How can I get the follow graph of paraboloidal surfaces (ξ=1,η=2) with the coordinate vectors ξ, η0 , φ0 as shown in the picture.
Realation between cartesian coordinates and paraboloidal :
x=1/2 (ξ2 - η2), y=ξ η cos(φ), z=ξ η sin(φ)
I wrote the following code:
Student:-VectorCalculus
S1 := PositionVector([1/2*(-eta^2 + 1), eta*cos(phi), eta*sin(phi)], cartesian[x, y, z]):
LH := PlotPositionVector(S1, eta = -2 .. 0, phi = 0 .. 2*Pi, coordcurve = [eta = -2, tangent = true, binormal = true, vectornum = 1], scaling = constrained)
S2 := PositionVector([1/2*(xi^2 - 4), 2*xi*cos(phi), 2*xi*sin(phi)], cartesian[x, y, z]):
LG := PlotPositionVector(S2, xi = -1 .. 1, phi = 0 .. 2*Pi, coordcurve = [xi = 1, tangent = true, vectornum = 1], scaling = constrained)
And I got the two paraboloidal surfaces with the vectors separently.How can I get only one graph with these two surfaces as shown in the picture (with ξ=1, η=2) ?
If I have a vector like u:=<-2+m,3+m> and then I put m:=5 (for exemple) when I repeat u it doesnot replace the value of m by 5,
instead repeats the initial expression. I would like to find a way to achieve this in order to automate calculations.
This website suggests that the viewer write equations containing differentials and use them to plot topographical lines.
https://mathcurve.com/courbes3d.gb/topographic/topographic.shtml
I am basically familiar with equations containing derivatives, but not with equations containing differentials.
How can one employ these to draw the lines shown in the website's various plots of surfaces?
S := proc (n) local i; for i to n do if i <= n and type(i, divisors(n)) and type(n/i, odd) then sum(i) end if end do end proc
I solved a simple PDE numerically and found that I couldn't implement a simple thing!
For example:
PDE := diff(u(x,t),t)=1/10*diff(u(x,t),x,x);
IBC := {u(x,0)=1, u(0,t)=0, D[1](u)(1,t)=0};
pds := pdsolve(PDE,IBC,numeric);
p1 := pds:-plot(t=0): p2 := pds:-plot(t=1/10):p3 := pds:-plot(t=1/2):p4 := pds:-plot(t=1):
plots[display]({p1,p2,p3,p4});
I got some spatial dependencies for different fixed t. But I want to get opposite! How to get time dependence for fixed x?
Replacing t with x results in an error.
Update.
This equation is example, really I solve this:
PDE := diff(u(x,t),t)+v*(1+k*sin(2*Pi*f*t))*diff(u(x,t),x)=a*diff(u(x,t),x,x);
IBC := {u(x,0)=T__0,u(0,t)=sin(2*Pi*f*t),u(L,t)=T__0};
So sin makes this equation nonlinear, so I need numerical procedure.
I have the following function:
f:=t->862.979774+1825.011621/([1+1.54943476*e^(-677.0138344*t)]^(131537/203808))
Is there any way Maple can calculate the indefinite integral of f(t)? I have tried integrating f(t) in a range t=tmin..tmax numerically using dsolve/numeric and plotting the numeric integral and I am satisfied with the result, but I would much prefer an analytic integration so that I obtain some function y(t) that I can later use which will be the indefinite integral of f(t).
So far, I have tried unsuccessfully to obtain an indefinite integral of f(t) using int and dsolve. Thanks in advance.
when trying to solve equation using fsolve, it returns just what i wrote and didn't solve. Can anyone help? I tried all i know. File is attached below.
Thanks a lot.
