I want to perform a numerical evaluation of sums of integrals of relatively complicated functions. I know about the evalf(Int( )) and evalf(Sum( )) commands to numerically evaluate both sums and integrals individually. My question is: what is the time-efficient way to numerically evaluate a sum of integrals?
Here is a simplified sketch of what I have.
Say I define my complicated function F of the variable x (which will be integrated over) and of some constant parameter n.
I am interested in numerically evaluating in a time efficient way the following sum of integrals of F:
Where should I apply the evalf() command(s)? Should I go evalf(Sum( evalf(Int( )))) or evalf(Sum( Int())) or sum( evalf(Int( ))), or something else? I am not too worried about the accuracy here: it is for plots mainly. How to make this numercal evaluation fast?
Bonus question. If now I make F also depend on t, and wish to define a function G(t) out of a linear combination of such sums of integrals: is the method the same? I can have G(t) defined numerically with a t dependance. For example:
Thanks a lot!
PS: F is a complicated function in the sense that it is rationnal in some (non-usual) polynomials defined by a Rodrigues Rormula. The integrand has no singularity on the domain of integration. I have Maple 2018.
complexplot3d((z - 1)/(z^2 + z + 1), z = -4 - 4*I .. 4 + 4*I, view = [-2 .. 2, -2 .. 2, 0 .. 2], grid = [70, 70], shading = zhue)
How can I change this color of complex plot to take mirror image of my enhanced portrait? I see this is inverse but I don't know the source of this situation. I guess that zhue is indicaded by H = arg(f(z)) L = l(|f(z)|) S=1 in MAPLE but I don't know how to transfer and change this to the second picture coloring. I built the code for the second picture using codes from this post:
https://www.mapleprimes.com/questions/226790-Is-There-Any-Maple-Code-For-The-domain
I want to present this complexplot with the same coloring so thank for all yours advise.
Dear Users!
Hope everyone is fine here. I want to formulate the table like give bellow (Table 5.17) in maple so that I can copy it in word file and can edit.
The values of y[1,1],y[2,1],y[2,2],y[3,1],y[3,2],y[3,3]...y[nops(HAq),nops(HAq)] present in the following maple code. Thanks in advance
Refine_Extrapolation.mw
I'm a bit confused about set ordering.
According to help there are those features
  1. object id (same kind of data-structures to be grouped togther)
  2. object length
  3. lexicographical or numerical orders
  4. recurse on components
  5. address
Have a look at the following set.
  • If object length has higher priority than lexicographical order, why is HBSEVO before LBS?
  • If lexicographical order has higher priority, which is HBSPLATEEVO after VGZEVO?
Download SetSortOrder.mw
I asked before how to determine whether a graph is  outerplanar graph.  vv  and  Carl Love  provided very good guidance.
https://www.mapleprimes.com/questions/229128--How-To-Determine-If-A-Graph-Is-Outerplanar
 Today I tried to use the previous code to further determine whether a plane graph is maximal outerplanar graph.
maximal outerplanar graph is an outerplanar graph that cannot have any additional edges added to it while preserving outerplanarity.
IsOuterplanar:= proc(G::Graph)
uses GT= GraphTheory;
    GT:-IsPlanar(GT:-GraphJoin(G, GT:-PathGraph(1)))
IsmaximalOuterplanar:= proc(G::Graph)
uses GT= GraphTheory:
local glist, Outerplanartest:
      glist:= map[2](GT:-AddEdge,G,GT:-Edges(GT:-GraphComplement(G)),inplace = false ):
       Outerplanartest:=IsOuterplanar~(glist):
      if evalb(true in Outerplanartest) then
         return false:
         return true:
      fi:
I feel that the  above adding edges in programs is a bit inefficient.
So I wonder if there is a better way.  Then I want to start from property of this graph class.
Some Properties:
  1. Every maximal outerplanar graph with n vertices has exactly 2n − 3 edges.
  2. A graph on  n (>=3) vertices  is  maximal outerplanar graph  if and if  every bounded face of a maximal outerplanar graph is a triangle and boundary of  unbounded face  is  Hamiltonian cycle.
I noticed the second one. I don’t know if it can be achieved through programming
I want to get some information about the degree sequence of the face with the help of the dual graph . But I know  dual graph not unique   since  there are different plane embeddings  for not 3 connected  planar graphs.
Or is there a more efficient way?
