My maplet
mpt := Maplet(Window("Точка выше или ниже прямой",
[[Plotter[f]()], ["1st vector"],
[TextField[v1](), TextField[v2](), TextField[v5]()],
["2nd vector"],
[TextField[v3](), TextField[v4](), TextField[v6]()], ["Скаляр"],
[TextField[scalar]()], [Button("Add", Evaluate(f = 'work(1)'))],
[[ToggleButton['d2']("2D", 'value' = true, 'group' = 'BG1')],
[ToggleButton['d3']("3D", 'value' = false, 'group' = 'BG1')]]]),
ButtonGroup['BG1']())
Now I choose via toogle button what to plot 2D or 3D addition but I need to plot it in two different plotter, is there a way to do it?
Procedure
with(Maplets);
with(Elements);
with(Tools);
[AddAttribute, AddContent, Get, ListBoxSplit, Parse, Print, Set,
  SetTimeout, StartEngine, StopEngine]
with(LinearAlgebra);
with(Student[LinearAlgebra]);
with(Maplets[Elements]);
work:=proc(g)
     local x1, y1, x2, y2, scalar;z1, z2,d2,d3,u,v,U,V,r1,r2,r3,R1,R2,R3,V1:
 x1 := Get(v1::algebraic);
 y1 := Get(v2::algebraic);
z1 := Get(v5::algebraic);
x2 := Get(v3::algebraic);
y2 := Get(v4::algebraic);
z2 := Get(v6::algebraic);
scalar := Get(scalar::algebraic);
 d2:= Get(d2);
d3:= Get(d3);
 if d2 = true then  u, v:=<x1, y1>, <x2, y2>;
elif d3 = true then   u, v:=<x1, y1,z1>, <x2, y2,z2>;
end if;  U:=arrow(u, color=red):
V:=arrow(u, v, color=black):
   r1:=u+v: r2:=u-v: r3:=ScalarMultiply(u,scalar):r4:=ScalarMultiply(v,scalar):
R1:=arrow(r1, color=red):
 R2:=arrow(v, r2, color=black):
R3:=arrow(r3, color=black):
 R4:=arrow(r4, color=black):
V1:=arrow(v, color=blue):
if g = 1 then return VectorSumPlot(u,v, show=1, caption="Треугольник", vectorcolors=[red,blue]);
Repeat once again what do I need: I want to plot addition of vectors in 2D and 3D in 2 different plotters at once
https://www.maplesoft.com/applications/view.aspx?SID=3938&view=html
i find this example
how to write piano note A and B frequency music to wave file?
how to convert a function to transition matrix?
how to convert a differential system to transition matrix?
Hi everybody and thank you all in advanced.
I tried this:
  1. convert([a,b],`*`) # this worked
  2. convert([a,b],`/`) # this gives an error
  3. map(`/`,a,b) # this worked
Questions:
  1. How can I make code for point (2) work? Apparently `/` is not an option for convert.
  2. I was looking for a function that divide two symbols, something like divide(a,b) and outputs a/b for some simple
  3. programing purposes but find no one. (a,b) could be numbers, could be trig functions or polynomials.
    Of course, you can just input a/b or lis[i]/lis[i+n], but a knowledgeable answer to this will cast light over Maple’s ways and my wrong ways.
Let be the sequence (an) so that a1 = 1, a(n+1) = 5*a(n) + sqrt(k*a(n)^2 -8), for all n >=1. I know that, the answer is k = 24.  How can I choice number k so that the sequence is an integer sequence?
I am trying to export the data list to .dat but i received that error. New with coding and Maple.
a := sin(x^(1/3))+sin(x)^(1/3);
                      / (1/3)\         (1/3)
                   sin\x     / + sin(x)
b := diff(a, x);
                     / (1/3)\
                  cos\x     /      cos(x)
                      (2/3)             (2/3)
                   3 x          3 sin(x)
output := fopen("Ospino.dat", WRITE);
for x by .5 to 50 do fprintf(output, "%f\t %f\t \n", x, b) end do;
Error, (in fprintf) number expected for floating point format
fclose(output);
add(q[k],k=1..5)
I'd like to be able to display a general result such as
q_1 + q_2 + ... + q_n
ideally maple would do all the special stuff for me, e.g., somehow I could do
add(q[k],k=1..2..n)
but I can't even seem to get a nice output manually that doesn't involve a lot of printing code.
