with(ExcelTools):
Export(R,"𝙴𝚖𝚙𝚕𝚘𝚢𝚎𝚎𝚜.𝚡𝚕𝚜","𝙿𝚊𝚢𝚛𝚘𝚕𝚕","𝙱𝟸")
how to make the export excel file take his name from variable ?
for example
V:=800;
so the export file will make name as 800 , and so on |?
How to use for loop inside unapply operator
test.mw
I am not sure why I cannot do: plot3d([f(x,y,'g(x, y)')], x=0..1,y=0..1).
And the use of single quote in Maple 2019 and 2017 are giving different results. that is, the plot (note, not plot3d) results in the attched script by Maple 2017 and 2019 are different...
I want to know whether sqp method do a local search or a global search. Thank you.
I found that i can use  simplify under assumption to gain the result :
simplify((-p^3)^(1/3), assume = negative);
                               -p
simplify((p^3)^(1/3), assume = positive);
                               p
But confusing ! I expected the simplify command just with the option=symbolic works at the same manner ?
My purpose :
simplify((-p^7)^(1/7), assume = negative);
-p
simplify((p^7)^(1/7), assume = positive);
p
Without negative sign the simple symbolic result appears :
simplify((p^3)^(1/3), symbolic);
p
In power 3 the Imaginary part is included too !
simplify(((-p)^3)^(1/3), symbolic);
(1/2)*p*(I*3^(1/2)+1)
NOT WORKING !
simplify((p^7)^(1/7), symbolic);
p
simplify((-p^7)^(1/7), symbolic);
p*(-1)^(1/7)
simplify((-p^7)^(1/7), symbolic, radical);
(-p^7)^(1/7)
Download odd_negative_powers.mwodd_negative_powers.mw
I create a lot of procs and functions and then find myself having to create sequences of their values. I use for loops, seq or create a new proc to do it.
e.g., suppose I have a proc like f := n->n^2 or whatever. I can do [seq(f(k),k=0..5)]. Is there a very simple notation that maple has to do the same? E.g., hypopthetically f($$0..5) and it handles the accumulation in to a sequence itself
e.g., I have an equation that is written like a/b*c and maple rewrites it as a*c/b.
c is a complicated expression and when it's written with b under it, it takes up far more vertical spaces than necessary giving less visual resolution even if b is just 2.
In latex notation it is the difference between \frac{a}{b} c and \frac{ac}{b}.
In general what is the process? I noticed I can sometimes use ` ` to block things in but this also interfers with mathamtical notation. e.g., `3^f` becomes just that rather than f writen as a superscript.
Clearly I could hack it using various things but I want something direct and simple that tells maple not to try to do it's magic tricks.
For example, sometimes I might have 2*(a + b) and maple displays it as 2a + 2b. If I write it as `2`*(a+b) then this is noted as 2*(a+b) but the 2 is different.. I guess it is treated as a string or something... For my cases it works since I'm not trying to calculate anything from the expression but just for visual purposes, other times though I might want to calculate(usually the visual doesn't matter in calculation but sometimes both are desired).
I really want to avoid having to litter the expressions with special syntax to get such simple behavior. Something to tell maple not to carry out whatever algebraic transform it is programmed to do.
BTW, what does ! do? !3 + 4 opens a new window with an exit code.
the following command
collect(c4*dnub*kpbr*ksr*nur*nurdel + c4*dnur*kpbr*ksr*nub*nurdel, [nur, nub, dnur, dnub, nurdel, nubdel, dnurdel, dnubdel, c4], distributed)
returns
However, I am expecting it to return
c4*kpbr*ksr*(dnub*nur*nurdel+dnur*nub*nurdel)
Where is the error?
Lets say I have an expression
f:=(a+b)*x1+(a^2+b^2)*(x1+x2^2)+c*(x2-x3)*a*b
and I have a list
p:=[a+b,a^2+b^2,c*b*a].
How can I get the coefficients of the element from p in f, ie,
cof=[x1,x1+x2^2, x2-x3].
such that cof[i] corresponds to p[i]?
Thanks in advance for your suggestions.
