what is the best way to "extract" a list of terms from a sum of terms.
So something like this::
split_expr(a+b+3) should return [a,b,3]
split_expr(diff(x(t),t)) should return  [ diff(x(t),t)]
split_expr(Int(abc(t), t=2..3) + 3) should return [Int(abc(t), t=2..3) , 3]
I very often have expressions with sums of many terms, and need to run some command on each element (say simplify, or collect, etc)... i've been using convert(expr, list) to split things up, apply a command and recombine, but the convert command breaks on some cases. Maybe this is something that maple can do natively?
thanks!
Example of problematic file:  Model050913.mw
Maple 2020 (either 32- or 64-bit), Maple 2019, and Maple 2017 cannot open a .mw file that I created in 2006.  These Maple versions display this .mw file from 2006 as a garbled mess and cannot work with the garbled mess.  In contrast, Maple 18 opens this file from 2006 without problems.  Did the .mw file format change some time after Maple 18?  Interestingly, Maple 2020 can open a .mw version of the problematic 2006 file that I save with Maple 18.  Can Maple 2020 be updated so that Maple 2020 can open old .mw files (e.g., 2006 and earlier)?  Is the inability of Maple 2020 to open files from 2006 and earlier a bug in Maple 2020?  I can workaround this problem by using Maple 18.  But correcting a bug in Maple 2020 that garbles old .mw files would be helpful.
I am trying to represent a set of data using the errorplot command as follows
plotlims50 := ErrorPlot(xcoords = vectorl, sigmasl50, yerrors = [0.1e-1, 0.4e-1, 0.1e-1, 0.3e-1, 0.3e-1, 0.6e-1, 0.6e-1, 0.1e-1, 0.4e-1, 0.6e-1, 0.5e-1, 0.3e-1, 0.2e-1, 0.2e-1], color = "green")
I guess it's okey, but I would like to have that kind of small lines at the end of the bar and perpendicular to it (like in the image below). Is it possible?
Thank you so much in advance
im solving 2 ODe with boundary conditions.. i got this error Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 10, got 8
with(plots,implicitplot3d);with(plots, display3d);
                        [implicitplot3d]
Error, (in with) package plots does not export display3d
As i understand it correct: there is no display3d command in the plots package to find.
Someone is using this display3d in Maple ,but is doesn't matter , because display and display3d  working both the same
Example :
p1:=implicitplot3d(x^2+y^2-1=0,x=-2..2,y=-2..2,z=-2..2):
p2:=implicitplot3d(y^2+z^2-1=0,x=-2..2,y=-2..2,z=-2..2):
display({p1,p2});
display3d({p1,p2});
or even
display3DA({p1,p2}); gives 2 3d pics ?
Is there a special display3d command in Maple ?, because (one or more)  plot3d plotstructures with display should show all 3d pics in Maple  ?
I'm working on a procedure involving conic equations such as follows...
Conic:=a*x^2+2*h*x*y+b*y^2+2*f*x+2*g*y+c;
and I have a file filled with values in order of the variables I want them assigned to.
e.g 2,-6,3,0,0
I'm only looking for the specific command I need for maple to link the two.
Any help would be greatly apreciated.
from help, it says
The expression assuming property calling sequence evaluates the expression under the assumption property on all names in expression.
Then why
expr := Sum((-1)^n - 1, n = 1 .. infinity):
simplify(op(1,expr)) assuming n::even;
does not simplify expr to zero, while
assume(n::even):
does simplify expr to zero.
I would have expected both to give zero.
If I have a tensor T[mu,nu,alpha] in 3-dimensions which is symmetric on {mu,nu} and anti-symmetric on {nu,alpha}, then the number of independent components should be zero. However, if I put this into Maple, using Library:-MinimizeTensorComponents followed by Library:-NumberOfIndependentTensorComponents it returns 4.
Any insight into why it does this would be great, thanks.
I am trying to customize the Venn Diagram generated by the VennDiagram command in the Statistics package. I would like to be able to shade just any of the regions. For example, if only two sets (A and B) are being displayed, I would like to be able to shade just A, just B, both A and B, or both A and/or B. Also, is it possible to have a rectangle surrounding the circles which represents the universal set? Could the circles be labeled with the letter "A" or "B" to be able to identify each set?
venn.mw
Here is a strange one...
