I was wondering if there was a way to permute a list to get a list of sums of permutations.
for example,
list:=[a,b,c]
permute(list,2) gives me ([a,b] [b,c] [c,a])
I would like to get this instead: ([a+b],[b+c],[c+d])
the quick brown fox jumps over the lazy dog
Download the_quick_brown_fox_jumps_over_the_lazy_dog.mw
I have a long description that contains some Maple commands.
I dont want to use # as the lines dont show up when i use
Isee:=proc(a)
    interface(verboseproc = 3);
    printf("%P", eval(a));
end proc
The long description is. Any way around the problem?
Test:=proc(A,B,C)  description  "Computes projective line through 2 projective points or intersert of 2 projective lines as a projective point or coincidence of piont  line
 Does some checking on validity of inputs.
Mobposn:- Global Variable, must = 1 or 3.
Points are returned as <1,x,y> or <x,y,1>
 Lines are returned as <z,x,y> or <x,y,z>,
normalgpt :- Global Variable must be 0 or 1.
Points with algecraic elements are not reduced to <1,x,y> or <x,y,1> if 0
 Points are defined as row vectors and  lines as column `vectors"`;
 print(A,B,A-C);
Hi, please how do I return the roots of a function in the form of I*y. The roots are [-.2381948477, -0.1434221912e-3, 0., 0.1434221912e-3, .2381948477] and I want to return them as [-.2381948477*I, -0.1434221912e-3*I, 0., 0.1434221912e-3*I, .2381948477*I]. I tried to use subs () function but couldn't work.
with(Student[Calculus1]):
soln := Roots(y-0.4646295e-3*tanh(y)+0.1839145082e-2*tanh(y)/(0.6000000000e-3*y^2-0.1840000000e-2), y);
subs(soln, I*y);
I don't have Maple yet, but if it can solve this problem for me then I'm ready to purchase!
I have a probability mass function pmf(in) to define a discrete probability distribution, based on a combinatoric analysis of an object of size n. So I don't have a drv X, I have a formula to generate Xn for 0 <= n, where n + 1 is then the size of the outcome alphabet.
In other words,
Xn = {0 <= i <= n : p(xi) = pmf(i, n)}
Where pmf(i, n) is 'well behaved' in the sense that it's not producing arbitrary results. As n increases, Xn has the same distribution simply with more detail.
So my question is, can Maple calculate the entropy, usually written H(X), of this distribution at, dare I say it, the limit, X?
Can it calculate it symbolically, or can it 'only' approximate it by a Taylor series or something?
Thanks in advance, this problem really has me stumped!
Is it possible to create a shaded area between a set of three LineChats in Maple?
I want to LinearSolve a square matrix (434160,434160) with sparse storage.
When I use SparseIterative with levelfill = 1, the commande gives a solution with very bad precision. I used many other options to get better precision without succes.
When I use SparseDirect (which I want to use), my PC (with 16G RAM) is bloqued and I must shut down it.
Is any advices to use SparseDirect for matrix with high dimensions and sparse storage.
Or, I must use another PC or another type of storage.
Dear power users, could someone be so kind to help me out with this file and give me some explanation on what I did wrong?
QuestionMaplePrimes.mw Thank you for you time and help
Why does an attempt to solve the ODEs in the uploaded worksheet fail and how can this error be removed so they can be solved?
