I want to declare 'd' as a constant.
Please tell me how to declare 'd' as a constant.
intersection de deux droites l1 et l2 telles que l1 sous forme parametrique est [57/5 + 20*t, -21/5 - 40*t, 20*t] et de la meme façon
 l2 [249/100 - 120*t, 471/100 - 80*t, 200*t]. t est le parametre  . maple donne pour l'intersection de l1 et l2 le point P de coordonnes
 [249/100, 471/100, 0] que je ne trouve pas .expliquez moi ce resultat et merci beaucoup.
I have a big matrix which is computed in a worksheet, now I have to use this matrix in another worksheet. Could you recommend some ways of healthy transferring of quantities between worksheets?
here is logical_circuit.msim
i cannot connect the output of the left two AndGates to the input of the right AndGate. They are both digital signal connectors, why cannot be connected?
with(LinearAlgebra);
A := Matrix([[2, 1, 0, 0, 3], [0, 2, 1, 0, 0], [0, 0, 2, 1, 0], [0, 0, 0, 2, 1], [0, 0, 0, 0, 2]]);
sparsematrixplot(A, matrixview, color = "Red", symbol = "cross");
How do I change the plot to show other symbols? Even though I write for example "cross" I still get the default box.
Also, is there a way in which I can let the color depend on the number in the matrix? Right now it just shows all non-zero entries.
digits := 20;
unprotect(D);
G := 0.04361098108*x^2 + 0.4810001561*x*y + 1.326278064*y^2 - 0.7320831383*x - 2.656083763*y + 1 = 0
f := (x, y) -> lhs(G);
coeffs(f(x, y));
A, B, C, D, E, F := coeffs(f(x, y));
A := coeff(f(x, y), x, 2);
B := coeff(coeff(f(x, y), x), y);
C := coeff(f(x, y), y, 2);
D := coeff(coeff(f(x, y), x, 1), y, 0);
E := coeff(coeff(f(x, y), y, 1), x, 0);
F := tcoeff(f(x, y));
expand(B^2 - ((4*A) . C));
                          digits := 20
   f := proc (x, y) options operator, arrow; lhs(G) end proc
  1, -0.7320831383, 1.326278064, 0.04361098108, 0.4810001561,
    -2.656083763
A, B, C, D, E, F := 1, -0.7320831383, 1.326278064, 0.04361098108,
  0.4810001561, -2.656083763
                       A := 0.04361098108
                       B := 0.4810001561
                        C := 1.326278064
                       D := -0.7320831383
                       E := -2.656083763
                             F := 1
                               0.
with(geometry):
_EnvHorizontalName := 'x': _EnvVerticalName := 'y':
conic(co,f(x,y),[x,y]):
detail(co);
   GeometryDetail\["name of the object", co],
   ["form of the object", ellipse2d],
   ["center", [1.212351672 ^(10, 10), -2.198412833 ^(10, 9)]],
   ["foci", [[2.424703344 ^(10, 10), -4.396825668 ^(10, 9)],
   [0.1787052775, 0.9855002601]]],
   ["length of the major axis", 2.464245740 ^(10, 10)],
   ["length of the minor axis", 66579.62094],
   [                                               2
   ["equation of the ellipse", 1. + 0.04361098108 x
    + 0.4810001561 x y + 1.326278064 y  - 0.7320831383 x
    - 2.656083763 y = 0]/;
   "_noterminate";
G is a parabola with B^2-4*A*C=0 or an ellipse ? A =1 or F=1 ? Thank you for youy answer.
I need the Infinitesimals(Lie group analysis) of the system of PDE. I have attached below the system of PDE in MAPLE given below.MAPLE_Help.mw
I have code which in module which does this
           DEtools:-kovacicsols(ode,func)
Where ode is some ode and func is y(x).  When I step in the debugger, I get exception at this. It says
       DBG> DEtools:-kovacicsols(ode,func)
       Error, `DEtools` does not evaluate to a module
Same exact code works OK from worksheet as expected.   SO for some reason, inside this module it does not see DEtools and I have no idea why.
