I have noticed that fieldplot3d can fail when calling a procedure that contains if statements.  It appears that fieldplot3d is attempting to evaluate the statements within the procedure, instead of simply calling the procedure with numerical values.
We are still on lockdown in the UK, and this has kept me amused for a while now.  But I have run out of ideas and could really use some help!
fieldplot3d_and_if_statements.mw
kernelopts(version);
`Maple 2020.0, X86 64 LINUX, Mar 4 2020, Build ID 1455132`
convert([1,2,3], Vector[row]);
Vector[row](3, {(1) = 1, (2) = 2, (3) = 3})
convert([1,2,3], Vector[col]);
This worksheet shows an unexpected behavior of pdsolve().  It solves the heat equation on the interval (−1,1) but fails on the interval (0,1).  I see no technical reason for this happening — it's probably due to a little bug lurking somewhere.
`The "Physics Updates" package is not installed`
Solve the heat equation on the interval -1 < x and x < 1 and
boundary conditions u(-1, t) = 0, u(1, t) = 0.
pde := diff(u(x,t),t) = diff(u(x,t),x,x);
diff(u(x, t), t) = diff(diff(u(x, t), x), x)
bc := u(-1,t)=0, u(1,t)=0;
ic := u(x,0) = cos(Pi/2*x);
u(x, 0) = cos((1/2)*Pi*x)
pdsol := expand(pdsolve({pde,bc,ic}));
u(x, t) = cos((1/2)*Pi*x)*exp(-(1/4)*t*Pi^2)
That's good.  Apply pdetest to verify it:
pdetest(pdsol, [pde,bc,ic]);
[0, 0, 0, 0]
Now, solve the same problem on the interval 0 < x and x < 1 and
boundary condition u__x(0, t) = 0 and u(1, t) = 0.  It should be
evident that the solution remains the same as the one calculated
above, due to symmetry, and here is the verification:
bc_new := D[1](u)(0,t)=0, u(1,t)=0;
(D[1](u))(0, t) = 0, u(1, t) = 0
pdetest(pdsol, [pde,bc_new,ic]);
[0, 0, 0, 0]
But for some reason Maple's pdsolve fails to solve the PDE.  Actually
its response is somewhat erratic -- sometimes it returns nothing at all,
and sometimes it exits with an error message.
pdsolve({pde,bc_new,ic});
Download pdsolve-fails.mw
I need to solve general linear programming problem with multi-precision support. What are my options with Maple 2020?
This is a sawtooth GIF from the wikipage Sawtooth wave
I want to recreate this animation in Maple. Could someone help me out with the formula to create this
What have I done!
Whatever I have created - Maple doesn't think it is a list.
The question is - what is it then?
proclist.mw
I'm trying to obtain the dynamical response of a simply-supported beam with a cantilever extension, coupled to a spring-mass system. In mathematical terms, this system is ruled by three PDEs (relative to each bare part of the main structure) and one ODE (relative to the spring-mass system). I think my mathemical model is finely formulated, but Maple keeps telling me this:
Error, (in pdsolve/numeric/process_IBCs) improper op or subscript selector
I believe it is because my PDEs depend on "x" and "t", while the ODE depends solely on "t". I have tried to transform my ODE into a "PDE", making it also dependent of "x", but without imposing any boundary conditions relative to "x". However, after this Maple points a new error message:
Error, (in pdsolve/numeric) initial/boundary conditions must be defined at one or two points for each independent variable
Could someone help me finding a solution? My algorythm in shown in the attached file below.
Worksheet.mw
I'm trying to plot this integral but without success. Could someone help me?  I tried it the following way.
Thanks in advance for any help!
integral_test.mw
Hello everyone, we are doing some excercises on graphs. The commands PetersenGraph and GeneralisedPetersenGraph only draw an indirected one, and i was wondering, is there a way to draw a directed Petersen graph?
Here's a very simple example, working as intended:
Now, if I try to use the exception indexing function:
We can notice that b[1] isn't using exception anymore (as if the fourth input overwrote the second one) and that b[1][2] isn't linked to the value "two". However, if I define the tables first, I get the expected result:
Why does the exception indexing function prevent me from getting an existing table entry in the second case?
how to generate a graph of ellipsoid from ellipse equation ( revolution x axis or y axis) ?
QEllipsoide.mw
Hi Guys,
I am trying to intgrate a function involving hyperbolic functions in a range of 0 to 1 and it is giving me very large value of 10^94. However, on doing integration terms terms i can see that some large terms involving 10^191 cancel out with each other and I can have a fnite value of this integration. It would be really helpful if someone can help me out why it is happening with int function and how can I solve this case involving hyperbolic function. For reference maple file is attached. Thanks in advance and much appreciated.
With Regards
Sunit
question.mw
I've drawn shape with the Graph function and all the lines are drawn as the same length even though the shape is weighted and when I do the WeightMatrix function I get the right weights.  What do I need to do to have the lines drawn to the correct length?
THE ISSUE: It's returning a list of [1] when it should be returning [1,1,1,7]
##Find remainder##
rm := proc(a, b) local n; n := 0; while 0 <= b - n*a do n := n + 1; end do; b - (n - 1)*a; end proc;
rm := proc (a, b) local n; n := 0; while 0 <= b-n*a do n := n+1
   end do; b-(n-1)*a end proc
rm(8, 3657);
rm(16, 12345);
                               9
##FINDING THE WHOLE NUMBER PORTION ##
whole := proc(a, b) local r, i; r := 0; i := 0; if a < b then r := rm(a, b); i := (b - r)/a; else 0; end if; end proc;
whole := proc (a, b) local r, i; r := 0; i := 0; if a < b then
   r := rm(a, b); i := (b-r)/a else 0 end if end proc
whole(8, 3657);
                              457
whole(16, 12345);
                              771
j = whole(8, 3657);
                            j = 457
k = rm(8, 3657);
                             k = 1
L := [];
                            L := []
L := [op(L), rm(8, 8657)];
                            L := [1]
j = whole(8, 457);
                             j = 57
##GETTING THE LIST OF DIGITS (BEFORE REVERSING)##
HELPER := proc(a, b, L) local j; j := whole(a, b); [op(L), rm(a, b)]; if 0 < j then HELPER(a, j, L); else ; end if; L; end proc;
HELPER := proc (a, b, L) local j; j := whole(a, b); [op(L),
   rm(a, b)]; if 0 < j then HELPER(a, j, L) else  end if; L end
   proc
CNS := proc(a, b) HELPER(a, b, L); end proc;
          CNS := proc (a, b) HELPER(a, b, L) end proc
CNS(8, 3657);
                              [1]
HELPER(8, 3657, L);
                              [1]
First 562 563 564 565 566 567 568 Last Page 564 of 2433
