I have a very simple task:
convert([a,b],`*`)
the result is of course a*b.  However if I load the Physics package beforehand, that is,
with(Physics)
convert([a,b],`*`)
the followinkg error shows up:
Error, unrecognized conversion: Physics:-`*`
I have read that the Physcs package redefines the mutiplication. This must be the source of the problem.
But how can I proceed. I need to do this task with the Physics package loaded.
Any help will be appreciated!
Hello everyone, I'm trying to interpolate a function using the roots of a Chebyshev polynomial as interpolation points, and then compute the absolute error. I want to compute that error via numerical integration, however, Maple is returning the expression of the integration itself. Why is that?
This is the code I'm using:
with(CurveFitting):
u := x -> exp(1/2*x^2 - 1/2):
r := evalf(allvalues(RootOf(ChebyshevT(5, x), x))):
points := Vector(5, i -> r[i]):
u_points := Vector(5, i -> u(points[i])):
P__2 := PolynomialInterpolation(points, u_points, x):
evalf(int(abs(u(x) - P__2), x = -1 .. 1))
This is the result:
I often create diagrams in Maple and export them so I can embed them in a Word Doc.  Lately, when I right-click on the picture so I can select "export," the entire program closes.   It seems to happen more when the picture is in 3D.   Am I doing something wrong?     Thanks.
           David
This is the graph I want but Nb must be equal to Nt. I should get values -diff(theta(eta), eta) for Bi or Nt Nb first?
BiNbNtxx.mw
Dear Users!
Hope everyone is fine here. Let me explain my problem first for this consider
diff(Y(xi), xi) = mu*(1-Y(xi)^2)
Then the derivative of a function U=u(Y(xi)) using chain rule (and expression menstiones as red) is given as,
diff(U, xi) = (diff(diff(Y, xi), Y))*U and (diff(diff(Y, xi), Y))*U = mu*(1-Y(xi)^2)*(diff(U, Y))
Similarly the second-order derivaitve of U=u(Y(xi)) using chain rule (and expression menstiones as red) is given as,
((ⅆ)^(2))/(ⅆ xi^(2))U=(ⅆ)/(ⅆ xi)(mu (1-Y^(2)(xi))*(ⅆ)/(ⅆ Y)U)=((ⅆ)/(ⅆ Y)*(ⅆ)/(ⅆ xi)Y)(mu (1-Y^(2)(xi))*(ⅆ)/(ⅆ Y)U)=(ⅆ)/(ⅆ Y)(mu^(2) (1-Y^(2)(xi))^(2)*(ⅆ)/(ⅆ Y)U)=-2 Y(xi) mu^(2) (1-Y^(2)(xi))*(ⅆ)/(ⅆ Y)U+ mu^(2) (1-Y^(2)(xi))^(2)*((ⅆ)^(2))/(ⅆ Y^(2))U;
In the similar way I want to compute the higher-order (like 5th order) derivaitve of U w.r.t. xi using the chain rule  (and expression menstiones as red) explained in above. Kindly help me soolve my problem
I am waiting for positive response.
Hi there!
I need a function that receives a function of several complex variables f(z), z=z_1,...z_n as an argument and returns its decomposition into its real and imaginary parts as functions of real variables: f(z)=u(x,y)+i*v(x,y).
Here is my Maple code for the case of two complex variables z_1, z_2:
UV:=proc(f, n) #second argument n is a number of variables
  local i, X, Y, XY, w, u, v:
  X:=[seq(x[i], i=1..n)]: # Create lists of real variables x_j, y_j
  Y:=[seq(y[i], i=1..n)]:
  XY:=zip((a,b)->a+I*b, X, Y): # Create a list of x_j + I * y_j
  map(a -> assume(a, real), X): # assume all x_j, y_j are real
  map(a -> assume(a, real), Y):
  w:=f(op(XY)): # substitute x+iy into f(z)
  u:=Re(w):
  v:=Im(w):
  return([u, v]):
To call the function, I need to type something like this:
UV((z1,z2) -> exp(z1+z2), 2)
The trouble I have is when I try calling this function inside another function that receives as arguments n functions of n complex arguments, in other words, it receives two lists, say: Z:=[z_1,...z_n], F:=[f_1,...f_n]. At some point, I need to decompose each f_j into its real and imaginary parts but unfortunately calling UV inside this function neither accepts lists
UV(Z -> f_j, n)
nor it understands something like
UV(op(Z) -> f_j, n) or UV((op(Z)) -> f_j, n).
Maybe my approach to this problem is incorrect from the very beginning, but I don't see any other acceptable ways to do it. Can anybody help me?
  • How to get the ln(z) 3d plot example in the FunctionAdvisor /plot ?
  • a table plot, to show different plots together
I do not understand why  simplify(eq,size,assume =t::real); gives an error but simplify(eq,size) assuming t::real; does not.
Which is the correct way to use assumptions with simplify? Inside or outside? And why would it make a difference?
Maple 2020.2 on windows 10.
`The "Physics Updates" version in the MapleCloud is 1122 and is the same as the version installed in this computer, created 2021, December 22, 16:3 hours Pacific Time.`
eq:=t = 1/2*Int(1/ln(exp(t^2-2*t*y+y^2))^(1/2)/exp(t^2-2*t*y+y^2)/(exp(t^2-2*t*y+y^2)-1),exp(t^2-2*t*y+y^2))+c[1];
t = (1/2)*(Int(1/(ln(exp(t^2-2*t*y+y^2))^(1/2)*exp(t^2-2*t*y+y^2)*(exp(t^2-2*t*y+y^2)-1)), exp(t^2-2*t*y+y^2)))+c[1]
Error, (in assuming) when calling '`anonymous procedure called from tools/recurse/indets`'. Received: 'invalid input: `simplify/int/simplify` expects its 3rd argument, r, to be of type {name, list({range, name = range}), name = anything}, but received exp((t-y)^2)'
t = (1/2)*(Int(1/(ln(exp((y-t)^2))^(1/2)*exp((y-t)^2)*(exp((y-t)^2)-1)), exp((y-t)^2)))+c[1]
I know the above inert int looks strange, but this is why it is inert. Later on there will be change of variable to make the integration variable a single symbol again as in normal integration usage.