II.01.mw
f:=(x,y)-> x*y^3-x^2/y^3;
eq:= subs([x=alpha*x,y=alpha^p*y],f(x,y));
lis:=[]:
for tmp in op(eq) do
    if has(tmp,alpha) then
       lis:=[op(lis),op(2,simplify(select(has,tmp,alpha)))];
    fi;
od;
lis;
PDEtools:-Solve(lis[1]=lis[2],p)
This method happend to work for this example, but it does not work in general. This is because the function can be anything. Here is a second example
f:=(x,y)-> -2/3*x+1/3*(x^2+3*y)^(1/2);
We see by inspection if p=2 then we can write the above as, by setting p=2 as
But the Maple code I had above does not work on this
lis:=[]:
       lis:=[op(lis),simplify(select(has,tmp,alpha))];
    fi;
od;
lis;
The problem is finding all powers of alpha in each term and setting up an equation to find p such that all terms have same numerical value.
So I abandoned this method as too messy to program (it works well for hand solution, this is an example where solving something by hand is easier than on the computer) and then tried solve directly, like this (on the first example)
eq:= subs([x=alpha*x,y=alpha^p*y],f(x,y))- alpha^r*f(x,y)=0;
And here is where I am stuck. I need to ask Maple if it can find alpha, r that are rational numbers, such that the above equation is solved.
PDEtools:-Solve(eq,[p,r])
But we know from above that p=1/6 and r=3/2 is solution
simplify(subs([p=1/6,r=3/2],eq))
             0=0
The question is: Can Maple solve such an equation for  p,r? I remember now reading something about parameteric solver in Maple. I need to look that up to see if it helps. I tried SolveTools:-SemiAlgebraic on this, but it did not help.
Are there better methods to determine in Maple if function is isobaric and to find the index p and r?
Reference: book
Notice, some places define isobaric function as one in which we can find p such that
But this is not correct. I've seen it on 2 pages on the net. The correct definition is
Also note: When p=1 isobaric function becomes a homogeneous function which is special case of isobaric and r is now called the degree of homogeneity
But for isobaric, p do not have to be 1. This is the main difference.
f(x,y) will always be a function of x,y.  I will add more examples of isobaric functions to test against.
edit. Simplified question is restated below
After looking more into this. I found I actually wanted to solve the simpler problem, which is
So please ignore the general case of isobaric where r<>p-1 which is harder.
I only need to look at this case where r=p-1 which is actually simpler. It turned out this is what I need for my solver and not the general case.
I will now give my solution to this and show where the problem I am having.
I am using Maple solve to find p. So no r any more. Only solving for one variable. But Maple solve fails sometimes. And this is the problem.
The problem is that solve can find p for many cases, but fails on some, where there is clearly a solution. I will show 5 examples below.
#example 1. WORKS
f:=(x,y)-> 3*sqrt(x*y);
eq:= subs([x=alpha*x,y=alpha^p*y],f(x,y))- alpha^(p-1)*f(x,y)=0;
PDEtools:-Solve(eq,p) assuming alpha>0;
#example 2. WORKS
f:=(x,y)-> 4*(x*y)^(1/3);
#example 3. WORKS
f:=(x,y)-> (-3*x^2*y-y^2)/(2*x^3+3*x*y);
#example 4 WORKS
f:=(x,y)-> (-(x*y)/2+sqrt(x^2*y^2-4*y)/2)*y;
And here is the one that does not work
#Example 5. Does not work. How to make it work?
f:=(x,y)-> -2*x/3+sqrt(x^2+3*y)/3;
There is a solution for this. p=2 works. Why solve did not find it? I mean, it gives RootOf, which does not help me decide if this is isobaric or not. Why it did not find the solution p=2?
simplify(subs(p=2,eq)) assuming alpha>0
                 0=0
Using Mathemtica, it found p=2 solution. How to make Maple find this solution is my question.
Sorry for the long question. I first thought I needed the general isobaric case, but found later i needed the simpler one.
Plot the wedge cut from the cylinder x²+y²=1 by the planes z=-y and z=0.
Plot the solid that lies between the cylinder z= y^2 and the xy -plane that is bounded by the planes x = 0, x =1, y = −1, y =1.
