I am trying to calculate a probability density function for the distance between two points inside a unit circle.  I have succeeded with doing this for a few differing applications, but I am stuck on this problem.  I use uniformly distributed polar coordinates to find x and y values for two independent points.  When I ask for the PDF of the distance, I get a FAIL.
I am assuming that such a calculation is possible, I've succeeded with similar problems, but here I am stuck.  I hope my problem is rooted in my lack of knowledge, as opposed to a limitation of Maple.
Here are my Maple statements:
with(Statistics);
th1 := RandomVariable(Uniform(0, 2*Pi));
th2 := RandomVariable(Uniform(0, 2*Pi));
r1 := RandomVariable(Uniform(0, 1));
r2 := RandomVariable(Uniform(0, 1));
x1 := r1*cos(th1);
y1 := r1*sin(th1);
x2 := r2*cos(th2);
y2 := r2*sin(th2);
Dist := sqrt((x1 - x2)^2 + (y1 - y2)^2);
f := simplify(PDF(Dist, t));
Does anyone have any idea as to what I am doing wrong?  Thank you.
_local(gamma)
with(plots)
sol3 := sqrt(2)*sqrt(-tau*gamma)*tanh(x-tau*t^alpha/alpha)*exp(I*gamma*(x+((2*gamma^3*tau-4*gamma*tau+8*tau^2)/(2*gamma^2)-tau*gamma)*t^alpha/((gamma-2*tau)*alpha)))/gamma
lprint(indets(sol3, name))
{alpha, gamma, t, tau, x}
P :=   [ alpha=1, gamma=-2,  tau=3]
[alpha = 1, gamma = -2, tau = 3]
PP := convert(sol3, polar)
polar(2^(1/2)*abs(tau*gamma)^(1/2)*exp(-Im(gamma*(x+((1/2)*(2*gamma^3*tau-4*gamma*tau+8*tau^2)/gamma^2-tau*gamma)*t^alpha/((gamma-2*tau)*alpha))))*abs(tanh(x-tau*t^alpha/alpha)/gamma), argument((-tau*gamma)^(1/2)*tanh(x-tau*t^alpha/alpha)*exp(I*gamma*(x+((1/2)*(2*gamma^3*tau-4*gamma*tau+8*tau^2)/gamma^2-tau*gamma)*t^alpha/((gamma-2*tau)*alpha)))/gamma))
polarplot(sol3, x = -20 .. 20, t = 0 .. 10, axis[radial] = [color = "Blue"])
Download polar.mw
How do I get my actual solution which involves _Z? I have  tried answers that w ere given on questions related to _Z in a solution but mine is not working. I am completely new to Maple ,kindly help me.
eq1 := Lambda[h]+rho[2]*R[h]-(b[h]+kappa+beta[1])*S[h] = 0
eq2 := T[h] = 0
T[h] = 0
eq3 := R[h]-kappa*S[h]/(rho[2]+b[h]) = 0
eq4 := Lambda[m]*L-(alpha+pi)*S[m] = 0
eq5 := c(1-L/K)*S[m]-(d+Lambda[m])*L = 0
sol := solve({eq1, eq2, eq3, eq4, eq5}, [T[h], S[h], R[h], L, S[m]])
[[T[h] = 0, S[h] = Lambda[h]*(rho[2]+b[h])/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), R[h] = kappa*Lambda[h]/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), L = 0, S[m] = 0], [T[h] = 0, S[h] = Lambda[h]*(rho[2]+b[h])/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), R[h] = kappa*Lambda[h]/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), L = (alpha+pi)*RootOf(-c((K*Lambda[m]-_Z*alpha-_Z*pi)/(K*Lambda[m]))*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)/Lambda[m], S[m] = RootOf(-c((K*Lambda[m]-_Z*alpha-_Z*pi)/(K*Lambda[m]))*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)]]
DF := sol[1]
