I would like to solve this equation and keep the parameters a and eta unknown and assign them a value later on. Is it possible ?
I know I can solve this equation numerically, it works, but I want to change the parameters to fit experimental data.
I tried this :
ode:=diff(y(t),t)=-(4/3)*(a/eta)*(y(t)^3+1):
lambdaE:=dsolve({ode,y(0)=1},y(t),explicit);
But the solution appears with RootOf expression and I can't get a numerical solution afterwards.
lambdaE := y(t) = RootOf(6*eta*sqrt(3)*arctan(((2*_Z - 1)*sqrt(3))/3) - eta*sqrt(3)*Pi - 3*eta*ln(_Z^2 - _Z + 1) + 6*eta*ln(_Z + 1) - 6*eta*ln(2) + 24*t*a)
I tried some things from forums but nothing works.
Do you have any leads on how to do it please ?
Thank you in advance
Manon
is there easy way to simulate lines rotation like robotic arm following point P moving by adjusting angle q1 and q2?
i feel point two lines and simulate static two lines in animate is also not easy.
with(geometry):
#Joint at (5,5)
#length a  2, y=7, x, solve(subs(y=7,2^2 = (y-5)^2+(x-5)^2), x)[1];
#length b 2, y=1, x, solve(subs(y=4,2^2 = (y-5)^2+(x-5)^2), x)[1];
point(A, 5, 5), point(B, solve(subs(y=7,2^2 = (y-5)^2+(x-5)^2), x)[1], 7):
point(C, 5, 5), point(D, solve(subs(y=4,2^2 = (y-5)^2+(x-5)^2), x)[1], 4):
line(L1, [A, B]);
line(L2, [C, D]);
_EnvHorizontalName := x;
_EnvVerticalName := y;
Equation(L1);
Equation(L2);
solve(Equation(L1), y);
solve(Equation(L2), y);
plot([solve(Equation(L1), y),solve(Equation(L2), y)], x = 1 .. 2);
animate(plot, [Equation(L1),Equation(L2), x = 0 .. 2], A = -3 .. 3);
Angle Reference from below
angle of L2 , q1a
angle of L1,  q2a
p1 := vector([a*cos(q1), a*sin(q1)]);
P := evalm(p1 + b*vector([cos(q1+q2), sin(q1+q2)]));
Pe := map(expand, P);
A := {cos(q1) = c1, sin(q1) =s1, cos(q2)=c2, sin(q2)=s2};
P := subs(A, op(Pe));
F1 := [x - P[1], y - P[2], s1^2+c1^2-1, s2^2+c2^2-1 ];
F2 := subs({a=1, b=1}, F1);
with(Groebner):
g1 := Basis(F2, plex(c2, s2, c1, s1, y, x));
g1 := [-4*x^2+x^4+2*x^2*y^2+y^4-4*y*x^2*s1-4*y^3*s1+4*s1^2*x^2+4*s1^2*y^2, 2*y*s1+2*x*c1-x^2-y^2, 4*x-x^3-y^2*x+2*y*x*s1-2*y^2*c1-4*s1^2*x+4*y*s1*c1, s1^2+c1^2-1, x*s1-y*c1+s2, -y^2+2-x^2+2*c2];
map(indets, g1);
g2 := Basis(F2, plex(c2, s2, c1, s1));
assume point x = 1, y = 0.5
g2spec := subs({x=1, y=1/2}, [g2[1],g2[3]]);
S1 := [solve(g2spec[1])];
q1a := evalf(arcsin(S1[1]));
q1b := evalf(arcsin(S1[2]));
S2 := [solve(subs(s1=S1[1], g2spec[2])), solve(subs(s1=S1[2], g2spec[2])) ];
q2a := evalf(arcsin(S2[1]));
q2b := evalf(arcsin(S2[2]));
q2a := subs({a=2,b=2}, q2a);
if q2a < 0 then
 q2a_pi := evalf(eval(-q2a-Pi));
 q2a_pi := evalf(eval(Pi-q2a));
end if:
q2a_pi;
q2b := subs({a=2,b=2}, q2b);
if q2b < 0 then
 q2b_pi := evalf(eval(-q2b-Pi));
 q2b_pi := evalf(eval(Pi-q2b));
end if:
q2b_pi;
I've been using Physics:-Latex in my large program, and checking the output visually. I noticed this small issue on one page.
When asking Physics:-Latex to generate Latex for this expression
It gives
While when using standard latex() command, the result is
Below is the worksheet attached. Using Latest Physics and Maple.
