I am trying to calculate the Dirichlet integral with the residue theorem and the LineInt command. I use the classic lace (Cf below) and the function exp(iz)/z. I don't understand why the LineInt function returns zero on the top semicircle. The result should depend on r and only be zero for limit(%, R = infinity).
Thanks for your help.
hi I want to color points like phase portraits of complex functions, so I did something like this:
with(Statistics);
with(LinearAlgebra);
data := Matrix(<Sample(Uniform(-2, 2), [10, 2]) | RandomVector(10, generator = rand(0 .. 3))>);
pointplot(data[() .. (), 1], data[() .. (), 2], symbolsize = 20, symbol = solidbox, colorscheme = ["valuesplit", data[() .. (), 3], [0 = "Red", 1 = "Blue", 2 = "Green", 3 = "Purple"]]);
f := (x, y) -> x^2 - y^2 + 2*I*x*y;
LR := <seq(Re(f(data[1 .. 10, 1 .. 2][i, 1], data[1 .. 10, 1 .. 2][i, 2])), i = 1 .. 10)>;
LI := <seq(Im(f(data[1 .. 10, 1 .. 2][i, 1], data[1 .. 10, 1 .. 2][i, 2])), i = 1 .. 10)>;
pointplot(LR(), LI(), symbolsize = 20, symbol = solidbox, colorscheme = ["valuesplit", data[() .. (), 3], [0 = "Red", 1 = "Blue", 2 = "Green", 3 = "Purple"]]);
there should color points like this in the input (domain coloring of the f(z)=z^2 ):
and output space:
for example these two stripes of pink points on the input space tell us that all those points get mapped
somewhere to the pink direction, the lower right of the output space, thanks in advance
I spent some hours to manipulate the Nabla operator as in textbook, but i have an issue.
Thank you for your help
First thing i did is :
with(Physics); with(Vectors);
I declare S0 and P0 as constant with
Parameters(S0,P0)
I have the expression
Exp := S0*(P(x, y, z, t) * - P0)
I apply the Nabla Operator and get
(%Nabla) S(x, y, z, t)) = S0*Nabla, P(x, y, z, t) * - S0*NablaP0
As S0 and P0 are constants, How to remove the S0*NablaP0 term  ?
I tried some combinations of expand and simplify.
Howdy,
I am trying to understand various approaches to threading in Maple. I can naturally parallelize some computations, but only if I can figure out threading. The punchline is this - running something on a single core takes significantly longer when I break it into threads.
I picked a command that takes some time - suppose I have a Lie algebra G, and I want to know if H is a subalgebra. If I do this 16 times in a row, it takes about 3 seconds consistently. Here I made an array of 16 copies of H. Then I can simply ask which element is a subalgebra:
is_subalgebra:=proc(list_of_algs)
local i;
for i in list_of algs do
Query(i, "Subalgebra");
Then running the following gives me an answer of about 3:
st := time();
is_subalgebra(my_list);
time() - st;
Suppose I want to run this on cores = 4 or 5 or...
are_subalgebras_t := proc(list, cores)
local ...., mutex, threadlist;
threadlist:= [];
mutex := Threads[Mutex][Create]();
<create cores chunks of list, call it sublist>
for i in sublist do
 Threads[Mutex][Lock](mutex);
 threadlist:= [op(ts), Create(are_subalgebra(i))];
 Threads[Mutex][Unlock](mutex);
Wait(op(threadlist));
return;
The unecessary code is removed, but I:
1: Create a mutex
2: Chunk up my list into as many pieces as I want
3: Lock my mutex
4: Spawn a thread on the current chunk, save the thread id in a list
5: Unlock the mutex (I just want to add thread ids to my list safely)
6: Repeat 3-5 for each chunk
7: Wait until all threads are done
My machine has 16 cores, and if I run this on say 8 cores it takes almost 10 seconds. I can see that it starts executing the threads immediately - an example run shows I might spawn two threads, then the first thread starts, the third spawns, and then they complete in some order. Predictably, every run through is different. This tells me that I am getting parallelization, but at the detriment of runtime.
