has a simple elementary antiderivative but int(f,x) is huge and not elementary. What method would you suggest to find it?
with(geometry):
_EnvHorizontalName := x:
_EnvVerticalName := y:
R := 11:
r := 7:
a := sqrt(R*r):
b := 2:
circle(C1, [point(P1, [0, 0]), R]):
circle(C2, [point(P2, [R + 2*b + r, 0]), r]):
ellipse(p, (x - R - b)^2/b^2 + y^2/a^2 = 1):
draw([C1(color = yellow, filled = true),
C2(color = red, filled = true), p(color = blue, filled = true),
C1(color = black), C2(color = black), p(color = black)],
axes = none, view = [-15 .. 35, -15 .. 15], scaling = constrained):
alpha := arctan((R - r)/(R + 2*b + r));
long := cos(alpha)*(R + 2*b + r);
evalf(%);
circle(C2, [point(P2, [long, r - R]), r]);
rotation(p1, p, alpha, 'clockwise');
detail(p1);
point(A, 0, -R);
point(B, long, -R);
line(L1, [A, B]);
point(cen, [(143*sqrt(5))/25, -(26*sqrt(5))/25]);
reflection(L2, L1, cen);
detail(L2);
Error, (in geometry:-reflection) unable to compute coeff
Error, (in geometry:-detail) unknown object:  L2
draw([C1(color = yellow, filled = true), C2(color = red, filled = true), p1(color = blue, filled = true), C1(color = black), C2(color = black), p1(color = black), L1(color = black)], axes = none, view = [-15 .. 35, -15 .. 15], scaling = constrained);
A Bug in reflection ? Why these error messages. Thank you.
Given
expr:=c[2]*sin(sqrt(3)*x/2) + c[3]*cos(sqrt(3)*x/2);
expr:=convert(expr,tan);
How to change the second result above (with the tan) back the the original form it was in?
I tried all different convert and simplification commands, and non managed to get back the original form.
convert(expr,sincos);
simplify(expr,size);
#etc...
Maple 2022.1 on windows 10
First 281 282 283 284 285 286 287 Last Page 283 of 2431
