Wrote some Maple code, and want to share.
I put less than eight hours into this exploration.
I have been running a computer to find Fermat factors for over ten years now.  Want support.
This is an exploration in some mostly composite whole numbers.
see 2_to_the_exponent_p_3.pdf
also see
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/2_to_the_exponent_p_3.mw .
Download 2_to_the_exponent_p_3.mw
Have a look.
Matt
ff := dsolve({eq1, Vt(0)=0}, Vt(t), type=numeric, method=classical, start=0, stepsize=.00001);
this is a old syntax of maple 5, with maple 2017 version it is not working, is it possible to solve non linear equatins with maple
When I click on the "install" option for the update to the Physics Package, get the following error message:
Fetching package "Physics Updates" from MapleCloud...
Version: 988
URL: https://maple.cloud
An error occurred, the package was not installed:
Unable to log into Maplesoft account: Forbidden (403)
The 3-D Workspace of the stuart platfrom example
https://de.maplesoft.com/products/maplesim/modelgallery/detail.aspx?id=34
displays as follows. Clicking on the central object I get
Q1: What does "Unlayed out view mean"?
Q2: What is actually displayed in the center?
Q3: Why is only one leg shown in instead of 6?
I would really appreciate more insight into the 3-D Workspace. I use it to inspect structural integrity of models and assembly errors, but I am often lost by its behavior.
(I have tried to work it out myself with online resources, Maples help system and MapleSim user guide.)
In Maple 2021.1
int(cos(3*x)/(-(-1+8*cos(x)^2)^(1/2)+(3*cos(x)^2-sin(x)^2)^(1/2)),x)
gives
Error, (in SumTools:-DefiniteSum:-ClosedForm) numeric exception: division by zero
But in Maple 2020.2 it works OK giving an answer. (A very long one)
btw, the answer should be
3/4*arcsin(2/3*sin(x)*3^(1/2))-3/4*arctan(sin(x)/(-1+4*cos(x)^2)^(1/2))-3/4*arctan(sin(x)/(-1+8*cos(x)^2)^(1/2
))+5/8*arcsin(2/7*sin(x)*14^(1/2))*2^(1/2)-1/2*sin(x)*(-1+4*cos(x)^2)^(1/2)-1/2*sin(x)*(-1+8*cos(x)^2)^(1/2)
Is this a known issue? I know Maple int has went some changes and improvements in Maple 2021 from the release notes. May be this was caused by some of these changes?
https://www.maplesoft.com/products/maple/new_features/
  • Integration has been enhanced with improved algorithms for indefinite integration, and the ability to easily specify which integration method should be used and to compare the results from different methods."
Maple 2021.1 on windows 10
update July 2, 2021
These are additional failed integration in 2021.1 that throw exceptions now. no errors in 2020.2
#427
#533 #no error in Maple 2020, it does not evaluate there. But no error
int((-3+exp(7*x))^(2/3)/exp(2*x),x)
#26/11 #no error in Maple 2020, it does not evaluate there. But no error
int((b*x+(b^2*x^2+a)^(1/2))^(1/2)/(b^2*x^2+a)^(1/2),x)
Do some of you know the form of all primes greater than five?
Is it 6*p +/- 1?
maple_about_primes.pdf
et/convert/                                  Maple_prime_expository_number_one_for_sharing.mw .
Download Maple_prime_expository_number_one_for_sharing.mwmaple_about_primes.pdf
Matt
We consider a triangle ABC, its circumscribed circle (O), of radius R, its inscribed circle (I) of centre I. We designate by α, β, γ the points of contact of BC, CA, AB with the circle (I), by A', B', C' the points of meeting other than A, B, C, of AI, BI, CI with the circle (O), by the media of BC, CA, AB.
.Establish that there is a conic (E), focus I, tangent to βγ, γα, αβ.
My code :
with(geometry);
with(plots); _local(gamma);
_EnvHorizontalName := x; _EnvVerticalName := y;
alias(coor = coordinates);
point(A, -5, -5); point(B, 7, -1); point(C, 1, 5);
triangle(ABC, [A, B, C]); circumcircle(_O, ABC, 'centername' = OO); incircle(_I, ABC, 'centername' = Io);
line(lBC, [B, C]); sol := solve({Equation(_I), Equation(lBC)}, {x, y}); point(alpha, subs(sol, x), subs(sol, y));
line(lCA, [C, A]); sol := solve({Equation(_I), Equation(lCA)}, {x, y}); point(beta, subs(sol, x), subs(sol, y));
line(lAB, [A, B]); sol := solve({Equation(_I), Equation(lAB)}, {x, y}); point(gamma, subs(sol, x), subs(sol, y));
line(lAO, [A, OO]); intersection(Ap, lAO, lBC);
line(lBO, [B, OO]); intersection(Bp, lBO, lCA);
line(lCO, [C, OO]); intersection(Cp, lCO, lAB);
midpoint(l, B, C); midpoint(m, A, C); midpoint(n, A, B);
triangle(T, [alpha, beta, gamma]);
dr := draw([ABC(color = blue), _O(color = red), _I(color = magenta), lAO(color = black), lBO(color = black), lCO(color = black), T(color = red), alpha, beta, gamma, Ap, Bp, Cp, l, m, n], printtext = true);
display([dr], axes = normal, scaling = constrained, size = [800, 800]);
How to find the Equation of (E); Thank you.
