I use Syrup to solve for the transfer function of a circuit, and in particular, the voltage at a given node.   If I use the "trans" option, the solution generates the expected result, in the expected format.  Syrup solves the differential equations and the resulting time domain equation is as expected.
If I then use the 'AC'  option, I get the result in the s-domain.  I then solve for the step response, and take the inverse Laplace transform.  The solution is given in terms of sinh and cosh.
If I plot the voltage in either solution as a function of time, the plots are identical.  So, the sinh/cosh solution must be somehow simplifiable so that it "looks" like the time domain solution I get from the transient analysis.
with(inttrans)
with(Syrup)NULL
with(DynamicSystems)
interface('displayprecision' = 8)
with(plots)
assum := R1::real, C1::real, R2::real, C2::real, R1 > 0, R2 > 0, C1 > 0, C2 > 0, t::realvin::real, vin > 0
vin::real, 0 < vin
ckt := [vin(5), Rm(1.0*10^7), Cm(1.8*10^(-11), ic = 0), `&//`(R1(9.*10^6), C1(1.5*10^(-11), ic = 0)), `&//`(R2(1.*10^6), C2(1.5*10^(-11), ic = 0))]
[vin(5), Rm(10000000.0), Cm(0.1800000000e-10, ic = 0), `&//`(R1(9000000.), C1(0.1500000000e-10, ic = 0)), `&//`(R2(1000000.), C2(0.1500000000e-10, ic = 0))]
ckt1 := [vin(0), Rm(0.10e8), Cm(0.18e-10, ic = 2.5), `&//`(R1(0.9e7), C1(0.15e-10, ic = 2.25)), `&//`(R2(0.1e7), C2(0.15e-10, ic = .25))]
Draw(ckt)
Solution doing Transient Analysis
deqs, rest := Solve(ckt, 'tran', 'returnall')
sol1 := dsolve(deqs):
Reassign rest to include the solution.
rest := eval(rest,sol1):
Compute the voltage across the capacitor Cm.
tmp1:=simplify(eval(v[Cm](t), sol1));
(1/32164)*(-415*8041^(1/2)-40205)*exp((100000/459)*(-119+8041^(1/2))*t)+5/2+(1/32164)*(415*8041^(1/2)-40205)*exp(-(100000/459)*(119+8041^(1/2))*t)
evalf[5]((1/32164)*(-415*8041^(1/2)-40205)*exp((100000/459)*(-119+8041^(1/2))*t)+5/2+(1/32164)*(415*8041^(1/2)-40205)*exp(-(100000/459)*(119+8041^(1/2))*t))
-2.4070*exp(-6389.4*t)+2.5000-0.92993e-1*exp(-45461.*t)
solve(tmp1=2.5*(1-exp(-1)),t)
p10 := plot(tmp1, t = 0 .. 0.00050000, color = 'blue', linestyle = 'dash')
p10 := plot(tmp1, t = 0 .. 0.5e-3, color = 'blue', linestyle = 'dash')
Solution from AC analysis:
sol, rest := Solve(ckt, 'returnall')
vnode2 := eval(v[2], sol)
1000000*(27*s+1000000)/(1377*s^2+71400000*s+400000000000)
NULLNULL
Impulse Response
temp1 := invlaplace(vnode2, s, t)
(1000000/24123)*exp(-(700000/27)*t)*(3*8041^(1/2)*sinh((100000/459)*t*8041^(1/2))+473*cosh((100000/459)*t*8041^(1/2)))
41.454*exp(-25926.*t)*(269.02*sinh(19536.*t)+473.*cosh(19536.*t))
Step Response
temp2 := invlaplace(vnode2/s, s, t)
5/2-(5/16082)*exp(-(700000/27)*t)*(83*8041^(1/2)*sinh((100000/459)*t*8041^(1/2))+8041*cosh((100000/459)*t*8041^(1/2)))
p1 := plot({temp2, (1-exp(-1))*2.5}, t = 0 .. 0.5e-3)
temp3 := solve(temp2 = (1-exp(-1))*2.5, t)
0.1505875131e-3
p2 := plot([temp3, temp3], [0, 2.5])
display({p1, p10, p2})
What is going on?  Where are the sinh and cosh terms in the solution coming from and why wont it simplify so that it looks like the other solution if they are identical?  Is there something special I need to do when using the invlaplace function?