Can anyone tell me where my approach is going wrong? I was unable to get any Map functions to work at all.
alpha := .985
.985
for i to 7 do for j from -1 by .1 to 1 do Exact[j] := ((1-j)*(1/2))*exp((1+j)*(1/2)); Y[0] := proc (x) options operator, arrow; -(1/8)*exp(1)+1/2+(-(1/8)*exp(1)-3/4)*x+(1/8)*exp(1)*x^2+((1/8)*exp(1)+1/4)*x^3 end proc; Ics := Z(-1) = 1, Z(1) = 0, (D(Z))(-1) = 0, (D(Z))(1) = -(1/2)*exp(1); exp(x) := convert(taylor(exp(x), x = 0, 25), polynom); f := proc (x) options operator, arrow; ((1/32)*x-5/32)*exp((1/2)*x+1/2) end proc; p := proc (x) options operator, arrow; 0 end proc; q := proc (x) options operator, arrow; -1/4 end proc; r := proc (x) options operator, arrow; 0 end proc; u := proc (x) options operator, arrow; -1/16 end proc; eq[i] := diff(Z(x), `$`(x, 4)) = (1-alpha)*(diff(Y[i-1](x), `$`(x, 4)))+alpha*(f(x)-p(x)*(diff(Y[i-1](x), `$`(x, 3)))-q(x)*(diff(Y[i-1](x), `$`(x, 2)))-r(x)*(diff(Y[i-1](x), x))-u(x)*Y[i-1](x)); s[i] := evalf(dsolve({Ics, eq[i]}, Z(x))); Y[i] := unapply(op(2, s[i]), x); App[j] := evalf(Y[i](j)); Er[j] := abs(App[j]-Exact[j]); print([App[j], Exact[j], Er[j]]) end do end do
[1.00000001, 1, 0.1e-7]
[.99889373, .9987075410, 0.1861890e-3]
[.99542387, .9946538260, 0.7700440e-3]
[.98930908, .9875591065, 0.17499735e-2]
[.98020108, .9771222065, 0.30788735e-2]
[.96769238, .9630190630, 0.46733170e-2]
[.95132386, .9449011655, 0.64226945e-2]
[.93059225, .9223939070, 0.81983430e-2]
[.90495743, .8950948190, 0.98626110e-2]
[.87384983, .8625717020, 0.112781280e-1]
[.83667770, .8243606355, 0.123170645e-1]
[.79283435, .7799638580, 0.128704920e-1]
[.74170543, .7288475200, 0.128579100e-1]
[.68267630, .6704392900, 0.122370100e-1]
[.61513924, .6041258120, 0.110134280e-1]
[.53850104, .5292500040, 0.92510360e-2]
[.45219044, .4451081856, 0.70822544e-2]
[.35566578, .3509470278, 0.47187522e-2]
[.24842284, .2459603111, 0.24625289e-2]
[.13000273, .1292854830, 0.7172470e-3]
[0., 0., 0.]
[.99870526, .9987075410, 0.22810e-5]
[.99464487, .9946538260, 0.89560e-5]
[.98753974, .9875591065, 0.193665e-4]
[.97708963, .9771222065, 0.325765e-4]
[.96297160, .9630190630, 0.474630e-4]
[.94483868, .9449011655, 0.624855e-4]
[.92231783, .9223939070, 0.760770e-4]
[.89500815, .8950948190, 0.866690e-4]
[.86247884, .8625717020, 0.928620e-4]
[.82426685, .8243606355, 0.937855e-4]
[.77987484, .7799638580, 0.890180e-4]
[.72876867, .7288475200, 0.788500e-4]
[.67037492, .6704392900, 0.643700e-4]
[.60407851, .6041258120, 0.473020e-4]
[.52922004, .5292500040, 0.299640e-4]
[.44509347, .4451081856, 0.147156e-4]
[.35094315, .3509470278, 0.38778e-5]
[.24596164, .2459603111, 0.13289e-5]
[.12928690, .1292854830, 0.14170e-5]
[-0.2e-7, 0., 0.2e-7]
[2., 1, 1.]
