 Dear Maple community,
I am struggling with the numerical solution of the complex (linear) partial differential equation to obtain results. For example, I see such as this statement "Error, (in pdsolve/numeric/plot) unable to compute solution for t<HFloat(0.0): signum is not differentiable at complex values" pops up. I did my homework but I didn't get anything. I will be happy if someone could give me some suggestions or advice. Thank you in advance.
Hi, need help with ploting task. Could someone help with this?
Task:
The svg generated by Export, for example,
svg_code := Export(plot(x), target = direct, format = "svg");
is broken (the svg generated is invalid).
Is there a fix for this issue?
If there is no fix, is there a way to output (to be assigned to a variable) a text (ascii) containing base64 encorded png of a plot.
Hello, so my maple won't solve any function involving either cos, tan or sin. Has anyone experienced this before or know how to fix it?
For example i need to find: cos(30), but it comes up as cos(30) after I hit enter.
Many thanks to anyone who tries to help! :)
Hi, I have a problem with solution task. Why eq2 doesn't accept value of x1?
P := 12; M := 6; q := 2; BC := 2; Q := q*BC; CN := (1/2)*BC; NB := CN; AK := 1; KC := AK*evalf(cot((1/6)*Pi)); KN := KC+CN; BK := NB+KN;
                            P := 12
                             M := 6
                             q := 2
                            BC := 2
                             Q := 4
                            CN := 1
                            NB := 1
                            AK := 1
                       KC := 1.732050808
                       KN := 2.732050808
                       BK := 3.732050808
eq1 := x1 = (P*evalf(cos((1/6)*Pi))-Q*sin((1/6)*Pi))/sin((1/6)*Pi);
                    eq1 := x1 = 16.78460970
eq2 := x2 = AK*P+BK*x1+KN*Q+M;
            eq2 := x2 = 3.732050808 x1 + 28.92820323
solve({eq1, eq2}, {x1, x2});
              {x1 = 16.78460970, x2 = 91.56921942}
NULL;
B := vector(2, [(P*evalf(cos((1/6)*Pi))-Q*sin((1/6)*Pi))/sin((1/6)*Pi), AK*P+BK*x1+KN*Q+M]);
        B := [16.78460970, 3.732050808 x1 + 28.92820323]
A := matrix(2, 2, [[1, 0], [0, 1]]);
                               [1  0]
                          A := [    ]
                               [0  1]
C := evalm(1/A);
                               [1  0]
                          C := [    ]
                               [0  1]
x := evalm(`&*`(C, B));
        x := [16.78460970, 3.732050808 x1 + 28.92820323]
Hello everyone. does anyone please correct my worksheet? I
E := 1/e^5
S := 1/e^5
f := proc (x) options operator, arrow; x^2-2 end proc
a := 1
b := 2
"while b-a>=S or (abs(f(a))>=E and abs(abs(f(b))>=E)        "
Error, unable to match delimiters
"while b-a>=S or (abs(f(a))>=E and abs(abs(f(b))>=E)"
"do"
Error, unable to parse
"do"
"if (f(x[a])-f(x[b])=0)"
Error, invalid 'if' statement
print(Method*fail)
Method*fail
break
Error, break or next not in loop
"fi;"
"fi;"
c := b-f(b)*(b-a)/(f(b)-f(a))
4/3
"if f(c)<E then"
Error, unterminated 'if' statement
"if f(c)<E then"
break
"elif f(a) f(c)<0 then"
b := c
4/3
"else"
"else"
a := c
4/3
"end if;"
"end if;"
"end do;"
"end do;"
[a, b]
[4/3, 4/3]
abs(f(a))
2/9
abs(f(b))
2/9
Download Method.mw
am trying to solve but could not get the required answer
how I can I get MAPLe to simplify this to Pi/2-beta ,
simplify(arctan(sin(beta)/cos(beta)),arctrig) assuming beta<Pi/2,beta>0;
simplify(arctan(sin(beta)/cos(beta)),symbolic) assuming beta<Pi/2,beta>0;
why i can't get Pi/2-beta
https://www.mapleprimes.com/questions/219048-Help-File-Edit-After-Storing-In-A-Database
I found a previous post which contained a worksheet script for creating help, but this example is likely out-of-date. Can anyone provide a similar example for post-2018 help files to save me considerable trial and error.
I want to open an external *.XML file and put this information in a list (every part is a row). Later, i will change a specific row with other text. Finally, I want to copy all this changes in the same file (rewrite the file).
Someone to help me?