How do I remove these unwanted trailing zeros from my plot ? I have tried setting striptrailing=true from the Tyesetting package but no difference. Thanks
how can i extract solution for each GB to excel file
Eq1 := diff(f(x), `$`(x, 3))+2*GB*a*alpha*f(x) = 0; Eq2 := f(0) = 1, (D(f))(0) = 0, f(1) = 0
Eq3 := {Eq1, Eq2}
{diff(diff(diff(f(x), x), x), x)+2*GB*a*alpha*f(x) = 0, f(0) = 1, f(1) = 0, (D(f))(0) = 0}
Hlist := [0, 5, 6, 10]; params := {a = 7, alpha = 2}
{a = 7, alpha = 2}
for k to 4 do R := Hlist[k]; Sol_f[H] := dsolve(eval(Eq3, `union`(params, {GB = R})), numeric) end do
proc (x_bvp) local res, data, solnproc, _ndsol, outpoint, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then outpoint := evalf[_EnvDSNumericSaveDigits](x_bvp) else outpoint := evalf(x_bvp) end if; data := Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(78, {(1) = .0, (2) = 0.7422014940098305e-2, (3) = 0.15247037874053848e-1, (4) = 0.23520755103823496e-1, (5) = 0.3229677454019059e-1, (6) = 0.4163972613012182e-1, (7) = 0.5163047433585985e-1, (8) = 0.6236471548371652e-1, (9) = 0.7395995268651741e-1, (10) = 0.865635409488798e-1, (11) = .10037386494155838, (12) = .11564679222653715, (13) = .13272336112005387, (14) = .1520729596986236, (15) = .1744030835655522, (16) = .20081719187277686, (17) = .23287978474503113, (18) = .2696382833116828, (19) = .30942370514871853, (20) = .35052688440207136, (21) = .39189960663752765, (22) = .43045939689378565, (23) = .46406520016444347, (24) = .4926053926873776, (25) = .5167851003350923, (26) = .5376216024209438, (27) = .5559231840204688, (28) = .5722936854718627, (29) = .5871581085615549, (30) = .6008206508251621, (31) = .613507361562576, (32) = .6253918899303244, (33) = .6366076943924017, (34) = .6472594108447342, (35) = .6574286185464324, (36) = .667182426192274, (37) = .6765759166669013, (38) = .6856560419917522, (39) = .694464489935754, (40) = .7030331909945008, (41) = .7113893933075516, (42) = .7195587800827726, (43) = .7275642453721933, (44) = .7354262387990891, (45) = .7431631740698084, (46) = .7507921727962193, (47) = .7583272647542358, (48) = .7657828547984458, (49) = .7731719918385156, (50) = .7805069149512255, (51) = .787800042336253, (52) = .7950633754902232, (53) = .802308883829374, (54) = .8095471292208104, (55) = .816788620070316, (56) = .8240445807266021, (57) = .8313260771552303, (58) = .8386433234849713, (59) = .8460074049212739, (60) = .8534299380344416, (61) = .8609213167489855, (62) = .8684912825541682, (63) = .8761497779391109, (64) = .8839064180293265, (65) = .8917702742321805, (66) = .8997477423309259, (67) = .9078436543374889, (68) = .9160613937315915, (69) = .9244024655177719, (70) = .9328635823555885, (71) = .9414402432317543, (72) = .9501252904326655, (73) = .9589057176767743, (74) = .9677706161338872, (75) = .9764838806404585, (76) = .9847529627091501, (77) = .9925779854438055, (78) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(78, 3, {(1, 1) = 1.0, (1, 2) = .0, (1, 3) = 38.386176015354714, (2, 1) = 1.0010381945843554, (2, 2) = .2771893448193658, (2, 3) = 36.30728934760168, (3, 1) = 1.0042963757113128, (3, 2) = .55270571236988, (3, 3) = 34.110832525099134, (4, 1) = 1.0100102471873285, (4, 2) = .8252878570049964, (4, 3) = 31.778055437429416, (5, 1) = 1.0184448193935531, (5, 2) = 1.093253963708355, (5, 3) = 29.28629045181688, (6, 1) = 1.0298983861788318, (6, 2) = 1.3543840804437328, (6, 3) = 26.60756232968718, (7, 1) = 1.044709521932798, (7, 2) = 1.605755570899463, (7, 3) = 23.706383861466097, (8, 1) = 1.0632513045490988, (8, 2) = 1.8432767789658882, (8, 3) = 20.53919210009709, (9, 1) = 1.0859275260569894, (9, 2) = 2.061281786793718, (9, 3) = 17.05104269389171, (10, 1) = 1.1131592778616584, (10, 2) = 2.2518387196230063, (10, 3) = 13.171455221803619, (11, 1) = 1.1453761649071785, (11, 2) = 2.4037357375480184, (11, 3) = 8.805376459470997, (12, 1) = 1.1829232618447163, (12, 2) = 2.5004107831489004, (12, 3) = 3.8275101658570896, (13, 1) = 1.2259023831041698, (13, 2) = 2.5168946136272687, (13, 3) = -1.9312040672586204, (14, 1) = 1.273823202340899, (14, 2) = 2.41442292263844, (14, 3) = -8.703714673093767, (15, 1) = 1.32489881040714, (15, 2) = 2.1299191347716695, (15, 3) = -16.831193254948268, (16, 1) = 1.3741361227552364, (16, 2) = 1.55419875396813, (16, 3) = -26.82152738780503, (17, 1) = 1.4080508419131426, (17, 2) = .49443414154220483, (17, 3) = -39.33552182611952, (18, 1) = 1.3963830671356963, (18, 