Is there any alternative to Mathematica's "RegionFunction" in Maple, with applications of controlling the plotting domain for surface plots ? This question has been asked previosly, and given a workaround by "Markiyan Hirnyk", suggesting to leave the function that is to be plotted undefined outside of the plot region. Something like:
f1 := proc(x,y) if x^2 + y^2 > 0 and x^2 + y^2 < 4 then 8 - x^2 - y^2 end if end proc:
f2 := proc(x,y) if x^2 + y^2 > 0 and x^2 + y^2 < 4 then x^2 + y^2 end if end proc:
plot3d({f1,f2}, -2..2, -2..2)
The result is clearly not good looking. You can increase the number of points, but we need a better way to do this.
BTW, the similar question was asked in 2010. Are there any better alternatives, ~ 10 years later ?
Please explain the logic used to construct the plot below.
plots:-implicitplot(r >= cos(theta), r = 0 .. 1/3, theta = 0 .. 2*Pi, filledregions, coords = polar, numpoints = 5000, scaling = constrained)
I found that while using maple gui cases of corruption, stuck while typing etc. Hope this problem will get solved in coming version
I have a differential equation. I can solve it using dsolve and plot it with odeplot. For example I obtain P(x).
I also have another equation. For example V in terms of x. So, I can plot it with plot(V).
Now I want to plot V in terms of P. How can I do that?
Thanks for your help
Dear Users!
Hoped everything going fine with you. I want to make animation of ten solutions as given bellow but fail to do that. Please see it fix the problem. I shall be very thankful to u.
SOLNSuy[1, 1] := 2.5872902469406659197*10^(-20)-.65694549571241255901*y+1.9708364871372376767*y^2-1.3138909914248251176*y^3-1.6010739356637904911*10^(-19)*y^4;
SOLNSuy[2, 1] := -4.002204462000*10^(-20)-1.7879176897079605225*y+5.3637530691192141414*y^2-3.5758353794044226250*y^3-6.8309939211286845440*10^(-12)*y^4;
SOLNSuy[3, 1] := -1.1953264450000*10^(-19)-3.2481690589079594122*y+9.7445071767154794599*y^2-6.4963381177952273213*y^3-1.2292726248071398400*10^(-11)*y^4;
SOLNSuy[4, 1] := -2.6720465500000*10^(-19)-4.9239979672954025921*y+14.771993901873204315*y^2-9.8479959345587718955*y^3-1.9029826928878336000*10^(-11)*y^4;
SOLNSuy[5, 1] := 3.416928541000*10^(-20)-6.7268498492441931137*y+20.180549547714413714*y^2-13.453699698443639810*y^3-2.6580790570532587008*10^(-11)*y^4;
SOLNSuy[6, 1] := -2.554122292000*10^(-20)-8.5884528335125514887*y+25.765358500514014457*y^2-17.176905666966875698*y^3-3.4587270427710613504*10^(-11)*y^4;
SOLNSuy[7, 1] := -9.206107680000*10^(-20)-10.456823708331499352*y+31.370471124965259849*y^2-20.913647416590986491*y^3-4.2774005353527132160*10^(-11)*y^4;
SOLNSuy[8, 1] := 1.9644186790000*10^(-19)-12.293003938471349390*y+36.879011815379230436*y^2-24.586007876856948223*y^3-5.0932823222176363520*10^(-11)*y^4;
SOLNSuy[9, 1] := -3.775112769000*10^(-19)-14.068404975282556550*y+42.205214925807397100*y^2-28.136809950465931724*y^3-5.8908824448577377280*10^(-11)*y^4;
SOLNSuy[10, 1] := 1.146281780000*10^(-19)-15.762658869974768890*y+47.287976609878780960*y^2-31.525317739837422477*y^3-6.6589592851037286400*10^(-11)*y^4;
plots[animate](plot, [SOLNSuy[A, 1], y = 0 .. 1], A = 1 .. 10);
Special request:
@acer @Carl Love @Kitonum @Preben Alsholm
Simple example to illustrate the desired functionality:
Say we have a 2D vector function which describes the position of a particle
r := t -> <5*cos(Pi*t), 5*sin(Pi*t)>
We want to define the velocity and acceleration as functions, so we could do something like
v := t -> <diff(r(t)[1], t), diff(r(t)[2], t)>
The problem now is that we cannot call our velocity function with numeric arguments.