DF2 := sol[2]
[T[h] = 0, S[h] = Lambda[h]*(rho[2]+b[h])/(b[h]^2+(kappa+rho[2]+beta[1])*b[h]+beta[1]*rho[2]), R[h] = kappa*Lambda[h]/(b[h]^2+(kappa+rho[2]+beta[1])*b[h]+beta[1]*rho[2]), L = (alpha+pi)*RootOf(-c((K*Lambda[m]-_Z*alpha-_Z*pi)/(K*Lambda[m]))*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)/Lambda[m], S[m] = RootOf(-c((K*Lambda[m]-_Z*alpha-_Z*pi)/(K*Lambda[m]))*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)]
solve({eq4, eq5}, [L, S[m]], explicit)
[[L = 0, S[m] = 0], [L = (alpha+pi)*RootOf(-c((K*Lambda[m]-_Z*alpha-_Z*pi)/(K*Lambda[m]))*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)/Lambda[m], S[m] = RootOf(-c((K*Lambda[m]-_Z*alpha-_Z*pi)/(K*Lambda[m]))*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)]]
theIndets := indets(indets(sol, atomic))
{K, L, alpha, d, kappa, pi, Lambda[h], Lambda[m], R[h], S[h], S[m], T[h], b[h], beta[1], rho[2]}
allvalues(sol)
[[T[h] = 0, S[h] = Lambda[h]*(rho[2]+b[h])/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), R[h] = kappa*Lambda[h]/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), L = 0, S[m] = 0], [T[h] = 0, S[h] = Lambda[h]*(rho[2]+b[h])/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), R[h] = kappa*Lambda[h]/(kappa*b[h]+b[h]^2+b[h]*beta[1]+b[h]*rho[2]+beta[1]*rho[2]), L = -K*(RootOf(-c(_Z)*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)-1), S[m] = -K*Lambda[m]*(RootOf(-c(_Z)*Lambda[m]+d*alpha+Lambda[m]*alpha+d*pi+Lambda[m]*pi)-1)/(alpha+pi)]]
Download maple_code_for_disease_equilibruim.mw
How i can find parameter after substitution in our pde
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
declare(u(x, t))
declare(f(x, t))
f(x, t)*`will now be displayed as`*f
pde := diff(u(x, t), `$`(x, 3))+6*u(x, t)*(diff(u(x, t), x))+diff(u(x, t), t) = 0
diff(diff(diff(u(x, t), x), x), x)+6*u(x, t)*(diff(u(x, t), x))+diff(u(x, t), t) = 0
map(int, diff(diff(diff(u(x, t), x), x), x)+6*u(x, t)*(diff(u(x, t), x))+diff(u(x, t), t) = 0, x)
3*u(x, t)^2+diff(diff(u(x, t), x), x)+int(diff(u(x, t), t), x) = 0
pde1 := %
Y := u(x, t) = 2*(diff(ln(f(x, t)), `$`(x, 2)))
u(x, t) = 2*(diff(diff(f(x, t), x), x))/f(x, t)-2*(diff(f(x, t), x))^2/f(x, t)^2
L := eval(pde1, Y)
3*(2*(diff(diff(f(x, t), x), x))/f(x, t)-2*(diff(f(x, t), x))^2/f(x, t)^2)^2+2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4-2*(diff(f(x, t), x))*(diff(f(x, t), t))/f(x, t)^2+2*(diff(diff(f(x, t), t), x))/f(x, t) = 0
numer(lhs(3*(2*(diff(diff(f(x, t), x), x))/f(x, t)-2*(diff(f(x, t), x))^2/f(x, t)^2)^2+2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4-2*(diff(f(x, t), x))*(diff(f(x, t), t))/f(x, t)^2+2*(diff(diff(f(x, t), t), x))/f(x, t) = 0))*denom(rhs(3*(2*(diff(diff(f(x, t), x), x))/f(x, t)-2*(diff(f(x, t), x))^2/f(x, t)^2)^2+2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4-2*(diff(f(x, t), x))*(diff(f(x, t), t))/f(x, t)^2+2*(diff(diff(f(x, t), t), x))/f(x, t) = 