Download help_maple.mw
My Maple worksheet, which was working fine a few days ago, suddently cannot be modified. Many elements on the top bar (execute group, execute entire worksheet, insert maple prompt) are grayed out. Additionally I cannot edit any commands in the worksheet; clicking a command does not show any cursor and keyboard input does nothing.
Apparently I have entered some kind of read-only mode. I do not know how I did this. Meanwhile, if I start a new worksheet I can edit and execute as normal.
How do I revert my worksheet back to normal?
I dont like cursing, but this had got me going.
How are there no solutions for the intersection points, i am only getting some, but not all of them, but i did ask Maple to produce an answer, but it however failed to produce all the answers. Its not that i did not try different techniques.
I really wonder what went wrong. How could this be?! Just Maple... Answers between zero and 2 Pi... plz.... (!!!)
The answers i get with the suggested method from my math book dont give any straight answer. How is that an answer, i dont want imaginary numbers, i dont want to have  Z values (what is with that anyways?)..
Well here is what i found. Also if i were to ask for solutions between x values closer together i got more answers that were not there before. That is not what i want, that is like manual labor, that is not what i want at all, i want to be faster not slower. My graphing calculator was even a faster and that did get all the answers right away..
Any way, it missed an answer between 1/2Pi and Pi, answers that were not there before when looking for values between 0 and 2Pi.
So, so odd..
It says in english: Also with finding solutions for solving goniometric equations with Maple, we should not forget that there are more solutions than just one, most of the times. We give you two methods to find all the solutions for solving goniometric equations.
#first attempt
evalf(solve({x > 0*Pi, sin(x) = cos(4*x-(1/6)*Pi), x < 2*Pi}, x, allsolutions, explicit)); smartplot(sin(x), cos(4*x-(1/6)*Pi)); plot([sin(x), cos(4*x-(1/6)*Pi)], x = 0 .. 2*Pi, y = 0 .. 1); evalf(solve({x > (1/2)*Pi, sin(x) = cos(4*x-(1/6)*Pi), x < Pi}, x, allsolutions, explicit))
{x = 4.188790204}, {x = 5.445427267}
{x = 1.675516082}, {x = 2.932153141}
#second attempt
"f(x):=sin(x); g(x):= cos(4 x-1/(6)*Pi);fsolve([f,g]);"
proc (x) options operator, arrow, function_assign; sin(x) end proc
proc (x) options operator, arrow, function_assign; cos(4*x-(1/6)*Pi) end proc
[6.8067840827778841, -9.1035796650957585]
#third attempt;
_EnvAllSolutions := true; solve(sin(x) = cos(4*x-(1/6)*Pi), x)
-(2/3)*Pi+2*Pi*_Z4, -arctan((1/6)*3^(1/2)*(2*((1/2)*(4+(4*I)*3^(1/2))^(1/3)+2/(4+(4*I)*3^(1/2))^(1/3))^2-(1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3)-4)/((1/4)*(4+(4*I)*3^(1/2))^(1/3)+1/(4+(4*I)*3^(1/2))^(1/3)))+2*Pi*_Z5, -arctan((1/6)*3^(1/2)*(2*(-(1/4)*(4+(4*I)*3^(1/2))^(1/3)-1/(4+(4*I)*3^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3)))^2+(1/4)*(4+(4*I)*3^(1/2))^(1/3)+1/(4+(4*I)*3^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))-4)/(-(1/8)*(4+(4*I)*3^(1/2))^(1/3)-(1/2)/(4+(4*I)*3^(1/2))^(1/3)+((1/4)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))))-Pi+2*Pi*_Z5, -arctan((1/6)*3^(1/2)*(2*(-(1/4)*(4+(4*I)*3^(1/2))^(1/3)-1/(4+(4*I)*3^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3)))^2+(1/4)*(4+(4*I)*3^(1/2))^(1/3)+1/(4+(4*I)*3^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))-4)/(-(1/8)*(4+(4*I)*3^(1/2))^(1/3)-(1/2)/(4+(4*I)*3^(1/2))^(1/3)-((1/4)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))))+Pi+2*Pi*_Z5, arctan((1/3)*3^(1/2)*(2*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 