Can maple compute the following integral
Integral ( z^(-0.5), z in M) where  M is the lower half-unit circle from +1 to -1
Many thanks
How I can apply the condition or assuming (a>0) in ?
I want to have a plot according to the attached figure.
restart; A5 := 2.4821; A3 := .8417; A4 := -.1384; K := 0.3e-2; `&sigma;&sigma;` := (9*A3*A5*a^2-10*A4^2*a^2)/(24*A3^(3/2))+K/(2*a*A3^(1/2))
2.4821
.8417
-.1384
1.004210973*a^2+0.1634980569e-2/a
solve(sigma = 1.004210973*a^2+0.1634980569e-2/a, a)
solve(sigma = 1.004210973*a^2-0.1634980569e-2/a, a)
plot({1.079801433*10^(-25)*(-6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3)+3.074042610*10^24*sigma/(-6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3), 1.079801433*10^(-25)*(6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3)+3.074042610*10^24*sigma/(6.465854665*10^71+1.058832302*10^46*sqrt(-2.057991547*10^56*sigma^3+3.729044048*10^51))^(1/3)}, sigma = -.2 .. .2)
Download plot
Normally the wheel mouse will scroll a file like it does in just about every other program... but when the mouse is over a code edit region it does nothing ;/ As one is scrolling with the wheel and a code edit region pops up this breaks the flow and requires hoops, I don't like hoops!
Seems most mouse funcitons do not work well in the region. Just trying to select and drag doesn't scroll the region.
I was writing in a maple document when suddently all the text and equations collapsed into a single line at the top, making it unreadable and unusuable. I was not able to restore a previous backup of the file, however i did manage to salvage a smaller part of the document. Both files are included.
corrupted.mw
what_i_managed_to_save.mw
ModularSquareRoot can't handle a really big n because of the factorization problem. But I would like to know if there is any other function than can use as parameters the factorization of n.
I already have an algorithm that does that for n=pq with p, q primers, and could generalize it, but I was wondering whether there was a built-in function that does that.
The Folium of Descartes (see the wikipedia page about this curve) is an algebraic curve defined by the equation 𝑥 ^3 + 𝑦 ^3 − 3𝑎𝑥𝑦 = 0, where 𝑎 is a constant. You will need the information on this wikipedia page in order to plot the following graphs. plot them for 𝑎 = 1,  Graph the curve with 𝑎 = 1 using the command implicitplot in the range of −3 ≤ 𝑥 ≤ 3 and −3 ≤ 𝑦 ≤ 3. (which i have already done)
However i am unable to Add a plot of the line 𝑥 + 𝑦 + 𝑎 = 0 on the same graph but dashed and with a different color (set numpoints as 10000).
Does global optimization toolbox has randomization option it gives same value every time
In addition to defining a function in a standard way, a fast and convenient way to turn a formula (an expression) into a function is to use unapply command (check Maple help center for this command). The following items are about defining functions.
  1. Define a function midpoint, which returns the average of two arguments given on input. For example, midpoint(2,3) returns 2.5, midpoint(a,b) returns 𝑎+𝑏2.
  2. b) For two positive natural numbers 𝑎 and 𝑏 we can define the least common multiple lcm(𝑎,𝑏) via their greatest common divisor gcd (𝑎,𝑏), i.e.: lcm(𝑎,𝑏) = 𝑎𝑏gcd (𝑎,𝑏). When 𝑎 and/or 𝑏 are zero, lcm(𝑎; 𝑏)=0. Use the arrow operator and piecewise to define the function my_lcm which returns the least common multiple of two natural numbers.
  3. c) The quadratic formula allows to write the roots of 𝑝 = 𝑎𝑥2+𝑏𝑥+𝑐 explicitly in terms of 𝑎,𝑏, and 𝑐.
First 632 633 634 635 636 637 638 Last Page 634 of 2433