2) = -1.2180825786825746, (18, 3) = -53.82166494495346, (19, 1) = 1.3012694763249404, (19, 2) = -3.663599829854037, (19, 3) = -68.9378273523391, (20, 1) = 1.0883742078812664, (20, 2) = -6.790682032244631, (20, 3) = -82.81223942735504, (21, 1) = .7332094872654484, (21, 2) = -10.452310970196194, (21, 3) = -93.50953969605982, (22, 1) = .25897959052489655, (22, 2) = -14.180229882914377, (22, 3) = -98.99519214944469, (23, 1) = -.2736962891670773, (23, 2) = -17.521396851088035, (23, 3) = -99.01407158290625, (24, 1) = -.8136490124950762, (24, 2) = -20.296295881657187, (24, 3) = -94.7222241169801, (25, 1) = -1.3314780494820997, (25, 2) = -22.506289855361793, (25, 3) = -87.49079585871775, (26, 1) = -1.8188105138896593, (26, 2) = -24.238671480113556, (26, 3) = -78.31861638361846, (27, 1) = -2.274980464806825, (27, 2) = -25.579703152510636, (27, 3) = -67.83990377359022, (28, 1) = -2.7023359694535296, (28, 2) = -26.59962914680849, (28, 3) = -56.43892166690841, (29, 1) = -3.1035298077817575, (29, 2) = -27.350861692718976, (29, 3) = -44.360678454090205, (30, 1) = -3.480971874211851, (30, 2) = -27.872564247073623, (30, 3) = -31.768407619168595, (31, 1) = -3.8367994850784832, (31, 2) = -28.194497966345814, (31, 3) = -18.772234877979404, (32, 1) = -4.1728963854105405, (32, 2) = -28.339516338097162, (32, 3) = -5.445909446947036, (33, 1) = -4.490809409335731, (33, 2) = -28.32524046551249, (33, 3) = 8.15799212324777, (34, 1) = -4.79180151570542, (34, 2) = -28.165414760706334, (34, 3) = 22.00101835188759, (35, 1) = -5.07684520530807, (35, 2) = -27.87092798584902, (35, 3) = 36.05161315989217, (36, 1) = -5.346755175391735, (36, 2) = -27.45046541461933, (36, 3) = 50.2863172936417, (37, 1) = -5.602182989617742, (37, 2) = -26.91099448460295, (37, 3) = 64.68625227277516, (38, 1) = -5.843673697667125, (38, 2) = -26.258035422800074, (38, 3) = 79.23768210215435, (39, 1) = -6.071704048752482, (39, 2) = -25.495766256210366, (39, 3) = 93.93289981377228, (40, 1) = -6.2865413908219105, (40, 2) = -24.62772878811068, (40, 3) = 108.75956231452248, (41, 1) = -6.488365978798334, (41, 2) = -23.65679257680415, (41, 3) = 123.70610360203507, (42, 1) = -6.677333159112298, (42, 2) = -22.58497056483621, (42, 3) = 138.7655689743947, (43, 1) = -6.853528847273043, (43, 2) = -21.41364299686328, (43, 3) = 153.9322389267795, (44, 1) = -7.016969051653059, (44, 2) = -20.143642894855606, (44, 3) = 169.20103738641026, (45, 1) = -7.167602423383424, (45, 2) = -18.77531208673614, (45, 3) = 184.56726411455978, (46, 1) = -7.305318948190193, (46, 2) = -17.308463785577665, (46, 3) = 200.02720191881534, (47, 1) = -7.429914789924158, (47, 2) = -15.742833500440952, (47, 3) = 215.57366381270867, (48, 1) = -7.5411512337736974, (48, 2) = -14.07748834798679, (48, 3) = 231.2023620438113, (49, 1) = -7.6387175183803055, (49, 2) = -12.311201649894752, (49, 3) = 246.90787049883542, (50, 1) = -7.722236201337924, (50, 2) = -10.442397132353205, (50, 3) = 262.6842145190337, (51, 1) = -7.791267758846605, (51, 2) = -8.468923343360544, (51, 3) = 278.52653824235927, (52, 1) = -7.8452938116098725, (52, 2) = -6.388204943712167, (52, 3) = 294.42939738489036, (53, 1) = -7.883711765855054, (53, 2) = -4.197150420318326, (53, 3) = 310.38713103269964, (54, 1) = -7.905821198580051, (54, 2) = -1.892601667252537, (54, 3) = 326.3903402911911, (55, 1) = -7.910828488449073, (55, 2) = .5290144403384773, (55, 3) = 342.4283606903575, (56, 1) = -7.897834733740855, (56, 2) = 3.071950114910132, (56, 3) = 358.4904700009592, (57, 1) = -7.865820550715685, (57, 2) = 5.740854241512291, (57, 3) = 374.5633917646863, (58, 1) = -7.8136422508457315, (58, 2) = 8.540470599699889, (58, 3) = 390.62915821433086, (59, 1) = -7.740012374279895, (59, 2) = 11.476245256966607, (59, 3) = 406.6682461492493, (60, 1) = -7.643479793744403, (60, 2) = 14.554220207210015, (60, 3) = 422.65803020173627, (61, 1) = -7.522439269923206, (61, 2) = 17.780264481034628, (61, 3) = 438.5681647539286, (62, 1) = -7.375125762150111, (62, 2) = 21.160183253505476, (62, 3) = 454.3610522058657, (63, 1) = -7.1995921572266015, (63, 2) = 24.70000314066167, (63, 3) = 469.9927541150128, (64, 1) = -6.993708734091879, (64, 2) = 28.405653224338753, (64, 3) = 485.41088215213205, (65, 1) = -6.75516438589842, (65, 2) = 32.282737127940095, (65, 3) = 500.55315920962886, (66, 1) = -6.48154379932051, (66, 2) = 36.33528116108361, (66, 3) = 515.3425355069513, (67, 1) = -6.170329168881457, (67, 2) = 