1)^3-7*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 1)+2)/RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 1))+2*Pi*_Z6, arctan((1/3)*3^(1/2)*(2*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 2)^3-7*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 2)+2)/RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 2))+2*Pi*_Z6, arctan((1/3)*3^(1/2)*(2*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 3)^3-7*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 3)+2)/RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 3))+Pi+2*Pi*_Z6, arctan((1/3)*3^(1/2)*(2*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 4)^3-7*RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 4)+2)/RootOf(_Z^4-_Z^3-4*_Z^2+4*_Z+1, index = 4))+Pi+2*Pi*_Z6
#fourth attempt;
RootOf(sin(x) = cos(4*x-(1/6)*Pi), x); allvalues(%)
RootOf(sin(_Z)-sin(4*_Z+(1/3)*Pi))
-(2/3)*Pi+2*Pi*_Z7, -arctan((1/6)*3^(1/2)*(2*((1/2)*(4+(4*I)*3^(1/2))^(1/3)+2/(4+(4*I)*3^(1/2))^(1/3))^2-(1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3)-4)/((1/4)*(4+(4*I)*3^(1/2))^(1/3)+1/(4+(4*I)*3^(1/2))^(1/3)))+2*Pi*_Z8, -arctan((1/6)*3^(1/2)*(2*(-(1/4)*(4+(4*I)*3^(1/2))^(1/3)-1/(4+(4*I)*3^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3)))^2+(1/4)*(4+(4*I)*3^(1/2))^(1/3)+1/(4+(4*I)*3^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))-4)/(-(1/8)*(4+(4*I)*3^(1/2))^(1/3)-(1/2)/(4+(4*I)*3^(1/2))^(1/3)+((1/4)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))))-Pi+2*Pi*_Z8, -arctan((1/6)*3^(1/2)*(2*(-(1/4)*(4+(4*I)*3^(1/2))^(1/3)-1/(4+(4*I)*3^(1/2))^(1/3)-((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3)))^2+(1/4)*(4+(4*I)*3^(1/2))^(1/3)+1/(4+(4*I)*3^(1/2))^(1/3)+((1/2)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))-4)/(-(1/8)*(4+(4*I)*3^(1/2))^(1/3)-(1/2)/(4+(4*I)*3^(1/2))^(1/3)-((1/4)*I)*3^(1/2)*((1/2)*(4+(4*I)*3^(1/2))^(1/3)-2/(4+(4*I)*3^(1/2))^(1/3))))+Pi+2*Pi*_Z8, arctan((1/6)*3^(1/2)*(2*(1/4+(1/4)*5^(1/2)+(1/4)*(30-6*5^(1/2))^(1/2))^3+1/4-(7/4)*5^(1/2)-(7/4)*(30-6*5^(1/2))^(1/2))/(1/8+(1/8)*5^(1/2)+(1/8)*(30-6*5^(1/2))^(1/2)))+2*Pi*_Z9, arctan((1/6)*3^(1/2)*(2*(1/4+(1/4)*5^(1/2)-(1/4)*(30-6*5^(1/2))^(1/2))^3+1/4-(7/4)*5^(1/2)+(7/4)*(30-6*5^(1/2))^(1/2))/(1/8+(1/8)*5^(1/2)-(1/8)*(30-6*5^(1/2))^(1/2)))+Pi+2*Pi*_Z9, arctan((1/6)*3^(1/2)*(2*(1/4-(1/4)*5^(1/2)+(1/4)*(30+6*5^(1/2))^(1/2))^3+1/4+(7/4)*5^(1/2)-(7/4)*(30+6*5^(1/2))^(1/2))/(1/8-(1/8)*5^(1/2)+(1/8)*(30+6*5^(1/2))^(1/2)))+2*Pi*_Z9, arctan((1/6)*3^(1/2)*(2*(1/4-(1/4)*5^(1/2)-(1/4)*(30+6*5^(1/2))^(1/2))^3+1/4+(7/4)*5^(1/2)+(7/4)*(30+6*5^(1/2))^(1/2))/(1/8-(1/8)*5^(1/2)-(1/8)*(30+6*5^(1/2))^(1/2)))+Pi+2*Pi*_Z9
​​​​​​​Download Question_for_maple_primes.mw
how can I find e^(-x) with respect to x in this relation
e^x (1 + sqrt(1 + e^(-2 x))) - sinh^(-1)(e^(-x))=x
This worksheet attempts to implement figures in Section 3 of the book "Indra's pearls" by Mumford, Series and Wright using the  command complexplot.