A simple solution is to call the function via "subs", as in
subs(t = 2, v(t))
but IMHO, this is not very elegant and I guess inefficient. Is there a command that enables for pulling out the evaluated result from diff such that it can be used directly as a functional expression ? I.e., I want to be able to call
v(2)
directly, without having to do substitutions.
EDIT:
I found that you can do
v := <diff(r(t)[1], t, diff(r(t)[2], t)>
v := unapply(v, t)
but please provide your recommendations. Thanks
Hi everyone:
I want to earn f(zeta) and zeta=x/a while the f(x) is:
f:=(x)->A1*sin(k*x)+A2*cos(k*x)+A3*sinh(k*x)+A4*cosh(k*x)
zeta=x/a and a, k, A1..A4 are constants.
f(zeta)=?
I have problem with usage of diff function. I need to compute partial derivative over  diff(varphi__l(t),t) in that equation.
T__ln := (1/2)*(diff(varphi__l(t), t))^2+((1/2*(m))*v__l+(1/2*(I))*(diff(varphi__l(t), t))^2)+((1/2*(m))*v+(1/2*(I))*(diff(varphi__l(t), t))^2)
If I am trying to use:
diff(T__ln, diff(varphi__l(t), t))
I get the error:
Error, invalid input: diff received diff(varphi__l(t), t), which is not valid for its 2nd argument
Hi all, this is my first post here, I'm finding Maple super interesting so far.
I had a little problem with plots, whenever I update my underlying function and re-run my cells it won't update the curve at all whether automatically or after selecting the entry and pressing `execute ! `.
I'd have the select and delete the plot and then re-plot again.
Is this how it is or there is something I'm missing?
LeadingTerm(y^2-x^2/y, plex(x, y));
(in Groebner:-LeadingTerm) the input is not polynomial in, {x, y}
how to do when fraction in it ?
it return error
plot(x mod 3, x=-5..5);
plots exactly the same as
plot(x, x=-5..5);
plot(floor(x) mod 3, x=-5..5);
The mod function is doing nothing, why?
If I do 5 mod 4 I get 1, as expected.
n := 0
u[0] := x^3+(1/2)*A*x^2
for k from 0 to n do
A[k] := sum((Diff(u[i], x))*(Diff(u[k-i], x)), i = 0 .. k);
A[k] := sum((diff(u[i], x))*(diff(u[k-i], x)), i = 0 .. k)
it gives A[0]:=0 which is incorrect. why? and how it will give correct answer?
Please simulate it geometricaly ?
FILM
Need the code of the following:
h is the step size could be 0.1 or 0.01 etc
Dear experts
I am trying to study linear version of the Navier-Stokes (NS) equation. I define NS equations in a way suggested in this page
with(PDEtools): with(Student[VectorCalculus]):
SetCoordinates(cartesian[x,y,z]):
V:= VectorField(< v[1](x,z,t),0,v[3](x,z,t)>);
NavierStokes:= diff(V,t) - nu*Laplacian(V) +1/rho* Gradient(p(x,z,t)) - VectorField(< 0,0,-g>)=0;
the velocity components are intriduced as following
v[1]:=(x,z,t)->diff(f(z),z)*exp(I*k*x+(-1)*I*omega*t);
v[2]:=(x,z,t)->0;
v[3]:=(x,z,t)->(-1)*I*k*f(z)*exp(I*k*x+(-1)*I*omega*t);
So the problem is 2D model so that v[1] and v[3] satisfy incompresibility condition. It is clear that substituting velocity components into NS leads to differential equations for f(z). The general form of f(z) is
f(z) = a1*cosh(k*z)+a2*sinh(k*z)+a3*cosh(kappa*z)+a4*sinh(kappa*z).
my problems are
1) apply v[1], v[3] and find f(z) with Maple. then apply boundary conditions to find coeffs a[i] with Maple
2) In addition, Substituting the f(z) into BCs leads to a linear homogeneous system of equations for the coefficients. The vanishing of the determinant of this system which is the condition for the existence of a nontrivial solution is interested. How can I do that?
3) f(z) is for the case that the bottom is z=0 and surface is z=h. in my case bottom is z=-h and surface is z=0. how to do this in the solution. I dont know how to apply it.
4) calculate pressure
this file is what I did.
NSE.mw
First 609 610 611 612 613 614 615 Last Page 611 of 2433