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 784 and is the same as the version installed in this computer, created 2020, August 31, 0:51 hours Pacific Time.`
expr:=1/2*int(exp(-t)*f(t),t)*exp(t)-1/2*exp(-t)*int(exp(t)*f(t),t)
(1/2)*(int(exp(-t)*f(t), t))*exp(t)-(1/2)*exp(-t)*(int(exp(t)*f(t), t))
Physics:-Latex(expr)
\frac{\left(\int {\rm e}^{-t} f \left(t \right)d t \right) {\rm e}^{t}}{2}+-\frac{1}{2} {\rm e}^{-t} \left(\int {\rm e}^{t} f \left(t \right)d t \right)
latex(expr)
{\frac {\int \!{{\rm e}^{-t}}f \left( t \right) \,{\rm d}t{{\rm e}^{t}
}}{2}}-{\frac {{{\rm e}^{-t}}\int \!{{\rm e}^{t}}f \left( t \right)
\,{\rm d}t}{2}}
THe latex file used to compile the Maple output Latex using TeXLive distribution on Linux is
\documentclass[12pt]{article}
\usepackage{amsmath}
%\usepackage{maplestd2e} %not needed for this example
\begin{document}
%output of Physics:-Latex()
%output of maple latex()
{\frac {\int \!{{\rm e}^{-t}}f \left( t \right) \,{\rm d}t{{\rm e}^{t}}}{2}}-{\frac {{{\rm e}^{-t}}\int \!{{\rm e}^{t}}f \left( t \right) \,{\rm d}t}{2}}
\end{document}
Download latex_issue_5.mw
Hello everyone, my computer installed Maple 2016, 2020 and set Maple 2016 as default opening files .mw, .mws. How to change default to Maple 2020 . I tried searching on Google but not found.
Thank you very much.
How to calculate the residual sum of squares of a Nonlinear Fitting?
I tried but was unsuccessful.
How I can prove the following equation in red box.
Also, Pn(v) and qn(v) are the real combinations of half-integer Legendre functions.
For more details please see
https://math.stackexchange.com/questions/2746660/potential-flow-around-a-torus-laplace-equation-in-toroidal-coordinates/3809487#3809487
I did already some programmingexercises , but this sort of programming example i did not encounter in the programmingbook
How it is programmed in general lines ?
I do have a lot of small procedures to learn from
But it is too much asked here on the forum to explain all ins and outs for this procedure, because it is not that simple.
Download Basisgrid_procedure.mw
When I'm doing math more complicated, than in the first line, Maple gives the incorrect type of unit.
I want the unit as displayed in the first line, but by using the math/syntax shown in the last line.
Maple does not have "Joule per kilogram times kelvin", as a choosable option when I do the syntax in the last line.
Is there any way I can end up with the correct unit, even tho I am using syntaxes?
In theory, I should end up with the same answer as a result?.
Is it possible to make executed math aka 2D Outputs, automatically align left?
I'm doing it manually for every execution I make. But is there any setting, that does orient the text to the left by standard?
I have intervals A=(-infinity,7), B=(-10,25), and C=(15,infinity). How do I use Maple to perform the union and intersection of such intervals?
I spend all day on this, since some tests I have were failing when I changed to using Physics:-Latex() vs. latex(). I made no change at all in my own code other than to replace latex() by Physics:-Latex().
I am still not sure why that is, but it seems due to symbol clash somewhere.  First time I run my test, it passes, next time if fails. When I change back to latex(), the test passes each time.
This seems to be due to when calling Physics:-Latex() the very first time, it automatically changing diff(y(x),x) to y'(x). May be it is storing its own x in there. (this happens on special input and not for each input, that is why only some tests fail and not all of them).
So next time I call the test it failes. May be due to different x being used. I do not know.
All what I know now is that using latex() makes my dsolve test passes each time.
But here I will show the issue which I think if fixed, should fix the main problem.
Calling Physics:-Latex() causes it to automatically change diff(y(x),x) to y'(x)  even though I am not using Typeseeting at all.
s:= y = u*x:  #special case input which causes the typesetting to kick in
ode:=diff(y(x),x)=1:
print(ode);
Physics:-Latex(s,output = string):
print(ode);
Notice how the derivative changes on its own to using y'(x).  Now compare with latex()
s:= y = u*x:
print(ode);
latex(s,output = string):
print(ode);
So something happens inside Physics:-:Latex which causes this.
For now, I will change back to latex() until I figure more what is going on so that my test do not fail. I like to use Physics:-:Latex as it made the latex look much better.
Maple 2020.1, Physics 778
interface(version)
`The "Physics Updates" version in the MapleCloud is 778 and is the same as the version installed in this computer, created 2020, August 29, 9:34 hours Pacific Time.`
s:= y = u*x:
print(ode);
#latex(s,output = string):
print(ode);
diff(y(x), x) = 1
diff(y(x), x) = 1
Additional observation
This change of typesetting does not happen all the time. For example if s:= y = x: then it works OK. i.e. it does not change typesetting. But if s:= y = u*x: then it changes typesetting. which is very strange why that is.
I stepped into Physics:-Latex using the debugger., The typesetting changes after the call to Physics:-Latex:-Print.
Download latex_issue_2.mw
Determine how many transitive relations there are on a set with n elements for all positive integers n with n<=7.
Custom Palettes and Palette Entries on windows Pro 7
Read a tutorial from a user @les 185
https://www.mapleprimes.com/posts/207781-Custom-Palettes-And-Palette-Entries
Is this still valid this tutorial from 2015  in the current version of Maple ?
This seems to be userunfriendly.
There was a example in clickable calculus video showing 2D math about vectorcalculus and a positionvector fomulaes  noted with dots ( one and two dots)
How do i get this notation and is it usable in Mapleinput  1D ?
First 512 513 514 515 516 517 518 Last Page 514 of 2432
