sqrt(4) gives 2 in CAS systems, since the principal root is returned by default.
Is there an option to have Maple return all roots? Which in this case 2,-2?
I'll explain the context why I need this.
When I solve an ODE, I get a solution that I need to solve for constant of integration C from initial conditions. For an example assume the ODE becomes, after replacing initial condition the following  eq:=4^(1/2) = -2+_C1;
So now when solving for _C1  in maple and then calling simplify, gives one solution which _C1=4 (case root=2) which when replaced back into the general solution gives the particular solution.
But this means the second solution is lost, which is when _C1=0  (case root=-2) which could have been obtained from the non-principal root of 4^(1/2)
eq:=4^(1/2) = -2+_C;
solve(eq,_C);
gives
And I would like to get {4,0} instead.
In practice, this becomes important.
Here is an actual ODE, which should have 2 solutions. Mathematica gives both solutions, and Maple gives one solution.  This is due to the above.
ode:=diff(y(x),x)-y(x)=x*y(x)^(1/2);
ic:=y(0)=4;
dsolve([ode,ic])
In Mathematica
ode=y'[x]-y[x]==x*y[x]^(1/2);
ic={y[0]==4};
sol=DSolve[{ode,ic},y[x],x]
The second solution above came from when constant of integration is zero. The first solution is the one Maple  gave (when expanded).
When I worked the solution by hand, I tracked this to issue with sqrt(4) giving 2 and not +2,-2 when doing solve() to solve for C at the end.
I could ofcourse leave C=sqrt(4)  and not call simplify  on it  and that works.
But I thought to ask here to see if there is some option in Maple, so that when it sees (n)^m to return all m roots when calling solve() and not just the principal one. Even for m=2.
I looked at root and tried allsolutions=true but they did not help. Looked at solve/details and did not spot something. I tried only few of the options there, as there are so many.
Any suggestions what to try?
Suppose that S={u1,u2,u3,u4}⊂ℝ5  where
u1=<
u2=< -163, 171, 218, -92>
u3=< -287, 73, -284, -115>
u4=<-32, 172, 206, -180>
v=< 761, -1381, 7566, 3492>
The vector v  is in the span of S  written in the form
αu1+βu2+γu3+δu4 .
Find a possible set of values for α, β, γ, δ.  Enter the values of α, β, γ, δ  as a sequence in the box below
Suppose that
u1=<388, -635, -480, 554, -288, 732, -118>
u2=< -987, 789, 487, -919, 248, 994, -807>
u3=-316, -470, -522, -769, -159, 629, 806>
u4=<381, 740, -834, 722, -46, 49, 795>
Suppose that Av=(b1  b2  ⋯  b7)^T .
       Enter the value of b1  in the box below.
Can anyone help with this question with a step by step solution. TIA.
I am trying to use this command
plot({0, 2*x^2, 2*x^2 - 2*x^3 + 8/3*x^4 - 4*x^5}, x = -10 .. 10, color = ["DarkGreen", "CornflowerBlue", "Burgundy"])
However, only the last function is showing up. 0 and 2x^2 is not showing up. I can't change the axes sizes because then the last function disappears.
I would like to plot results that combine numerical solutions from odes with polynomials (from a collocation procedure). Here is the part of the worksheet:
What is the best way to plot the approximate solutions here?
Suppose that S={p1, p2, p3, p4},  where
              p1(x)=  71+73x−153x2−259x3−108x4+245x5,
              p2(x)=  37+189x+287x2−167x3+279x4−51x5,
              p3(x)=  -199−200x−62x2+59x3+262x4−70x5,
              p4(x)= 48+295x+18x2+235x3+209x4+279x5,  and
                p(x)= 6143+20711x+8974x2−30368x3+18964x4+17937x5.
To avoid typing errors, you can copy and past the following sequences to your Maple worksheet.
The polynomial p  is a linear combination of S  written in the form
αp1+βp2+γp3+δp4 .
[α,β,γ,δ]=
CAN ANYONE HELP ME WITH THIS QUESTION WITH A STEP BY STEP SOLUTION. TIA.