The worksheet seems to display Figure 3.1 on page 63 accurately but fails to correctly display Figure 3.4 on page 67.
Can complexplot be coded to accurately display this figure?
Indras_pearls_spirals.mw
I need to compute all roots of a polynomial equation for geometric reasons. I do want accuracy but more important is speedy calculations. I know fsolve works pretty well, but I process the polynomials on my own first. Does the roots command work better? What about solvetools. Any and all thoughts welcome.
Note I need to compute all roots.
While solving an exercise in class, I ran into the following interesting solution of a transcendental equation.  It was not intentionally designed to be like this.
eq := 2*exp(-2*t) + 4*t = 127:
fsolve(eq, t=0..infinity);
                         31.75000000
The solution looks like a rational number while it was expected to be transcendental.  Let's increase the number of digits:
Digits := 20:
Digits := 10:
                     31.750000000000000000
Let's make it even more accurate:
Digits := 29:
Digits := 10:
                 31.750000000000000000000000000
And even more:
Digits := 40:
Digits := 10:
           31.74999999999999999999999999986778814353
Is there a deep reason why the solution is so close to being a rational or is it just a coincidence?
I want to estimate numerically the value of P (that is the probability that f exceeds the value 12 when x, y and z are uniformly distributed within the box [-Pi, Pi]3).
f := sin(x)+7*sin(y)^2+0.1*z^4*sin(x);
Omega := [x, y, z] =~ [(-Pi..Pi)$3]:
                                2        4
               sin(x) + 7 sin(y)  + 0.1 z  sin(x)
h := Heaviside(f-12):
P := Int(h, Omega);
Here is a simple Monte Carlo estimation of P.
f_MC  := x -> sin(x[1])+7*sin(x[2])^2+0.1*x[3]^4*sin(x[1]);
h_MC  := x -> Heaviside(f_MC(x) - 12);
omega := -Pi, Pi;
P_MC := proc(N)
  local Z := Statistics:-Sample(Uniform(omega), [N, 3]):
  local F := Vector(N, n -> h_MC(Z[n])):
  local K := add(F):
  local P := evalf(add(F)/N):
  local q := Statistics:-Quantile(Normal(0, 1), 0.005, numeric):
  local e := -q*sqrt(P*(1-P)/N):
  printf("A bilateral 99%% confidence interval that Prob(f > 12) is %1.3e +/- %1.2e\n", P, e);
P_MC(10^6)
A bilateral 99% confidence interval that Prob(f > 12) is 1.643e-02 +/- 3.27e-04
I was hoping to get a value for P using  evalf/Int with some method.
But I didn't succeed with any of the methods for multiple integration:
  • The following command returns 0 for n=1 and 2 and Int(h, Omega) if n >=3
    evalf( Int(h, Omega, 'epsilon=1e-n', 'method=_MonteCarlo') );
  • And all my attempts with methods from the Cuba library have resulted in an unevaluated Int(h, Omega) integral.
Could you help me to estimate P using  evalf/Int ?
TIA
Can anyone tell me what's going wrong with int(Heaviside(f-1/2), x=0..1, y=0..1); ?
f := x*y:
JH := int(Heaviside(f-1/2), x=0..1, y=0..1);  #???
 JP := int(piecewise(x*y>1/2, 1, 0), x=0..1, y=0..1);
                          1   1
                          - - - ln(2)
                          2   2
# integrate "1" over the domain where f > 1/2
S := solve(f=1/2, x):
JS := int(1, x=S..1, y=1/2..1);
                          1   1
                          - - - ln(2)
                          2   2
При использовании «объединения» нумерация не сохраняется. Непонятно, по каким алгоритмам «объединение» применяется к тому или иному месту. Почему sistema [1] не равно GRAN [1]? Как я могу это исправить?