T := diff(Phi(xi), xi);
                           d
                          ---- Phi(xi)
                           dxi
T := (p*a^(-Phi(xi))+q+r*a^Phi(xi))/ln(a);
                    (-Phi(xi))          Phi(xi)
                 p a           + q + r a
                             ln(a)
u[0] := C[0]+C[1]*a^Phi(xi)+C[2]*a^(2*Phi(xi));
                         Phi(xi)         (2 Phi(xi))
            C[0] + C[1] a        + C[2] a
u[1] := diff(u[0], xi);
               Phi(xi) / d          \
         C[1] a        |---- Phi(xi)| ln(a)
                       \ dxi        /
                      (2 Phi(xi)) / d          \
            + 2 C[2] a            |---- Phi(xi)| ln(a)
                                  \ dxi        /
d[1] := C[1]*a^Phi(xi)*T*ln(a)+2*C[2]*a^(2*Phi(xi))*T*ln(a);
         Phi(xi) /   (-Phi(xi))          Phi(xi)\
   C[1] a        \p a           + q + r a       /
                (2 Phi(xi)) /   (-Phi(xi))          Phi(xi)\
      + 2 C[2] a            \p a           + q + r a       /
u[2] := diff(d[1], xi);
      Phi(xi) / d          \       /   (-Phi(xi))
C[1] a        |---- Phi(xi)| ln(a) \p a           + q
              \ dxi        /
        Phi(xi)\         Phi(xi) /
   + r a       / + C[1] a        |
    (-Phi(xi)) / d          \
-p a           |---- Phi(xi)| ln(a)
               \ dxi        /
        Phi(xi) / d          \      \           (2 Phi(xi)) / d
   + r a        |---- Phi(xi)| ln(a)| + 4 C[2] a            |----
                \ dxi        /      /                       \ dxi
          \       /   (-Phi(xi))          Phi(xi)\
   Phi(xi)| ln(a) \p a           + q + r a       / + 2 C[2]
   (2 Phi(xi)) /    (-Phi(xi)) / d          \
  a            |-p a           |---- Phi(xi)| ln(a)
               \               \ dxi        /
        Phi(xi) / d          \      \
                \ dxi        /      /
d[2] := C[1]*a^Phi(xi)*T*ln(a)*(p*a^(-Phi(xi))+q+r*a^Phi(xi))+C[1]*a^Phi(xi)*(-p*a^(-Phi(xi))*T*ln(a)+r*a^Phi(xi)*T*ln(a))+4*C[2]*a^(2*Phi(xi))*T*ln(a)*(p*a^(-Phi(xi))+q+r*a^Phi(xi))+2*C[2]*a^(2*Phi(xi))*(-p*a^(-Phi(xi))*T*ln(a)+r*a^Phi(xi)*T*ln(a));
      Phi(xi) /   (-Phi(xi))          Phi(xi)\          Phi(xi) /
C[1] a        \p a           + q + r a       /  + C[1] a        \
    (-Phi(xi)) /   (-Phi(xi))          Phi(xi)\
-p a           \p a           + q + r a       /
        Phi(xi) /   (-Phi(xi))          Phi(xi)\\
   + r a        \p a           + q + r a       //
   + 4 C[2] a            \p a           + q + r a       /  + 2 C[
      (2 Phi(xi)) /
  2] a            \
expand((2*k*k)*w*beta*d[2]-(2*alpha*k*k)*d[1]-2*w*u[0]+k*u[0]*u[0]);
          2                         Phi(xi)
-2 alpha k  C[1] p + 2 k C[0] C[1] a
                             2                      3
                   / Phi(xi)\             / Phi(xi)\
   + 2 k C[0] C[2] \a       /  + 2 k C[1] \a       /  C[2]
                      2             Phi(xi)
   - 2 w C[0] + k C[0]  - 2 w C[1] a
                        2                     2
              / Phi(xi)\          2 / Phi(xi)\
   - 2 w C[2] \a       /  + k C[1]  \a       /
                       4
           2 / Phi(xi)\       2              Phi(xi)
   + k C[2]  \a       /  + 4 k  w beta C[1] a        p r
        2             / Phi(xi)\
   + 6 k  w beta C[1] \a       /  q r
         2              Phi(xi)
   + 12 k  w beta C[2] a        p q
         2             / Phi(xi)\
   + 16 k  w beta C[2] \a       /  p r
         2             / Phi(xi)\           2              2
   + 20 k  w beta C[2] \a       /  q r + 4 k  w beta C[2] p
              2       Phi(xi)              2      / Phi(xi)\
   - 2 alpha k  C[1] a        q - 2 alpha k  C[1] \a       /  r
   - 4 alpha k  C[2] a        p - 4 alpha k  C[2] \a       /  q
              2      / Phi(xi)\         2
   - 4 alpha k  C[2] \a       /  r + 2 k  w beta C[1] p q
        2              Phi(xi)  2
   + 2 k  w beta C[1] a        q
        2             / Phi(xi)\   2
   + 4 k  w beta C[1] \a       /  r
        2             / Phi(xi)\   2
   + 8 k  w beta C[2] \a       /  q
                                 4
         2             / Phi(xi)\   2
   + 12 k  w beta C[2] \a       /  r
value(%);
          2                         Phi(xi)
                             2                      3
                      2             Phi(xi)
                        2                     2
                       4
        2             / Phi(xi)\
         2              Phi(xi)
         2             / Phi(xi)\
         2             / Phi(xi)\           2              2
              2      / Phi(xi)\         2
        2              Phi(xi)  2
        2             / Phi(xi)\   2
        2             / Phi(xi)\   2