0)) = numer(rhs(3*(2*(diff(diff(f(x, t), x), x))/f(x, t)-2*(diff(f(x, t), x))^2/f(x, t)^2)^2+2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4-2*(diff(f(x, t), x))*(diff(f(x, t), t))/f(x, t)^2+2*(diff(diff(f(x, t), t), x))/f(x, t) = 0))*denom(lhs(3*(2*(diff(diff(f(x, t), x), x))/f(x, t)-2*(diff(f(x, t), x))^2/f(x, t)^2)^2+2*(diff(diff(diff(diff(f(x, t), x), x), x), x))/f(x, t)-8*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))/f(x, t)^2+24*(diff(diff(f(x, t), x), x))*(diff(f(x, t), x))^2/f(x, t)^3-6*(diff(diff(f(x, t), x), x))^2/f(x, t)^2-12*(diff(f(x, t), x))^4/f(x, t)^4-2*(diff(f(x, t), x))*(diff(f(x, t), t))/f(x, t)^2+2*(diff(diff(f(x, t), t), x))/f(x, t) = 0))
2*f(x, t)^2*(3*(diff(diff(f(x, t), x), x))^2+f(x, t)*(diff(diff(diff(diff(f(x, t), x), x), x), x))+f(x, t)*(diff(diff(f(x, t), t), x))-4*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))-(diff(f(x, t), x))*(diff(f(x, t), t))) = 0
PP := simplify(2*f(x, t)^2*(3*(diff(diff(f(x, t), x), x))^2+f(x, t)*(diff(diff(diff(diff(f(x, t), x), x), x), x))+f(x, t)*(diff(diff(f(x, t), t), x))-4*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))-(diff(f(x, t), x))*(diff(f(x, t), t))) = 0)
%/(2*f(x, t)^2)
3*(diff(diff(f(x, t), x), x))^2+f(x, t)*(diff(diff(diff(diff(f(x, t), x), x), x), x))+f(x, t)*(diff(diff(f(x, t), t), x))-4*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))-(diff(f(x, t), x))*(diff(f(x, t), t)) = 0
collect(%, f)
(diff(diff(diff(diff(f(x, t), x), x), x), x)+diff(diff(f(x, t), t), x))*f(x, t)+3*(diff(diff(f(x, t), x), x))^2-4*(diff(diff(diff(f(x, t), x), x), x))*(diff(f(x, t), x))-(diff(f(x, t), x))*(diff(f(x, t), t)) = 0
pde2 := %
N = 1
N = 1
(14)
S := f(x, t) = a[0]+a[1]*exp(t*n[1]+x*k[1])
(15)
A := eval(pde2, S)
(a[1]*k[1]^4*exp(t*n[1]+x*k[1])+a[1]*n[1]*k[1]*exp(t*n[1]+x*k[1]))*(a[0]+a[1]*exp(t*n[1]+x*k[1]))-a[1]^2*k[1]^4*(exp(t*n[1]+x*k[1]))^2-a[1]^2*k[1]*(exp(t*n[1]+x*k[1]))^2*n[1] = 0
(16)
simplify((a[1]*k[1]^4*exp(t*n[1]+x*k[1])+a[1]*n[1]*k[1]*exp(t*n[1]+x*k[1]))*(a[0]+a[1]*exp(t*n[1]+x*k[1]))-a[1]^2*k[1]^4*(exp(t*n[1]+x*k[1]))^2-a[1]^2*k[1]*(exp(t*n[1]+x*k[1]))^2*n[1] = 0)
a[0]*a[1]*exp(t*n[1]+x*k[1])*k[1]*(k[1]^3+n[1]) = 0
(17)
%/exp(t*n[1]+x*k[1])
(k[1]^3+n[1])*k[1]*a[1]*a[0] = 0
(18)
PPP := %
(19)
Co := solve(PPP, {a[0], a[1], k[1], n[1]})
{a[0] = a[0], a[1] = a[1], k[1] = k[1], n[1] = -k[1]^3}, {a[0] = a[0], a[1] = a[1], k[1] = 0, n[1] = n[1]}, {a[0] = a[0], a[1] = 0, k[1] = k[1], n[1] = n[1]}, {a[0] = 0, a[1] = a[1], k[1] = k[1], n[1] = n[1]}
(20)
case1 := Co[1]
(21)
F := subs(case1, S)
f(x, t) = a[0]+a[1]*exp(-t*k[1]^3+x*k[1])
(22)
F1 := eval(Y, F)
u(x, t) = 2*a[1]*k[1]^2*exp(-t*k[1]^3+x*k[1])/(a[0]+a[1]*exp(-t*k[1]^3+x*k[1]))-2*a[1]^2*k[1]^2*(exp(-t*k[1]^3+x*k[1]))^2/(a[0]+a[1]*exp(-t*k[1]^3+x*k[1]))^2
(23)
pdetest(F1, pde)
N = 2
N = 2
(25)
S2 := f(x, t) = a[0]+a[1]*exp(t*n[1]+x*k[1])+a[2]*exp(t*n[2]+x*k[2])+a[3]*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])