40.565998727887454, (67, 3) = 529.6889889597641, (68, 1) = -5.818925492294148, (68, 2) = 44.97610249233706, (68, 3) = 543.4893781093477, (69, 1) = -5.42471537565811, (69, 2) = 49.564815551335016, (69, 3) = 556.626589733943, (70, 1) = -4.9852667690195, (70, 2) = 54.327433776793995, (70, 3) = 568.9657561995768, (71, 1) = -4.498249202540579, (71, 2) = 59.25696421609918, (71, 3) = 580.3613834866482, (72, 1) = -3.9615778090146163, (72, 2) = 64.34308239636641, (72, 3) = 590.6566951289624, (73, 1) = -3.3737288363633975, (73, 2) = 69.56998582501373, (73, 3) = 599.6830958927808, (74, 1) = -2.7333299078047895, (74, 2) = 74.9209285737396, (74, 3) = 607.2722920468946, (75, 1) = -2.0573924158706256, (75, 2) = 80.23895127261001, (75, 3) = 613.1257096022034, (76, 1) = -1.372878019405228, (76, 2) = 85.32648255190304, (76, 3) = 617.1049532901717, (77, 1) = -.6862764603683912, (77, 2) = 90.16517673340196, (77, 3) = 619.3676770101681, (78, 1) = .0, (78, 2) = 94.76568300546467, (78, 3) = 620.0866880268571}, datatype = float[8], order = C_order); YP := Matrix(78, 3, {(1, 1) = .0, (1, 2) = 38.386176015354714, (1, 3) = -280.0, (2, 1) = .2771893448193658, (2, 2) = 36.30728934760168, (2, 3) = -280.2906944836195, (3, 1) = .55270571236988, (3, 2) = 34.110832525099134, (3, 3) = -281.2029851991676, (4, 1) = .8252878570049964, (4, 2) = 31.778055437429416, (4, 3) = -282.802869212452, (5, 1) = 1.093253963708355, (5, 2) = 29.28629045181688, (5, 3) = -285.1645494301949, (6, 1) = 1.3543840804437328, (6, 2) = 26.60756232968718, (6, 3) = -288.3715481300729, (7, 1) = 1.605755570899463, (7, 2) = 23.706383861466097, (7, 3) = -292.5186661411834, (8, 1) = 1.8432767789658882, (8, 2) = 20.53919210009709, (8, 3) = -297.71036527374764, (9, 1) = 2.061281786793718, (9, 2) = 17.05104269389171, (9, 3) = -304.059707295957, (10, 1) = 2.2518387196230063, (10, 2) = 13.171455221803619, (10, 3) = -311.6845978012643, (11, 1) = 2.4037357375480184, (11, 2) = 8.805376459470997, (11, 3) = -320.70532617401, (12, 1) = 2.5004107831489004, (12, 2) = 3.8275101658570896, (12, 3) = -331.21851331652056, (13, 1) = 2.5168946136272687, (13, 2) = -1.9312040672586204, (13, 3) = -343.25266726916755, (14, 1) = 2.41442292263844, (14, 2) = -8.703714673093767, (14, 3) = -356.67049665545176, (15, 1) = 2.1299191347716695, (15, 2) = -16.831193254948268, (15, 3) = -370.9716669139992, (16, 1) = 1.55419875396813, (16, 2) = -26.82152738780503, (16, 3) = -384.7581143714662, (17, 1) = .49443414154220483, (17, 2) = -39.33552182611952, (17, 3) = -394.2542357356799, (18, 1) = -1.2180825786825746, (18, 2) = -53.82166494495346, (18, 3) = -390.98725879799497, (19, 1) = -3.663599829854037, (19, 2) = -68.9378273523391, (19, 3) = -364.3554533709833, (20, 1) = -6.790682032244631, (20, 2) = -82.81223942735504, (20, 3) = -304.7447782067546, (21, 1) = -10.452310970196194, (21, 2) = -93.50953969605982, (21, 3) = -205.29865643432555, (22, 1) = -14.180229882914377, (22, 2) = -98.99519214944469, (22, 3) = -72.51428534697104, (23, 1) = -17.521396851088035, (23, 2) = -99.01407158290625, (23, 3) = 76.63496096678163, (24, 1) = -20.296295881657187, (24, 2) = -94.7222241169801, (24, 3) = 227.8217234986213, (25, 1) = -22.506289855361793, (25, 2) = -87.49079585871775, (25, 3) = 372.81385385498794, (26, 1) = -24.238671480113556, (26, 2) = -78.31861638361846, (26, 3) = 509.2669438891046, (27, 1) = -25.579703152510636, (27, 2) = -67.83990377359022, (27, 3) = 636.994530145911, (28, 1) = -26.59962914680849, (28, 2) = -56.43892166690841, (28, 3) = 756.6540714469883, (29, 1) = -27.350861692718976, (29, 2) = -44.360678454090205, (29, 3) = 868.9883461788921, (30, 1) = -27.872564247073623, (30, 2) = -31.768407619168595, (30, 3) = 974.6721247793183, (31, 1) = -28.194497966345814, (31, 2) = -18.772234877979404, (31, 3) = 1074.3038558219753, (32, 1) = -28.339516338097162, (32, 2) = -5.445909446947036, (32, 3) = 1168.4109879149514, (33, 1) = -28.32524046551249, (33, 2) = 8.15799212324777, (33, 3) = 1257.4266346140048, (34, 1) = -28.165414760706334, (34, 2) = 22.00101835188759, (34, 3) = 1341.7044243975176, (35, 1) = -27.87092798584902, (35, 2) = 36.05161315989217, (35, 3) = 1421.5166574862594, (36, 1) = -27.45046541461933, (36, 2) = 50.2863172936417, (36, 3) = 1497.0914491096858, (37, 1) = -26.91099448460295, (37, 2) = 64.68625227277516, (37, 3) = 1568.611237092968, (38, 1) = -26.258035422800074, (38, 2) = 79.23768210215435, (38, 3) = 1636.228635346795, (39, 1) = -25.495766256210366, (39, 