Suppose that S={u1,u2,u3,u4,u5,u6}⊂ℝ5  where
u1=  <
u2 = <-65, -11, -47, 18, -15>
u3 = <-240, 90, -265, 495, -175:>
u4= <-53, 70, 84, -80, 61>
u5= <9, 0, 46, -55, -37>
u6 =< 176, -280, -520, 540, -96>
Find a possible set of values for λ1, λ2, λ3, λ4, λ5, λ6, not all zero, such that
λ1u1+λ2u2+λ3u3+λ4u4+λ5u5+λ6u6=0 .
Enter the values of  λ1, λ2, λ3, λ4, λ5, λ6  as a sequence in the box below
[λ1, λ2, λ3, λ4, λ5, λ6]=
Hint: There are infinitely many solutions for λ1, λ2, λ3, λ4, λ5, λ6 .   The solution given by Maple will be in terms of parameters. To get one possible set of values, not all zero, choose some nice values for the parameters.
CAN ANYONE HELP ME WITH THIS QUESTION. I DO NOT KNOW HOW TO APPROACH THIS QUESTION. CAN I GET A SETP BY STEP SOLUTION PLS. THANKS.
How  to animate ( with animate command)  this situation for Exporting to GIF  animated file ?
ComplexeExplore.mw
Dear All.
I hope we are all staying safe.
Please I want to solve Sine Gordon Equation using a numerical method I constructed (non-classical), I need to compare the result of the method with the exact solution to generate the errors. However, since the exact solution has two variables, x, and t, I really don't know how to accommodate the two in my coding.
Can someone be of help in this regard?
Thank you and kind regards
Download Discretization_of_Sine_Gordon_Equation.mw
Download Sine_Gordon_Implementation_Trial.mw
How can I use assmptions in partial differential equations?
For example consider the following differential equation
pde:=diff(u(x,t),t)+alpha*diff(u(x,t),x)=0
sol:=pdsolve(pde,build) assuming alpha=0
This gives me the same solution if alpha!=0
I also tried this
assume(alpha=0)
sol=pdsolve(pde,build)
I again got the same result as if alpha!=0. Except this time there was a tilde on the right side of alpha (to my knowledge that means there are assumptions on alpha)
How do you apply assumptions in PDEs?
Could it be correct ?
If L= 1.158R  then half of smallest circle is covered  to proof
I derived a formulue for this in GX
abs(((((((L)^(2)*(-1))+((R)^(2)*4)))^(1/2)*L*(-1/2))+(arctan((((((L)^(2)*(-1))+((R)^(2)*4)))^(1/2)*(L)^((-1))))*(L)^(2))+(arctan((((((L)^(2)*(-1))+((R)^(2)*4)))^(1/2)*(((L)^(2)+((R)^(2)*(-2))))^((-1))*L))*(R)^(2)*(-1))));
abs(-(1/2)*(-L^2+4*R^2)^(1/2)*L+arctan((-L^2+4*R^2)^(1/2)/L)*L^2-arctan((-L^2+4*R^2)^(1/2)*L/(L^2-2*R^2))*R^2)
verg:=%;
subs(R=1,verg);#
abs(-(1/2)*(-L^2+4)^(1/2)*L+arctan((-L^2+4)^(1/2)/L)*L^2-arctan((-L^2+4)^(1/2)*L/(L^2-2)))
verg2:=%
solve(verg2 = Pi,L); # area half small circle with R=1 => 2*Pi* R^2/2 = Pi ,
L must be expressed in R ?
Download de_koe_in_het_weiland.mw
Hi I was wondering if this is allowed and possible, because of the convienience of being able to call it up with the ?[command name] command, it would be an ideal scenario to write extensive notes for procedures and commands I write myself or written by others that are not part of the original maple install, I forget why and how to use alot of the things i write and this would be convienient for me to have quick access to, also to share with others on here or on stack exchange when maple has a stack exchange community.