(26)
eq5 := normal(eval(pde2, S2))
exp(t*n[1]+x*k[1])*a[0]*a[1]*k[1]^4-4*exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[1]^3*k[2]+6*exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[1]^2*k[2]^2-4*exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[1]*k[2]^3+exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[1]*n[1]-exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[1]*n[2]-exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[2]*n[1]+exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[2]*n[2]+exp(t*n[1]+x*k[1])*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[1]*a[3]*k[2]*n[2]+exp(t*n[2]+x*k[2])*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[2]*a[3]*k[1]*n[1]+exp(t*n[1]+x*k[1])*a[0]*a[1]*k[1]*n[1]+exp(t*n[2]+x*k[2])*a[0]*a[2]*k[2]^4+exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[1]^4+exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[2]^4+exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[1]^4+exp(t*n[1]+x*k[1])*exp(t*n[2]+x*k[2])*a[1]*a[2]*k[2]^4+exp(t*n[1]+x*k[1])*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[1]*a[3]*k[2]^4+exp(t*n[2]+x*k[2])*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[2]*a[3]*k[1]^4+4*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[1]^3*k[2]+6*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[1]^2*k[2]^2+4*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[1]*k[2]^3+exp(t*n[2]+x*k[2])*a[0]*a[2]*k[2]*n[2]+exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[1]*n[1]+exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[1]*n[2]+exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[2]*n[1]+exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])*a[0]*a[3]*k[2]*n[2] = 0
(27)
indets(eq5)
{t, x, a[0], a[1], a[2], a[3], k[1], k[2], n[1], n[2], exp(t*n[1]+x*k[1]), exp(t*n[2]+x*k[2]), exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])}
(28)
eq6 := eval(eq5, {t*n[1]+x*k[1] = X, t*n[2]+x*k[2] = Y}); indets(eq6)
Error, invalid input: exp expects its 1st argument, x, to be of type algebraic, but received u(x,t) = 2*diff(diff(f(x,t),x),x)/f(x,t)-2*diff(f(x,t),x)^2/f(x,t)^2
{eq6}
(29)
S3 := f(x, t) = a[0]+sum(exp(t*n[i]+x*k[i]), i = 1 .. 3)+a[1]*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])+a[2]*exp(t*n[1]+t*n[3]+x*k[1]+x*k[3])+a[3]*exp(t*n[2]+t*n[3]+x*k[2]+x*k[3])+a[4]*exp(t*n[1]+t*n[2]+t*n[3]+x*k[1]+x*k[2]+x*k[3])
f(x, t) = a[0]+exp(t*n[1]+x*k[1])+exp(t*n[2]+x*k[2])+exp(t*n[3]+x*k[3])+a[1]*exp(t*n[1]+t*n[2]+x*k[1]+x*k[2])+a[2]*exp(t*n[1]+t*n[3]+x*k[1]+x*k[3])+a[3]*exp(t*n[2]+t*n[3]+x*k[2]+x*k[3])+a[4]*exp(t*n[1]+t*n[2]+t*n[3]+x*k[1]+x*k[2]+x*k[3])
(30)
eq5 := normal(eval(pde2, S3))
Download N-soliton.mw
I want to calculate Hodge Star of forms on a solvable Lie algebra L, I have defined a metric tensor g on it. But when I use that g to compute the Hodge Star of an operator it tells me that the g is not a metric tensor.