2) = 93.93289981377228, (39, 3) = 1700.0771336506948, (40, 1) = -24.62772878811068, (40, 2) = 108.75956231452248, (40, 3) = 1760.231589430135, (41, 1) = -23.65679257680415, (41, 2) = 123.70610360203507, (41, 3) = 1816.7424740635336, (42, 1) = -22.58497056483621, (42, 2) = 138.7655689743947, (42, 3) = 1869.6532845514434, (43, 1) = -21.41364299686328, (43, 2) = 153.9322389267795, (43, 3) = 1918.988077236452, (44, 1) = -20.143642894855606, (44, 2) = 169.20103738641026, (44, 3) = 1964.7513344628567, (45, 1) = -18.77531208673614, (45, 2) = 184.56726411455978, (45, 3) = 2006.9286785473587, (46, 1) = -17.308463785577665, (46, 2) = 200.02720191881534, (46, 3) = 2045.489305493254, (47, 1) = -15.742833500440952, (47, 2) = 215.57366381270867, (47, 3) = 2080.376141178764, (48, 1) = -14.07748834798679, (48, 2) = 231.2023620438113, (48, 3) = 2111.5223454566353, (49, 1) = -12.311201649894752, (49, 2) = 246.90787049883542, (49, 3) = 2138.8409051464855, (50, 1) = -10.442397132353205, (50, 2) = 262.6842145190337, (50, 3) = 2162.226136374619, (51, 1) = -8.468923343360544, (51, 2) = 278.52653824235927, (51, 3) = 2181.5549724770494, (52, 1) = -6.388204943712167, (52, 2) = 294.42939738489036, (52, 3) = 2196.682267250764, (53, 1) = -4.197150420318326, (53, 2) = 310.38713103269964, (53, 3) = 2207.439294439415, (54, 1) = -1.892601667252537, (54, 2) = 326.3903402911911, (54, 3) = 2213.629935602414, (55, 1) = .5290144403384773, (55, 2) = 342.4283606903575, (55, 3) = 2215.03197676574, (56, 1) = 3.071950114910132, (56, 2) = 358.4904700009592, (56, 3) = 2211.3937254474395, (57, 1) = 5.740854241512291, (57, 2) = 374.5633917646863, (57, 3) = 2202.429754200392, (58, 1) = 8.540470599699889, (58, 2) = 390.62915821433086, (58, 3) = 2187.8198302368046, (59, 1) = 11.476245256966607, (59, 2) = 406.6682461492493, (59, 3) = 2167.2034647983705, (60, 1) = 14.554220207210015, (60, 2) = 422.65803020173627, (60, 3) = 2140.174342248433, (61, 1) = 17.780264481034628, (61, 2) = 438.5681647539286, (61, 3) = 2106.282995578498, (62, 1) = 21.160183253505476, (62, 2) = 454.3610522058657, (62, 3) = 2065.035213402031, (63, 1) = 24.70000314066167, (63, 2) = 469.9927541150128, (63, 3) = 2015.8858040234484, (64, 1) = 28.405653224338753, (64, 2) = 485.41088215213205, (64, 3) = 1958.238445545726, (65, 1) = 32.282737127940095, (65, 2) = 500.55315920962886, (65, 3) = 1891.4460280515575, (66, 1) = 36.33528116108361, (66, 2) = 515.3425355069513, (66, 3) = 1814.8322638097427, (67, 1) = 40.565998727887454, (67, 2) = 529.6889889597641, (67, 3) = 1727.692167286808, (68, 1) = 44.97610249233706, (68, 2) = 543.4893781093477, (68, 3) = 1629.2991378423615, (69, 1) = 49.564815551335016, (69, 2) = 556.626589733943, (69, 3) = 1518.9203051842708, (70, 1) = 54.327433776793995, (70, 2) = 568.9657561995768, (70, 3) = 1395.87469532546, (71, 1) = 59.25696421609918, (71, 2) = 580.3613834866482, (71, 3) = 1259.5097767113623, (72, 1) = 64.34308239636641, (72, 2) = 590.6566951289624, (72, 3) = 1109.2417865240925, (73, 1) = 69.56998582501373, (73, 2) = 599.6830958927808, (73, 3) = 944.6440741817513, (74, 1) = 74.9209285737396, (74, 2) = 607.2722920468946, (74, 3) = 765.332374185341, (75, 1) = 80.23895127261001, (75, 2) = 613.1257096022034, (75, 3) = 576.0698764437751, (76, 1) = 85.32648255190304, (76, 2) = 617.1049532901717, (76, 3) = 384.4058454334638, (77, 1) = 90.16517673340196, (77, 2) = 619.3676770101681, (77, 3) = 192.15740890314953, (78, 1) = 94.76568300546467, (78, 2) = 620.0866880268571, (78, 3) = -.0}, datatype = float[8], order = C_order); errproc := proc (x_bvp) local outpoint, X, Y, yout, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; Digits := 15; outpoint := evalf(x_bvp); X := Vector(78, {(1) = .0, (2) = 0.7422014940098305e-2, (3) = 0.15247037874053848e-1, (4) = 0.23520755103823496e-1, (5) = 0.3229677454019059e-1, (6) = 0.4163972613012182e-1, (7) = 0.5163047433585985e-1, (8) = 0.6236471548371652e-1, (9) = 0.7395995268651741e-1, (10) = 