Dear friends, please I would like to ask for your help with the following problem:
I have a remember table generated by a recursive procedure
x:= proc(n)
option remember;
It helps compute x(1), x(2), x(3), x(4).
After several additional steps I have a new x(2), say
x(2):= 3;
With this new x(2) I need to recompute x(3), x(4). I've tried
forget( x, [ x(3), x(4) ], subfunctions = false );
x(3);
x(4);
However, I do not get the new values of x(3) and x(4) but the old ones. What could it be wrong?
Many thanks for your help.
I have a matrix and all elements has two indexes. For example 3x3 case:
1,1 1,2 1,3
2,1 2,2 2,3
3,1 3,2 3,3
So if I want to travers this matrix in zig-zag way and fill it with increasing numbers I will get this matrix:
1 2 6
3 5 7
4 8 9
From 1 to 2,3 and 4,5,6 ...
We have 9 elemets in this order:
1 - (1,1); 2 - (1,2); 3 - (2,1); 4 - (3,1); 5 - (2,2); 6 - (1,3); 7 - (2,3); 8 - (3,2); 9 - (3,3).
The question is - do we have a way to convert two indexes in one digit like (3,1) -> 4 or (2,3) -> 7
Could you help me please if there is a way to convert to
I am not able to get the proper integration results
Question_integration_eqn18.mw
Dm(A, p, i(t)) := A^gamma*(a-b*p+c*i(t))
Lsc := cl*(int(Dm(A, p, i(t))*(1-1/(1+delta(T-t))), t = t2 .. T))
cl*(int(A^gamma*(a-b*p+c*i(t))*(1-1/(1+delta(T-t))), t = t2 .. T))
simplify(Lsc)
cl*A^gamma*(int((a-b*p+c*i(t))*delta(T-t)/(1+delta(T-t)), t = t2 .. T))
subs(i(t) = (A^gamma*(-b*p+a)*ln(1+delta*(T-t))-R*delta)/delta, Lsc)
cl*(int(A^gamma*(a-b*p+c*(A^gamma*(-b*p+a)*ln(1+delta*(T-t))-R*delta)/delta)*(1-1/(1+delta(T-t))), t = t2 .. T))
simplify(%)
cl*(int(-(-A^(2*gamma)*c*(-b*p+a)*ln(1+delta*(T-t))+A^gamma*delta*(R*c+b*p-a))*delta(T-t)/(1+delta(T-t)), t = t2 .. T))/delta
Download Question_integration_eqn18.mw
So, here again, I'm still having this problem with Maple 2020 on Machbook OS 10.13.6 (all updates have been performed): Maple 2020 does not start. I see an icon appearing in the dock but it then disappears soon without showing anything like splash something. I reinstalled and restarted the copmuter several times, reactivated the software several times (always successful), and still I'm having the problem. I installed java and then it worked for one time, but after that the same problem happens and I'm still having this issue.
I went through steps suggestged in the help and arrived at JAVA reisntallation. What else can I try?
Please help me. Thanks.
Hiro
Suddently Maple 2020 (on Macbook) stops launching... I reinstalled it and restarted a couple of times.
Can someone give me some clues about what is causing this problem.
I really need it right now...
