Bonjour,
Comment transformer cette liste de résultat:
a := {x = -12, y = -23}, {x = -34, y = 87}, {x = 18, y = 98}, {x = 27, y = 93}, {x = 45, y = 68}
En une liste simple telle que L: = [-12,-23,-34,87,18,98,27,93,45,68 ]
Merci
HELLO,
How to transform this result list :
In a simple list such that :  L: = [-12,-23,-34,87,18,98,27,93,45,68 ]
Thank You
I have two summations that Maple converts to hypergeometric outputs. Is there a way to stop that?
I dont know how to get Maple to expand the Hyper geometric output for a given walue of N
if the value of N is defined first the output is as I would expect.
The real problem, the sumations are nested and when I get to four nested sums Maple sits there for hours trying to evaluate the general case.
I have only included the first 2 summations.
Any insights on this would be appreciated.
a := -(sum(C2^(m-1)*C0^m*factorial(2*m)/(C1^(2*m-1)*factorial(m+1)*factorial(m)), m = 0 .. N))
-2*C1/(C2*(1+(-(4*C0*C2-C1^2)/C1^2)^(1/2)))+C2^N*C0^(N+1)*GAMMA(2*N+3)*(N+2)*hypergeom([1, 3/2+N], [N+3], 4*C0*C2/C1^2)/(C1^(2*N+1)*GAMMA(N+3)^2)
N := 4
4
a
-2*C1/(C2*(1+(-(4*C0*C2-C1^2)/C1^2)^(1/2)))+42*C2^4*C0^5*hypergeom([1, 11/2], [7], 4*C0*C2/C1^2)/C1^9
b := -(sum(C2^(m-1)*C0^m*factorial(2*m)/(C1^(2*m-1)*factorial(m+1)*factorial(m)), m = 0 .. N))
-C1/C2-C0/C1-2*C2*C0^2/C1^3-5*C2^2*C0^3/C1^5-14*C2^3*C0^4/C1^7
NULL``
unassign('N')
c := sum(sum((-1)^(m[3]+1)*factorial(2*m[2]+3*m[3])*C0^(1+m[2]+2*m[3])*C2^m[2]*C3^m[3]/(factorial(1+m[2]+2*m[3])*factorial(m[2])*factorial(m[3])*C1^(1+2*m[2]+3*m[3])), m[3] = 0 .. N), m[2] = 0 .. N)
sum(C2^m[2]*(-factorial(2*m[2])*C0^(1+m[2])*hypergeom([(2/3)*m[2]+1, (2/3)*m[2]+2/3, 1/3+(2/3)*m[2]], [1+(1/2)*m[2], 3/2+(1/2)*m[2]], -(27/4)*C0^2*C3/C1^3)/(factorial(1+m[2])*C1^(1+2*m[2]))-factorial(2*m[2]+3*N+3)*C0^(3+m[2]+2*N)*C3^(N+1)*hypergeom([1, (2/3)*m[2]+2+N, 5/3+(2/3)*m[2]+N, 4/3+(2/3)*m[2]+N], [N+2, 2+(1/2)*m[2]+N, 5/2+(1/2)*m[2]+N], -(27/4)*C0^2*C3/C1^3)*(-1)^N/(factorial(3+m[2]+2*N)*factorial(N+1)*C1^(4+2*m[2]+3*N)))/factorial(m[2]), m[2] = 0 .. N)
NULLN := 4
4
c
