I want to import the data included here to my Maple code:
https://www.gw-openscience.org/GW150914data/P150914/fig2-unfiltered-template-reconstruction-H.txt
There are 3 columns of data: time, NR strain, Reconstructed strain. I am not interested in the middle column; I want to plot the reconstructed strain as a function of time. I could use some help.
Cheers!
Two days ago I have answered a question about using numapprox:-infnorm for functions of several variables. The question is now deleted. Is it possible to find whether it was deleted by the author (even if she/he has used the "best answer" tag)?
I compute by hand the bifurcation point of an ode,
I fouded x=-1/2 a+ 1/2 corresponding to  h= (a+1)^2/4  with 0<a<1
The same solution is obtained using Maple code.
I tried to plot the birfurcation diagram to stech with kind of bifrucation ( saddle, Holf . transcritical , periodic, or someting else)
But I get
Error, (in plots/implicitplot) invalid input: invalid range for first variable
bifurcation_diagram.mw
thank you for any help
While solving a math problem, one has to deal with a system of 25 linear equations with a parameter s (Laplace transform variable). i tried formulating the system in a matrix form using GenerateMatrix and inverting the system using solve with LU or QR method but without success. i attach a minimal working environment for the system of equations at hand. Any help or advice is highly appreciated – thank you!
PDE:
(a+b)*(uxx+vxy)+c*laplacian(u)=0
(a+b)*(vxy+vyy)+c*laplacian(v)=0
a,b,c=const.  Initial:u=1/2*sin(2*theta),v=cos(theta)
Text book says: Solve by complex variable method
I have a PDEs depend on u1(r,z)
I would like to decompose u1 as sum of two function c1*r*U(z)+u(r,z) and  , where c1 is constant,  then i would like to substitute u1 in the pde by   c1*r*U(z)+u(r,z) then obtain the corresponding new equation
subs_function.mw
thank you
Is there a way to make a library file that automatically has the functions/procedures loaded on startup and after it any new or open ".mw" can use functions/procedures from library with no redefinition?
I have a table that includes the numeric and exact solution of a complex PDE.
I want to calculate error between exact and numeric solution.
Question 1: Which type of error is mostly used for complex solutions? Absolute error or relative error ,ecludian norm error etc.
Question 2: How to calculate absolute error in complex solutions?
 |abs(Exact_Solution)-abs(Numeric_Solution)|
or
|abs(Exact_Solution-Numeric_Solution)|
interface(rtablesize=19):
Table_1:=Matrix(19,4,{(1, 1) = x, (1, 2) = t, (1, 3) = Exact_Solution, (1, 4) =
Numeric_Solution, (2, 3) = .58480350959087385609+1.0129093910559867400*I, (2, 4
) = .58480354764257321311+1.0129094569634633407*I, (3, 2) = .2, (3, 3) = .58507\
763625784549559+1.0133841923708911330*I, (3, 4) = .58507767430954485264+1.01338\
42582783677337*I, (4, 2) = .4, (4, 3) = .58590001649935378049+1.014808596732324\
2462*I, (4, 4) = .58590005455105313755+1.0148086626398008469*I, (5, 2) = .6, (5
, 3) = .58727066619506620449+1.0171826316446769860*I, (5, 4) = .587270690527719\
69197+1.0171826737900691093*I, (6, 2) = .8, (6, 3) = .58918956627727806829+1.02\
05062640817160297*I, (6, 4) = .58918959060993155574+1.0205063062271081530*I, (7
, 2) = 1.0, (7, 3) = .59165666981620797589+1.0247794127586756112*I, (7, 4) = .5\
9165677643905044333+1.0247795974348560123*I, (8, 1) = .5, (8, 3) = .59165805893\
555155139+1.0247818187839564608*I, (8, 4) = .59165677643905044333+1.02477959743\
48560123*I, (9, 1) = .5, (9, 2) = .2, (9, 3) = .58919046685310110177+1.02050782\
39247975919*I, (9, 4) = .58918959060993155574+1.0205063062271081530*I, (10, 1)
= .5, (10, 2) = .4, (10, 3) = .58727131671750391922+1.0171837583825905714*I, (
10, 4) = .58727069052771969197+1.0171826737900691093*I, (11, 1) = .5, (11, 2) =
.6, (11, 3) = .58590207620818846348+1.0148121642526747156*I, (11, 4) = .5859000\
5455105313755+1.0148086626398008469*I, (12, 1) = .5, (12, 2) = .8, (12, 3) = .5\
8507958971290229630+1.0133875758542998141*I, (12, 4) = .58507767430954485264+1.\
0133842582783677337*I, (13, 1) = .5, (13, 2) = 1.0, (13, 3) = .5848057178847424\
9287+1.0129132159331652617*I, (13, 4) = .58480354764257321311+1.012909456963463\
