Sketch the 3d graph of solid bounded inside a sphere of x²+y²+z²=4z and below a cone z=√(x²+y²) on xy-plane.
Any one has smart way to help verify this Maple solution to this ODE? I can't figure it out
ode:=diff(y(x),x)-y(x) = x*y(x)^(1/2):
ic:= y(0)=4:
maple_sol:=dsolve([ode,ic],'implicit'):
the_diff_1:=odetest( (lhs-rhs)(maple_sol)=0,[ode,ic]);
maple_sol:=dsolve([ode,ic],'explicit'):
the_diff_2:=odetest( (lhs-rhs)(maple_sol)=0,[ode,ic]);
Tried few simplifications but not everything. I am assuming Maple solution is correct.
Maple 2021.1
Hello there,
While I was trying to calculate the complex (i.e., P and Q) power equations, I got this question.
Thus, I wonder if I can have a chance to ask the question here:
a. When the voltage and current are defined as functions, taking the t (time) as a input variable, I was not able to get the proper outcome from the operation. Those attempts are labeled as '#1' and '#2' in the attached worksheet.
b. When the voltage and current are defined as simple complex expression, I was able to see what I wanted. The expression is named as 'ideal' in the attached worksheet.
c. Therefore, my question is to see if there is a way to make the operaion using the functions in the same way as done by the simple expressions.
d. Any insight would be appreciated.
Q20210617.mw
Dear Fellows, greetings
I am solving a system of equations under some assumptions and those assupmtions are a must to impose. However maple fails to apply those while solving the equations. For example solution 4 gives b=c as a solution but in assumtion it is clrealy mentioned that b<>c. Kindly guide me what mistake am I making in the code.
System_problem.mw
Background
This 'quirk' of Maple behaviour cropped up when I was considering solutions for the question posted here
https://www.mapleprimes.com/questions/232433-Extract-From-Record
where the OP had "poorly structured" data which meant it was a bit "awkward" to access required fields. A number of more-or-less satisfactory solution were proposed, and the OP seems happy
The Issue
One possible way to solve the original problem would be to restructure the data as a DataFrame. The "natural" way to do this would be to use numeric row indexes.. Note that these row indexes are not contiguous, and are in no particular order. However using this approach means that accessing fields from the dataframe is not consistent.
Sometimes the supplied row label is interpreted as a 'label', sometimes it is interpreted as the "row number". It appears that the latter interpretation is preferentially used
I can't make up my mind whether to call this a "bug" or not, but I can see the inconsistent interpretation resulting in chaos.
Before submitting an SCR I'd like to know if anyone else sees this as a bug
Consider the code
  prettyprint=1:
# data
  S := [`206` = Record(mu = 508.001018040,  sigma = 125.002863204708),
          `4` = Record(mu = 1008.001018040, sigma = 167.707232430134),
          `2` = Record(mu = 1208.001018040, sigma = 141.512246146314),
          `5` = Record(mu = 808.001018040,  sigma = 117.156800098735)
# Construct the above as a dataframe - note row labels are numbers!
  DF:= DataFrame( Matrix([seq( [rhs(j):-mu, rhs(j):-sigma], j in S)]),
                  rows= [seq( parse( lhs(j) ), j in S)],
                  columns=[mu, sigma]
  DF[206, mu];
  DF[2, mu];  ## Errr No!
  DF[5, sigma];
               [           mu             sigma      ]
               [206  508.001018040   125.002863204708]
         DF := [ 4   1008.001018040  167.707232430134]
               [ 2   1208.001018040  141.512246146314]
               [ 5   808.001018040   117.156800098735]
                         508.001018040
                         1008.001018040
                        117.156800098735
Note that DF[2, mu] outputs the entry from the second row - not the one from the row labelled with the number 2
I imagina a similar issue would occur with numeric column indexes, although I haven't tried this
I have a list of records :
S := [`206` = Record(mu = 508.001018040, sigma = 125.002863204708), `4` = Record(mu = 1008.001018040, sigma = 167.707232430134), `2` = Record(mu = 1208.001018040, sigma = 141.512246146314), `5` = Record(mu = 808.001018040, sigma = 117.156800098735)]
How can I extract from S the mu and sd corresponding to a number.
eg input 2 get 1208.001018040,141.512246146314
like this:  rhs(S[3]):-mu, rhs(S[3]):-sigma, (I know from inpection 2 occurs in the 3rd slot but assume i don't know where it occurs). I tried using Search...