-C0*hypergeom([1/3, 2/3], [3/2], -(27/4)*C0^2*C3/C1^3)/C1-273*C0^11*C3^5*hypergeom([1, 16/3, 17/3], [6, 13/2], -(27/4)*C0^2*C3/C1^3)/C1^16+C2*(-C0^2*hypergeom([1, 4/3, 5/3], [3/2, 2], -(27/4)*C0^2*C3/C1^3)/C1^3-6188*C0^12*C3^5*hypergeom([1, 19/3, 20/3], [13/2, 7], -(27/4)*C0^2*C3/C1^3)/C1^18)+(1/2)*C2^2*(-4*C0^3*hypergeom([5/3, 7/3], [5/2], -(27/4)*C0^2*C3/C1^3)/C1^5-162792*C0^13*C3^5*hypergeom([1, 20/3, 22/3], [6, 15/2], -(27/4)*C0^2*C3/C1^3)/C1^20)+(1/6)*C2^3*(-30*C0^4*hypergeom([7/3, 8/3], [5/2], -(27/4)*C0^2*C3/C1^3)/C1^7-4883760*C0^14*C3^5*hypergeom([1, 22/3, 23/3], [6, 15/2], -(27/4)*C0^2*C3/C1^3)/C1^22)+(1/24)*C2^4*(-336*C0^5*hypergeom([10/3, 11/3], [7/2], -(27/4)*C0^2*C3/C1^3)/C1^9-164745504*C0^15*C3^5*hypergeom([1, 25/3, 26/3], [6, 17/2], -(27/4)*C0^2*C3/C1^3)/C1^24)
e := sum(sum((-1)^(m[3]+1)*factorial(2*m[2]+3*m[3])*C0^(1+m[2]+2*m[3])*C2^m[2]*C3^m[3]/(factorial(1+m[2]+2*m[3])*factorial(m[2])*factorial(m[3])*C1^(1+2*m[2]+3*m[3])), m[3] = 0 .. N), m[2] = 0 .. N)
-C0/C1-5*C2^3*C0^4/C1^7-C2*C0^2/C1^3-2*C2^2*C0^3/C1^5-3*C0^5*C3^2/C1^7+12*C0^7*C3^3/C1^10-55*C0^9*C3^4/C1^13-14*C0^5*C2^4/C1^9+C0^3*C3/C1^4+330*C0^7*C2^4*C3/C1^12-5005*C0^9*C2^4*C3^2/C1^15+61880*C0^11*C2^4*C3^3/C1^18-678300*C0^13*C2^4*C3^4/C1^21+5*C0^4*C2*C3/C1^6-28*C0^6*C2*C3^2/C1^9+165*C0^8*C2*C3^3/C1^12-1001*C0^10*C2*C3^4/C1^15+21*C0^5*C2^2*C3/C1^8-180*C0^7*C2^2*C3^2/C1^11+1430*C0^9*C2^2*C3^3/C1^14-10920*C0^11*C2^2*C3^4/C1^17+84*C0^6*C2^3*C3/C1^10-990*C0^8*C2^3*C3^2/C1^13+10010*C0^10*C2^3*C3^3/C1^16-92820*C0^12*C2^3*C3^4/C1^19
Download why_hypergeom.mw
Hello, I am solving an ODE numerically:
restart: deq1 := diff(y(t), t, t)+y(t)*abs(y(t)) = 0; ic1 := y(0) = 1.0, (D(y))(0) = 0.;
dsol1 := dsolve({deq1, ic1}, numeric, range = 0 .. 10);
odeplot(dsol1);
I need to get the plots of the first and second derivatives of the solution. Ok, I can get the first derivating by transforming the equation to system with two unknown functions and reducing the order, but I also need the second and possibly higher derivatives.
I am a student who is learning to use Maple to perform numerical analysis of phase field. There has been no solution to the problem of high anisotropy. The reference code is as follows
W :=piecewise(beta>=Pi/2+thetaM and beta<=Pi-thetaM, 1+eps*cos(4*beta),
       beta>=Pi/2-thetaM and beta<=Pi/2+thetaM, (1+esp*cos(4*thetaM))/cos(thetaM)*cos(4*beta));
However, there is no problem at all when simply performing the following settings.
W := 1+ eps*cos(4*beta);
Please tell me how to write such a conditional maple statement. I have referenced many examples on the official website, but none of them succeeded. This includes writing the code in the following form.