[2., .9987075410, 1.001292459]
[2., .9946538260, 1.005346174]
[2., .9875591065, 1.012440894]
[2., .9771222065, 1.022877794]
[2., .9630190630, 1.036980937]
[2., .9449011655, 1.055098834]
[2., .9223939070, 1.077606093]
[2., .8950948190, 1.104905181]
[2., .8625717020, 1.137428298]
[2., .8243606355, 1.175639364]
[2., .7799638580, 1.220036142]
[2., .7288475200, 1.271152480]
[2., .6704392900, 1.329560710]
[2., .6041258120, 1.395874188]
[2., .5292500040, 1.470749996]
[2., .4451081856, 1.554891814]
[2., .3509470278, 1.649052972]
[2., .2459603111, 1.754039689]
[2., .1292854830, 1.870714517]
[2., 0., 2.]
[1.00000000, 1, 0.]
[.99902820, .9987075410, 0.3206590e-3]
[.99581870, .9946538260, 0.11648740e-2]
[.98992527, .9875591065, 0.23661635e-2]
[.98089421, .9771222065, 0.37720035e-2]
[.96826375, .9630190630, 0.52446870e-2]
[.95156339, .9449011655, 0.66622245e-2]
[.93031319, .9223939070, 0.79192830e-2]
[.90402310, .8950948190, 0.89282810e-2]
[.87219221, .8625717020, 0.96205080e-2]
[.83430805, .8243606355, 0.99474145e-2]
[.78984585, .7799638580, 0.98819920e-2]
[.73826774, .7288475200, 0.94202200e-2]
[.67902206, .6704392900, 0.85827700e-2]
[.61154254, .6041258120, 0.74167280e-2]
[.53524746, .5292500040, 0.59974560e-2]
[.44953895, .4451081856, 0.44307644e-2]
[.35380210, .3509470278, 0.28550722e-2]
[.24740416, .2459603111, 0.14438489e-2]
[.12969376, .1292854830, 0.4082770e-3]
[0.1e-7, 0., 0.1e-7]
[1.00000002, 1, 0.2e-7]
[.99870689, .9987075410, 0.6510e-6]
[.99464990, .9946538260, 0.39260e-5]
[.98754844, .9875591065, 0.106665e-4]
[.97710162, .9771222065, 0.205865e-4]
[.96298633, .9630190630, 0.327330e-4]
[.94485556, .9449011655, 0.456055e-4]
[.92233620, .9223939070, 0.577070e-4]
[.89502732, .8950948190, 0.674990e-4]
[.86249795, .8625717020, 0.737520e-4]
[.82428488, .8243606355, 0.757555e-4]
[.77989071, .7799638580, 0.731480e-4]
[.72878132, .7288475200, 0.662000e-4]
[.67038351, .6704392900, 0.557800e-4]
[.60408269, .6041258120, 0.431220e-4]
[.52922015, .5292500040, 0.298540e-4]
[.44509054, .4451081856, 0.176456e-4]
[.35093889, .3509470278, 0.81378e-5]
[.24595805, .2459603111, 0.22611e-5]
[.12928542, .1292854830, 0.630e-7]
[-0.1e-7, 0., 0.1e-7]
[1.0000000, 1, 0.]