0.865635409488798e-1, (11) = .10037386494155838, (12) = .11564679222653715, (13) = .13272336112005387, (14) = .1520729596986236, (15) = .1744030835655522, (16) = .20081719187277686, (17) = .23287978474503113, (18) = .2696382833116828, (19) = .30942370514871853, (20) = .35052688440207136, (21) = .39189960663752765, (22) = .43045939689378565, (23) = .46406520016444347, (24) = .4926053926873776, (25) = .5167851003350923, (26) = .5376216024209438, (27) = .5559231840204688, (28) = .5722936854718627, (29) = .5871581085615549, (30) = .6008206508251621, (31) = .613507361562576, (32) = .6253918899303244, (33) = .6366076943924017, (34) = .6472594108447342, (35) = .6574286185464324, (36) = .667182426192274, (37) = .6765759166669013, (38) = .6856560419917522, (39) = .694464489935754, (40) = .7030331909945008, (41) = .7113893933075516, (42) = .7195587800827726, (43) = .7275642453721933, (44) = .7354262387990891, (45) = .7431631740698084, (46) = .7507921727962193, (47) = .7583272647542358, (48) = .7657828547984458, (49) = .7731719918385156, (50) = .7805069149512255, (51) = .787800042336253, (52) = .7950633754902232, (53) = .802308883829374, (54) = .8095471292208104, (55) = .816788620070316, (56) = .8240445807266021, (57) = .8313260771552303, (58) = .8386433234849713, (59) = .8460074049212739, (60) = .8534299380344416, (61) = .8609213167489855, (62) = .8684912825541682, (63) = .8761497779391109, (64) = .8839064180293265, (65) = .8917702742321805, (66) = .8997477423309259, (67) = .9078436543374889, (68) = .9160613937315915, (69) = .9244024655177719, (70) = .9328635823555885, (71) = .9414402432317543, (72) = .9501252904326655, (73) = .9589057176767743, (74) = .9677706161338872, (75) = .9764838806404585, (76) = .9847529627091501, (77) = .9925779854438055, (78) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(78, 3, {(1, 1) = .0, (1, 2) = .0, (1, 3) = 0.21374101479472934e-9, (2, 1) = 0.6617043163614648e-14, (2, 2) = 0.15815604852839844e-11, (2, 3) = 0.21311837323331495e-9, (3, 1) = 0.25343727453304818e-13, (3, 2) = 0.3236859819203722e-11, (3, 3) = 0.21227882088379557e-9, (4, 1) = 0.608178113423069e-13, (4, 2) = 0.4970351848975599e-11, (4, 3) = 0.21125160962194817e-9, (5, 1) = 0.11336987512724689e-12, (5, 2) = 0.6786995734632931e-11, (5, 3) = 0.20993325149852807e-9, (6, 1) = 0.1850029120583241e-12, (6, 2) = 0.8693080167652104e-11, (6, 3) = 0.20819378569749641e-9, (7, 1) = 0.28253966655178614e-12, (7, 2) = 0.10684057021809762e-10, (7, 3) = 0.2058724893755894e-9, (8, 1) = 0.4083861282846956e-12, (8, 2) = 0.12759826289631252e-10, (8, 3) = 0.20278447790781166e-9, (9, 1) = 0.5665515205281028e-12, (9, 2) = 0.14908481409452215e-10, (9, 3) = 0.19858389734160558e-9, (10, 1) = 0.765632284881089e-12, (10, 2) = 0.1710637073672902e-10, (10, 3) = 0.19283723931777497e-9, (11, 1) = 0.10095317904433423e-11, (11, 2) = 0.19293637254403415e-10, (11, 3) = 0.18490648517398407e-9, (12, 1) = 0.13018676569087828e-11, (12, 2) = 0.21365714310981305e-10, (12, 3) = 0.17382791885584998e-9, (13, 1) = 0.16425961487017066e-11, (13, 2) = 0.23112487818588823e-10, (13, 3) = 0.15809028547142478e-9, (14, 1) = 0.20174042817671427e-11, (14, 2) = 0.24066937733876484e-10, (14, 3) = 0.13530521149880537e-9, (15, 1) = 0.23588523733158e-11, (15, 2) = 0.23231216316050875e-10, (15, 3) = 0.10156224121561319e-9, (16, 1) = 0.2393011093467379e-11, (16, 2) = 0.18149054144044492e-10, (16, 3) = 0.51706195251559185e-10, (17, 1) = 0.9084877415827434e-12, (17, 2) = 0.314096305880786e-11, (17, 3) = -0.32841258405195813e-11, (18, 1) = -0.45491514609546456e-11, (18, 2) = -0.20025596832171e-10, (18, 3) = 0.51921619668659705e-10, (19, 1) = -0.146658137108361e-10, (19, 2) = -0.2416251850244477e-10, (19, 3) = 0.43252805140703903e-9, (20, 1) = -0.24237492293530955e-10, (20, 2) = 0.3599372556048811e-10, (20, 3) = 0.1223259174809578e-8, (21, 1) = -0.24535443635530228e-10, (21, 2) = 0.1903555252463994e-9, (21, 3) = 0.2245871545259929e-8, (22, 1) = -0.11739792007986929e-10, (22, 2) = 0.37030660671350455e-9, (22, 3) = 0.28847498354569104e-8, (23, 1) = 0.6161988712155101e-11, (23, 2) = 0.5116509035009505e-9, (23, 3) = 0.30511215548502548e-8, (24, 1) = 0.24143172302904838e-10, (24, 2) = 0.6156361580552844e-9, (24, 3) = 0.2967037607906237e-8, (25, 1) = 0.4099280962473993e-10, (25, 2) = 0.6934931258243783e-9, (25, 3) = 0.27586166265908647e-8, (26, 1) = 0.5667287481842802e-10, (26, 2) = 0.7529934557834415e-9, (26, 3) = 0.24793432501917947e-8, (27, 1) = 0.7128596741818145e-10, (27, 2) = 0.7986347832025048e-9, (27, 3) = 0.21545638229423175e-8, (28, 1) = 0.8495334319877626e-10, (28, 2) = 0.8332910094275046e-9, (28, 3) = 0.17982758736276522e-8, (29, 1) = 0.9776913816729528e-10, (29, 2) = 0.8589525126881634e-9, (29, 3) = 0.14187573949711434e-8, (30, 1) = 0.10982483919576233e-9, (30, 2) = 0.876990864247837e-9, (30, 3) = 0.10219138652783984e-8, (31, 1) = 0.12119861873621406e-9, (31, 2) = 