 I am new to Maple.  I will appreciate any assistance with a Maple iterative procedure to find the value of s at a given temperature for F(x,r,s, T) = 0 with all other variables fixed.  F is a complicated function.
Is possible to operate Grid Computing Toolbox together with Maple on one local multicore machine?
If yes, what is the proper instalation/configuration procedure on Windows or Linux?
As the title says, I was trying to load a library that is stored in .lib file to use in a maple cloud application. Locally, I think i can get it to work, but I don't know how to use this external file on the cloud itself.
Does anyone know if this is possible?
Is it possible to draw objects in Maple graphically, that are defined by parameters?
Like rectangles with width and height, circles with a radius, triangles, etc.
I want to get data from 2D plots and 3Dplots and want to export to Excel or Matlab.
For  2D plots, the following code works. The data can be exported to Excel. No problem.
P1:=plot(sin(x));
data1:=op([1,1],P1);
ExcelTools:-Export(data1, "C:/Users/student/Desktop/XLdat.csv", "Sheet1", "A1");
ExportMatrix("C:/Users/student/Desktop/XLdat.csv", data1);
1. But the following code doesn' t work for exporting the data to Matlab. Why?
restart: P1:=plot(sin(x));
dataMat:=plottools:-getdata(P1);
dataMat2:=convert(dataMat,Matrix):
ExportMatrix( "test.mat",dataMat2, target=Matlab);
 2. How to write a code in order to get data from the 3D plot and to export to Excel or Matlab?
For example;
z=sin(x)*cos(y);
P2:=plot3d(z);
Maple 2020.2
In Maple, series(f(x), x=x0, order) will produce an expansion where the number of terms is specified by "order". But is it possible to specify the maximum power of (x-x0) that is needed, regardless of the starting order? This is especially a problem if the starting order is negative. To make it worse, in practice the number of terms produced by Maple may not be equal to "order", when nontrivial algebraic cancellations change the exact starting order. Experimenting with different choices of "order" case by case is not practical, when automation is needed for many runs involving different functions. MultiSeries:-series doesn't solve my problem, either.
P.S. MultiSeries:-series is more reliable than series in giving the number of terms specified by the user, but it still breaks down sometimes for complicated problems, for example producing much fewer terms than specified. My main concern, i.e. being able to specifiy an absolute maximium power, is also not addressed by switching from series to MultiSeries:-series.
I am trying to use Grid:-Seq to speed up some calculations.  To this end, I wrote the following procedure:
fun:=proc(model1::list,model2::list,vars::list,conds::set,tlim::numeric)
description "This function returns models with matching structures":
local ans1,ans2,res:=NULL:
if evalb(expand(model1)<>expand(model2)) then
     (ans1,ans2):=UtilsIORelation:-findMatchingStructures(subs(conds,model1),subs(conds,model2),vars,tlim):
     if nops(ans1) > 1 then
        res:=model1:
     end if:
end if:
return(res):
I checked if the procedure works by issuing the following command
aux:=[seq](fun(modelX[i],model,vars,conds,2),i=1..nops(modelX)):
and it did work. The result is what I needed.
But when I try it using Grid:-Seq instead of seq, I got the following error message:
infolevel[Grid:-Seq]:=3:
Grid:-Set(fun,findMatchingStructures,'model','vars','conds');
aux:=[Grid:-Seq](fun(modelX[i],model,vars,conds,2),i=1..nops(modelX)):
Error, (in fun) findMatchingStructures is not a command in the UtilsIORelation package.
What am I missing?
Many thanks
Requesting a code to compute for n>=1 the number of distinct proper divisors of n which properly divide a proper divisor of n.
0,0,0,1,0,1,0,2,1,1,0,3,0,1,1,3,0,2,0,3,1,1,0,5...
example: n=24= 2^3*3
There are 5 proper divisors of 24 having the above property: 1,2,3,4,6, so a(24)=5.
How I can solve following differential equations.?
I want to plot phase diagrams versus time.
diff(xi[i](t), t) versts t (i=1,2,3,4,5,6)
66.mw
Can this equation has four integer solutions?
I am consider the equation a^2*x^2/(x-a)^2+x^2 = m/n and trying to find the integer numbers a, m, n so that the given equation has integer solutions?
Four_integer_solutions.mw
Hello.
I am currently working on a geometric proof, that cutting a cone can give you an ellipse. I have chosen the 'Dandelin spheres' proof, but i am having trouble plotting a hollow cone containing two solid spheres of different sizes.
I thought i could maybe define each function, and then just display th surface area of the revolution of the cone, and the volume of revolution of the spheres in the same plotting table. However, this has proven more difficult than i thought.
f(x):=0.5*x
g(x):=sqrt(0.81-(x-2)^2)
h(x):=sqrt(3.57^2-(x-8)^2)
display([VolumeOfRevolution(f(x), x = 0 .. 10, output = plot, scaling = constrained), VolumeOfRevolution(g(x), x = 0 .. 10, output = plot, scaling = constrained), VolumeOfRevolution(h(x), x = 0 .. 10, output = plot, scaling = constrained)])
(I am aware that i have plotted the cone function (f(x), straight line) as volume and not surface area of revolution)
This does not give me one combined plot, but 3 seperate:(
I hope someone has the time to help!
I'm able to
1) Display a plot using
display(plot(x2, x = 0 .. 10))
2) Modify the created plot using the Context Panel and change the horizontal axis range to -5 to 10
but how can I:
3) Save the modified plot as an expression statement with which I can replace my display expression, in order to save the modified plotting expression before reexecuting the document?
Is it possible to check, if a component - like a combobox - exists?
Why is a row of a matrix has type Matrix, but a column of a Matrix has type Vector (column vector)
I expected a row of a matrix to also be a Vector (row vector).
A:=Matrix([[1,2],[3,4]]);
A(1,..);
whattype(%);
A(..,1);
whattype(%);
This might be by design or documented somewhere. But I find it not consistent.  Either both results should be Matrices, or both should be Vectors (the more logical way).
Maple 2020.2 on windows 10.
I want to write two different numbered lists in the same document like:
  1. Item one list one
  2. Item two list one
And the second list:
  1. Item one list two
  2. Item two list two
The problem is that whenever I use the "Set the paragraph to be a numered list item" button, the item becomes a part of the same list as every other list item in the document. How can i separate two lists?
First 441 442 443 444 445 446 447 Last Page 443 of 2432