[.9987075, .9987075410, 0.410e-7]
[.9946539, .9946538260, 0.740e-7]
[.9875592, .9875591065, 0.935e-7]
[.9771225, .9771222065, 0.2935e-6]
[.9630194, .9630190630, 0.3370e-6]
[.9449015, .9449011655, 0.3345e-6]
[.9223945, .9223939070, 0.5930e-6]
[.8950954, .8950948190, 0.5810e-6]
[.8625722, .8625717020, 0.4980e-6]
[.8243613, .8243606355, 0.6645e-6]
[.7799644, .7799638580, 0.5420e-6]
[.7288483, .7288475200, 0.7800e-6]
[.6704399, .6704392900, 0.6100e-6]
[.6041262, .6041258120, 0.3880e-6]
[.5292503, .5292500040, 0.2960e-6]
[.4451084, .4451081856, 0.2144e-6]
[.3509472, .3509470278, 0.1722e-6]
[.2459606, .2459603111, 0.2889e-6]
[.1292855, .1292854830, 0.170e-7]
[0.1e-6, 0., 0.1e-6]
[2., 1, 1.]
[2., 0., 2.]
Download fourthLINEARBOUD042021.mw
alpha := .985
.985
[0., 0., 0.]
[2., 1, 1.]
[2., 0., 2.]
[1.00000000, 1, 0.]
[1.0000000, 1, 0.]
[2., 1, 1.]
[2., 0., 2.]
alpha := .985
.985
[0., 0., 0.]
[2., 1, 1.]
[2., 0., 2.]
[1.00000000, 1, 0.]
[1.0000000, 1, 0.]
[2., 1, 1.]
[2., 0., 2.]
alpha := .985
.985
[0., 0., 0.]
[2., 1, 1.]
[2., 0., 2.]
[1.00000000, 1, 0.]
[1.0000000, 1, 0.]
[2., 1, 1.]
[2., 0., 2.]
PLS FIND ATTACHED A MAPLE CODE TO SOLVE SOME BOUNDARY VALUE PROBLEM, BUT IT JUMP SOME ITERATION WITHOUT EVALUATION WHICH END UP WITH INACCURATE SOLUTION.
> restart;
> exp(1) := 2.7182818284590452354;
> alpha := .975;
> NULL;
> st := time[real]();
> for i to 4 do for j from 0 by .1 to 4-exp(1) do Exact[j] := evalf(ln(exp(1)+j)); Y[0] := proc (x) options operator, arrow; 1+x/exp(1)+(1/4)*((exp(1))^2-8*exp(1)+24*ln(2)*exp(1)-32)*x^2/(exp(1)*(16-8*exp(1)+(exp(1))^2))+(1/4)*(16*ln(2)*exp(1)-16-8*exp(1)+(exp(1))^2)*x^3/((-64+48*exp(1)-12*(exp(1))^2+(exp(1))^3)*exp(1)) end proc; Ics := Z(0) = 1, (D(Z))(0) = 1/exp(1), Z(4-exp(1)) = evalf(ln(4)), (D(Z))(4-exp(1)) = 1/4; f := proc (x) options operator, arrow; 0 end proc; p := proc (x) options operator, arrow; 0 end proc; q := proc (x) options operator, arrow; 0 end proc; r := proc (x) options operator, arrow; 0 end proc; u := proc (x) options operator, arrow; 0 end proc; eq[i] := diff(Z(x), `$`(x, 4)) = (1-alpha)*(diff(Y[i-1](x), `$`(x, 4)))+alpha*(-6*convert(taylor(exp(-4*Y[i-1](x)), x = 0, 20), polynom)); s[i] := dsolve({Ics, eq[i]}, Z(x)); Y[i] := unapply(op(2, s[i]), x); App[j] := evalf(Y[i](j)); Er[j] := abs(App[j]-Exact[j]); print([App[j], Exact[j], Er[j]]) end do end do; time[real]()-st;
Dear maple users
Greetings.
I hope you are all fine.
In this code, I am solving the PDEs via pdsolve with numeric.
There is some mistake in the boundary condition and pdsolve.
Kindly help me that to get the solution for this PDE.
Waiting for your reply.
