I am new to maplesim and trying to learn it.
While simulation of the battery operated 4 wheeled driven electric vehicle
it tells can't find solution.
Same time if i connect a fixed reference all four wheels are running (same place) but not moving since the frame fixed.
HELP ME TO SOLVE THIS.
thank you..
Hi everyone,
I am trying to integrate this function, however, it did not generate any results. Is there any chance to make this run?
I0 := 1/sqrt(1-C2OverC1*cos(t))^3
1/(1-C2OverC1*cos(t))^(3/2)
`assuming`([int(I0, t = 0 .. 2*Pi)], [C2OverC1 > -1, C2OverC1 < 1])
Download ellipticIntegral.mw
Hello all,
Would you please tell me how to rewrite the expression 'Is_square' like 'Is_square2'?
The way how the first expression is re-written is that both numerator and denominator were divided by 'sigma^2*omega[rK]^2':
One attempt I made was to use 'algsub' command using the subexpression ''sigma^2*omega[rK]'', but somehow it missed the term in the denominator.
Is_square := M[dmax]*(sigma^2*omega[rK]^2 + omega[r]^2)*L[sigma]/(3*p*omega[r]*omega[rK]*L[mu]^2*sigma^2);
(1/3)*M[dmax]*(sigma^2*omega[rK]^2+omega[r]^2)*L[sigma]/(p*omega[r]*omega[rK]*L[mu]^2*sigma^2)
Is_square2 := M[dmax]*(1 + omega[r]^2/(sigma^2*omega[rK]^2))*L[sigma]/(3*p*omega[r]*L[mu]^2/omega[rK]);
(1/3)*M[dmax]*(1+omega[r]^2/(sigma^2*omega[rK]^2))*L[sigma]*omega[rK]/(p*omega[r]*L[mu]^2)
algsubs(omega[rK]*sigma^2=tt, Is_square);
(1/3)*M[dmax]*L[sigma]*(tt*omega[rK]+omega[r]^2)/(p*omega[r]*L[mu]^2*omega[rK]*sigma^2)
Download Qprime_20200621.mw
Suppose I have
with(GraphTheory):
vertices:=["M","P","C"]:
edge_weights:={[{"M","P"},3],[{"M","C"},1]}:
G1:=Graph(vertices,edge_weights)
EigenvectorCentrality(G1)
Is it right to say the EigenvalueCentrality values correspond to the names in the vertices correspondingly?  ie M corresponds to 0.4415.. P corresponds to  0.4188.. and C corresponds to 0.1396... ?
sub:=x/C;
expr:=1/2*x*(p^2+a)/p;
And now
subs(p = sub, expr)
But
algsubs(p = sub,expr)
Notice one "p" is still not replaced.
This is very annoying. I looked at help and did not see anything about this. I could have missed it. It looks like it does not replace "p" when it is in denominator:
algsubs(p = x,1/p)
Remains 1/p but
subs(p = x,1/p)
gives 1/x as expected.
May be this is documented somewhere? But why it does this?
This was generated when running some code on Maple 2020.1.
Just wondering if this might indicate some problem internally, or is this something that can happen.
ZZ:=Int(-(a*_a^2+(_a^4*a^2-4*_a*b*y(x))^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*b*y(x))^(1/2)+6*y(x)),_a = _b .. x)+Intat(-2/(a*x^3+x*(a^2*x^4-4*_f*b*x)^(1/2)+6*_f)-Int(2/(_a^4*a^2-4*_a*_f*b)^(1/2)*b*_a/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)+(a*_a^2+(_a^4*a^2-4*_a*_f*b)^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)^2*(-2*_a^2/(_a^4*a^2-4*_a*_f*b)^(1/2)*b+6),_a = _b .. x),_f = y(x))+_C1 = 0;
timelimit(30,value(ZZ))
Error, (in discont/zero) too many levels of recursion
The problem is that I am not able to trap the error. This does not work
try
timelimit(30,value(ZZ));
catch:
  print("ignore");
end try;
Why can't one catch this error inside try/catch? It means the whole program can not  continue.
Maple 2020.1
Update Jan 9, 2025
This bug is still in Maple 2024.2. Will check again in 5 years. May be someone in Maplesoft will fix it by then.
Int(-(a*_a^2+(_a^4*a^2-4*_a*b*y(x))^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*b*y(x))^(1/2)+6*y(x)), _a = _b .. x)+Intat(-2/(a*x^3+x*(a^2*x^4-4*_f*b*x)^(1/2)+6*_f)-(Int(2*b*_a/((_a^4*a^2-4*_a*_f*b)^(1/2)*(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f))+(a*_a^2+(_a^4*a^2-4*_a*_f*b)^(1/2))*(-2*_a^2*b/(_a^4*a^2-4*_a*_f*b)^(1/2)+6)/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)^2, _a = _b .. x)), _f = y(x))+_C1 = 0
Download not_fixed_jan_9_2025.mw
 by using its expansion Write the Maple  program.
Type the Maple command string that calculates this expression for the number of n arbitrarily entered from the keyboard.Can you help me please ?
  1. a1 = x and for every n >= 1 ,
write the Maple procedure that calculates the term a100 for x = 2.
 Write the Maple program that finds the differential equation that accepts the solution. (c1, c2, c3 are arbitrary constants.)
After
 > save mytable, "foo.m";
in whitch folder may I find the file "foo.m" ?
I try with the function "search" of Windows 10, but it can't find it.
Thanks for a answer.
Serge
Hello all,
Is there any way to avoid the 'Error, recursive assignment' in the expressions below?
The 's' at the LHS of ':=' is different from the 's' in 'omega[s]' or 'omega['s']'.
s NULL:= omega[sl]/omega[s];
s ``:= omega[sl]/omega['s'];
Download Q_20200621.mw
I try to figure out how to add »kr« as a currency symbol, and as currency in the Numeric Formatting list.
Can it be done?
Kind regards
I hvae Maple 2020 installed on Linux Ubuntu, and there is a foler maple2020. Could anyone help me with, where is the user initialization file,  .mapleinit, in Maple Linux, or how to creat an  .mapleinit file?
Many Thanks.
This works
patmatch(3*g(x),A::nonunit(algebraic)*B::function,'la');
la
[A = 3, B = g(x)]
But this fails
patmatch(3*g(x),conditional(A::nonunit(algebraic)*B::function, true ),'la');
Error, (in PatternMatching:-AlgStruct:-Match) improper op or subscript selector
I am not able to see why. In the above I used true for the condition, just to keep things simple. Any boolean valued expression will work.
changing the above to
patmatch(3*g(x),conditional(A::anything*B::function, true ),'la');
it works. No error. [A = 3, B = g(x)]
What did I do wrong in the above syntax which generated the error?
Maple 2020.1
First 543 544 545 546 547 548 549 Last Page 545 of 2433
