I drew a polygon using some point coordinates combined with the pointplot.
c1 := <0, -2>:
c2 := <1, 2>:
c3 := <2, 2>:
c4 := <0.5, 6>:
c5:=<1, 4>:
p1:=pointplot([c1, c2, c3, c4,c5, c1], color = red, connect = true);
I ‘d like to add  label  of endpoints to polygons, although I did this via textplot, but it didn't feel very neat. I hope when the polygon is drawn, labels of  every endpoints appear . These labels are the names of the assignment variable for the coordinates of the endpoints.
c1 := <0, -2>:
c2 := <1, 2>:
c3 := <2, 2>:
c4 := <0.5, 6>:
c5:=<1, 4>:
t1 :=textplot([0, -2, 'typeset'("c1")], 'align' = 'above'):
t2 :=textplot([1, 2, 'typeset'("c2")], 'align' = 'above'):
t3 :=textplot([2, 2, 'typeset'("c3")], 'align' = 'above'):
t4 :=textplot([0.5, 6, 'typeset'("c4")], 'align' = 'above'):
t5 :=textplot([1, 4, 'typeset'("c5")], 'align' = 'above'):
p1:=pointplot([c1, c2, c3, c4,c5, c1], color = red, connect = true):
display({p1, t1,t2,t3,t4,t5});
I think  DrawGraph command  in graph theory package  is very good to achieve this in a sense.
Hello everyone.
Please help me solve this equation for u using Maple.
Div(u) = d(ru)/(dr)*1/r = 2*a = const; u = u(r);
Divergence(u) = d(ru)/(r*dr) and d(ru)/(r*dr) = 2*a and 2*a = const
u = u(r)
Thanks in advance for your help.
i'm working with the confluent Heun function (Maple 2019).
Since for the case of an integer coefficient delta or gamma there are two integer Frobenius roots at the regular singularities 0 or 1, there is a logarithmic term in the Frobenius solution at these singularities. So, my question is the following:
When moving around this singularity in the complex plane, the value of the logarithmic term might depend on the choice of the complex logarithm's branch cuts. So, does anybody know just about how HeunC is implemented? Is there sth like a power series solution, which value would in my oppinion depend on this choice of a branch cut?
Or is there another implementation that preserves us from this ambiguity in the case of logarithmic singularities (i.e. integer coefficients in the confluent Heun equation)?
Many thanks,
integration_doubt.mw
Hello all,
I am trying to solve for the first-order derivative of a function f2 w.r.t variable a when it is equated to 0. the function f2 is a summation of two integrals as shown in the file. Kindly help me if there is any way to obtain solutions without numerical settings. Can functionalities like the Leibnitz rule be done in MAPLE? Thanks for your advice/help.
Could you please give an example of a code where I can add outputs from a loop to a list. I am using the break command to end the loop so I don't have the number of elements in advance.
Edit: I have also changed the title accordingly. There was more to this question, somehow which was omitted. I am writing it again. My code looks like below:
if ...
do H[i]:=int(K);
... end do;
I want an array of H[i]'s. The loop breaks when a condition is met, so I can't create an array with a given dimension beforehand. Thank you.
How do I find with maple's help  for which parameter m does the equation:
x^2+2*m*x-6*x=m^3 have one of its roots equal to the square of the other root?
I wrote the following orders
With(GeM):
gem_decl_vars(indeps=[t,x], deps=[u(t,x)]);
gem_decl_eqs([diff(u(t,x),t,t)+a∗diff(u(t,x),x,x)+b∗
u(t,x)+c∗(u(t,x))^3=0],solve_for=[diff(u(t,x),t,t)])
det_eqs:=gem_conslaw_det_eqs([t,x,u(t,x),diff(u(t,x),
t),diff(u(t,x),x)]):
CL_multipliers:=gem_conslaw_multipliers();
simplified_eqs:=DEtools[rifsimp](det_eqs,
CL_multipliers, mindim=1)
in maple 17, but the program cannot calculate and gives me an error. Does anyone help me to solve this problem.
BTW "recusant" is an old word, religious in origin, for someone who refuses to do what they're told, or believe what they're told to believe.
Here's my problem:
phi := (1+sqrt(5))/2;
plots[pointplot]([seq([n, sin(n*phi)], n = 1000 .. 2000)], symbol = point, axes = boxed, labels = [n, typeset('sin(n*phi)')], labeldirections = [horizontal, vertical])
produces a label sin( n phi ).  I want it to say sin( phi n ).
I've tried the noncommuting times &*  (which prints &*) and the matrix product . (which prints as a function call).
Is there a way to typeset this product in the order that I want?  Here "n" is the variable and "phi" is the constant (yes that looks weird, but so does the graph).  I suspect that there is; I think "typeset" is probably much more powerful than I have been kludging it as.  Help?
screenshot:
I have this function : r(theta) = sec[t(theta)] = sec * (theta - (Pi/2) * (2/Pi *(theta + Pi/4))).
Since this function is in terms of (theta,r(theta)) ... how would I graph this in terms of Cartesian Co-ordinates instead of Polar ?
Hi, I have animated plot visualizing the moving of point from location a to location b. I need line to be plotted in trace of moved point in area. Please see the code that I implement below. Many Thanks
with(Statistics):
L:=[[0],[34,7],[39,8,6], [45,2,3,7]]:
animate(( PointPlot, [L[trunc(t)]], t=1..3, frames=50), symbol=solidcircle,symbolsize=40);
Sorry for this simple question but I am new to Maple and need to do just this one thing...
Lets say I have a function fp(x) which draws out some envelope when I change p. I wanted to calculate this euqation by hand but this does not seem possible, since f is too complex. How can I use Maple to find the area under any Enevelope? Or maybe a bit simpler: How can I just find the envelope and save it to use it later?
I am sorry,since I don't know anything about Maple and I need that fast...
I want to solve the following equation and, assuming x=x_r+Ix_i where x_r and x_i are real and imaginary part of x,  plot x_r and x_i versus y . How can I do in Maple?
x^6+x^4*(1.02-0.50e-2*y)+x^2*(-0.4950e-2*y+0.625e-5*y^2)+0.625e-5*y^2=0
I have number 0.12
I use convert(0.12,string), result ".12" lost 0. Why?
Please help me @acer
Hi everyone
I am a learner using the maple program and I have a problem drawing multiple lines with different styles. I have tried the following:
restart; with(VectorCalculus); with(LinearAlgebra); with(DEtools);
F0 := 0; zeta := .25; w := 1; Omega := 1; m := 1;
ode1 := diff(x(t), t) = y(t); ode2 := diff(y(t), t) = F0*cos(Omega*t)/m-2*zeta*w*y(t)-w^2*x(t);
DEplot([ode1, ode2], [x(t), y(t)], t = 0 .. 10, x = -100 .. 100, y = -100 .. 100, [[x(0) = 0, y(0) = 50], [x(0) = 9, y(0) = 25], [x(0) = 85, y(0) = 20], [x(0) = .25, y(0) = .5], [x(0) = 7, y(0) = 5]], linestyle = [dash, dashdot, dot, longdash, spacedash], linecolor = [red, green, black, navy, maroon], thickness = 2, axes = normal, labels = [x(t), y(t)], arrows = medium, stepsize = 0.1e-1);
I would like to obtain in the graph that each trajectory has a different type of line.
On the other hand I wonder: Is it possible to use the options boxed and normal at the same time?
Greetings and thank you all
First 375 376 377 378 379 380 381 Last Page 377 of 2432