In this problem h(z) is piecewise
Bc:
code:JVB.mw
Note: z=0.5:
I'm facing this issue when I try to use the Dsolve function in maple, it indicates me the following error :
"Error, (in dsolve/numeric/SC/firststep) unable to evaluate the partial derivatives of f(x,y) for stiff solution"
Here is part of the code :
Lagerkraft:=rhs(Eq__Sys_4_ohneZwang[1][2])=0;
                          / d        \
Lagerkraft := cos(phi(t)) |--- phi(t)|  a__ks m__k
                          \ dt       /
                 / d        \
   + cos(phi(t)) |--- phi(t)|  a__sss m__ss
                 \ dt       /
                 / d        \
   + cos(phi(t)) |--- phi(t)|  l__k m__ko
                 \ dt       /
                 / d        \
   + cos(phi(t)) |--- phi(t)|  l__k m__p
                 \ dt       /
     /  2        \
     | d         |
   + |---- phi(t)| sin(phi(t)) a__ks m__k
     |   2       |
     \ dt        /
     /  2        \
     | d         |
   + |---- phi(t)| sin(phi(t)) a__sss m__ss
     |   2       |
     \ dt        /
     /  2        \
     | d         |
   + |---- phi(t)| sin(phi(t)) l__k m__ko
     |   2       |
     \ dt        /
     /  2        \                                      /
     | d         |                                      |   4
   + |---- phi(t)| sin(phi(t)) l__k m__p + 5000000 A exp|- ---
     |   2       |                                      \  961
     \ dt        /
                                             2\
  /            /phi(t) + Pi\                \ |
  |100 Pi trunc|-----------| - 25 phi(t) + 9| | u + 200000 u A = 0
  \            \   4 Pi    /                / /
indets(Lagerkraft,name)
  {A, Pi, a__ks, a__sss, l__k, m__k, m__ko, m__p, m__ss, t, u}
Parameterliste__5:=[
A=4071.5*10^(-6),
a__ks=-20.94481*10^(-3),
a__kos=14.063837*10^(-3),
a__sss=0,
l__k=100*10^(-3),
m__k=11.02736,
m__ko=0.7237868,
m__p=1.437419,
m__ss=15,
u=1
Parameterliste__5 := [A = 0.004071500000, a__ks = -0.02094481000,
  a__kos = 0.01406383700, a__sss = 0, l__k = --, m__k = 11.02736,
                                             10
  m__ko = 0.7237868, m__p = 1.437419, m__ss = 15, u = 1]
Lagerkraft5a:=subs(Parameterliste__5, Lagerkraft);
                                            / d        \
 Lagerkraft5a := -0.01484538000 cos(phi(t)) |--- phi(t)|
                                            \ dt       /
                                  /  2        \
                                  | d         |
    + 814.3000000 - 0.01484538000 |---- phi(t)| sin(phi(t)) +
                                  |   2       |
                                  \ dt        /
                  |   4
   20357.50000 exp|- ---
                  \  961
                                              2\
   /            /phi(t) + Pi\                \ |
   |100 Pi trunc|-----------| - 25 phi(t) + 9| | = 0
   \            \   4 Pi    /                / /
indets(Lagerkraft5a,name)
                            {Pi, t}
Lösung_Lagerkraft:=dsolve({Lagerkraft5a,AB},phi(t),numeric,dsolve_options);
Hi folks, here's a bug in converting abs to Heavisides:
Converting the derivative of the abs function to a piecewise function is fine:
convert(abs(1,x),piecewise);
returns
piecewise(x < 0, -1, x = 0, undefined, 0 < x, 1);
Whereas,
convert(abs(1,x),Heaviside);
returns 1.