> den := -(-(conjugate(chi)-conjugate(phi))*(chi+phi)*conjugate(lambda)+lambda*(conjugate(chi)+conjugate(phi))*(chi-phi))*(-(conjugate(chi)+conjugate(phi))*(chi-phi)*conjugate(lambda)+lambda*(conjugate(chi)-conjugate(phi))*(chi+phi));
> phi:=exp(I*lambda*(x-t/(4*lambda^2)-w^2)):chi:=exp(-I*lambda*(x-t/(4*lambda^2)-w^2)):
> den1:=simplify(dsubs({phi,chi},den));
> dsubs({exp((1/4*I)*(4*lambda^2*w^2-4*lambda^2*x+t)/lambda), exp(-(1/4*I)*(4*lambda^2*w^2-4*lambda^2*x+t)/lambda)}, 4*conjugate(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2-4*conjugate(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+8*abs(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2+8*abs(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+4*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda^2-4*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda^2-16*abs(lambda)^2)
Since "cos(...)" appears in every term in last equation (except a last one), how to common it?
The  galois routine returns the group of  polynomials within quotation marks, e.g.  "6T1".
How to convert  things like  "6T1"  into just   6T1, i.e. how to get rid of the quotation symbols?
with(PDEtools):
alias(f=f(x,t),g=g(x,t));
f, g
eq1:=diff(f,x)=-I*eta*f +I*exp(-I*t)*g;
diff(f, x) = -I*eta*f+I*exp(-I*t)*g
eq2:=diff(g,x)=-I*eta*g +I*exp(I*t)*f;
diff(g, x) = -I*eta*g+I*exp(I*t)*f
eq3:=diff(f,t)=(I*eta^2-I/2)*f +I*eta*exp(-I*t)*g;
diff(f, t) = (I*eta^2-(1/2)*I)*f+I*eta*exp(-I*t)*g
eq4:=diff(g,t)=(-I*eta^2+I/2)*g +I*eta*exp(I*t)*f;
diff(g, t) = (-I*eta^2+(1/2)*I)*g+I*eta*exp(I*t)*f
#### The solution of (2)-(5) is
eq5:=f=I*(c1*exp(A)-c2*exp(-A))*exp(-i*t/2);
f = I*(exp(A)*c1-c2*exp(-A))*exp(-(1/2)*i*t)
eq6:=g=(c2*exp(A)-c1*exp(-A))*exp(i*t/2);
g = (c2*exp(A)-c1*exp(-A))*exp((1/2)*i*t)
#### where
c1=sqrt(h-sqrt(h^2-1))/sqrt(h^2-1);c2=sqrt(h+sqrt(h^2-1))/sqrt(h^2-1);A=sqrt(h^2-1)*(x+I*h*t);
c1 = (h-(h^2-1)^(1/2))^(1/2)/(h^2-1)^(1/2)
c2 = (h+(h^2-1)^(1/2))^(1/2)/(h^2-1)^(1/2)
A = (h^2-1)^(1/2)*(x+I*h*t)
#### How to verify (6) and (7) is the solution of (2)-(5)?
Download verification.mw
I'm trying to document some generator calculations that use terms line Xd'. In Maple that turns into a derivative. I converted several 'ed variables into atomic variables. They have made my work sheet unusable. They appear to randomly loose connecin to their assigned values and prevent numeric solutions by showing  up in symbolic form. Once this happens, I have to check each instance where the variable isuse to find where the loss/lossses occured. (copy and past each instance of the variable and check its value).
Once found I can't find a consistant way to re-associate them with the assigned value.
Any suggestions. See botton of attaced work sheet.
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/WS_Gen_I_and_E_for_fauls_on_HS_of_GSU_-_Time_Response_&_51V_Trip_Times_-R5a.mw .
Download WS_Gen_I_and_E_for_fauls_on_HS_of_GSU_-_Time_Response_&_51V_Trip_Times_-R5a.mw
How to define 4 functions from the dsolve solution of a system of 4 differential equations?
restart: with(plots): with(DEtools):with(LinearAlgebra):with(Statistics):with(CurveFitting):with(Optimization):
ddesys := {diff(S(t),t) = -beta*S(t)*Ix(t)/N,
diff(Ex(t),t) = beta*S(t)*Ix(t)/N - sigma*Ex(t-tau__1),
diff(Ix(t), t) = sigma*Ex(t - tau__1)- gamma*Ix(t-tau__2),
diff(R(t),t) = gamma*Ix(t-tau__2),
diff(Dx(t),t) = delta*Ix(t),
S(0) = 80900, Ex(0) = 1, Ix(0) = 1, R(0) = 0, Dx(0) = 0 }:
dsn := dsolve(eval(ddesys, {beta = 4, gamma = 0.0478, sigma = 0.10, delta = 0.0005, N=80900, tau__1 = 1.1,tau__2 = 8.7,tau__3 = 0}), numeric):
Please can you give me a hand with numerical solving and visualising the partial differential wave equation with stochastic term eta(t), using methods of stochastic calculus?
diff(u(x, t), t $ 2) - (1+eta(t))*diff(u(x, t), x $ 2) = 0
I had a look at the "stochastic" package by Sasha Cyganowski, but couldn't find an example for stochastic pde.
Look forward to your help.
Dmitrii
First 557 558 559 560 561 562 563 Last Page 559 of 2433
