Hi everyone, how can i plot nonlinear phase portraithere k,w, alpha,K, k, gamma, beta are arbitrary constants and i have three equilibrium points:
I hope the resulting graphics are as follows :
How can I plot these phase portraits? Thanks in advance.
hello,
i want to animate a sequence from a nomeric solution i recived, i have a sequene for displacment and another one for time, is there a way to do that ?
Has somebody experienced something like that before?
I was searching for a bug in a sheet, and was absolute unable to find out why some results in a sheet were different from another sheet.
Found out that it actually was a pure graphics problem. With normal zoom (100%) the minus signum is not visible.
Blowing up the zoom to 125% shows the signum again.
I have an expression of the form
Expr := n0*C[0] + n1*C[1] + ... + nk*C[k] + n = 0,
where the numbers n0,...,nk and n are known to Maple (after it made some calculations), whereas C[0],...,C[k] are undetermined.
I would like to know the values of all of n0,...,nK and n. For n0,...,nk, I found them with
coeff(Expr, C[m], 1),
with m in 0,...,k. But I don't know how to get the value of the "independent term" n.
Can someone help me with this?
I have a list of lists made from a combinat and was wondering how to make a new list from it that only contains lists that the elements sum up to 0.
For example:
L1 := [[1,1,1,1], [1,2,0,0], [0,0,0,0], [1,1,-2,0]];
and I want the result to be
L2:= [[0,0,0,0], [1,1,-2,0]]
Thank you in advance! I'm new to maple so would appreciate the guidance!
I am studying something about complex numbers.
What commands are specific to find in Maple for complex numbers ?
  • complexplot()
  • conformal()
  • conformal3d()
It seems that there are a lot of standard calculus statements can be used by adding the word : complex
Iam using here a package downloaded from Maple website : complex analysis for mathematics and engineering
Got the impression that some modern plot commands for complex numbers are not yet in this book present ..and how about other commands?
an_introduction_to_complex_numbers.mws
Is an analytic solution possible for this problem: find an expression for maximum of power subject to constraints f=0, g=0, h=0? The feasible range is: T1, T2, R, Rthhot, Rthcold, and Z>0.
I know how to solve it using either FindMaximum or Langrage multiplier if I assign numerical values to T1, T2, R, Rthhot, Rthcold, and Z. I'd like to know if it's possible to find an analytic solution if I leave T1, T2, R, Rthhot, Rthcold and Z as parameters
I tried this but it did not work:
f := (X, Y, Rload, Rth, S) -> -(T1 - X)/Rthhot + (X - Y)/Rth + S^2*X*(X - Y)/(R + Rload) + (-1)*0.5*S^2*Rload*(X - Y)^2/(R + Rload)^2;
g := (X, Y, Rload, Rth, S) -> (Y - T2)/Rthcold - (X - Y)/Rth - S^2*Y*(X - Y)/(R + Rload) + (-1)*0.5*S^2*Rload*(X - Y)^2/(R + Rload)^2;
h := (X, Y, Rload, Rth, S) -> S^2*Rth/R - Z;
power := (X, Y, Rload, Rth, S) -> S^2*(X - Y)^2*Rload/(R + Rload)^2;
LagrangeMultipliers(power(X, Y, Rload, Rth, S), [f(X, Y, Rload, Rth, S), g(X, Y, Rload, Rth, S), h(X, Y, Rload, Rth, S)], [X, Y, Rload, Rth, S]);
Hello everybody,
I managed to get to the point that i could start part 2 of the book series of applied Dutch math.
This paragraph is about Taylor series.
Now i am being asked to find a solution for the taylorseries with a certain x value. That is all fine, Maple can spit it out. But to put in into something that is there with a sum sign in front of it is something else. I have to convert the solution into something that is written with "x to the k-ed, something something".
Now i did find to solution to a not so complex one. I will add that one on the maple sheet. But there is this one that is really complex, and i cant get my head around how to get to the final solution that makes the sum go and work well. It does have some series to it. But i dont know how to find that one out. Is there some trick to make it work?
Without further ado:
a.
taylor(1/(3-x), x = 2)
series(1+x-2+(x-2)^2+(x-2)^3+(x-2)^4+(x-2)^5+O((x-2)^6),x = 2,6)
Sum((x-2)^k, k = 0 .. infinity)
b.
taylor(sqrt(x), x = 1, 16)
series(1+(1/2)*(x-1)-(1/8)*(x-1)^2+(1/16)*(x-1)^3-(5/128)*(x-1)^4+(7/256)*(x-1)^5-(21/1024)*(x-1)^6+(33/2048)*(x-1)^7-(429/32768)*(x-1)^8+(715/65536)*(x-1)^9-(2431/262144)*(x-1)^10+(4199/524288)*(x-1)^11-(29393/4194304)*(x-1)^12+(52003/8388608)*(x-1)^13-(185725/33554432)*(x-1)^14+(334305/67108864)*(x-1)^15+O((x-1)^16),x = 1,16)
"Sum(((x-1)^(k))/(???????),k=0..infinity)"
8*(1/2); 16*(1/8); 128*(1/16); 256*(1/128); 1024*(1/256); 2048*(1/1024); 32768*(1/2048); 65536*(1/32768); 262144*(1/65536); 524288*(1/262144); 4194304*(1/524288); 8388608*(1/4194304); 33554432*(1/8388608); 67108864*(1/33554432)
4
8
4
16
4
8
4
Greetings,
The Function
Download Mapleprimes_Book_2_Question_1.mw
Is Maple Flow available as individual licence similar to Maple?