PS Прошу прощения за грамматические ошибки, английский плохо знаю
1. mws
рестарт;
B:=matrix([[1,        0,        1,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0],
[-1,        -1,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0],
[0,        0,        -1,        0,        -1,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0],
[0,        1,        0,        1,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0],
[0,        0,        0,        0,        1,        1,        0,        1,        0,        0,        0,        0,        0,        0,        0,        0],
[0,        0,        0,        -1,        0,        -1,        -1,        0,        0,        0,        0,        0,        0,        0,        0,        0],
[0,        0,        0,        0,        0,        0,        1,        0,        1,        0,        0,        0,        0,        0,        0,        0],
[0,        0,        0,        0,        0,        0,        0,        -1,        0,        -1,        0,        0,        0,        0,        0,        0],
[0,        0,        0,        0,        0,        0,        0,        0,        -1,        0,        -1,        -1,        0,        0,        0,        0],
[0,        0,        0,        0,        0,        0,        0,        0,        0,        1,        1,        0,        1,        0,        0,        0],
[0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        1,        0,        1,        0,        0],
[0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        -1,        0,        -1,        0],
[0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        -1,        0,        -1],
[0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        0,        1,        1]
E:=16:V:=14;
V: = 14
G:=2*E; êîëè÷åñòâî ãðàíè÷íûõ óñëîâèé
G: = 32
l:=[1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1]:
for i to E do
De[i]:=-diff(phi[i](s[i]),s[i]$2)=He*phi[i](s[i]):  Äó âèäà -(diff(phi[i](s[i]), `$`(s[i], 2))) = H[e]*phi[i](s[i])
for i to E do
FSR[i]:=subs(s[i]=x,dsolve(De[i],phi[i](s[i]),output=basis)):  Îáùèå ðåøåíèÿ
for i to E do
OBCHEE_RECHIE[i]:=unapply(C[i+i-1]*FSR[i][2]+C[i+i]*FSR[i][1],x): od:
for i to E do
PROIZ:=diff(OBCHEE_RECHIE[i](x),x):
PROIZ_OB_RECH[i]:=unapply(PROIZ,x):od:
×òåíèå ìàòðèöû èíöèäåíòíîñòè
i0:=1:i1:=1:z:=1:y:=1:
for i from 1 to V do
 y:=1: z:=1:
  for j from 1 to E do
   if B[i,j]=1 then
    x[z]:=j: z:=z+1:
   fi:
   if B[i,j]=-1 then
    x[y]:=j:
    y:=y+1:
   fi:
  od;
  if z>=2 then
   v0[i0]:=[seq(x[s],s=1..z-1)]:
   i0:=i0+1:
  fi:
  if y>=2 then
   v1[i1]:=[seq(x[s],s=1..y-1)]:
   i1:=i1+1:
  fi:
v0:=convert(v0,list):
v1:=convert(v1,list):
Ïîäñ÷åò êîëè÷åñòâà ãðàíè÷íûõ óñëîâèé òèïà f(0)
number0:=0:
for i to i0-1 do
if nops(v0[i])=2 then number0:=number0+2; fi:
if nops(v0[i])=3 then number0:=number0+4; fi:
number0:=number0/2; #êîëè÷åñòâî ãðàíè÷íûõ óñëîâèé òèïà f(0)
number0 := 9
Ïîäñ÷åò êîëè÷åñòâà ãðàíè÷íûõ óñëîâèé òèïà f(1)