Download simplify_error.mw
Hi, I'm just trying to use assign, like in Maple,
s := solve({x + y = 1, 2*x + y = 3}, {x, y});
                      s := {x = 2, y = -1}
assign(s);
x, y;
                             2, -1
in MapleFlow, but it doesn't work!
Any ideas?
Thanks very much in advance
Equação26_12.mw
Download Equação26_12.mw
How can i get datas and graphs of implicit function. I tried...
with(DEtools, odeadvisor);
ode := diff(y(x), x) = (-0.1*(y(x) - 0.7)^3 - 0.8*y(x)*(y(x) - 0.7)^2)/(0.7^2 - 2*0.7*y(x) + y(x)^2 - 0.7*0.2*0.8);
                                    3                        2
         d         -0.1 (y(x) - 0.7)  - 0.8 y(x) (y(x) - 0.7)
 ode := --- y(x) = -------------------------------------------
         dx                                        2
                            0.378 - 1.4 y(x) + y(x)
odeadvisor(ode);
          /                            3                        2\
          | d         -0.1 (y(x) - 0.7)  - 0.8 y(x) (y(x) - 0.7) |
odeadvisor|--- y(x) = -------------------------------------------|
          | dx                                        2          |
          \                    0.378 - 1.4 y(x) + y(x)           /
ans := dsolve(ode, implicit);
                2        9                    199
ans := x + ----------- + -- ln(10 y(x) - 7) + --- ln(90 y(x) - 7)
           10 y(x) - 7   28                   252
   + _C1 = 0
ic1 := y(0) = 0;
                        ic1 := y(0) = 0
sol := dsolve([ode, ic1], implicit);
                2        9                    199
sol := x + ----------- + -- ln(10 y(x) - 7) + --- ln(90 y(x) - 7)
           10 y(x) - 7   28                   252
     2   10         10
   + - - -- ln(7) - -- I Pi = 0
     7   9          9
subs(x = 1, sol);
   9        2        9                    199
   - + ----------- + -- ln(10 y(1) - 7) + --- ln(90 y(1) - 7)
   7   10 y(1) - 7   28                   252
        10         10
        9          9
solve(9/7 + 2/(10*y(1) - 7) + (9*ln(10*y(1) - 7))/28 + (199*ln(90*y(1) - 7))/252 - (10*ln(7))/9 - 10*I*Pi/9 = 0, y(1));
1     /      /
-- exp|RootOf|-280 I Pi exp(_Z) - 280 ln(7) exp(_Z) + 15680 I Pi
90    \      \
          /1           56\
   + 81 ln|- exp(_Z) - --| exp(_Z) + 199 _Z exp(_Z) + 15680 ln(7)
          \9           9 /
                          /1           56\                   \\
   + 324 exp(_Z) - 4536 ln|- exp(_Z) - --| - 11144 _Z - 13608||
                          \9           9 /                   //
     7
     90
implicitplot(sol, x = 0 .. 10, y = 0 .. 10);
                /         2        9
    implicitplot|x + ----------- + -- ln(10 y(x) - 7)
                \    10 y(x) - 7   28
         199                   2   10         10
       + --- ln(90 y(x) - 7) + - - -- ln(7) - -- I Pi = 0,
         252                   7   9          9
      x = 0 .. 10, y = 0 .. 10|
but I wasn't successful.
Thank you everyone!
I am trying to solve an ODE with nonlinear boundary conditions, it is a BVP. And the maple let me to specify an approximate initial solution. I just don't know how to define the initial solution. What format is the initial solution? I have tried the Help Document told me to, but I still can't figure it out. Please help me, thank you!
In
I want to compute x__0 as a function of alpha. I tried fsolve but could not make it work (see attached).
What did I do wrong? Are there other ways in Maple to solve such problems?
I am stuck here and would very much appreciate help.
inverse_function_with_fsolve.mw
Update:
Its likely that the recently introduced warnings for definite integrals would have helped in this case to find a solution on my own. When I run this worksheet with Maple 2023, it immediately suggests the use of assumptions.
Hi everyone.
I need a program in maple to simulate the orbit of a satellite slowed down by the earth's atmosphere.
I chose the simple case, in which the orbits of the two are elliptical and I use The animation to do this. In this case I did not consider that the satellite interacts with the atmosphere.
Now,  I need equations to write part of the program in which I think the satellite is slowed down by the earth's atmosphere. I don't have any ideea to resolve this problem.
Soo.. I really need your' help as soon as posible.
Thank you a lot!
Dear Users!
Hope you are doing well. I have a funtion give bellow:
beta[1]*exp(x*alpha[1]+y*beta[1]-z*sqrt(-alpha[1]^2-beta[1]^2))/(1+exp(x*alpha[1]+y*beta[1]-z*sqrt(-alpha[1]^2-beta[1]^2)));
For any value of alpha[1] and beta[1] the term highlighted red becomes the imaginary form. I want to separate the real and imaginary parts of this function. Kindly help me in this matter, thanks
Hi, I am trying to enter into the Mini-Course Computer Algebra for Physicists from the help, but instead of going to the page I get the help page of Physics[FeynmanIntegral]. Can anyone confirm that this happens to them on Maple 2021.2?
Kevin
First 357 358 359 360 361 362 363 Last Page 359 of 2431