I want to compute the series expansion of i3_r wrt (x, y, z) at point (x=y=z=0):
i2   := (x,y) -> -(1/2)*I*(exp(I*x)*(sin(x)/x)-exp(I*y)*(sin(y)/y))/(x-y):
i3_r := -(1/2)*I*(i2(y,z)-i2(y,x))/(z-x);
My first attempt was to compute this mulltiple series expansion this way:
ordre := 3:
sx := convert( series(i3_r, x, ordre), polynom);
sy := convert( series(sx  , y, ordre), polynom);
sz := convert( series(sy  , z, ordre), polynom);
But this gives me sy=sz=0 whatever the expansion order.
I then do this:
sx :=              convert(series(i3_r , x, ordre), polynom):
sy := add(map(u -> convert(series(u    , y, ordre), polynom), [op(expand(sx))])):
sz := add(map(u -> convert(series(u    , z, ordre), polynom), [op(expand(sy))]));
and obtained non zero results for both sy and sz (but are they are correct ?).
Could you explain me what happens and tell me how to find the series expansion of i3_r wrt (x, y, z) ?
TIA
with(plots)
fixedparameter := [Nb = 0, Nt = 0, Bi = 1000, Le = 10]
DE1 := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))-[diff(f(eta), eta)]^2 = 0
diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))-[diff(f(eta), eta)]^2 = 0
DE2 := diff(theta(eta), eta, eta)+Pr*f(eta)*(diff(theta(eta), eta))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*[diff(theta(eta), eta)]^2 = 0
diff(diff(theta(eta), eta), eta)+Pr*f(eta)*(diff(theta(eta), eta))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*[diff(theta(eta), eta)]^2 = 0
DE3 := diff(phi(eta), eta, eta)+Le*(diff(phi(eta), eta))+Nt*(diff(theta(eta), eta, eta))/Nb = 0
diff(diff(phi(eta), eta), eta)+Le*(diff(phi(eta), eta))+Nt*(diff(diff(theta(eta), eta), eta))/Nb = 0
BC1 := f(0) = 0, f(eta) = 1-exp(-eta), (D(f))(0) = 1, (D(f))(10) = 0
BC2 := theta(10) = 0, (D(theta))(0) = -Bi*[1-theta(0)]
BC3 := phi(0) = 1, phi(10) = 0
L := [0.7e-1, .2, .7, 2, 7, 20, 70]; for k to 7 do R := dsolve(eval({BC1, BC2, BC3, DE1, DE2, DE3}, Pr = L[k]), [f(eta), theta(eta), phi(eta)], numeric, output = listprocedure); Y || k := rhs(R[5]); YP || k := -rhs(R[6]) end do
Download ODEprobz.mw
H.M.mw
with(plottools):
with(CurveFitting):
with(Statistics):
Digits := 10:
L := point([0, 0, 0], color = blue, symbol = cross, symbolsize = 50), point([0, 0, 1], color = red, symbol = cross, symbolsize = 50), point([0, 1, 0], color = black, symbol = cross, symbolsize = 50):
display(L, axes = boxed, view = [-1 .. 1, -1 .. 1, -1 .. 1], orientation = [125, 65])
Download H.M.mw
Hi experts,
I have an equation. I tried to use subs command to substitute x with complex number p+iq in this equation and then separate the Re and Im part of the equation, but it does not work.
How can I do this?
How can I plot the Re and Im part of the equation vs y for some different parameters?
Equation:
eq.mw
I would like to open a specially formatted document from start/new document. I set  up one with a fixed width table to make it easy to print to A4. I find the very useful for taking notes.
Currently I just save it as  a usual document. The attached shows the basic setup I use. Contents arn't too relivant.
"R(m2,m3,m4,...)≡((2 m2+3 m3+4 m4+...)!)/((1+m2+2 m3+3 m4+...)!m2!m3!m4!...)"
Xterm := factorial(2*m+3*n+4*p+5*q)*c[2]^m*c[3]^n*c[4]^p*c[5]^q/(factorial(1+m+2*n+3*p+4*q)*factorial(m)*factorial(n)*factorial(p)*factorial(q))
k := 5
5
x := add(add(add(add(Xterm, q = 0 .. 4*k), p = 0 .. 3*k), n = 0 .. 2*k), m = 0 .. k)
nops(x)
22176
nops(TestPoly)
ldegree(TestPoly)
mtaylor(TestPoly, [c[2], c[3], c[4], c[5]], k+2)
TestPoly
C1 := 1; C2 := -2; C3 := 3; C4 := -4; C5 := 5
5
Poly1 := expand((y+C1)*(y+C2)*(y+C3)*(y+C4)*(y+C5))
y^5+3*y^4-23*y^3-51*y^2+94*y+120
Poly1 := Poly1/coeff(Poly1, y, 0)
(1/120)*y^5+(1/40)*y^4-(23/120)*y^3-(17/40)*y^2+(47/60)*y+1
fsolve(Poly1, y)
-5., -3., -1., 2., 4.
coeff(Poly1, y, 1)
47/60
Poly2 := algsubs(y = -z/coeff(Poly1, y, 1), Poly1)
-(6480000/229345007)*z^5+(324000/4879681)*z^4+(41400/103823)*z^3-(1530/2209)*z^2-z+1
(14)
-0.28254e-1*z^5+0.66398e-1*z^4+.39876*z^3-.69262*z^2-1.*z+1.
(15)
solve(Poly2, z)
-47/30, -47/15, 47/12, 47/20, 47/60
(16)
-%/coeff(Poly1, y, 1)
2, 4, -5, -3, -1
(17)
Download A4_format.mw
First 359 360 361 362 363 364 365 Last Page 361 of 2431