number1:=0:
for i to i1-1 do
if nops(v1[i])=2 then number1:=number1+2; fi:
if nops(v1[i])=3 then number1:=number1+4; fi:
number1:=number1/2; #êîëè÷åñòâî ãðàíè÷íûõ óñëîâèé òèïà f(1)
number1 := 9
Êîëè÷åñòâî ãðàíè÷íûõ óñëîâèé ñ ïðîèçâîäíûìè
GP:=i0-1+i1-1;
GP := 14
ÍÓËÅÂÛÅ ÓÑËÎÂÈß
i:=1:
while i<number0+1 do
for j to i0-1 do
if nops(v0[j])=2 then
GRAN[i]:=OBCHEE_RECHIE[v0[j,1]](0)-OBCHEE_RECHIE[v0[j,2]](0)=0;
i:=i+1;
fi;
if nops(v0[j])=3 then
GRAN[i+1]:=OBCHEE_RECHIE[v0[j,2]](0)-OBCHEE_RECHIE[v0[j,3]](0)=0;
i:=i+2;
fi;
od; od;
ÅÄÈÍÈ×ÍÛÅ ÓÑËÎÂÈß (ÈËÈ îò l)
i:=number0+1:
while i<number0+number1+1 do
for j to i1-1 do
if nops(v1[j])=2 then
GRAN[i]:=OBCHEE_RECHIE[v1[j,1]](l[v1[j,1]])-OBCHEE_RECHIE[v1[j,2]](l[v1[j,2]])=0;
i:=i+1;
fi;
if nops(v1[j])=3 then
GRAN[i+1]:=OBCHEE_RECHIE[v1[j,2]](l[v1[j,2]])-OBCHEE_RECHIE[v1[j,3]](l[v1[j,3]])=0;
i:=i+2;
fi;
od; od;
ÍÓËÅÂÛÅ ÏÐÎÈÇÂÎÄÍÛÅ
i:=number0+number1+1:
while i<number0+number1+nops(v0) do
 for j to nops(v0) do
  for y from 1 to nops(v0[j]) do
   x[y]:=PROIZ_OB_RECH[v0[j,y]](0);
  od;
  m:='m';
  GRAN[i]:=sum(x[m],m=1..nops(v0[j]));
  i:=i+1;
 od;
od;
ÍÅÍÓËÅÂÛÅ ÏÐÎÈÇÂÎÄÍÛÅ
i: = число0 + число1 + nops (v0) +1:
в то время как i <G + 1 сделать
 для j до nops (v1) сделать
  для y от 1 до nops (v1 [j]) сделать
   x [y]: = PROIZ_OB_RECH [v1 [j, y]] (l [v1 [j, y]]);
  od;
  m: = 'm';
  ГРАН [i]: = сумма (x [m], m = 1..nops (v1 [j]));
  я: = я + 1;
 od;
od;
новогодний
sistema: = {}:
новенькие
время: = {}:
для я от 2 до G делаю
  sistema: = sistema union {GRAN [i]}:
  peremenie: = peremenie union {C [i]}:
коэфф: = решить (система, изменение):
коэфф:
система [1];
C[2]*He^(1/2)+C[6]*He^(1/2)
ГРАН [1];
C[1]-C[5] = 0
urav: = subs (koeff, GRAN [1]):
uravnenie: = collect (numer (lhs (normal (urav))), {He, C [1]}):
uravn: = remove (has,%, C [1]):
uravnenie_sobs_chisla: = evalf (algsubs (He = x, uravn)):
ВЕСЕЛЫЕ: = неприменить (uravnenie_sobs_chisla, x):
Скачать 1.mws
Initially I have a system of w(x,y,t) and f(x,y,t). I have a set of two partial differential equations with this system. Later on, the system is modified into w(x,y,t,z) andf(x,y,t,z) where x and z are related due to the presence of boundary layers. Because of this, the partial differential expressions with respect to x has to change.
For example, initially: diff(w(x,y,t),x)=diff(w(x,y,t),x)
Later on, when the system gets modified in the presence of boundary layers on application of chain rule: diff(w(x,y,t,z),x)=diff(w(x,y,t,z),x)+diff(w(x,y,t,z),z)*diff(z,x)
This change has to happen for all higher order derivatives of x. In my case, I have upto 4th order derivative in x. How do I achieve these changes in the expressions in Maple in an elegant manner?
Good day everyone. I need to calculate series of the function given above. But I can not find result. It writes "Error, (in series/function) improper op or subscript selector". How can I fix this error? Please help me.
The detailed file has been attached above.
