I was playing around with some of the maple examples(specifically the knots) and all the plots seem difficult to visualize in 3D... well, more difficult than they should.
In some cases the plots look more like projections and 2D because the graphical representation does seem to project in to the depth of the screen in a natural way.
Mainly it happens when rotating when some of the curve's appear to stay in front due to the highlighting and size issues.
I'm not sure exactly what the problem is but I imagine it definitely can be improved. It may be simply that there are no other depth cues in the plot to make things more real.
1. I'd like anti-aliased edges. The edges of the plot are hard and not correct coloring wise(do not fade like in real life).
2. Some type of depth perspective where the size changes with depth in to the screen in a meaningful way.
3. Proper coloring of this. Maple seems to handle the lighting correctly but it is far too weak to give the impresson of depth
I think maple essentially does all this(except probably AA, although there is probably a setting somewhere) but it seems they are not properly tweaked for maximum realism. I played with the lighting and projection and it seems to help a little but not much.
Any ideas on how to improve this? Ideally something that doesn't have to be set every plot.
hello everyone,
   INGT.mw
L__d := 100:
L__b := 200:
L__c := L__d+(1/2)*L__b;
200
X := .3;
.3
Error, (in plot) procedure expected, as range contains no plotting variable
`ΔE__g` := 1.155*X+.37*X^2;
.3798
V__0 := .6*`ΔE__g`;
.22788
m__D := 0.67e-1*m[e];
0.67e-1*m[e]
m__B := (0.67e-1+0.83e-1*X)*m[e];
0.919e-1*m[e]
Sol := solve(2*cos(L__d*sqrt(E__x))+(m__D*sqrt((V__0-E__x)/E__x)/m__B-m__B*sqrt(E__x/(V__0-E__x))/m__D)*sin(L__d*sqrt(E__x))-(m__D*sqrt((V__0-E__x)/E__x)/m__B+m__B*sqrt(E__x/(V__0-E__x))/m__D)*sin(L__d*sqrt(E__x))*exp(-sqrt(V__0-E__x)*L__b) = 0, E__x);
0.1110897170e-2, 0.3531161505e-2, -.2585338615+0.9991335677e-27*I
E__1 := 0.1110897170e-2:
K__1 := sqrt(E__1);
0.3333012406e-1
K__2 := sqrt(V__0-E__1);
.4762027959
C := cosh((1/2)*K__2*L__b);
0.2399908351e21
beta := m__D*K__2/(m__B*K__1);
10.41631973
B := -beta*sinh((1/2)*K__2*L__b);
-0.2499821271e22
A := -B*sin(K__1*L__d)+C*cos(K__1*L__d);
-0.7112056933e21
(14)
h := proc (x) options operator, arrow; piecewise(x <= -L__c, A*exp(K__2*(x+L__c)), -L__c < x and x < -(1/2)*L__b, -B*sin(K__1*(x+(1/2)*L__b))+C*cos(K__1*(x+(1/2)*L__b)), abs(x) <= (1/2)*L__b, (1/2)*exp(K__2*x)+(1/2)*exp(-K__2*x), (1/2)*L__b < x and x < L__c, -B*sin(K__1*(x-(1/2)*L__b))+C*cos(K__1*(x-(1/2)*L__b)), L__c <= x, A*exp(K__2*(x-L__c))) end proc:
'h(x)' = h(x);
h(x) = piecewise(x <= -200, -7.112056933*10^20*exp(95.24055918+.4762027959*x), -200 < x and x < -100, 2.499821271*10^21*sin(3.333012406+0.3333012406e-1*x)+2.399908351*10^20*cos(3.333012406+0.3333012406e-1*x), abs(x) <= 100, (1/2)*exp(.4762027959*x)+(1/2)*exp(-.4762027959*x), 100 < x and x < 200, 2.499821271*10^21*sin(0.3333012406e-1*x-3.333012406)+2.399908351*10^20*cos(0.3333012406e-1*x-3.333012406), 200 <= x, -7.112056933*10^20*exp(-95.24055918+.4762027959*x))
(15)
L__y := 200:
L__z := 200:
P := proc (x, y, z) options operator, arrow; h(x)*cos(Pi*y/L__y)*cos(Pi*z/L__z) end proc:
'Psi(x, y, z)' = P(x, y, z);
Psi(x, y, z) = piecewise(x <= -200, -7.112056933*10^20*exp(95.24055918+.4762027959*x), -200 < x and x < -100, 2.499821271*10^21*sin(3.333012406+0.3333012406e-1*x)+2.399908351*10^20*cos(3.333012406+0.3333012406e-1*x), abs(x) <= 100, (1/2)*exp(.4762027959*x)+(1/2)*exp(-.4762027959*x), 100 < x and x < 200, 2.499821271*10^21*sin(0.3333012406e-1*x-3.333012406)+2.399908351*10^20*cos(0.3333012406e-1*x-3.333012406), 200 <= x, -7.112056933*10^20*exp(-95.24055918+.4762027959*x))*cos((1/200)*Pi*y)*cos((1/200)*Pi*z)