0.8884384414068472e-9, (31, 3) = 0.6113196945671567e-9, (32, 1) = 0.13194536181092119e-9, (32, 2) = 0.8940935343871139e-9, (32, 3) = 0.18958612224147546e-9, (33, 1) = 0.1421034511267267e-9, (33, 2) = 0.8946023759386806e-9, (33, 3) = -0.24151798358672923e-9, (34, 1) = 0.15173459103634197e-9, (34, 2) = 0.890292600785599e-9, (34, 3) = -0.680621711939455e-9, (35, 1) = 0.16085584900871135e-9, (35, 2) = 0.8816923848879957e-9, (35, 3) = -0.112675278788525e-8, (36, 1) = 0.1694927906902929e-9, (36, 2) = 0.8689606740007918e-9, (36, 3) = -0.15790797703029465e-8, (37, 1) = 0.17766688271008688e-9, (37, 2) = 0.8524194555746267e-9, (37, 3) = -0.2037000474455717e-8, (38, 1) = 0.1854153557046071e-9, (38, 2) = 0.8321878405243527e-9, (38, 3) = -0.24999561526619108e-8, (39, 1) = 0.19271741055197827e-9, (39, 2) = 0.8084450298695515e-9, (39, 3) = -0.2967596855008954e-8, (40, 1) = 0.19960793855467597e-9, (40, 2) = 0.7812801551816712e-9, (40, 3) = -0.3439694098295936e-8, (41, 1) = 0.20608273385672261e-9, (41, 2) = 0.7508009529277227e-9, (41, 3) = -0.3915938494413602e-8, (42, 1) = 0.21214411615546314e-9, (42, 2) = 0.7170679029918045e-9, (42, 3) = -0.4395917295441028e-8, (43, 1) = 0.2178162740801877e-9, (43, 2) = 0.6801782610494025e-9, (43, 3) = -0.4879454958084554e-8, (44, 1) = 0.22307505792290622e-9, (44, 2) = 0.6400707246037973e-9, (44, 3) = -0.5366363171426886e-8, (45, 1) = 0.22792663267245126e-9, (45, 2) = 0.596788468093401e-9, (45, 3) = -0.5856735844943015e-8, (46, 1) = 0.23235772030479177e-9, (46, 2) = 0.5503712224233628e-9, (46, 3) = -0.6350243465827074e-8, (47, 1) = 0.23638476869867436e-9, (47, 2) = 0.5007838964884985e-9, (47, 3) = -0.6846352628530876e-8, (48, 1) = 0.2399826547596872e-9, (48, 2) = 0.44797493712876514e-9, (48, 3) = -0.7345909288023861e-8, (49, 1) = 0.24314767746970955e-9, (49, 2) = 0.3919441530467946e-9, (49, 3) = -0.7847826952926815e-8, (50, 1) = 0.2458633553763264e-9, (50, 2) = 0.3325930338144637e-9, (50, 3) = -0.8351962221384333e-8, (51, 1) = 0.2481176496667275e-9, (51, 2) = 0.2698850071047016e-9, (51, 3) = -0.8858604164736875e-8, (52, 1) = 0.24989864164578096e-9, (52, 2) = 0.2037421854623591e-9, (52, 3) = -0.9367169852109535e-8, (53, 1) = 0.2511868319065834e-9, (53, 2) = 0.13403592712019737e-9, (53, 3) = -0.9877961190186058e-8, (54, 1) = 0.25194722806050053e-9, (54, 2) = 0.6068854794188144e-10, (54, 3) = -0.10389999059726765e-7, (55, 1) = 0.25216103000641414e-9, (55, 2) = -0.16426412087914983e-10, (55, 3) = -0.10904142671968567e-7, (56, 1) = 0.25181047788846003e-9, (56, 2) = -0.9744592357883526e-10, (56, 3) = -0.11418952784898342e-7, (57, 1) = 0.25084708208867255e-9, (57, 2) = -0.18252768360712056e-9, (57, 3) = -0.1193350480225618e-7, (58, 1) = 0.24924216152550573e-9, (58, 2) = -0.2718278165342341e-9, (58, 3) = -0.12449299125456e-7, (59, 1) = 0.2469647322823809e-9, (59, 2) = -0.3654926237200361e-9, (59, 3) = -0.12964216944950137e-7, (60, 1) = 0.2439385432872567e-9, (60, 2) = -0.46374566629486124e-9, (60, 3) = -0.13477191099854094e-7, (61, 1) = 0.2401392779850783e-9, (61, 2) = -0.5667827937551021e-9, (61, 3) = -0.13989002634087752e-7, (62, 1) = 0.2354974830501514e-9, (62, 2) = -0.6748203135319071e-9, (62, 3) = -0.144966926321542e-7, (63, 1) = 0.2299556698858384e-9, (63, 2) = -0.7879969316169068e-9, (63, 3) = -0.1499985558975845e-7, (64, 1) = 0.22344335042145828e-9, (64, 2) = -0.906569122267802e-9, (64, 3) = -0.15496633446164436e-7, (65, 1) = 0.21588699161848774e-9, (65, 2) = -0.1030706052504292e-8, (65, 3) = -0.1598507069938262e-7, (66, 1) = 0.2072001570759953e-9, (66, 2) = -0.11604415138593787e-8, (66, 3) = -0.16462981859028595e-7, (67, 1) = 0.1973239834078538e-9, (67, 2) = -0.12960869498348117e-8, (67, 3) = -0.16926252731900467e-7, (68, 1) = 0.1861481274670076e-9, (68, 2) = -0.14375072189369759e-8, (68, 3) = -0.17373690408853017e-7, (69, 1) = 0.17360182955573136e-9, (69, 2) = -0.15847891575527738e-8, (69, 3) = -0.17799737782051196e-7, (70, 1) = 0.1595911628943475e-9, (70, 2) = -0.17377594077856065e-8, (70, 3) = -0.18200148769816036e-7, (71, 1) = 0.14405378999774726e-9, (71, 2) = -0.1896185117484409e-8, (71, 3) = -0.1857211954096187e-7, (72, 1) = 0.12690950590380987e-9, (72, 2) = -0.20597762848508742e-8, (72, 3) = -0.1890888800221457e-7, (73, 1) = 0.10811586884916081e-9, (73, 2) = -0.2228107102170434e-8, (73, 3) = -0.1920524894652217e-7, (74, 1) = 0.8762389472881187e-10, (74, 2) = -0.2400509994779305e-8, (74, 3) = -0.19456175522202756e-7, (75, 1) = 