Ek4:=sqrt((Ea^2*Eb^2-Eab^2*X5^2)*Ds);
((((1/2)*k((1/2)*k^2/m2+X2)^2/m1((1/2)*k^2/m2+X2)+X1((1/2)*k^2/m2+X2))*((1/2)*k((1/2)*k^2/m2+X1)^2/m2((1/2)*k^2/m2+X1)+X2((1/2)*k^2/m2+X1))-((1/2)*k((1/2)*k^2/m2+X1)^2/m1((1/2)*k^2/m2+X1)+X2((1/2)*k^2/m2+X1))*X5^2)*(((1/2)*k((1/2)*k^2/m2+X2)^2/m1((1/2)*k^2/m2+X2)+X1((1/2)*k^2/m2+X2)-(1/2)*k((1/2)*k^2/m2+X1)^2/m2((1/2)*k^2/m2+X1)-X2((1/2)*k^2/m2+X1))^2+4*((1/2)*k((1/2)*k^2/m2+X1)^2/m1((1/2)*k^2/m2+X1)+X2((1/2)*k^2/m2+X1))^(1/2)*X5^2))^(1/2)
series(Ek4,k=0,4);
series(sqrt(Ek4),k=0,4);
Download function.mwfunction.mw
I want to create a random polynomial using randpoly() with coefficients in a given list A := [1,1,2,5,6].
For that, I need to create a function that works as rand(1..9) but that when called returns a random element of A instead of a random number between 1 and 9.
What I have tried so far is
r := rand(1..numelems(A))
A[r()]
However, that returns a random element of A, not a function that returns a random element of A.
I've also tried
rand(A(1..numelems(A)))
But that gives an error.
One way of solving this problem would be to find out how to create a `..` type with the desired elements, something that works as 1..9 but with the elements of A. But convert(A,`..`) doesn't work and the rest of the things I tried don't work either.
 I can’t use my "Filled" command to simultaneously explore my 3 graphs
Thanks for ideas
PétalesGraphes.mw
Hi, I am new to MAPLE and trying to solve the given BVP using shooting method but after defining the expression in u0 and u1, the code didn't compute the numerical value, and so that the whole code won't run exactly.
Please help me out to figure out the problem. I am looking for the answer. (NOTE: I copied this code from the web and it run so fine with the example but when I changed it according to me, it give me errors.)
The code is given below:
with(DEtools);
dpdexi := 2;
K := 0.2;
epsilon := 0.0001;
                       epsilon := 0.0001
ode1 := (diff(phi(eta), eta) + epsilon*K*diff(phi(eta), eta)^3)/(1 + epsilon*diff(phi(eta), eta)^2) = dpdexi*eta;
bc1 := phi(0) = 0, phi(1) = 0;
a := 0;
b := 1;
ic1 := bc1[1], D(phi)(a) = alpha;
constraint := lhs(bc1[2]) - rhs(bc1[2]);
constraint = 0;
a0 := 0;
u0 := eval(constraint, phi(b) = PHIb(eval({ic1, ode1}, alpha = a0), phi(eta), b));
a1 := 0.01;
u1 := eval(constraint, phi(b) = PHIb(eval({ic1, ode1}, alpha = a1), phi(eta), b));
while fnormal(u1 - u0) <> 0 do
    z := solve(u1 = (u1 - u0)*(a1 - x)/(a1 - a0), x);
    a0, a1 := a1, z;
    u0, u1 := u1, eval(constraint, u(b) = Ub(eval({ic1, ode1}, alpha = z), u(x), b));
alpha_opt1 := z;
shoot_sol1 := evalf(dsolve(eval({ic1, ode1}, alpha = alpha_opt1), u(x), implicit));
infolevel[dsolve] := 3;
exact_sol1 := combine(dsolve({bc1, ode1}, u(x)));
infolevel[dsolve] := 0;
plot([rhs(exact_sol1), rhs(shoot_sol1)], x = 0 .. 1, color = [BLACK, RED], thickness = [5, 2], legend = ['exact', 'shooting'], title = "Figure 17.3");
evalf(eval(rhs(shoot_sol1), x = 1));
First 380 381 382 383 384 385 386 Last Page 382 of 2432