1> /Library/Frameworks/Maple.framework/Versions/2019/bin/maple ; exit;
    |\^/|     Maple 2019 (APPLE UNIVERSAL OSX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2019
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> version();
 User Interface: 1435526
         Kernel: 1435526
        Library: 1435526
                                    1435526
> DE := (28*x + 44)*u(x) + (336*x^2 +
> 726*x - 12)*diff(u(x), x) + (144*x^3 + 396*x^2 - 9*x)*diff(u(x), x, x);
                               2               /d      \
DE := (28 x + 44) u(x) + (336 x  + 726 x - 12) |-- u(x)|
                                               \dx     /
                               / 2      \
             3        2        |d       |
     + (144 x  + 396 x  - 9 x) |--- u(x)|
                               |  2     |
                               \dx      /
> dsolve({DE,u(0)=2},u(x));
memory used=21.5MB, alloc=44.3MB, time=0.37
memory used=53.3MB, alloc=84.3MB, time=0.94
Error, (in dsolve) when calling 'property/ConvertRelation'. Received: 'numeric
exception: division by zero'
Presumably, the solution should be
u0:=2*HeunG((11 - 5*sqrt(5))/(11 + 5*sqrt(5)), 352/(9*(11 + 5*sqrt(5))^3*(-11 + 5*sqrt(5))^2), 1/6, 7/6, 4/3, 1/2, -8*x/(11 + 5*sqrt(5)));
(I get that by replacing coefficient 44 in DE with variable e44, solve, then substitute back e44 = 44.)
But maybe the problem is that this solution turns out to be an algebraic function:
u1:=2^(7/6)/(1 - 22*x + sqrt(-16*x^2 - 44*x + 1))^(1/6);
Dear friends, please I would like to ask for your help with an odd problem I have using the remove command.
I have an array
A:=Array([1,4,1,7]);
and I need to remove its first element A[1].
A:= remove[flatten](x -> x = A[1], A);
Instead of getting the result  A:= [4 1 7] I get  A:=[4 7], and I can't understand why.
Could you please help me with a solution to the problem? Many thanks for the help.
I have been  working on a Maple code written almost 17 years back. The code generates a 3D model input for modelling analysis in ABAQUS software. The input file generated is different from the usual ABAQUS input files. I am seeking help with how to make changes to the input file generated to import into the  ABAQUS. I am uploading the notepad version of the input file as the Maple does not allow .inp files. Please do find the below attachment.
wucell.txt
How can I find the corresponding group for the Lie algebra given in the picture (using Maplesoft software)?
Also, the command Lies Third Theorem works only for Solvable representations. What to for unsolvable representation.
Given two sets of lie algebra data, How to check, using maple software, that these lie algebras are isomorphic?
for example :
The two sets of lie algebras are given as : L1 := [[e1, e4] = e1, [e2, e3] = e1, [e2, e4] = e2]
L2 := [[e1, e2] = e1].
Hi there,
Could you help me with Harley's norm computation algorithm that is based on the Fast Extended Euclidean Algorithm that was suggested by Harley in an email to NMBRTHRY list in 2002 and that described in Vercauteren's thesis pp 87-90:
https://pdfs.semanticscholar.org/c945/c98267db064b272c87a885fc5eeb764b0b2d.pdf
enter image description here enter image description here
My implementation working correctly and fast for low degree polynomials without modulo and for high degree polynomials with modulo M, where M is a prime number greater than 2^N. But all I need - it's a resultant modulo 2^N (or 2^(Nc) due to Vercauteren's Remark 3.10.3) of two large polynomials. So I should include in routine mod 2^N (or mod 2^(Nc)...) instructions to avoid exponential coefficients' growing. But since the 2^N is not prime it's a problem - polynomials contain even coefficients and this leads to some even denominators - and for example multiplicative inverse 1/2 mod 2^N doesn't exist. Please tell me how to solve this problem?
How to adapt XGCD routine for correct mod 2^N calculation of resultant (norm)?
mod prime version of XGCD:
XGCD.mw
First 524 525 526 527 528 529 530 Last Page 526 of 2433