W :=betta->piecewise(beta>=Pi/2+thetaM and beta<=Pi-thetaM, 1+eps*cos(4*beta),
Remarks, beta is an angle, set as follows.
subs(beta=t_atan2(diff(pho(x,y),y), diff(pho(x,y),x))
We give a line (D) and a point A located at a distance AH=h from D. A constant angle of magnitude alpha pivots to its apex A and we call B and C the points where its sides cut the line D. Let O be the center of the circle circumscribed to the triangle ABC.
Demonstrate that the B and C tangents to the O circle keep a fixed direction.
Here is my code which don't work for slopes are not equal.
restart; with(plots): with(geometry):unprotect(D):
_EnvHorizontalName := 'x':_EnvVerticalName := 'y':
line(D, y = (1/2)*x-1); point(A, 5, 5); PerpendicularLine(lp, A, D); h := distance(A, D); intersection(H, D, lp);
alpha := (1/16)*Pi;
rotation(lp1, lp, (1/6)*Pi, 'clockwise', A); rotation(lp2, lp1, (1/6)*Pi-alpha, 'clockwise', A); FindAngle(lp1, lp2); evalf(%);
intersection(B, D, lp1); intersection(C, D, lp2);
triangle(T, [A, B, C]);
circumcircle(Elc, T, 'centername' = OO);
TangentLine(tgB, B, Elc); TangentLine(tgC, C, Elc);
evalf(slope(tgB)); evalf(slope(tgC));
dr := draw([D(color = blue), lp(color = red), Elc(color = green), A, B, C, T(color = black), H, tgB, tgC], printtext = true);
display([dr], axes = none, scaling = constrained);
Fig := proc (k) local dr, Elc, B, C, lp1, lp2; global D, A, lp, H, alpha; geometry:-rotation(lp1, lp, (1/6)*Pi+k, 'clockwise', A); geometry:-rotation(lp2, lp1, (1/6)*Pi-alpha+k, 'clockwise', A); geometry:-intersection(B, D, lp1); geometry:-intersection(C, D, lp2); geometry:-triangle(T, [A, B, C]); geometry:-circumcircle(Elc, T, 'centername' = OO); geometry:-TangentLine(tgB, B, Elc); geometry:-TangentLine(tgC, C, Elc); dr := geometry:-draw([D(color = blue), lp(color = red), Elc(color = green), A, B, C, T(color = black), H, tgB, tgC], printtext = true); plots:-display([dr], axes = none, scaling = constrained) end proc;
iframes := 10;
display([seq(Fig((1/12)*Pi+i/(10*iframes)), i = 1 .. iframes)], insequence, scaling = constrained);
How to improve this code ? Thank you.
Could anybody help me with how to solve the linear time-varying differential equation set in Maple?
A good example will works well.
I've finally decided to see what I could to do with DocumentTools.
I started with these simple lines from ?DocumentTools:-Do
with(DocumentTools):
Do(int(%expression, x=%from::integer..%to::integer));
Error, (in DocumentTools:-GetProperty) Attempted to retrieve property of unknown component expression.
These next ones return the expected plot but an alert window
Do(%Plot1=plot(x^2, x=0..1));
However the Click and Drag icon is disabled in the plot toolbar and invisible in the plot menu.
The behaviour of these commands do not depend on whether they are written in a worksheet, a section or a code edit region.
Could you detail me the very first steps do use DocumentTools features?
TIA
DT-Do.mw
Suppose we want to compute the following derivate:
x := [x__1, x__2, x__3]
f := [x__1]
Gradf := Matrix(1, 3, (i,j) -> diff(f[i], x[j]));
Gradf2 := Matrix(3, 3, (i,j) -> diff(Gradf[i], x[j]));
my question is how to convert Gradf from [1  0 0] to [1,0,0]?
Hello there,
Would you allow me to ask this question?