Hiro
doubt_3.mw
Hi, I am trying to do a simple think like
od2 := diff(x^3, x)+v+2 = 0
od3 := diff(v^2, v)+x+4 = 0
solve({(1),(2)},{x,v})
but with my code,  I am doing the exact same but getting the following error
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({list, set})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received {[1316.872428*(-0.1500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+3.000000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-3.000000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(int(.2*(.1*t+1)*i__m2(t), t = 0 .. t__2))/N^.98-11.76000000/(N^.98*((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2))+1185.185185*(-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-6.0000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))/(N^.98*((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2))+6.00*(-75.50000000*N^2.02+45.45000000*N^1.02+306.00*N^0.2e-1)/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)-1.200000000/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)-9.6*(-75.37500000*N^3.02+45.30000000*N^2.02+303.00*N^1.02)/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)] = 0, [-650*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2+65843.62140*N^0.2e-1*(-0.6750000000e-3*t__2^2-0.1350000000e-1*t__2+0.7500000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`-0.9000000000e-1-0.1500000000e-1*t__2*(0.900e-1*t__2+.90)+3.000000*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.900e-1*t__2+.90)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.6914062500e-6*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.6914062500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.1464843750e-7*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.1464843750e-7*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.1064062500e-3*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.1064062500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(int(.2*(.1*t+1)*i__m2(t), t = 0 .. t__2))+65843.62140*N^0.2e-1*(-0.1500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+3.000000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-3.000000)*(-0.5625000000e-3*t__2^2-0.1125000000e-1*t__2+0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`-0.7500000000e-1-0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(int(.2*(.1*t+1)*i__m2(t), t = 0 .. t__2))+13168.72428*N^0.2e-1*(-0.1500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+3.000000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-3.000000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(.1*t__2+1)*i__m2(t__2)+588.0000000*N^0.2e-1*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2+.60*(98765.43210*N^0.2e-1*(-0.5859375000e-5*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.5859375000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.9796875000e-3*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.9796875000e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.900e-1*t__2+.90)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+98765.43210*N^0.2e-1*(-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-6.0000)*(-0.5625000000e-3*t__2^2-0.1125000000e-1*t__2+0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`-0.7500000000e-1-0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+i__m2(t__2))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)-.60*(98765.43210*N^0.2e-1*(-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-6.0000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+int(i__m2(t), t = 0 .. t__2))*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-(0.1500000000e-2*T^2+0.3000000000e-1*T)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-6.00*(-25.00000000*N^3.02+22.50000000*N^2.02+300*N^1.02)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-.1700000000*T*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-2.4*(.1000000000*T-.2000000000)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-4*(0.1562500000e-3*T^2+0.1250000000e-1*T)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-12.0*(0.2500000000e-1*T-.1000000000*N)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2+9.6*(-18.75000000*N^4.02+15.00000000*N^3.02+150*N^2.02)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2] = 0}
Please help
Unfortunately,  Optimization:-Maximize command in following example returns a not precise result (I use Maple 2020).
s1:= Optimization:-Maximize((x-2*y)/(5*x^2-2*x*y+2*y^2), {2*x^2 - y^2 + x*y=1})
Maple is running the following results:
I read help of  Maximize, It seems to be using only numerical methods .
The Minimize and Maximize commands use various methods implemented in a built-in library provided by the Numerical Algorithms Group (NAG).
Can't Maple find a symbolic solution for extreme values under such constrained inequality or equality conditions?
Ps:
For the correct  symbolic  solution, we can try to  use Mathematica 12.
Maximize[{(x - 2*y)/(5*x^2 - 2*x*y + 2*y^2),
  2*x^2 - y^2 + x*y == 1}, {x, y}]
  We can compare numerical sizes of Optimal solution between maple and mathematica.
Digits:=20;
sqrt(2.)/4.
Another Problem:
If I accept numerical solutions of maple ,how do I estimate errors without knowing the exact solution ?
I am trying to compute the rank of the Commutator Matrix of a Lie algebra. That is, I wish to construct a matrix version of the multiplication table for a given matrix Lie algebra, and then compute the rank of this matrix.
Download CommutatorExample.mw
with(DifferentialGeometry); with(LieAlgebras)
M := [Matrix([[1, 0], [0, 0]]), Matrix([[0, 0], [0, 1]]), Matrix([[0, 1], [0, 0]])]
[Matrix(%id = 18446744078224010646), Matrix(%id = 18446744078224010766), Matrix(%id = 18446744078224003190)]
L := LieAlgebraData(M, Alg1)
_DG([["LieAlgebra", Alg1, [3, table( [ ] )]], [[[1, 3, 3], 1], [[2, 3, 3], -1]]])
DGsetup(L)
`Lie algebra: Alg1`
T := MultiplicationTable("LieTable")
Matrix(%id = 18446744078223968366)
I have the above, but I run into two issues:
1. It doesn't have matrix format, so Rank is undefined (I have tried convert(T,matrix) to no avail),
2. I need to be able to remove the first and second rows and columns from T (because these rows/columns are occupied by the Lie algebra's basis elements, and separating lines, respectively).