Unable_to_convert.mw
with(plots): with(geometry):
_EnvHorizontalName := 'x':
_EnvVerticalName := 'y':
a := 7:
point(E, 0, a*sqrt(3)/2):
point(B, -a/2, 0):
point(C, a/2, 0):
point(o, 0, a*sqrt(3)/6):
point(A, 0, a/2):
point(H, 0, 0):
R := (3-sqrt(3))*sqrt(2)*a/12:
point(J, 0, a*sqrt(3)/6 - R):
triangle(Tr1, [E, B, C]):
triangle(Tr2, [A, B, C]):
StretchRotation(E1, E, B, Pi/4, clockwise, sqrt(2)/2);
coordinates(E1);
StretchRotation(E2, E, C, Pi/4, counterclockwise, sqrt(2)/2);
coordinates(E2);
triangle(Tr3, [E, B, E1]);
triangle(Tr4, [E, C, E2]);
triangle(Tr5, [B, C, J]);
circle(cir, [point(P1,[0,a*sqrt(3)/6]), R]):
poly := Matrix([[0, a*sqrt(3)/2], [-7/4 + (7*sqrt(3))/4, -7/4 + (7*sqrt(3))/4], [0, a/2], [7/4 - (7*sqrt(3))/4, -7/4 + (7*sqrt(3))/4]], datatype = float);
pol1 := polygonplot(poly, colour = "Magenta", transparency = 0.7, gridlines);
tex := textplot([0.2, a*sqrt(3)/2, "zE"], 'align' = {'above', 'right'});
draw([Tr1(color = cyan),
Tr3(color = green),
tex,
cir(color=blue),
Tr2(color = red),
Tr4(color = grey),
Tr1(color=blue)],'view' = [-5 .. 5, 0 .. 7],
axes = normal, scaling = constrained,size=[800,800]);
Error, (in geometry:-draw) the option must be of type equation or name
line(L1, [B, o]);
Equation(L1);
line(L1, -(7*x*sqrt(3))/6 + (7*y)/2 - (49*sqrt(3))/12 = 0);
reflection(J1, J, L1);
triangle(Tr6, [B, J1, E]);
line(L2, [C, o]);
Equation(L2);
line(L2, -(7*x*sqrt(3))/6 - (7*y)/2 + (49*sqrt(3))/12 = 0);
reflection(J3, J, L2);
triangle(Tr7, [C, J3, E]);
triangle(T1, [E, J1, A]);
triangle(T2, [E, C, E2]);
triangle(T3, [B, H, J]);
triangle(T4, [C, H, J]);
draw([cir(color = orange, filled = true, transparency = 0.1), pol1, Tr6(color = blue, filled = true, transparency = 0.2), Tr5(color = blue, filled = true, transparency = 0.2), Tr7(color = blue, filled = true, transparency = 0.2), T1(color = green, filled = true, transparency = 0.2), T2(color = green, filled = true, transparency = 0.2), T3(color = green, filled = true, transparency = 0.2), T4(color = green, filled = true, transparency = 0.2)], axes = none, scaling = constrained);
NULL;
NULL;
Why these errors messages ? Thank you.
Problem 1)   Give graph G1 and a graph G2  the problem is to extract maximum isomorphic copies of G1 from G2 such that it has no edge intersection maximum number is floor((number of edges of G2)/(number of edges of G1)) and display the Edge sets of those isomorphic graphs and the graph formed by the remaining edges sometimes their may be no remaing edges too.  Need all possible such copies.
Problem 2) Give graph G1 and a graph G2  the problem is to extract maximum isomorphic copies of G1 from G2 such that each copy has  exactly one edge intersection with each of the copies and that one edge intersection occurs only between those two copies and  display the Edge sets of those isomorphic graphs . Need all possible such copies.
If any more examples or explation will give kind help please I can give more examples or more kind please help.
I had written this c++ code years back for problem 2 which i have forgotten kind help if possible to make it better with maplesoft.
Please take your time. Kind help help plese it will be very helpful it is of real help.
orthogonal.txt
I had written this c++ code years back for problem 1 which i have forgotten kind help if possible to make it better with maplesoft.
decom.txt
Need to maintain memory space as graph size is a little big may be
would usage of database or any other be useful dont know I had done those code in c++ long back which i forgotten logic too.
Please please help based on latest technology please take your time and kind help I apologize disturb you kind help.
I would surely acknowledge for this great work as much as I can much more than I can acknowlege too
I am using Maple 2020
I need to conver 2D points to projective points. Originally I used lists but now need to handle vectors too. To add to that that the projective coordinate for points is now being stated as [1,x,y] instead of [x,y,1]. That is was easy enough to handle for lists.
I have a lot of old worksheets that use the list form [x,y,1] that I want to maintain compatibility with. I only have one procedure I need to convert.