3407*I, (14, 1) = 1.0, (14, 3) = .61222010009837745680+1.0603963187852935669*I,
(14, 4) = .61222010009837745677+1.0603963187852935669*I, (15, 1) = 1.0, (15, 2)
= .2, (15, 3) = .60700988526763399480+1.0513719619800970123*I, (15, 4) = .60700\
988526763399480+1.0513719619800970123*I, (16, 1) = 1.0, (16, 2) = .4, (16, 3) =
.60234868471511732616+1.0432985257988700194*I, (16, 4) = .60234868471511732617+
1.0432985257988700194*I, (17, 1) = 1.0, (17, 2) = .6, (17, 3) = .59823621894610\
415849+1.0361755261425513984*I, (17, 4) = .59823621894610415846+1.0361755261425\
513983*I, (18, 1) = 1.0, (18, 2) = .8, (18, 3) = .59467229263079952050+1.030002\
6246900120270*I, (18, 4) = .59467229263079952054+1.0300026246900120270*I, (19,
1) = 1.0, (19, 2) = 1.0, (19, 3) = .59165677643905044330+1.0247795974348560123*
I, (19, 4) = .59165677643905044333+1.0247795974348560123*I},datatype = anything
,storage = rectangular,order = Fortran_order,shape = [])
I want to check whether the solution trial_sol satisfies the following PDE by Maple:
PDE:=diff(diff(u(x,y,t),x,y)/u(x,y,t),t$2)-diff(diff(u(x,y,t),x,y)/u(x,y,t),x$2)+2*diff((u(x,y,t)^2),x,t);
trial_sol:=(x,y,t)->sqrt(r)*tan((-t*v+x+c*y) *abs(sqrt(r)/(sqrt(2*c-2*c*(v^2)))))/(sqrt(2)*sqrt(v));
pdetest(u(x,y,t)=trial_sol(x,y,t),PDE);
Maple says the trial_sol is not a solution for PDE.
But Mathematica says that it is a solution. What is the problem?
I plotted the following tangent function with Maple and Mathematica for t=4.
func:=unapply(-tan((-4*t+x+2*y)/(2*sqrt(15)))/(2*sqrt(2)),x,y,t);
plot3d(func(x,y,4),x=-15..15,y=-15..15);
Maple 3D plot:
Mathematica 3D plot:
I think that Maple shows the asymptotes. Is it possible to close the asymptotes?
I'm french and I'm working on an Imac.
The path for the desktop is  /Users/myname/Desktop.
If cur := "/Users/myname", one can easily verify this:
IsDirectory(cat(cur, "/Desktop"))
In some application I'm developping, I use a  FileDialog Maplet to select a directory where to write a file.
For an unknown reason this maplet doesn't display the desktop with the name Desktop, but with it's french counterpart Bureau.
# Observe thet the desktop (8th line above) is named "Desktop"
# Now run
 maplet := Maplet(
      FileDialog['FD1'](
        'title' = "Output Directory",
        'directory' = cur,
        'fileselectionmode' = directoriesonly,
        'onapprove' = Shutdown(['FD1']),
        'oncancel' = Shutdown()
res := Maplets[Display](maplet):
StringTools:-StringSplit(res[], cur);
                        ["", "/Bureau"]
As a result, saving a file in cur/Bureau generates an error.
Here is a more detailed worksheet:
English_French_confusion.mw
Of course I have adjusted my code in an ad hoc way by french translating  what the maplet returns, but it is just a band-aid on a larger wound. For instance "Downloads" appears as "Téléchargements", and so on, and many names potentially need to be translated.
I do not understand why FileTools seems to "work in english" while  FileDialog seems to "work in french".
I suspect this is due to the fact that my Imac, although natively "English speaking", uses a French overlay.
For instance the  Unix command pwd run in a terminal window indicates Users or Desktop, while  < command + i > executed on a given file displays Utilisateurs and Bureau.
Could it be that FileTools relies upon English, while FileDialog  relies upon the regionalized language?
What do you advice me:
  • to intervene at the Apple level by changing the "user" language my Imac uses,
  • to intervene at the FileDialog  level (if possible),
  • or to keep translating undesired outcomes from FileDialog?
I need to treat Eqs. (1.85-1.86) as a system of equations that should be solved simultaneously, and use numerical solutions in Eqs. (1.87-1.90)
Do you know if there are in-built commands that can do this?
It's ok isolate command? I need the solution sin(a)=+-1/(3^0.5)
attach photo, i need simple step after 2.78 like book, solution is sin(a)=+-1/(3)^0.5.
I try to understand why maple does ot plot the behavior of x^1/3 for negative real number,
inverse_function_xthree.mw
root(x,3) is function defined verywhere, but why maple plot only this function for x positive
thank you
First 437 438 439 440 441 442 443 Last Page 439 of 2432