I believe that if I can convert T into a matrix somehow, I can simply use SubMatrix to remove the things I don't want, and then Rank should work.
Any help would be greatly appreciated!
P.S. Thanks to dharr1338 for the suggestion of including the worksheet, I'm very new to Maple and MaplePrimes, so I appreciate the patience.
Hi, I am working on a bification diagram and was wondering if there is a way to plot the stable and unstable curves onto one figure.
I have two curves, if the eq1<eq2 I would like to indicate when this happens, with a dashed line.
When eq1>eq3 I would like to indicate this with a soild line.
implicitplot, x[m] vs x[u] with axis[2]=[mode=log]
r:=0.927: K:=1.8182*10^8:d[v]:=0.0038:d[u]:=2: delta:=1: p[m]:=2.5: M:=10^4: p[e]:=0.4: d[e]:=0.1: d[t]:=5*10^(-9): omega:=2.042: b:=1000: h[e]:=1000:h[u]:=1:h[v]:=10^4:
eq1 := r*d[t]*h[e]*x[u]^3+(r*h[e]*(-K*d[t]+d[t]*h[v]+d[e])+r*p[e]*x[m])*x[u]^2+(r*h[e]*(-K*d[t]*h[v]-K*d[e]+d[e]*h[v])+K*p[e]*(d[u]-r)*x[m])*x[u]-r*K*h[e]*d[e]*h[v];
eq2 := (d[t]*x[u]+d[e])*(2*r*x[u]/K+d[u]*p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e])*(h[e]+p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e]))))-r)+d[u]*h[e]*x[u]*(p[e]*h[v]*x[m]/(h[v]+x[u])^2-d[t]*p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e])))/(h[e]+p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e])))^2
i have matrix M depend on x1 x2 x3 .... want limit of M. for sure can use loop like M[i,j]:=limit(M[i,j],[x1=0,x2=0,...]; i=1.. j=1..
want use map2 to do all at same time, try map2(limit,[x1=0,x2=0],M); gives error
Error, invalid input: limit expects its 1st argument, expr, to be of type Or(equation, algebraic), but received [x1 = 0, x2 = 0]
is possible to do using map or other thing not loop
Consider the family of functions "{`f__n`   : -infinity< n<infinity}," where the index n is
integer, and f__n; proc (R) options operator, arrow; R end proc.   It is known that diff(f__n(x), x) = `f__n-1`(x) for all n.
I want to convey that information to Maple.  For instance, given the input
diff(f[3](x),x), Maple should return f__2(x).  Similarly:
diff(f[3](x), x$2)                   should return   f__1(x)
f[4](x)*diff(f[3](x),x)^5   should return   f__4(x)*f__2(x)^5
What is a good way of doing that?
I have tried to get a simple matlab example of a fourier transform code to work in Maple. This is just to understand a simple fourier transform and eventually try some more difficult 2D transforms.
with(RandomTools):
with(orthopoly):
with(ArrayTools):
with(DiscreteTransforms):
Digits:=15:
# 1D Fourier Transform
Fs := 1000;                       # Sampling frequency
T := 1/Fs;                        # Sampling period
L := 1500;                        # Length of signal
t := Vector(L, i -> i-1)*T:       # Time vector
f := Fs*Vector(floor(L/2)+1, i-> i-1)/L:   # Frequency
S:= Vector(L, i -> 0.7*sin(2.0*Pi*50*t[i]) + sin(2.0*Pi*120*t[i])):    # Signal
Z1 := FourierTransform(Vector(L, j->S[j])):              # DFT
Z2 := Vector(L, i-> sqrt(Re(Z1[i])**2 + Im(Z1[i])**2)):  # Amplitude
FP1 := pointplot({seq([f[n],Z2[n]],n=1..floor(L/2)+1)}, labels=["Frequency","Amplitude"], connect=true, color=green):
display(FP1, axes=boxed);
The right answer should be a plot with frequencies at 50Hz and 120Hz, with amplitudes at 0.7 and 1.0, respectively. However my amplitude axes is off somehow and I don't understand why.