abs_problem.mw
`Standard Worksheet Interface, Maple 2020.2, Mac OS X, November 11 2020 Build ID 1502365`
convert(%%,Heaviside);
-1+2*Heaviside(x)+undefined*Dirac(x)
abs(x)=convert(abs(x),Heaviside);
diff(%,x);
strange:=convert(%,Heaviside);
eval(subs(x=-1,%));
abs(x) = -x+2*x*Heaviside(x)
abs(1, x) = -1+2*Heaviside(x)+2*x*Dirac(x)
1 = -1+2*Heaviside(x)
1 = -1
plot([(abs(x)),lhs(strange),rhs(strange)],x=-5..5,colour=[black,red,blue]);
Download abs_problem.mw
The following code is time consuming. Please improve the code, if it is possible. Thanks for taking your time
T := time():
M := 50:
Digits := 30:
L := 500:
R := (1/2):
nu := 0.3:
Em := 0.70e11:
N := 1:
Ec := 0.380e12:
E:= Em*(1-(y/h+1/2)^N)+Ec*(y/h+1/2)^N:
X :=(int(E*(z+(1/2)*R), [z = y-(1/2)*R .. 0, y = -(1/2)*R .. (1/2)*R]))/(int(E, [z = y-(1/2)*R .. 0, y = -(1/2)*R .. (1/2)*R])):
beta := Pi^2/L^2:
G := E/(2*(1+nu)):
phi := add(b[n]*y^n, n = 0 .. M):
Eq := diff(phi, y$2)+(diff(E, y))*(diff(phi, y))/E+((diff(E, y$2))/E-((diff(E, y))/E)^2)*phi-2*beta*(1+nu)*(phi-1):
st := [seq(coeftayl(Eq, y = 0, j), j = 0 .. M-2)]:
for k to M-1 do
b[k+1] := solve(st[k], b[k+1])
phi := subs(y = y-X, phi):
phi := subs(solve({eval(phi, y = -(1/2)*R+X), subs(y = f, phi)}, {b[0], b[1]}), phi):
f := piecewise(`and`(z >= -R, z <= 0), z+(1/2)*R+X, -z+(1/2)*R+X):
Digits := 4:
int(phi*G, [z = y-(1/2)*R .. 0, y = -(1/2)*R .. (1/2)*R], numeric)+int(phi*G, [z = 0 .. -y+(1/2)*R, y = -(1/2)*R .. (1/2)*R], numeric);
Time = Time()-T;
Note that the calculation of the integration requires alot of time. Both returns a similar result (calculation of an integration is sufficient)
I'm trying to use a text editor (notepad++) to developp a code in Maple.
Before creating a package, i would like to test step by step the different procedures that i create.
To do so, i would like to launch some procedures created in notepad++. I guess i have to call the maple kernel from notepad++. How can i do to call the maple kernel from a editor (in my case notepad++) ?
Next, would it be possible for me to test directly on a worksheet a procedure that i have been created in notepad and launched from notepad ?
I thank you in advance for your help.
hi! lately I'm thinking about animating complex phase portraits so I tried something like this:
f := (a, z) -> (z*a - 1)/(z^2 + z + 1);
display(seq(densityplot(proc(x, y) local res; res := evalhf(argument(f(1/100*a, y + x*I))); return res; end proc, -4 .. 4, -4 .. 4, axes = boxed, view = [-2 .. 2, -2 .. 2], restricttoranges, colorstyle = HUE, style = surface, grid = [201, 201]), a = 1 .. 200), insequence = true);
but this takes a long time to load. Do you how can we optimizate this code?
In a maple code, i have the symbol dollar as an the last argument of a procedure.
What is the meaning of the use of dollar symbol as an argument in a maple procedure ?
Thank you for your help.
I just upgraded to Maple 2021 and started getting strange results - similar calculations seemed to work in Maple 2020.
I am looking at correlated bivariate normal distributions. When doing a fully symbolic verification of the normalization, I get an incorrect result of infinity. I also get strange results when integrating over a circular region, but the normalization seemed to be a very elementary calculation.
Maybe someone can check this make sure I'm not losing my marbles. I've attached a worksheet.
Bivariate_Gaussian.mw
hi, do you know how can we plot analogy situation from this post:
https://mathematica.stackexchange.com/questions/100051/dynamic-epicycles/100108#100108
I really like simplicity and beauty of the idea from:
https://www.mapleprimes.com/posts/206167-Procedures-For-Two-Animations
and I wonder if it would be possible to add a third rolling circle similarly not including such long code from first page.
thanks in advance
First 416 417 418 419 420 421 422 Last Page 418 of 2432
