I want to write two different numbered lists in the same document like:
  1. Item one list one
  2. Item two list one
And the second list:
  1. Item one list two
  2. Item two list two
The problem is that whenever I use the "Set the paragraph to be a numered list item" button, the item becomes a part of the same list as every other list item in the document. How can i separate two lists?
how to get a table with Relative Error and Absolute Error in Maple?
I tried in (https://www.maplesoft.com/support/help/Maple/view.aspx?path=Student/NumericalAnalysis/RelativeError) but was unsuccessful.
Ivi
Hi, how to write a loop and solve the algebraic expression? is the loop and do loop are the same thing? if different then pls mention how to solve the same question by using do loop?
solution_loop_help.mw
Suppose that we have a excel file as follows:
We can import the excel file to Maple as follows:
ExcelTools:-Import("C:\\Users\\student\\list.xlsx", "Page1");
  • QUESTION 1: How to filter the cell including ".edu" in the column A and how to print them to column B as follows:
Hi everyone how can I plot like a graphic?
I am having problems with the code I am trying to write in Maple 2020. I have attached the code in this question.
I hope someone can help me out.
Error, invalid input: rhs received 0, which is not valid for its 1st argument, expr
Thanks very much
Download EXAMPLE.mw
Hi, how to find the point where two lines intersect each other by using the command.
Help_point_of_intersection.mw
Hi, pls help me to write a loop for prime number....for n between 1 to 100
help_prime_number.mw
When I typ:
> phi; kappa;
It gives symbols φ and K.
I do not want this, I want the words phi and kappa.
How do I turn this off?
I understand it has something to do with SYMBOL or a Palette?
I see a Palette left named 'Greek' or 'Trigonometric & Hyperbolic' that have phi in them, but how do I delete a Palette (If that is how I stop these symbols)?
I'm not really good with the software, I just use it for some school work.
Thank you in advance for your help!
Hey
Is it possible to draw a slope field for a second order differential equation with initial conditions?
I am asking for your help, as I would like to know if it's possible to integrate a function using SI-units.
This is what I get when I try:
Copied directly:
with(Units[Standard]);
∫10 ⟦m⟧/(⟦s⟧^(2))ⅆ⟦s⟧
Error, invalid differential
                       /      (m)
Typesetting:-mambiguous|int10 ----Typesetting:-mambiguous(
                       |         2
                       \      (s)
  DifferentialD(s), Typesetting:-merror("invalid differential"))|
Why 3D .eps figures produced by Maple 2020 are often excessively large?
So, it´s a little heavy to the viewer and to compile to PDF.
  • How could we reduce the size without losing any quality?
Is the following function w
equal to next functions for a=1 or a= -1?
if a=1 then
w=
if a=-1 then
w=
where n>1, B,c and k are arbitrary constants.
a:=-1:
B:=0:
c:=2:
h:=1:
#assume(n>1):
n:=3:
assume(0<=x and x<h):
assume(0<=t and t<h):
a:=-1:
if is(a>0)=true then
omega:=(x,t)->((2*c*n/(a*(n+1)))*(sin ((x-c*t+B)*sqrt(a)*(n-1)/(2*n)))^2 )^(1/(n-1));
print(omega(x,t));
elif is(a<0)=true then
omega:=(x,t)->(-(2*c*n/(a*(n+1)))*sinh ((x-c*t+B)*sqrt(-a)*(n-1)/(2*n))^2 )^(1/(n-1));
print(omega(x,t));
end if:
plot3d(omega(x,t),x=0..1,t=0..1);
a:=-1:
n:=3:
c:=2:
r:=0:
k_1:=0:
k_2:=0:
h:=1:
n:=3:
if a=1 then
  omega:=(x,t)->piecewise(abs(x-c*t)<=2*n*(k_1-r)*Pi/(k_1*(n-1)),(sqrt(2*c*n/(n+1))*sin ((x-c*t)*(n-1)/(2*n)+r*Pi/k_1))^(2/(n-1)),0);
print(omega(x,t));
elif a=-1 then
  omega:=(x,t)->(sqrt(2*c*n/(n+1))*sinh ((x-c*t)*(n-1)/(2*n)+k_2))^(2/(n-1));
print(omega(x,t));
end if:
Hi I have a transfer function first or second order and I want to get it into standard form
Which the transfer function is
of H(s)/(W__I(s) so how height of a tank (H) is affected by incoming flow rate (W__i(s)) but I need to get this transfer function into standard 1st order form
Where I need to find what K and tau are to get it in to this form and tau is always in the units of time. How can I do this in maple? It's pretty impossible by hand I find. I've attached my workbook for it.
General_form.mw
I am doing some analyses of autonomous DEs (single equation and systems). Maple is able to easily produce 2d- and 3d-phase protraits for systems. However, I am struggling to produce 1d-phase portrait for autonomous first-order DEs. I would like to produce a single axis with some labels and decorations which include the following:
  1. All equilibrium/critical solutions of the DE.
  2. Arrows on the axis indicating if the non-equilibrium solutions are increasing or decreasing in a certain interval.
For example, for dy/dx = -y^2*(5*y-1)^2, would like to produce the plot in the attached file.
How might I achieve this?
1d-phase_portrait.pdf
First 442 443 444 445 446 447 448 Last Page 444 of 2432