Could you help me please to plot a fuction with domain and complex range (Maple 2020.1). For example:
f := (x, w) -> exp(w*x*I)
x,w are real numbers
I've just want to use indexes in functions, like this (Maple 2020.1)
f[l,m]:=(x,y)->x^k + y^m
But I can't get the result of it:
f[1,1](2,2)
Maple show me not 4, but the same function.
Hi, am trying to differentiate the following eq w.r.t t2 and N. But in t2 I am getting zero and in wrt N, an Error (non-algebraic expressions cannot be differentiated). But according to the article, I am following expression should come.
I am differentiating following
TCS := proc (N, T, m, n) options operator, arrow; piecewise(M <= t__3 and N <= t__4, TCS__1, M <= t__3 and t__4 < N, TCS__2, t__3 <= M and N <= t__4, TCS__3, `t__3 ` <= M and t__4 < N, TCS__4) end proc
ode5 := diff(proc (N, T, m, n) options operator, arrow; piecewise(M <= t__3 and N <= t__4, TCS__1, M <= t__3 and t__4 < N, TCS__2, t__3 <= M and N <= t__4, TCS__3, `t__3 ` <= M and t__4 < N, TCS__4) end proc, t__2) = 0
ode6 := diff(proc (N, T, m, n) options operator, arrow; piecewise(M <= t__3 and N <= t__4, TCS__1, M <= t__3 and t__4 < N, TCS__2, t__3 <= M and N <= t__4, TCS__3, `t__3 ` <= M and t__4 < N, TCS__4) end proc, N) = 0
Error, non-algebraic expressions cannot be differentiated
following are the pre-requisite to use above (also in the attachment doubt_2.mw)
i__m1(t) = ((-c*t^2*theta__m^2+b*t*theta__m^2+2*c*t*theta__m-b*theta__m+theta__m^2-2*c)*exp(theta__m*t)*a*N^alpha*(lambda-1)/theta__m^3-(-b*theta__m+theta__m^2-2*c)*a*N^alpha*(lambda-1)/theta__m^3)*exp(-theta__m*t)
i__m2(t) = (-(-c*t^2*theta__m^2+b*t*theta__m^2+2*c*t*theta__m-b*theta__m+theta__m^2-2*c)*exp(theta__m*t)*a*N^alpha/theta__m^3+(-c*t__2^2*theta__m^2+b*t__2*theta__m^2+2*c*t__2*theta__m-b*theta__m+theta__m^2-2*c)*exp(theta__m*t__2)*a*N^alpha/theta__m^3)*exp(-theta__m*t)
TC__m := A__m/(t__1+t__2)+(int(h__m*(i__m*t+1)*i__m1(t), t = 0 .. t__1))*(int(h__m*(i__m*t+1)*i__m2(t), t = 0 .. t__2))+P__m*I__om*m*(-(1/3)*a*c*N^alpha*M^3+(1/2)*a*b*N^alpha*M^2+a*N^alpha*M)/(t__1+t__2)+C__m*theta__m*(int(i__m1(t), t = 0 .. t__1)+int(i__m2(t), t = 0 .. t__2))/(t__1+t__2)