(16)
INGT := proc (x__i) `assuming`([evalf(int(int(int(P(x, y, z)^2*exp(-lambda*sqrt((x-x__i)^2+y^2+z^2)), x = -infinity .. infinity), y = -L__y .. L__y), z = -L__z .. L__z))], [0 < lambda]) end proc
evalf(INGT(2))
Download INGT.mw
L__d := 100:
L__b := 200:
200
X := .3;
.3
`&Delta;E__g` := 1.155*X+.37*X^2;
.3798
V__0 := .6*`&Delta;E__g`;
.22788
0.67e-1*m[e]
0.919e-1*m[e]
K__1 := sqrt(E__1);
0.3333012406e-1
.4762027959
0.2399908351e21
10.41631973
-0.2499821271e22
-0.7112056933e21
(14)
'h(x)' = h(x);
(15)
L__y := 200:
L__z := 200:
(16)
evalf(INGT(2))
Download INGT.mw
I'm trying to calculate a triple integral complicated by a procedure that changes each time a variable xi, while the program takes a lot of time and it gives me the message "Warning, computation interrupted". If anyone can help me I will be very happy
Is there something I should be doing whenever I use simplify to avoid things like this, or should I stop using the "is" function all together?
interface(showassumed = 0):
sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1)
(n-k+1)*binomial(n+1, k)/(k+1) = binomial(n+1, k+1)
#And we have:
is(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1))
FAIL
#And since:
is(simplify(convert(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1), 'factorial')))
is(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1)) = is(simplify(convert(sum(binomial(k+j, k), j = 0 .. n-k) = binomial(n+1, k+1), 'factorial')))
Download main.mw
Can I know how to write code about to solve the second kind of linear Fredholm and also Volterra approximation integral by Simpson's method and Galerkin method, and I need a book about advance math to the integral equation, thanks.
  1. Does it have any detail manual for Matlab programming using Maple symbolic engine? (Except help documentation of Maple Symbolic Toolbox in Matlab).
  2. How to maximize the running speed of the codes programmed by Maple symbolic toolbox? Any Notes?
  3. How to use the function 'GenerateMatrix' of Maple in Matlab? What's the syntax to use this function in Matlab?
Best Regards.
Si
I wonder how integrate can be applied term by term to the following nonlinear differential equation
(diff(y(t), t))*(diff(y(t), t, t, t))-(diff(y(t), t))*y(t)^2-(diff(y(t), t))*(diff(y(t), t, t))-(diff(y(t), t))*A*y(t)
The expected output will be something like
(diff(y(t), t))*(diff(y(t), t, t))-(1/3)*y(t)^3-(1/2)*A*y(t)^2-(1/2)*(diff(y(t), t))^2+C+int((diff(y(s), s, s))^2, s = 0 .. t)
map(x-> integrate(x,t),(diff(y(t), t))*(diff(y(t), t, t, t))-(diff(y(t), t))*y(t)^2-(diff(y(t), t))*(diff(y(t), t, t))-(diff(y(t), t))*A*y(t))
solves most of it but not the first part.
Many thanks
Ed
I was attempting to construct  a log question and noticed a problem with the answers that are being resolved by maple.
with(StringTools):
a := 2:
b := 10:
 c := -4:
d := 5:
rs := 4:
#notice I use the word filler below, in order to randomize later and replace "filler" with various "log[base]" or "ln".
equation1 := convert(filler(a*x+b)-filler(c*x+d) = rs, string):
equationAct := parse(SubstituteAll(equation1, filler, cat(ln))):
answer := [solve(equationAct, x)]:
#it appears maple is applying the log properties and suggesting solutions outside the real domain, for the individual log expressions.  The plot of the equation seems to confirm this.