What I tried in the worksheet below is to map an expression to x-axis and another expression to y-axis, while both expressions have the same input (or independent variable). However, the resulting plot still shows those two expressions as two separate curves. Would you tell me how to map or assign the expressions to each axis?
Digits := 6:
j := I:
L__adpu := 1.66;
L__aqpu := 1.61;
L__lpu := 0.15;
R__apu := 0.003;
E__tpu := 1.0;
MVA := 555;
1.66
1.61
.15
0.3e-2
1.0
555
A__sat := 0.0312500:
B__sat := 6.93147:
I__tpu_compare := (P__t - j* Q__t) / E__tpu;
-(1.00000*I)*Q__t+1.00000*P__t
I__tpu_a := abs(I__tpu_compare);
abs(-(1.00000*I)*Q__t+1.00000*P__t)
Phi := arccos(P__t / (I__tpu_a * E__tpu));
arccos(1.00000*P__t/abs(-(1.00000*I)*Q__t+1.00000*P__t))
E__a__tilde := E__tpu + (R__apu + j * L__lpu) * I__tpu_compare;
1.0+(0.3e-2+.15*I)*(-(1.00000*I)*Q__t+1.00000*P__t)
psi__at := abs(E__a__tilde);
abs(1.0+(0.3e-2+.15*I)*(-(1.00000*I)*Q__t+1.00000*P__t))
psi__I := A__sat * exp(B__sat * (psi__at - 0.8));
0.312500e-1*exp(6.93147*abs(1.0+(0.3e-2+.15*I)*(-(1.00000*I)*Q__t+1.00000*P__t))-5.54518)
K__sd := psi__at / (psi__at + psi__I);
abs(1.0+(0.3e-2+.15*I)*(-(1.00000*I)*Q__t+1.00000*P__t))/(abs(1.0+(0.3e-2+.15*I)*(-(1.00000*I)*Q__t+1.00000*P__t))+0.312500e-1*exp(6.93147*abs(1.0+(0.3e-2+.15*I)*(-(1.00000*I)*Q__t+1.00000*P__t))-5.54518))
K__sq := K__sd;
X__ad := K__sd * L__adpu:
X__d := X__ad + L__lpu:
X__aq := K__sq * L__aqpu:
X__q := X__aq + L__lpu:
delta__i := arctan((X__q * I__tpu_a * cos(Phi) - R__apu * I__tpu_a * sin(Phi))/(E__tpu + R__apu * I__tpu_a * cos(Phi) + X__q * I__tpu_a * sin(Phi))):
e__q := E__tpu * cos(delta__i):
i__d := I__tpu_a * sin(delta__i + Phi):
i__q := I__tpu_a * cos(delta__i + Phi):
i__fd := (e__q + R__apu * i__q + X__d * i__d)/(X__ad):
i_armature := sqrt(i__d^2 + i__q^2):
i_armature2 := subs(P__t = 0, i_armature):
i_armature3 := subs(P__t = 0.5, i_armature):
i_armature4 := subs(P__t = 1.0, i_armature):
plotA := plot(i_armature2, Q__t = -0.6..0.6):
plotB := plot(i_armature3, Q__t = -0.6..0.6):
plotC := plot(i_armature4, Q__t = -0.6..0.6):
plots:-display([plotA, plotB, plotC]);
i__fd2 := subs(P__t = 0, i__fd):
i__fd3 := subs(P__t = 0.5, i__fd):
i__fd4 := subs(P__t = 1.0, i__fd):
plotD := plot(i__fd2, Q__t = -0.6..0.6):
plotE := plot(i__fd3, Q__t = -0.6..0.6):
plotF := plot(i__fd4, Q__t = -0.6..0.6):
plots:-display([plotD, plotE, plotF]);
plot([i__fd2, i_armature2, Q__t = -0.6..0.6]); #failed, two expressions are plotted seperately.