i__d(t) = (-(-c*t^2*theta__d^2+b*t*theta__d^2+2*c*t*theta__d-b*theta__d+theta__d^2-2*c)*a*N^alpha*exp(theta__d*t)/theta__d^3+(-c*t__3^2*theta__d^2+b*t__3*theta__d^2+2*c*t__3*theta__d-b*theta__d+theta__d^2-2*c)*a*N^alpha*exp(theta__d*t__3)/theta__d^3)*exp(-theta__d*t)
TC__d1 := A__d*m/(t__1+t__2)+m*(int(h__d*(i__d*t+1)*i__d(t), t = 0 .. t__3))/(t__1+t__2)+P__d*I__OD*m*n*(-(1/3)*a*c*N^alpha*N^3+(1/2)*a*b*N^alpha*N^2+a*N^alpha*N)/(t__1+t__2)+P__m*theta__m*m*(int(i__d(t), t = 0 .. t__3))/(t__1+t__2)+P__m*I__c*m*(int(i__d(t), t = M .. t__3))/(t__1+t__2)-P__d*I__e*m*(-(1/3)*a*c*N^alpha*M^3+(1/2)*a*b*N^alpha*M^2+a*N^alpha*M)/(t__1+t__2)
TC__d2 := A__d*m/(t__1+t__2)+m*(int(h__d*(i__d*t+1)*i__d(t), t = 0 .. t__3))/(t__1+t__2)+P__d*I__OD*m*n*(-(1/3)*a*c*N^alpha*N^3+(1/2)*a*b*N^alpha*N^2+a*N^alpha*N)/(t__1+t__2)+P__m*theta__m*m*(int(i__d(t), t = 0 .. t__3))/(t__1+t__2)-P__d*I__e*m*(-(1/4)*a*c*N^alpha*t__3^4+(1/3)*a*b*N^alpha*t__3^3+(1/2)*a*N^alpha*t__3^2+M-t__3-(1/3)*a*c*N^alpha*t__3^3+(1/2)*a*b*N^alpha*t__3^2+a*N^alpha*t__3)/(t__1+t__2)
i__r(t) = (-(-c*t^2*theta__r^2+b*t*theta__r^2+2*c*t*theta__r-b*theta__r+theta__r^2-2*c)*a*N^alpha*exp(theta__r*t)/theta__r^3+(-c*t__4^2*theta__r^2+b*t__4*theta__r^2+2*c*t__4*theta__r-b*theta__r+theta__r^2-2*c)*a*N^alpha*exp(theta__r*t__4)/theta__r^3)*exp(-theta__r*t)
TC__r1 := A__r*m*n/(t__1+t__2)+m*n*(int(h__r*(i__r*t+1)*i__r(t), t = 0 .. t__4))/(t__1+t__2)+P__d*theta__r*m*n*(int(i__r(t), t = 0 .. t__4))/(t__1+t__2)+P__d*I__c*m*n*(int(i__r(t), t = N .. t__4))/(t__1+t__2)-P__r*I__e*m*n*(-(1/4)*a*c*N^alpha*N^4+(1/3)*a*b*N^alpha*N^3+(1/2)*a*N^alpha*N^2)/(t__1+t__2)
TC__r2 := A__r*m*n/(t__1+t__2)+m*n*(int(h__r*(i__r*t+1)*i__r(t), t = 0 .. t__4))/(t__1+t__2)+P__d*theta__r*m*n*(int(i__r(t), t = 0 .. t__4))/(t__1+t__2)-P__r*I__e*m*n*(-(1/4)*a*c*N^alpha*t__4^4+(1/3)*a*b*N^alpha*t__4^3+(1/2)*a*N^alpha*t__4^2+N-t__4-(1/3)*a*c*N^alpha*t__4^3+(1/2)*a*b*N^alpha*t__4^2+a*N^alpha*t__4)/(t__1+t__2)
TCS__1 := TC__m+TC__d1+TC__r1
TCS__2 := TC__m+TC__d1+TC__r2
TCS__3 := TC__m+TC__d2+TC__r1
TCS__4 := TC__m+TC__d2+TC__r2
First 529 530 531 532 533 534 535 Last Page 531 of 2433