The command
plots[textplot]({[4.2,1.9,typeset(sin(30°))]},
symbol=point,color=black,font=["Arial","Bold",25]);
will output
Can we have the number 30 in a non-italic format?
mapleatha
Why is the minus sign so weak even in the bold font case? My students sometimes miss it in online tests.
How do we make the minus sign bolder?
mapleatha
First question
Let P1 the logical proposition
with(Logic):
local O
P1 := (&not O) &and (&not C) &implies (&not Q);
Is it possible to obtain its contraposition P2  in a form that contains &implies?
# P2 := (Q) &implies &not ((&not O) &and (&not C));
Second question
Why does the modulo 2 canonical form of proposition P5 above contains "1" "plus" other terms:
(if 1 is present this means 1 + something = 1 and then that P5 is a tautology, which is obviously wrong as Tautology(P5) shows)
with(Logic):
local O
P1 := (&not O) &and (&not C) &implies (&not Q);-
P3 := op(1, P2) &and (&not C);
P4 := op(2, P2) &and (&not C);
P5 := P3 &implies P4:
Canonicalize(P5, {O, C, Q}, form=MOD2)
                   C O Q + C Q + O Q + Q + 1
Verificaion of what the modulo 2 canonical form of a proposition including an "addititive" tautology is
T := O &or (&not O):
Canonicalize(T, {O}, form=MOD2);
Canonicalize(T &or S, {O, S}, form=MOD2);
Is it that I missed something or is iot a bug?
Watchout: this result has been obtained with Maple 2015.2
TIA
Is there any command for defining piecewise functions in 2 dimensional domain (x, y)
Say (x,y) such that ((0,0)<(x,y)<(1,1), x+y, (1,1)<(x,y)<(2,1), x-y), x=0..2, y=0..1)
Thanks for help.
Ramakrishnan
I started using maple around 1995 on the Inverse Symbolic Calculator to discover the MRB constant and got put on this list.
Do you consider yourself to be one?
From Wikipedia, the free encyclopedia
Jump to navigationJump to search
This is a list of amateur mathematicians—people whose primary vocation did not involve mathematics (or any similar discipline) yet made notable, and sometimes important, contributions to the field of mathematics.
Hi, I want to animate the motion of an electrond around a negative-source electric field. The trajectory would be iperbolic, however I've encountered one problem: I have to compose the movemente with 4 different animate pointplot3d, and they all start at a certain point at the same time and end in another at the same time. Can I make it so that they all start when another one has finished and only the moving one is shown?
display(
animate(pointplot3d, [[A, sqrt(A^2 - 1), 0], symbol = solidsphere, symbolsize = 15, color = "Blue"], A = 1 .. 3),
pointplot3d([0, 0, 0], symbol = solidsphere, color = "Blue", symbolsize = 15),
animate(pointplot3d, [[-A, -sqrt(-1 + (-A)^2), 0], symbol = solidsphere, symbolsize = 15, color = "Blue"], A = -3 .. -1),
animate(pointplot3d, [[A, 3*sqrt(2)/4*A - sqrt(2)/4, 0], symbol = solidsphere, symbolsize = 15, color = "Blue"], A = 3 .. 6),
animate(pointplot3d, [[-A, 3*sqrt(2)/4*A - sqrt(2)/4, 0], symbol = solidsphere, symbolsize = 15, color = "Blue"], A = -6 .. -3),
implicitplot3d(x^2 + y^2 + z^2 = 17, x = -6 .. 6, y = -10 .. 10, z = -10 .. 10, color = "Green", style = wireframe),
scaling = constrained)
This is the code I've come up with, the blue still point is the elctron which powers the field, the moving blue point (there are 4 of them but all represent the same thing) is the moving electron and the green ball is a representation of the electric field.
Edit: I'll use the code for interactive components.
Thanks in advance to everyone!
I have a list of 1's and 2's. Something like [1,1,1,2,2,2]. I want to remove 1 or 2 from the list (only once), without needing to mention at which place. The remove command removes all of the occurrences, I need something similar which remove the given element only once.
>L:[1,1,1,2]
>remove(has, L, 1)
[2]
I want the output to be [1,1,2]
Does Maple support nested modules, to better organize library code?
First 405 406 407 408 409 410 411 Last Page 407 of 2432