Mobposn := 1;
testP := [2, 7];
if Mobposn = 1 then
    [1, op(testP)];
    [op(testP), 1];
I need to do the same for vector definition of the points. The points are defined as row Vectors
A:=<2,7>^%T
to get
Ap:=<1,2,7>^%T
or
Ap:=<2,7,1>^%T
I know coud just do (as these are short vectors)
Ap:=<1,A_1,A_2>^%T
or
Ap:=<A_1,A_2,1>^%T
Is there a more general way?
I am trying to do the following computation. I  extracted n*1 matrix from n*n matrix which unbelievably gives vector?
How I can do the following multiplication without using convert command? Or how to extract n*1 matrix (not vector) from n*n matrix without using convert?
A := Matrix(4, 4, {(1, 1) = m[1, 1], (1, 2) = m[1, 2], (1, 3) = m[1, 3], (1, 4) = m[1, 4], (2, 1) = m[2, 1], (2, 2) = m[2, 2], (2, 3) = m[2, 3], (2, 4) = m[2, 4], (3, 1) = m[3, 1], (3, 2) = m[3, 2], (3, 3) = m[3, 3], (3, 4) = m[3, 4], (4, 1) = m[4, 1], (4, 2) = m[4, 2], (4, 3) = m[4, 3], (4, 4) = m[4, 4]})
A := Matrix(4, 4, {(1, 1) = 0, (1, 2) = m[1, 2], (1, 3) = m[1, 3], (1, 4) = m[1, 4], (2, 1) = 0, (2, 2) = m[2, 2], (2, 3) = m[2, 3], (2, 4) = m[2, 4], (3, 1) = 0, (3, 2) = m[3, 2], (3, 3) = m[3, 3], (3, 4) = m[3, 4], (4, 1) = 0, (4, 2) = m[4, 2], (4, 3) = m[4, 3], (4, 4) = m[4, 4]})
A(1 .. 4, 1) := Matrix(4, 1):
A
Matrix([[0, m[1, 2], m[1, 3], m[1, 4]], [0, m[2, 2], m[2, 3], m[2, 4]], [0, m[3, 2], m[3, 3], m[3, 4]], [0, m[4, 2], m[4, 3], m[4, 4]]])
B := A(1 .. 4, 2)
B := Vector(4, {(1) = m[1, 2], (2) = m[2, 2], (3) = m[3, 2], (4) = m[4, 2]})
A.B
4
F := Matrix(4, 1, {(1, 1) = 0.4279668887e-7, (2, 1) = -0.3901148183e-7, (3, 1) = 0.3900685346e-7, (4, 1) = 0.})
Typesetting:-delayDotProduct(A, B)-F
Error, (in rtable/Sum) invalid input: dimensions do not match: Vector[column](1 .. 4) cannot be added to Matrix(1 .. 4, 1 .. 1)
A.convert(B, Matrix)-F
Matrix(4, 1, {(1, 1) = m[1, 2]*m[2, 2]+m[1, 3]*m[3, 2]+m[1, 4]*m[4, 2]-0.4279668887e-7, (2, 1) = m[2, 2]^2+m[2, 3]*m[3, 2]+m[2, 4]*m[4, 2]+0.3901148183e-7, (3, 1) = m[3, 2]*m[2, 2]+m[3, 3]*m[3, 2]+m[3, 4]*m[4, 2]-0.3900685346e-7, (4, 1) = m[2, 2]*m[4, 2]+m[3, 2]*m[4, 3]+m[4, 2]*m[4, 4]})
Download soalzarb.mw
I'm trying to draw the basins of attraction for King's method with f(z) = z^3 - 1
Thank you in Advance
I'm confused by the state equations resulting from linearizing the DoublePendulum example model.
The state equations are:
diff(x[1](t),t) = x[2](t),
diff(x[2](t),t) = 0,
diff(x[3](t),t) = x[4](t),
diff(x[4](t),t) = 0
where:
x[1](t) = R1_theta(t),
x[2](t) = diff(R1_theta(t),t),
x[3](t) = R2_theta(t),
x[4](t) = diff(R2_theta(t),t)
Am I understanding correctly that the state equations say that the angular acceleration of both revolute joints is zero? This is clearly not the case when you simulate the model and view the plots for angular acceleration. Can someone explain to me what's going on? Model with worksheet attached.
First 289 290 291 292 293 294 295 Last Page 291 of 2431