                                 4
         2             / Phi(xi)\   2
simplify(%);
           2                         Phi(xi)
                     (2 Phi(xi))             (3 Phi(xi))
    + 2 k C[0] C[2] a            + 2 k C[1] a            C[2]
                (2 Phi(xi))         2  (2 Phi(xi))
    - 2 w C[2] a            + k C[1]  a
            2  (4 Phi(xi))            2       (2 Phi(xi))
    + k C[2]  a            - 2 alpha k  C[1] a            r
               2       (2 Phi(xi))
    - 4 alpha k  C[2] a            q
               2       (3 Phi(xi))                      2
    - 4 alpha k  C[2] a            r - 2 w C[0] + k C[0]
                Phi(xi)      2              (2 Phi(xi))
    - 2 w C[1] a        + 6 k  w beta C[1] a            q r
          2              (2 Phi(xi))
    + 16 k  w beta C[2] a            p r
          2              (3 Phi(xi))
    + 20 k  w beta C[2] a            q r
         2              Phi(xi)
          2              Phi(xi)          2              2
    + 12 k  w beta C[2] a        p q + 4 k  w beta C[2] p
               2       Phi(xi)              2       Phi(xi)
    - 2 alpha k  C[1] a        q - 4 alpha k  C[2] a        p
         2              (3 Phi(xi))  2
    + 4 k  w beta C[1] a            r
         2              (2 Phi(xi))  2
    + 8 k  w beta C[2] a            q
          2              (4 Phi(xi))  2      2
    + 12 k  w beta C[2] a            r  + 2 k  w beta C[1] p q
         2              Phi(xi)  2
collect(%, a^Phi(xi));
Error, (in collect) cannot collect a^Phi(xi)
Is it possible to auto close brackets in Maple? Like when I type "sin(pi" it would automatically create a closing bracket and I could just press enter to calculate
I am trying to find Lie subalgebra for finding optimal solutions directly with the help of MAPLE.  Please help me to find it. Share MAPLE code please.
Any good online training for maple soft to purchase
How to solve this differential equation numerically
eq:=diff(f(tau), tau) =Af(tau) +Lf(tau) +C+Bf(tau)
Hello everyone, I am very new to Maple so please bear with me. I have created a procuedure that rearranges
NaturalNumbers:=proc(k)
[$1..2*k-1]
Into
eq_arrangement:=proc(k)  local i,j,a;  for i from 1 to k-1 do
  a[2*i-1]:=k+i;
  a[2*i]:=k-i;
[k,seq(a[j],j=1..2*(k-1))];end proc;
My question is how I can repeat this procudure the sufficient number of times until I get back to [$1..2*k-1] in that order.
Thank you so much!
I'm trying to plot the function below. However, I cannot get the plot to exceed 10 on the x-axis. I have tried changing the axis properties but the function is just "cut off". I have had the same problem with similar functions and ended up using other software.
The function should have valid values above 10.
Does anyone know how I can fix this?
h := x -> 1.23 + x*1*0.0001 + 0.12*log(50000*x) + abs((-1)*0.03*log(x/0.001))
Thank you in advance :)
Hello, dear All
I have Maple2021 installed and I'll use the newest Physics Version. But
it does not work.
How can I activate the Physic Version 935?
When I start the file: "Wirtinger_Derivatives.mw"  I get
With kind regards
Wolfgang Gellien
I have found few PDE's so far  that timeout in Maple 2021 which did not do that in Maple 2020.2. Using same amount of time out, on same PC.
After some debugging, I found that that cause is calling latex:-Settings(....) before calling  timelimit(pdsolve(...))  causes the timeout.
At first, I thought this must be coincidence. Why would calling latex make pdsolve timeout?
So I tried again and again and again. Each time, removing the call to latex makes pdsolve not time out. Putting latex call back in, now pdsolve times out. Each time restart is always called (in new cell) before.
The timeout is 10 minutes.  Without latex called before, pdsolve took about about 5 minutes on my PC to solve the PDE.
Any one could see if they can reproduce this?
Why would calling latex:-Settings(....)  causes pdsolve now use all 10 minutes and then timeout? This is very strange.
Maple 2021. Latex Physics package. Windows 10.
attached is worksheet showing this with many tries.
latex:-Settings(UseImaginaryUnit=i,
      UseColor = false,
      powersoftrigonometricfunctions= mixed, ## computernotation,
      leavespaceafterfunctionname = true,
      cacheresults = false,
      spaceaftersqrt = true
pde :=  a*ln(lambda*x)^n*diff(w(x,y),x)+ b*ln(mu*x)^m*diff(w(x,y),y) = c*ln(nu*x)^k*w(x,y)+p*ln(beta*y)^s+q;
timelimit(60*10,pdsolve(pde,w(x,y)));
#Error, (in expand) time expired
#OR
#Error, (in evala/Divide/heuristic) time expired
#no problem solution found.
why_time_out_with_latex_march_23_2021.mw
First 429 430 431 432 433 434 435 Last Page 431 of 2432