with(DifferentialGeometry);
with(LieAlgebras);
A := Matrix(4, 4, [[A__11, A__12, A__13, A__14], [A__21, -A__11, A__23, A__24], [-A__24, -A__23, -A__11, A__21], [-A__14, -A__13, A__12, A__11]]);
x := [x__1, x__2, x__3, x__4, x__5, x__6];
StructureEquations := [[x[6], x[1]] = a*x[1], [x[6], x[2]] = add(A[1, i]*x[i + 1], i = 1 .. 4), [x[6], x[3]] = add(A[2, i]*x[i + 1], i = 1 .. 4), [x[6], x[4]] = add(A[3, i]*x[i + 1], i = 1 .. 4), [x[6], x[5]] = add(A[4, i]*x[i + 1], i = 1 .. 4)];
L := LieAlgebraData(StructureEquations, [x[1], x[2], x[3], x[4], x[5], x[6]], Alg1);
DGsetup(L);
with(Tensor);
e := [e1, e2, e3, e4, e5, e6];
theta := [theta1, theta2, theta3, theta4, theta5, theta6];
omega := evalDG(add(theta[i] &wedge theta[7 - i], i = 1 .. 3));
g := evalDG(add(theta[i] &t theta[7 - i], i = 1 .. 3));
HodgeStar(g, theta1)
It is showing the following error,
Error, (in DifferentialGeometry:-Tensor:-HodgeStar) expected 1st argument to be a metric tensor. Received: _DG([["tensor", Alg1, [["cov_bas", "cov_bas"], []]], [`...`]])
How can I correct this? If not is there an alternative of doing what I am trying to do?
I would like to define a binary operator, let's say T, such that `T`(a, b) be displayed a T b.
Is this possible in Maple (preferably 2015 [define doesn't have a 'binary' property], but a solution for any higher version would be welcome)?
Example
`union`(a, b);
`union`(a, b)
alias(`#mo("≅")` = `union`):
`union`(a, b);
`#mo("≅")`(a, b)
# desired:
`#mrow(mo("a"),mo(" "),mo("≅"),mo(" "),mo("b"))`
Download binary_operator.mw
I am trying to find the phase portraits of a dynamical system; couples ODE system but it appears in singular form. How can we remove the singularity of coupled ODE system in P and W depending on \xi, where \alpha is scalar and v is velocity.
How remove quadratic singularity to make this system Hamiltonian in below coupled ODE system in P & W.
 singular_system.mw
with(PDEtools):
alias(P = P(xi), W = W(xi))
P, W
rf1 := diff(P, xi) = W
diff(P, xi) = W
rf2 := diff(W, xi) = (P-(alpha^2+1)*P*W^2)/(v+(1/2*(alpha^2+1))*P^2)
diff(W, xi) = (P-(alpha^2+1)*P*W^2)/(v+(1/2)*(alpha^2+1)*P^2)
Download singular_system.mw
I would like the graph to display the optimal point clearly marked with a red dot. Additionally, the optimal point should be labeled for easy identification. what is the syntax for it.