plotA := plot(lhs(equationAct), x = -10 .. 10):
plotB := plot(rhs(equationAct), x = -10 .. 10):
plots[display](plotA, plotB);
NewtonRaphsonSYS:=proc(X,F,X0,TOL,itmax)
local Xn,H,FX,J,i,m,n,Err;
m:=LinearAlgebra[Dimension](Vector(X));
Xn:=Vector(m);
H:=Vector(m);
FX:=Vector(m);
J:=Matrix(m,m);
Xn:=X0;
for n to itmax do
    FX:=eval(F,[seq(X[i]=Xn[i],i=1..m)]);
    J:=evalf(VectorCalculus[Jacobian](F,X=convert(Xn,list)));
H:=-Inverse(J).Vector(FX);
Xn:=Xn+H;
printf("%3d %.8f",n,Xn[1]);
for i from 2 to m do;
 printf("%.8f",Xn[i]);
for i from 1 to m do;
 printf("%.3g",H[i]);
printf("\n");
if (LinearAlgebra[VectorNorm](H,2)<TOL) then break end if;
F:=[xy-z^2-1,xyz+y^2-x^2-2,e^x+z-e^y-3];
X:=[x,y,z];
X0:= <1,1,1>;
TOL:=0.00000001;
itmax:=10;
      [  2             2    2             x        y    ]
      [-z  + xy - 1, -x  + y  + xyz - 2, e  + z - e  - 3]
                           [x, y, z]
                Vector[column](%id = 4442374402)
                                 -8
                             1 10
                               10
NewtonRaphsonSYS(X,F,X0,TOL,itmax);
Maple is not able to simplify x^3+a*x+b) -(y^3+a*y+b) )^2/(x-y)^4   into (x^2 + x*y + y^2 + a)^2/(x - y)^2
wtf
p.s.  how do I get maple to show steps in simplifications
Hello people :)
As the captian says, im trying to remove an old task i've made.
But i get this:
Error in Get, invalid object [_XML_reply_data_get("reference" =
"_Maplets_reference_12","parameter" =
"value",_XML_content("Task,UserTasks,Nyops",&Entity "#xc3",&Enity
"#xa6","tning"))]
And i have no idea what it is, but it won't erase my task :'D
Thanks a bunch in advance!
Have a great weekend you all
Best regards Lucas :)
I am a student of economics writing my thesis. I have an inverse demand function defined:
p[i,j]=1-q[i,j]-αq[i,k]-β(q[h,j]+αq[h,k])
where α,β are scalars, i{1,2,}, j {1,2,3}, h/=i and k/=j.
I wanted to know how do i input this kind of function in the program and how do i calculate the function of q[i,j] (the inverse)
I would like to extract the x and y values from a list containing ordered pairs, [x,y], and display as a list.
For example, given
  A:= [ [4,2], [9,1], [6,8] ]
how can I obtain
 X:=[4,9,6] and Y:=[2,1,8]
using a simple command?
Why is lamba protected as something it traditionally isnt for this package?
lambda(n) = (-1)^Omega(n)
with(numtheory)
[GIgcd, bigomega, cfrac, cfracpol, cyclotomic, divisors, factorEQ, factorset, fermat, imagunit, index, integral_basis, invcfrac, invphi, iscyclotomic, issqrfree, ithrational, jacobi, kronecker, lambda, legendre, mcombine, mersenne, migcdex, minkowski, mipolys, mlog, mobius, mroot, msqrt, nearestp, nthconver, nthdenom, nthnumer, nthpow, order, pdexpand, phi, pi, pprimroot, primroot, quadres, rootsunity, safeprime, sigma, sq2factor, sum2sqr, tau, thue, varphi]
Omega := proc (n) options operator, arrow; bigomega(n) end proc:
numtheory:-lambda(667)
308
Download main.mw
My learning exercise today is the Calkin-Wilf Tree, and the first worksheet I have the issue, due to needing to use a set operator and at that point of computation losing the ordering if it were to be a list (I have tried with a list, and was unsuccessful) none the less my question is, can I alter the ordering condition for Sets in a worksheet produced therein?
I also encountered a strange result that I would appreciate an explaination for as seen below in the uploaded worksheet
https://en.wikipedia.org/wiki/Calkin–Wilf_tree
Q := proc (n) options operator, arrow; (`minus`(map(rhs, solve(`union`(seq({q[0] = 1/2, q[1] = 1, q[i+1] = 1/(2*floor(q[i])-q[i]+1)}, i = 1 .. n)))), map(rhs, solve(`union`(seq({q[0] = 1/2, q[1] = 1, q[i+1] = 1/(2*floor(q[i])-q[i]+1)}, i = 1 .. n-1))))))[] end proc
delta := proc (x, y) options operator, arrow; piecewise(x = y, 1, x <> y, 0) end proc
q[1] := 1
q[2] := 1/2
1/2
q0 := proc (n) options operator, arrow; 1/(2*floor(Q(n)*(1-delta(n, 2))+delta(n, 2)*q[2]+delta(n, 1)*q[1])-Q(n)*(1-delta(n, 2))-delta(n, 2)*q[2]-delta(n, 1)*q[1]+1) end proc
[seq(q0(k), k = 1 .. 20)][1]
1/(2*floor(()+1)+())
Download Q1_MP_08112019.mw
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
First 629 630 631 632 633 634 635 Last Page 631 of 2433