Best Regards,
In Kwon Park
Download Q20210416.mw
What is the reason for the warning?
f := (x, y, z) -> 1 - x^4 + ln(x^4) + z^4 - y^4 - y^4*(ln(z^4) - ln(y^4));
with(Optimization);
Minimize(f(x, y, z), {x^2 + y^2 - z^2 - 1 = 0, 0 <= x - 1, 0 <= y - x, 0 <= z - y});
Warning, no iterations performed as initial point satisfies first-order conditions
                 [0., [x = 1., y = 1., z = 1.]]
Suppose we have a state vector x=[x_1,y_1,theta_1,x_2,y_2,theta_2] and a vector field f=[cos(theta_1),sin(theta_1),0,0,0,0]
How we can define a vector field with 6 dimentions?
with(VectorCalculus);
f := VectorField([cos(theta__1),sin(theta__1),0,0,0,0],'cartesian ??? '[x__1,y__1,z__1,x__2,y__2,z__2]);
I need to compute the Jacobian of f wrt x:
Jacobian(f, [x_1,y_1,theta_1,x_2,y_2,theta_2]
In an answer to an earlier question
https://mapleprimes.com/questions/232067-Error-Invalid-Neutral-Operator
I inadvertently used the "Insert Contents" link - AND IT WORKED
Anybody know how long this has been fixed?
How can I plot vector using maple
Maple return the following error
Error, invalid neutral operator
plotvector.mw
In trying to create a plot that shades the region between two concentric circles, I decided to try using the Picture procedure found here: https://www.mapleprimes.com/posts/145922-Perimeter-Area-And-Visualization-Of-A-Plane-Figure-
This is as far as I got.
"Picture := proc (L, C, N::posint := 100, Boundary::list := [linestyle = 1])    local i, var, var1, var2, e, e1, e2, P, Q, h;    global Border;    for i to nops(L) do    if type(L[i], listlist(algebraic)) then P[i] := op(L[i]) else    var := lhs(L[i, 2]); var1 := lhs(rhs(L[i, 2])); var2 := rhs(rhs(L[i, 2])); h := (var2-var1)/N;    if type(L[i, 1], algebraic) then e := L[i, 1];    if nops(L[i]) = 3 then P[i] := seq(subs(var = var1+h*i, [e*cos(var), e*sin(var)]), i = 0 .. N) else    P[i] := seq([var1+h*i, subs(var = var1+h*i, e)], i = 0 .. N) end if else    e1 := L[i, 1, 1]; e2 := L[i, 1, 2]; P[i] := seq(subs(var = var1+h*i, [e1, e2]), i = 0 .. N) end if end if    end do;    Q := [seq(P[i], i = 1 .. nops(L))];    Border := plottools[curve]([op(Q), Q[1]], op(Boundary));    [plottools[polygon](Q, C), Border];    end proc:"
L := [[3, t = 0 .. 2*Pi, polar], [2, t = 0 .. 2*Pi, polar]]; plots[display](Picture(L, color = yellow, [color = brown, thickness = 3]), scaling = constrained, view = [-4 .. 4, -4 .. 4])
Clearly, this is not what I want. I am probably missing something simple here. How can I get only the region between the two circles to be shaded?
Download shading_annular_regions.mw
Hello friends
PLEASE HELP
I have the following issue
I want to make one plot with specific values of argument
here is an example of 2d plot ,
what i want is to plot the same graph only with specific values of x for example x =-pi..pi/2  , -pi/4..pi/4  and so on
but this has to be in one plot , could please tell me the options how I can manage this problem .
At the end its a 3Dplot , x is a function of y and t
so actually i want to make 3d plot in a different ares of y and t
something like this plot3d(u ,x=-1..1,t=-1..1 , x=2..3 , t=2..3 .... )
or maybe in opposite way ,to restrict some values of x and t
( idea is that function is periodic but I dont want to get crazy high values of the function, especially where functuon goes to infinity  )
PLEASE HELP
thank you very much in advance
First 420 421 422 423 424 425 426 Last Page 422 of 2432