The  sheet is attached below :
trial_question.mw
ContoursWithLabels(............................, labels = ["delta0", "s2"]);
how to make delta0  and s2 ? and delta should be symbol not word?
in this link   https://maplesoft.com/applications/Preview.aspx?id=123874  there is paper/application
which is supposed to have Maple package called with(PSsolver);
But when downloading the application (by clicking on the download link) and opening it, it only has one file
              an_extension_of_prelle-singer_method_and_maple_implementatio.mws
Where will the package (source code) itself PSolver be?  I can't see any other link in the Maple page above to download additional files which might include the package itself.
The worksheet above says this
Before actualy introducing the ideas concerning our program, let us first load it to the Maple section. (Please, put the library file into directory `c:/DirectoryWhereIputtheLibrary`).
I googled and not able to find it also. This was written almost 24 years ago, so trying to contact the author now might not be good idea.
Should not the Maple application be all self contained with all the files needed to run it?
Any one has copy of this package by any chance?
the most paper use another function to get the result and then do substitute i try to get by the way of them but i fail so how about if we can get the results in direct function there is any way for finding thus parameter after substitution of our function in ode?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
"          with(Student[ODEs][Solve]):"
_local(gamma)
ode := beta*U(xi)^2*c^2+(-alpha*c^2+1)*U(xi)+mu^2*c^2*(diff(diff(U(xi), xi), xi)) = 0
n := 2
F := U(xi) = sum(tanh(xi)^(i-1)*(B[i]*sech(xi)+A[i]*tanh(xi)), i = 1 .. n)+A[0]
U(xi) = B[1]*sech(xi)+A[1]*tanh(xi)+tanh(xi)*(B[2]*sech(xi)+A[2]*tanh(xi))+A[0]
K1 := eval(ode, F)
beta*(B[1]*sech(xi)+A[1]*tanh(xi)+tanh(xi)*(B[2]*sech(xi)+A[2]*tanh(xi))+A[0])^2*c^2+(-alpha*c^2+1)*(B[1]*sech(xi)+A[1]*tanh(xi)+tanh(xi)*(B[2]*sech(xi)+A[2]*tanh(xi))+A[0])+mu^2*c^2*(B[1]*sech(xi)*tanh(xi)^2-B[1]*sech(xi)*(1-tanh(xi)^2)-2*A[1]*tanh(xi)*(1-tanh(xi)^2)-2*tanh(xi)*(1-tanh(xi)^2)*(B[2]*sech(xi)+A[2]*tanh(xi))+2*(1-tanh(xi)^2)*(-sech(xi)*tanh(xi)*B[2]+A[2]*(1-tanh(xi)^2))+tanh(xi)*(sech(xi)*tanh(xi)^2*B[2]-sech(xi)*(1-tanh(xi)^2)*B[2]-2*A[2]*tanh(xi)*(1-tanh(xi)^2))) = 0
solve(identity(K1, {xi}), {A[0], A[1], A[2], B[1], B[2]})
Error, (in unknown) incorrect use of identity(<expr>,<name>)
Download Find_params.mw
Is there any function that returns a boolean value that tells me if a point is within a polygon or not?
I tried to contact an author using the menu item more->contact autor.
I got the following back from postmaster@maplesoft.com
The IP-adress 199.71.183.16 (domain maplesoft.com) does not match the IP-adress of my mailprovider.
The authentification of the mailprovider works when I send directly from this mailprovider to gmail accounts.
Is this a known issue when sending via maplesoft.com or only temporary?
Is gmail too restrictive?
Problem Q15 in the book Parabolic Problems by David Angell and Thomas Britz describes a large circle (LC) and several smaller circles (SCs) which are each tangent to its neighbour SC(s), and externally to LC. All circles are tangent to the x axis and above it.
Section one of this worksheet displays the LC and six of the SCs based on the book's formula for the diameter of the latter in terms of the diameter of the LC and the largest SC, which is determined by the user.
Section two finds and displays that all of the displayed SCs' centers lie on the diameter of a circle closely related to the LC and larger than it.
Can this be proved to be the case for any sizes of the LC and SCs in the same formation as that displayed?
Parabola_Problems_Q15.mw
First 43 44 45 46 47 48 49 Last Page 45 of 2430