Then I tried with :-  before DEtools, but this did not help. it gives
DBG> :-DEtools:-kovacicsols(ode,func)
Error, `table([(dperiodic_sols)=proc () `DEtools/init`() <> 0; `ODEtools/intfactor`(_passed); end etc...
In a worksheet, it all works OK
ode:=diff(diff(y(x),x),x) = (-3/16/x^2-2/9/(x-1)^2+3/16/x/(x-1))*y(x);
func:=y(x);
Gives the solution with no error.
Any suggestion what could be the cause and what to try next? I never seen anything like this. I am running this code using
interface(warnlevel=4);
kernelopts('assertlevel'=2):
I am able to make a MWE. It seems this always happens in the debugger.  But if  I let it run, it works somehow. Only when I try to step into it, it gives error. Here is MWE
foo:=proc(ode,func)
   local result;
    DEBUG();
    result:=DEtools:-kovacicsols(ode,func);
    return result;
And now
func:=y(x);
foo(ode,y(x))
Now in the debugger if I do DEtools:-kovacicsols(ode,func) or if I stepin the call, I get the error. But I hit the continue botton, I do not get the error and it gives solution.
Why this happens?
Maple 2021.2 on windows 10
as the cuts show,  i build a simple  system to check how does the "edge with init" work? The switch is "ideal opening switch". the rising edge is always "0" while the voltage is always 1v, it seems that the "edge with init" doesn't work. Please give me some explaintion of the problem.
here is thetest.msim
@acer,
In the past, you had shown how to use take a given sparse A matrix and store the LU components and use the same factorization for multiple backsolves at https://www.mapleprimes.com/posts/41191-Solving-Sparse-Linear-Systems-In-Maple#comment200817
When PDEs are solved, we are calling the A matrix at every time step (with some discretizations in x) and the factorization is done and stored at every time step (this is time-consuming and memory-consuming). Is it possible to call UMFPACK using only the sparse storage and entries? The main routine seems to provide the option
https://people.sc.fsu.edu/~jburkardt/f77_src/umfpack/umfpack.html
This would mean that the pattern is found only once for the Jacobian at t= 0, then only the non-zero sparse entries (vector/row, not a matrix) are updated at every time step.
To be clear, what I am asking for is create a random sparse matrix (say 4x4 or 10x10)
create a b Vector.
Solve AZ =b with method = SparseDirect. (This should internally create and store R, CC, X as at https://people.sc.fsu.edu/~jburkardt/f77_src/umfpack/umfpack.html)
Store R, CC, X and update only X for a different A matrix with the same sparsity pattern and solve for Z using stored (R, CC), and updated X.
j'ai deux spheres concentriques s1 et s2  de centre O(-1,-1,-1) de rayon respectivement 3 et 2. mais maple donne que FindAngle(s1,s2)=arcos(31/12). comment expliquez ceçi et merci beaucoup.
PDETWOSTEPVARIAMETHOD.mwPDETWOSTEPVARIAMETHOD.mw
Pls i need help to correct this iteration code, I wrote but is not given the correct answer. find attached the worksheet
Hi again everybody,
I hope this can help in some classrooms.
This procedure has some warnings.  Someone else can clean it up.
Also, the ithprime() command can make it a bit slicker.
I did work with prime constelations project, and you can see my web page at mattanderson.fun  .
Refference oeis.org/A40 .
Some prime constelations, and k-tuples, are not of 'general intrest' yet, so they are not in the OEIS encyclopedia YET!
But prime numbers are exciting.  I like doing calculations.
Hopefully someone in the next generation will take up an intrest and do what I did.
pairs_procedure.mw
pairs_procedure.pdf
I wish the best on all of you.
Matt C. Anderson
which kind of input is DeepLearning:-Optimizer(GradientDescent()) suppose to take? Nummeric value or function?
I am fairly new to maple and needing to use it for my project this year. I have been advised to use it to help solve the following integral:
int(2/(1-x^p)^(1/p), x=0..1)
It will give me the answer I am looking for, however I cannot get it to explain the steps to get the answer. I have tried Student Calculus1 and ShowSolution but neither of them seem to be working.
Any help would be really appreiacted!
First 341 342 343 344 345 346 347 Last Page 343 of 2431