I want to solve a simple newsvendor problem for general Demand Probability Distribution with maple code.
let,
Underage cost
                              c[u]
Overage cost
                              c[o]
Demand (
D;
) follows pdf
f(.);
 and CDF
F;
Decision varible is quantity
q;
So cost function is
TC := piecewise(q-D >= 0, c[o]*(q-D), q-D < 0, c[u]*(-q+D));
 piecewise(0 <= q - D, c[o] (q - D), q - D < 0, c[u] (-q + D))
After taking expectation of TC and derivating it w.r.t q we will get
q;
* as critical fractile i.e.
q*= F^(-1) (
                             c[u]
                          c[u] + c[o]
)      i.e. F inverse (
c[u]/(c[u]+c[o]);
Can someone please help me how to find q* in MAPLE using solve() or any other function?
Thanks in Advance!
This might be something basic. But looking at help I do not see it now.
why has(expr,sqrt) do not give true?  is something special about sqrt function?
mysol :=sin(x);
has(mysol,sin); #works
mysol :=ln(x);
has(mysol,ln);  #works
mysol :=sqrt(x);
has(mysol,sqrt);  #does not work
hasfun(mysol,sqrt);  #does not work
Just wondering why, that is all. Only this worked
hastype(mysol,sqrt)
I am sure there is a good reason for this. sqrt seems to be special function.
Maple 2020.2
I'm trying to solve the following ode system:
odes := diff(a0(t), t) - diff(a1(t), t) + diff(a2(t), t) = 0, diff(a0(t), t) - diff(a2(t), t) - 16*a2(t) = 0, diff(b0(t), t) + diff(b1(t), t) + diff(b2(t), t) = 0, diff(b0(t), t) - diff(b2(t), t) - 48*b2(t) = 0, diff(a1(t), t) + 4*diff(a2(t), t) - 3*diff(b1(t), t) + 12*diff(b2(t), t) = 0, diff(a0(t), t) + diff(a1(t), t) + diff(a2(t), t) - diff(b0(t), t) + diff(b1(t), t) - diff(b2(t), t) = 0;
ics := a0(0) - a2(0) = 0, b0(0) - b2(0) = 1, a0(0) - a1(0) + a2(0) = 0, b0(0) + b1(0) + b2(0) = 1, a1(0) + 4*a2(0) - 3*b1(0) + 12*b2(0) = 0, a0(0) + a1(0) + a2(0) - b0(0) + b1(0) - b2(0) = 0;
dsdef := dsolve({ics, odes}, numeric);
There are 6 ordinary differential equations with 6 initial conditions. The functions are named a0(t), a1(t), a2(t), b0(t), b1(t), b2(t).
The question is that Maple solve the system analliticaly (exact dsolve) but when I run the "numerical dsolve" it returns: "Error, (in DEtools/convertsys) invalid specification of initial conditions", and I can't recognize the error/s.
How to show that the function z0(t)=t²+exp(-t)  is solution of z"(t)+2z'(t)+z(t)=2exp(-t); Thank you.
I tried to draw a normal boxplot for the a simple data using Maple. My attempt is in below.
X := [13, 15, 16, 16, 19, 20, 21, 21, 22, 22, 25, 25, 25, 25, 30, 33, 33, 35, 35, 35, 35, 36, 40, 45, 46, 52, 70]:
P1 := Statistics[BoxPlot](X, offset = 1, distance = 1, width = 1, orientation = horizontal, outliers = true);
plots[display](P1, view = [1 .. 80, 0.5 .. 2.5]);
But I am not happy from the result.
  1. It seems the box-plot range doesn't include the max, 70, instead it puts a circle there!
      2. What are the small rectangles and circles? I just need a simple box-plot with the line-range starting from min and ending at max, then a box starting from the first quartile and ending at the third quartile and a vertical line at the median. No extra feature and not ignoring any data.
      3. I don't want the vertical axis which is for the index of the data, I just have one data and that vertical axis is just distracting the audience.
How to resolve these three issues?
First 461 462 463 464 465 466 467 Last Page 463 of 2432