Suppose we have an unknown parametric function like g(x). We do not know the exact form but we know that g(x) is increasing and concave. Also, we define h(x) = g(x)*f(x) where we know the exact form of f(x) like f(x)=2x+5. Here, I want to investigate if the function h(x) is concave or not. How is it possible to do this?
In this worksheet the solve command almost immediately gives up and DirectSearch[SolveEquations] is erratic.
For some triangle/inellipse points of tangency the latter provides a nonsense answer and for others it produces an almost correct solution.
Is there a set of conditions which determine the possibility of an inellipse within a triangle?
Inellipse.mw
A responder will have to establish a connection to the DirectSearch package.
Here is my first attempt to work with Embedded Components.
I loaded the "Bezier curve" example ("how to drag points") and the "Linear Regression" one ("how to add points") from the MathApps, merge the codes and modified them in order to draw a polygon with an arbitrary number of sides.
After many unsuccessful attempts I begin to understand the mogic behind Embedded Components (I'm familiar with Maplets and I'm sure this didn't help me).
For now , I am able to define points, drag them, and erase everything. A small step for Mankind but a huge step for me.
What I would like to do now is to erase some points.
The basic code is
# Plot1 is the PlotComponent
# The list of the points is pt
# x0 and y0 are the co-ordinates of the point to remove from pt
# _removing is the number of the point in pt closest to (x0, y0)
# Update is the procedure which does the plot in Plot1
Remove := proc()
     x0 := DO(%Plot1( "clickx" ) );
     y0 := DO(%Plot1( "clicky" ) );
     d := map(n -> add((pt[n]-~[x0, y0])^~2), [$1..nops(pt)]):
     _removing := sort(d, output=permutation)[1];
     subsop(_removing=NULL, pt);
     Update();
Unfortunately I don't understand well enough the logic of  Embedded Components to make this work
Can you help me fix this?
TIA
sketch.mw
PS: In procedure Update I define two plots named fond (=background) and grille (=grid): grille is a workaround to "toggle gridlines" or 'gridlines'=true for none of these options work for me (Maple 2015.2, Mac OSX Mojave)
I have have been trying to creat a slider and use the value as a "variable" to vary the sin function..
I tried many things and can't seem to get iit to work...any suggestions woul be appreciated..I am still brand new to Maple
I have searched Application center..and spend hours trying to get this right...I am attacing my worksheet
Thanks for your help!
Frank
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/CreatingSlider.mw .
Download CreatingSlider.mw
Just in case the worksheet won't work I am attaching a jpeg
To my knowledge, I think it should return 'true'. But in this case and many other similar cases, it returns 'false'. Sometimes after rebooting my laptop it gives 'true'. This made me crazy. Please help!
X
Y
z
19.8
12
1.62
24.7
14
1.2
26
16
1.25
35.1
20
0.84
37.8
20.83
0.74
10.8
9
3.98
16.1
12
2.46
38.3
18
0.52
24.5
16
1.42
15.8
11
2.35
28.2
17.8
1.19
56.8
27
0.37
25.4
17
1.34
29.3
18.1
1.12
How to plot the (x,y,z) points on 3d plot like first point is (19.8,12,1.62) like that in order
and connect all the ponts above as a line
Kind help your help will be acknowleged
IN FIBONACCI RABBIT PROBLEM, SUPPOSE ONLY 3/4 (PROPORTION) OF FEMALES BECOME PREGNANT THEN HOW TO DETERMINE THE ANNUAL RATE OF INCREASE IN RABBITS?
First 401 402 403 404 405 406 407 Last Page 403 of 2432