How find one curve fitting exponential  equation (or any other curve fitting) for the points:
X := [-0.012, -0.010, -0.004, -0.002, -0.001, -0.0001, 0.0001, 0.001, 0.002, 0.004, 0.010, 0.012];
Y := [-0.695, -0.7, -0.74, -0.825, -0.95, -1.0, 1.0, 0.95, 0.825, 0.74, 0.7, 0.695];
I tried, but it wasn't. Look:
f := c + exp(-b*x);
                       f := c + exp(-b x)
Statistics*[NonlinearFit](f, X, Y, x);
Statistics [NonlinearFit(c + exp(-b x), [-0.012, -0.010, -0.004,  -0.002, -0.001, -0.0001, 0.0001, 0.001, 0.002, 0.004, 0.010,
  0.012], [-0.695, -0.7, -0.74, -0.825, -0.95, -1.0, 1.0, 0.95, 0.825, 0.74, 0.7, 0.695], x)]
The Maple not find the curve.
I should get a curve like that (exemple):
I can't understand why select(has,3*C,x) returns 1  and select(has,3+C,x) returns 0
I was expecting to get NULL or {}. But when doing select(has,[3*C],x) and select(has,[3+C],x)  now both return [ ] as expected
Where did 1 and 0 come from in the above examples? I looked at help page, but do not see it.
select(has,3*C,x)
select(has,3+C,x)
or the same:
select(z->has(z,x),3*C);
select(z->has(z,x),3+C)
The select function selects the operands of the expression e which satisfy
the Boolean-valued procedure f, and creates a new object of the same type
as e. Those operands for which f does not return true are discarded in the
newly created object.
The above is the same as if one typed
select(x->false,3+C);
select(x->false,3*C);
I am trying to learn how do somethings without using pattern matching and it is a struggle so far for me.
For an example, now I want to ask Maple to tell me if C[1] (which is a constant) exist in expression, as long as C[1] does not occur as argument to exp(....)
I'll explain why I want to do this and show small example and show how I ended solving it and ask if there is better way.
Given this expression (this can be result of dsolve for example. Made up here)
I just need to determine if the expression has C[1] anywhere, which is NOT an argument to exp(). In the above example, there is one.
The reason I want to find this, is that this is the constant of integration for first order ODE, and I want to repalce exp(C[1]) by constant C[1], but as long as there is no C[1] allready anywhere in expression on its, otherwise I need to introduce new constant C[2], which I do not want to do (since first order, should have only one constant of integration) and in this case will leave the expression as is and not try to simplify it.
But indets tells one that C[1] is there, not where. This is what I tried
expr:=1/exp(z)*arcsinh(x*exp(C[1]))+x*C[1]*sin(exp(x))+3*exp(C[1]*y)*sqrt(sin(exp(3*C[1])));
indets(expr, specfunc(exp));
Now I can find if C[1] is argument to exp(....) from the above or not by more processing. (using applyrule or subsindets, etc...)
But first I still need to to determine if there is C[1] that exist anywhere else, as long it is not inside exp(.....).  If I do
indets(expr, C[1]);
But this does not tell me the information I want. It just says expression has C[1] somewhere.
I looked at evalindets and looked at applyrule and do not see how to use these to do what I want.
Basically I want to tell Maple this
     indets(expr,C[1], conditional( C[1] is not anywhere inside exp(.....) ))
I can solve this using pattern matching. But I fnd Maple pattern matching awkaward to use sometimes and trying to learn how to do things without it.
So this is how I ended solving it. I replace all the C[1] inside exp(....) with ZZZ. Then use indets again to check if C[1] still there or not. This tells me what I want.
new_expr:=subsindets(expr, specfunc(exp), ()-> ZZZ);
if indets(new_expr, C[1])<>{} then
   print("C[1] exist outside exp()");
   print("C[1] does not exist outside exp()");
fi;
And
expr:=1/exp(z)*arcsinh(x*exp(C[1]))+x*sin(exp(x))+3*exp(C[1]*y)*sqrt(sin(exp(3*C[1])));
fi;
is there a better way to do this?
First 540 541 542 543 544 545 546 Last Page 542 of 2433