0.6597647839692229e-10, (75, 2) = -0.2571949957407786e-8, (75, 3) = -0.19650196577522936e-7, (76, 1) = 0.4403563168815861e-10, (76, 2) = -0.27358008655389504e-8, (76, 3) = -0.19784033238859742e-7, (77, 1) = 0.2201801640944132e-10, (77, 2) = -0.28918571075789674e-8, (77, 3) = -0.1986208486392248e-7, (78, 1) = .0, (78, 2) = -0.3040105066991136e-8, (78, 3) = -0.19890096842081592e-7}, datatype = float[8], order = C_order); if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "right" then return X[78] elif outpoint = "order" then return 8 elif outpoint = "error" then return HFloat(1.9890096842081592e-8) elif outpoint = "errorproc" then error "this is already the error procedure" elif outpoint = "rawdata" then return [3, 78, [f(x), diff(f(x), x), diff(diff(f(x), x), x)], X, Y] else return ('procname')(x_bvp) end if end if; if outpoint < X[1] or X[78] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[78] end if; V := array([1 = 4, 2 = 0]); if Digits <= trunc(evalhf(Digits)) then L := Vector(4, 'datatype' = 'float'[8]); yout := Vector(3, 'datatype' = 'float'[8]); evalhf(`dsolve/numeric/lagrange`(78, 3, X, Y, outpoint, var(yout), var(L), var(V))) else L := Vector(4, 'datatype' = 'sfloat'); yout := Vector(3, 'datatype' = 'sfloat'); `dsolve/numeric/lagrange`(78, 3, X, Y, outpoint, yout, L, V) end if; [x = outpoint, seq('[f(x), diff(f(x), x), diff(diff(f(x), x), x)]'[i] = yout[i], i = 1 .. 3)] end proc; if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "method" then return "bvp" elif outpoint = "right" then return X[78] elif outpoint = "order" then return 8 elif outpoint = "error" then return HFloat(1.9890096842081592e-8) elif outpoint = "errorproc" then return eval(errproc) elif outpoint = "rawdata" then return [3, 78, "depnames", X, Y, YP] else error "non-numeric value" end if end if; if outpoint < X[1] or X[78] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[78] end if; if Digits <= trunc(evalhf(Digits)) and (_EnvInFsolve <> true or _EnvDSNumericSaveDigits <= trunc(evalhf(Digits))) then V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0, (3, 1) = .0, (3, 2) = .0, (4, 1) = .0, (4, 2) = .0, (5, 1) = .0, (5, 2) = .0, (6, 1) = .0, (6, 2) = .0, (7, 1) = .0, (7, 2) = .0}, datatype = float[8], order = C_order); yout := Vector(3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8]); evalhf(`dsolve/numeric/hermite`(78, 3, X, Y, YP, outpoint, var(yout), var(L), var(V))) else if _EnvInFsolve = true then Digits := _EnvDSNumericSaveDigits end if; V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = 0., (1, 2) = 0., (2, 1) = 0., (2, 2) = 0., (3, 1) = 0., (3, 2) = 0., (4, 1) = 0., (4, 2) = 0., (5, 1) = 0., (5, 2) = 0., (6, 1) = 0., (6, 2) = 0., (7, 1) = 0., (7, 2) = 0.}, order = C_order); yout := Vector(3, {(1) = 0., (2) = 0., (3) = 0.}); `dsolve/numeric/hermite`(78, 3, X, Y, YP, outpoint, yout, L, V) end if; [outpoint, seq(yout[i], i = 1 .. 3)] end proc, (2) = Array(0..0, {}), (3) = [x, f(x), diff(f(x), x), diff(diff(f(x), x), x)], (4) = 0}); solnproc := data[1]; if not type(outpoint, 'numeric') then if outpoint = "solnprocedure" then return eval(solnproc) elif member(outpoint, ["start", "left", "right", "errorproc", "rawdata", "order", "error"]) then return solnproc(x_bvp) elif outpoint = "sysvars" then return data[3] elif procname <> unknown then return ('procname')(x_bvp) else _ndsol := pointto(data[2][0]); return ('_ndsol')(x_bvp) end if end if; try res := solnproc(outpoint); [x = res[1], seq('[f(x), diff(f(x), x), diff(diff(f(x), x), x)]'[i] = res[i+1], i = 1 .. 3)] catch: error  end try end proc
Download Untitled.mw
I would like to use  the Liebniz notation that someone from the technical support posted here
Writing Derivatives at a Point Using Leibniz Notation
to display a formula that is not just a partial derivative but a more complex expression invoking partial derivatives.
Typically an expression like this one:
2*(Diff(f(mu__1, mu__2), mu__1))^2*lambda__1^2-(Diff(f(mu__1, mu__2), mu__1))^2*mu__1^2+2*(Diff(f(mu__1, mu__2), mu__2))^2*lambda__2^2-(Diff(f(mu__1, mu__2), mu__2))^2*mu__2^2+2*(Diff(f(mu__1, mu__2), mu__1))*(Diff(f(mu__1, mu__2), mu__2))*lambda__1*lambda__2-2*(Diff(f(mu__1, mu__2), mu__1))*mu__1*(Diff(f(mu__1, mu__2), mu__2))*mu__2
Could anyone help me to do this?
(PS: I'm still using Maple 2015.2)
Can I get to know how to interface maple with gnu plot. Thank you.
First 607 608 609 610 611 612 613 Last Page 609 of 2433
